  4. Test Adapter OpenLigaDB
    6.0k
adapteropenligadbtest
716 Beiträge 59 Kommentatoren 222.4k Aufrufe 52 Beobachtet
  • OliverIOO OliverIO
    @meister-mopper
    Dann poste bitte die Konfiguration des Widgets (Widget Export)
    Sowie den Inhalt der eingestellten datenpunkte
    Meister MopperM Online
    Meister Mopper
    #677
    @oliverio
    Das Widget ist:
    [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-allmatches":"openligadb.0.bl1.2025.allmatches","oid-currgameday":"openligadb.0.bl1.2025.currgameday"},"style":{"left":"649px","top":"54px","color":"white","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"large"},"widgetSet":"openligadb"}]
    Datenpunkt ist currgameday.
    Proxmox und HA ...
    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
    OliverIOO 2 Antworten Letzte Antwort
      @oliverio
      Das Widget ist:
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #678
      @meister-mopper
      Allgames?
      Ach dein curgameday ist allgames.
      Meine Adapter und Widgets
      Links im Profil
        @oliverio
        Das Widget ist:
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #679
        @meister-mopper
        Ah jetzt.
        Die Berechnung von curgameday ist falsch. Da wird 34 berechnet.
        Die Anzeige ist damit korrekt, weil es der 16.5.2026 ist.
        Mal schauen, da ist ne Besonderheit von Corona drin, weil damals die Spieltage nicht wirklich immer squenziell abgeschlossen waren.
        Evtl mach ich die wieder raus.
        Ok, der aktuelle Spieltag wird aus der folgenden api entnommen
        https://api.openligadb.de/getcurrentgroup/Bl1
        Ergebnis ist 34
        Beschreibung der api ist
        /getcurrentgroup/{leagueShortcut}
        Gibt die aktuelle Group (entspricht z.B. bei der Fussball-Bundesliga dem 'Spieltag') des als Parameter zu übergebenden leagueShortcuts (z.B. 'bl1') aus. Der aktuelle Spieltag
        wird jeweils zur Hälfte der Zeit zwischen dem letzten Spiel des letzten Spieltages und dem ersten Spiel des nächsten Spieltages erhöht.
        Also 17.5.2025 und 22.8.25
        Also ab ca 5.7.2025 oder so, wenn ich richtig gerechnet habe, müsste dann da 1 kommen
        Links im Profil
        D4vED 1 Antwort Letzte Antwort
          @meister-mopper
          Ah jetzt.
          Ergebnis ist 34
          D4vED Offline
          D4vED Offline
          D4vE
          schrieb am zuletzt editiert von D4vE
          #680
          @oliverio ist bei mir auch so :)
          aber das nächste spiel stimmt schonmal nur das erste nicht ^^ mal gucken ob die das noch fixxen :)
          Iobroker Installation date 2021-08-16
          Platform: linux init system: Docker
          cod.m Zigbee Coordinator: CZC v1.0
          • D4vED D4vE
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #681
            @d4ve
            Solange bei curgameday noch eine hohe Zahl drin steht, klappt die Berechnung nicht. Der 5.7. war grob geschätzt von mir.
            In den nächsten Tagen wird da dann 1 drin stehen.
            Muss mal schauen ob ich da etwas verbessere, aber aktuell sind die Prioritäten nicht bei den Adaptern ☀️😎🚴🏊
            Links im Profil
              @d4ve
              D4vED Offline
              D4vED Offline
              D4vE
              #682
              @oliverio sagte in Test Adapter OpenLigaDB:
              @d4ve
              Supi <3 ne das teil läuft schon super. und hilft mir sehr. danke für die gute Arbeit.
              • OliverIOO Offline
                OliverIOO Offline
                OliverIO
                #683
                So, für bl1 2025/2026 steht jetzt 1 drin.
                Jetzt passt alles.
                Ich überlege mir aber mal was bei Gelegenheit.
                https://github.com/oweitman/ioBroker.openligadb/issues/691
                Links im Profil
                  Jetzt passt alles.
                  Meister Mopper
                  #684
                  @oliverio
                  Durch Zeitablauf erledigt 😊
                  Aus meiner Sicht musste da nüscht ändern.
                  Proxmox und HA ...
                    @oliverio
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #685
                    @meister-mopper
                    Ja, aber es hat schon verwirrt und ich kann schon rausfinden, wenn eine Liga generell noch nicht begonnen hat um das dann auf 1 zu setzen.
                    Links im Profil
                    • OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #686
                      Neue Version 1.9.0
                      • der Abruf erfolgt nun per axios
                      • zur Standardisierung wird nun eine Utility Klasse von mir eingesetzt
                      • Die Funktionsstruktur wurde zu einer Klasse umgearbeitet
                      • von callbacks wurde nun zu async/await gewechselt.
                      • Die Berechnung von Current Gameday, also der aktuelle Spieltag wurde verbessert. Bis zum ersten Spiel wird generell der Spieltag 1 angenommen. Danach wird der von openligadb bereitgestellte Wert verwendet. Der openligadb Wert hat in der Vergangenheit manchmal noch den letzten Spieltag der Vorgängersaison ergeben, da die API hier nicht saison spezifisch ist.
                      Links im Profil
                        Neue Version 1.9.0
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #687
                        Version wird nun demnächst im stable auftauchen
                        Neue Version 1.9.0
                        Links im Profil
                        • OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #688
                          Neue Version 1.9.1
                          • Ein Problem mit Ligen mit leerer Spielliste wurde behoben
                          Links im Profil
                          O 1 Antwort Letzte Antwort
                            Neue Version 1.9.1
                            O Online
                            O Online
                            Oli
                            #689
                            @OliverIO
                            hi, kann ich bei dem Widget der Spieltage, die Farbe der Zeile vom Datum der Spieltage ändern?
                            Oliver
                            • O Oli
                              @OliverIO
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              #690
                              @Oli kannst du bitte mal ein Screenshot machen und markieren was du genau meinst?
                              Links im Profil
                                O Online
                                O Online
                                Oli
                                #691
                                @OliverIO
                                ich möchte bei den gelb markierten Zeilen die Hintergrundfarbe ändern
                                Oliver
                                • O Oli
                                  @OliverIO
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #692
                                  @Oli
                                  das ist recht einfach.
                                  im css reiter einfach die folgende Anweisung eintragen
                                  .oldb-datetime {
                                      color: red;
                                  Links im Profil
                                    @Oli
                                    .oldb-datetime {
                                        color: red;
                                    O Online
                                    O Online
                                    Oli
                                    #693
                                    @OliverIO
                                    super, danke das hab ich soweit hinbekommen und an meine Bedürfnisse anpassen können.
                                    Jetzt habe ich aber noch eine Farge, bekomme ich den Hintergrund der Zeilen auch irgendwie durchgängig geändert, sowie bei den Torschützen?
                                    Oliver
                                    • O Oli
                                      @OliverIO
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      #694
                                      @Oli
                                      das beste ist, das mit den web developer tools des browsers zu untersuchen. die öffnet man entweder mit der F12 Taste oder ungefähr am Ort des Interesses mit der rechten Maustaste und Inspect oder Untersuchen oder so ähnlich je nach Browser.
                                      Ich habe dir mal eine Zeile herauskopiert, da siehst du die verschiedenen css klassen.
                                      Links im Profil
                                        @Oli
                                        O Online
                                        O Online
                                        Oli
                                        #695
                                        @OliverIO
                                        sorry, ich nochmal.
                                        die markierte Spalte bei ".oldb-datetime" hat aber leider keine CSS Klasse, wie mache ich es da?
                                        Oliver
                                        • O Oli
                                          @OliverIO
                                          sorry, ich nochmal.
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #696
                                          @Oli
                                          Da kann man mit den css selektoren spielen.
                                          Entweder
                                          .oldb-tt td {
                                          Um alle td Elemente zu adressieren oder
                                          .oldb-tt tr und tr:first-child Oder eine der anderen pseudo selektoren um die Elemente separat zu treffen
                                          https://wiki.selfhtml.org/wiki/CSS/Selektoren/nth-child
                                          Welchen Stil willst du anwenden?
                                          In der Developer Konsole kannst du die selektoren direkt ausprobieren in dem du bspw
                                          $$(".oldb-tt td") eingibst, dann kommt in einem Array alle Elemente zurück. Durch Klick auf ein Element im Array springt es dann direkt zum Element zum prüfen wo es dann genau liegt
                                          Links im Profil
