  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 35.2k Aufrufe 16 Beobachtet
  • AsgothianA Asgothian
    @flugschüler sagte in Tester wanted - Zigbee Adapter 3.1:
    Ist das so richtig? Dann sende ich die daten vom neuen zigbee adapter.
    Fast - was ich nicht erkennen kann: welche der Meldungen sind die Reaktionen auf ein 'Device Query', insbesondere beim neuen Adapter.
    A.
    Flugschüler
    #73
    @asgothian
    ELEVATED:I01 (1fea) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (1fea) value generated '76' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:O01 (24b0) User state change of state zigbee.0.a4c13886e50d0115.device_query with value true (ack: false) from system.adapter.admin.0
    ELEVATED:O02 (24b0) Change state 'device_query' at device 0xa4c13886e50d0115 type '2CT'
    ELEVATED:Oqs (24b0) Device query for '0xa4c13886e50d0115/1' triggered
    ELEVATED:Oqe (24b0) ELEVATED O07: Device query for '0xa4c13886e50d0115/1' complete
    ELEVATED:I01 (34df) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (34df) value generated '80' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (34df) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":10240,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,166]}}]}...}
    ELEVATED:I01 (3516) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (3516) value generated '72' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (3516) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":10496,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,18,226]}}]}...}
    ELEVATED:I01 (354e) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (354e) value generated '80' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (354e) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":10752,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
    ELEVATED:I01 (3587) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (3587) value generated '80' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (3587) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":11008,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,21,89]}}]}...}
    ELEVATED:I01 (35bd) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (35bd) value generated '76' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (35bd) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":11264,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
    ELEVATED:I01 (35f2) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (35f2) value generated '76' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (35f2) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":11520,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,18,226]}}]}...}
    ELEVATED:I01 (3628) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (3628) value generated '76' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (3628) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":11776,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
    ELEVATED:I01 (365f) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
    ELEVATED:I02 (365f) value generated '80' from device a4c13886e50d0115 for 'Link quality'
    ELEVATED:I01 (365f) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":12032,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
    • F Flugschüler
      @asgothian
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #74
      @flugschüler wurden in diesem Fall die fraglichen Werte aktualisiert ?
      F 1 Antwort Letzte Antwort
        Flugschüler
        #75
        @asgothian Wenn du die datenpunkte meinst es wurde nichts aktuallisiert.
        • CodierknechtC Offline
          Codierknecht
          #76
          Ich erhalte in unregelmäßigen Abständen folgende Einträge im Log:
          zigbee.0    2025-09-19 12:28:54.929	warn	Resolve Entity did not manage to find a mapped device for [object Object]
          zigbee.0    2025-09-19 12:24:38.716	warn	Resolve Entity did not manage to find a mapped device for [object Object]
          zigbee.0    2025-09-19 12:22:01.497	warn	Resolve Entity did not manage to find a mapped device for [object Object]
          Fehlt da evtl. ein JSON.stringify() ?
          Und by the way: Beim "reconfigure" eines Device müsste es korrekt heißen: "Device is being reconfigured"
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          • F Flugschüler
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #77
            Muss eigentlich. Schau mal bitte bei dem DP current_b nach wann der das letzte mal aktualisiert wurde.
            Alternativ: Installier mal bitte vom iobroker GitHub die 3.1.2 - da sind kleinere Bugfixes beim Logging enthalten- und wiederhol dann bitte die Tests mit der 3.1.2 (abwarten, sowie device query)
            A.
            • CodierknechtC Codierknecht
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #78
              @codierknecht sagte in Tester wanted - Zigbee Adapter 3.1:
              Danke für den Hinweis - ist gefixed in der 3.1.2 auf Github - die Meldung kommt nur. noch wenn sie wirklich benötigt wird.
              Das sprachliche hab ich gerade lokal geändert - wird also in 3.1.3 gefixed sein
              A.
              Nachtrag: die Meldungen kommen weil er versucht, die device definition für den Koordinator zu finden. Der hat aber keine :). Das filter ich in der Github Version raus - also keine Meldungen mehr.
              JLegJ 1 Antwort Letzte Antwort
                A.
                JLegJ Offline
                JLegJ Offline
                JLeg
                #79
                @asgothian ...being on that... ;) - Adapter 3.1.2, bei den umgedrehten Kacheln kickt der "Raumname" bei entsprechender Länge ein Icon weg:
                Ansonsten läuft 3.1.2 sehr gut bei mir, ohne Auffälligkeiten...
                  A.
                  Flugschüler
                  #80
                  @asgothian Ich hab jetzt geschaut was wann aktuallisiert wird und das einzige was aktuallisiert wird ist Link quality und Message from Zigbee bei Adapter 3.1.2 über git installiert. Bei Adapter 3.0.5 funktioniert alles prima.
                  • F Flugschüler
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #81
                    Das wissen wir schon. Ich brauch die Meldungen, um zu sehen wo das hängen bleibt. Alternativ - ein Gerät damit ich das selber Debuggen kann.
                    Ansonsten wirst du auf 3.0.5 bleiben müssen und von der Unterstützung von neuen Geräten abgeschnitten. Die Änderung / Ursache liegt in einer Änderung der ZH/ZHC Bibliotheken. Ohne mithilfe werde ich das nicht finden, und ohne Wechsel auf diese Bibliotheken werden neue Geräte nicht funktionieren.
                    A.
                    Und nein - ich werde mir keins kaufen. Ich steck da schon reichlich Freizeit rein - ich werd jetzt nicht auch noch Geld versenken in Geräte die ich nicht gebrauchen kann.
                      A.
                      Flugschüler
                      schrieb am zuletzt editiert von Flugschüler
                      #82
                      @asgothian
                      ELEVATED:I01 (b0bd) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b0bd) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b0bd) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24064,"dpValues":[{"dp":20,"datatype":2,"data":{"type":"Buffer","data":[0,0,8,205]}}]}...}
                      ELEVATED:I01 (b0e8) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b0e8) value generated '80' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b0e8) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24320,"dpValues":[{"dp":19,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,161]}}]}...}
                      ELEVATED:I01 (b113) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b113) value generated '72' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b113) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24576,"dpValues":[{"dp":101,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
                      ELEVATED:I01 (b13c) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b13c) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b13c) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":24832,"dpValues":[{"dp":102,"datatype":2,"data":{"type":"Buffer","data":[0,0,21,196]}}]}...}
                      ELEVATED:I01 (b166) message received '{"linkquality":80}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b166) value generated '80' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b166) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25088,"dpValues":[{"dp":103,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]}...}
                      ELEVATED:I01 (b19a) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b19a) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b19a) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25344,"dpValues":[{"dp":104,"datatype":2,"data":{"type":"Buffer","data":[0,0,19,161]}}]}...}
                      ELEVATED:I01 (b1cf) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b1cf) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b1cf) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25600,"dpValues":[{"dp":141,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
                      ELEVATED:I01 (b1f9) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (b1f9) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (b1f9) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":25856,"dpValues":[{"dp":142,"datatype":4,"data":{"type":"Buffer","data":[0]}}]}...}
                      ELEVATED:I01 (9975) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (9975) value generated '72' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (999e) message received '{"linkquality":76}' from device a4c13886e50d0115 type '2CT'
                      ELEVATED:I02 (999e) value generated '76' from device a4c13886e50d0115 for 'Link quality'
                      ELEVATED:I01 (999e) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":22784,"dpValues":[{"dp":117,"datatype":2,"data":{"type":"Buffer","data":[0,0,161,211]}}]}...}
                      ELEVATED:O01 (a68b) User state change of state zigbee.0.a4c13886e50d0115.device_query with value true (ack: false) from system.adapter.admin.0
                      ELEVATED:O02 (a68b) Change state 'device_query' at device 0xa4c13886e50d0115 type '2CT'
                      ELEVATED:Oqs (a68b) Device query for '0xa4c13886e50d0115/1' triggered
                      ELEVATED:Oqe (a68b) ELEVATED O07: Device query for '0xa4c13886e50d0115/1' complete
                      Du musst dir sicher das Gerät nicht kaufen. Ich würde mir auch nicht ein gerät kaufen das ich nicht brauche. Ich bin ja froh und dankbar wenn du mir hilfst. Aber ich bin nur ein leihe und kein programmierer ich hoffe die logs bringen dir irgend etwas. Danke!
                      • F Flugschüler
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #83
                        @flugschüler Die Logs sind immer noch etwas irritierend. Im Payload sind Daten vorhanden, die aber angeblich nicht auf ein Ergebnis verweisen. Das irritiert mich.
                        Da grabe ich gerade nach. Im Payload vom Device sind die Daten jedenfalls vorhanden.
                        A.
                          A.
                          Flugschüler
                          #84
                          @asgothian Kann ich noch irgendwie helfen damit wir das Problem lösen können?
                          • F Flugschüler
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #85
                            @flugschüler Ich grab noch - so in 30 Minuten müsstest du nochmal was testen
                              Flugschüler
                              #86
                              @asgothian 👍
                              • F Flugschüler
                                @asgothian 👍
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #87
                                @flugschüler Du hast die Meldungen aus dem Admin kopiert - da sind sie abgeschnitten. Ich brauche zu dieser Meldung
                                das vollständige Original.
                                Da kommst du ran durch
                                • Log Seite aufrufen
                                • log herunterladen (das von heute)
                                • im Log nach ELEVATED:I01 (b166) suchen - da sollte es genau 2 Zeilen geben.
                                A.
                                  A.
                                  Flugschüler
                                  #88
                                  @asgothian said in Tester wanted - Zigbee Adapter 3.1:
                                  ELEVATED:I01 (b166)
                                  Ich finde keinen eintrag mit ELEVATED:I01 (b166)
                                  • F Flugschüler
                                    ELEVATED:I01 (b166)
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #89
                                    @flugschüler den hast du mir aber vorhin selber gepostet. Hast du danach das Log gelöscht ?
                                      Flugschüler
                                      #90
                                      @asgothian kann sein war das ein Fehler😧
                                      2025-09-19 15:04:27.104 - warn: zigbee.0 (56875) ELEVATED:I01 (77e0) Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":12032,"dpValues":[{"dp":107,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,0]}}]},"linkquality":72,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,40,2,0,47,107,2,0,4,0,0,0,0]},"zclTransactionSequenceNumber":40,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
                                      2025-09-19 15:04:27.108 - warn: zigbee.0 (56875) ELEVATED:I01 (77e0) message received '{"linkquality":72}' from device a4c13886e50d0115 type '2CT'
                                      Hilft dir das?
                                      • F Flugschüler
                                        Hilft dir das?
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #91
                                        Jein. Zumindest kann ich jetzt sehen welche Daten beim DeviceQuery kommen.
                                        Bitte mach folgendes:
                                        Installier die 3.1.3 von hier:
                                        https://github.com/asgothian/ioBroker.zigbee
                                        lass die etwa laufen, damit ich sehen kann was das Gerät an Daten sendet.
                                        Nach so 10 Minuten: bitte ein Device Query
                                        Und dann nochmal die Log einträge posten. Allerdings bitte die aus dem heruntergeladenen Log, nicht die gekürzten aus dem Admin.
                                        Da kommen jetzt mehr Informationen.
                                        A.
                                          A.
                                          Flugschüler
                                          #92
                                          @asgothian iobroker_log.txt
