  3. Off Topic
  4. Pflege des Betriebssystems
  5. System krumm?
System krumm?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
27 Beiträge 4 Kommentatoren 2.9k Aufrufe 1 Beobachtet
    @luft-post sagte in Test Adapter SmartControl 0.3.x-0.6.x Latest:
    keine direkte Ausgabe bei "iob diag"
    sondern?
    luft-post
    bei Eingabe kommt nix
    komme nur mit Strg+C wieder raus
    • L luft-post
      @luft-post
      Ruf das mal so auf:
      curl -L -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
      L 1 Antwort Letzte Antwort
      • L luft-post
        @thomas-braun ja, das funktioniert
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.34+rpt-rpi-2712
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 5 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-09-30 20:40:20 CEST
                   Universal time: Tue 2025-09-30 18:40:20 UTC
                         RTC time: Tue 2025-09-30 18:40:20
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         true
        Display-Manager:        * lightdm.service - Light Display Manager
        Desktop:
        Session:                tty
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.t         arget' or run 'iobroker fix'
        *** MEMORY ***
        Mem:             17G        3.8G         11G         36M        1.5G         13G
        Swap:           536M          0B        536M
        Total:           17G        3.8G         12G
        Active iob-Instances:   31
                16219 M total memory
                 3594 M used memory
                 3393 M active memory
                  913 M inactive memory
                11392 M free memory
                  155 M buffer memory
                 1231 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 20:40:20 up 26 min,  3 users,  load average: 0.69, 0.61, 0.46
        Tasks: 286 total,   1 running, 285 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :  16219.2 total,  11393.0 free,   3594.8 used,   1386.3 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12624.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  7.9G     0  7.9G   0% /dev
        tmpfs          tmpfs     1.6G   15M  1.6G   1% /run
        /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
        tmpfs          tmpfs     8.0G  400K  8.0G   1% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
        /dev/sda       ext4      234G   28K  222G   1% /backup
        tmpfs          tmpfs     1.6G  176K  1.6G   1% /run/user/1000
        [Tue Sep 30 20:14:12 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory num         a_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_ba         se=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=         yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Tue Sep 30 20:14:13 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Qu         ota mode: none.
        [Tue Sep 30 20:14:14 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
        [Tue Sep 30 20:14:15 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota m         ode: none.
        Show mounted filesystems:
        TARGET               SOURCE         FSTYPE      OPTIONS
        /                    /dev/nvme0n1p2 ext4        rw,noatime
        |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/boot/firmware     /dev/nvme0n1p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors
        `-/backup            /dev/sda       ext4        rw,noatime,stripe=8191
        /var:
        2.6G    /var/
        1.4G    /var/lib
        1.2G    /var/lib/mysql
        989M    /var/lib/mysql/iobroker
        697M    /var/cache
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        677M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        716M    /opt/iobroker/iobroker-data/
        443M    /opt/iobroker/iobroker-data/files
        148M    /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/files/vis-2
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        72M     /opt/iobroker/iobroker-data/objects.jsonl
        52M     /opt/iobroker/iobroker-data/states.jsonl
        30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
        *** ZigBee Settings ***
        HINT:
        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
        /dev/ttyACM0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.19.0
        /usr/bin/node           v22.19.0
        /usr/bin/npm            10.9.3
        /usr/bin/npx            10.9.3
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.19.0-1nodesource1
          Candidate: 22.20.0-1nodesource1
          Version table:
             22.20.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         *** 22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 1564)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.2
        javascript:     8.9.2
        nodejs modules from github:     6
        +-- iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
        +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b         271464570809d9a27ecf9)
        +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a7809067872         64e3)
        +-- iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
        +-- iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
        +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9         485a372b9a3b56)
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081,          bind: 0.0.0.0, run as: admin
          system.adapter.alarm.0                  : alarm                 : raspberrypi                              - disabled
        + system.adapter.alpha2.0                 : alpha2                : raspberrypi                              -  enabled
          system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              - disabled
          system.adapter.birthdays.0              : birthdays             : raspberrypi                              -  enabled
          system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
          system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          system.adapter.daswetter.1              : daswetter             : raspberrypi                              -  enabled
        + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
        + system.adapter.device-watcher.0         : device-watcher        : raspberrypi                              -  enabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
          system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
        + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
          system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
          system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
          system.adapter.fullcalendar.0           : fullcalendar          : raspberrypi                              - disabled
          system.adapter.fully-tablet-control.0   : fully-tablet-control  : raspberrypi                              - disabled
          system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              - disabled
        + system.adapter.history.0                : history               : raspberrypi                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        + system.adapter.homepilot20.0            : homepilot20           : raspberrypi                              -  enabled
        + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          system.adapter.jarvis.0                 : jarvis                : raspberrypi                              - disabled
          system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1885,          bind: 0.0.0.0
          system.adapter.notification-manager.0   : notification-manager  : raspberrypi                              - disabled
          system.adapter.onvif-alt.0              : onvif-alt             : raspberrypi                              - disabled
        + system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              - disabled
          system.adapter.pushover.0               : pushover              : raspberrypi                              - disabled
        + system.adapter.pushsafer.0              : pushsafer             : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
        + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
          system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
          system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
        + system.adapter.siegenia.0               : siegenia              : raspberrypi                              -  enabled
        + system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              -  enabled
          system.adapter.smartcontrol.1           : smartcontrol          : raspberrypi                              - disabled
          system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
        + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883,          bind: 192.168.2.70
          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
          system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
          system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
        + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
          system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
        + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088,          bind: 0.0.0.0, run as: admin
          system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
          system.adapter.tradfri.0                : tradfri               : raspberrypi                              - disabled
          system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
        + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi                              - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi                              - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
          system.adapter.vis-material-webfont.0   : vis-material-webfont  : raspberrypi                              - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
          system.adapter.weatherunderground.1     : weatherunderground    : raspberrypi                              - disabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082,          bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
          system.adapter.wifilight.0              : wifilight             : raspberrypi                              - disabled
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/t         tyACM0
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Adapters
        Adapter    "admin"        : 7.7.2    , installed 7.7.2
        Adapter    "alarm"        : 3.7.4    , installed 3.7.4
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "alpha2"       : 1.0.0    , installed 1.0.3
        Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
        Adapter    "device-reminder": 3.1.2  , installed 3.1.2
        Adapter    "device-watcher": 2.13.1  , installed 2.13.1
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hue"          : 3.16.2   , installed 3.16.2
        Adapter    "ical"         : 1.16.2   , installed 1.16.2
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
        Adapter    "iot"          : 3.3.0    , installed 3.4.3
        Adapter    "jarvis"       : 3.1.8    , installed 3.2.0-rc.5
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "notification-manager": 1.3.0, installed 1.3.0
        Adapter    "parser"       : 2.2.4    , installed 2.2.4
        Adapter    "ping"         : 1.6.2    , installed 1.7.9
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "schoolfree"   : 1.1.12   , installed 1.1.12
        Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
        Adapter    "siegenia"     : 1.1.1    , installed 1.1.1
        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
        Adapter    "socketio"     : 6.7.1    , installed 7.0.8
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "terminal"     : 1.0.0    , installed 1.0.0
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
        Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
        Adapter    "ws"           : 2.6.2    , installed 3.0.19
        Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
        Objects and States
        Objects:        38379
        States:         29235
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists... Done
        Pending Updates: 39
        *** Listening Ports ***
        tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       15443      2395/io.sonoff.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5779       795/sshd: /usr/sbin
        tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       11041      1805/io.hm-rpc.0
        tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       14402      1820/io.hm-rpc.1
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8756       762/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8765       762/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          8208       761/cupsd
        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        5829       855/mariadbd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          5781       795/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          8207       761/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10643      1508/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       16265      2854/io.web.0
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17467      2740/io.terminal.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6363       592/avahi-daemon: r
        udp        0      0 0.0.0.0:42064           0.0.0.0:*                           104        6365       592/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        6364       592/avahi-daemon: r
        udp6       0      0 :::40252                :::*                                104        6366       592/avahi-daemon: r
        udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          10567      668/NetworkManager
        2025-09-30 20:36:12.340  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
        2025-09-30 20:36:24.474  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
        2025-09-30 20:36:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 48 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 40 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 46 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 34 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257407830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257407830,"c":"script.js.common.11_FensterUeberwachungOG"})
        2025-09-30 20:36:48.957  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
        2025-09-30 20:36:49.004  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
        2025-09-30 20:37:01.352  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
        2025-09-30 20:37:13.485  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
        2025-09-30 20:37:25.633  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
        2025-09-30 20:37:25.677  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.4 (ac         k = true)
        2025-09-30 20:37:37.818  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.2 (ack =          true)
        2025-09-30 20:37:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 49 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 41 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 47 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 35 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257467830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257467830,"c":"script.js.common.11_FensterUeberwachungOG"})
        2025-09-30 20:38:02.471  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45.1 (ack =          true)
        2025-09-30 20:38:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 50 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 42 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 48 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 36 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257527830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257527830,"c":"script.js.common.11_FensterUeberwachungOG"})
        2025-09-30 20:38:51.080  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
        2025-09-30 20:39:03.580  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.5 (ac         k = true)
        2025-09-30 20:39:15.703  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
        2025-09-30 20:39:27.846  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 45 (ack = t         rue)
        2025-09-30 20:39:39.955  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.6 (ac         k = true)
        2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching Meldung, msg= Gästebadfenste         r seit 8 Std. 8 Min. geöffnet! NoMsgAtPresence= false Presence= true
        2025-09-30 20:39:47.804  - info: javascript.0 (1605) script.js.common.10_FensterUeberwachungEG: Reaching WriteMessageLog, Message=Gäs         tebadfenster seit 8 Std. 8 Min. geöffnet!
        2025-09-30 20:39:47.830  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 51 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 43 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 49 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 37 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257587830,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257587830,"c":"script.js.common.11_FensterUeberwachungOG"})
        2025-09-30 20:39:52.088  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack =          true)
        2025-09-30 20:40:16.781  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack =          true)
        2025-09-30 20:40:28.904  - info: siegenia.0 (2375) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack =          true)
        2025-09-30 20:40:47.831  - info: javascript.0 (1605) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.Fenst         erUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td          style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></tabl         e><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' sty         le='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr>         <td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(         1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right         : 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black         ; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszi         mmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 13 Std. 52 Min.<br></div></td></tr><tr><td colsp         an='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); heigh         t: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; f         ont-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding         -left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style=         'font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 14 Std. 44 Min.<br></div></td></tr><tr><td colspan='2' style='border         : 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/ico         ns-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-         weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding         -right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-siz         e:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 3 Std. 50 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px sol         id black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-sv         g/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: b         old; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 1         0px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; fon         t-weight:normal;'>Fenster geschlossen: 13 Std. 38 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759257647831,"q":0,"from         ":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_FensterUeberwachungOG"})
        iob diag has finished.
        pi@raspberrypi:~ $
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
        iob diag has finished.l here for C&P =============":0,"from":"system.adapter.javascript.0","lc":1759257647831,"c":"script.js.common.11_Fenster
        Your zigbee.0 COM-Port is NOT matchingYour zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: 'by-id'. Please check your setting.
        Pending Updates: 39
        Korrigier das schon mal und nach einem Reboot
        cd /opt/iobroker/ && npm ls
        zeigen.
        • L luft-post
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           536M          0B        536M
          Total:           17G        3.8G         12G
                   3594 M used memory
                  11392 M free memory
                    155 M buffer memory
                   1231 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          *** FILESYSTEM ***
          /var:
          2.6G    /var/
          1.4G    /var/lib
          1.2G    /var/lib/mysql
          697M    /var/cache
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.2
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        38379
          States:         29235
          Pending Updates: 39
          pi@raspberrypi:~ $
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
          @luft-post
          Und den
          iob fix
          kannste auch mal drüber jagen.
            @luft-post
            Und den
            iob fix
            luft-post
            so, ich denke ich habe alles gemacht. hier die gewünschte Ausgabe. iob fix läuft gerade noch
            pi@raspberrypi:~ $ cd /opt/iobroker/ && npm ls
            iobroker.inst@3.0.0 /opt/iobroker
            ├── @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
            ├── iobroker.admin@7.7.2
            ├── iobroker.alarm@3.7.4
            ├── iobroker.alexa2@3.27.3
            ├── iobroker.alpha2@1.0.3 (git+ssh://git@github.com/Eisbaeeer/ioBroker.alpha2.git#803bd6302dca3e4b44164d23e58a8a096e21e972)
            ├── iobroker.awtrix-light@2.0.0
            ├── iobroker.backitup@3.3.5
            ├── iobroker.birthdays@4.0.0
            ├── iobroker.chromecast@4.0.0
            ├── iobroker.cloud@5.0.1
            ├── iobroker.daswetter@3.2.3
            ├── iobroker.device-reminder@3.1.2
            ├── iobroker.device-watcher@2.13.1
            ├── iobroker.discovery@5.0.0
            ├── iobroker.dwd@2.8.5
            ├── iobroker.email@2.0.4
            ├── iobroker.fb-checkpresence@1.4.0
            ├── iobroker.feiertage@1.2.1
            ├── iobroker.flot@1.12.0
            ├── iobroker.fritzbox@0.6.0
            ├── iobroker.fullcalendar@2.4.5
            ├── iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
            ├── iobroker.fullybrowser@3.1.2
            ├── iobroker.history@3.0.1
            ├── iobroker.hm-rega@5.1.0
            ├── iobroker.hm-rpc@2.0.2
            ├── iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
            ├── iobroker.hue@3.16.2
            ├── iobroker.ical@1.16.2
            ├── iobroker.icons-mfd-png@1.2.1
            ├── iobroker.icons-mfd-svg@1.2.0
            ├── iobroker.iot@3.4.3
            ├── iobroker.jarvis@3.2.0-rc.5
            ├── iobroker.javascript@8.9.2
            ├── iobroker.js-controller@7.0.7
            ├── iobroker.mqtt@6.1.4
            ├── iobroker.notification-manager@1.3.0
            ├── iobroker.onvif-alt@0.2.0 (git+ssh://git@github.com/Jey-Cee/iobroker.onvif-alt.git#7cd1174688b599cad552d2c6881cd1b6684f99a9)
            ├── iobroker.parser@2.2.4
            ├── iobroker.ping@1.7.9
            ├── iobroker.pollenflug@2.0.0
            ├── iobroker.pushover@4.1.0
            ├── iobroker.pushsafer@1.1.0
            ├── iobroker.rpi2@2.4.0
            ├── iobroker.sayit@5.0.0
            ├── iobroker.schoolfree@1.1.12
            ├── iobroker.shuttercontrol@2.0.5
            ├── iobroker.siegenia@1.1.1 (git+ssh://git@github.com/Apollon77/ioBroker.siegenia.git#b071bc8a25c04204898575d6a2f7e8aef03d2af7)
            ├── iobroker.smartcontrol@2.0.1
            ├── iobroker.sonoff@3.2.1
            ├── iobroker.sonos@3.0.0
            ├── iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
            ├── iobroker.spotify-premium@1.5.2
            ├── iobroker.sql@3.0.1
            ├── iobroker.tankerkoenig@3.4.0
            ├── iobroker.terminal@1.0.0
            ├── iobroker.tr-064@4.3.0
            ├── iobroker.tradfri@3.1.3
            ├── iobroker.tuya@3.16.0
            ├── iobroker.vis-2@2.13.4
            ├── iobroker.vis-bars@0.1.4
            ├── iobroker.vis-canvas-gauges@1.0.1
            ├── iobroker.vis-fancyswitch@1.1.0
            ├── iobroker.vis-history@1.0.0
            ├── iobroker.vis-hqwidgets@1.5.1
            ├── iobroker.vis-icontwo@1.18.0
            ├── iobroker.vis-inventwo@3.3.5
            ├── iobroker.vis-jqui-mfd@1.1.1
            ├── iobroker.vis-justgage@2.1.7
            ├── iobroker.vis-keyboard@0.0.2
            ├── iobroker.vis-map@1.1.2
            ├── iobroker.vis-material-advanced@1.7.4
            ├── iobroker.vis-materialdesign@0.5.9
            ├── iobroker.vis-metro@1.2.0
            ├── iobroker.vis-rgraph@0.0.2
            ├── iobroker.vis-timeandweather@1.2.2
            ├── iobroker.vis@1.5.6
            ├── iobroker.weatherunderground@3.7.0
            ├── iobroker.web@7.0.8
            ├── iobroker.whatsapp-cmb@0.3.0
            ├── iobroker.wifilight@2.0.3
            └── iobroker.zigbee@3.0.5
            • L luft-post
              luft-post
              @luft-post
              Fehler steht leider immer noch an
              • L luft-post
                @luft-post
                luft-post
                hier noch mal der aktuelle iob diag
                ```bash
                Script v.2025-08-09
                *** BASE SYSTEM ***
                       Icon name: computer
                          Kernel: Linux 6.12.47+rpt-rpi-2712
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
                CPU threads: 4
                Current issues:
                               Local time: Tue 2025-09-30 21:10:53 CEST
                           Universal time: Tue 2025-09-30 19:10:53 UTC
                                 RTC time: Tue 2025-09-30 19:10:53
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Display-Server:         false
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:             17G        3.4G         12G         14M        1.4G         13G
                Swap:           536M          0B        536M
                Total:           17G        3.4G         12G
                         3286 M used memory
                         2981 M active memory
                          869 M inactive memory
                        11710 M free memory
                          196 M buffer memory
                         1159 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                top - 21:10:53 up 10 min,  2 users,  load average: 1.06, 1.08, 0.64
                Tasks: 230 total,   1 running, 229 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :  16219.1 total,  11710.8 free,   3286.4 used,   1356.2 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12932.7 avail Mem
                *** FILESYSTEM ***
                tmpfs          tmpfs     1.6G   14M  1.6G   1% /run
                tmpfs          tmpfs     8.0G   32K  8.0G   1% /dev/shm
                tmpfs          tmpfs     1.6G  160K  1.6G   1% /run/user/1000
                [Tue Sep 30 21:00:25 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=88:A2:9E:1C:3B:23 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=541a5899-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                [Tue Sep 30 21:00:26 2025] EXT4-fs (nvme0n1p2): mounted filesystem d6ecfcd5-2703-41bf-9301-10c403b6fb0c ro with ordered data mode. Quota mode: none.
                [Tue Sep 30 21:00:27 2025] EXT4-fs (nvme0n1p2): re-mounted d6ecfcd5-2703-41bf-9301-10c403b6fb0c r/w.
                [Tue Sep 30 21:00:28 2025] EXT4-fs (sda): mounted filesystem 99c4331b-c542-48d4-9081-700cecce1b69 r/w with ordered data mode. Quota mode: none.
                |-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                2.6G    /var/
                1.4G    /var/lib
                1.2G    /var/lib/mysql
                698M    /var/cache
                639M    /opt/iobroker/iobroker-data/
                34M     /opt/iobroker/iobroker-data/objects.jsonl
                13M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/nodejs         v22.20.0
                /usr/bin/node           v22.20.0
                /usr/bin/npm            10.9.3
                /usr/bin/npx            10.9.3
                nodejs:
                  Installed: 22.20.0-1nodesource1
                  Version table:
                 *** 22.20.0-1nodesource1 1001
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 242)
                admin:          7.7.2
                javascript:     8.9.2
                +-- iobroker.fully-tablet-control@0.3.0-beta.5 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#a9a607c702141a6568b271464570809d9a27ecf9)
                +-- iobroker.homepilot20@0.0.31 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#201286583714176646bfa1030a780906787264e3)
                +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#38686d69a56249fda3acbcfae9485a372b9a3b56)
                Adapter State
                + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231009140255-if00
                + instance is alive
                Objects and States
                Objects:        38379
                States:         29244
                Pending Updates: 0
                tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      112        6119       831/mariadbd
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6496       772/sshd: /usr/sbin
                tcp        0      0 192.168.2.70:1883       0.0.0.0:*               LISTEN      1001       22046      3523/io.sonoff.0
                tcp        0      0 192.168.2.70:42001      0.0.0.0:*               LISTEN      1001       20727      3371/io.hm-rpc.1
                tcp        0      0 192.168.2.70:42010      0.0.0.0:*               LISTEN      1001       20699      3356/io.hm-rpc.0
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          6010       742/cupsd
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16255      3066/iobroker.js-co
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17358      3066/iobroker.js-co
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          6009       742/cupsd
                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22859      3726/io.terminal.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23579      3834/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18649      3091/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          6498       772/sshd: /usr/sbin
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7953       591/avahi-daemon: r
                udp        0      0 0.0.0.0:54916           0.0.0.0:*                           104        7955       591/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        7954       591/avahi-daemon: r
                udp6       0      0 :::47089                :::*                                104        7956       591/avahi-daemon: r
                udp6       0      0 fe80::ba24:34b9:1b1:546 :::*                                0          6708       660/NetworkManager
                2025-09-30 21:09:05.362  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
                2025-09-30 21:09:05.984  - info: host.raspberrypi instance system.adapter.web.0 in version "7.0.8" started with pid 3834
                2025-09-30 21:09:06.444  - info: admin.0 (3091) ==> Connected system.user.admin from ::ffff:192.168.2.211
                2025-09-30 21:09:09.341  - info: web.0 (3834) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
                2025-09-30 21:09:09.645  - info: web.0 (3834) socket.io server listening on port 8082
                2025-09-30 21:09:09.649  - info: web.0 (3834) http server listening on port 8082
                2025-09-30 21:09:11.072  - info: daswetter.0 (3597) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2025-09-30 21:09:11.583  - info: daswetter.0 (3597) cleaned everything up...
                2025-09-30 21:09:11.715  - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-09-30 21:09:11.872  - info: daswetter.1 (3614) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2025-09-30 21:09:12.377  - info: daswetter.1 (3614) cleaned everything up...
                2025-09-30 21:09:12.504  - info: host.raspberrypi instance system.adapter.daswetter.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-09-30 21:09:12.508  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.9 (ack = true)
                2025-09-30 21:09:12.548  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.7 (ack = true)
                2025-09-30 21:09:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 12 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 18 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 7 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259354853,"q":0,"from":"system.adapter.javascript.0","lc":1759259354853,"c":"script.js.common.11_FensterUeberwachungOG"})
                2025-09-30 21:09:16.312  - debug: smartcontrol.0 (3707) [_asyncOnMessage] command 'Verify Adapter Configuration' received from admin/index_m.html. Verifying the configuration and sending the result back to index_m.html...
                2025-09-30 21:09:16.356  - debug: smartcontrol.0 (3707) [_asyncOnMessage] Configuration verification failed, 4 issue(s) found.
                2025-09-30 21:09:24.520  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
                2025-09-30 21:09:24.561  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.temperature.indoor changed: 25.8 (ack = true)
                2025-09-30 21:10:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 21 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 13 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 19 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 8 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259414853,"q":0,"from":"system.adapter.javascript.0","lc":1759259414853,"c":"script.js.common.11_FensterUeberwachungOG"})
                2025-09-30 21:10:37.869  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
                2025-09-30 21:10:50.009  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
                2025-09-30 21:11:02.518  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.7 (ack = true)
                2025-09-30 21:11:14.687  - info: siegenia.0 (3502) state siegenia.0.192_168_2_150.params.airbase.humidity.indoor changed: 44.8 (ack = true)
                2025-09-30 21:11:14.853  - info: javascript.0 (3176) script.js.common.11_FensterUeberwachungOG: setForeignState(id=javascript.0.FensterUeberwachungOG.OverviewTable, state={"val":"<table style='width:100%; border-collapse: collapse; border: 0px solid black;'><tr><td style='height: 20px; text-align:center; padding-top: 5px; padding-bottom: 5px; font-size:14px; font-weight: normal;'></td></tr></table><table style='width:100%; border-collapse: collapse;'><thead><tr><th width='40px' style='text-align:left;'</th><th width='40px' style='text-align:left;'</th><th width='20px' style='text-align:center;'></th><th style='text-align:left;'></th></tr></thead><tbody><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Arbeitszimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 6 Tage 14 Std. 22 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Bad<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 1 Tag 15 Std. 14 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Kinderzimmer 1<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 9 Tage 4 Std. 20 Min.<br></div></td></tr><tr><td colspan='2' style='border: 1px solid black; background-color:#4caf50;'><img style=' margin: auto; display: block; filter: invert(1); height: 40px;'  src='/icons-mfd-svg/fts_window_1w.svg'></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; font-size:16px; font-weight: bold; text-align:center; background-color:#4caf50;'>0<br></td><td style='border: 1px solid black; padding-left: 10px; padding-right: 10px; padding-top: 4px; font-size: 16px; font-weight: bold; background-color:#4caf50;'>Schlafzimmer<br><div style='font-size:12px; font-weight:normal;'>Fenster geschlossen: 14 Std. 9 Min.<br></div></td></tr></tbody></table>","ack":true,"ts":1759259474853,"q":0,"from":"system.adapter.javascript.0","lc":1759259474853,"c":"script.js.common.11_FensterUeberwachungOG"})
                pi@raspberrypi:/opt/iobroker $
                • L luft-post
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 5 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** TIME AND TIMEZONES ***
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  pi
                  HOME=/home/pi
                  GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi systemd-journal iobroker
                  iobroker
                  HOME=/home/iobroker
                  *** DISPLAY-SERVER SETUP ***
                  Display-Manager:        * lightdm.service - Light Display Manager
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           536M          0B        536M
                  Total:           17G        3.4G         12G
                  Active iob-Instances:   31
                          16219 M total memory
                           3286 M used memory
                          11710 M free memory
                            196 M buffer memory
                           1159 M swap cache
                            511 M total swap
                              0 M used swap
                            511 M free swap
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  7.9G     0  7.9G   0% /dev
                  /dev/nvme0n1p2 ext4      117G   12G  100G  11% /
                  tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                  /dev/nvme0n1p1 vfat      510M   69M  442M  14% /boot/firmware
                  /dev/sda       ext4      234G   28K  222G   1% /backup
                  /var:
                  2.6G    /var/
                  1.4G    /var/lib
                  1.2G    /var/lib/mysql
                  698M    /var/cache
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.9.3
                  /usr/bin/npx            10.9.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.2
                  javascript:     8.9.2
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        38379
                  States:         29244
                  Pending Updates: 0
                  @luft-post
                  Funktioniert jetzt der Aufruf von
                  iob diag
                  wieder auf direktem Weg?
                  L 1 Antwort Letzte Antwort
                    @luft-post
                    iob diag
                    luft-post
                    @thomas-braun ja
                    • L luft-post
                      @thomas-braun ja
                      @luft-post
                      Gut, dann sind deine verfummelten Rechte jetzt wieder gerade.
                      NICHT als iobroker einloggen, NICHT als root einloggen.
                      Du zerballerst dir damit sonst die Rechte.
                      Und nachdem deine Kiste jetzt wieder senkrecht ist schaut dein Problem mit dem Adapter genau wie aus?
                      HomoranH L 2 Antworten Letzte Antwort
                        ich hab den Teil mal abgetrennt und aus Tester hierher geschoben
                          @luft-post
                          @thomas-braun sagte in System krumm?:
                          dann bitte wieder im Original Thread weitermachen!
                            luft-post
                            @homoran ok vielen Dank
