  4. Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen
    6.6k
bodenfeuchte-sensorengartenbewässerungsprinkle controlwetterabhängig
314 Beiträge 43 Kommentatoren 79.9k Aufrufe 42 Beobachtet
  • T toki1973
    @dirk-peter said in Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen:
    Der Schalter Auto on/off (sprinklecontrol.0.control.autoOnOff) steht auf undefined und wird deshalb als AUS gewertet.
    Danke für die Rückmeldung.
    Und wo habe ich das auf der Oberfläche auf aus gestellt?
    Aktuell schaltet nicht zu einer Uhrzeit ein.
    sprinklecontrol.0
    2024-05-27 12:02:39.165	info	Sprinkle: autoOnOff == Aus ( undefined )
    sprinklecontrol.0
    2024-05-27 12:02:38.795	debug	state sprinklecontrol.0.control.parallelOfMax changed: 0 : 2 (ack = true)
    sprinklecontrol.0
    2024-05-27 12:02:38.794	debug	state sprinklecontrol.0.control.restFlow changed: 1800 (1800 Grundwasser) (ack = true)
    sprinklecontrol.0
    2024-05-27 12:02:36.746	debug	adapter.config.events: [{"enabled":true,"sprinkleName":"DualR2 POWER1","name":"sonoff.0.DualR2.POWER1","triggerID":"","wateringTime":"6","wateringAdd":"100","wateringInterval":"0","addWateringTime":"0","addTriggersIrrigation":"30","maxSoilMoistureIrrigation":"8","maxSoilMoistureRainPct":"120","triggersIrrigation":"50","pipeFlow":"1800","booster":false,"endIrrigation":false,"methodControlSM":"fixDay","inGreenhouse":false,"triggerSM":"","analogZPct":"0","analogOHPct":"100","startDay":"fixDay","sun":true,"mon":true,"tue":true,"wed":true,"thur":true,"fri":true,"sat":true},{"enabled":true,"sprinkleName":"DualR2 POWER2","name":"sonoff.0.DualR2.POWER2","triggerID":"","wateringTime":"8","wateringAdd":"100","wateringInterval":"0","addWateringTime":"0","addTriggersIrrigation":"50","maxSoilMoistureIrrigation":"8","maxSoilMoistureRainPct":"120","triggersIrrigation":"50","pipeFlow":"1799","booster":false,"endIrrigation":false,"methodControlSM":"fixDay","inGreenhouse":false,"triggerSM":"","analogZPct":"0","analogOHPct":"100","startDay":"fixDay","sun":true,"mon":true,"tue":true,"wed":true,"thur":true,"fri":true,"sat":true}]
    sprinklecontrol.0
    2024-05-27 12:02:36.743	debug	Config DualR2__POWER2 created (1) - {"startFixDay":[true,true,true,true,true,true,true],"startDay":"fixDay","enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.DualR2__POWER2.autoOn","objectName":"DualR2__POWER2","objectID":"sprinklecontrol.0.sprinkle.DualR2__POWER2.runningTime","idState":"sonoff.0.DualR2.POWER2","updateStateTimerID":null,"sprinkleID":1,"wateringTime":8,"wateringAdd":100,"wateringInterval":0,"addWateringTime":0,"pipeFlow":1799,"methodControlSM":"fixDay","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":9.6,"triggersIrrigation":4,"pctTriggerIrrigation":50,"pctAddTriggersIrrigation":50}}
    sprinklecontrol.0
    2024-05-27 12:02:36.742	debug	Config DualR2__POWER1 created (0) - {"startFixDay":[true,true,true,true,true,true,true],"startDay":"fixDay","enabled":true,"booster":false,"endIrrigation":false,"autoOn":true,"autoOnID":"sprinklecontrol.0.sprinkle.DualR2__POWER1.autoOn","objectName":"DualR2__POWER1","objectID":"sprinklecontrol.0.sprinkle.DualR2__POWER1.runningTime","idState":"sonoff.0.DualR2.POWER1","updateStateTimerID":null,"sprinkleID":0,"wateringTime":6,"wateringAdd":100,"wateringInterval":0,"addWateringTime":0,"pipeFlow":1800,"methodControlSM":"fixDay","triggerSM":"","inGreenhouse":false,"analogZPct":null,"analogOHPct":null,"soilMoisture":{"val":null,"pct":null,"bool":null,"min":0.08,"maxIrrigation":8,"maxRain":9.6,"triggersIrrigation":4,"pctTriggerIrrigation":50,"pctAddTriggersIrrigation":30}}
    sprinklecontrol.0
    2024-05-27 12:02:36.718	info	starting. Version 0.2.13 in /opt/iobroker/node_modules/iobroker.sprinklecontrol, node: v18.19.1, js-controller: 5.0.17
    Eingestellt ist:
    Tauchpumpe: Durchflussmenge = 1800 l/h
    Ventil 1: Durchflussmenge = 1800 l/h ; Bewässerungszeit = 5min
    Ventil 2: Durchflussmenge = 1799 l/h ; Bewässerungszeit = 6 min
    Und eine Start Uhrzeit
    Intervall steht auf 0
    Nun schaltet der Adapter abwechselnd Ventil 1 und Ventil 2 aus und ein - die Pumpe aber nicht.
    Dirk PeterD Online
    Dirk PeterD Online
    Dirk Peter
    #291
    @toki1973
    Hallo Schau mal unter Objekte
    Hier hast du einen Schalter unter control / autoOnOff. Dieser muss im Automatikmodus auf Auto(true) stehen. Ansonsten kannst du nur manuell wässern in dem du eine Zahl z.B. 5 unter runningTime eingibst. jetzt würdest du diesen Kreis für 5:00 Minuten wässern.
    MfG Dirk Peter
    frana120500F 1 Antwort Letzte Antwort
    • Dirk PeterD Dirk Peter
      @toki1973
      MfG Dirk Peter
      frana120500F Offline
      frana120500
      #292
      ich teste gerade den Sprincle Adapter und habe das Problem, dass er zur angegebenen Zeit einschaltet, nach der eingestellten Bewässerungszeit Kreis 1 abschaltet und auf Kreis 2 wechselt, aber er schaltet Kreis 2 nicht ab nach der Bewässerungszeit. Beide Kreise haben exakt die gleichen Einstellungen.
      Ich habe zwei Hunter Ventile, also 2 Kreise, an einem Sonoff 4ch Pro, jeweils NC, also stromlos geschlossen.
      Habe ein seeeehr umfangreiches Script zur Bewässerung, würde das jedoch versuchen durch den Adapter abzulösen.
      Jemand ne Idee warum die Abschaltung vom 2. Kreis nicht funktioniert, das einschalten jedoch schon?
      Danke euch.
      464952390_8607492346001320_2183244827881634000_n.jpg F.
      Dirk PeterD 1 Antwort Letzte Antwort
      • frana120500F frana120500
        Danke euch.
        Dirk PeterD Online
        Dirk PeterD Online
        Dirk Peter
        #293
        @frana120500
        Hallo frana120500,
        was wurde denn protokolliert und hast du auch eine Konfiguration für mich!
        Dirk Peter
          @frana120500
          Hallo frana120500,
          Dirk Peter
          frana120500
          #294
          @dirk-peter Moin, protokolliert wurde mE garnix zum Ausschaltzeitpunkt. Ich teste es aber nochmal. Konfiguration sh. Bilder
            Dirk PeterD Online
            Dirk PeterD Online
            Dirk Peter
            #295
            @frana120500
            Hallo, unter Protokolle sollte es so in etwa aussehen!
            Das ein und ausschalten der Steuerspannung (voltage) und der Pumpe (pump) könnten bei dir fehlen, wenn du keinen Aktor angegeben hast.
            Deine Konfiguration bekommst du unter Instanzen => Einstellungen oben rechts als Download. Mit dieser könnte ich deinen Adapter sehr schnell testen. Deine Einstellungen sehen so erstmal gut aus.
            Wenn du unter sprinklecontrol.0.sprinkle.Kreis_1.runningTime eine Zahl eingibst z.B. 2 so startet dieser Kreis für 2 min.
            !!! Verwende bitte bei deinen Namen keine Leertasten! Dies kann zu Fehlern im Betrieb führen.
            Dirk Peter
              Matt77CHE
              #296
              ist es eigentlich möglich ein Hauptventil hinzuzufügen (Ventil vor der Pumpe)?
              • M Matt77CHE
                Dirk PeterD Online
                Dirk PeterD Online
                Dirk Peter
                #297
                @matt77che Ich weiß nicht ganz was du damit erreichen möchtest! Aber das Hauptventil müsste ja dann einschalten , wenn die Pumpe läuft und ausgehen wenn die Pumpe ausgeschaltet wird. Also klemm das Ventil doch einfach auf die Pumpe mit drauf.
                  Matt77CHE
                  #298
                  @dirk-peter sagte in Test Adapter Sprinkle Control 0.2.x mit neuen Funktionen:
                  Wie meinst du das? - Wortwörtlich geht nicht.
                  Per extra-Script die beiden verknüpfen? - Schön wäre es, wenn man nicht immer noch nebenbei-Scripte am laufen haben müsste....
                  Könnte ja auch im Adapter eine Position geben...
                  • ioT4dbI Online
                    ioT4dbI Online
                    ioT4db
                    schrieb am zuletzt editiert von ioT4db
                    #299
                    Hallo @dirk-peter,
                    ich bekomme an manchen Tagen über Pushover viele ähnliche Meldungen kurz hintereinander. Bspw.: "Sprinkle Control Cistern Filled 13 % (8%)"
                    Heute morgen waren es ca. 90 Stück so jede Minute eine 🤔 .
                    Mein Füllstandssensor schwankt manchmal um ein % herum.
                    Wann genau wird denn diese Meldung ausgelöst?
                    Danke schonmal und VG
                    Daniel
                    Dirk PeterD 3 Antworten Letzte Antwort
                    • ioT4dbI ioT4db
                      Hallo @dirk-peter,
                      Daniel
                      Dirk PeterD Online
                      Dirk PeterD Online
                      Dirk Peter
                      #300
                      @iot4db Ja du hast recht, das kann ganz schön nerven! Versuche es noch vor meinem Urlaub zu ändern. Denke wenn eine Meldung kommt das die Zisterne wieder bereit zum Bewässern ist, reicht vollkommen aus.
                      • ioT4dbI ioT4db
                        Hallo @dirk-peter,
                        Daniel
                        Dirk PeterD Online
                        Dirk PeterD Online
                        Dirk Peter
                        #301
                        @iot4db Eine Frage noch: Welche Version verwendest du? Bei 0.2.17 kommt jedenfalls nur eine Meldung beim überschreiten des Mindestfüllstandes + 5%.
                        ioT4dbI 1 Antwort Letzte Antwort
                          ioT4dbI Online
                          ioT4dbI Online
                          ioT4db
                          #302
                          @dirk-peter hi, ich nutze die 0.2.17
                          • ioT4dbI ioT4db
                            Dirk PeterD Online
                            Dirk PeterD Online
                            Dirk Peter
                            #303
                            @iot4db Eigenartig bei mit kommt die Meldung nur einmal und zwar wenn die Zisterne wieder von Grundwasserversorgung zu Zisternenversorgung umspringt. Also nur einmal bei einem Füllstand von Mindestfüllstand plus 5%, also mit einer Hysterese von 5%. Ich denke deine Zisterne bräuchte eine größere Hysterese. Mal sehen was ich da machen kann.
                              Aktuelle Test Version 0.2.x
                              Veröffentlichungsdatum 27.06.2021
                              Github Link https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol
                              Latest Version 0.2.11 ab 22.05.2022
                              Beschreibung https://github.com/Dirk-Peter-md/ioBroker.sprinklecontrol/blob/master/docs/de/sprinklecontrol.md
                              Hallo, jetzt kommen die Bodenfeuchte-Sensoren [analog, bistabil] und das Wochenprogramm [Bewässerung mit festen Tagen (ohne Sensoren)] für den Adapter "Sprinkle Control" zur Gartenbewässerung
                              Die gewünschten Bodenfeuchte-Sensoren habe ich jetzt integriert, aber ich brauch eure Hilfe, da ich keine Sensoren zum Testen besitze.
                              Besten Dank für die Hilfe im Voraus!
                              Einstellungen in der Konfiguration
                              1. Zusätzliche Einstellungen
                              • hier kann ein Schwellwert für die Wettervorhersage eingestellt werden damit die Bewässerung nicht verschoben wird wenn es kaum Regnet.
                              1. Bewässerungskreis bearbeiten => Haupteinstellungen => Einschaltpunkt zum Gießen
                                Hier kann unter Methode zur Kontrolle der Bodenfeuchtigkeit folgende Auswahl getroffen werden:
                                • Berechnung der Verdunstung
                                • Bodenfeuchtesensor bistabil
                                • Bodenfeuchtesensor analog
                              2.1 Berechnung der Verdunstung
                              • hier wird die Verdunstung intern durch die Wetterstation ermittelt. Es läuft also für diesen Kreis alles wie bisher!
                              2.2 Bodenfeuchtesensor bistabil
                              • Eingangssignal bistabil (true|false)
                              • interne Umwandlung in true = 0% und false = 100%
                              • sollte kein Signal ausgelesen werden können 50%
                              • bei 0% wird der Bewässerungskreis beim nächsten Start eingeschaltet mit der vorgegebenen Bewässerungszeit
                              • Sensor im Gewächshaus => bei Auswahl wird die Wettervorhersage nicht berücksichtigt
                              2.3 Bodenfeuchtesensor analog
                              • Eingangssignal analog mit offenen Wertebereich
                              • interne Umwandlung in 0 ... 100%, hierzu muss unbedingt eingegeben werden
                                • analoger Bodenfeuchtesensor bei 0 Prozent (Sensor in der Luft) => kleinster möglicher Wert für 0 %
                                • analoger Bodenfeuchtesensor bei 100 Prozent (Sensor im Wasser) => größter möglicher Wert für 100 %
                              • Einschaltpunkt in % => bei Unterschreitung wird der Bewässerungskreis beim nächsten Start eingeschaltet
                              • Bewässerungszeit wird verlängert je weiter der Einschaltpunkt unterschritten wird.
                              2.4 Start an festen Wochentagen (ohne Sensoren)
                              Ihr habt hier zur Auswahl
                              • Drei Tage Rhythmus → Der 1. Tag der Bewässerung ist der Folgetag, nach dem Speichern der Konfiguration, und dann jeden 3. Tag in Folge.
                              • Jeden zweiten Tag → Der 1. Tag der Bewässerung ist der Folgetag, nach dem Speichern der Konfiguration, und dann jeden 2. Tag in Folge.
                              • An festen Tagen starten → Die Bewässerungstage werden individuell nach Wochentagen bestimmt.
                                Info → Die Bewässerungsdauer wird Verlängert siehe Doku (Beschreibung auf GitHub).
                              Ich hoffe ich habe an alles gedacht und richtig programmiert, meldet bitte die Fehler die Auftreten, da ich keine Sensoren für Tests besitze. Wenn die ersten Tests positiv sind, so werde ich wieder im Latest(beta) veröffentlichen und die Doku aktualisieren. Danke für die mithilfe
                              sigi234S Online
                              sigi234S Online
                              #304
                              @dirk-peter
                              Hallo, kannst du da ev. helfen?
                              https://forum.iobroker.net/topic/64734/support-adapter-energiefluss-erweitert-v0-7-7/12?_=1751228470980
                              • ioT4dbI ioT4db
                                Hallo @dirk-peter,
                                Daniel
                                Dirk PeterD Online
                                Dirk PeterD Online
                                Dirk Peter
                                #305
                                @iot4db 0.2.18 ist jetzt am Start.
                                Änderung Einschalthysterese der Zisterne auf 20% erhöht. Damit sollte die Meldung nur noch einmal erfolgen.
                                ioT4dbI 2 Antworten Letzte Antwort
                                  ioT4dbI Online
                                  ioT4dbI Online
                                  ioT4db
                                  #306
                                  @dirk-peter super, ich teste...
                                    ioT4dbI Online
                                    ioT4dbI Online
                                    ioT4db
                                    #307
                                    @dirk-peter hallo Dirk,
                                    ich denke die letzte Anpassung ist, scheinbar für mein Setup, nicht die Lösung.
                                    Heute bspw. wurde duch die zus. Hysterese von 20% verhindert, dass SprinkleControl bewässert. siehe Screenshot.
                                    Ich versuche mal etwas detailierter mein Setup zu beschreiben.
                                    • ich habe keine Hauptpumpe, nur eine Zisternenpumpe
                                    • die Nachspeisung wir durch ein extra Blockly realisiert > ab 10% wird nachgespeist bis die Zisterne 20% hat (ich will die Zisterne immer nur soweit nachfüllen wie nötig, um für Regenfälle "platz" zu haben)
                                    • in Sprinklecontrol habe ich 8% eingestellt, was theoretisch nie erreicht wird, wenn die Nachspeisung richtig funktioniert (die 8% sind also eine Art Not-Sperre)
                                    Ich bin jetzt erstmal zurück auf die 0.2.17
                                    • ioT4dbI ioT4db
                                      Dirk PeterD Online
                                      Dirk PeterD Online
                                      Dirk Peter
                                      #308
                                      @iot4db Als Lösung sehe ich nur eine individuelle Eingabe der Hysterese. Diese könnte man in der Konfiguration ablegen.
                                      Was deine Schwankungen des Füllstandes angeht, so solltest du vielleicht über eine Glättung der Werte nachdenken.
                                      Übrigens bei meinem Füllstandsensor HM-Sen-Wa-Od habe ich auch ab und zu extreme Schwankungen,
                                      aber dann wird nur auf die Grundwasserpumpe umgeschaltet und gut ist es.
                                      Aber zurück zum Thema, versuche es mit der individuelle Eingabe der Hysterese bis zum Wochenende umzusetzen.
                                        ioT4dbI Online
                                        ioT4dbI Online
                                        ioT4db
                                        #309
                                        @dirk-peter alles klar, danke.
                                        wie groß war die Standard-Hyterese in 0.2.17? 5%?
                                        ich hab erstmal den Stand auf 4% runtergesetzt, damit sollten ja (zum Test mit der 0.2.17) die vielen Meldungen nicht mehr kommen...
                                        • ioT4dbI ioT4db
                                          Dirk PeterD Online
                                          Dirk PeterD Online
                                          Dirk Peter
                                          #310
                                          @iot4db Ja die 0.2.17 waren 5%. Mache es jetzt individuell einstellbar.
