  4. Test Adapter OpenLigaDB
    6.0k
adapteropenligadbtest
716 Beiträge 59 Kommentatoren 222.4k Aufrufe 52 Beobachtet
    @oliverio
    Habe den Adapter mal gestoppt und die Objekte gelöscht.
    Nach Adapterneustart beginnt die Saison nach wie vor am 16.05. :man-shrugging:
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #676
    @meister-mopper
    Dann poste bitte die Konfiguration des Widgets (Widget Export)
    Sowie den Inhalt der eingestellten datenpunkte
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO OliverIO
      @meister-mopper
      Meister MopperM Online
      Meister Mopper
      #677
      @oliverio
      Das Widget ist:
      [{"tpl":"tplOLiDBGameDay2","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","maxicon":"25","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"oid-allmatches":"openligadb.0.bl1.2025.allmatches","oid-currgameday":"openligadb.0.bl1.2025.currgameday"},"style":{"left":"649px","top":"54px","color":"white","font-family":"Arial, Helvetica, sans-serif","font-weight":"normal","font-size":"large"},"widgetSet":"openligadb"}]
      Datenpunkt ist currgameday.
      Proxmox und HA ...
      Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
      OliverIOO 2 Antworten Letzte Antwort
        @oliverio
        Das Widget ist:
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #678
        @meister-mopper
        Allgames?
        Ach dein curgameday ist allgames.
        Links im Profil
          @oliverio
          Das Widget ist:
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #679
          @meister-mopper
          Ah jetzt.
          Die Berechnung von curgameday ist falsch. Da wird 34 berechnet.
          Die Anzeige ist damit korrekt, weil es der 16.5.2026 ist.
          Mal schauen, da ist ne Besonderheit von Corona drin, weil damals die Spieltage nicht wirklich immer squenziell abgeschlossen waren.
          Evtl mach ich die wieder raus.
          Ok, der aktuelle Spieltag wird aus der folgenden api entnommen
          https://api.openligadb.de/getcurrentgroup/Bl1
          Ergebnis ist 34
          Beschreibung der api ist
          /getcurrentgroup/{leagueShortcut}
          Gibt die aktuelle Group (entspricht z.B. bei der Fussball-Bundesliga dem 'Spieltag') des als Parameter zu übergebenden leagueShortcuts (z.B. 'bl1') aus. Der aktuelle Spieltag
          wird jeweils zur Hälfte der Zeit zwischen dem letzten Spiel des letzten Spieltages und dem ersten Spiel des nächsten Spieltages erhöht.
          Also 17.5.2025 und 22.8.25
          Also ab ca 5.7.2025 oder so, wenn ich richtig gerechnet habe, müsste dann da 1 kommen
          Links im Profil
          D4vED 1 Antwort Letzte Antwort
            @meister-mopper
            Ah jetzt.
            Ergebnis ist 34
            D4vED Offline
            D4vED Offline
            D4vE
            schrieb am zuletzt editiert von D4vE
            #680
            @oliverio ist bei mir auch so :)
            aber das nächste spiel stimmt schonmal nur das erste nicht ^^ mal gucken ob die das noch fixxen :)
            Iobroker Installation date 2021-08-16
            Platform: linux init system: Docker
            cod.m Zigbee Coordinator: CZC v1.0
            • D4vED D4vE
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #681
              @d4ve
              Solange bei curgameday noch eine hohe Zahl drin steht, klappt die Berechnung nicht. Der 5.7. war grob geschätzt von mir.
              In den nächsten Tagen wird da dann 1 drin stehen.
              Muss mal schauen ob ich da etwas verbessere, aber aktuell sind die Prioritäten nicht bei den Adaptern ☀️😎🚴🏊
              Links im Profil
                @d4ve
                D4vED Offline
                D4vED Offline
                D4vE
                #682
                @oliverio sagte in Test Adapter OpenLigaDB:
                @d4ve
                Supi <3 ne das teil läuft schon super. und hilft mir sehr. danke für die gute Arbeit.
                • OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #683
                  So, für bl1 2025/2026 steht jetzt 1 drin.
                  Jetzt passt alles.
                  Ich überlege mir aber mal was bei Gelegenheit.
                  https://github.com/oweitman/ioBroker.openligadb/issues/691
                  Links im Profil
                    Jetzt passt alles.
                    Meister Mopper
                    #684
                    @oliverio
                    Durch Zeitablauf erledigt 😊
                    Aus meiner Sicht musste da nüscht ändern.
                    Proxmox und HA ...
                      @oliverio
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #685
                      @meister-mopper
                      Ja, aber es hat schon verwirrt und ich kann schon rausfinden, wenn eine Liga generell noch nicht begonnen hat um das dann auf 1 zu setzen.
                      Links im Profil
                      • OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #686
                        Neue Version 1.9.0
                        • der Abruf erfolgt nun per axios
                        • zur Standardisierung wird nun eine Utility Klasse von mir eingesetzt
                        • Die Funktionsstruktur wurde zu einer Klasse umgearbeitet
                        • von callbacks wurde nun zu async/await gewechselt.
                        • Die Berechnung von Current Gameday, also der aktuelle Spieltag wurde verbessert. Bis zum ersten Spiel wird generell der Spieltag 1 angenommen. Danach wird der von openligadb bereitgestellte Wert verwendet. Der openligadb Wert hat in der Vergangenheit manchmal noch den letzten Spieltag der Vorgängersaison ergeben, da die API hier nicht saison spezifisch ist.
                        Links im Profil
                          Neue Version 1.9.0
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #687
                          Version wird nun demnächst im stable auftauchen
                          Neue Version 1.9.0
                          Links im Profil
                          • OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #688
                            Neue Version 1.9.1
                            • Ein Problem mit Ligen mit leerer Spielliste wurde behoben
                            Links im Profil
                            O 1 Antwort Letzte Antwort
                              Neue Version 1.9.1
                              O Online
                              O Online
                              Oli
                              #689
                              @OliverIO
                              hi, kann ich bei dem Widget der Spieltage, die Farbe der Zeile vom Datum der Spieltage ändern?
                              Oliver
                              • O Oli
                                @OliverIO
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #690
                                @Oli kannst du bitte mal ein Screenshot machen und markieren was du genau meinst?
                                Links im Profil
                                  O Online
                                  O Online
                                  Oli
                                  #691
                                  @OliverIO
                                  ich möchte bei den gelb markierten Zeilen die Hintergrundfarbe ändern
                                  Oliver
                                  • O Oli
                                    @OliverIO
                                    OliverIOO Offline
                                    OliverIOO Offline
                                    OliverIO
                                    #692
                                    @Oli
                                    das ist recht einfach.
                                    im css reiter einfach die folgende Anweisung eintragen
                                    .oldb-datetime {
                                        color: red;
                                    Links im Profil
                                      @Oli
                                      .oldb-datetime {
                                          color: red;
                                      O Online
                                      O Online
                                      Oli
                                      #693
                                      @OliverIO
                                      super, danke das hab ich soweit hinbekommen und an meine Bedürfnisse anpassen können.
                                      Jetzt habe ich aber noch eine Farge, bekomme ich den Hintergrund der Zeilen auch irgendwie durchgängig geändert, sowie bei den Torschützen?
                                      Oliver
                                      • O Oli
                                        @OliverIO
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #694
                                        @Oli
                                        das beste ist, das mit den web developer tools des browsers zu untersuchen. die öffnet man entweder mit der F12 Taste oder ungefähr am Ort des Interesses mit der rechten Maustaste und Inspect oder Untersuchen oder so ähnlich je nach Browser.
                                        Ich habe dir mal eine Zeile herauskopiert, da siehst du die verschiedenen css klassen.
                                        Links im Profil
                                          @Oli
                                          O Online
                                          O Online
                                          Oli
                                          #695
                                          @OliverIO
                                          sorry, ich nochmal.
                                          die markierte Spalte bei ".oldb-datetime" hat aber leider keine CSS Klasse, wie mache ich es da?
                                          Oliver
