  4. Tester Zigbee Adapter 3.x gesucht
zigbeezigbee adapter
259 Beiträge 27 Kommentatoren 66.5k Aufrufe 38 Beobachtet
  • arteckA arteck
    @bigmike71 der war zwar da aber hat die gleiche funktion gehabt wie das allgmeine Pairing..
    den haben wir ausgebaut...
    hast du auch mal die Sensoren aufgeweckt da wo die sind ?? es reicht manchmal nicht einfach nur abzuwarten
    Eduard77E Online
    Eduard77E Online
    Eduard77
    schrieb am zuletzt editiert von Eduard77
    #165
    @arteck
    Ich habe wieder versucht Vibrationssensor zu koppeln. (https://forum.iobroker.net/topic/80035/tester-für-zigbee-adapter-2-0-x-gesucht/524?_=1750953573650)
    Aber jedes Mal wenn ich den koppeln will, stürzt ZigBee Adapter v3 ab.
    Mein Debug LOG ist recht Groß:
    host.DebianIO LOG.txt, 2025-06-26 175036.959 - debug zigbe.txt
    2025-06-26 17:50:36.959 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":64,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:36.960 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
    2025-06-26 17:50:36.961 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953036959,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":64,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:36.979 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":64,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:36.980 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":64,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:50:39.960 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":65,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:39.960 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
    2025-06-26 17:50:39.961 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953039960,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":65,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:39.967 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":65,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:39.968 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":65,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:50:39.968 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:42.961 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":66,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:42.962 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
    2025-06-26 17:50:42.962 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953042961,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":66,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:42.969 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":66,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:42.970 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":66,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:50:44.780 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c987c SNZB-03P was last seen '231.914' seconds ago.
    2025-06-26 17:50:44.783 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x08ddebfffed98402 SNZB-02P was last seen '640.874' seconds ago.
    2025-06-26 17:50:44.785 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c9f4e SNZB-03P was last seen '2056.22' seconds ago.
    2025-06-26 17:50:44.786 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c138ba25a96096 TY0201 was last seen '1592.687' seconds ago.
    2025-06-26 17:50:44.790 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c1389e3efbd451 TY0201 was last seen '25.904' seconds ago.
    2025-06-26 17:50:44.791 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x286847fffe753954 TS0601 was last seen '930.545' seconds ago.
    2025-06-26 17:50:44.794 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x187a3efffe39a1e4 SWV was last seen '82.87' seconds ago.
    2025-06-26 17:50:45.574 - info: javascript.0 (389) script.js.VIS.View_wechsel: View to check:Samsung_TAB/Haupmenu
    2025-06-26 17:50:45.575 - info: javascript.0 (389) script.js.VIS.View_wechsel: View found in:0
    2025-06-26 17:50:45.967 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":67,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:45.967 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
    2025-06-26 17:50:45.968 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953045967,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":67,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":67,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:45.971 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":67,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:50:48.970 - debug: zigbee.0 (239349) handleMessage. {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":68,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:48.970 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'commandQueryNextImageRequest', cluster 'genOta', data '{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102}' from endpoint 1 with groupID 0
    2025-06-26 17:50:48.971 - debug: zigbee.0 (239349) Type commandQueryNextImageRequest device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"commandQueryNextImageRequest","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":1}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953048970,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"fieldControl":0,"manufacturerCode":4742,"imageType":2060,"fileVersion":4102},"linkquality":102,"groupID":0,"cluster":"genOta","meta":{"zclTransactionSequenceNumber":68,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}}}
    2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) No converter available for 'SNZB-06P' '08ddebfffe0fefec' with cluster 'genOta' and type 'commandQueryNextImageRequest'
    2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:50:48.974 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":68,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:50:48.975 - debug: zigbee.0 (239349) value generated '"{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":0,\"manufacturerCode\":4742,\"imageType\":2060,\"fileVersion\":4102},\"linkquality\":102,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":68,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":true,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:50:48.975 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:51:39.929 - debug: zigbee.0 (239349) handleMessage. {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":62,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":102,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":69,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
    2025-06-26 17:51:39.930 - debug: zigbee.0 (239349) Received Zigbee message from '0x08ddebfffe0fefec', type 'attributeReport', cluster 'msOccupancySensing', data '{"occupancy":0}' from endpoint 1 with groupID 0
    2025-06-26 17:51:39.931 - debug: zigbee.0 (239349) Type attributeReport device {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":69,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["occupancy"]},{"key":["occupancy_timeout"]},{"key":["occupancy_sensitivity"]},{"key":["illumination"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"msOccupancySensing","type":["attributeReport","readResponse"],"options":[{"name":"no_occupancy_since","label":"No occupancy since","access":2,"type":"list","property":"no_occupancy_since","description":"Sends a message after the last time no occupancy (occupancy: false) was detected. When setting this for example to [10, 60] a `{\"no_occupancy_since\": 10}` will be send after 10 seconds and a `{\"no_occupancy_since\": 60}` after 60 seconds.","item_type":{"name":"time","label":"Time","access":3,"type":"numeric"}}]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"1030","type":["attributeReport","readResponse"]},{"cluster":"64529","type":["attributeReport","readResponse"]}],"exposes":[{"name":"occupancy","label":"Occupancy","access":5,"type":"binary","property":"occupancy","description":"Indicates whether the device detected occupancy","value_on":true,"value_off":false},{"name":"occupancy_timeout","label":"Occupancy timeout","access":7,"type":"numeric","property":"occupancy_timeout","description":"Unoccupied to occupied delay","value_max":65535,"value_min":15},{"name":"occupancy_sensitivity","label":"Occupancy sensitivity","access":7,"type":"enum","property":"occupancy_sensitivity","description":"Sensitivity of human presence detection","values":["low","medium","high"]},{"name":"illumination","label":"Illumination","access":1,"type":"enum","property":"illumination","description":"Only updated when occupancy is detected","values":["dim","bright"]}],"ota":true,"zigbeeModel":["SNZB-06P"],"model":"SNZB-06P","vendor":"SONOFF","description":"Zigbee occupancy sensor","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x08ddebfffe0fefec"} incoming event: {"type":"attributeReport","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":18,"_applicationVersion":1,"_dateCode":"20231213","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":263,"inputClusters":[0,3,1030,1280,64599,64529],"outputClusters":[3,25],"profileID":260,"ID":1,"clusters":{"64529":{"attributes":{"8193":1}},"genBasic":{"attributes":{"modelId":"SNZB-06P","manufacturerName":"SONOFF","powerSource":4,"zclVersion":3,"appVersion":1,"hwVersion":0,"dateCode":"20231213","swBuildId":"1.0.6"}},"ssIasZone":{"attributes":{"iasCieAddr":"0x00124b002f8f72e0","zoneState":1}},"msOccupancySensing":{"attributes":{"ultrasonicUToOThreshold":2,"occupancy":0}}},"deviceIeeeAddress":"0x08ddebfffe0fefec","deviceNetworkAddress":47765,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x08ddebfffe0fefec"}}],"_hardwareVersion":0,"_ieeeAddr":"0x08ddebfffe0fefec","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1750953099928,"_manufacturerID":4742,"_manufacturerName":"SONOFF","_modelID":"SNZB-06P","_networkAddress":47765,"_powerSource":"DC Source","_softwareBuildID":"1.0.6","_type":"Router","_zclVersion":3,"_linkquality":102,"_skipDefaultResponse":false,"_lastDefaultResponseSequenceNumber":69,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"endpoint":"[Circular]","data":{"occupancy":0},"linkquality":102,"groupID":0,"cluster":"msOccupancySensing","meta":{"zclTransactionSequenceNumber":69,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}}}
    2025-06-26 17:51:39.933 - debug: zigbee.0 (239349) message received '{"linkquality":102}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated '102' from device 08ddebfffe0fefec for 'Link quality'
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) message received '{"msg_from_zigbee":"{\"type\":\"attributeReport\",\"data\":{\"occupancy\":0},\"linkquality\":102,\"groupID\":0,\"cluster\":\"msOccupancySensing\",\"meta\":{\"zclTransactionSequenceNumber\":69,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated '"{\"type\":\"attributeReport\",\"data\":{\"occupancy\":0},\"linkquality\":102,\"groupID\":0,\"cluster\":\"msOccupancySensing\",\"meta\":{\"zclTransactionSequenceNumber\":69,\"frameControl\":{\"frameType\":0,\"manufacturerSpecific\":false,\"direction\":1,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}"' from device 08ddebfffe0fefec for 'Message from Zigbee'
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) message received '{"occupancy":false}' from device 08ddebfffe0fefec type 'SNZB-06P'
    2025-06-26 17:51:39.934 - debug: zigbee.0 (239349) value generated 'false' from device 08ddebfffe0fefec for 'Occupancy'
    2025-06-26 17:51:39.935 - debug: zigbee.0 (239349) No value published for device 08ddebfffe0fefec
    2025-06-26 17:51:44.781 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c987c SNZB-03P was last seen '291.915' seconds ago.
    2025-06-26 17:51:44.783 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x08ddebfffed98402 SNZB-02P was last seen '700.874' seconds ago.
    2025-06-26 17:51:44.785 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x0ceff6fffe7c9f4e SNZB-03P was last seen '2116.22' seconds ago.
    2025-06-26 17:51:44.786 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c138ba25a96096 TY0201 was last seen '1652.687' seconds ago.
    2025-06-26 17:51:44.791 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0xa4c1389e3efbd451 TY0201 was last seen '85.905' seconds ago.
    2025-06-26 17:51:44.792 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x286847fffe753954 TS0601 was last seen '990.546' seconds ago.
    2025-06-26 17:51:44.794 - debug: zigbee.0 (239349) DeviceAvailability:Non-pingable device 0x187a3efffe39a1e4 SWV was last seen '142.87' seconds ago.
    Eduard77E 1 Antwort Letzte Antwort
    • Eduard77E Eduard77
      @arteck
      Eduard77E Online
      Eduard77E Online
      Eduard77
      #166
      @arteck
      Oder ist das Sensor kaputt und lässt das Adapter anstürzen?
      kein anderes Gerät, was ich erfolgreich gekoppelt habe, hat Adapter zum Abstürzt gebracht.
      Danke für deine Mühe
      Eduard
        @arteck
        Eduard
        AlexHaxe
        #167
        @edis77 said in Tester Zigbee Adapter 3.x gesucht:
        @arteck
        Deine herdsman Konverter sind mit 23.13.0 relativ alt. Wenn ich die Commit-Historie richtig lese, dann wird Dein Gerät frühestens mit Version 23.44.0 unterstützt.
        • Eduard77E Online
          Eduard77E Online
          Eduard77
          #168
          @alexhaxe
          Wo kann ich diese Info finden und was kann man machen.
          EDIT:
          Hab ich diese Info im Log gefunden.
          Installed Version: iobroker.zigbee@latest (Converters 23.13.0 Herdsman 3.3.2)
          Also lasse ich den Sensor liegen. Bis es Kompatibel wird.
          • AsgothianA Asgothian
            @hadebe der externe Konverter ist ein Stück Software welches du ggf. Eingetragen hast um den Sensor unterstützt zu bekommen. Bitte prüfen. Doku dazu siehe Doku auf GitHub.
            Hadebe
            #169
            @asgothian Da es wohl keinen externen Konverter in meiner Installation gibt, woran könnte es noch liegen, dass das Gerät unerkannt bleibt?
            • H Hadebe
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #170
              @hadebe Installier bitte die Version vonGitHub. Dann sollte zumindest der Fehler weg sein. Ob Dein Gerät in der da heran gezogenen ZHC version unterstützt ist weiss ich nicht - es ist aber fraglich.
              A.
              H 1 Antwort Letzte Antwort
                A.
                Hadebe
                #171
                @asgothian Ergebnis wie vorher, Pairing wird gestartet, aber unsupported device:
                2025-06-29 10:54:55.526 - info: zigbee.0 (1106366) 0x54ef44100123779e (addr 28846): Unsupported (model lumi.sensor_ht.agl001)(EndDevice)
                Laut Z2M wird das Gerät unterstützt (hatte Homoran auch schon bestätitgt).
                Muss ich jetzt nur auf eine aktueller ZHC warten oder was kann ich noch machen?
                Eduard77E AsgothianA 2 Antworten Letzte Antwort
                • H Hadebe
                  Eduard77E Online
                  Eduard77E Online
                  Eduard77
                  #172
                  @hadebe
                  Du hast das gleich Problem wie ich oben.
                  Dein Gerät wird frühestens mit Version 23.36.0 unterstützt.
                  • H Hadebe
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    #173
                    @hadebe auf GitHub gibt es seit heute einen Branch der immer die latest ZHC nutzt. Du kannst diesen installieren - allerdings ist das aktuell nicht aktiv getestet, da ich für die kommenden 6 Wochen keine Tests durchführen kann.
                    Link zur Installation ist:
                    https://github.com/ioBroker/ioBroker.zigbee/tarball/ZHC_latest
                    Wichtig: Die ZHC Version die installiert wird hängt davon ab zu welchem Zeitpunkt diese Version installiert wird. Ansonsten bleibt der Adapter-Code synchron zum Hauptzweig. Ich kann aber nicht garantieren das durch Anpassungen am ZHC sich etwas verändert.
                    Ansonsten kannst du versuchen einen externen Konverter für das Gerät zu bauen. Das erfordert etwas wissen in JS. Der Normale Weg ist:
                    • im Qelltext der ZHC den Converter finden
                    • Identifizieren welche Includes / Requires dieser benötigt (alles in der gleichen Datei)
                    • Aus diesen Daten eine JS Datei wie im Spoiler als Beispiel hinterlegt erzeugen
                    const tuya = require('zigbee-herdsman-converters/lib/tuya');
                    const modernExtend = require('zigbee-herdsman-converters/lib/modernExtend');
                    const {deviceEndpoints, onOff} = require('zigbee-herdsman-converters/lib/modernExtend');
                    const exposes = require("zigbee-herdsman-converters/lib/exposes");
                    const ea = exposes.access;
                    const e = exposes.presets;
                    const definition = {
                       zigbeeModel: ['TS000F'], // The model ID from the device.
                       model: 'TS000F',
                       vendor: 'inventwo',
                       description: '1-Kanal-Relais mit DS18B20',
                       fingerprint: [{modelID: 'TS000F', manufacturerName: '_TZ3218_7fiyo3kv'}], // This helps z2m identify the device
                       fromZigbee: [tuya.fz.datapoints], // Define converters that are used to convert from Zigbee messages to MQTT messages.
                       toZigbee: [], // Define converters that are used to convert from MQTT messages to Zigbee messages.
                       extend: [
                           deviceEndpoints({"endpoints":{"0":0,"1":1}}),
                           onOff({"powerOnBehavior":false,"endpointNames":["1"]}),
                           // tuya.modernExtend.dpTemperature({dp: 0x66, scale: 10})
                        exposes: [
                           e.temperature().withDescription('inventwo Innenraum'),
                       ], // Defines what capabilities (like temperature or on/off) are exposed to MQTT
                       meta: {
                           multiEndpoint: true,
                           tuyaDatapoints: [
                               [102, 'temperature', tuya.valueConverter.divideBy10]
                       configure: async (device, coordinatorEndpoint, logger) => {
                           const endpoint = device.getEndpoint(1);
                           await endpoint.bind('genOnOff', coordinatorEndpoint);
                           // More configurations can be added here
                    module.exports = definition;
                    • diese Datei im Zigbee Datenverzeichnis ablegen (/opt/iobroker/iobroker-data/zigbee_0)
                    • den Dateinamen in der Adapter-Konfig unter 'external converters' ablegen.
                    • Adapter neu starten, und im Log prüfen ob er geladen wird.
                    A.
                      @hadebe
                      Hadebe
                      #174
                      @edis77 Das ist ein sehr guter Tip, danke dafür. Wie bei dir 23.13.0
                      Nachdem ich wie von @Asgothian vorgeschlagen von github den Adapter installiert habe, sieht die ZHC Welt besser aus:
                      2025-06-29 10:50:55.502 - info: zigbee.0 (1106116) Installed Version: ioBroker/ioBroker.zigbee (Converters 23.35.0 Herdsman 4.0.0)
                      Das ist zwar gut, aber noch knapp vor der von @Edis77 zitierten. Ich warte dann weiter...
                           model: 'TS000F',
                           vendor: 'inventwo',
                           extend: [
                            exposes: [
                           meta: {
                               tuyaDatapoints: [
                        A.
                        Hadebe
                        #175
                        @asgothian habe deinen Link bei "Adapter installieren" > "aus eigener URL" >"benutzerdefiniert" eingegeben (so war es vermutlich gemeint). Leider wird die selbe Konverter Version angezogen wie bei Installation von github:
                        2025-06-30 08:29:21.581 - info: zigbee.0 (1183192) Installed Version: ioBroker/ioBroker.zigbee#ZHC_latest (Converters 23.35.0 Herdsman 4.0.0)
                        Habe ich dich richtig verstanden, dass unter deinem Link häufiger Updates erfolgen als im github Hauptzweig, d.h. ich würde die Installation in ein paar Tagen wiederholen und hätte eine höhere Version?
                        Und danke für deinen Versuch meine Skills auf einen neuen Level zu heben, aber mein Wissen über JS bewegt sich nah bei Null
                        Ansonsten bleibt für mich warten.
                        • AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #176
                          @hadebe da muss bei deiner Installation etwas schief gegangen sein. Eigentlich solltest du ZHC 23.66.0 bekommen haben.
                          Bitte unter /opt/iobroker/node-modules prüfen welche ZHC versione(en) installiert sind.
                          Eduard77E H 2 Antworten Letzte Antwort
                            Eduard77E Online
                            Eduard77E Online
                            Eduard77
                            schrieb am zuletzt editiert von Eduard77
                            #177
                            @asgothian
                            ich habe jetzt von deinem Github Link installiert und bei mir sieht es jetzt so aus.
                            zigbee.0 2025-06-30 09:07:29.423	info	Installed Version: ioBroker/ioBroker.zigbee#ZHC_latest (Converters 23.67.0 Herdsman 4.0.0)
                              Hadebe
                              schrieb am zuletzt editiert von Hadebe
                              #178
                              @asgothian dein Link funktioniert offensichtlich. War mein Vorgehen korrekt?
                              Bin in dem Verzeichnis, aber wie finde ich die Version - in package.json ist nur 23.35.0 eingetragen?
                              • H Hadebe
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                #179
                                @hadebe du musst über npm auf der Konsole auflisten lassen welche version(en) installiert sind - es kann mehrere geben. Ich hab den Befehl nicht im Kopf und kann das auch nicht mal eben prüfen, sorry.
                                A.
                                GaspodeG H 2 Antworten Letzte Antwort
                                  A.
                                  GaspodeG Offline
                                  GaspodeG Offline
                                  Gaspode
                                  schrieb am zuletzt editiert von Gaspode
                                  #180
                                  @asgothian said in Tester Zigbee Adapter 3.x gesucht:
                                  @hadebe
                                  z.B. so:
                                  npm ls zigbee-herdsman-converters
                                    A.
                                    Hadebe
                                    #181
                                    @Asgothian bei mir ist nur die ältere Version vorhanden:
                                    pi@raspi01:/opt/iobroker/node_modules $ npm ls zigbee-herdsman-converters
                                    iobroker.inst@3.0.0 /opt/iobroker
                                    └─┬ iobroker.zigbee@3.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#ae472aefab7fbb3c70b56d3c477662e265e52f03)
                                      └── zigbee-herdsman-converters@23.35.0
                                    • GaspodeG Gaspode
                                      @hadebe
                                      z.B. so:
                                      Hadebe
                                      #182
                                      @gaspode danke, da hätte ich lange forschen müssen
                                      • H Hadebe
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #183
                                        @hadebe bitte nochmal vom gleichen link installieren. Du solltest jetzt eine neuere Version bekommen.
                                        H Eduard77E 2 Antworten Letzte Antwort
                                          Hadebe
                                          #184
                                          @asgothian Super! So geht's.
                                          └─┬ iobroker.zigbee@3.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#7a9fc13062e49f8aea5b8e7b5cccfb4f90d45b3c)
                                            └── zigbee-herdsman-converters@23.67.0
                                          Mit der neuen Version wird auch das Gerät erkannt
