  4. Test Adapter drops-weather 1.2.x
    6.7k
drops-weathermcm1957
196 Beiträge 21 Kommentatoren 44.3k Aufrufe 24 Beobachtet
  • Chris76eC Offline
    Chris76eC Offline
    Chris76e
    #167
    Bei mir funktioniert es noch nicht, habe die alte Instanz gelöscht und dann neuinstalliert, gleicher Fehler wie vorher. Auch das umstellen auf en und dann de brachte nichts. Den Link kann ich im Browser öffnen.
    drops-weather.0	2025-06-04 22:37:45.112	info	Terminated (NO_ERROR): Without reason
    drops-weather.0	2025-06-04 22:37:45.110	debug	pages 2
    drops-weather.0	2025-06-04 22:37:45.100	debug	destroy browser
    drops-weather.0	2025-06-04 22:37:45.099	warn	TimeoutError: Navigation timeout of 30000 ms exceeded
    drops-weather.0	2025-06-04 22:37:14.988	debug	creating new page ...
    drops-weather.0	2025-06-04 22:37:14.987	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/xxx
    drops-weather.0	2025-06-04 22:37:14.666	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
    drops-weather.0	2025-06-04 22:37:14.665	debug	browserPath set to puppeteer default
    drops-weather.0	2025-06-04 22:37:14.665	debug	browserMode set to automatic, running on linux / x64
    drops-weather.0	2025-06-04 22:37:14.656	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.6
    drops-weather.0	2025-06-04 22:37:02.007	info	Terminated (NO_ERROR): Without reason
    drops-weather.0	2025-06-04 22:37:01.879	debug	pages 2
    drops-weather.0	2025-06-04 22:37:01.868	debug	destroy browser
    drops-weather.0	2025-06-04 22:37:01.868	warn	TimeoutError: Navigation timeout of 30000 ms exceeded
    drops-weather.0	2025-06-04 22:36:31.768	debug	creating new page ...
    drops-weather.0	2025-06-04 22:36:31.767	debug	Reading data from : https://www.niederschlagsradar.de/en-gb/city/xxx
    drops-weather.0	2025-06-04 22:36:31.391	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
    drops-weather.0	2025-06-04 22:36:31.390	debug	browserPath set to puppeteer default
    drops-weather.0	2025-06-04 22:36:31.390	debug	browserMode set to automatic, running on linux / x64
    drops-weather.0	2025-06-04 22:36:31.379	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.6
    drops-weather.0	2025-06-04 22:35:55.122	info	Terminated (NO_ERROR): Without reason
    drops-weather.0	2025-06-04 22:35:55.120	debug	pages 2
    drops-weather.0	2025-06-04 22:35:55.108	debug	destroy browser
    drops-weather.0	2025-06-04 22:35:55.107	warn	TimeoutError: Navigation timeout of 30000 ms exceeded
    drops-weather.0	2025-06-04 22:35:24.950	debug	creating new page ...
    drops-weather.0	2025-06-04 22:35:24.950	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/xxx
    drops-weather.0	2025-06-04 22:35:24.498	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
    drops-weather.0	2025-06-04 22:35:24.497	debug	browserPath set to puppeteer default
    drops-weather.0	2025-06-04 22:35:24.496	debug	browserMode set to automatic, running on linux / x64
    drops-weather.0	2025-06-04 22:35:24.485	info	starting. Version 1.2.4 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#d2e17ec6cddd59c7cad2b96530c18615393cbe2c) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.6
    • mcm1957M mcm1957
      Das Problem wurde lokalisiert und behoben. Der Defaultwert bei einer Neuinstallation war falsch.
      In 1.2.4 ist das Problem für NEUINSTALLATIONEN behoben.
      Existiuerende Installationen bitte:
      • Sprache auf en umstellen
      • speichern (!)
      • Sprache wieder auf deutsch stellen
      • speichern
      Damit wird der Parameterwert korrigiert.
      Marco 3
      #168
      @mcm1957
      Neuinstallationen: 1.2.4 aktuell nur über die Katze installierbar. 1.2.4
      oder
      aber auf der Beta Seite ist noch 1.2.3.
      Also Katzen install :)
      • M Marco 3
        @mcm1957
        oder
        mcm1957M Online
        mcm1957M Online
        mcm1957
        #169
        @marco-3
        je klar. Repo witd nur 2x Tag aktualisiert.
        Und bitte keine Github INstallation ohne explizite Aufforderung. Wenn schon eilig, bitte "von npm" benutzen oder 'Benutzerdefiniert' und url iobroker.drops-weather@1.2.4 ...
        Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
        GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
        Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
        Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
          Marco 3
          #170
          sehr schön ... läuft...
          • icebearI Online
            icebearI Online
            icebear
            #171
            Ich bekomme bei mir im Moment noch die folgende Fehlermeldung:
            drops-weather.0
            2025-06-05 08:31:02.220	error	Error: DB closed
            drops-weather.0
            drops-weather.0
            2025-06-05 08:31:02.077	warn	get state error: Connection is closed.
            drops-weather.0
            2025-06-05 08:31:02.077	warn	Could not perform strict object check of state drops-weather.0.data_1h.actualRain: DB closed
            drops-weather.0
            drops-weather.0
            2025-06-05 08:31:02.076	warn	Could not perform strict object check of state drops-weather.0.data_5min.actualRain: DB closed
            drops-weather.0
            2025-06-05 08:31:01.121	info	Terminated (NO_ERROR): Without reason
            drops-weather.0
            2025-06-05 08:30:51.248	info	starting. Version 1.2.4 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#d2e17ec6cddd59c7cad2b96530c18615393cbe2c) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.16.0, js-controller: 7.0.6
            • icebearI icebear
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              drops-weather.0
              mcm1957M Online
              mcm1957M Online
              mcm1957
              #172
              @icebear said in Test Adapter drops-weather 1.2.x:
              non-npm: iobroker-community-adapters/ioBroker.drops-weather#d2e17ec6cddd59c7cad2b96530c18615393cbe2c):
              Installier bitte zuerst mal die Version aus dem (latest / beta) repository.
              Dann bitte das logging auf DEBUG stellen und output posten.
              icebearI 1 Antwort Letzte Antwort
              • mcm1957M mcm1957
                icebearI Online
                icebearI Online
                icebear
                #173
                @mcm1957 said in Test Adapter drops-weather 1.2.x:
                O.K. Ich hab den Adapter jetzt erstnochmal gelöscht und dann wieder installiert.
                Jetzt funktioniert es. Danke.
                • Chris76eC Offline
                  Chris76eC Offline
                  Chris76e
                  schrieb am zuletzt editiert von Chris76e
                  #174
                  Warum läuft der bei mir nicht mehr? Habe jetzt schon mehrmals alles gelöscht und neu installiert. iob neugestartet, den fix ausgeführt. Aber immer das gleiche.
                  Bei den anderen logs war der timeout bei
                  60000
                  bei mir immer
                  Andere sprache getest, andere Stadt, immer der selbe Fehler....
                  drops-weather.0	2025-06-05 17:06:22.578	info	Terminated (NO_ERROR): Without reason
                  drops-weather.0	2025-06-05 17:06:22.529	debug	pages 2
                  drops-weather.0	2025-06-05 17:06:22.520	debug	destroy browser
                  drops-weather.0	2025-06-05 17:06:22.519	warn	TimeoutError: Navigation timeout of 30000 ms exceeded
                  drops-weather.0	2025-06-05 17:05:52.366	debug	creating new page ...
                  drops-weather.0	2025-06-05 17:05:52.364	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/xxx
                  drops-weather.0	2025-06-05 17:05:51.951	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                  drops-weather.0	2025-06-05 17:05:51.949	debug	browserPath set to puppeteer default
                  drops-weather.0	2025-06-05 17:05:51.949	debug	browserMode set to automatic, running on linux / x64
                  drops-weather.0	2025-06-05 17:05:51.932	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.6
                  drops-weather.0	2025-06-05 17:01:29.256	info	Terminated (NO_ERROR): Without reason
                  drops-weather.0	2025-06-05 17:01:29.254	debug	pages 2
                  drops-weather.0	2025-06-05 17:01:29.244	debug	destroy browser
                  drops-weather.0	2025-06-05 17:01:29.243	warn	TimeoutError: Navigation timeout of 30000 ms exceeded
                  drops-weather.0	2025-06-05 17:00:59.089	debug	creating new page ...
                  drops-weather.0	2025-06-05 17:00:59.089	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/xxx
                  drops-weather.0	2025-06-05 17:00:58.482	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                  drops-weather.0	2025-06-05 17:00:58.480	debug	browserPath set to puppeteer default
                  drops-weather.0	2025-06-05 17:00:58.478	debug	browserMode set to automatic, running on linux / x64
                  drops-weather.0	2025-06-05 17:00:58.448	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.2, js-controller: 7.0.6
                  • Chris76eC Chris76e
                    60000
                    bei mir immer
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #175
                    @chris76e
                    Schau ob https://www.niederschlagsradar.de/de-de/city/xxx bei dir erreichbar ist.
                    Dass bei dir das timeout 30s beträgt ist überraschend. Im code steht hardcoded 60000.
                    https://github.com/iobroker-community-adapters/ioBroker.drops-weather/blob/d2e17ec6cddd59c7cad2b96530c18615393cbe2c/main.js#L27C14-L27C25
                    Chris76eC 1 Antwort Letzte Antwort
                    • mcm1957M mcm1957
                      @chris76e
                      Chris76eC Offline
                      Chris76eC Offline
                      Chris76e
                      #176
                      @mcm1957
                      der link ist erreichbar. Wie entferne ich den Apater am besten für eine neuinstallation? Gibt es vieleicht nen befehl über die Commando Zeile damit wirklich alles entfernt wird?
                      Das ist die main.js bei meinem System
                      'use strict';
                      const utils = require('@iobroker/adapter-core');
                      const os = require('node:os');
                      const puppeteer = require('puppeteer-extra');
                      const StealthPlugin = require('puppeteer-extra-plugin-stealth');
                      // add the stealth plugin
                      puppeteer.use(StealthPlugin());
                      let watchdog = null;
                      let browser = null;
                      class DropsWeather extends utils.Adapter {
                           * @param options ioBroker optionen
                          constructor(options) {
                              super({
                                  ...options,
                              this.mainURLEN = 'https://www.meteox.com/';
                              this.mainURLDE = 'https://www.niederschlagsradar.de/';
                              this.pageTimeout = 60000;
                              this.on('ready', this.onReady.bind(this));
                              this.on('unload', this.onUnload.bind(this));
                      • mcm1957M mcm1957
                        Aktuelle Test Version 1.2.4
                        Veröffentlichungsdatum 4.6.2025
                        Github Link https://github.com/iobroker-community-adapters/ioBroker.drops-weather
                        Beschreibung
                        Der Adapter drops-weather wurde in Abstimmung und mit Unterstützung des originalen Authors in den iobroker-community-organisation Bereich übernommen.
                        Ein herzliches DANKE an @inbux der diesen Adapter geschrieben hat und ihn nun der community zur Verfügunvg gestellt hat. Ein großes Danke geht auch an @arteck der die Umstellung von axios auf puppeteer vorgenommen hat.
                        Der Adapter ist derzeit nur via Github und npm (als url "iobroker.drops-weather@latest" eingeben) installierbar. Ein Review bzw. eine Aufnahme ins LATEST / BETA Repository steht auf meiner Liste.
                        Rückmeldungen aller Art - insbesondere auch Infos das der Adapter wie gewünscht funktioniert - sind herzlich willkommen.
                        Hinweis:
                        Frühere Diskussionsbeiträge zu diesem Adapter finden sich hier: https://forum.iobroker.net/topic/58629/test-adapter-drops-weather-0-3-x
                        Changelog
                        1.0.0 (2025-03-17)
                        • (mcm1957) adapter has been migrated to iobroker-community-adapters organisation
                        • (mcm1957) adapter requires node.js 20.x, js-controller 6 and admin 7 now.
                        • (arteck) axios has been replaced by puppeteer
                        • (mcm1957) dependencies have been updated
                        1.1.0 (2025-03-19)
                        • (mcm1957) support for raspberryPi / arm architecture added
                        • (mcm1957) adminUI extended to allow browser selection
                        1.2.0 (2025-03-24)
                        • (mcm1957) Timeout has been encreased to 15s.
                        • (mcm1957) Logging has been reduced.
                        • (arteck) Adapter has been converted to scheduled operation.
                        • (mcm1957) A spelling error blocking chromium-browser manual selection has been corrected.
                        1.2.1 (2025-03-25)
                        • (arteck) Language support has been added.
                        • (mcm1957) Unused dependencies have been removed.
                        1.2.2 (2025-03-29)
                        • (arteck) Puppeteer-extra and puppeteer-extra-plugin-stealth have been added
                        1.2.3 (2025-03-29)
                        • (arteck) Text is now deleted if no text is available
                        1.2.4 (2025-06-04)
                        • (mcm1957) fix language default.
                        sigi234S Online
                        sigi234S Online
                        #177
                        @mcm1957
                        neue Meldungen:
                        drops-weather.0
                        2025-06-06 03:33:16.154	error	Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
                        drops-weather.0
                        2025-06-06 03:33:16.154	error	ProtocolError: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed. at <instance_members_initializer> (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:102:14) at new Callback (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:106:16) at CallbackRegistry.create (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\common\CallbackRegistry.js:24:26) at Connection._rawSend (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Connection.js:99:26) at CdpCDPSession.send (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\CdpSession.js:73:33) at NetworkManager.addClient (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\NetworkManager.js:62:20) at FrameManager.initialize (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\FrameManager.js:174:38) at #initialize (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Page.js:291:36) at CdpPage._create (C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Page.js:103:31) at C:\SmartHome\node_modules\puppeteer-core\lib\cjs\puppeteer\cdp\Target.js:205:42
                        drops-weather.0
                        2025-06-06 03:33:16.154	error	unhandled promise rejection: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
                        drops-weather.0
                        2025-06-06 03:33:16.153	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        drops-weather.0
                        2025-06-06 03:33:16.149	warn	ProtocolError: Network.enable timed out. Increase the 'protocolTimeout' setting in launch/connect calls for a higher timeout if needed.
                        • icebearI Online
                          icebearI Online
                          icebear
                          schrieb am zuletzt editiert von icebear
                          #178
                          und bei mir war erst alles gut, aber jetzt kommt andauernd wieder:
                          drops-weather.0
                          2025-06-06 07:50:46.756	error	Error: DB closed
                          drops-weather.0
                          2025-06-06 07:50:46.755	error	Error: DB closed
                          drops-weather.0
                          2025-06-06 07:50:46.748	warn	get state error: Connection is closed.
                          drops-weather.0
                          2025-06-06 07:50:46.747	warn	Could not perform strict object check of state drops-weather.0.data_1h.chartRain: DB closed
                          drops-weather.0
                          2025-06-06 07:50:46.746	warn	get state error: Connection is closed.
                          drops-weather.0
                          2025-06-06 07:50:46.746	warn	Could not perform strict object check of state drops-weather.0.data_5min.chartRain: DB closed
                          drops-weather.0
                          2025-06-06 07:50:46.602	warn	get state error: Connection is closed.
                          drops-weather.0
                          2025-06-06 07:50:46.501	warn	get state error: Connection is closed.
                          drops-weather.0
                          2025-06-06 07:50:45.763	info	Terminated (NO_ERROR): Without reason
                          deinstallieren und neu installieren hab ich schon gemacht, Language hab ich trotz neu Installation auch nochmal von 'de' auf 'en' und wieder zurück gestellt, ändert aber nix.
                          EDIT:
                          Hier noch die Ausgabe vom Debug-Mode:
                          drops-weather.0
                          2025-06-06 08:11:10.354	error	Error: DB closed
                          drops-weather.0
                          2025-06-06 08:11:10.353	error	Error: DB closed
                          drops-weather.0
                          2025-06-06 08:11:10.351	debug	redis get drops-weather.0.data_1h.chartRain, error - DB closed
                          drops-weather.0
                          2025-06-06 08:11:10.350	debug	redis get drops-weather.0.data_5min.chartRain, error - Connection is closed.
                          drops-weather.0
                          2025-06-06 08:11:10.342	debug	Rain (data_1h): [{"label":"10:00","value":"0"},{"label":"11:00","value":"0"},{"label":"12:00","value":"0"},{"label":"13:00","value":"0"},{"label":"14:00","value":"0"},{"label":"15:00","value":"0.1"},{"label":"16:00","value":"0"},{"label":"17:00","value":"0.3"},{"label":"18:00","value":"0.1"},{"label":"19:00","value":"0"},{"label":"20:00","value":"0.1"},{"label":"21:00","value":"0"},{"label":"22:00","value":"0.1"},{"label":"23:00","value":"0"},{"label":"00:00","value":"0"},{"label":"01:00","value":"0"},{"label":"02:00","value":"0"},{"label":"03:00","value":"0"},{"label":"04:00","value":"0"},{"label":"05:00","value":"0.2"},{"label":"06:00","value":"0.3"},{"label":"07:00","value":"0.1"},{"label":"08:00","value":"0.1"},{"label":"09:00","value":"0.2"}]
                          drops-weather.0
                          2025-06-06 08:11:10.319	warn	get state error: Connection is closed.
                          drops-weather.0
                          2025-06-06 08:11:10.314	debug	Rain (data_5min): [{"label":"08:10","value":"0"},{"label":"08:15","value":"0"},{"label":"08:20","value":"0"},{"label":"08:25","value":"0"},{"label":"08:30","value":"0"},{"label":"08:35","value":"0"},{"label":"08:40","value":"0"},{"label":"08:45","value":"0"},{"label":"08:50","value":"0"},{"label":"08:55","value":"0"},{"label":"09:00","value":"0"},{"label":"09:05","value":"0"},{"label":"09:10","value":"0"},{"label":"09:15","value":"0"},{"label":"09:20","value":"0"},{"label":"09:25","value":"0"},{"label":"09:30","value":"0"},{"label":"09:35","value":"0"},{"label":"09:40","value":"0"},{"label":"09:45","value":"0"},{"label":"09:50","value":"0"},{"label":"09:55","value":"0"},{"label":"10:00","value":"0"},{"label":"10:05","value":"0"},{"label":"10:10","value":"0"},{"label":"10:15","value":"0"},{"label":"10:20","value":"0"},{"label":"10:25","value":"0"},{"label":"10:30","value":"0"},{"label":"10:35","value":"0"},{"label":"10:40","value":"0"},{"label":"10:45","value":"0"},{"label":"10:50","value":"0"},{"label":"10:55","value":"0"},{"label":"11:00","value":"0"},{"label":"11:05","value":"0"},{"label":"11:10","value":"0"},{"label":"11:15","value":"0"}]
                          host.iobroker
                          2025-06-06 08:11:10.489	info	instance system.adapter.drops-weather.0 having pid 26365 terminated with code 0 (NO_ERROR)
                          drops-weather.0
                          2025-06-06 08:11:09.536	info	Terminated (NO_ERROR): Without reason
                          drops-weather.0
                          2025-06-06 08:11:09.173	debug	pages 2
                          drops-weather.0
                          2025-06-06 08:11:09.141	debug	destroy browser
                          drops-weather.0
                          2025-06-06 08:11:09.135	debug	creating 1 hour states
                          drops-weather.0
                          2025-06-06 08:11:09.134	debug	creating 5 min states
                          drops-weather.0
                          2025-06-06 08:11:09.134	debug	weatherData found
                          drops-weather.0
                          2025-06-06 08:11:09.131	debug	got labeltext "Es bleibt vorläufig trocken"
                          drops-weather.0
                          2025-06-06 08:11:09.127	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:10:00Z\",\"timestamp\":1749190200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:15:00Z\",\"timestamp\":1749190500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:20:00Z\",\"timestamp\":1749190800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:25:00Z\",\"timestamp\":1749191100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:30:00Z\",\"timestamp\":1749191400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:35:00Z\",\"timestamp\":1749191700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:40:00Z\",\"timestamp\":1749192000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:45:00Z\",\"timestamp\":1749192300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:50:00Z\",\"timestamp\":1749192600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T06:55:00Z\",\"timestamp\":1749192900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:00:00Z\",\"timestamp\":1749193200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:05:00Z\",\"timestamp\":1749193500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:10:00Z\",\"timestamp\":1749193800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:15:00Z\",\"timestamp\":1749194100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:20:00Z\",\"timestamp\":1749194400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:25:00Z\",\"timestamp\":1749194700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:30:00Z\",\"timestamp\":1749195000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:35:00Z\",\"timestamp\":1749195300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:40:00Z\",\"timestamp\":1749195600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:45:00Z\",\"timestamp\":1749195900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:50:00Z\",\"timestamp\":1749196200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T07:55:00Z\",\"timestamp\":1749196500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:05:00Z\",\"timestamp\":1749197100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:10:00Z\",\"timestamp\":1749197400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:15:00Z\",\"timestamp\":1749197700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:20:00Z\",\"timestamp\":1749198000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:25:00Z\",\"timestamp\":1749198300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:30:00Z\",\"timestamp\":1749198600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:35:00Z\",\"timestamp\":1749198900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:40:00Z\",\"timestamp\":1749199200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:45:00Z\",\"timestamp\":1749199500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:50:00Z\",\"timestamp\":1749199800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:55:00Z\",\"timestamp\":1749200100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:05:00Z\",\"timestamp\":1749200700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:10:00Z\",\"timestamp\":1749201000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:15:00Z\",\"timestamp\":1749201300}],\"daypart\":[{\"precipitationrate\":0.03,\"time\":\"2025-06-06T05:00:00Z\",\"timestamp\":1749186000,\"weathericon\":[1,0,-1,-1,0,-1,-1,-1,-1]},{\"precipitationrate\":0.04,\"time\":\"2025-06-06T06:00:00Z\",\"timestamp\":1749189600,\"weathericon\":[1,0,-1,-1,0,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T07:00:00Z\",\"timestamp\":1749193200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":50.5,\"longitude\":6.86,\"quadindex\":\"BCACADCABDBAAAC\",\"source\":\"radar-nl\",\"timestamp\":1749189600}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T08:00:00Z\",\"timestamp\":1749196800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T09:00:00Z\",\"timestamp\":1749200400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T10:00:00Z\",\"timestamp\":1749204000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T11:00:00Z\",\"timestamp\":1749207600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T12:00:00Z\",\"timestamp\":1749211200},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T13:00:00Z\",\"timestamp\":1749214800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T14:00:00Z\",\"timestamp\":1749218400},{\"lightningclass\":-1,\"precipitationrate\":0.3,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T15:00:00Z\",\"timestamp\":1749222000},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T16:00:00Z\",\"timestamp\":1749225600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T17:00:00Z\",\"timestamp\":1749229200},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T18:00:00Z\",\"timestamp\":1749232800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T19:00:00Z\",\"timestamp\":1749236400},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T20:00:00Z\",\"timestamp\":1749240000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T21:00:00Z\",\"timestamp\":1749243600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T22:00:00Z\",\"timestamp\":1749247200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-06T23:00:00Z\",\"timestamp\":1749250800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T00:00:00Z\",\"timestamp\":1749254400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T01:00:00Z\",\"timestamp\":1749258000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T02:00:00Z\",\"timestamp\":1749261600},{\"lightningclass\":-1,\"precipitationrate\":0.2,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T03:00:00Z\",\"timestamp\":1749265200},{\"lightningclass\":-1,\"precipitationrate\":0.3,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T04:00:00Z\",\"timestamp\":1749268800},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T05:00:00Z\",\"timestamp\":1749272400},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T06:00:00Z\",\"timestamp\":1749276000},{\"lightningclass\":-1,\"precipitationrate\":0.2,\"precipitationtype\":\"rain\",\"time\":\"2025-06-07T07:00:00Z\",\"timestamp\":1749279600}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":50.504,\"longitude\":6.855,\"quadindex\":\"BCACADCABDABB\",\"source\":\"weathercomputer\",\"timestamp\":1749190261}}},"," timezoneOffset: 120,"," locals: {\"labels\":[[0,\"trocken\"],[0.1,\"Nieselregen\"],[1,\"leichter Regen\"],[2,\"Starkregen\"]],\"language\":\"de\",\"strings\":{\"unavailable\":\"Etwas ist schief gelaufen\",\"mmph\":\"mm pro Std.\",\"now\":\"Jetzt\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                          drops-weather.0
                          2025-06-06 08:11:09.121	debug	domcontent loaded, evaluate page
                          drops-weather.0
                          2025-06-06 08:11:00.788	debug	creating new page ...
                          drops-weather.0
                          2025-06-06 08:11:00.786	debug	Reading data from : https://www.niederschlagsradar.de/de-de/city/2821520
                          drops-weather.0
                          2025-06-06 08:10:59.356	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"userDataDir":"/dev/null","args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors","--disable-extensions","--disable-component-extensions-with-background-pages","--disable-default-apps","--mute-audio","--no-default-browser-check","--autoplay-policy=user-gesture-required","--disable-background-timer-throttling","--disable-backgrounding-occluded-windows","--disable-notifications","--disable-background-networking","--disable-breakpad","--disable-component-update","--disable-domain-reliability","--disable-sync"]}
                          drops-weather.0
                          2025-06-06 08:10:59.355	debug	browserPath set to puppeteer default
                          drops-weather.0
                          2025-06-06 08:10:59.354	debug	browserMode set to automatic, running on linux / x64
                          drops-weather.0
                          2025-06-06 08:10:59.323	info	starting. Version 1.2.4 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.16.0, js-controller: 7.0.6
                            Marco 3
                            #179
                            Mal eine Frage zum Datenumfang.
                            Ist es eventuell geplant die Wind Richtung und Windstärke mit einzufangen?
                            • M Marco 3
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #180
                              @marco-3 said in Test Adapter drops-weather 1.2.x:
                              Erstell für Erweiterungswünsche gener ein Issue.
                              ABER - solange der Adapeter immer wieder merkbare Stabilitätsprobleme zeigt muss man überlegen wieviel Aufwand man da noch reinsteckt. Leider steht ja kein definiertes API zur Verfügung sondern es muss bzw. wird versucht die Webseite zu scrapen - was schon be geringen Änderungen der Webseite zu Stabilitätsproblemen und Anpassungsbedarf führt.
                              • E Online
                                E Online
                                emil70
                                #181
                                Habe es mal unter Docker auf Synologie aufgespielt
                                Fehlermeldung
                                drops-weather.0
                                	2025-08-04 18:54:08.665	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                                drops-weather.0
                                	2025-08-04 18:54:08.665	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                drops-weather.0
                                	2025-08-04 18:54:08.664	warn	TypeError: Cannot read properties of null (reading 'newPage')
                                drops-weather.0
                                	2025-08-04 18:54:08.662	warn	setTimeout called, but adapter is shutting down
                                drops-weather.0
                                	2025-08-04 18:54:08.661	error	error launching browser undefined - Error: Failed to launch the browser process!/opt/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directoryTROUBLESHOOTING: https://pptr.dev/troubleshooting
                                drops-weather.0
                                	2025-08-04 18:54:08.651	error	Cannot read properties of null (reading 'pages')
                                PlatformBetriebssystem:linux
                                Architektur:x64
                                CPUs:4
                                Geschwindigkeit:2197 MHz
                                Modell:Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                                RAM:11.5 GB
                                System-Betriebszeit:2 T. 19:58:12
                                Node.js:v20.18.2
                                Zeit:1754276673997
                                Zeitversatz:-120
                                NPM:10.8.2
                                Adapter-Anzahl:572
                                Datenträgergröße:3572.6 GB
                                Freier Festplattenspeicher:2158.0 GB
                                Aktive Instanzen:29
                                Pfad:/opt/iobroker/
                                Betriebszeit:2 T. 19:08:42
                                aktiv:true
                                _nodeCurrent:20.18.2
                                _nodeNewest:20.19.4
                                _nodeNewestNext:20.19.4
                                _npmCurrent:10.8.2
                                _npmNewest:10.8.2
                                _npmNewestNext:10.8.2
                                Bekommt man das da gelöst??
                                gruss emil70
                                iobroker,pihole,homematic,motioneys,solaranlage laufen auf Proxmox (16 x AMD Ryzen 7 6800H with Radeon Graphics )
                                • David G.D Online
                                  David G.D Online
                                  David G.
                                  #182
                                  @emil70
                                  Selbe bei mir.
                                  v7.6.17
                                  99+
                                  99+
                                  Log-Größe: 1.4 KB
                                  drops-weather.0
                                  Zeit
                                  debug
                                  Nachricht
                                  host.iobroker
                                  2025-08-04 19:15:44.761	info	instance system.adapter.drops-weather.0 in version "1.2.7" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 108752
                                  host.iobroker
                                  2025-08-04 19:15:44.755	info	instance scheduled system.adapter.drops-weather.0 */5 * * * *
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	error	Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	warn	TypeError: Cannot read properties of null (reading 'newPage')
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	warn	setTimeout called, but adapter is shutting down
                                  drops-weather.0
                                  2025-08-04 19:15:45.981	error	error launching browser undefined - Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	error	Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	warn	TypeError: Cannot read properties of null (reading 'newPage')
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	warn	setTimeout called, but adapter is shutting down
                                  drops-weather.0
                                  2025-08-04 19:15:45.977	error	error launching browser undefined - Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-138.0.7204.168/chrome-linux64/chrome: error while loading shared libraries: libnspr4.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                  drops-weather.0
                                  2025-08-04 19:15:45.973	error	Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-08-04 19:15:45.973	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:298:37) at DropsWeather.readDataFromServer (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:149:18) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                  bash        Script v.2025-03-08
                                  *** BASE SYSTEM ***        Static hostname: iobroker
                                         Icon name: computer-container
                                           Chassis: container ☐
                                    Virtualization: lxc
                                            Kernel: Linux 6.8.12-11-pve
                                      Architecture: x86-64
                                  OS is similar to:
                                  model name      : 12th Gen Intel(R) Core(TM) i3-12100
                                  Docker          : false
                                  Virtualization  : lxc
                                  Kernel          : x86_64
                                  Userland        : 64 bit
                                  Systemuptime and Load:
                                   19:12:55 up 1 day,  5:47,  2 users,  load average: 0.87, 0.85, 0.87
                                  CPU threads: 4
                                  *** LIFE CYCLE STATUS ***
                                  Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                  *** TIME AND TIMEZONES ***
                                                 Local time: Mon 2025-08-04 19:12:55 CEST
                                             Universal time: Mon 2025-08-04 17:12:55 UTC
                                                   RTC time: n/a
                                                NTP service: inactive
                                            RTC in local TZ: no
                                  *** Users and Groups ***
                                  User that called 'iob diag':
                                  david
                                  HOME=/home/david
                                  GROUPS=david adm dialout sudo audio video plugdev users iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  GROUPS=iobroker tty dialout audio video plugdev
                                  *** DISPLAY-SERVER SETUP ***
                                  Display-Server: false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            8.6G        4.5G        4.0G         81K        127M        4.1G
                                  Swap:           536M        521M         15M
                                  Total:          9.1G        5.0G        4.0G
                                  Active iob-Instances:   55
                                           8192 M total memory
                                           4251 M used memory
                                           2347 M active memory
                                           1857 M inactive memory
                                           3819 M free memory
                                              0 M buffer memory
                                            121 M swap cache
                                            512 M total swap
                                            496 M used swap
                                             15 M free swap
                                  top - 19:12:55 up 1 day,  5:47,  2 users,  load average: 0.87, 0.85, 0.87
                                  Tasks:  85 total,   1 running,  84 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   8192.0 total,   3817.4 free,   4253.3 used,    121.3 buff/cache
                                  MiB Swap:    512.0 total,     15.0 free,    497.0 used.   3938.7 avail Mem
                                  *** FAILED SERVICES ***
                                    UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                                  * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                                  1 loaded units listed.
                                  *** DMESG CRITICAL ERRORS ***
                                  dmesg: read kernel buffer failed: Operation not permitted
                                  No critical errors detected
                                  *** FILESYSTEM ***
                                  Filesystem             Type      Size  Used Avail Use% Mounted on
                                  tank/subvol-118-disk-0 zfs        32G  8.7G   24G  27% /
                                  none                   tmpfs     492K  4.0K  488K   1% /dev
                                  none                   tmpfs     8.0K  4.0K  4.0K  50% /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                  udev                   devtmpfs   16G     0   16G   0% /dev/tty
                                  tmpfs                  tmpfs      16G     0   16G   0% /dev/shm
                                  tmpfs                  tmpfs     6.3G  124K  6.3G   1% /run
                                  tmpfs                  tmpfs     5.0M     0  5.0M   0% /run/lock
                                  tmpfs                  tmpfs     3.2G     0  3.2G   0% /run/user/1000
                                  Show mounted filesystems:
                                  TARGET SOURCE                 FSTYPE OPTIONS
                                  /      tank/subvol-118-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
                                  /var:
                                  1.4G    /var/
                                  901M    /var/log
                                  900M    /var/log/journal/409c783458ed4c4c8725e302ab3b413c
                                  467M    /var/cache
                                  Archived and active journals take up 899.7M in the file system.
                                  /opt/iobroker/backups:
                                  1.1G    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  1.1G    /opt/iobroker/iobroker-data/
                                  531M    /opt/iobroker/iobroker-data/backup-objects
                                  272M    /opt/iobroker/iobroker-data/files
                                  93M     /opt/iobroker/iobroker-data/node-red
                                  92M     /opt/iobroker/iobroker-data/node-red/node_modules
                                  82M     /opt/iobroker/iobroker-data/states.jsonl
                                  41M     /opt/iobroker/iobroker-data/mymedia/smoke.mp4
                                  25M     /opt/iobroker/iobroker-data/mymedia/wasserhahn.mp4
                                  21M     /opt/iobroker/iobroker-data/mymedia/clock_stopmotion.mov
                                  16M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                  USB-Devices by-id:
                                  *** ZigBee Settings ***
                                  HINT:
                                  Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                  tcp
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  *** NodeJS-Installation ***
                                  /usr/bin/nodejs         v20.19.4
                                  /usr/bin/node           v20.19.4
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  /usr/bin/corepack       0.32.0
                                  nodejs:
                                    Installed: 20.19.4-1nodesource1
                                    Candidate: 20.19.4-1nodesource1
                                    Version table:
                                   *** 20.19.4-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                       20.19.3-1nodesource1 1001
                                       20.19.2-1nodesource1 1001
                                       20.19.1-1nodesource1 1001
                                       20.19.0-1nodesource1 1001
                                       20.18.3-1nodesource1 1001
                                       20.18.2-1nodesource1 1001
                                       20.18.1-1nodesource1 1001
                                       20.18.0-1nodesource1 1001
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       18.19.0+dfsg-6~deb12u2 500
                                          500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                       18.19.0+dfsg-6~deb12u1 500
                                          500 http://security.debian.org bookworm-security/main amd64 Packages
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 107241)
                                  Core adapters versions
                                  admin:          7.6.17
                                  javascript:     8.9.2
                                  nodejs modules from github:     7
                                  +-- iobroker.ai-toolbox@0.1.3 (git+ssh://git@github.com/ToGe3688/ioBroker.ai-toolbox.git#f1fed33e3501a08d6052e01340e1ae1cda003746)
                                  +-- iobroker.drops-weather@1.2.7 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.drops-weather.git#f0523e2380d3b95c612de4d4fc04c4bc6ee581e6)
                                  +-- iobroker.google-sharedlocations@2.1.4 (git+ssh://git@github.com/Garfonso/ioBroker.google-sharedlocations.git#73e87eafd1922418a4829d93697b2268eacada2a)
                                  +-- iobroker.playstation@0.0.3 (git+ssh://git@github.com/Lucky-ESA/ioBroker.playstation.git#5b43878f7d3f6b0a0cafff9a9882bd12c7f4dc20)
                                  +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#97c61972c09ae9e53b157f4abc64e7e39efe617c)
                                  +-- iobroker.smoothed@1.4.0 (git+ssh://git@github.com/BenAhrdt/ioBroker.smoothed.git#f864b035a8f8a432cb4aefb945158162d597b80b)
                                  +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#87a9b7837569274a136c4fa03ee6fbfd8a20f183)
                                  Adapter State
                                  + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                                  + system.adapter.adb.0                    : adb                   : iobroker                                 -  enabled
                                  + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.ai-assistant.0           : ai-assistant          : iobroker                                 -  enabled
                                  + system.adapter.ai-toolbox.0             : ai-toolbox            : iobroker                                 -  enabled
                                    system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                                  + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
                                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                  + system.adapter.countdown.0              : countdown             : iobroker                                 -  enabled
                                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                    system.adapter.daswetter.1              : daswetter             : iobroker                                 -  enabled
                                    system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
                                  + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                    system.adapter.devices.0                : devices               : iobroker                                 - disabled
                                    system.adapter.drops-weather.0          : drops-weather         : iobroker                                 -  enabled
                                  + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                  + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                    system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                                    system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                  + system.adapter.google-sharedlocations.0 : google-sharedlocations: iobroker                                 -  enabled
                                  + system.adapter.gsmsms.0                 : gsmsms                : iobroker                                 -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                  + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                    system.adapter.iceroad.0                : iceroad               : iobroker                                 -  enabled
                                  + system.adapter.imap.0                   : imap                  : iobroker                                 -  enabled
                                  + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                  + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                    system.adapter.logparser.0              : logparser             : iobroker                                 - disabled
                                  + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                                  + system.adapter.lovelace.1               : lovelace              : iobroker                                 -  enabled, port: 8092, bind: 0.0.0.0, run as: admin
                                    system.adapter.matter.0                 : matter                : iobroker                                 - disabled
                                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                                    system.adapter.nina.0                   : nina                  : iobroker                                 - disabled
                                  + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                                    system.adapter.notification-manager.0   : notification-manager  : iobroker                                 - disabled
                                  + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                  + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                    system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                                  + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                  + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                                    system.adapter.playstation.0            : playstation           : iobroker                                 - disabled
                                  + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                    system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
                                  + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                                  + system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                                    system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                                    system.adapter.rssfeed.0                : rssfeed               : iobroker                                 - disabled
                                    system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
                                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1888, bind: 192.168.99.33
                                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.smoothed.0               : smoothed              : iobroker                                 -  enabled
                                  + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
                                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                  + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                  + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                  + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                  + system.adapter.wireguard.0              : wireguard             : iobroker                                 -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.99.4:6638
                                  + instance is alive
                                  ioBroker-Repositories
                                  │ (index) │ name               │ url                                                     │ auto upgrade │
                                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                  Upgrade policy: none
                                  Installed ioBroker-Adapters
                                  Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                                  Adapter    "adb"          : 0.0.7    , installed 0.0.7
                                  Adapter    "adguard"      : 1.0.1    , installed 1.0.1
                                  Adapter    "admin"        : 7.6.17   , installed 7.6.17
                                  Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                  Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                                  Adapter    "bosesoundtouch": 0.11.1  , installed 0.11.1
                                  Adapter    "countdown"    : 3.0.0    , installed 3.0.0
                                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                                  Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                                  Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                  Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                  Adapter    "drops-weather": 1.2.7    , installed 1.2.7
                                  Adapter    "echarts"      : 1.9.2    , installed 2.0.6
                                  Adapter    "email"        : 2.0.4    , installed 2.0.4
                                  Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
                                  Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                  Adapter    "gsmsms"       : 1.0.0    , installed 1.0.0
                                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                                  Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                                  Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                                  Adapter    "imap"         : 0.3.0    , installed 0.3.0
                                  Adapter    "iot"          : 3.3.0    , installed 3.3.0
                                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                  Controller "js-controller": 7.0.6    , installed 7.0.6
                                  Adapter    "linux-control": 1.1.5    , installed 1.1.5
                                  Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                                  Adapter    "lovelace"     : 4.1.15   , installed 5.0.0
                                  Adapter    "matter"       : 0.5.1    , installed 0.5.1
                                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                  Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                  Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                  Adapter    "notification-manager": 1.2.1, installed 1.3.0
                                  Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                  Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                                  Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                  Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                  Adapter    "ping"         : 1.6.2    , installed 1.7.9
                                  Adapter    "places"       : 1.3.0    , installed 1.3.0
                                  Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                                  Adapter    "proxy"        : 1.3.2    , installed 1.3.2
                                  Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                                  Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
                                  Adapter    "roborock"     : 0.6.18   , installed 0.6.19
                                  Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
                                  Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                                  Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                                  Adapter    "smoothed"     : 1.4.0    , installed 1.4.0
                                  Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                  Adapter    "sony-bravia"  : 1.1.0    , installed 1.1.0
                                  Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                  Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                                  Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                                  Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                                  Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                                  Adapter    "wireguard"    : 1.7.0    , installed 1.7.0
                                  Adapter    "zigbee"       : 2.0.5    , installed 3.0.1
                                  Objects and States
                                  Objects:        35683
                                  States:         32075
                                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:3 http://security.debian.org bookworm-security InRelease
                                  Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 192.168.99.33:1888      0.0.0.0:*               LISTEN      1001       39195      934/io.shelly.0
                                  tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       39634      1079/adb
                                  tcp        0      0 192.168.99.33:49292     0.0.0.0:*               LISTEN      1001       29391      760/io.hm-rpc.1
                                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          25769      295/master
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       26228      449/node-red
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       35596      968/io.sonoff.0
                                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       34994      835/io.mqtt.0
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21425      1/init
                                  tcp        0      0 192.168.99.33:42010     0.0.0.0:*               LISTEN      1001       26591      745/io.hm-rpc.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       25810      122/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19308      122/iobroker.js-con
                                  tcp6       0      0 :::8091                 :::*                    LISTEN      1001       71921      1634/io.lovelace.0
                                  tcp6       0      0 :::8093                 :::*                    LISTEN      1001       72114      1741/io.rest-api.0
                                  tcp6       0      0 :::8092                 :::*                    LISTEN      1001       71971      1685/io.lovelace.1
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24780      309/io.admin.0
                                  tcp6       0      0 :::8083                 :::*                    LISTEN      1001       57312      1894/io.web.1
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57270      1877/io.web.0
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       72158      1758/io.simple-api.
                                  tcp6       0      0 :::1980                 :::*                    LISTEN      1001       25097      449/node-red
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          21427      1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          23320      1/init
                                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          25770      295/master
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          21426      1/init
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       76158      1844/io.upnp.0
                                  udp        0      0 192.168.99.33:5353      0.0.0.0:*                           1001       41584      1007/io.tr-064.0
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       37268      952/io.shelly.1
                                  udp6       0      0 :::111                  :::*                                0          21428      1/init
                                  2025-08-04 19:10:43.240  - error: drops-weather.0 (107328) Cannot read properties of null (reading 'pages')
                                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) error launching browser undefined - Error: Failed to launch the browser process!
                                  2025-08-04 19:10:43.244  - warn: drops-weather.0 (107328) setTimeout called, but adapter is shutting down
                                  2025-08-04 19:10:43.244  - warn: drops-weather.0 (107328) TypeError: Cannot read properties of null (reading 'newPage')
                                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) unhandled promise rejection: Cannot read properties of null (reading 'pages')
                                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) TypeError: Cannot read properties of null (reading 'pages')
                                  2025-08-04 19:10:43.244  - error: drops-weather.0 (107328) Cannot read properties of null (reading 'pages')
                                  2025-08-04 19:10:43.252  - info: host.iobroker instance system.adapter.drops-weather.0 having pid 107328 terminated with code 0 (NO_ERROR)
                                  2025-08-04 19:10:58.584  - info: admin.0 (309) <== Disconnect system.user.admin from ::ffff:192.168.99.143 admin
                                  2025-08-04 19:11:46.726  - info: mqtt.0 (835) Client [gaszaehler] reconnected. Old secret 1754307314012_4778. New secret 1754327506723_9892
                                  2025-08-04 19:11:46.753  - info: mqtt.0 (835) Client [gaszaehler] subscribes on "mqtt.0.gaszaehler.ctrl.flow_start"
                                  2025-08-04 19:11:46.763  - info: mqtt.0 (835) Client [gaszaehler] subscribes on "mqtt.0.gaszaehler.ctrl.set_prevalue"
                                  2025-08-04 19:11:46.953  - info: mqtt.0 (835) Client [gaszaehler] publishOnSubscribe
                                  2025-08-04 19:11:46.963  - info: mqtt.0 (835) Client [gaszaehler] publishOnSubscribe
                                  E 1 Antwort Letzte Antwort
                                  • David G.D David G.
                                    @emil70
                                    Selbe bei mir.
                                    v7.6.17
                                    99+
                                    99+
                                    Log-Größe: 1.4 KB
                                    drops-weather.0
                                    Zeit
                                    debug
                                    Nachricht
                                    host.iobroker
                                    host.iobroker
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                    drops-weather.0
                                      Virtualization: lxc
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                    CPU threads: 4
                                                     RTC time: n/a
                                              RTC in local TZ: no
                                    david
                                    HOME=/home/david
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:           536M        521M         15M
                                             8192 M total memory
                                             4251 M used memory
                                             3819 M free memory
                                                0 M buffer memory
                                              121 M swap cache
                                              512 M total swap
                                              496 M used swap
                                               15 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    1.4G    /var/
                                    901M    /var/log
                                    467M    /var/cache
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    admin:          7.6.17
                                    javascript:     8.9.2
                                    Adapter State
                                    + instance is alive
                                    Objects and States
                                    Objects:        35683
                                    States:         32075
                                    Pending Updates: 0
                                    E Online
                                    E Online
                                    emil70
                                    #183
                                    @david-g
                                    HAbe etzt das nachinstalliert und nun geht es
                                    sudo apt update
                                    sudo apt install libnss3
                                    sudo apt install libatk1.0-0
                                    sudo apt install libxkbcommon-x11-0
                                    sudo apt-get install libxcomposite-dev
                                    sudo apt-get install libxdamage1
                                    sudo apt-get install libxrandr2
                                    sudo apt-get install libgbm-dev
                                    sudo apt-get install libasound2
                                    sudo apt-get install -y libatk-bridge2.0-0 libgtk-3.0
                                    gruss emil70
                                    ilovegymI David G.D 2 Antworten Letzte Antwort
                                    • E emil70
                                      @david-g
                                      sudo apt update
                                      ilovegymI Offline
                                      ilovegymI Offline
                                      ilovegym
                                      schrieb am zuletzt editiert von ilovegym
                                      #184
                                      @emil70 setz die Pakete in die ENV im Docker, sonst muss du sieh ja jedesmal neu nach installieren..
                                      dir hier meine ich:
                                      - PACKAGES=nano redis-tools influxdb cifs-utils nfs-common
                                      und da hintendran alle Pakete einfach mit Leerzeichen dazwischen
                                      • E emil70
                                        @david-g
                                        sudo apt update
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #185
                                        @emil70
                                        Ja, so läuft es.
                                        sudo apt update && sudo apt install -y libnss3 libatk1.0-0 libxkbcommon-x11-0 libxcomposite-dev libxdamage1 libxrandr2 libgbm-dev libasound2 libatk-bridge2.0-0 libgtk-3-0
                                        Müssten die Abhängigkeiten nicht vom Adapter mit installiert werden?
                                        E ilovegymI 2 Antworten Letzte Antwort
                                        • ilovegymI ilovegym
                                          dir hier meine ich:
                                          E Online
                                          E Online
                                          emil70
                                          #186
                                          @ilovegym
                                          Kann ich dir nicht sagen. Wie sehe ich das unter docker?
                                          gruss emil70
                                          ilovegymI 1 Antwort Letzte Antwort
