  4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
adapteratomfeediobroker.rssfeedrdfrssviswidget
705 Beiträge 35 Kommentatoren 241.7k Aufrufe 38 Beobachtet
  • T trojanhector
    @oliverio
    Das scheint sich auch auf das JSON Widget 0.1.9 auszuwirken. Habe hier auch Fehlermeldungen mit Bezug auf RSS-FEED (3.3.1).
    Hier der Log aus der Console.
    load script:41
               GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js net::ERR_ABORTED 404 (Not Found)
    (anonymous) @ load script:41
    (anonymous) @ jsonp chunk loading:43
    (anonymous) @ ensure chunk:6
    (anonymous) @ ensure chunk:5
    ./RSSArticleMarqueeV5 @ container-entry:6
    a @ container-entry:28
    (anonymous) @ visLoadWidgets.tsx:144
    await in (anonymous)
    (anonymous) @ visLoadWidgets.tsx:177
    a @ visLoadWidgets.tsx:173
    (anonymous) @ visLoadWidgets.tsx:326
    Promise.then
    (anonymous) @ visLoadWidgets.tsx:254
    Promise.then
    r @ visLoadWidgets.tsx:225
    (anonymous) @ visWidgetsCatalog.tsx:302
    c @ helpers.ts:98
    setTimeout
    (anonymous) @ browserapierrors.ts:109
    (anonymous) @ visWidgetsCatalog.tsx:301
    collectRxInformation @ visWidgetsCatalog.tsx:300
    onWidgetsLoaded @ Editor.jsx:813
    onLoaded @ Editor.jsx:1028
    loadWidgets @ visEngine.jsx:1529
    await in loadWidgets
    (anonymous) @ visEngine.jsx:208
    Promise.then
    O @ visEngine.jsx:196
    cs @ react-dom.production.min.js:184
    Vs @ react-dom.production.min.js:197
    Hi @ react-dom.production.min.js:291
    Ml @ react-dom.production.min.js:279
    gl @ react-dom.production.min.js:279
    fl @ react-dom.production.min.js:279
    rl @ react-dom.production.min.js:267
    S @ scheduler.production.min.js:13
    T @ scheduler.production.min.js:14Understand this errorAI
    load script:41
               GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_colors_blue_js-node_modules_mui_material_colors_common_js-n-6f5860.f842f4ec.chunk.js net::ERR_ABORTED 404 (Not Found)
    Promise.then
    Promise.then
    c @ helpers.ts:98
    setTimeout
    Promise.then
    console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: ChunkLoadError: Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.
    (error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)
    (anonymous) @ console.ts:40
    (anonymous) @ visLoadWidgets.tsx:197
    Promise.catch
    (anonymous) @ visLoadWidgets.tsx:196
    Promise.then
    Promise.then
    c @ helpers.ts:98
    setTimeout
    Promise.then
    console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {"message":"Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.\n(error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)","name":"ChunkLoadError","type":"error","request":"http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js"}
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    #645
    @trojanhector
    Ja
    Das neue Widget wurde in der kompilation nicht mit übernommen.
    Irgendwas wurde an den basisbibliotheken für den Build verändert, was ich aber noch herausfinden muss.
    Bluefox will/hat auf ein komplett neues Build-System umstellen (vite), hat aber bisher erst für typescript adapter Beispiele. Für JavaScript müsste es auch funktionieren, benötige da aber wieder mal F+E Zeit, die gerade nicht da ist.
    Daher aktuell bitte noch v4 verwenden. Da fehlt halt daspopup Feature. Die neue Version v5 habe ich gemacht, das der Wechsel bewusst erfolgt, da nun mehr Eigenschaften für das Widget eingegeben werden müssen.
    Meine Adapter und Widgets
    Links im Profil
    • OliverIOO Offline
      OliverIOO Offline
      OliverIO
      #646
      Neue Version rssfeed 3.5.0
      Das Update betrifft aktuell nur den rssfeed adapter + die vis1 widgets, nicht den vis-2 adapter
      • in den templates des jsonTemplate widgets können nun auch async/await funktionen verwendet werden. Siehe Beispiel in der Dokumentation: JSON Template mit async/await
      Links im Profil
      • OliverIOO Offline
        OliverIOO Offline
        OliverIO
        #647
        Neue Version vis-2-widgets-rssfeed 1.1.2
        Die build-Probleme konnte ich beheben, auch wenn mir die Ursache dafür unerklärlich ist.
        Somit wäre das popup-Feature für das Marquee Widget (widget version 5) auch funktionsfähig.
        @Oli Bitte testen
        @trojanhector sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
        Das JSON widget dürfte das unter vis2 nicht betreffen, da dieses widget sich nun im adapter vis-2-widgets-ovarous befindet. Aber du hast wahrscheinlich beide installiert, somit siehst du die rssfeed fehlermeldungen.
        Links im Profil
        O OliverIOO 3 Antworten Letzte Antwort
        • OliverIOO Offline
          OliverIOO Offline
          OliverIO
          #648
          Ich poste das hier auch mal rein.
          das Widget JSON Template für vis-2 befindet sich ja nun im Adapter vis-2-widgets-ovarious
          dafür gibt es nun ein Update
          Neue Version 1.0
          • das feature async/await wurde ergänzt, d.h. auch hier können nun Funktionen mit async/await definiert und verwendet werden.
          Links im Profil
          • OliverIOO Offline
            OliverIOO Offline
            OliverIO
            #649
            Der Usecase für die interaktive Todolist mit direkter Datenbank-Kommunikation wurde nun hinzugefügt
            https://github.com/oweitman/ioBroker.rssfeed?tab=readme-ov-file#use-case-for-a-database-supported-task-list
            vlg auch hier
            https://forum.iobroker.net/topic/80347/button-wert-aus-der-vis-in-sql-eintragen-speichern/11?_=1742498938735
            Links im Profil
            • OliverIOO OliverIO
              @Oli Bitte testen
              O Offline
              O Offline
              Oli
              #650
              @oliverio
              sorry für die späte Antwort. Das neue "marquee widget 5" wird jetzt mit angezeigt
              Oliver
              • O Oli
                @oliverio
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                #651
                @oli
                Links im Profil
                  @Oli Bitte testen
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  #652
                  Die Version 1.1.2 befindet sich nun im stable
                  @oliverio sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
                  @Oli Bitte testen
                  Links im Profil
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    #653
                    Diese Version ist nun auf Stable verfügbar
                    Neue Version rssfeed 3.5.2
                    Links im Profil
                    • OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #654
                      Neue Version iobroker.vis-2-widgets-rssfeed 1.2.0
                      • Das compiler framework wurde von CRA auf vite umgestellt
                      • Das deprecated widget RSSMarquee wurde entfernt. RSSMarquee5 ist bereits seit einigen Versionen verfügbar
                      Es wäre schön, wenn das noch jemand bei sich testen könnte, da die zugrundeliegenden Änderungen umfangreich waren. An der Nutzerfunktionalität dürfte sich nichts geändert haben.
                      Links im Profil
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        #655
                        Diese Version befindet sich nun auch im stable repository
                        Links im Profil
                          trojanhector
                          #656
                          @oliverio Servus,
                          bei mir verschwinden die Widgets bei v 1.2.0. Sowohl im Editor für VIS als auch auf der Homepage.
                          Nach Rückstellen auf 1.1.2 sind sie wieder da.
                          Verfügbar: 7.0.6
                          Installiert: 7.0.6
                          Plattform: linux
                          Betriebssystem: linux
                          Architektur: arm64
                          Node.js: v20.19.3
                          RSS Feed: 3.5.2
                          NPM: 10.8.2
                          _npmNewest: 10.8.2
                          _nodeNewestNext: 20.19.3
                          _nodeNewest: 20.19.3
                          _npmCurrent: 10.8.2
                          _npmNewestNext: 10.8.2
                          _nodeCurrent: 20.19.3
                          • T trojanhector
                            @oliverio Servus,
                            Verfügbar: 7.0.6
                            Installiert: 7.0.6
                            Plattform: linux
                            Architektur: arm64
                            Node.js: v20.19.3
                            RSS Feed: 3.5.2
                            NPM: 10.8.2
                            _npmNewest: 10.8.2
                            _npmCurrent: 10.8.2
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            #657
                            @trojanhector
                            Bitte einmal auf der Konsole
                            iob upload all
                            Und wenn dann immer noch nicht, dann bitte
                            Evtl Fehlermeldungen auf der Browser Konsole mit f12 schauen
                            Links im Profil
                              @trojanhector
                              iob upload all
                              trojanhector
                              #658
                              @oliverio
                              es geht nacht iob updload all leider immer noch nicht.
                              Der Browser wirft folgende Fehlermeldungen:
                              • T trojanhector
                                @oliverio
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                #659
                                @trojanhector
                                Ja das ist eigentlich der Fehler der mit Upload sich erledigt.
                                Diendatei ist im aktuellen Paket auch enthalten und wurde im Beta bereits mehrfach installiert
                                Starte bitte auch mal noch den vis-2 Adapter neu
                                Iob Upload all dauert auch eine weile
                                Links im Profil
                                T O 2 Antworten Letzte Antwort
                                  @trojanhector
                                  trojanhector
                                  #660
                                  @oliverio
                                  Der Adapter wurde neu gestartet, die Homepage neu aufgerufen. Es gibt keine Änderung.
                                  T OliverIOO 2 Antworten Letzte Antwort
                                    @trojanhector
                                    O Offline
                                    O Offline
                                    Oli
                                    #661
                                    @oliverio
                                    ich habe das gleiche Problem wie @trojanhector, ein "iob upload all" und ein Neustart des VIS-2 Adapters bringt keinen Erfolg.
                                    Installierte VIS-Version: 2.9.64
                                    Uncaught SyntaxError: Cannot use import statement outside a module
                                    visLoadWidgets.tsx:197  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
                                    visLoadWidgets.tsx:198  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {}
                                    (anonymous) @ visLoadWidgets.tsx:198
                                    Oliver
                                    • T trojanhector
                                      @oliverio
                                      trojanhector
                                      #662
                                      @trojanhector
                                      Ich habe auf VIS-2 2.12.10 upgedatet. Da sind die Widgets wieder da.
                                      • T trojanhector
                                        @oliverio
                                        OliverIOO Offline
                                        OliverIOO Offline
                                        OliverIO
                                        #663
                                        @trojanhector
                                        Ich versuche morgen oder übermorgen mal das nachzustellen.
                                        Ok ich schaue mal ob es an vis2 2.9.64 liegt und muss dann ggfs. Die requirements noch anpassen.
                                        Links im Profil
                                        • J Offline
                                          jwerlsdf
                                          #664
                                          ich habe VIS1. Wie kann ich denn einen festen Textbaustein im Lauffeld anzeigen lassen? Könnte mir bitte jemand auf die Sprünge helfen?
