  4. jarvis v3.1.x - just another remarkable vis
1.9k Beiträge 94 Kommentatoren 927.4k Aufrufe 77 Beobachtet
  • S Stadtschloss
    ich würde gerne mein IKEA Tredansen Rollo als BlindLevelAction Trigger einfügen in dem StateList Widget. Leider bekomme ich das einfach nicht hin... könnt ihr mit weiterhelfen?
    Das ist der Objektbaum vom Rollo:
      "zigbee.0.b4e3f9fffe528XXX": {
        "type": "device",
        "common": {
          "name": "Wohnzimmer Rollo Rechts",
          "type": "E2103",
          "icon": "img/E2103.png",
          "statusStates": {
            "onlineId": "zigbee.0.b4e3f9fffe528XXX.available"
          "modelIcon": "https://www.zigbee2mqtt.io/images/devices/E2103.png"
        "native": {
          "id": "b4e3f9fffe528XXX"
        "from": "system.adapter.zigbee.0",
        "user": "system.user.admin",
        "ts": 1749842556131,
        "_id": "zigbee.0.b4e3f9fffe528XXX",
        "acl": {
          "object": 1636,
          "owner": "system.user.admin",
      "zigbee.0.b4e3f9fffe528XXX.available": {
        "type": "state",
        "common": {
          "name": "Available",
          "type": "boolean",
          "read": true,
          "write": false,
          "role": "state"
        "native": {},
        "ts": 1743693233611,
        "_id": "zigbee.0.b4e3f9fffe528XXX.available",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": true,
        "ack": true
      "zigbee.0.b4e3f9fffe528XXX.battery": {
        "type": "state",
        "common": {
          "name": "Battery percent",
          "type": "number",
          "unit": "%",
          "read": true,
          "write": false,
          "role": "value.battery",
          "min": 0,
          "max": 120,
          "icon": "img/battery_p.png"
        "native": {},
        "ts": 1747980451501,
        "_id": "zigbee.0.b4e3f9fffe528XXX.battery",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": 120,
        "ack": true
      "zigbee.0.b4e3f9fffe528XXX.device_query": {
        "type": "state",
        "common": {
          "name": "Trigger device query",
          "type": "boolean",
          "read": false,
          "write": true,
          "role": "button"
        "native": {},
        "ts": 1743693232861,
        "_id": "zigbee.0.b4e3f9fffe528XXX.device_query",
        "acl": {
          "object": 1636,
          "state": 1636,
      "zigbee.0.b4e3f9fffe528XXX.identify": {
        "type": "state",
        "common": {
          "name": "Initiate device identification",
          "type": "string",
          "states": {
            "identify": "identify"
          "read": true,
          "write": true,
          "role": "state"
        "native": {},
        "ts": 1749842559467,
        "_id": "zigbee.0.b4e3f9fffe528XXX.identify",
        "acl": {
          "object": 1636,
          "state": 1636,
      "zigbee.0.b4e3f9fffe528XXX.link_quality": {
        "type": "state",
        "common": {
          "name": "Link quality",
          "type": "number",
          "read": true,
          "write": false,
          "role": "state",
          "min": 0,
          "max": 255
        "native": {},
        "_id": "zigbee.0.b4e3f9fffe528XXX.link_quality",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": 69,
        "ack": true
      "zigbee.0.b4e3f9fffe528XXX.msg_from_zigbee": {
        "type": "state",
        "common": {
          "name": "Message from Zigbee",
          "type": "string",
          "read": true,
          "write": false,
          "role": "state"
        "native": {},
        "_id": "zigbee.0.b4e3f9fffe528XXX.msg_from_zigbee",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": "{\"type\":\"commandQueryNextImageRequest\",\"data\":{\"fieldControl\":1,\"manufacturerCode\":4476,\"imageType\":4487,\"fileVersion\":604241936},\"linkquality\":69,\"groupID\":0,\"cluster\":\"genOta\",\"meta\":{\"zclTransactionSequenceNumber\":54,\"frameControl\":{\"frameType\":1,\"manufacturerSpecific\":false,\"direction\":0,\"disableDefaultResponse\":false,\"reservedBits\":0}},\"endpoint_id\":1}",
        "ack": true
      "zigbee.0.b4e3f9fffe528XXX.position": {
        "type": "state",
        "common": {
          "name": "Position of this cover",
          "type": "number",
          "unit": "%",
          "read": true,
          "write": true,
          "role": "state",
          "min": 0,
          "max": 100
        "native": {},
        "_id": "zigbee.0.b4e3f9fffe528XXX.position",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": 100,
        "ack": true
      "zigbee.0.b4e3f9fffe528XXX.send_payload": {
        "type": "state",
        "common": {
          "name": "Send to Device",
          "type": "string",
          "read": true,
          "write": true,
          "role": "state"
        "native": {},
        "_id": "zigbee.0.b4e3f9fffe528XXX.send_payload",
        "acl": {
          "object": 1636,
          "state": 1636,
      "zigbee.0.b4e3f9fffe528XXX.state": {
        "type": "state",
        "common": {
          "name": "state",
          "type": "string",
          "states": {
            "OPEN": "OPEN",
            "CLOSE": "CLOSE",
            "STOP": "STOP"
          "read": true,
          "write": true,
          "role": "switch"
        "native": {},
        "_id": "zigbee.0.b4e3f9fffe528XXX.state",
        "acl": {
          "object": 1636,
          "state": 1636,
        "val": "OPEN",
        "ack": false
    Nur welche werte muss ich hier eintragen? Hoch und runter funktioniert. Aber der Stop button meldet "true" auf dem State statt "STOP"
    MCU
    #1799
    @stadtschloss Mach mal bitte ein GIF (screenToGif) und zeige was beim State passiert wenn du STOP auf der Fernbedienung drückst und was passiert, wenn du STOP beim State auswählst.
    • M MCU
      Stadtschloss
      #1800
      @mcu Habe keine Fernbedienung verbunden. Der State nimmt folgendes an: "CLOSE" "OPEN" und "STOP".
      Close - Schließt das Rollo
      Open - Öffnet das Rollo
      Stop - Unterbricht den Verfahrvorgang des Rollos
      Wenn ich Stop in Jarvis drücke, wird "true" in den State bei meiner aktuellen Config eingegeben.
      • S Stadtschloss
        MCU
        #1801
        @stadtschloss Ok, man braucht für den STOP-Vorgang einen eigenen DP. Die Logik muss man sich dann im Programm aufbauen. Kannst du das? Hast du mehrere von den zigbee Rollos im Einsatz?
        Beispiel für ein Rollo
        den DP 0_userdata.0.jarvis.zigbeeRollo.stop muss man dann in jarvis zuordnen
        // zigbeeRollo v1.0.0
        // Zigbee Rollos mit einem STATE-DP zigbee.0.bxxxxx.state OPEN,CLOSE,STOP
        let zigbeeRolloDP   = '0_userdata.0.jarvis.zigbeeRollo'
        let jarvisStopDP    = zigbeeRolloDP + '.stop'
        let stateDP         = zigbeeRolloDP + '.stateDP'
        createStateAsync(jarvisStopDP,           {read: true, write: true, name: "STOP für Jarvis", desc:'', type: "boolean", role: "", def: false });
        createStateAsync(stateDP,           {read: true, write: true, name: "STATE vom Rollo", desc:'', type: "string", role: "", def: '' });
        on({id: jarvisStopDP, change: "any"}, function (obj) {
            let value = obj.state.val;
            if(value){
                let dp = getState(stateDP).val
                setState(dp, 'STOP',true)
                setTimeout(()=>{
                    setState(jarvisStopDP, false,true)
                },500)
        • H Offline
          Hohenbostler
          #1802
          Hi zusammen. Ich bin ( glaube ich ) auf der V3.2 R17 . Und seit ewigen Monaten möchte ich mal wieder Geräte prüfen un importieren. Leider bekomme ich aber keine Geräte angezeigt.
          Die Konsole zeigt mir folgende Meldungen:
          Jemand eine Ahnung wo das Problem ist ? Den Roborock habe ich schon seit ewigkeiten nicht mehr. Theoretisch aber noch die als Seite im Jarvis von ihm.
          Vielleicht hat ja jemand eine Ahnung
          • H Hohenbostler
            MCU
            #1803
            @hohenbostler
            Hab ich noch nicht gesehen. Im ioBroker.log ein Hinweis?
            Versuche
            • Sprache verstellen -> F2 - Einstellungen
            • Jarvis-Instanz neu starten
            • evtl auf der console ein Upload durchführen
            iob upload jarvis
            H 1 Antwort Letzte Antwort
            • M MCU
              @hohenbostler
              Versuche
              iob upload jarvis
              Hohenbostler
              #1804
              @mcu
              Danke für die Antwort.
              Log ist fehlerfrei. Sprache mal testweise auf englisch gestellt. Instanz neugestartet. Problem besteht weiterhin.
              Zurück auf deutsch. Instanz neu gestartet leider weiterhin das Problem.
              • H Hohenbostler
                @mcu
                MCU
                #1805
                @hohenbostler Dann versuch mal ein Upload
                siehe oben
                oder über die Adapter
                • M MCU
                  siehe oben
                  Hohenbostler
                  #1806
                  @mcu
                  pload [15] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [14] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [13] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [12] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [11] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [10] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                  upload [9] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [8] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [7] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [6] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [5] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/index.html index.html text/html
                  upload [4] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/jarvis.png jarvis.png image/png
                  upload [3] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/bootstrap.min.css lib/bootstrap.min.css text/css
                  upload [2] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/bootstrap.min.js lib/bootstrap.min.js application/javascript
                  upload [1] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/lib/jquery-3.7.1.min.js lib/jquery-3.7.1.min.js application/javascript
                  upload [0] jarvis.admin /opt/iobroker/node_modules/iobroker.jarvis/admin/words.js words.js application/javascript
                  Updating objects from io-package.json for adapter "jarvis" with version "3.2.0-rc.17"
                  upload [205] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/index.html index.html text/html
                  upload [200] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/apple-touch-icon-ipad.png jarvis/apple-touch-icon-ipad.png image/png
                  upload [150] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set1_1.1593123e.png jarvis/assets/weather_set1_1.1593123e.png image/png
                  upload [100] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set5_14.894b9d30.png jarvis/assets/weather_set5_14.894b9d30.png image/png
                  upload [90] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/assets/weather_set5_6.2c556b53.png jarvis/assets/weather_set5_6.2c556b53.png image/png
                  upload [80] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icon-192x192.png jarvis/icon-192x192.png image/png
                  upload [70] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/drawable-hdpi/ic_launcher.png jarvis/icons/android/drawable-hdpi/ic_launcher.png image/png
                  upload [60] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/mipmap-hdpi/ic_launcher_foreground.png jarvis/icons/android/mipmap-hdpi/ic_launcher_foreground.png image/png
                  upload [50] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/android/mipmap-xxxhdpi/ic_launcher.png jarvis/icons/android/mipmap-xxxhdpi/ic_launcher.png image/png
                  upload [40] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/icon-1024x1024.png jarvis/icons/icon-1024x1024.png image/png
                  upload [30] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-29.png jarvis/icons/ios/AppIcon-29.png image/png
                  upload [20] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-60@3x~car.png jarvis/icons/ios/AppIcon-60@3x~car.png image/png
                  upload [19] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon-83.5@2x~ipad.png jarvis/icons/ios/AppIcon-83.5@2x~ipad.png image/png
                  upload [18] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@2x.png jarvis/icons/ios/AppIcon@2x.png image/png
                  upload [17] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@2x~ipad.png jarvis/icons/ios/AppIcon@2x~ipad.png image/png
                  upload [16] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon@3x.png jarvis/icons/ios/AppIcon@3x.png image/png
                  upload [15] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon~ios-marketing.png jarvis/icons/ios/AppIcon~ios-marketing.png image/png
                  upload [14] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/ios/AppIcon~ipad.png jarvis/icons/ios/AppIcon~ipad.png image/png
                  upload [13] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/README.txt jarvis/icons/web/README.txt text/plain
                  upload [12] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/apple-touch-icon.png jarvis/icons/web/apple-touch-icon.png image/png
                  upload [11] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/favicon.ico jarvis/icons/web/favicon.ico image/vnd.microsoft.icon
                  upload [10] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-192-maskable.png jarvis/icons/web/icon-192-maskable.png image/png
                  upload [9] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-192.png jarvis/icons/web/icon-192.png image/png
                  upload [8] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-512-maskable.png jarvis/icons/web/icon-512-maskable.png image/png
                  upload [7] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/icons/web/icon-512.png jarvis/icons/web/icon-512.png image/png
                  upload [6] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/index.html jarvis/index.html text/html
                  upload [5] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/app.hash.json jarvis/js/app.hash.json application/json
                  upload [4] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/app.licences.json jarvis/js/app.licences.json application/json
                  upload [3] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/jarvis/js/index-259e1438.js jarvis/js/index-259e1438.js application/javascript
                  upload [2] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.hash.json js/app.hash.json application/json
                  upload [1] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/js/app.licences.json js/app.licences.json application/json
                  upload [0] jarvis /opt/iobroker/node_modules/iobroker.jarvis/www/user/example.js user/example.js application/javascript
                  Leider erfolglos. Geräte noch immer leer
                  • H Hohenbostler
                    @mcu
                    MCU
                    #1807
                    @hohenbostler Hast du Systemupdates gemacht?
                    Zwischen dem Zeitpunkt wo noch alles funktioniert hat und jetzt
                    • M MCU
                      Hohenbostler
                      #1808
                      @mcu
                      Wie gesagt ich habe nach neuen Geräten seit Monaten wenn nicht sogar 1-2 Jahren eigentlich nicht geschaut.
                      Iobrokder updates in der Zeit einige.
                      PlatformBetriebssystem:linux
                      Architektur:x64
                      CPUs:4
                      Geschwindigkeit:3100 MHz
                      Modell:Intel(R) Core(TM) i3-8100T CPU @ 3.10GHz
                      RAM:8 GB
                      System-Betriebszeit:7 T. 02:54:38
                      Node.js:v20.19.2
                      Zeit:1751047866852
                      Zeitversatz:-120
                      NPM:10.8.2
                      Adapter-Anzahl:569
                      Datenträgergröße:29.4 GB
                      Freier Festplattenspeicher:15.3 GB
                      Aktive Instanzen:39
                      Pfad:/opt/iobroker/
                      Betriebszeit:7 T. 02:54:36
                      aktiv:true
                      _nodeCurrent:20.19.2
                      _nodeNewest:20.19.3
                      _nodeNewestNext:20.19.3
                      _npmCurrent:10.8.2
                      _npmNewest:10.8.2
                      _npmNewestNext:10.8.2
                      • H Hohenbostler
                        @mcu
                        Architektur:x64
                        CPUs:4
                        RAM:8 GB
                        Node.js:v20.19.2
                        Zeit:1751047866852
                        Zeitversatz:-120
                        NPM:10.8.2
                        Adapter-Anzahl:569
                        Aktive Instanzen:39
                        Pfad:/opt/iobroker/
                        aktiv:true
                        _nodeNewest:20.19.3
                        _npmCurrent:10.8.2
                        _npmNewest:10.8.2
                        MCU
                        #1809
                        @hohenbostler Hast du mal ein komplett-Neustart vom System durchgeführt?
                        Wenn nein, dann vorher system updates machen, es gibt schon neuere Version
                        Du klickst hier?
                        • M MCU
                          Du klickst hier?
                          Hohenbostler
                          #1810
                          @mcu
                          System sicher auch schon x mal neu gestartet
                          ja genau da und dann wird dort nichts angezeigt
                          • H Hohenbostler
                            @mcu
                            MCU
                            #1811
                            @hohenbostler Hast du in der Zeit neue Adapter installiert? Ich vermute es hat mit irgendeiner nicht gesetzten Übersetzung zu tun.
                            i18n -> Internationalisierung - Übersetzung von Begriffen
                            • M MCU
                              Hohenbostler
                              #1812
                              @mcu
                              Hey sorry für die späte Antwort.
                              Also sicherlich gibt es adapter die ich installiert habe. Wie gesagt das ist ja schon ewig so.
                              • H Hohenbostler
                                @mcu
                                MCU
                                #1813
                                @hohenbostler Dann bitte als Issue in github eintragen. Danke.
                                U 1 Antwort Letzte Antwort
                                • M MCU
                                  U Offline
                                  U Offline
                                  uwe72
                                  #1814
                                  @mcu wollte fragen, ob man die Buttons von ihrer Bedeutung her "umdrehen" kann?
                                  d.h. aktuell geht "hoch" auf 100 und "runter" auf 0. Da es eine Markise ist, wäre anders herum intuitiver.
                                  Danke!
                                  • U uwe72
                                    Danke!
                                    MCU
                                    #1815
                                    @uwe72
                                    https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/styles/blindlevelaction-rollladen/button-tauschen
                                    Bedeutung? Evtl mit min und max in Datenpunkt-Eigenschaft ändern
                                    R 1 Antwort Letzte Antwort
                                    • M MCU
                                      @uwe72
                                      R Online
                                      R Online
                                      reutli
                                      #1816
                                      @mcu & all
                                      irgendwie habe ich bei Jarvis 3.x den Überblick verloren... Habe seit langem die 3.1.9beta am Laufen (wurde mir damalas aus einem Grund empfohlen, den ich nicht mehr weiss), mehr oder weniger stabil.
                                      Habe komische "Sprünge" in der VIS auf dem Smartphone (iPhone), wenn ich längere Widgetseiten habe und auf einen Knopf z.B. "hoch-/runter Button" drücke. Dann scrollt die Seite, statt den Button zu bedienen (nein, ist nicht am Rand ;o)
                                      Das sind aber nur Kleinigkeiten.
                                      Was mich mehr interessiert ist die Frage, nach DER stabilen letzten empfohlenen Version und wie es hier weiter geht? Ich sehe unzählige Alphas, Betas und RCs in Github, unzählige issues.
                                      Ich bin mir bewusst (habe selbst einmal angefangen einen Adapter zu schreiben und dann aufgegeben wegen Zeit und skill) was es heisst ein solches Projekt zu warten und am Laufen zu halten. Dennoch möchte ich als Verwender natürlich wisse, woran ich bin und ob hier noch was entwickelt wird und ggf. zu einer stabilen Version kommt.
                                      Das ist eine offene Frage ohne Vorwurf oder Ähnlichem (bevor ich hier "gesteinigt" werde)!
                                      Ich fand/finde Jarvis aber so einfach un intuitiv, dass es für mich schade wäre, wenn ich hier weg müsste. Ich brauche keine visuell tolle Visualisierung, sondern etwas, das einfach und schnell konfiguriert ist und leicht zu verwenden ist - genau das ist Jarvis für mich heute.
                                      Also konkret:
                                      1. welches ist die am besten laufenden Version mit dem höchsten Stand an funktionierenden Kompromissen?
                                      2. ist diese Version irgendwo dokumentiert/so benannt?
                                      3. im Stable steht die 3.1.8 - warum? hier gibt/gab es doch bedeutende Fehler, oder?
                                      4. Könnte man eine Doku aufsetzen, welche Versionen welche Vor- und Nachteile haben? Das hilft dem Anwender ggf. die zu wählen, mit der er am wenigsten auf Fehler läuft
                                      5. Gibt es die Pro Version im eigenlichen Sinn noch?
                                      6. wer pflegt den Adapter noch?
                                      Danke.
                                      Gruss
                                      Micha
                                      iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                      *Wer freundlich ist, dem wird freundlich geholfen *
                                      • R reutli
                                        @mcu & all
                                        Also konkret:
                                        Danke.
                                        Gruss
                                        Micha
                                        MCU
                                        #1817
                                        @reutli
                                        • zu 1: zurzeit (21.09.2025) v3.2.0-rc.17, grundsätzlich immer die neueste Version, da dort Fehler behoben werden "sollten", die es in einer Vorgängerversion gab. Leider gibt es Versionen, die dann wieder andere Fehler hervorbringen. Ist bei der Komplexität halt nicht so einfach, dazu kommen Änderungen von nodejs und ioBroker usw.
                                        • zu 2: ja, Infos zur v3.2. Beta
                                        • zu 3: Weil der Entwickler (zefau) es so entschieden hat. Diskussionen waren damals nicht möglich.
                                        • zu4: Auf keinen Fall, da Jeder in einer Version noch andere Fehler entdeckt und dann hätte man eine Empfehlung gegeben und der User ärgert sich, hat leider auch schon gegeben bei einigen Versionen.
                                        • zu 5: Ja, wer scripts usw nutzen möchte muss weitherin bezahlen (12€ / Jahr)
                                        • zu 6: Zefau, mal mehr mal weniger, zurzeit weniger. Zu sehen unter : https://github.com/Zefau
                                        • M MCU
                                          @reutli
                                          R Online
                                          R Online
                                          reutli
                                          #1818
                                          @mcu
                                          Danke für Deine Antworten! Also nichts Neues 😕
                                          Trotzdem noch eine konkrete Nachfrage:
                                          Ich setze die 3.1.9beta ein. Läuft die 3.2.0-rc.17 so gut und welches sind die 'known issues'? Da das Downgrade nichts so einfach ist, würde ich das Risiko gerne abwägen. Sonst müsste ich ein testsystem aufbauen...
                                          Danke.
