  4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
adapteratomfeediobroker.rssfeedrdfrssviswidget
705 Beiträge 35 Kommentatoren 241.7k Aufrufe 38 Beobachtet
  • O Oli
    @oliverio
    ich verwende edge, chrome und silk überall das gleiche
    vielleicht hilft dir das weiter:
    hub.ts:494
     Uncaught (in promise) TypeError: Ut(...).isOlderThan is not a function
        at qt (hub.ts:494:65)
        at sdk.ts:19:15
        at t.init (sdk.ts:91:3)
        at Object._initializeSentry (widgets.min.js:1:20151)
        at Object.initializeSentry (widgets.min.js:1:19863)
    qt	@	hub.ts:494
    (anonymous)	@	sdk.ts:19
    t.init	@	sdk.ts:91
    _initializeSentry	@	widgets.min.js:1
    await in initializeSentry
    (anonymous)	@	materialdesign.js:35
    (anonymous)	@	widgets.min.js:1
    (anonymous)	@	visEngine.jsx:1199
    Promise.then
    emit	@	visEngine.jsx:1199
    getObject	@	widgets.min.js:1
    getVersion	@	widgets.min.js:1
    (anonymous)	@	materialdesign.js:32
    setTimeout
    waitForVisConnected	@	widgets.min.js:1
    showVersion	@	materialdesign.js:31
    customWidgets.js:2
     Uncaught SyntaxError: Cannot use import statement outside a module (at customWidgets.js:2:1)
    visLoadWidgets.tsx:197
     Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
    (anonymous)	@	visLoadWidgets.tsx:197
    Promise.catch
    (anonymous)	@	visLoadWidgets.tsx:196
    n	@	visLoadWidgets.tsx:173
    (anonymous)	@	visLoadWidgets.tsx:326
    Promise.then
    (anonymous)	@	visLoadWidgets.tsx:254
    Promise.then
    r	@	visLoadWidgets.tsx:225
    (anonymous)	@	visWidgetsCatalog.tsx:302
    setTimeout
    (anonymous)	@	visWidgetsCatalog.tsx:301
    collectRxInformation	@	visWidgetsCatalog.tsx:300
    onWidgetsLoaded	@	Runtime.jsx:813
    onLoaded	@	Runtime.jsx:1028
    loadWidgets	@	visEngine.jsx:1529
    await in loadWidgets
    (anonymous)	@	visEngine.jsx:208
    Promise.then
    Mt	@	visEngine.jsx:196
    visLoadWidgets.tsx:198
     Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {}
    (anonymous)	@	visLoadWidgets.tsx:198
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #686
    @oli
    http status code der cutomwidgets bitte, so wie im post geschrieben, oder zeigen mit screenshot.
    wenn die datei nicht geladen wird sind das folgefehler.
    dann ist ja nix da was ausgeführt werden könnte
    Meine Adapter und Widgets
    Links im Profil
    O 1 Antwort Letzte Antwort
    • OliverIOO OliverIO
      @oli
      O Offline
      O Offline
      Oli
      #687
      @oliverio
      ich hoffe, dass ich jetzt das richtige erwischt habe
      Request URL
      http://192.168.2.222:8082/vis-2/widgets/vis-2-widgets-rssfeed/customWidgets.js
      Request Method
      GET
      Status Code
      200 OK
      Remote Address
      192.168.2.222:8082
      Referrer Policy
      strict-origin-when-cross-origin
      cache-control
      public, max-age=60
      connection
      keep-alive
      content-encoding
      gzip
      content-type
      application/javascript; charset=utf-8
      date
      Sat, 02 Aug 2025 10:36:33 GMT
      etag
      W/"f28-m6ffyixFsaIxy+qdViuvo0tnzh0"
      keep-alive
      timeout=5
      transfer-encoding
      chunked
      vary
      Accept-Encoding
      accept
      accept-encoding
      gzip, deflate
      accept-language
      de,de-DE;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6
      cache-control
      no-cache
      connection
      keep-alive
      host
      192.168.2.222:8082
      pragma
      no-cache
      referer
      http://192.168.2.222:8082/vis-2/edit.html
      user-agent
      Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/138.0.0.0 Safari/537.36 Edg/138.0.0.0
      Oliver
      • O Oli
        @oliverio
        Request URL
        Request Method
        GET
        Status Code
        200 OK
        Remote Address
        192.168.2.222:8082
        Referrer Policy
        cache-control
        public, max-age=60
        connection
        keep-alive
        content-encoding
        gzip
        content-type
        date
        etag
        keep-alive
        timeout=5
        transfer-encoding
        chunked
        vary
        Accept-Encoding
        accept
        accept-encoding
        gzip, deflate
        accept-language
        cache-control
        no-cache
        connection
        keep-alive
        host
        192.168.2.222:8082
        pragma
        no-cache
        referer
        user-agent
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #688
        @oli
        Ok, danke, seltsam. Die Datei wird geladen.
        Das muss ich mal auf einem cleanen system testen
        Passt halt nicht zur Fehlermeldung
        Kannst du das nochmal checken?
        Also http Status 200 und gleichzeitig kommt die Fehlermeldung?
        Links im Profil
          @oli
          O Offline
          O Offline
          Oli
          #689
          @oliverio
          ja, ist so, http Status ist 200 und gleichzeitig kommt die Fehlermeldung
          Oliver
          • O Oli
            @oliverio
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #690
            @oli
            so, habe mal in einem cleanen iobroker system unter windows vis-2 und den adapter vis-2-widgets-rssfeed installiert. Ergebnis: hat alles funktioniert. auf anhieb.
            meine Vermutung wäre nun, wie schon mal, wo ich nach iob diag nachgefragt habe, das an deinem system irgend etwas nicht stimmt.
            evtl musst du mal vis-2 deinstallieren und wieder installieren.
            evtl auch den iobroker komplett neu aufzusetzen.
            Links im Profil
              @oli
              trojanhector
              #691
              @oliverio Servus,
              seit kurzen funktioniert die Anzeige der JSON Vorlage nicht mehr.
              Im Log kann ich nichts erkennen.
              Meine Umgebung:
              Admin: 7.7.2
              VIS-2: 2.13.4
              RSS: 3.5.2
              Ovarious: 1.0.0
              node.js: 22.19.0
              js-controller: 7.0.7
              • T trojanhector
                @oliverio Servus,
                Meine Umgebung:
                Admin: 7.7.2
                VIS-2: 2.13.4
                RSS: 3.5.2
                Ovarious: 1.0.0
                node.js: 22.19.0
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                #692
                @trojanhector
                zu aller erst. bitte wechsle auf den adapter vis-jsontemplate,
                da ich, wenn jsontemplate im stable ist, anfangen werde
                die jsontemplate funktionen aus rssfeed auszubauen und den adapter vis2-widgets-ovarious auf deprecated zu setzen.
                ich habe getestet und am widget selbst kein problem entdecken können.
                in deinem screenshot steht eine fehlermeldung drin, die auf ein problem an deinen daten ausweist
                die pfeile >> zeigen dir die Zeile in der das Problem auftaucht
                ich vermute mal das data oder data[0] undefined ist.
                hier ein kleines testszenario
                json für den datenpunkt
                  "pstring":"Auto",
                  "pnumber":123,
                  "pobject":{"prop1":"abc"}
                und das template
                <% //debugger %>
                undefined: <%- JSON.stringify(undefined) %><br><br>
                stringify: <%- JSON.stringify(data) %> <br><br>
                original: <%- data %> <br><br>
                pstring: <%- data.pstring %> <br><br>
                das sollte sowas wie folgt ausgeben
                wenn du dich damit auskennst, kannst du die kommentarzeichen im ersten statement vor debugger entfernen und bei geöffneten web developer tools selbst debuggen. das von ejs (dem template compiler) erzeugte script ist ganz gut lesbar und du kannst selbst schauen was wo in welchen variablen tatsächlich ankommt. die reinterpretation des templates erfolgt immer nachdem mindestens 1 zeichen geändert worden ist.
                Links im Profil
                  @trojanhector
                    "pstring":"Auto",
                    "pnumber":123,
                  und das template
                  <% //debugger %>
                  trojanhector
                  #693
                  @oliverio said in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
                  Das gewünschte Ergebnis bekomme ich nur im Editor angezeigt, aber nicht live.
                  Live ist es dann:
                  und
                  • T trojanhector
                    Live ist es dann:
                    und
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #694
                    @trojanhector
                    dann wechsle zunächst auf den adapter vis-jsontemplate
                    ich werde am adapter vis-2-widgets-ovarious nichts mehr machen.
                    die funktionalität ist identisch. das widget musst du neu setzen.
                    Links im Profil
                    • OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #695
                      Adapter rssfeed, Info zu Version 3.6.1
                      • Wichtig: JSON-Template-Widgets werden als veraltet markiert;
                        bitte verwendet stattdessen den
                        neuen Adapter iobroker.vis-jsontemplate
                      • Hinzufügen einer Benachrichtigung für das Update, um die Nutzer darüber zu informieren- Entfernung des veralteten Marquee4-Widgets
                      • Optimierung des Widget-Buildprozesses
                      • Integration von Übersetzungen und CSS in den Buildprozess
                      • Entfernung nicht genutzter CSS-Stile
                      Links im Profil
                      • OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #696
                        Für diejenigen, die selber Templates erstellen oder vorhandene anpassen, wurde die Dokumentation um zwei wichtige hinweise erweitert.
                        https://github.com/oweitman/ioBroker.rssfeed#very-important-note-for-use-in-vis--vis-2
                        Links im Profil
                        • N Offline
                          N Offline
                          nordstern19_72
                          #697
                          ich hatte seit einiger Zeit bei einem Feed vom RND, den ich im Adapter eingetragen habe von axios ein 403 als Fehler beim Request bekommen.
                          Habe ich mit mehreren verschiedenen Feeds von denen probiert, keine Besserung.
                          Hingegen haben Feeds von NTV oder Tagesschau immer funktioniert.
                          Nicht funktioniert haben die Feeds, die man hier findet:
                          https://www.rnd.de/services/hier-finden-sie-die-rss-feeds-ihres-rnd-IU6KPQWIVBADPAGOOQKNQCQET4.html
                          Mir hat nach Recherche über axios geholfen dem Request einen User-Agent mitzugeben.
                          Dazu musste die lib/rssFeedServer.js etwas angepasst werden:
                          try {
                                      axios({
                                          method: 'get',
                                          url: url,
                                          headers: {
                                              Accept: 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7',
                                              'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36',
                                          responseType: 'stream',
                          Seitdem werden wieder Daten abgerufen und in den entsprechenden States gespeichert.
                          Vielleicht mögen die beim RND solche Abfrage der Feeds mit nodejs/axios nicht und haben da einen "403-Riegel" vorgeschoben.
                          Nordstern
                          • N nordstern19_72
                            try {
                                        axios({
                                            method: 'get',
                                            url: url,
                                            headers: {
                            Nordstern
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #698
                            @nordstern19_72
                            guter input.
                            das kann ich machen.
                            wahrscheinlich sendet aios einen eigenen user agent header und manche prüfen darauf.
                            Links im Profil
                            • N Offline
                              N Offline
                              nordstern19_72
                              #699
                              Danke...
                              Nordstern
                              • N nordstern19_72
                                Danke...
                                Nordstern
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #700
                                @nordstern19_72
                                du kannst mal das folgende alpha release testen:
                                • gehe auf adapters
                                • aktiviere expertenmodus (grüner knopf oben)
                                • gehe auf den katzenknopf
                                • wähle im dialog custom aus
                                • trage bei url das folgende ein
                                iobroker.rssfeed@4.0.4-alpha.0
                                freue mich auf Rückmeldung.
                                wenn das passt, dann würde ich ein offizielles release machen.
                                andere können ebenfalls mittesten:
                                Links im Profil
                                N 1 Antwort Letzte Antwort
                                  @nordstern19_72
                                  • gehe auf adapters
                                  N Offline
                                  N Offline
                                  nordstern19_72
                                  #701
                                  @OliverIO
                                  Habe ich gemacht.
                                  Funktioniert einwandfrei!
                                  Gute Idee den User-Agent einstellbar im Admin zu haben.
                                  Danke...
                                  Nordstern
                                  • N nordstern19_72
                                    @OliverIO
                                    Habe ich gemacht.
                                    Danke...
                                    Nordstern
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #702
                                    @nordstern19_72
                                    super, dann release ich offiziell
                                    Links im Profil
                                    • OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #703
                                      Neue Version 4.1.2 rssfeed
                                      • Das Feature mit dem einstellbaren header ist nun im beta verfügbar.
                                      Links im Profil
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #704
                                        Neue Version 1.2.3 vis-2-widgets-rssfeed
                                        • keine funktionale Erweiterung
                                        • Abhängigkeiten wurden aktualisiert
                                        • Probleme aus dem repochecker wurden behoben
                                        • react wurde auf 18 aktualisiert.
                                        Links im Profil
                                        • OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #705
                                          rssfeed 4.1.2 befindet sich nun im stable repository
                                          Links im Profil
