  3. Entwicklung
  4. Adapter Worx Landroid v3.x.x
    6.3k
814 Beiträge 91 Kommentatoren 248.0k Aufrufe 78 Beobachtet
  • N NewPaint2
    Ich weiß nicht ob es hilft, bei mir kam die Meldung am 14.06.2025 das erste mal mitten in der Nacht. Schaut mal ob ihr weiter damit kommt.
    2025-06-14 23:30:54.639  - info: worx.0 (258859) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.2, js-controller: 7.0.7
    2025-06-14 23:30:54.839  - info: worx.0 (258859) Use new aws-iot-device-sdk-v2.
    2025-06-14 23:30:54.840  - info: worx.0 (258859) Changed timeout for edgecut to 5000
    2025-06-14 23:30:54.842  - info: worx.0 (258859) Login to worx
    2025-06-14 23:30:55.004  - warn: javascript.0 (258721) getState "worx.0.2020302091010020598D.mower.status" not found (3)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at HandleScreensaverUpdate (script.js.common.NSPanel.NSPanelTS-test:12672:31)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at Object.<anonymous> (script.js.common.NSPanel.NSPanelTS-test:4043:17)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at step (script.js.common.NSPanel.NSPanelTS-test:33:23)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at Object.next (script.js.common.NSPanel.NSPanelTS-test:14:53)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at script.js.common.NSPanel.NSPanelTS-test:8:71
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at new Promise (<anonymous>)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at __awaiter (script.js.common.NSPanel.NSPanelTS-test:4:12)
    2025-06-14 23:30:55.005  - warn: javascript.0 (258721)     at Object.<anonymous> (script.js.common.NSPanel.NSPanelTS-test:4039:12)
    2025-06-14 23:30:55.283  - error: worx.0 (258859) AxiosError: Request failed with status code 429
    2025-06-14 23:30:55.286  - error: worx.0 (258859) "429 TOO MANY REQUESTS"
    2025-06-14 23:30:55.294  - info: worx.0 (258859) Start login
    2025-06-14 23:30:55.584  - error: worx.0 (258859) AxiosError: Request failed with status code 429
    2025-06-14 23:30:55.584  - error: worx.0 (258859) "429 TOO MANY REQUESTS"
    2025-06-14 23:30:55.726  - error: worx.0 (258859) AxiosError: Request failed with status code 429
    2025-06-14 23:30:55.726  - error: worx.0 (258859) "429 TOO MANY REQUESTS"
    2025-06-14 23:30:55.747  - info: worx.0 (258859) Start MQTT connection
    2025-06-14 23:30:55.748  - warn: worx.0 (258859) No mower found to start mqtt
    2025-06-14 23:30:55.752  - info: worx.0 (258859) Start check devices object!
    #324
    Was heisst in diesem Log eigentlich
    @newpaint2 sagte in Adapter Worx Landroid v3.x.x:
    ist der state oder der Wert nicht da?
    N 1 Antwort Letzte Antwort
      N Offline
      N Offline
      NewPaint2
      #325
      @homoran Gute Frage... das war das erste mal wo sich der worx Adapter im Log gemeldet hatte. In den States befindet er sich, warum er hier "daneben greift..." kann ich nicht beantworten. Bei mir war das auch jedes Mal wenn die App mal ging das der Roboter weg war und ich musste den mit dem QR Code verbinden. Der Mower ist ein WR153e aus 2019, vielleicht schränkt das über die Jahrgänge der Geräte etwas die Fehlersuche ein.
      • L Lucky_ESA
        @armilar Danke werde mal schauen aber nach einem iob Neustart wird diese aufgeräumt, glaube ich.
        Hattest du auch die 3.2.3 installiert gehabt?
        @NewPaint2 Wechsel bitte auf die 3.2.4 - Wird auch bald als Stable angeboten.
        Gruß//Lucky
        N Offline
        N Offline
        NewPaint2
        #326
        @lucky_esa es war die 3.2.3, den Wechsel habe ich schon gemacht jetzt ist alles auf 3.2.4 aber da flieg ich mit einem Start mit Fehler 429 raus. Mein Anbieter ist die Telekom, öffentlich erreichbare IP-Nummer hinter einer Fritzbox. Mower ist ohne Probleme im W-Lan und hat auch keine Ecken wo er dieses nicht erreicht.
        • L Lucky_ESA
          Gruß//Lucky
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          Most Active Forum Testing
          #327
          @lucky_esa
          Werde die 26h erneut starten. Die App brachte die gleichen Sperr-Infos. War dann am rätseln, bis meine Frau dann sagte, dass ihre App auch Probleme macht 😖
          Also jetzt ist ihre auch gelöscht 😊
          • BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            #328
            Ich habe zwar heute gerade endlich den Draht verlegt und gerade erst meinen WR169E eingerichtet, aber eventuell kann ich etwas beisteuern.
            Ich musste ja meine Email-Adresse bestätigen, danach war ich auf der Webseite
            https://id.worx.com/login
            Dort kann man dann unter Applications sehen was mit dem Gerät verbunden ist - und den Zugriff zurückziehen.
            Wie sieht es da bei euch aus? Der Adapter müsste ja entweder als Android-Gerät oder etwas anderes dort auftauchen.
            • BananaJoeB BananaJoe
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #329
              @bananajoe
              Keine Chance… Die Webseite wird bei uns nicht geladen und zeigt den Fehler 429. Benutzt Du eine andere (zuvor ungenutzte IP) ist spätestens mit dem Login die IP auch gesperrt…
              GarganoG BananaJoeB 2 Antworten Letzte Antwort
              • ArmilarA Armilar
                @bananajoe
                GarganoG Offline
                GarganoG Offline
                Gargano
                #330
                @armilar ,@bananajoe, @Lucky_ESA
                Interessantes Verhalten :
                Ich komme mit Chrome, Edge oder FF nicht auf https://id.worx.com/login.
                Wie erwähnt der Fehler 429
                Mit den Tor-Browser komme ich jedoch drauf.
                Schaut dann so aus :
                • ArmilarA Armilar
                  @bananajoe
                  BananaJoeB Offline
                  BananaJoeB Offline
                  BananaJoe
                  #331
                  @armilar das passt zu der Annahme das nicht Worx sperrt sondern zuvor schon Cloudflare als Sicherheitsdienstleister
                  Bei mir wäre das schlecht - ich habe eine feste IP-Adresse ...
                  Der a.nel.cloudflare.com aus dem Screenshot ( dieser Post: https://forum.iobroker.net/post/1278181) ist zumindest sowohl über IPv4 als auch IPv6 erreichbar
                  EvilElsE 1 Antwort Letzte Antwort
                  • GarganoG Gargano
                    BananaJoeB Offline
                    BananaJoeB Offline
                    BananaJoe
                    #332
                    @gargano 5 Stück? Wobei 2 habe ich jetzt auch schon, die App auf meinem Handy und nachdem ich das Produkt registriert habe auch noch https://account.worxlandroid.com/
                    GarganoG 1 Antwort Letzte Antwort
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      #333
                      @bananajoe
                      Ich komme auch mit dem Tor-Browser auf meinen Account.
                      Was macht denn das Revoke Access genau ? Ich habe kein IOS-Gerät
                      Vielleicht versucht es auch mal ein anderer mit dem Tor-Browser.
                      • L Lucky_ESA
                        das neue Release 3.0.0 ist nun raus. Die Leute die mit latest unterwegs sind sollten nun ein Update sehen.
                        Ihr könnt euch bei @hsteinme bedanken, der seine komplette Freizeit geopfert hat meine Änderungen zu testen und mir jede Menge Ideen geliefert hat.
                        Des Weiteren hat er uns alle Infomationen zur Verfügung gestellt wie z. Bsp. alle Status-/Errormeldungen und CMD Commands.
                        Nun zu den Neuerungen:
                        Folgender Softwarestand ist erforderlich:
                        Node 18 oder 20 (18 wird empfohlen)
                        JS-Controller >= 5.0.19
                        Admin >=6.13.16
                        Der Crash node_modules/aws-crt/dist/bin/ wird nun abgefangen und dann die alte Verbindung verwendet. Wie bereits beschrieben trennt Worx diese jede 15 Minute aber die Reconnection habe ich von 5 Sekunden auf 1 Sek. reduziert.
                        Logeintrag beim Start - Use new aws-iot-device-sdk-v2. -> Neue Verbindung mit Zwangstrennung jede Stunde
                        Logeintrag beim Start - Use old aws-iot-device-sdk. Please cleanup your System with iob fix !!!! -> Alte Verbindung mit Zwangstrennung alle 15 Minuten
                        Linux User sollten mit iob fix das Problem lösen können aber bei Windows hilft wohl nur eine komplette Deinstallation von iob und Node.
                        Viele Fixed die über Sentry eingegangen sind.
                        10 Minuten Ping in der Instanzeistellung entfernt (war unötig - weiterhin kann worx.0.xxx.mower.mqtt_update verwendet werden)
                        Draht Mäher:
                        Statusmeldung angepasst
                        Errormeldungen angepasst
                        sendCommand angepasst (CMD)
                        Vision Mäher:
                        Status Headlight in mower hinzugefügt (und nein, die kann man nicht ein/ausschalten)
                        Modul Höhe Mähwerk hinzugefügt
                        Dynamischer calendar hinzugefügt (hier hat sich die Struktur geändert. Es müssen alle Blocklys und Scripte anngepasst werden)
                        Ordner areas entfernt (Es müssen alle Blocklys und Scripte anngepasst werden)
                        Neuer Ordner multiZones hinzugefügt
                        cutOverSlabs hinzugefügt
                        cameraStatus hinzugefügt
                        cameraError hinzugefügt
                        firmware_body hinzugefügt
                        firmware_head hinzugefügt
                        Neue cmd (sendCommand) hinzugefügt
                        und alles was ich vergessen habe hinzugefügt...Einfach in die Anleitung schauen.
                        Der cmd Befehl 0 ist für ein Update der Mqtt Daten. Dieser ist weiterhin deaktiviert da ihr das über worx.0.xxx.mower.mqtt_update abfragen könnt. Dieser State wir gezählt und schützt euch gegen die 24h Sperre.
                        Sind wir nun gegen die 24h Sperre geschützt?
                        NEIN!
                        Worx zählt alles...Hier ist es egal, ob der Befehl vom Handy kommt oder/und von ioBroker. Im Sekundentakt ca. 130 x worx.0.xxx.mower.mqtt_update ausführen führt zum Hauptgewinn 24h Sperre.
                        Natürlich könnt ihr euren Account, mit ca. 200 x im Sekundentakt den Adapter neu starten, auch sperren...Hier werde ich noch eine Limitierung hinzufügen.
                        @hsteinme Da du mich ja die letzten 3 Wochen gefühlt 100 x am Tage verbessert hast...Habe ich was vergessen?
                        Edit 17.04.2025
                        Derzeit gibt es nur 2 Scripte die mit diesen Adapter laufen.
                        https://forum.iobroker.net/topic/32382/zeigt-her-eure-views-zum-thema-mähroboter/542
                        Hier wird leider der daswetter Adapter benötigt. Eventuell veröffentliche ich einen Ersatzadapter open-meteo der bereits bei mir auf GIT liegt.
                        Oder mit Alexa steuern:
                        https://forum.iobroker.net/topic/4834/adapter-worx-landroid-v2-x-x/1191
                        Gruß//Lucky
                        #334
                        @lucky_esa
                        ich kam eben in den Login id.worx.com/login und hab die android app rausgeworfen, ebenso Alexa (keine Ahnung, warum die da drin war).
                        Dann den Adapter gestartet, sofort wieder Error 429.
                        Login geht da auch nicht mehr, die App erspare ich mir.
                        Also eindeutig was mit dem Adapter, lief hier in Version 3.2.4.
                        wenn du irgendwelche Daten brauchst.. sag bescheid, bitte.
                        L 1 Antwort Letzte Antwort
                          @lucky_esa
                          Lucky_ESA
                          #335
                          @neuschwansteini Eigentlich sollt ihr eure APP ausprobieren und nicht den Adapter. Wenn alles funktioniert dann dringend erst in der Instanz Einstellung den roten Button drücken damit eure allte Session geköscht wird und dann noch den Adapter auf debug stellen.
                          Wenn du im Log keine Fehlermeldungen siehst dann bringt der mir leider nichts.
                          Gruß//Lucky
                          ? 2 Antworten Letzte Antwort
                          • L Lucky_ESA
                            Gruß//Lucky
                            #336
                            @lucky_esa
                            Ok dann ist ja klar, dass ich das falsch gemacht habe, ok. Dann warten wir mal und dann lade ich mir die App wieder herunter..
                            Ist ja logisch, wenn der die alte Session wieder aktiviert hat..
                            Bjoern77B 1 Antwort Letzte Antwort
                              @lucky_esa
                              Bjoern77B Offline
                              Bjoern77B Offline
                              Bjoern77
                              #337
                              Moin
                              Rückmeldung von mir nach ~40h. Hier mein Verlauf:
                              • Adapter gestoppt
                              • App auf 2 Geräten deinstalliert
                              • ~40h gewartet
                              • App auf einem Gerät wieder installiert
                              • Beim Anmelden kam schon "Verbindungsfehler"
                              • Neustart der App bringt wieder "Langsamer, sie stellen zu viele...."
                              Meine Email an den Support (Freitag) wurde noch nicht beantwortet
                              Was kann man noch testen?
                              Danke und Gruß
                              Björn
                              • L Lucky_ESA
                                Gruß//Lucky
                                #338
                                @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                                Nochmal von der Logik her.. wenn der Adapter gestoppt ist, funktioniert der rote Button doch garnicht, oder doch???
                                Und wenn ich den Adapter laufen lasse, werde ich immer geblockt..
                                Daher meine Frage.. wie soll das denn funktionieren?
                                Wenn ich den Adapter starte, startet er mit der alten Session, die wird gleich wieder geblockt, bis ich den roten Button gedrueckt habe und der Adapter einen neuen Sessionkey holt.. so war's ja jetzt..
                                Da ist meiner meinung nach n dicker Logikfehler drin!
                                • E Online
                                  E Online
                                  eve11
                                  #339
                                  Vielleicht wäre es am besten den Adapter zu deinstallieren und von Vorne anzufangen.
                                  • E eve11
                                    #340
                                    @eve11 sagte in Adapter Worx Landroid v3.x.x:
                                    ja, richtig, bevor noch mehr user sich ihren Account damit sperren...
                                      EvilElsE Offline
                                      EvilElsE Offline
                                      EvilEls
                                      schrieb am zuletzt editiert von EvilEls
                                      #341
                                      @bananajoe sagte in Adapter Worx Landroid v3.x.x:
                                      a.nel.cloudflare.com aus dem report-to header ist nur eine URL zu der der Browser anonymisierte Trackingdaten schickt. Das hat direkt nichts mit dem 429 zu tun. Habe es nur eingerahmt um zu zeigen, dass Cloudflare das Problem sieht.
                                      Aber, account.worxlandroid.com sowie id.worx.com liegen bei Cloudflare. (Siehe server header)
                                      Der 429 wird also nicht von worx sondern von Cloudflare geworfen. Dort wird sofort auf IP Ebene der 429 zurückgegeben, ohne überhaupt die Requests zu worx weiterzugeben.
                                      Wenn ich mir bei der Telekom eine neue IP abhole, kann ich problemlos auf account.worxlandroid.com sowie id.worx.com zugreifen. Ohne Einschränkungen.
                                      Unter id.worx.com habe ich alle verbundenen Apps gelöscht.
                                      Dann Adapter gestartet:
                                      worx.0
                                      2025-06-22 11:48:52.573	warn	Serial number 202130267209007208FB was not found. Please delete the object tree worx.0.202130267209007208FB.
                                      worx.0
                                      2025-06-22 11:48:52.549	info	Start check devices object!
                                      worx.0
                                      2025-06-22 11:48:52.546	warn	No mower found to start mqtt
                                      worx.0
                                      2025-06-22 11:48:52.546	info	Start MQTT connection
                                      worx.0
                                      2025-06-22 11:48:52.531	error	{"message":"Too Many Attempts."}
                                      worx.0
                                      2025-06-22 11:48:52.531	error	AxiosError: Request failed with status code 429
                                      worx.0
                                      2025-06-22 11:48:52.265	info	Connected to worx server
                                      worx.0
                                      2025-06-22 11:48:51.723	info	Start login
                                      worx.0
                                      2025-06-22 11:48:51.718	error	{"error":"invalid_grant","error_description":"The refresh token is invalid.","hint":"Token has been revoked"}
                                      worx.0
                                      2025-06-22 11:48:51.718	error	AxiosError: Request failed with status code 400
                                      worx.0
                                      2025-06-22 11:48:51.202	info	Login to worx
                                      worx.0
                                      2025-06-22 11:48:51.200	info	Use new aws-iot-device-sdk-v2.
                                      worx.0
                                      2025-06-22 11:48:51.105	info	starting. Version 3.2.4 in /opt/iobroker/node_modules/iobroker.worx, node: v20.19.1, js-controller: 7.0.7
                                      Danach account.worxlandroid.com sowie id.worx.com wieder 429. Alles dicht.
                                      Also, neue IP geholt.
                                      Wieder kann ich problemlos auf account.worxlandroid.com sowie id.worx.com zugreifen.
                                      Interessanterweise sind wieder zwei Apps verbunden:
                                      account. wird durch Zugriffe über die Webseite hinzugefügt.
                                      app. durch den Adapter.
                                      D.h., als ich den Adapter angeworfen habe, ist mindestens ein Login Versuch pro Applikation zu worx durchgekommen.
                                      Nun ist die Frage, warum cloudflare danach alle Requests von meiner IP blockt.
                                      Entweder:
                                      • Cloudflare registriert das Login-Verhalten als „suspekt“ oder „botartig“ und blockiert die IP automatisch per WAF (Web Application Firewall) Rule, Bot Management oder Rate-Limit Rule.
                                      • Worx hat auf seinem Origin-Backend ein Regelwerk, das bei verdächtigem Verhalten IPs an Cloudflare zurückmeldet (z. B. über Firewall API oder custom Access Rules via API). ZB, wenn App ungültigen Token 5× sendet → API erkennt Missbrauch → löst Blockierung via Cloudflare API aus. (halte ich aber für unwahrscheinlich)
                                      Zu erstem Szenario würde auch passen, dass worx ein Problem mit mqtt DDOS eingeräumt (https://forum.iobroker.net/topic/74380/adapter-worx-landroid-v3-x-x/281?_=1750584154729) hat.
                                      Also, mit neuer IP und funktionierenden Webseitzugriffen worx App installiert.
                                      Diese ist seit gut 5 Tagen deinstalliert.
                                      Login schlägt fehl. (Err: "Verbindung fehlgeschlagen")
                                      Beim erneuten öffnen der App dann das bekannte, Langsamer.
                                      Webseiten account.worxlandroid.com sowie id.worx.com wieder 429.
                                      Mit neuer IP komme ich dann wieder auf die Webseiten und sehe wieder zwei Applications
                                      play.google. offensichtlich die Android APp
                                      Also halten wir fest, es sieht alles danach aus, dass Cloudflare der Ausführende ist (429 zurückgibt), aber es ist nicht klar ob:
                                      Cloudflare autonom durch die aktivierten Schutzfunktionen (Bot Detection, Rate Limits etc.) handelt
                                      ODER
                                      durch explizite Konfigurationen von Worx (z. B. Regeln wie „blockiere IP, wenn ...“)
                                      DAS genau muss worx untersuchen.
                                      • EvilElsE EvilEls
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        worx.0
                                        Entweder:
                                        ODER
                                        #342
                                        @evilels sagte in Adapter Worx Landroid v3.x.x:
                                        wenn ich bei einer Website ein cloudflare popup erhalte, heisst es immer
                                        "bitte bestätigen Sie, dass Sie ein Mensch sind"
                                        Sollte der Fehler/ Block von cloudflare kommen, wird IMHO genau diese Überprüfung wohl eine Software (interpretiert als möglicherweise schädlicher Bot) ergeben
                                          Lucky_ESA
                                          #343
                                          @neuschwansteini sagte in Adapter Worx Landroid v3.x.x:
                                          Die Session ist in worx.0.session gespeichert welchen man auch manuell leeren kann. Der rote Button leert den State und das auch ohne das der Adapter eingeschaltet ist. Das refreshToken kann immer wieder verwendet werden es sei denn, ihr ändert PW, User und Application dann erfolgt ein neuer Login. Dieses Verhalten ist von Worx gewünscht und wird mir sogar als Example Code zur Verfügung gestellt.
                                          Mir ist bewusst das ihr versucht eine Lösung zu finden und sucht den Fehler beim Adapter. Was ihr alle gemeinsam habt kann ich nicht sagen aber für mich sieht es nach einer Account Sperrung aus. Warum das so ist kann euch nur Worx sagen.
                                          Ich werde mal den retry-after ausgeben lassen. Dieser sollte ja eigentlich die Zeit beinhalten, wie lange ihr gesperrt seit.
                                          Eure Mails an Worx sollte nicht mehr 3-Party enthalten sondern das ihr mit der Worx APP immer sofort blockiert werdet.
                                          Mittlerweile habe ich auch das Gefühl, dass es irgendwas mit der DDOS Attacke zu tun hat.
                                          Gruß//Lucky
