lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 9.2m Aufrufe 260 Beobachtet
  • CiwaC Ciwa
    danke für die schnelle Antwort. JS Adapter habe ich manuell auf 9.0.11 hochgezogen.
    Befehle habe ich der Reihe nach gestartet. Das Ergebnis bleibt gleich.
    Script läuft fehlerfrei, Anzeige Waiting for content: Ausgabe auf FlashNextionAdv0 http://nspanel.de/nspanel-v4.9.5.tft:
    19:38:15.084 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v4.9.5.tft
    19:38:15.097 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"FLASHNEXTIONADV0 http://nspanel.de/nspanel-v4.9.5.tft"}
    19:38:59.962 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:39"}
    19:39:59.962 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:40"}
    19:40:59.961 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:41"}
    19:41:59.961 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:42"}
    19:42:30.902 MQT: SmartHome/NS_Panel/tele/STATE = {"Time":"2025-08-26T19:42:30","Uptime":"0T00:05:10","UptimeSec":310,"Heap":166,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":999,"MqttCount":1,"Berry":{"HeapUsed":3,"Objects":38},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"Ciwa","BSSId":"E0:28:6D:48:FF:B5","Channel":13,"Mode":"HT40","RSSI":100,"Signal":-46,"LinkCount":1,"Downtime":"0T00:00:03"}}
    19:42:30.954 MQT: SmartHome/NS_Panel/tele/SENSOR = {"Time":"2025-08-26T19:42:30","ANALOG":{"Temperature1":26.7},"ESP32":{"Temperature":80.0},"TempUnit":"C"}
    19:42:59.962 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:43"}
    19:43:59.962 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:44"}
    19:44:59.970 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:45"}
    19:45:59.962 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:46"}
    19:46:59.965 MQT: SmartHome/NS_Panel/stat/RESULT = {"Command":"Unknown","Input":"CUSTOMSEND time~20:47"}
    Irgendwo habe ich noch was verkehrt gemacht.......
    Ciwa
    T
    T
    TT-Tom
    #7500
    @ciwa
    hast du wirklich Berry 10 drauf?
    nimm mal die Spannung weg und starte das Panel neu
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    CiwaC 1 Antwort Letzte Antwort
    • T TT-Tom
      @ciwa
      CiwaC
      CiwaC
      Ciwa
      #7501
      @tt-tom
      habe ich gemacht. Ergebnis bleibt gleich....
      no blaming, no complaining, no excuses......only responsibility
      • teletapiT
        teletapiT
        teletapi
        #7502
        @ciwa
        Dann bleibt ja eigentlich nur noch die Tasmota Installation wenn der Flash Nextion Befehl als unbekannt deklariert wird
        • CiwaC Ciwa
          @tt-tom
          T
          T
          ticaki
          #7503
          @ciwa
          Hast du auch geguckt das was in der autoexec.be drin steht?
          Spenden
          teletapiT 1 Antwort Letzte Antwort
          • T ticaki
            @ciwa
            teletapiT
            teletapiT
            teletapi
            #7504
            @ticaki Das sagste gerade was das hatte ich die Tage auch schonmal das die autoexec.be plötzlich leer war. das sollte in jedem Fall geprüft werden
            • CiwaC
              CiwaC
              Ciwa
              #7505
              Och man was ist das denn? Die ist wirklich leer.....Läuft jetzt erst mal in der alten Version. Morgen dann zweiter Anlauf. Danke euch
              Ciwa
              • CiwaC Ciwa
                Ciwa
                ArmilarA
                ArmilarA
                Armilar
                Most Active Forum Testing
                #7506
                @ciwa
                Also, der Berry 9 kann das genauso wie der Berry 10... Beim Berry 10 ist die Chance aber größer, dass das Flashen auch durchläuft, da die Dateien jetzt auch größer sind...
                Mit dem JS. 9.0.11 sind alle Voraussetzungen erfüllt für das Skript 4.9.5.1 oder DEV v4.9.5.2 (optional zur 4.9.5.1 mit Wetteradapter Bright Sky)
                Für das Flashen der TFT ist nur Tasmota und der Berry erforderlich... Da der Berry ja bereits antwortet und das Flashen nicht anfängt, gibt es für mich nur 2 Anhaltspunkte (abgesehen davon sendet das Skript bereits permanent die Uhrzeit)
                1. Tom hat recht und da hat sich etwas intern weggehängt, dass nur mit stromlos zu reparieren ist? (Aber dann gleich beide?)
                2. Du hast irgendetwas installiert, dass die Kommunikation eines NSPanels (Tasmota) mit dem Internet (http://) verbietet!
                3. Durch das Backlog UrlFetch https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/refs/heads/main/tasmota/berry/10/autoexec.be; Restart 1 muss das Panel jammindestens 1x durchgestartet worden sein
                4. Tippe in der Tasmota-Konsole mal Weblog 3 und sende dann das Log der ersten Sekunden
                EDIT:
                Kann natürlich auch andere Ursachen haben wie:
                • Passwort für Weboberfläche gesetzt?
                • HTTP API deaktiviert?
                • ArmilarA Armilar
                  @ciwa
                  EDIT:
                  CiwaC
                  CiwaC
                  Ciwa
                  schrieb am zuletzt editiert von Ciwa
                  #7507
                  @armilar
                  Also jetzt bin ich wieder auf die JS 9.0.11. Dann Berry update, danach war die autoexec.be leer. Die habe ich wieder eingespielt. Dann tft Update das startet jetzt auch, bleibt aber hängen.
                  22:35:57.216 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                  ganz komisch.
                  Hier der Weblog 3 Output
                  22:01:34.975 CMD: FlashNextionAdv0 http://nspanel.de/nspanel-v4.9.5.tft
                  22:01:34.991 MQT: SmartHome/NS_Panel/stat/RESULT = {"FlashNextionAdv":"Done"}
                  22:01:35.042 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.9.5.tft
                  22:01:36.282 FLH: Send (High Speed) flash start
                  22:01:36.671 BRY: Exception> 'type_error' - unsupported operand type(s) for <: 'nil' and 'int'
                  22:01:43.018 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:01:43.087 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:01:43.202 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:01:59.933 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:00.060 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:00.121 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:00.222 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:27.904 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:27.984 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:28.079 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:28.223 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:28.298 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:28.404 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:43.013 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:43.077 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:43.191 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:02:59.934 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:00.060 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:00.125 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:00.224 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:43.066 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:43.142 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:03:43.235 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:46:59.142 CMD: Grp 0, Cmd 'FLASHNEXTION', Idx 1, Len 36, Pld -99, Data 'http://nspanel.de/nspanel-v4.9.5.tft'
                  22:46:59.151 MQT: SmartHome/NS_Panel/stat/RESULT = {"FlashNextion":"Done"}
                  22:46:59.209 SRC: MQTT
                  22:46:59.211 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 24, Pld -99, Data 'dimmode~1~100~6371~65535'
                  22:46:59.231 NXP: skipped command becuase still flashing
                  22:46:59.239 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:46:59.251 FLH: host: nspanel.de, port: 80, get: /nspanel-v4.9.5.tft
                  22:46:59.253 WIF: DNS failed for nspanel.de after 1 ms
                  22:46:59.254 FLH: Connected:false
                  22:46:59.356 FLH: Retry 2
                  22:46:59.557 FLH: Retry 3
                  22:46:59.858 FLH: Retry 4
                  22:47:00.259 FLH: Retry 5
                  22:47:00.259 FLH: Nothing available to read!
                  22:47:00.263 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
                  22:47:00.266 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                  22:47:00.268 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
                  22:47:00.272 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
                  22:47:00.311 SRC: MQTT
                  22:47:00.312 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:46'
                  22:47:00.335 NXP: skipped command becuase still flashing
                  22:47:00.345 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:47:00.367 SRC: MQTT
                  22:47:00.368 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 30, Pld -99, Data 'date~Dienstag, 26. August 2025'
                  22:47:00.390 NXP: skipped command becuase still flashing
                  22:47:00.397 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:47:00.429 SRC: MQTT
                  22:47:00.430 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 20, Pld -99, Data 'pageType~pageStartup'
                  22:47:00.454 NXP: skipped command becuase still flashing
                  22:47:00.466 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:47:00.484 HTP: Command
                  22:47:00.491 SRC: WebCommand from 192.168.7.75
                  22:47:00.493 CMD: Grp 0, Cmd 'GETDRIVERVERSION', Idx 1, Len 0, Pld -99, Data ''
                  22:47:00.505 MQT: SmartHome/NS_Panel/tele/RESULT = {"nlui_driver_version":"9"}
                  22:47:00.562 SRC: MQTT
                  22:47:00.563 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:47'
                  22:47:00.578 NXP: skipped command becuase still flashing
                  22:47:00.586 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:47:59.814 SRC: MQTT
                  22:47:59.815 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:48'
                  22:47:59.829 NXP: skipped command becuase still flashing
                  22:47:59.836 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  22:48:59.812 SRC: MQTT
                  22:48:59.813 CMD: Grp 0, Cmd 'CUSTOMSEND', Idx 1, Len 10, Pld -99, Data 'time~23:49'
                  22:48:59.836 NXP: skipped command becuase still flashing
                  22:48:59.845 MQT: SmartHome/NS_Panel/stat/RESULT = {"CustomSend":"Done"}
                  Edit:
                  Hat jetzt abgebrochen Panel zeigt:
                  • CiwaC Ciwa
                    @armilar
                    ganz komisch.
                    Edit:
                    ArmilarA
                    ArmilarA
                    Armilar
                    #7508
                    @ciwa
                    Jo das sieht sehr gut aus...
                    Kommunikation startet zur TFT URL und dann kommt sowas ;-)
                    Okay - Du hast eine statische IP vergeben und/oder ein besonderes Binding für das Panel im Router gesetzt.
                    Das mag Tasmota nicht...
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#32-fehler-bei-flashnextion---type-error-unsupported-operand-types
                    backlog savedata 1; ipaddress1 0.0.0.0; savedata 0; restart 1
                    damit bekommt das Panel eine IP vom DHCP
                    und dann neue IP suchen und:
                    Wenn's dann immer noch die Meldung gibt, dann im Router nach Bindings suchen...
                    Seit der Einführung von ipv6 im Tasmota passiert das mit dem Fehler... danach sollte sich das aber ohne diesen Fehler flashen lassen...
                    EDIT: Den weißen Screen mit "Model does not match" kannst du getrost ignorieren... Kann ja nicht passen, weil nichts gesendet wurde... 😊
                    EDIT2: Sollte das Flash irgendwo zwischen 0 und 100% abbrechen, dann Panel restart und neu flashen...
                    • ArmilarA Armilar
                      @ciwa
                      CiwaC
                      CiwaC
                      Ciwa
                      #7509
                      @armilar
                      Vielen Dank für die Zeit die du hier investierst.
                      Ich mag halt feste IPs für den ganzen Iot Kram :)
                      Jetzt ist erst mal Feierabend :)
                      Ciwa
                      ArmilarA T 2 Antworten Letzte Antwort
                      • CiwaC Ciwa
                        @armilar
                        Ciwa
                        ArmilarA
                        ArmilarA
                        Armilar
                        #7510
                        @ciwa
                        Solang es hilft, gerne
                        Ich mag halt feste IPs für den ganzen Iot Kram 🙂
                        Ich auch... Macht die Verwaltung so einfach... Man kann anschließend wieder eine statische IP vergeben... Man muss sich nur das nächste Mal an diese Prozedere erinnern (passiert sonst wieder)
                        Ich flashe ja so häufig, dass die statischen NSPanel IP's bei mir keinen Sinn mehr machen.
                        • CiwaC Ciwa
                          @armilar
                          Ciwa
                          T
                          T
                          TT-Tom
                          #7511
                          @ciwa
                          Du kannst im Router festlegen, das er der Mac-Adresse (Panel) immer diese IP zuweisen soll. In Tasmota lässt du alles auf DHCP. Sso funktioniert es bei mir schon seit Monden.
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            @ciwa
                            T
                            T
                            ticaki
                            #7512
                            @ciwa
                            @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
                            @ciwa
                            So wurde mir das auch von einem Netzwerktechniker empfohlen, besser zu administrieren.
                            Spenden
                            • T
                              T
                              ticaki
                              #7513
                              Für Berry update bitte diesen Befehlt benutzen:
                              Backlog UfsDelete autoexec.old; UfsRename autoexec.be,autoexec.old; UrlFetch https://raw.githubusercontent.com/ticaki/ioBroker.nspanel-lovelace-ui/refs/heads/main/tasmota/berry/10/autoexec.be; Restart 1
                              Der benennt die autoexec.be in autoexec.old um - vorher wird die alte .old gelöscht und läd dann die neue Version. Damit sollte es nicht eine existierende aber leere autoexec.be geben.
                              Spenden
                              • T ticaki
                                CiwaC
                                CiwaC
                                Ciwa
                                #7514
                                das Spiel geht in eine neue Runde.
                                • Berry Update ok
                                • TFT Update ok (Schöner Startbildschirm)
                                • Ip Adresse wieder zurück statisch
                                • JS 9.0.11
                                • Script adaptiert und läuft fehlerfrei
                                NS Panel abgeschmiert....Webinterface erreichbar, TFT zeigt Fehler:
                                Ciwa
                                • CiwaC Ciwa
                                  • Berry Update ok
                                  • JS 9.0.11
                                  Ciwa
                                  ArmilarA
                                  ArmilarA
                                  Armilar
                                  #7515
                                  @ciwa
                                  Da scheint sich aber auch ein Flash nochmal versucht zu haben... ist bislang nur beim Adapter passiert. Und auch nur wenn der Haken im mqtt.x bei:
                                  gesetzt war.
                                  Ist es nach einem Reboot wieder okay? Ansonsten nochmal flashen...
                                  • ArmilarA Armilar
                                    @ciwa
                                    gesetzt war.
                                    CiwaC
                                    CiwaC
                                    Ciwa
                                    #7516
                                    @armilar
                                    Das wars, Teilerfolg super! Haken raus & Neuflashen war die Lösung. Das Eine Panel läuft wieder perfekt, alle Funktionen drauf. Danke dafür.
                                    Mein zweites Funktioniert leider jetzt gar nicht mehr. Ich habe es vom Sockel abgezogen um es Stromlos zu machen (Dummheit ole).
                                    • TFT dunkel
                                    • IP nicht erreichbar
                                    • manuell bestromen geht auch nicht (Stromaufnahme jedoch messbar)
                                    • Versorgungsspannung Sockel ok
                                    Ciwa
                                    • CiwaC Ciwa
                                      @armilar
                                      • TFT dunkel
                                      Ciwa
                                      ArmilarA
                                      ArmilarA
                                      Armilar
                                      #7517
                                      @ciwa
                                      okay - hmm - das ist jetzt Neuland... IP nicht erreichbar ist aktuell unser Problem, es sei denn das Panel befindet sich im Tasmota AP Modus und möchte ins WLAN...
                                      Hört sich ja irgendwie nach einem kompletten Reset an...
                                      • ArmilarA Armilar
                                        @ciwa
                                        CiwaC
                                        CiwaC
                                        Ciwa
                                        #7518
                                        @armilar
                                        eher nach Hardwaredefekt :-/ Tasmota Accesspoint ist auf jeden Fall keiner Sichtbar.
                                        Stromaufnahme ist da und schwankt. Mehr nicht..... Aber Egal....werde erst mal eins auf Ersatz anschaffen. Bei den Basteleien hier, sicher nicht die schlechteste Idee :)
                                        Was anderes noch....Der JS Adapter haut jetzt Warnmeldungen raus:
                                        javascript.0
                                        	2025-08-27 21:38:59.670	warn	State "system.adapter.javascript.0.lastSync" has no existing object, this might lead to an error in future versions
                                        das würde ich gerne noch abstellen.
                                        Ciwa
                                        • CiwaC Ciwa
                                          @armilar
                                          javascript.0
                                          Ciwa
                                          T
                                          T
                                          ticaki
                                          #7519
                                          @ciwa
                                          mach mal den tasmota tasten reset mußte mal nach suche, ich weiß gerade nicht auswendig wie der ging.
                                          Spenden
                                          83.9k
