  3. Off Topic
  4. Pflege des Betriebssystems
  5. System krumm?
System krumm?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 1 Beobachtet
  • L luft-post
    @thomas-braun ja, das funktioniert
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-09-30 20:40:20 CEST
               Universal time: Tue 2025-09-30 18:40:20 UTC
                     RTC time: Tue 2025-09-30 18:40:20
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.t         arget' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             17G        3.8G         11G         36M        1.5G         13G
    Swap:           536M          0B        536M
    Total:           17G        3.8G         12G
    Active iob-Instances:   31
            16219 M total memory
             3594 M used memory
             3393 M active memory
              913 M inactive memory
            11392 M free memory
              155 M buffer memory
             1231 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
    Tasks: 286 total,   1 running, 285 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  16219.2 total,  11393.0 free,   3594.8 used,   1386.3 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12624.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  7.9G     0  7.9G   0% /dev
    tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
    /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
    tmpfs          tmpfs     8.0G  400K  8.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
    /dev/sda       ext4      234G   28K  222G   1% /backup
    tmpfs          tmpfs     1.6G  176K  1.6G   1% /run/user/1000
    [Tue Sep 30 20:14:12 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory num         a_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_ba         se=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=         yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Tue Sep 30 20:14:13 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Qu         ota mode: none.
    [Tue Sep 30 20:14:14 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
    [Tue Sep 30 20:14:15 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota m         ode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/nvme0n1p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors
    `-/backup            /dev/sda       ext4        rw,noatime,stripe=8191
    /var:
    2.6G    /var/
    1.4G    /var/lib
    1.2G    /var/lib/mysql
    989M    /var/lib/mysql/iobroker
    697M    /var/cache
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    677M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    716M    /opt/iobroker/iobroker-data/
    443M    /opt/iobroker/iobroker-data/files
    148M    /opt/iobroker/iobroker-data/backup-objects
    72M     /opt/iobroker/iobroker-data/files/vis-2
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    72M     /opt/iobroker/iobroker-data/objects.jsonl
    52M     /opt/iobroker/iobroker-data/states.jsonl
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.19.0
    /usr/bin/node           v22.19.0
    /usr/bin/npm            10.9.3
    /usr/bin/npx            10.9.3
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.19.0-1nodesource1
      Candidate: 22.20.0-1nodesource1
      Version table:
         22.20.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
     *** 22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 1564)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     6
    +-- iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
    +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b         271464570809d9a27ecf9)
    +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a7809067872         64e3)
    +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
    +-- iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9         485a372b9a3b56)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081,          bind: 0.0.0.0, run as: admin
      system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
    + system.adapter.alpha2.0                 : alpha2                : raspberrypi                              -  enabled
      system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
      system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
    + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.daswetter.1              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
      system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              - disabled
      system.adapter.fully-tablet-control.0   : fully-tablet-control  : raspberrypi                              - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.homepilot20.0            : homepilot20           : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1885,          bind: 0.0.0.0
      system.adapter.notification-manager.0   : notification-manager  : raspberrypi                              - disabled
      system.adapter.onvif-alt.0              : onvif-alt             : raspberrypi                              - disabled
    + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
      system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
    + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
    + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.siegenia.0               : siegenia              : raspberrypi                              -  enabled
    + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
      system.adapter.smartcontrol.1           : smartcontrol          : raspberrypi                              - disabled
      system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883,          bind: 192.168.2.70
      system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
    + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
    + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088,          bind: 0.0.0.0, run as: admin
      system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
      system.adapter.tradfri.0                : tradfri               : raspberrypi                              - disabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
      system.adapter.weatherunderground.1     : weatherunderground    : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082,          bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/t         tyACM0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alarm"        : 3.7.4    , installed 3.7.4
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "alpha2"       : 1.0.0    , installed 1.0.3
    Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.16.2   , installed 1.16.2
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.4.3
    Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-rc.5
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "ping"         : 1.6.2    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
    Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
    Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
    Objects and States
    Objects:        38379
    States:         29235
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 39
    *** Listening Ports ***
    tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       15443      2395/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5779       795/sshd: /usr/sbin
    tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       11041      1805/io.hm-rpc.0
    tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       14402      1820/io.hm-rpc.1
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8756       762/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8765       762/iobroker.js-con
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8208       761/cupsd
    tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        5829       855/mariadbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5781       795/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8207       761/cupsd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10643      1508/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16265      2854/io.web.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17467      2740/io.terminal.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6363       592/avahi-daemon: r
    udp        0      0 0.0.0.0:42064           0.0.0.0:*                           104        6365       592/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6364       592/avahi-daemon: r
    udp6       0      0 :::40252                :::*                                104        6366       592/avahi-daemon: r
    udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          10567      668/NetworkManager
    2025-09-30 20:36:12.340  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
    2025-09-30 20:36:24.474  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
    2025-09-30 20:36:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 48 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 40 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 46 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 34 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257407830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257407830,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 20:36:48.957  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
    2025-09-30 20:36:49.004  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
    2025-09-30 20:37:01.352  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
    2025-09-30 20:37:13.485  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
    2025-09-30 20:37:25.633  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
    2025-09-30 20:37:25.677  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
    2025-09-30 20:37:37.818  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.2 (ack =          true)
    2025-09-30 20:37:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 49 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 41 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 47 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 35 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257467830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257467830,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 20:38:02.471  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
    2025-09-30 20:38:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 50 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 42 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 48 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 36 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257527830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257527830,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 20:38:51.080  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
    2025-09-30 20:39:03.580  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
    2025-09-30 20:39:15.703  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
    2025-09-30 20:39:27.846  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
    2025-09-30 20:39:39.955  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.6 (ac         k = true)
    2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching Meldung, msg= Gästebadfenste         r seit 8 Std. 8 Min. geöffnet! NoMsgAtPresence= false Presence= true
    2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching WriteMessageLog, Message=Gäs         tebadfenster seit 8 Std. 8 Min. geöffnet!
    2025-09-30 20:39:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 51 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 43 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 49 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 37 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257587830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257587830,"c":"script.js.common.11_FensterUeberwachungOG"})
    2025-09-30 20:39:52.088  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
    2025-09-30 20:40:16.781  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack =          true)
    2025-09-30 20:40:28.904  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack =          true)
    2025-09-30 20:40:47.831  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 52 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 44 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 50 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 38 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257647831,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_FensterUeberwachungOG"})
    iob diag has finished.
    pi@raspberrypi:~ $
    Script v.2025-08-09
    *** BASE SYSTEM ***
           Icon name: computer
        Architecture: arm64
    OS is similar to:
    Docker          : false
    Kernel          : aarch64
    Userland        : 64 bit
    CPU threads: 4
    Current issues:
    iob diag has finished.l here for C&P =============":0,"from":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_Fenster
    @luft-post sagte in Test Adapter SmartControl 0.3.x-0.6.x Latest:
    Your zigbee.0 COM-Port is NOT matchingYour zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: 'by-id'. Please check your setting.
    Pending Updates: 39
    Korrigier das schon mal und nach einem Reboot
    cd /opt/iobroker/ && npm ls
    zeigen.
    • L luft-post
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           536M          0B        536M
      Total:           17G        3.8G         12G
               3594 M used memory
              11392 M free memory
                155 M buffer memory
               1231 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      1.4G    /var/lib
      1.2G    /var/lib/mysql
      697M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        38379
      States:         29235
      Pending Updates: 39
      pi@raspberrypi:~ $
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
      @luft-post
      Und den
      iob fix
      kannste auch mal drüber jagen.
      L 1 Antwort Letzte Antwort
        @luft-post
        Und den
        iob fix
        luft-post
        so, ich denke ich habe alles gemacht. hier die gewünschte Ausgabe. iob fix läuft gerade noch
        pi@raspberrypi:~ $ cd /opt/iobroker/ && npm ls
        iobroker.inst@3.0.0 /opt/iobroker
        ├── @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
        ├── iobroker.admin@7.7.2
        ├── iobroker.alarm@3.7.4
        ├── iobroker.alexa2@3.27.3
        ├── iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
        ├── iobroker.awtrix-light@2.0.0
        ├── iobroker.backitup@3.3.5
        ├── iobroker.birthdays@4.0.0
        ├── iobroker.chromecast@4.0.0
        ├── iobroker.cloud@5.0.1
        ├── iobroker.daswetter@3.2.3
        ├── iobroker.device-reminder@3.1.2
        ├── iobroker.device-watcher@2.13.1
        ├── iobroker.discovery@5.0.0
        ├── iobroker.dwd@2.8.5
        ├── iobroker.email@2.0.4
        ├── iobroker.fb-checkpresence@1.4.0
        ├── iobroker.feiertage@1.2.1
        ├── iobroker.flot@1.12.0
        ├── iobroker.fritzbox@0.6.0
        ├── iobroker.fullcalendar@2.4.5
        ├── iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
        ├── iobroker.fullybrowser@3.1.2
        ├── iobroker.history@3.0.1
        ├── iobroker.hm-rega@5.1.0
        ├── iobroker.hm-rpc@2.0.2
        ├── iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
        ├── iobroker.hue@3.16.2
        ├── iobroker.ical@1.16.2
        ├── iobroker.icons-mfd-png@1.2.1
        ├── iobroker.icons-mfd-svg@1.2.0
        ├── iobroker.iot@3.4.3
        ├── iobroker.jarvis@3.2.0-rc.5
        ├── iobroker.javascript@8.9.2
        ├── iobroker.js-controller@7.0.7
        ├── iobroker.mqtt@6.1.4
        ├── iobroker.notification-manager@1.3.0
        ├── iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
        ├── iobroker.parser@2.2.4
        ├── iobroker.ping@1.7.9
        ├── iobroker.pollenflug@2.0.0
        ├── iobroker.pushover@4.1.0
        ├── iobroker.pushsafer@1.1.0
        ├── iobroker.rpi2@2.4.0
        ├── iobroker.sayit@5.0.0
        ├── iobroker.schoolfree@1.1.12
        ├── iobroker.shuttercontrol@2.0.5
        ├── iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
        ├── iobroker.smartcontrol@2.0.1
        ├── iobroker.sonoff@3.2.1
        ├── iobroker.sonos@3.0.0
        ├── iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
        ├── iobroker.spotify-premium@1.5.2
        ├── iobroker.sql@3.0.1
        ├── iobroker.tankerkoenig@3.4.0
        ├── iobroker.terminal@1.0.0
        ├── iobroker.tr-064@4.3.0
        ├── iobroker.tradfri@3.1.3
        ├── iobroker.tuya@3.16.0
        ├── iobroker.vis-2@2.13.4
        ├── iobroker.vis-bars@0.1.4
        ├── iobroker.vis-canvas-gauges@1.0.1
        ├── iobroker.vis-fancyswitch@1.1.0
        ├── iobroker.vis-history@1.0.0
        ├── iobroker.vis-hqwidgets@1.5.1
        ├── iobroker.vis-icontwo@1.18.0
        ├── iobroker.vis-inventwo@3.3.5
        ├── iobroker.vis-jqui-mfd@1.1.1
        ├── iobroker.vis-justgage@2.1.7
        ├── iobroker.vis-keyboard@0.0.2
        ├── iobroker.vis-map@1.1.2
        ├── iobroker.vis-material-advanced@1.7.4
        ├── iobroker.vis-materialdesign@0.5.9
        ├── iobroker.vis-metro@1.2.0
        ├── iobroker.vis-rgraph@0.0.2
        ├── iobroker.vis-timeandweather@1.2.2
        ├── iobroker.vis@1.5.6
        ├── iobroker.weatherunderground@3.7.0
        ├── iobroker.web@7.0.8
        ├── iobroker.whatsapp-cmb@0.3.0
        ├── iobroker.wifilight@2.0.3
        └── iobroker.zigbee@3.0.5
        • L luft-post
          luft-post
          @luft-post
          Fehler steht leider immer noch an
          • L luft-post
            @luft-post
            luft-post
            hier noch mal der aktuelle iob diag
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
                   Icon name: computer
                      Kernel: Linux 6.12.47+rpt-rpi-2712
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
            CPU threads: 4
            Current issues:
                           Local time: Tue 2025-09-30 21:10:53 CEST
                       Universal time: Tue 2025-09-30 19:10:53 UTC
                             RTC time: Tue 2025-09-30 19:10:53
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Display-Server:         false
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:             17G        3.4G         12G         14M        1.4G         13G
            Swap:           536M          0B        536M
            Total:           17G        3.4G         12G
                     3286 M used memory
                     2981 M active memory
                      869 M inactive memory
                    11710 M free memory
                      196 M buffer memory
                     1159 M swap cache
                      511 M total swap
                        0 M used swap
                      511 M free swap
            top - 21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
            Tasks: 230 total,   1 running, 229 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  16219.1 total,  11710.8 free,   3286.4 used,   1356.2 buff/cache
            MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12932.7 avail Mem
            *** FILESYSTEM ***
            tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
            tmpfs          tmpfs     8.0G   32K  8.0G   1% /dev/shm
            tmpfs          tmpfs     1.6G  160K  1.6G   1% /run/user/1000
            [Tue Sep 30 21:00:25 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
            [Tue Sep 30 21:00:26 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
            [Tue Sep 30 21:00:27 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
            [Tue Sep 30 21:00:28 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota mode: none.
            |-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            2.6G    /var/
            1.4G    /var/lib
            1.2G    /var/lib/mysql
            698M    /var/cache
            639M    /opt/iobroker/iobroker-data/
            34M     /opt/iobroker/iobroker-data/objects.jsonl
            13M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/nodejs         v22.20.0
            /usr/bin/node           v22.20.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            nodejs:
              Installed: 22.20.0-1nodesource1
              Version table:
             *** 22.20.0-1nodesource1 1001
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 242)
            admin:          7.7.2
            javascript:     8.9.2
            +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
            +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
            +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
            Adapter State
            + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
            + instance is alive
            Objects and States
            Objects:        38379
            States:         29244
            Pending Updates: 0
            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        6119       831/mariadbd
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6496       772/sshd: /usr/sbin
            tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       22046      3523/io.sonoff.0
            tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       20727      3371/io.hm-rpc.1
            tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       20699      3356/io.hm-rpc.0
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6010       742/cupsd
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16255      3066/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17358      3066/iobroker.js-co
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6009       742/cupsd
            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22859      3726/io.terminal.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23579      3834/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18649      3091/io.admin.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          6498       772/sshd: /usr/sbin
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7953       591/avahi-daemon: r
            udp        0      0 0.0.0.0:54916           0.0.0.0:*                           104        7955       591/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        7954       591/avahi-daemon: r
            udp6       0      0 :::47089                :::*                                104        7956       591/avahi-daemon: r
            udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          6708       660/NetworkManager
            2025-09-30 21:09:05.362  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
            2025-09-30 21:09:05.984  - info: host.raspberrypi instance system.adapter.web.0 in version "7.0.8" started with pid 3834
            2025-09-30 21:09:06.444  - info: admin.0 (3091) ==> Connected system.user.admin from ::ffff:192.168.2.211
            2025-09-30 21:09:09.341  - info: web.0 (3834) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
            2025-09-30 21:09:09.645  - info: web.0 (3834) socket.io server listening on port 8082
            2025-09-30 21:09:09.649  - info: web.0 (3834) http server listening on port 8082
            2025-09-30 21:09:11.072  - info: daswetter.0 (3597) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-09-30 21:09:11.583  - info: daswetter.0 (3597) cleaned everything up...
            2025-09-30 21:09:11.715  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-09-30 21:09:11.872  - info: daswetter.1 (3614) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-09-30 21:09:12.377  - info: daswetter.1 (3614) cleaned everything up...
            2025-09-30 21:09:12.504  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-09-30 21:09:12.508  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack = true)
            2025-09-30 21:09:12.548  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.7 (ack = true)
            2025-09-30 21:09:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 12 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 18 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 7 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259354853,"q":0,"from":"system.adapter.javascript.0","lc":1759259354853,"c":"script.js.common.11_FensterUeberwachungOG"})
            2025-09-30 21:09:16.312  - debug: smartcontrol.0 (3707) [_asyncOnMessage] command 'Verify Adapter Configuration' received from admin/index_m.html. Verifying the configuration and sending the result back to index_m.html...
            2025-09-30 21:09:16.356  - debug: smartcontrol.0 (3707) [_asyncOnMessage] Configuration verification failed, 4 issue(s) found.
            2025-09-30 21:09:24.520  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
            2025-09-30 21:09:24.561  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.8 (ack = true)
            2025-09-30 21:10:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 21 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 13 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 19 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 8 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259414853,"q":0,"from":"system.adapter.javascript.0","lc":1759259414853,"c":"script.js.common.11_FensterUeberwachungOG"})
            2025-09-30 21:10:37.869  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
            2025-09-30 21:10:50.009  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
            2025-09-30 21:11:02.518  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
            2025-09-30 21:11:14.687  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
            2025-09-30 21:11:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 22 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 14 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 9 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259474853,"q":0,"from":"system.adapter.javascript.0","lc":1759259474853,"c":"script.js.common.11_FensterUeberwachungOG"})
            pi@raspberrypi:/opt/iobroker $
            • L luft-post
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
               Static hostname: raspberrypi
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.1
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              *** TIME AND TIMEZONES ***
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
              iobroker
              HOME=/home/iobroker
              *** DISPLAY-SERVER SETUP ***
              Display-Manager:        * lightdm.service - Light Display Manager
              Desktop:
              Session:                tty
              *** MEMORY ***
              Swap:           536M          0B        536M
              Total:           17G        3.4G         12G
              Active iob-Instances:   31
                      16219 M total memory
                       3286 M used memory
                      11710 M free memory
                        196 M buffer memory
                       1159 M swap cache
                        511 M total swap
                          0 M used swap
                        511 M free swap
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  7.9G     0  7.9G   0% /dev
              /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
              /dev/sda       ext4      234G   28K  222G   1% /backup
              /var:
              2.6G    /var/
              1.4G    /var/lib
              1.2G    /var/lib/mysql
              698M    /var/cache
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        38379
              States:         29244
              Pending Updates: 0
              @luft-post
              Funktioniert jetzt der Aufruf von
              iob diag
              wieder auf direktem Weg?
                @luft-post
                iob diag
                luft-post
                @thomas-braun ja
                • L luft-post
                  @thomas-braun ja
                  @luft-post
                  Gut, dann sind deine verfummelten Rechte jetzt wieder gerade.
                  NICHT als iobroker einloggen, NICHT als root einloggen.
                  Du zerballerst dir damit sonst die Rechte.
                  Und nachdem deine Kiste jetzt wieder senkrecht ist schaut dein Problem mit dem Adapter genau wie aus?
                  HomoranH L 2 Antworten Letzte Antwort
                    ich hab den Teil mal abgetrennt und aus Tester hierher geschoben
                      @luft-post
                      @thomas-braun sagte in System krumm?:
                      dann bitte wieder im Original Thread weitermachen!
                        luft-post
                        @homoran ok vielen Dank
