  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.2k Aufrufe 78 Beobachtet
  • EvilElsE EvilEls
    Nachdem meine Device retry-after: Sperre abgelaufen war (Support nerven), habe ich mir neue IP besorgt und auf https://id.worx.com/user/applications
    die Lagacy App rausgeschmissen.
    Dann im Adapter roten Button, danach Adapter gestartet:
    2025-07-04 00:18:13.524	info	Start Update for all devices
    2025-07-04 00:18:13.523	info	Request Counter: 1
    2025-07-04 00:18:13.244	info	Start check devices object!
    2025-07-04 00:18:13.082	info	Start MQTT connection
    2025-07-04 00:18:13.014	info	Autolock found! Create State : AutoLockTimer
    2025-07-04 00:18:13.013	info	Autolock found! Create State : AutoLock
    2025-07-04 00:18:13.005	info	ACS Module found! Create State : US.ACS_Status
    2025-07-04 00:18:13.002	info	ACS Module found! Create State : US.ACS
    2025-07-04 00:18:12.998	info	ACS Module found! Create State : US
    2025-07-04 00:18:12.991	info	Torque control found, create states...
    2025-07-04 00:18:12.632	info	Create product folder and states for WR165E
    2025-07-04 00:18:12.215	info	Create folder activityLog and set states.
    2025-07-04 00:18:12.204	info	No new Firmware found, create dummy states...
    2025-07-04 00:18:12.201	info	No new Firmware found, check states...
    2025-07-04 00:18:12.193	info	PartyModus found, create states...
    2025-07-04 00:18:12.191	info	OneTimeShedule found, create states...
    2025-07-04 00:18:12.168	info	DoubleShedule found, create states...
    2025-07-04 00:18:11.987	info	Multi-ZoneKeeper found! Create State : zoneKeeper
    2025-07-04 00:18:11.913	info	Found device M with id xxx
    2025-07-04 00:18:11.912	info	Found 1 devices
    2025-07-04 00:18:11.701	info	Connected to worx server
    2025-07-04 00:18:11.114	info	Start login
    2025-07-04 00:18:11.111	info	Login to worx
    2025-07-04 00:18:10.960	info	starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.7
    Kein Fehler mehr.
    Adapter Neustarts ebenfalls problemlos.
    Einstellungen über Adapter ändern klappt auch:
    2025-07-04 00:36:10.999	debug	Test Status: 1
    2025-07-04 00:36:10.966	debug	GET MQTT DATA from API: {xxx}
    2025-07-04 00:36:10.961	debug	Set new timestamp
    2025-07-04 00:36:10.961	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
    2025-07-04 00:36:10.960	debug	Request ID 57099 has been passed to the mower
    2025-07-04 00:36:10.960	debug	Worxcloud MQTT get Message for mower M (xxx)
    2025-07-04 00:36:10.960	debug	topic: PRM100/xxx/commandOut
    2025-07-04 00:36:10.960	debug	Mower MQTT: {xxx}
    2025-07-04 00:36:10.785	debug	Test Status: 1
    2025-07-04 00:36:10.762	debug	GET MQTT DATA from API: {xxx}
    2025-07-04 00:36:10.760	debug	Update this.deviceArray: 0
    2025-07-04 00:36:10.760	debug	Index Update: 0
    2025-07-04 00:36:10.561	info	Start Update for all devices
    2025-07-04 00:36:10.560	debug	Mower Endpoint : iot.eu-west-1.worxlandroid.com with user id xxx and mqtt registered true iot_registered true online true
    2025-07-04 00:36:10.558	debug	MQTT connected to: iot.eu-west-1.worxlandroid.com
    2025-07-04 00:36:10.557	debug	MQTT connection: {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}
    2025-07-04 00:36:10.229	debug	MQTT reconnect
    2025-07-04 00:36:09.228	debug	Offline
    2025-07-04 00:36:09.184	debug	sendData: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
    2025-07-04 00:36:09.184	debug	this.mqtt_response_check: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0},"request":1751582169180,"response":0,"action":"worx.0.xxx.mower.partyModus","user":"iobroker"}}
    2025-07-04 00:36:09.177	debug	lastCommand_start: {"57099":{"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}}
    2025-07-04 00:36:09.176	debug	Start MQTT ping: {"id":57099,"cmd":0,"lg":"de","sn":"xxx","tm":"00:36:09","dt":"04/07/2025","sc":{"m":1,"distm":0}}
    2025-07-04 00:36:09.176	debug	length: 0
    2025-07-04 00:36:09.176	info	Request Counter: 2
    2025-07-04 00:36:09.175	debug	Worxcloud MQTT sendMessage to xxx Message: {"sc":{ "m":1, "distm": 0}}
    2025-07-04 00:36:09.175	debug	state change: id_____ worx.0.xxx.mower.partyModus Mower xxx_____partyModus______{xxx}
    2025-07-04 00:36:09.174	debug	this.modules! {"xxx":{"edgeCut":false,"notify":true,"notify_excluded":["4","5","16","18"],"tq":0,"channel":true,"US":{"enabled":1},"al":{"lvl":0,"t":300},"al_last":300}}
    2025-07-04 00:36:09.174	debug	Request SN: xxx
    App ist seit Tagen deinstalliert.
    Nach Neuinstallation funktioniert diese auch wieder.
    Nachdem ich einen neuen Account erstellt hatte, war ich schon einmal so weit.
    Mal sehen, wie lange das nun funktioniert.
    Letztens hielt es für 3 oder 4 Tage.
    Dette
    #594
    @evilels Genau so habe ich es auch wieder ans Laufen bekommen.
    Schlimm ist nur, dass der Support das mit keiner Silbe erwähnt.
    Und die Frage bleibt, wie lange das "hält", bis die IP Adresse wieder geblockt wird.
    André KoschnikA 1 Antwort Letzte Antwort
    • D Dette
      André KoschnikA Offline
      André Koschnik
      #595
      Nachdem ich mit einer netten Dame von der Hotline gesprochen die das ganze sofort weitergeleitet hat. Da sie mir nicht helfen konnte und ich eine Standardantwort bekommen hatte. Auf die ich höflich, aber gedrungen geantwortet habe, kam dann das ...
      Sehr geehrter Herr xxx,
      vielen Dank, dass Sie sich an den Worx Support gewandt haben.
      Unsere Kollegen an der Fachabteilung arbeiten zurzeit an einer Lösung.
      Wir möchten Sie bitten, sich in Geduld zu begeben. Unser Team wird sich zeitnah um die Angelegenheit kümmern.
      Für Rückfragen stehen wir Ihnen jederzeit zur Verfügung.
      Ihr Worx Support-Team
      Um Ihnen unkompliziert und schnell weiterhelfen zu können, nutzen sie bitte unseren Livechat:
      https://eu.worx.com/de-de/support-fuer-landroid/
      Mit freundlichen Grüßen
      Sofia Müller
      Tel.: +4922195673161
      Mal schauen was zeitnah heißt. Mitte nächster Woche werde ich nochmal nachfragen.
      Für mich ist das eine Unannehmlichkeit die beseitig gehört. Aber man sollte das nicht überbewerten. Ich hoffe es kommt "zeitnah" eine Lösung seitens Worx.
      • N Offline
        N Offline
        nullfreizeit
        #596
        Also - hab jetzt folgendes probiert.
        Adapter von iobroker ausgeschaltet. Auf dem Handy nur Mobile Daten an und auf id.worx.com eingeloggt. Dort Passwort geändert. Dann App auf dem Handy gestartet und die geht zumindest mal wieder.
        Problem: iobroker Adapter geht nicht und sobald ich den anmache (Sitzungsdaten gelöscht) fliege ich wieder aus der App raus.
        Also das oben genannte wiederholt und iobroker erstmal nicht verwenden.
        Fazit: hab jetzt einen smarten Mäher der außer mit der eigenen Cloud zu kommunizieren nicht smart ist. Aber erstmal kann ich ihn wieder nutzen.
        • EvilElsE EvilEls
          Kein Fehler mehr.
          martenn
          #597
          @evilels said in Adapter Worx Landroid v3.x.x:
          Kein Fehler mehr.
          Habe vorhin genau diese Lösung ausprobiert und was soll ich sagen, ich kann wieder per App zugreifen. Den Adapter lasse ich aber zunächst einmal aus.
          • Q Offline
            Q Offline
            quinti
            #598
            Ich war etwa 10 Tage gesperrt. Adapter/App/Webseiten, überall 429.
            Seit Montag läuft bei mir wie alles.Was ich gemacht habe:
            -Iobroker Instanz gestoppt
            -App komplett gelöscht
            -Roboter ausgeschaltet.
            -3 komplette Tage alles ausgelassen und auch kein Einlogversuch gemacht.
            Dann habe mich zunächst auf der worx Seite eingelogt und hab etwas herumgesurft. Da das funktioniert hat, habe ich den Roboter wieder eingeschaltet und von Hand mähen lassen. Während dessen habe ich die App neu installiert. Die lief dann ohne "langsamer". Daten wurden brav angezeigt. Weil auch das geklappt hat, habe ich Adapter komplett gelöscht und die Version 3.2.6 neu installiert. Adapter startete ohne Probleme.
            Seit nun 5 Tagen läuft alles wieder ohne Fehler.
              bubus
              #599
              Das ist schön für euch, aber ich glaube, solange die Sperre nicht abgelaufen oder aufgehoben worden ist, kann ich machen, was ich will:
              Device retry-after: 58d - 10:12:10, zumindest läuft sie runter, hatte schon 62d 😀
              Auf die Antwort meiner 5. Konversation mit dem Suppert warte ich seit 2. Tagen.
              Heute den telefonischen Support gesprochen, das Problem wäre bekannt, es wird daran gearbeitet, ich soll bis Montag abwarten...
              Jetzt sperre ich dem Mäher vom Internet, lösche die App, stoppe den Adapter und warte bis Montag nach 17.00 Uhr.
              Ansonsten rufe ich Dienstag den Support wieder an.
              L 1 Antwort Letzte Antwort
              • M manny4566
                @lucky_esa
                Hi, ja das klappt. Die Webseite geht und ich kann mich normal anmelden. Sie lädt auch schnell im Browser.
                Ganz es sein, dass der Adapter gebremst wird durch z.b. pihole? Der läuft bei mir.
                5000ms ist ja nicht wirklich viel.
                Am nächsten Tag kam der Fehler übrigens nicht mehr. Natürlich samt IP Wechsel in der Nacht.
                L Online
                L Online
                Lucky_ESA
                #600
                @manny4566 sagte in Adapter Worx Landroid v3.x.x:
                @lucky_esa
                Diesen Timeout habe ich gewählt. Wenn du länger als 5 Sekunden benötigst dann stimmt was nicht mit deiner Internetverbindung. Du hast wahrscheinlich WLAN, oder?
                • B bubus
                  L Online
                  L Online
                  Lucky_ESA
                  #601
                  @bubus sagte in Adapter Worx Landroid v3.x.x:
                  Worx Support am besten 10 x pro Tag anrufen. Eine 72 Tage Sperrung ist echt nicht nett.
                  Gruß//Lucky
                  falke69F 1 Antwort Letzte Antwort
                  • L Lucky_ESA
                    Gruß//Lucky
                    falke69F Offline
                    falke69F Offline
                    falke69
                    #602
                    @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                    Gruß//Lucky
                    Guten Morgen @Lucky_ESA
                    Da hast Du Dich aber noch gewählt ausgedrückt mit "nett".
                    Ich finde das es komplett unverschämt ist, überhaupt eine Sperre zu verhängen, ohne den User vorher zu informieren, das er "zuviele" Anfragen stellt.
                    Weiterhin könnte ich mir auch vorstellen, dass die weniger Mäher verkaufen würden, wenn man die Dinger nicht irgendwie in das eigene Smarthome System integrieren kann (auf welche Weise auch immer)
                    Eine 72 Tage Sperre geht überhaupt nicht, ich würde dort permanent Terror machen auch wenn am Ende die an der Hotline nichts dafür können.
                    • Ben1983B Offline
                      Ben1983B Offline
                      Ben1983
                      #603
                      Mit der App komme ich wieder drauf.
                      Den Adapter aus github installieren, oder ist er auf NPM?
                      • falke69F falke69
                        Gruß//Lucky
                        bubus
                        schrieb am zuletzt editiert von bubus
                        #604
                        Zitat falke69:
                        "Weiterhin könnte ich mir auch vorstellen, dass die weniger Mäher verkaufen würden, wenn man die Dinger nicht irgendwie in das eigene Smarthome System integrieren kann"
                        Nur deswegen habe ich mich für den Mäher entschieden!
                        Dr. BakteriusD 1 Antwort Letzte Antwort
                        • B bubus
                          Dr. BakteriusD Online
                          Dr. Bakterius
                          #605
                          • EvilElsE Offline
                            EvilElsE Offline
                            EvilEls
                            #606
                            @saeft_2003 sagte in Adapter Worx Landroid v3.x.x:
                            Der Iobroker darf keinen Zugriff auf die WORX Landroid APP haben.
                            Wenn Sie eine inoffizielle App, Software oder Suite nutzen, sollten Sie diese deinstallieren und vom Roboter trennen. Wir unterstützen nur die offizielle Worx-Landroid-App, die Sie im App Store/Play Store herunterladen können. Die meisten Apps von Drittanbietern können sich negativ auf die Servereinstellungen auswirken, sodass wir sie vorerst nicht unterstützen. Wir weisen darauf hin, dass einige dieser Apps von unseren Sicherheitssystemen als bösartig eingestuft werden könnten, was eine vorübergehende Sperrung des Kontos zur Folge hat.
                            Warum bieten sie dann eine Schnittstelle für Third-Party Apps an? 🤔
                            S falke69F 2 Antworten Letzte Antwort
                            • EvilElsE EvilEls
                              saeft_2003
                              #607
                              @evilels
                              Genau das habe ich auch in meiner Antwort auf diese Mail geschrieben.
                              Zurück kam nur Standard blablabla das ich mich gedulden muss usw…
                              • EvilElsE EvilEls
                                falke69F Offline
                                falke69F Offline
                                falke69
                                #608
                                @evilels
                                Ich finde das es nur eine billige Austede ist.
                                Wenn es den Adapter für Iobroker nicht gäbe würden die Verlaufszahlen sicherlich bescheiden aussehen.
                                Und viele nutzen nur die App und bekommen den selben Mist als Antwort.
                                Die werden ein Problem mit der Cloud oder dem Anbieter der Cloud haben.
                                Alles kostet Geld.
                                Vielleicht haben die auch nur die abgespeckte Version genommen.
                                Aber egal. Es liegt an Worx und nicht an dem Adapter.
                                Ich war wie viele für eine Woche (andere länger) gesperrt und das hatte werder mit dem Adapter noch der App zu tun.
                                Worx hat hier eindeutig die Schuld und ist für den Mist verantwortlich!
                                HomoranH M 2 Antworten Letzte Antwort
                                • falke69F falke69
                                  @evilels
                                  Alles kostet Geld.
                                  #609
                                  @falke69 sagte in Adapter Worx Landroid v3.x.x:
                                  naja, wenn die weltweit in 6 Jahren nur 3200 Mäher verkauft haben sähe es sowieso mau aus
                                  • falke69F falke69
                                    @evilels
                                    Alles kostet Geld.
                                    manny4566
                                    #610
                                    @falke69
                                    Ich glaube der Adapter hat mal so null mit den Verkaufszahlen zu tun :D
                                    • M manny4566
                                      @falke69
                                      falke69F Offline
                                      falke69F Offline
                                      falke69
                                      #611
                                      @manny4566
                                      Es kann jeder für sich entscheiden. Ich hätte mir zum Beispiel das Teil auch nicht gekauft,
                                      wenn ich das Teil nicht irgenwie integriegen hätte können.
                                      Wenn ich das richtig mitgebkommen habe gibt es bei Kress die selben Probleme.
                                      Ich finde immer noch, dass es nicht sein kann das die User ohne Vorwarnung gesperrt werden.
                                      Selbts wenn man 10 oder zwanzig Mäher in der App verwalten würde, würde man laut Worx gesperrt, weil man über seinen Account zu viele Anfragen stellt. Für mich persönlich immer noch unbereiflich und nicht nachvollziehbar.
                                      Ich persönlich habe nicht nur den Mäher, sondern auch noch andere Produkte von Worx, weil ich bisher zufrieden war und auch die Akkus untereinander tauschen konnte.
                                      Aber nach so einem Disaster, was die sich da geleistet haben und die User vor den Kopf gestoßen haben, werde ich warscheinlich nach dem Ablebem meines Mähers mich für einen anderen Hersteller entscheiden.
                                      Wie gesagt, das ist meine persönliche Meinung.
                                        bubus
                                        #612
                                        HA, Alexa-Skill, AvaDeskApp?
                                          BananaJoeB Online
                                          BananaJoeB Online
                                          BananaJoe
                                          #613
                                          @homoran sagte in Adapter Worx Landroid v3.x.x:
                                          In Home Assistant sind es 7205:
                                          Also rund 10.000
                                          Hinzu kommen diejenigen welche z.B. die Pythonsskripte direkt nutzen bzw. andere Smarthome Systeme.
