  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    5.9k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    #1914
    @baeckerman83 installier nochmal bitte
    da sollte jetzt ein warning kommen.. den mal posten bitte
    • B baeckerman83
      @neuschwansteini
      Das lag an meiner Docker Installation. Ich habe das Image mal aktuallisiert, jetzt gibt es iob diag.
      Die Version 3.1.2 wirft aber weiterhin den Fehler. Ich dachte erst nicht, der Fehler kommt aber sobald er versucht das Auto zu laden.
      2025-02-19 20:52:57.906 - info: bluelink.0 (3085) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.18.2, js-controller: 6.0.11
      2025-02-19 20:52:57.938 - info: bluelink.0 (3085) Login to api
      2025-02-19 20:52:59.672 - info: bluelink.0 (3085) 1 Vehicles found
      2025-02-19 20:53:00.063 - info: bluelink.0 (3085) Read new update for VIN from the server
      2025-02-19 20:53:03.015 - error: bluelink.0 (3085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-02-19 20:53:03.016 - error: bluelink.0 (3085) unhandled promise rejection: The state contains the forbidden properties day, time!
      2025-02-19 20:53:03.018 - error: bluelink.0 (3085) Error: The state contains the forbidden properties day, time!
      at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:209:13)
      at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:3842:21)
      at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:3820:17)
      at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:133:30)
      at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21)
      at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
      at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
      2025-02-19 20:53:03.018 - error: bluelink.0 (3085) The state contains the forbidden properties day, time!
      2025-02-19 20:53:03.030 - info: bluelink.0 (3085) Adapter bluelink cleaned up everything...
      2025-02-19 20:53:03.038 - info: bluelink.0 (3085) terminating
      2025-02-19 20:53:03.039 - warn: bluelink.0 (3085) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-02-19 20:53:03.048 - error: bluelink.0 (3085) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-02-19 20:53:03.049 - error: bluelink.0 (3085) unhandled promise rejection: The state contains the forbidden properties day, time!
      2025-02-19 20:53:03.050 - error: bluelink.0 (3085) Error: The state contains the forbidden properties day, time!
      2025-02-19 20:53:03.050 - error: bluelink.0 (3085) The state contains the forbidden properties day, time!
      2025-02-19 20:53:03.542 - info: bluelink.0 (3085) terminating
      2025-02-19 20:53:03.551 - warn: bluelink.0 (3085) get state error: Connection is closed.
      2025-02-19 20:53:03.563 - error: bluelink.0 (3085) Cannot check object existence of "bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning": DB closed
      2025-02-19 20:53:03.569 - warn: bluelink.0 (3085) Could not perform strict object check of state bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.plugType: DB closed
      2025-02-19 20:53:03.570 - warn: bluelink.0 (3085) get state error: Connection is closed.
      2025-02-19 20:53:03.571 - error: bluelink.0 (3085) Error extract objectKeys: KNAC381AFR5176980.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
      2025-02-19 20:53:03.572 - error: bluelink.0 (3085) Error: Could not check object existence of bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning: Cannot check object existence of "bluelink.0.VIN.vehicleStatusRaw.vehicleStatus.evStatus.batteryPreconditioning": DB closed
      2025-02-19 20:53:03.688 - error: host.iobrokerMaster instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-02-19 20:53:03.689 - info: host.iobrokerMaster Restart adapter system.adapter.bluelink.0 because enabled
      2025-02-19 20:53:03.689 - warn: host.iobrokerMaster Do not restart adapter system.adapter.bluelink.0 because restart loop detected
      Script v.2025-02-02
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v10.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       20:37:08 up 147 days,  3:11,  0 user,  load average: 2.27, 5.05, 5.91
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
      Wed Feb 19 19:37:09 UTC 2025
      Wed Feb 19 20:37:09 CET 2025
      CET +0100
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             10G        7.0G        537M        2.2G        5.3G        3.3G
      Swap:           8.3G        868M        7.4G
      Total:           18G        7.9G        8.0G
      Active iob-Instances:   34
               9806 M total memory
               6702 M used memory
               3592 M active memory
               2193 M inactive memory
                511 M free memory
                  8 M buffer memory
               5018 M swap cache
               7931 M total swap
                827 M used swap
               7104 M free swap
      top - 20:37:09 up 147 days,  3:11,  0 user,  load average: 2.41, 5.03, 5.90
      Tasks:  41 total,   2 running,  39 sleeping,   0 stopped,   0 zombie
      %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   9806.5 total,    509.5 free,   6704.0 used,   5027.5 buff/cache
      MiB Swap:   7931.9 total,   7104.1 free,    827.9 used.   3102.5 avail Mem
      *** DMESG CRITICAL ERRORS ***
      1 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      Filesystem     Type   Size  Used Avail Use% Mounted on
      /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /
      tmpfs          tmpfs   64M     0   64M   0% /dev
      tmpfs          tmpfs  4.8G     0  4.8G   0% /sys/fs/cgroup
      /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /opt/iobroker
      /dev/vg1000/lv btrfs  5.3T  4.6T  663G  88% /etc/hosts
      shm            tmpfs   64M     0   64M   0% /dev/shm
      tmpfs          tmpfs  4.8G     0  4.8G   0% /proc/acpi
      tmpfs          tmpfs  4.8G     0  4.8G   0% /proc/scsi
      tmpfs          tmpfs  4.8G     0  4.8G   0% /sys/firmware
      [Wed Sep 25 18:26:53 2024] EXT4-fs (md0): barriers disabled
      [Wed Sep 25 18:26:53 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
      [Wed Sep 25 18:26:55 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Wed Sep 25 18:26:55 2024] EXT4-fs (md0): re-mounted. Opts: (null)
      [Wed Sep 25 18:27:58 2024] EXT4-fs (sdq1): barriers disabled
      [Wed Sep 25 18:27:59 2024] EXT4-fs (sdq1): recovery complete
      [Wed Sep 25 18:27:59 2024] EXT4-fs (sdq1): mounted filesystem with ordered data mode. Opts: nodelalloc,synoacl,data=ordered
      Show mounted filesystems:
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  /dev/vg1000/lv[/@syno/@docker/btrfs/subvolumes/81b1a4500d67ee19fc85084d0a4b18e9fc4d636a867707593d6b88ac22298438]       btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=2870,subvol=/@syno/@docker/btrfs/subvolumes/81b1a4500d67ee19fc85084d0a4b18e9fc4d636a867707593d6b88ac22298438
      |-/opt/iobroker    /dev/vg1000/lv[/@syno/docker/iobroker_data]        btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=919,subvol=/@syno/docker/iobroker_data
      |-/etc/resolv.conf /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/resolv.conf] btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/resolv.conf
      |-/etc/hostname    /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hostname]    btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hostname
      `-/etc/hosts       /dev/vg1000/lv[/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hosts]       btrfs  rw,relatime,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,subvolid=257,subvol=/@syno/@docker/containers/9c62beb901a325409adafcd8053411be60c9ddd6c4c73fe9da13844e0bed764e/hosts
      /var:
      16M     /var/
      14M     /var/lib
      13M     /var/lib/dpkg/info
      13M     /var/lib/dpkg
      1.9M    /var/cache
      /opt/iobroker/backups:
      45M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1016M   /opt/iobroker/iobroker-data/
      780M    /opt/iobroker/iobroker-data/files
      616M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.18.2-1nodesource1
        Version table:
       *** 20.18.2-1nodesource1 100
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobrokerMaster      iobrokerMaster (version: 6.0.11, hostname: iobrokerMaster, alive, uptime: 568)
      iobrokerslave       iobrokerslave (version: 6.0.11, hostname: iobrokerslave , alive, uptime: 534)
      Core adapters versions
      admin:          7.1.5
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobrokerMaster                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobrokerMaster                           -  enabled
      + system.adapter.backitup.0               : backitup              : iobrokerMaster                           -  enabled
      + system.adapter.ble.0                    : ble                   : iobrokerslave                            -  enabled
      + system.adapter.bluelink.0               : bluelink              : iobrokerMaster                           -  enabled
      + system.adapter.bmw.0                    : bmw                   : iobrokerMaster                           -  enabled
      + system.adapter.chromecast.0             : chromecast            : iobrokerMaster                           -  enabled
      + system.adapter.deconz.0                 : deconz                : iobrokerMaster                           -  enabled, port: 8088
      + system.adapter.denon.0                  : denon                 : iobrokerMaster                           -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : iobrokerMaster                           -  enabled
      + system.adapter.discovery.0              : discovery             : iobrokerMaster                           -  enabled
      + system.adapter.fritzbox.0               : fritzbox              : iobrokerMaster                           -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobrokerMaster                           -  enabled
      + system.adapter.growatt.0                : growatt               : iobrokerMaster                           -  enabled
      + system.adapter.ham.0                    : ham                   : iobrokerMaster                           -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobrokerMaster                           -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : iobrokerMaster                           -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobrokerMaster                           -  enabled
        system.adapter.influxdb.0               : influxdb              : iobrokerMaster                           - disabled, port: 8086
      + system.adapter.javascript.0             : javascript            : iobrokerMaster                           -  enabled
      + system.adapter.node-red.0               : node-red              : iobrokerMaster                           -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ocpp.1                   : ocpp                  : iobrokerMaster                           -  enabled, port: 9022
      + system.adapter.pi-hole.0                : pi-hole               : iobrokerMaster                           -  enabled
      + system.adapter.sayit.0                  : sayit                 : iobrokerMaster                           -  enabled
      + system.adapter.shelly.0                 : shelly                : iobrokerMaster                           -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobrokerMaster                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobrokerMaster                           -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sonos.0                  : sonos                 : iobrokerMaster                           -  enabled
      + system.adapter.sql.0                    : sql                   : iobrokerMaster                           -  enabled, port: 3306
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerMaster                           -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobrokerMaster                           -  enabled
      + system.adapter.tradfri.0                : tradfri               : iobrokerMaster                           -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobrokerMaster                           - disabled
      + system.adapter.web.0                    : web                   : iobrokerMaster                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Beta (latest)
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: Beta (latest)
      Adapter    "admin"        : 7.4.21   , installed 7.1.5  [Updatable]
      Adapter    "alexa2"       : 3.26.7   , installed 3.25.5 [Updatable]
      Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
      Adapter    "ble"          : 0.14.1   , installed 0.14.0 [Updatable]
      Adapter    "bluelink"     : 3.1.1    , installed 3.1.0  [Updatable]
      Adapter    "bmw"          : 2.9.3    , installed 2.9.3
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "deconz"       : 1.6.4    , installed 1.4.1  [Updatable]
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fritzdect"    : 2.5.13   , installed 2.5.11 [Updatable]
      Adapter    "growatt"      : 3.3.1    , installed 3.3.1
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.15.0 [Updatable]
      Adapter    "javascript"   : 8.9.1    , installed 8.8.3  [Updatable]
      Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
      Adapter    "node-red"     : 6.0.5    , installed 5.2.1  [Updatable]
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
      Adapter    "shelly"       : 9.0.0    , installed 8.2.1  [Updatable]
      Adapter    "socketio"     : 7.0.1    , installed 6.7.1  [Updatable]
      Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 6.3.1    , installed 6.2.5  [Updatable]
      Adapter    "ws"           : 3.0.5    , installed 2.6.2  [Updatable]
      Objects and States
      Objects:        14029
      States:         11607
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 4
      *** Listening Ports ***
      tcp        0      0 10.0.3.22:2001          0.0.0.0:*               LISTEN      1000       1501233678 -
      tcp        0      0 127.0.0.11:44114        0.0.0.0:*               LISTEN      0          1501197598 -
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1501225397 -
      tcp        0      0 10.0.3.22:2010          0.0.0.0:*               LISTEN      1000       1501229505 -
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       1501230419 -
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1501209631 -
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1501209333 -
      tcp        0      0 10.0.3.22:9292          0.0.0.0:*               LISTEN      1000       1501234686 -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1501210119 -
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1501237860 -
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1501234010 -
      tcp6       0      0 :::9022                 :::*                    LISTEN      1000       1501236578 -
      tcp6       0      0 :::3500                 :::*                    LISTEN      1000       1501233265 -
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1501217435 -
      udp        0      0 0.0.0.0:43135           0.0.0.0:*                           1000       1501234123 -
      udp        0      0 127.0.0.11:44075        0.0.0.0:*                           0          1501197597 -
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       1501233862 -
      udp        0      0 10.0.3.22:5353          0.0.0.0:*                           1000       1501232924 -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1501239355 -
      2025-02-19 20:33:27.020  - info: alexa2.0 (972) Initialization Done ...
      2025-02-19 20:33:32.386  - info: alexa2.0 (972) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2025-02-19 20:37:27.607  - info: host.iobrokerMaster stopInstance system.adapter.bmw.0 (force=false, process=true)
      2025-02-19 20:37:27.612  - info: bmw.0 (581) Got terminate signal TERMINATE_YOURSELF
      2025-02-19 20:37:27.615  - info: bmw.0 (581) terminating
      2025-02-19 20:37:27.629  - info: bmw.0 (581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-19 20:37:27.650  - info: host.iobrokerMaster stopInstance system.adapter.bmw.0 send kill signal
      2025-02-19 20:37:28.130  - info: bmw.0 (581) terminating
      2025-02-19 20:37:28.568  - info: host.iobrokerMaster instance system.adapter.bmw.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-19 20:37:32.669  - info: host.iobrokerMaster instance system.adapter.bmw.0 in version "2.9.3" started with pid 1574
      2025-02-19 20:37:40.602  - info: bmw.0 (1574) starting. Version 2.9.3 in /opt/iobroker/node_modules/iobroker.bmw, node: v20.18.2, js-controller: 6.0.11
      2025-02-19 20:37:40.659  - info: bmw.0 (1574) Session found. If the login fails please delete bmw.0.auth.session and restart the adapter
      2025-02-19 20:37:40.907  - info: bmw.0 (1574) Start getting bmw vehicles
      2025-02-19 20:37:41.265  - info: bmw.0 (1574) Found 3 bmw vehicles
      2025-02-19 20:37:51.598  - info: bmw.0 (1574) Initial first update of the vehicles
      2025-02-19 20:38:40.138  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-02-19 20:38:40.140  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-02-19 20:38:40.140  - info: alexa2.0 (972)     Device-type:A3M81UGFDWTUWE - Benjamin's Magenta Mini (Magenta Mini) (TIMERS_AND_ALARMS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MULTI_WAKEWORDS_SUPPORTED,EQUALIZER_CONTROLLER_MIDRANGE,SIRIUSXM,SET_TIME_ZONE,SLEEP,EQUALIZER_CONTROLLER_TREBLE,EARCONS,SUPPORTS_LOCALE,CUSTOM_ALARM_TONE,AUDIBLE,MUSIC_SKILL,TIDAL,SPEECH_RECOGNIZER_USS,ADAPTIVE_LISTENING,AUDIO_CONTROLS,DEEZER,PERSISTENT_CONNECTION,SET_LOCALE,APPLE_MUSIC,REMINDERS,VOLUME_SETTING,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,EQUALIZER_CONTROLLER_BASS,AMAZON_MUSIC,GOLDFISH,DREAM_TRAINING,ASCENDING_ALARM_VOLUME,MICROPHONE,KINDLE_BOOKS,AUDIO_PLAYER,CHANGE_NAME,I_HEART_RADIO,SOUND_SETTINGS,DEREGISTER_DEVICE,TUNE_IN,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,FAR_FIELD)
      2025-02-19 20:38:40.594  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-02-19 20:38:40.594  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-02-19 20:38:40.595  - info: alexa2.0 (972)     Device-type:A3BW5ZVFHRCQPO - Benjamin's BMW Group – Amazon Alexa Car Integration (BMW Group – Amazon Alexa Car Integration) (TIMERS_AND_ALARMS,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,SIRIUSXM,SLEEP,AUDIBLE,MUSIC_SKILL,TIDAL,ADAPTIVE_LISTENING,DEEZER,PERSISTENT_CONNECTION,APPLE_MUSIC,REMINDERS,VOLUME_SETTING,AMAZON_MUSIC,GOLDFISH,DREAM_TRAINING,MICROPHONE,HANDS_FREE,PEONY,KINDLE_BOOKS,AUDIO_PLAYER,CHANGE_NAME,I_HEART_RADIO,DEREGISTER_DEVICE,TUNE_IN)
      2025-02-19 20:38:40.897  - info: alexa2.0 (972) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-02-19 20:38:40.897  - info: alexa2.0 (972) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-02-19 20:38:40.897  - info: alexa2.0 (972)     Device-type:A1Q6UGEXJZWJQ0 - Benjamin's 2nd Fire TV (SHARKNADO,TIMERS_AND_ALARMS,PERSISTENT_CONNECTION,FLASH_BRIEFING,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,REMINDERS,MULTI_WAKEWORDS_SUPPORTED,VOLUME_SETTING,EARCONS,SUPPORTS_LOCALE,SUPPORTS_SOFTWARE_VERSION,CUSTOM_ALARM_TONE,MICROPHONE,CHANGE_NAME,SOUND_SETTINGS,SUPPORTS_LOCALE_SWITCH,DIALOG_INTERFACE_VERSION,SPEECH_RECOGNIZER_USS,ADAPTIVE_LISTENING,ACTIVE_AFTER_FRO,ARTHUR_TARGET)
      2025-02-19 20:38:54.895  - info: bmw.0 (1574) First update of Trips and Demands in 10 minutes
      #1915
      @baeckerman83
      und mach bitte die iobroker updates.. das ist ja n Sack voll... js-controller v6.x
      auf beiden, du hast ja Master/Slave..
        marchusar
        #1916
        Hallo, leider geht bei mir die 3.1.2 (und 3.1.1) auch nicht, nur die 3.1.0 läuft einwandfrei.
        Kann jemand helfen?
        2025-04-30 12:20:46.720 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" started with pid 13114
        2025-04-30 12:20:50.090 - info: bluelink.0 (13114) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
        2025-04-30 12:20:50.120 - info: bluelink.0 (13114) Login to api
        2025-04-30 12:20:52.354 - info: bluelink.0 (13114) 1 Vehicles found
        2025-04-30 12:20:52.518 - info: bluelink.0 (13114) Read new update for KNAC381xxx from the server
        2025-04-30 12:20:53.510 - error: bluelink.0 (13114) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-04-30 12:20:53.511 - error: bluelink.0 (13114) unhandled promise rejection: The state contains the forbidden properties day, time!
        2025-04-30 12:20:53.514 - error: bluelink.0 (13114) Error: The state contains the forbidden properties day, time!
        at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
        at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
        at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
        2025-04-30 12:20:53.514 - error: bluelink.0 (13114) The state contains the forbidden properties day, time!
        2025-04-30 12:20:53.523 - info: bluelink.0 (13114) Adapter bluelink cleaned up everything...
        2025-04-30 12:20:53.524 - info: bluelink.0 (13114) terminating
        2025-04-30 12:20:53.526 - warn: bluelink.0 (13114) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2025-04-30 12:20:53.532 - error: bluelink.0 (13114) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2025-04-30 12:20:53.533 - error: bluelink.0 (13114) unhandled promise rejection: The state contains the forbidden properties day, time!
        2025-04-30 12:20:53.534 - error: bluelink.0 (13114) Error: The state contains the forbidden properties day, time!
        2025-04-30 12:20:53.535 - error: bluelink.0 (13114) The state contains the forbidden properties day, time!
        2025-04-30 12:20:54.027 - info: bluelink.0 (13114) terminating
        2025-04-30 12:20:54.035 - warn: bluelink.0 (13114) get state error: Connection is closed.
        2025-04-30 12:20:54.041 - warn: bluelink.0 (13114) get state error: Connection is closed.
        2025-04-30 12:20:54.046 - error: bluelink.0 (13114) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning": DB closed
        2025-04-30 12:20:54.048 - warn: bluelink.0 (13114) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen.backLeft: DB closed
        2025-04-30 12:20:54.049 - warn: bluelink.0 (13114) get state error: Connection is closed.
        2025-04-30 12:20:54.050 - error: bluelink.0 (13114) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
        2025-04-30 12:20:54.051 - error: bluelink.0 (13114) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning": DB closed
        2025-04-30 12:20:54.054 - error: bluelink.0 (13114) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus": Connection is closed.
        2025-04-30 12:20:54.057 - error: bluelink.0 (13114) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
        2025-04-30 12:20:54.058 - error: bluelink.0 (13114) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus": Connection is closed.
        2025-04-30 12:20:54.247 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2025-04-30 12:20:54.248 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
        2025-04-30 12:20:54.248 - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
        iob diag
         Static hostname: raspberrypi4
               Icon name: computer
        Operating System: Raspbian GNU/Linux 12 (bookworm)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
        Kernel:                 armv7l
        Userland:               32 bit
        User-ID:                1000
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/nodejs         v20.19.1
        /usr/bin/node           v20.19.1
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.31.0
        Recommended versions are nodejs 20.19.1 and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:            4.0G        1.8G        1.4G        1.1M        990M        2.3G
        Swap:           209M          0B        209M
        Total:          4.2G        1.8G        1.6G
        Active iob-Instances:   19
        ioBroker Core:          js-controller           7.0.6
                                admin                   7.6.3
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.admin.1                  : admin                 : raspberrypi4                             -  enabled, port: 11443, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 11444, bind: 0.0.0.0 (SSL), run as: admin
        + system.adapter.web.1                    : web                   : raspberrypi4                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
        Objects:                4326
        States:                 3543
        Size of iob-Database:
        23M     /opt/iobroker/iobroker-data/objects.jsonl
        7.8M    /opt/iobroker/iobroker-data/objects.json.migrated
        7.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        2.9M    /opt/iobroker/iobroker-data/states.jsonl
        836K    /opt/iobroker/iobroker-data/states.json.migrated
        836K    /opt/iobroker/iobroker-data/states.json.bak.migrated
        Operating System is the current Debian stable version codenamed 'bookworm'!
        ? Meister MopperM 2 Antworten Letzte Antwort
        • M marchusar
          Kann jemand helfen?
          iob diag
                 Icon name: computer
              Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:           209M          0B        209M
                                  admin                   7.6.3
          Objects type: jsonl
          States  type: jsonl
          Objects:                4326
          States:                 3543
          #1917
          @marchusar
          welches Fahrzeug?
          • M marchusar
            Kann jemand helfen?
            iob diag
                   Icon name: computer
                Architecture: arm
            Kernel:                 armv7l
            Userland:               32 bit
            User-ID:                1000
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            MEMORY:
            Swap:           209M          0B        209M
                                    admin                   7.6.3
            Objects type: jsonl
            States  type: jsonl
            Objects:                4326
            States:                 3543
            Meister MopperM Online
            Meister Mopper
            #1918
            @marchusar
            Schick mal bitte die Langfassung von iob diag .
            Proxmox und HA ...
            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
              @marchusar
              welches Fahrzeug?
              marchusar
              #1919
              @neuschwansteini Kia EV6 2024 (vor FL)
              • M marchusar
                #1920
                @marchusar
                bei Kia kenn ich mich nich aus, ist das mit ccNC Infotainment? was bedeutet (vor FL) ???
                  @marchusar
                  marchusar
                  #1921
                  @neuschwansteini Vor Facelift, also noch das alte Entertainment System.
                    @marchusar
                    marchusar
                    schrieb am zuletzt editiert von marchusar
                    #1922
                    *** iob diag is starting up, please wait ***
                    iob diag needs to be updated. Please execute 'iobroker fix' first.
                    *** ioBroker Diagnosis ***
                    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                    https://forum.iobroker.net
                    Just copy and paste the Summary Page, including the ``` characters at start and end.
                    It helps us to help you!
                    * Some output is masked. For full results please use 'iob diag --unmask' *
                    Press any key to continue
                    ```bash
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                    OS is similar to: debian
                    Model		: Raspberry Pi 4 Model B Rev 1.1
                    Docker          : false
                    Virtualization  : none
                    Kernel          : armv7l
                    Userland        : 32 bit
                     16:20:36 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                                   Local time: Wed 2025-04-30 16:20:36 CEST
                               Universal time: Wed 2025-04-30 14:20:36 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal: 	tty
                    *** MEMORY ***
                    Mem:            4.0G        1.7G        1.5G        1.1M        1.0G        2.3G
                    Swap:           209M          0B        209M
                    Total:          4.2G        1.7G        1.7G
                             3837 M total memory
                             1647 M used memory
                              449 M active memory
                             1820 M inactive memory
                             1397 M free memory
                              295 M buffer memory
                              662 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    top - 16:20:37 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
                    Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 22.2 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3837.7 total,   1396.7 free,   1648.8 used,    957.9 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2189.0 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    No critical errors detected
                    *** FILESYSTEM ***
                    /dev/root                     ext4      917G   16G  865G   2% /
                    devtmpfs                      devtmpfs  1.8G     0  1.8G   0% /dev
                    tmpfs                         tmpfs     1.9G     0  1.9G   0% /dev/shm
                    tmpfs                         tmpfs     768M  928K  767M   1% /run
                    tmpfs                         tmpfs     5.0M   16K  5.0M   1% /run/lock
                    /dev/sda1                     vfat      253M   49M  204M  20% /boot
                    //192.168.178.5/Data/ioBroker cifs      3.6T  3.1T  567G  85% /opt/iobroker/backups
                    tmpfs                         tmpfs     384M     0  384M   0% /run/user/1000
                    /                       /dev/sda2                     ext4   rw,noatime
                    |-/boot                 /dev/sda1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                    `-/opt/iobroker/backups //192.168.178.5/Data/ioBroker cifs   rw,relatime,vers=3.0,cache=strict,username=marc,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.5,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                    /var:
                    3.8G	/var/
                    2.4G	/var/log/journal/416a7ba8464c4fd4b4fcb0daf197cbfb
                    2.4G	/var/log
                    665M	/var/lib
                    Archived and active journals take up 2.3G in the file system.
                    285M	/opt/iobroker/backups/
                    20K	/opt/iobroker/backups/cert
                    0	/opt/iobroker/backups/redistmp
                    1.4G	/opt/iobroker/iobroker-data/
                    831M	/opt/iobroker/iobroker-data/files
                    617M	/opt/iobroker/iobroker-data/files/javascript.admin
                    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                    17M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.e96554dd.chunk.js.map
                    8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                    8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                    *** ZigBee Settings ***
                    HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                    /dev/ttyACM0
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm 		10.8.2
                    /usr/bin/npx 		10.8.2
                    nodejs:
                      Installed: 20.19.1-1nodesource1
                      Candidate: 20.19.1-1nodesource1
                      Version table:
                     *** 20.19.1-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                         20.19.0-1nodesource1 1001
                         20.18.3-1nodesource1 1001
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2+rpi1 500
                            500 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm/main armhf Packages
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 3045397)
                    admin: 		7.6.3
                    javascript: 	8.8.3
                    Adapter State
                    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                      system.adapter.bluelink.0               : bluelink              : raspberrypi4                             -  enabled
                      system.adapter.chromecast.0             : chromecast            : raspberrypi4                             - disabled
                      system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
                      system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                    + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12001
                    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
                      system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4                             - disabled
                    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4                             -  enabled
                    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                    + system.adapter.node-red.0               : node-red              : raspberrypi4                             -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                    + system.adapter.radar2.0                 : radar2                : raspberrypi4                             -  enabled
                    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
                      system.adapter.sayit.0                  : sayit                 : raspberrypi4                             - disabled
                      system.adapter.sayit.1                  : sayit                 : raspberrypi4                             - disabled
                    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4                             - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
                      system.adapter.vis-map.0                : vis-map               : raspberrypi4                             -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4                             - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
                      system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4                             -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/ttyACM0
                    + instance is alive
                    Active repo(s): stable
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.6.3    , installed 7.6.3
                    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                    Adapter    "bluelink"     : 2.3.6    , installed 3.1.2
                    Adapter    "ical"         : 1.16.1   , installed 1.16.1
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                    Controller "js-controller": 7.0.6    , installed 7.0.6
                    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                    Adapter    "synochat"     : 1.3.3    , installed 1.3.3
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                    Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
                    Objects and States
                    Objects: 	4326
                    States: 	3542
                    Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                    Hit:3 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                    Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Pending Updates: 0
                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15423      931/dnsmasq
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13750      924/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       23465327   7089/node-red
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19535      2327/io.sonoff.0
                    tcp        0      0 192.168.178.6:12001     0.0.0.0:*               LISTEN      1001       19761      2406/io.hm-rpc.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15040      856/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15035      856/iobroker.js-con
                    tcp        0      0 192.168.178.6:12010     0.0.0.0:*               LISTEN      1001       18305      2537/io.hm-rpc.1
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10403573   13791/io.admin.0
                    tcp6       0      0 :::11443                :::*                    LISTEN      1001       23463646   6962/io.admin.1
                    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10394353   12831/io.web.1
                    tcp6       0      0 :::11444                :::*                    LISTEN      1001       23463849   7041/io.web.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15404      924/sshd: /usr/sbin
                    udp        0      0 0.0.0.0:47941           0.0.0.0:*                           108        13544      477/avahi-daemon: r
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18362      2657/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18363      2657/io.tuya.0
                    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15422      931/dnsmasq
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       16377      2315/io.radar2.0
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15419      931/dnsmasq
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13542      477/avahi-daemon: r
                    udp6       0      0 :::51335                :::*                                108        13545      477/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                108        13543      477/avahi-daemon: r
                    2025-04-30 16:17:36.147  - error: bluelink.0 (26380) Error: The state contains the forbidden properties day, time!
                    2025-04-30 16:17:36.148  - error: bluelink.0 (26380) The state contains the forbidden properties day, time!
                    2025-04-30 16:17:36.640  - info: bluelink.0 (26380) terminating
                    2025-04-30 16:17:36.650  - warn: bluelink.0 (26380) get state error: Connection is closed.
                    2025-04-30 16:17:36.656  - warn: bluelink.0 (26380) get state error: Connection is closed.
                    2025-04-30 16:17:36.664  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
                    2025-04-30 16:17:36.666  - warn: bluelink.0 (26380) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.breakOilStatus: DB closed
                    2025-04-30 16:17:36.667  - warn: bluelink.0 (26380) get state error: Connection is closed.
                    2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
                    2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
                    2025-04-30 16:17:36.672  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.remoteWaitingTimeAlert": Connection is closed.
                    2025-04-30 16:17:36.848  - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                    2025-04-30 16:17:36.848  - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                    2025-04-30 16:17:36.849  - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                    2025-04-30 16:20:00.015  - info: javascript.0 (2234) script.js.common.Kia.Update_from_Server: Refresh vehicle status from Server.
                    iob diag has finished.
                    • M marchusar
                      ```bash
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                      Docker          : false
                      Kernel          : armv7l
                      Userland        : 32 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Swap:           209M          0B        209M
                               3837 M total memory
                               1647 M used memory
                                449 M active memory
                               1397 M free memory
                                295 M buffer memory
                                662 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.8G	/var/
                      2.4G	/var/log
                      665M	/var/lib
                      USB-Devices by-id:
                      HINT:
                      /dev/ttyACM0
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin: 		7.6.3
                      javascript: 	8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects: 	4326
                      States: 	3542
                      Pending Updates: 0
                      #1923
                      @marchusar probier dann mal die Stable 2.3.6, bzw 2.3.7 die sind mit dem alten Infotainment gut gelaufen.
                      Darauf achten, dass die Daten vom Server geholt werden, sonst zieht's dir die 12V leer...
                        marchusar
                        #1924
                        @neuschwansteini Die 3.1.0 läuft bei mir einwandfrei. Nur die 3.1.1 und 3.1.2 laufen nicht. Und ich hatte mich auf die Streckendaten gefreut, die nun wieder drin sein sollen
                        • M marchusar
                          #1925
                          @marchusar
                          achsooooooooooooooooooooo...
                          na, das ist noch im Dev... das kann dauern.. kommt drauf an, wie @arteck Zeit und Lust hat..
                            @marchusar
                            marchusar
                            #1926
                            @neuschwansteini Wäre schön ... es schreiben halt ein paar, dass es bei denen läuft nachdem sie PIN und Passwort neu gesetzt haben - das habe ich schon versucht... dann bleibe ich bei 3.1.0 bis ich was anderes lese ...
                            • M marchusar
                              ```bash
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm
                              Docker          : false
                              Kernel          : armv7l
                              Userland        : 32 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              pi
                              HOME=/home/pi
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal: 	tty
                              *** MEMORY ***
                              Swap:           209M          0B        209M
                                       3837 M total memory
                                       1647 M used memory
                                        449 M active memory
                                       1397 M free memory
                                        295 M buffer memory
                                        662 M swap cache
                                        199 M total swap
                                          0 M used swap
                                        199 M free swap
                              *** FILESYSTEM ***
                              /var:
                              3.8G	/var/
                              2.4G	/var/log
                              665M	/var/lib
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyACM0
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin: 		7.6.3
                              javascript: 	8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects: 	4326
                              States: 	3542
                              Pending Updates: 0
                              Meister Mopper
                              #1927
                              @marchusar
                              Ich habe einen Niro EV '22 und bleibe auch erstmal bei der v3.1.0 im stable, weil die nachfolgenden Versionen noch nicht verlässlich funktionieren.
                              Mit der v3.1.0 bekomme ich zumindest von den Kia-Servern mehr oder weniger regelmäßig Daten (Kia ist offenbar ständig am basteln). Das Fzg steuern kann ich jedoch mit der v3.1.0 zuverlässig.
                              Hat zwar vermutlich nichts mit deinem Problem zu tun, aber:
                              Warum fährst du auf dem RPI4 ein 32-Bit System?
                              Warum sind zwei Admin installiert?
                              Wozu verwendest du den web.1?
                              Das solltest du anpassen:
                              HINT:
                              /dev/ttyACM0
                              Proxmox und HA ...
                              • M marchusar
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #1928
                                @marchusar sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                installier mal die GIT
                                https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck
                                im LOG wird jetzt ein error mit dem anfange PARSECHECK stehen..
                                poste mal die Zeilen vor dem abbruch.. vielleicht kann ich da schon was sehen
                                sonst
                                brauch ich deine Login Daten . das Problem ist mir bekannt aber ich kann es nicht nachstellen da mein PHEV in diesen Teil des sources nicht reinläuft..
                                die und pin nicht vergessen
                                @Neuschwansteini FL = FaceLift
                                MaBu59M M 3 Antworten Letzte Antwort
                                • arteckA arteck
                                  sonst
                                  MaBu59M Offline
                                  MaBu59M Offline
                                  MaBu59
                                  schrieb am zuletzt editiert von MaBu59
                                  #1929
                                  @arteck
                                  Ich verfolge schon länger die Posts hier. Bei mir läuft auch nur die Version 3.1.0, Ich habe den Adapter kompett gelöscht und mit deiner URL frisch installiert.
                                  Das sind die Zeilen aus dem Log.
                                  Ich hoffe, sie helfen dir weiter.
                                  Den Adapter finde ich richtig toll. Danke für deinen unermüdlichen Einsatz SUPER!!
                                  Manfred
                                  2025-05-02 18:57:13.468 - info: host.iobroker-pi iobroker url https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck --host iobroker-pi --debug
                                  2025-05-02 18:57:15.779 - info: host.iobroker-pi iobroker install Newan/ioBroker.bluelink#parsecheck
                                  2025-05-02 18:57:16.119 - info: host.iobroker-pi iobroker NPM version: 10.8.2
                                  2025-05-02 18:57:16.121 - info: host.iobroker-pi iobroker Installing Newan/ioBroker.bluelink#parsecheck... (System call)
                                  2025-05-02 18:57:27.369 - info: host.iobroker-pi iobroker
                                  2025-05-02 18:57:27.370 - info: host.iobroker-pi iobroker removed 120 packages, and changed 1 package in 11s
                                  2025-05-02 18:57:27.372 - info: host.iobroker-pi iobroker 280 packages are looking for funding run `npm fund` for details
                                  2025-05-02 18:57:27.464 - info: host.iobroker-pi iobroker upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
                                  2025-05-02 18:57:27.479 - info: host.iobroker-pi iobroker upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
                                  2025-05-02 18:57:27.492 - info: host.iobroker-pi iobroker Updating objects from io-package.json for adapter "bluelink" with version "3.1.2"
                                  2025-05-02 18:57:28.547 - info: host.iobroker-pi iobroker exit 0
                                  2025-05-02 18:58:01.723 - info: host.iobroker-pi iobroker add bluelink auto --host iobroker-pi --debug
                                  2025-05-02 18:58:04.052 - info: host.iobroker-pi iobroker host.iobroker-pi create instance bluelink
                                  2025-05-02 18:58:04.066 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.alive created
                                  2025-05-02 18:58:04.074 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.connected created
                                  2025-05-02 18:58:04.082 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.compactMode created
                                  2025-05-02 18:58:04.089 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cpu created
                                  2025-05-02 18:58:04.097 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cputime created
                                  2025-05-02 18:58:04.104 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapUsed created
                                  2025-05-02 18:58:04.114 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapTotal created
                                  2025-05-02 18:58:04.124 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memRss created
                                  2025-05-02 18:58:04.132 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.uptime created
                                  2025-05-02 18:58:04.141 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.inputCount created
                                  2025-05-02 18:58:04.147 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.outputCount created
                                  2025-05-02 18:58:04.155 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.eventLoopLag created
                                  2025-05-02 18:58:04.162 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.sigKill created
                                  2025-05-02 18:58:04.172 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.logLevel created
                                  2025-05-02 18:58:04.178 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info created
                                  2025-05-02 18:58:04.184 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info.connection created
                                  2025-05-02 18:58:04.190 - info: host.iobroker-pi iobroker host.iobroker-pi Set default value of bluelink.0.info.connection: false
                                  2025-05-02 18:58:04.206 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0 created
                                  2025-05-02 18:58:05.250 - info: host.iobroker-pi iobroker exit 0
                                  2025-05-02 18:58:08.043 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3381411
                                  2025-05-02 18:58:10.920 - info: bluelink.0 (3381411) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                  2025-05-02 18:58:10.947 - error: bluelink.0 (3381411) Check Settings. No Username set
                                  2025-05-02 19:01:47.770 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 (force=false, process=true)
                                  2025-05-02 19:01:47.780 - info: bluelink.0 (3381411) Got terminate signal TERMINATE_YOURSELF
                                  2025-05-02 19:01:47.782 - info: bluelink.0 (3381411) Adapter bluelink cleaned up everything...
                                  2025-05-02 19:01:47.783 - info: bluelink.0 (3381411) terminating
                                  2025-05-02 19:01:47.784 - info: bluelink.0 (3381411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2025-05-02 19:01:47.819 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 send kill signal
                                  2025-05-02 19:01:48.286 - info: bluelink.0 (3381411) terminating
                                  2025-05-02 19:01:48.345 - info: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2025-05-02 19:01:52.136 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3386355
                                  2025-05-02 19:01:54.595 - info: bluelink.0 (3386355) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                  2025-05-02 19:01:54.625 - info: bluelink.0 (3386355) Login to api
                                  2025-05-02 19:01:57.529 - info: bluelink.0 (3386355) 1 Vehicles found
                                  2025-05-02 19:01:58.384 - info: bluelink.0 (3386355) Read new update for KNACT811XXXXXXXXX from the server
                                  2025-05-02 19:01:58.783 - error: bluelink.0 (3386355) PARSECHECK [object Object] coord [object Object]
                                  2025-05-02 19:01:58.934 - error: bluelink.0 (3386355) PARSECHECK [object Object] speed [object Object]
                                  2025-05-02 19:01:59.034 - error: bluelink.0 (3386355) PARSECHECK [object Object] accuracy [object Object]
                                  2025-05-02 19:01:59.082 - error: bluelink.0 (3386355) PARSECHECK [object Object] vehicleLocation [object Object]
                                  2025-05-02 19:01:59.430 - error: bluelink.0 (3386355) PARSECHECK [object Object] doorOpen [object Object]
                                  2025-05-02 19:01:59.638 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:01:59.990 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc1 [object Object]
                                  2025-05-02 19:02:00.111 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc2 [object Object]
                                  2025-05-02 19:02:00.215 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc3 [object Object]
                                  2025-05-02 19:02:00.278 - error: bluelink.0 (3386355) PARSECHECK [object Object] atc [object Object]
                                  2025-05-02 19:02:00.279 - error: bluelink.0 (3386355) PARSECHECK [object Object] remainTime2 [object Object]
                                  2025-05-02 19:02:00.394 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:00.498 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:02:00.499 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:02:00.726 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:02:00.727 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:02:00.977 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:02:01.075 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfo [object Object]
                                  2025-05-02 19:02:01.190 - error: bluelink.0 (3386355) PARSECHECK [object Object] starttime [object Object]
                                  2025-05-02 19:02:01.290 - error: bluelink.0 (3386355) PARSECHECK [object Object] endtime [object Object]
                                  2025-05-02 19:02:01.291 - error: bluelink.0 (3386355) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                  2025-05-02 19:02:01.342 - error: bluelink.0 (3386355) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                  2025-05-02 19:02:01.513 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:02:01.514 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:02:01.779 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:02:01.886 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:02:01.887 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:02:01.888 - error: bluelink.0 (3386355) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                  2025-05-02 19:02:02.023 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:02:02.025 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                                  at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:140:34)
                                  at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:25)
                                  2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:02.046 - info: bluelink.0 (3386355) Adapter bluelink cleaned up everything...
                                  2025-05-02 19:02:02.047 - info: bluelink.0 (3386355) terminating
                                  2025-05-02 19:02:02.051 - warn: bluelink.0 (3386355) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2025-05-02 19:02:02.063 - error: bluelink.0 (3386355) PARSECHECK [object Object] ect [object Object]
                                  2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:02.065 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:02.066 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:02.202 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:02.301 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:02:02.302 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:02:02.350 - error: bluelink.0 (3386355) PARSECHECK [object Object] dte [object Object]
                                  2025-05-02 19:02:02.553 - info: bluelink.0 (3386355) terminating
                                  2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.evModeRange.[object Object]
                                  2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error: Connection is closed.
                                  2025-05-02 19:02:02.566 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:02.568 - error: bluelink.0 (3386355) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                                  2025-05-02 19:02:02.570 - error: bluelink.0 (3386355) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                                  2025-05-02 19:02:02.619 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  2025-05-02 19:02:02.620 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                  2025-05-02 19:02:33.340 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3387262
                                  2025-05-02 19:02:35.793 - info: bluelink.0 (3387262) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                  2025-05-02 19:02:35.822 - info: bluelink.0 (3387262) Login to api
                                  2025-05-02 19:02:37.874 - info: bluelink.0 (3387262) 1 Vehicles found
                                  2025-05-02 19:02:38.224 - info: bluelink.0 (3387262) Read new update for KNACT811XXXXXXXXX from the server
                                  2025-05-02 19:02:38.516 - error: bluelink.0 (3387262) PARSECHECK [object Object] coord [object Object]
                                  2025-05-02 19:02:38.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] speed [object Object]
                                  2025-05-02 19:02:38.621 - error: bluelink.0 (3387262) PARSECHECK [object Object] accuracy [object Object]
                                  2025-05-02 19:02:38.624 - error: bluelink.0 (3387262) PARSECHECK [object Object] vehicleLocation [object Object]
                                  2025-05-02 19:02:38.775 - error: bluelink.0 (3387262) PARSECHECK [object Object] doorOpen [object Object]
                                  2025-05-02 19:02:38.837 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:02:39.033 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc1 [object Object]
                                  2025-05-02 19:02:39.081 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc2 [object Object]
                                  2025-05-02 19:02:39.129 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc3 [object Object]
                                  2025-05-02 19:02:39.177 - error: bluelink.0 (3387262) PARSECHECK [object Object] atc [object Object]
                                  2025-05-02 19:02:39.178 - error: bluelink.0 (3387262) PARSECHECK [object Object] remainTime2 [object Object]
                                  2025-05-02 19:02:39.230 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:02:39.511 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:02:39.520 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfo [object Object]
                                  2025-05-02 19:02:39.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] starttime [object Object]
                                  2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] endtime [object Object]
                                  2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                  2025-05-02 19:02:39.629 - error: bluelink.0 (3387262) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                  2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:02:39.828 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:02:39.834 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:02:39.835 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:02:39.836 - error: bluelink.0 (3387262) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                  2025-05-02 19:02:39.889 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:02:39.891 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:39.893 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:39.894 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:39.898 - info: bluelink.0 (3387262) Adapter bluelink cleaned up everything...
                                  2025-05-02 19:02:39.900 - info: bluelink.0 (3387262) terminating
                                  2025-05-02 19:02:39.901 - warn: bluelink.0 (3387262) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2025-05-02 19:02:39.911 - error: bluelink.0 (3387262) PARSECHECK [object Object] ect [object Object]
                                  2025-05-02 19:02:39.913 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:02:39.914 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:39.918 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                                  at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
                                  at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
                                  2025-05-02 19:02:39.919 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                                  2025-05-02 19:02:39.993 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:02:40.045 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                                  2025-05-02 19:02:40.164 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:02:40.327 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                                  2025-05-02 19:02:40.374 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfos [object Object]
                                  2025-05-02 19:02:40.403 - info: bluelink.0 (3387262) terminating
                                  2025-05-02 19:02:40.415 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                                  2025-05-02 19:02:40.416 - error: bluelink.0 (3387262) Error: Connection is closed.
                                  2025-05-02 19:02:40.418 - error: bluelink.0 (3387262) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                                  2025-05-02 19:02:40.421 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                                  2025-05-02 19:02:40.422 - error: bluelink.0 (3387262) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                                  2025-05-02 19:02:40.472 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  2025-05-02 19:02:40.472 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                  2025-05-02 19:03:11.070 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3388073
                                  2025-05-02 19:03:13.585 - info: bluelink.0 (3388073) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                  2025-05-02 19:03:13.614 - info: bluelink.0 (3388073) Login to api
                                  2025-05-02 19:03:15.038 - info: bluelink.0 (3388073) 1 Vehicles found
                                  2025-05-02 19:03:15.320 - info: bluelink.0 (3388073) Read new update for KNACT811XXXXXXXXX from the server
                                  2025-05-02 19:03:15.617 - error: bluelink.0 (3388073) PARSECHECK [object Object] coord [object Object]
                                  2025-05-02 19:03:15.673 - error: bluelink.0 (3388073) PARSECHECK [object Object] speed [object Object]
                                  2025-05-02 19:03:15.722 - error: bluelink.0 (3388073) PARSECHECK [object Object] accuracy [object Object]
                                  2025-05-02 19:03:15.726 - error: bluelink.0 (3388073) PARSECHECK [object Object] vehicleLocation [object Object]
                                  2025-05-02 19:03:15.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] doorOpen [object Object]
                                  2025-05-02 19:03:15.942 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:03:16.094 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc1 [object Object]
                                  2025-05-02 19:03:16.141 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc2 [object Object]
                                  2025-05-02 19:03:16.188 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc3 [object Object]
                                  2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] atc [object Object]
                                  2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] remainTime2 [object Object]
                                  2025-05-02 19:03:16.290 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:03:16.442 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:03:16.443 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:03:16.551 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:03:16.559 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfo [object Object]
                                  2025-05-02 19:03:16.614 - error: bluelink.0 (3388073) PARSECHECK [object Object] starttime [object Object]
                                  2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] endtime [object Object]
                                  2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                  2025-05-02 19:03:16.665 - error: bluelink.0 (3388073) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                  2025-05-02 19:03:16.765 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                                  2025-05-02 19:03:16.766 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                                  2025-05-02 19:03:16.872 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                  2025-05-02 19:03:16.880 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                                  2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                  2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                  2025-05-02 19:03:16.933 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:03:16.934 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:16.936 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:16.937 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:16.941 - info: bluelink.0 (3388073) Adapter bluelink cleaned up everything...
                                  2025-05-02 19:03:16.942 - info: bluelink.0 (3388073) terminating
                                  2025-05-02 19:03:16.943 - warn: bluelink.0 (3388073) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  2025-05-02 19:03:16.946 - error: bluelink.0 (3388073) PARSECHECK [object Object] ect [object Object]
                                  2025-05-02 19:03:16.947 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  2025-05-02 19:03:16.948 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:16.949 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:16.950 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                                  2025-05-02 19:03:17.008 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:03:17.061 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                                  2025-05-02 19:03:17.162 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                  2025-05-02 19:03:17.213 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                  2025-05-02 19:03:17.214 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                  2025-05-02 19:03:17.217 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                                  2025-05-02 19:03:17.221 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfos [object Object]
                                  2025-05-02 19:03:17.445 - info: bluelink.0 (3388073) terminating
                                  2025-05-02 19:03:17.462 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batteryPower.[object Object]
                                  2025-05-02 19:03:17.463 - error: bluelink.0 (3388073) Error: Connection is closed.
                                  2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] batteryPower [object Object]
                                  2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] evStatus [object Object]
                                  2025-05-02 19:03:17.468 - error: bluelink.0 (3388073) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                                  2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.[object Object]
                                  2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                                  2025-05-02 19:03:17.524 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  2025-05-02 19:03:17.524 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                  2025-05-02 19:03:17.524 - warn: host.iobroker-pi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                                  • arteckA arteck
                                    sonst
                                    MaBu59M Offline
                                    MaBu59M Offline
                                    MaBu59
                                    #1930
                                    @arteck
                                    Ich glaube, ich habe dir zu viele Zeilen gesendet. War mein erster Versuch. Sorry!!
                                    • MaBu59M MaBu59
                                      @arteck
                                      arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #1931
                                      @mabu59 der knallt bei
                                      reserveChargeInfo2
                                      was immer da auch drin steht .. ich brauch die Login Daten..sonst wird das nix
                                      • arteckA arteck
                                        sonst
                                        marchusar
                                        #1932
                                        @arteck
                                        Sorry, war nicht am PC - hier jetzt die Log:
                                        2025-05-04 15:53:55.158 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23102
                                        2025-05-04 15:53:59.236 - info: bluelink.0 (23102) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                        2025-05-04 15:53:59.266 - info: bluelink.0 (23102) Login to api
                                        2025-05-04 15:54:01.542 - info: bluelink.0 (23102) 1 Vehicles found
                                        2025-05-04 15:54:01.674 - info: bluelink.0 (23102) Read new update for KNAC381xxx from the server
                                        2025-05-04 15:54:01.984 - error: bluelink.0 (23102) PARSECHECK [object Object] coord [object Object]
                                        2025-05-04 15:54:02.008 - error: bluelink.0 (23102) PARSECHECK [object Object] speed [object Object]
                                        2025-05-04 15:54:02.021 - error: bluelink.0 (23102) PARSECHECK [object Object] accuracy [object Object]
                                        2025-05-04 15:54:02.027 - error: bluelink.0 (23102) PARSECHECK [object Object] vehicleLocation [object Object]
                                        2025-05-04 15:54:02.111 - error: bluelink.0 (23102) PARSECHECK [object Object] doorOpen [object Object]
                                        2025-05-04 15:54:02.134 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:02.220 - error: bluelink.0 (23102) PARSECHECK [object Object] etc1 [object Object]
                                        2025-05-04 15:54:02.232 - error: bluelink.0 (23102) PARSECHECK [object Object] etc2 [object Object]
                                        2025-05-04 15:54:02.285 - error: bluelink.0 (23102) PARSECHECK [object Object] etc3 [object Object]
                                        2025-05-04 15:54:02.298 - error: bluelink.0 (23102) PARSECHECK [object Object] atc [object Object]
                                        2025-05-04 15:54:02.299 - error: bluelink.0 (23102) PARSECHECK [object Object] remainTime2 [object Object]
                                        2025-05-04 15:54:02.318 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:02.375 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:02.376 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:02.407 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                                        2025-05-04 15:54:02.408 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                                        2025-05-04 15:54:02.478 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:02.490 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                                        2025-05-04 15:54:02.491 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                        2025-05-04 15:54:02.492 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfo [object Object]
                                        2025-05-04 15:54:02.517 - error: bluelink.0 (23102) PARSECHECK [object Object] starttime [object Object]
                                        2025-05-04 15:54:02.575 - error: bluelink.0 (23102) PARSECHECK [object Object] endtime [object Object]
                                        2025-05-04 15:54:02.576 - error: bluelink.0 (23102) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                        2025-05-04 15:54:02.585 - error: bluelink.0 (23102) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                        2025-05-04 15:54:02.655 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                                        2025-05-04 15:54:02.656 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                                        2025-05-04 15:54:02.727 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:02.737 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                                        2025-05-04 15:54:02.738 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                        2025-05-04 15:54:02.739 - error: bluelink.0 (23102) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                        2025-05-04 15:54:02.806 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-05-04 15:54:02.807 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.810 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.810 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.821 - info: bluelink.0 (23102) Adapter bluelink cleaned up everything...
                                        2025-05-04 15:54:02.824 - info: bluelink.0 (23102) terminating
                                        2025-05-04 15:54:02.825 - warn: bluelink.0 (23102) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2025-05-04 15:54:02.830 - error: bluelink.0 (23102) PARSECHECK [object Object] ect [object Object]
                                        2025-05-04 15:54:02.831 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-05-04 15:54:02.832 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.833 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.834 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:02.927 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:02.939 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:02.940 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:02.947 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                                        2025-05-04 15:54:02.976 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:02.991 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:02.992 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:02.998 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                                        2025-05-04 15:54:03.004 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfos [object Object]
                                        2025-05-04 15:54:03.035 - error: bluelink.0 (23102) PARSECHECK [object Object] batteryPower [object Object]
                                        2025-05-04 15:54:03.036 - error: bluelink.0 (23102) PARSECHECK [object Object] evStatus [object Object]
                                        2025-05-04 15:54:03.173 - error: bluelink.0 (23102) PARSECHECK [object Object] tirePressureLamp [object Object]
                                        2025-05-04 15:54:03.194 - error: bluelink.0 (23102) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                                        2025-05-04 15:54:03.201 - error: bluelink.0 (23102) PARSECHECK [object Object] battery [object Object]
                                        2025-05-04 15:54:03.217 - error: bluelink.0 (23102) PARSECHECK [object Object] stopLamp [object Object]
                                        2025-05-04 15:54:03.247 - error: bluelink.0 (23102) PARSECHECK [object Object] headLamp [object Object]
                                        2025-05-04 15:54:03.328 - info: bluelink.0 (23102) terminating
                                        2025-05-04 15:54:03.396 - warn: bluelink.0 (23102) get state error: Connection is closed.
                                        2025-05-04 15:54:03.425 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                                        2025-05-04 15:54:03.427 - warn: bluelink.0 (23102) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightFrontLamp: DB closed
                                        2025-05-04 15:54:03.428 - warn: bluelink.0 (23102) get state error: Connection is closed.
                                        2025-05-04 15:54:03.429 - error: bluelink.0 (23102) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                        2025-05-04 15:54:03.430 - error: bluelink.0 (23102) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                                        2025-05-04 15:54:03.430 - error: bluelink.0 (23102) PARSECHECK [object Object] turnSignalLamp [object Object]
                                        2025-05-04 15:54:03.431 - error: bluelink.0 (23102) PARSECHECK [object Object] lampWireStatus [object Object]
                                        2025-05-04 15:54:03.435 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen": Connection is closed.
                                        2025-05-04 15:54:03.684 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2025-05-04 15:54:03.685 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                                        2025-05-04 15:54:34.900 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23155
                                        2025-05-04 15:54:38.281 - info: bluelink.0 (23155) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                        2025-05-04 15:54:38.315 - info: bluelink.0 (23155) Login to api
                                        2025-05-04 15:54:41.016 - info: bluelink.0 (23155) 1 Vehicles found
                                        2025-05-04 15:54:41.199 - info: bluelink.0 (23155) Read new update for KNAC381xxx from the server
                                        2025-05-04 15:54:41.518 - error: bluelink.0 (23155) PARSECHECK [object Object] coord [object Object]
                                        2025-05-04 15:54:41.538 - error: bluelink.0 (23155) PARSECHECK [object Object] speed [object Object]
                                        2025-05-04 15:54:41.595 - error: bluelink.0 (23155) PARSECHECK [object Object] accuracy [object Object]
                                        2025-05-04 15:54:41.602 - error: bluelink.0 (23155) PARSECHECK [object Object] vehicleLocation [object Object]
                                        2025-05-04 15:54:41.639 - error: bluelink.0 (23155) PARSECHECK [object Object] doorOpen [object Object]
                                        2025-05-04 15:54:41.665 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:41.747 - error: bluelink.0 (23155) PARSECHECK [object Object] etc1 [object Object]
                                        2025-05-04 15:54:41.805 - error: bluelink.0 (23155) PARSECHECK [object Object] etc2 [object Object]
                                        2025-05-04 15:54:41.818 - error: bluelink.0 (23155) PARSECHECK [object Object] etc3 [object Object]
                                        2025-05-04 15:54:41.833 - error: bluelink.0 (23155) PARSECHECK [object Object] atc [object Object]
                                        2025-05-04 15:54:41.834 - error: bluelink.0 (23155) PARSECHECK [object Object] remainTime2 [object Object]
                                        2025-05-04 15:54:41.885 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:41.935 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:41.936 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                                        2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                                        2025-05-04 15:54:42.035 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:42.046 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                                        2025-05-04 15:54:42.047 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                        2025-05-04 15:54:42.048 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfo [object Object]
                                        2025-05-04 15:54:42.069 - error: bluelink.0 (23155) PARSECHECK [object Object] starttime [object Object]
                                        2025-05-04 15:54:42.082 - error: bluelink.0 (23155) PARSECHECK [object Object] endtime [object Object]
                                        2025-05-04 15:54:42.083 - error: bluelink.0 (23155) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                        2025-05-04 15:54:42.091 - error: bluelink.0 (23155) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                        2025-05-04 15:54:42.115 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                                        2025-05-04 15:54:42.116 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                                        2025-05-04 15:54:42.186 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                        2025-05-04 15:54:42.200 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                                        2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                        2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                        2025-05-04 15:54:42.266 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-05-04 15:54:42.267 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:42.269 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                                        at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
                                        at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
                                        at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
                                        2025-05-04 15:54:42.270 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:42.275 - info: bluelink.0 (23155) Adapter bluelink cleaned up everything...
                                        2025-05-04 15:54:42.276 - info: bluelink.0 (23155) terminating
                                        2025-05-04 15:54:42.278 - warn: bluelink.0 (23155) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                        2025-05-04 15:54:42.282 - error: bluelink.0 (23155) PARSECHECK [object Object] ect [object Object]
                                        2025-05-04 15:54:42.284 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        2025-05-04 15:54:42.285 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:42.286 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:42.287 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                                        2025-05-04 15:54:42.357 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:42.380 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                                        2025-05-04 15:54:42.447 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                        2025-05-04 15:54:42.460 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                        2025-05-04 15:54:42.461 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                        2025-05-04 15:54:42.469 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                                        2025-05-04 15:54:42.475 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfos [object Object]
                                        2025-05-04 15:54:42.553 - error: bluelink.0 (23155) PARSECHECK [object Object] batteryPower [object Object]
                                        2025-05-04 15:54:42.554 - error: bluelink.0 (23155) PARSECHECK [object Object] evStatus [object Object]
                                        2025-05-04 15:54:42.656 - error: bluelink.0 (23155) PARSECHECK [object Object] tirePressureLamp [object Object]
                                        2025-05-04 15:54:42.679 - error: bluelink.0 (23155) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                                        2025-05-04 15:54:42.686 - error: bluelink.0 (23155) PARSECHECK [object Object] battery [object Object]
                                        2025-05-04 15:54:42.699 - error: bluelink.0 (23155) PARSECHECK [object Object] stopLamp [object Object]
                                        2025-05-04 15:54:42.774 - error: bluelink.0 (23155) PARSECHECK [object Object] headLamp [object Object]
                                        2025-05-04 15:54:42.780 - info: bluelink.0 (23155) terminating
                                        2025-05-04 15:54:42.791 - warn: bluelink.0 (23155) get state error: Connection is closed.
                                        2025-05-04 15:54:42.800 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                                        2025-05-04 15:54:42.803 - warn: bluelink.0 (23155) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftFrontLamp: DB closed
                                        2025-05-04 15:54:42.805 - warn: bluelink.0 (23155) get state error: Connection is closed.
                                        2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                        2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                                        2025-05-04 15:54:42.814 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                                        2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                        2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                                        2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] turnSignalLamp [object Object]
                                        2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] lampWireStatus [object Object]
                                        2025-05-04 15:54:43.003 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        2025-05-04 15:54:43.003 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because
                                          @marchusar
                                          HINT:
                                          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                          /dev/ttyACM0
                                          marchusar
                                          schrieb am zuletzt editiert von marchusar
                                          #1933
                                          @meister-mopper
                                          Bei mir läuft u.a. die Homematic nicht, wenn ich auf 64bit umstelle. Gerade nochmal versucht...
                                          Mein Zigbee läuft und bietet den Direktlink in der Config selbst so an. Auch hier hatte ich mit dem by-id Link schon mal Schwierigkeiten und seitdem ich es so nutze läuft es stabil.
                                          Die je 2 Instanzen sind für lokalen Zugriff ohne Passwort und externen Zugriff mit SSL und Passwort. Das funktioniert auch einwandfrei.
