  4. Shellys (Gen1) nicht mehr auffindbar nach Update
    6.6k
102 Beiträge 7 Kommentatoren 11.0k Aufrufe 6 Beobachtet
  • FichtendickichtF Fichtendickicht
    Re: Shelly Adapter - genereller Support
    Darf ich mich hier bitte anhängen, ich will aber nicht den Thread kapern.
    Seit dem letzten Update des IO-Brokers und des SHelly-adapters kann ich meine SHellys (Gen1) nicht mehr erreichen.
    Ich habe eine alte Version der Shelly Adapters (6.7.7) installiert aber leider ohne Erfolg.
    Ich erlaube mir hier das "iob diag" zu posten und bitte um Unterstützung.
    The ioBroker diag script is not specifically designed to run in Docker.
    Although it is generally safe to use, use it at your own risk.
    *** iob diag is starting up, please wait ***
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Hardware Vendor : Synology
    Kernel          : x86_64
    Userland        : 64 bit
    Docker          : v11.0.0
    Virtualization  : docker
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:29:21 up 16 days, 20:28,  0 user,  load average: 4.80, 3.79, 3.30
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    Thu Aug 14 12:29:21 UTC 2025
    Thu Aug 14 14:29:21 CEST 2025
    CEST +0200
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: 	false
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:             10G        5.5G        735M        273M        4.7G        4.8G
    Swap:           8.3G        1.7G        6.6G
    Total:           18G        7.2G        7.4G
    Active iob-Instances: 	16
             9806 M total memory
             5210 M used memory
             3967 M active memory
             3260 M inactive memory
              701 M free memory
              850 M buffer memory
             3608 M swap cache
             7931 M total swap
             1609 M used swap
             6322 M free swap
    top - 14:29:22 up 16 days, 20:28,  0 user,  load average: 4.97, 3.84, 3.32
    Tasks:  23 total,   1 running,  22 sleeping,   0 stopped,   0 zombie
    %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   9806.1 total,    699.0 free,   5212.9 used,   4459.1 buff/cache
    MiB Swap:   7931.9 total,   6322.5 free,   1609.4 used.   4593.1 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem        Type   Size  Used Avail Use% Mounted on
    none              aufs   2.7T  1.9T  868G  69% /
    tmpfs             tmpfs   64M     0   64M   0% /dev
    tmpfs             tmpfs  4.8G     0  4.8G   0% /sys/fs/cgroup
    shm               tmpfs   64M     0   64M   0% /dev/shm
    /dev/vg1/volume_1 ext4   2.7T  1.9T  868G  69% /opt/iobroker
    tmpfs             tmpfs  4.8G     0  4.8G   0% /proc/acpi
    tmpfs             tmpfs  4.8G     0  4.8G   0% /proc/scsi
    tmpfs             tmpfs  4.8G     0  4.8G   0% /sys/firmware
    Show mounted filesystems:
    TARGET             SOURCE        FSTYPE OPTIONS
    /                  none        aufs   rw,relatime,si=9b9cd6e224b287b0,dio,dirperm1
    |-/opt/iobroker    /dev/vg1/volume_1[/docker/iobroker_data]        ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/resolv.conf /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/resolv.conf] ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    |-/etc/hostname    /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/hostname]    ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    `-/etc/hosts       /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/hosts]       ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
    /var:
    35M	/var/
    33M	/var/lib
    19M	/var/lib/apt/lists
    19M	/var/lib/apt
    14M	/var/lib/dpkg
    /opt/iobroker/backups:
    1.1G	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    347M	/opt/iobroker/iobroker-data/
    211M	/opt/iobroker/iobroker-data/files
    74M	/opt/iobroker/iobroker-data/backup-objects
    47M	/opt/iobroker/iobroker-data/files/admin.admin
    46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    38M	/opt/iobroker/iobroker-data/objects.jsonl
    22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
    19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    13M	/opt/iobroker/iobroker-data/sqlite/sqlite.db
    8.8M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v22.18.0
    /usr/bin/node 		v22.18.0
    /usr/bin/npm 		10.9.3
    /usr/bin/npx 		10.9.3
    /usr/bin/corepack 	0.33.0
    nodejs:
      Installed: 22.18.0-1nodesource1
      Candidate: 22.18.0-1nodesource1
      Version table:
     *** 22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    buanet-iobroker-1   buanet-iobroker-1 (version: 7.0.6, hostname: buanet-iobroker-1, alive, uptime: 23015)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.17
    javascript: 	8.9.2
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : buanet-iobroker-1                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : buanet-iobroker-1                        -  enabled
    + system.adapter.backitup.0               : backitup              : buanet-iobroker-1                        -  enabled
    + system.adapter.discovery.0              : discovery             : buanet-iobroker-1                        -  enabled
    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : buanet-iobroker-1                        -  enabled
    + system.adapter.fronius.0                : fronius               : buanet-iobroker-1                        -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : buanet-iobroker-1                        -  enabled
    + system.adapter.info.0                   : info                  : buanet-iobroker-1                        -  enabled
    + system.adapter.javascript.0             : javascript            : buanet-iobroker-1                        -  enabled
    + system.adapter.modbus.0                 : modbus                : buanet-iobroker-1                        -  enabled
    + system.adapter.onvif.0                  : onvif                 : buanet-iobroker-1                        -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899,443
    + system.adapter.pid.0                    : pid                   : buanet-iobroker-1                        -  enabled
    + system.adapter.shelly.0                 : shelly                : buanet-iobroker-1                        -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sql.0                    : sql                   : buanet-iobroker-1                        -  enabled, port: 3307
    + system.adapter.telegram.0               : telegram              : buanet-iobroker-1                        -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : buanet-iobroker-1                        -  enabled
      system.adapter.vis-bars.0               : vis-bars              : buanet-iobroker-1                        -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : buanet-iobroker-1                        -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : buanet-iobroker-1                        -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : buanet-iobroker-1                        -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker-1                        -  enabled
      system.adapter.vis.0                    : vis                   : buanet-iobroker-1                        -  enabled
    + system.adapter.web.0                    : web                   : buanet-iobroker-1                        -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pid"          : 1.1.3    , installed 1.1.3
    Adapter    "shelly"       : 10.1.0   , installed 10.1.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects: 	4077
    States: 	3645
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       355613479  -
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       355613473  -
    tcp        0      0 127.0.0.11:33515        0.0.0.0:*               LISTEN      0          355599950  -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       355616483  -
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       355635954  -
    udp        0      0 127.0.0.11:54668        0.0.0.0:*                           0          355599949  -
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       361116839  -
    2025-08-14 14:17:13.156  - info: host.buanet-iobroker-1 stopInstance system.adapter.shelly.0 send kill signal
    2025-08-14 14:17:13.329  - info: host.buanet-iobroker-1 iobroker upload [16] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
    2025-08-14 14:17:13.339  - info: host.buanet-iobroker-1 iobroker upload [15] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
    2025-08-14 14:17:13.347  - info: host.buanet-iobroker-1 iobroker upload [14] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
    2025-08-14 14:17:13.357  - info: host.buanet-iobroker-1 iobroker upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    2025-08-14 14:17:13.365  - info: host.buanet-iobroker-1 iobroker upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
    2025-08-14 14:17:13.373  - info: host.buanet-iobroker-1 iobroker upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    2025-08-14 14:17:13.381  - info: host.buanet-iobroker-1 iobroker upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    2025-08-14 14:17:13.390  - info: host.buanet-iobroker-1 iobroker upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    2025-08-14 14:17:13.398  - info: host.buanet-iobroker-1 iobroker upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    2025-08-14 14:17:13.407  - info: host.buanet-iobroker-1 iobroker upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
    2025-08-14 14:17:13.417  - info: host.buanet-iobroker-1 iobroker upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    2025-08-14 14:17:13.425  - info: host.buanet-iobroker-1 iobroker upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen1.png img/mqttGen1.png image/png
    2025-08-14 14:17:13.479  - info: host.buanet-iobroker-1 iobroker upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen2.png img/mqttGen2.png image/png
    2025-08-14 14:17:13.523  - info: host.buanet-iobroker-1 iobroker upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen1.png img/restrictedLoginGen1.png image/png
    2025-08-14 14:17:13.566  - info: host.buanet-iobroker-1 iobroker upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen2.png img/restrictedLoginGen2.png image/png
    2025-08-14 14:17:13.578  - info: host.buanet-iobroker-1 iobroker upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
    2025-08-14 14:17:13.587  - info: host.buanet-iobroker-1 iobroker upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    2025-08-14 14:17:13.619  - info: shelly.0 (19623) terminating
    2025-08-14 14:17:13.731  - info: host.buanet-iobroker-1 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-08-14 14:17:14.621  - info: host.buanet-iobroker-1 iobroker exit 0
    2025-08-14 14:17:17.127  - info: host.buanet-iobroker-1 instance system.adapter.shelly.0 in version "10.1.0" started with pid 19720
    2025-08-14 14:17:20.703  - info: shelly.0 (19720) starting. Version 10.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v22.18.0, js-controller: 7.0.6
    2025-08-14 14:17:20.867  - info: shelly.0 (19720) Starting in CoAP mode. Listening on 0.0.0.0:5683
    2025-08-14 14:17:20.931  - info: shelly.0 (19720) [CoAP Server] Listening for packets in the network
    iob diag has finished.
    Danke!
    mcm1957M Online
    mcm1957M Online
    mcm1957
    @fichtendickicht
    Du hast lt. diag 10.1.0 installiert das wär ok.
    Bei GEN 1 check mal deine coap Settings am Shelly. Da darf NICHT mcast eingestrllt sein. Siehe Adapter Doku.
    Ansonsten bin ich bei Docker draussen.
    Support Repositoryverwaltung.
    LESEN - gute Forenbeitrage
    FichtendickichtF 1 Antwort Letzte Antwort
    • da_WoodyD da_Woody
      @fichtendickicht sagte in
      Shellys (Gen1) nicht mehr auffindbar nach Update:
      • system.adapter.shelly.0 : shelly : buanet-iobroker-1 - enabled, port: 1882, bind: 0.0.0.0
      laut dem biste auf mqtt unterwegs. 6.7.7 ist schon brutal alt.
      ohne infos über die config wirds schwierig.
      kenn mich allerdings mit dem buanet dingens nicht aus, sollte aber keinen unterschied machen.
      FichtendickichtF Offline
      Fichtendickicht
      schrieb am zuletzt editiert von Fichtendickicht
      @da_woody
      6.7.7 war nur testweise. Jetzt ist da lt. diag 10.1.0 drauf.
      Welche iobroker Distro verwendest Du?
      Welche Infos über die Config brauchst Du noch?
      Hier die Docker Config:
      Die IP-Adresse des Cotainers stimmt mit der Adresse im Shelly überein
      • mcm1957M mcm1957
        @fichtendickicht
        Fichtendickicht
        Das ist die Einstellung auf der Shelly.
        Früher stand da mcast drin und hat funktioniert.
          haselchenH Offline
          haselchenH Offline
          haselchen
          @fichtendickicht
          Warum betreibst Du den Container als "bridge"?
          Da musste jeden Port einzeln freigeben.
          • haselchenH haselchen
            @fichtendickicht
            Fichtendickicht
            @haselchen
            Weil unter host viele Ports bereits belegt sind und ich das gar nicht gestartet bekomme.
            Welche Ports muss ich denn freigeben?
            Die habe ich freigegeben:
              @haselchen
              haselchenH Offline
              haselchenH Offline
              haselchen
              @fichtendickicht
              Dann hast Du den Unterschied aber nicht verstanden.
              Unter der IP des Iobroker können die Ports nicht schon vergeben sein.
              Das erledigt der Container von selbst.
              Ein Container (im Host Modus) aufsetzen bzw. starten, da gibt es drölftausend Anleitungen.
                @fichtendickicht
                Fichtendickicht
                @haselchen
                Aha, danke für die Info, muss mich da erst schlau machen. Hab nur die Info dass das nicht geht wegen doppelt verwendeter Ports, und gleichzeitig ist bei EInstellung "host" der Container nach 15 Sekunden abgestürzt und hat neu gebootet.
                  @haselchen
                  @fichtendickicht
                  Eine Frage aus echter Neugier: Warum nutzst du Container, wenn dir anscheinend die Grundlagen fehlen?
                  mcm1957M FichtendickichtF 2 Antworten Letzte Antwort
                    @fichtendickicht
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @fichtendickicht
                    https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md#coap-coiot
                    An shelly fw 1.9.4 geht mcast nicht mehr.
                      @fichtendickicht
                      Fichtendickicht
                      Ich verwende Container seit die DS218+ erschienen ist (nocodb, grafana, iobroker, jenkins, duplicati etc.) und da sind meine Kenntnisse ausreichend gewesen.
                      • mcm1957M mcm1957
                        @fichtendickicht
                        Fichtendickicht
                        @mcm1957
                        Danke da steht´s ja laut und deutlich:
                        "Docker
                        Falls Du ioBroker in einem Docker-Container laufen hast, muss der Container im Netzwerkmodus host oder macvlan konfiguriert sein. Sollte der Docker-Container im Netzwerkmodus bridge laufen, werden keine Shelly-Geräte gefunden."
                        • mcm1957M mcm1957
                          @fichtendickicht
                          Fichtendickicht
                          @mcm1957
                          Ich bekomme den COntainer unter "host" nicht zum Laufen. Der rebootet nach spätestens 60 Sek.
                          • FichtendickichtF Offline
                            Fichtendickicht
                            @mcm1957
                            Verwende diese Firmware:
                            und
                            und habe den Container nun als "iob_public" konfiguriert, was scheinbar den Treiber "mcvlan" verwendet und nun habe ich 2 von 6 Shellys wieder am Adapter sichtbar.
                            Die anderen sind auch so nicht auffindbar, da hats scheinbar was anderes.
                              @fichtendickicht sagte in Shellys (Gen1) nicht mehr auffindbar nach Update:
                              aber warum du Container und z.b. keine VMs nutzst hast du mir nicht beantwortet.
                              Ich hatte immer nur VMs, weil mir Container zu tricky waren.
                              EDIT
                              Docker
                              du nutzst Docker?
                              das muss ich wohl überlesen haben
                                EDIT
                                Docker
                                du nutzst Docker?
                                Fichtendickicht
                                Oh, tut mir Leid, das habe ich nicht explizit im Anfangspost Preis gegeben.
                                Ja ich nutze Docker auf einer Synology DS218+
                                HomoranH haselchenH 2 Antworten Letzte Antwort
                                  @fichtendickicht Eben weil Docker so seine Eigenheiten hat, sollte das immer zu Beginn erwähnt werden
                                  suehe auch
                                    haselchenH Offline
                                    haselchenH Offline
                                    haselchen
                                    @fichtendickicht
                                    Hab genau Dein Setup.
                                    DS218+ und Docker ( Container Manager).
                                    Das Aufsetzen dauerte keine 2 min.
                                    Und wie ich schon schrieb, da gibt es Unmengen von Anleitungen im Netz .
                                    Ich brauche kein MCVlan und hab es auch nicht .
                                    Meine Shellys sind 1. , 2. und 3. Generation.
                                    Läuft alles wie am Schnürchen.
                                      Fichtendickicht
                                      @haselchen
                                      SUper , könntest Du bitte Deine Konfiguration teilen?
                                      Speziell mit dem SQL-Adapter gibts Probleme, der hat nun keinen Zugriff mehr auf MySql unter <NAS-IP>:3307
                                        Fichtendickicht
                                        @haselchen
                                        Ja, aber da kann es zu Portkonflikten kommen:
                                        ioBroker unter Docker auf der Synology DiskStation
                                        "Host
                                        Beim Host Netzwerk erhält der ioBroker Docker Container vollen Zugriff auf die Netzwerkschittstelle(n) der DiskStation. Er kümmert sich selbstständig um die zu öffnenden Ports und lauscht so auch auf alle anderen Pakete die die Netzwerkschnittstelle der DiskStation erreichen. Allerdings kann es hierbei zu Portkonflikten kommen. Dies geschieht, wenn der ioBroker versucht für sich oder einen seiner Adapter einen Port zu öffnen, den vielleicht schon der DiskStation Manager oder einer seiner Services verwendet."
                                          @haselchen
                                          "Host
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          @fichtendickicht
                                          Welcher sollte das bei Dir sein?
