  4. Adapter Hyundai (Bluelink) oder KIA (UVO)
    5.9k
2.5k Beiträge 161 Kommentatoren 1.2m Aufrufe 147 Beobachtet
  • M marchusar
    *** iob diag is starting up, please wait ***
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    * Some output is masked. For full results please use 'iob diag --unmask' *
    Press any key to continue
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: raspberrypi4
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 5.10.103-v7l+
        Architecture: arm
    OS is similar to: debian
    Model		: Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     16:20:36 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-04-30 16:20:36 CEST
               Universal time: Wed 2025-04-30 14:20:36 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            4.0G        1.7G        1.5G        1.1M        1.0G        2.3G
    Swap:           209M          0B        209M
    Total:          4.2G        1.7G        1.7G
    Active iob-Instances: 	19
             3837 M total memory
             1647 M used memory
              449 M active memory
             1820 M inactive memory
             1397 M free memory
              295 M buffer memory
              662 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 16:20:37 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
    Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 22.2 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3837.7 total,   1396.7 free,   1648.8 used,    957.9 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2189.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                    Type      Size  Used Avail Use% Mounted on
    /dev/root                     ext4      917G   16G  865G   2% /
    devtmpfs                      devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs                         tmpfs     1.9G     0  1.9G   0% /dev/shm
    tmpfs                         tmpfs     768M  928K  767M   1% /run
    tmpfs                         tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1                     vfat      253M   49M  204M  20% /boot
    //192.168.178.5/Data/ioBroker cifs      3.6T  3.1T  567G  85% /opt/iobroker/backups
    tmpfs                         tmpfs     384M     0  384M   0% /run/user/1000
    Show mounted filesystems:
    TARGET                  SOURCE                        FSTYPE OPTIONS
    /                       /dev/sda2                     ext4   rw,noatime
    |-/boot                 /dev/sda1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    `-/opt/iobroker/backups //192.168.178.5/Data/ioBroker cifs   rw,relatime,vers=3.0,cache=strict,username=marc,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.5,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    3.8G	/var/
    2.4G	/var/log/journal/416a7ba8464c4fd4b4fcb0daf197cbfb
    2.4G	/var/log
    665M	/var/lib
    Archived and active journals take up 2.3G in the file system.
    /opt/iobroker/backups:
    285M	/opt/iobroker/backups/
    20K	/opt/iobroker/backups/cert
    0	/opt/iobroker/backups/redistmp
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    831M	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    23M	/opt/iobroker/iobroker-data/objects.jsonl
    19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    17M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.e96554dd.chunk.js.map
    8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.1
    /usr/bin/node 		v20.19.1
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2+rpi1 500
            500 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 3045397)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.6.3
    javascript: 	8.8.3
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.admin.1                  : admin                 : raspberrypi4                             -  enabled, port: 11443, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
      system.adapter.bluelink.0               : bluelink              : raspberrypi4                             -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi4                             - disabled
      system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
    + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
      system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4                             - disabled
    + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4                             -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi4                             -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.radar2.0                 : radar2                : raspberrypi4                             -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
      system.adapter.sayit.0                  : sayit                 : raspberrypi4                             - disabled
      system.adapter.sayit.1                  : sayit                 : raspberrypi4                             - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4                             - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
      system.adapter.vis-map.0                : vis-map               : raspberrypi4                             -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4                             - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 11444, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : raspberrypi4                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4                             -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "bluelink"     : 2.3.6    , installed 3.1.2
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "synochat"     : 1.3.3    , installed 1.3.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
    Objects and States
    Objects: 	4326
    States: 	3542
    Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm InRelease
    Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15423      931/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13750      924/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       23465327   7089/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19535      2327/io.sonoff.0
    tcp        0      0 192.168.178.6:12001     0.0.0.0:*               LISTEN      1001       19761      2406/io.hm-rpc.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15040      856/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15035      856/iobroker.js-con
    tcp        0      0 192.168.178.6:12010     0.0.0.0:*               LISTEN      1001       18305      2537/io.hm-rpc.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10403573   13791/io.admin.0
    tcp6       0      0 :::11443                :::*                    LISTEN      1001       23463646   6962/io.admin.1
    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10394353   12831/io.web.1
    tcp6       0      0 :::11444                :::*                    LISTEN      1001       23463849   7041/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          15404      924/sshd: /usr/sbin
    udp        0      0 0.0.0.0:47941           0.0.0.0:*                           108        13544      477/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18362      2657/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18363      2657/io.tuya.0
    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15422      931/dnsmasq
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       16377      2315/io.radar2.0
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15419      931/dnsmasq
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13542      477/avahi-daemon: r
    udp6       0      0 :::51335                :::*                                108        13545      477/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13543      477/avahi-daemon: r
    2025-04-30 16:17:36.147  - error: bluelink.0 (26380) Error: The state contains the forbidden properties day, time!
        at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
        at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
        at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
        at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:133:30)
        at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21)
        at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
        at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
    2025-04-30 16:17:36.148  - error: bluelink.0 (26380) The state contains the forbidden properties day, time!
    2025-04-30 16:17:36.640  - info: bluelink.0 (26380) terminating
    2025-04-30 16:17:36.650  - warn: bluelink.0 (26380) get state error: Connection is closed.
    2025-04-30 16:17:36.656  - warn: bluelink.0 (26380) get state error: Connection is closed.
    2025-04-30 16:17:36.664  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
    2025-04-30 16:17:36.666  - warn: bluelink.0 (26380) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.breakOilStatus: DB closed
    2025-04-30 16:17:36.667  - warn: bluelink.0 (26380) get state error: Connection is closed.
    2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
    2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
    2025-04-30 16:17:36.672  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.remoteWaitingTimeAlert": Connection is closed.
    2025-04-30 16:17:36.848  - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-04-30 16:17:36.848  - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
    2025-04-30 16:17:36.849  - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
    2025-04-30 16:20:00.015  - info: javascript.0 (2234) script.js.common.Kia.Update_from_Server: Refresh vehicle status from Server.
    iob diag has finished.
    #1923
    @marchusar probier dann mal die Stable 2.3.6, bzw 2.3.7 die sind mit dem alten Infotainment gut gelaufen.
    Darauf achten, dass die Daten vom Server geholt werden, sonst zieht's dir die 12V leer...
      marchusar
      #1924
      @neuschwansteini Die 3.1.0 läuft bei mir einwandfrei. Nur die 3.1.1 und 3.1.2 laufen nicht. Und ich hatte mich auf die Streckendaten gefreut, die nun wieder drin sein sollen
      • M marchusar
        #1925
        @marchusar
        achsooooooooooooooooooooo...
        na, das ist noch im Dev... das kann dauern.. kommt drauf an, wie @arteck Zeit und Lust hat..
          @marchusar
          marchusar
          #1926
          @neuschwansteini Wäre schön ... es schreiben halt ein paar, dass es bei denen läuft nachdem sie PIN und Passwort neu gesetzt haben - das habe ich schon versucht... dann bleibe ich bei 3.1.0 bis ich was anderes lese ...
          • M marchusar
            ```bash
            Script v.2025-02-23
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : 32 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:           209M          0B        209M
                     3837 M total memory
                     1647 M used memory
                      449 M active memory
                     1397 M free memory
                      295 M buffer memory
                      662 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            *** FILESYSTEM ***
            /var:
            3.8G	/var/
            2.4G	/var/log
            665M	/var/lib
            USB-Devices by-id:
            HINT:
            /dev/ttyACM0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin: 		7.6.3
            javascript: 	8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	4326
            States: 	3542
            Pending Updates: 0
            Meister MopperM Online
            Meister Mopper
            #1927
            @marchusar
            Ich habe einen Niro EV '22 und bleibe auch erstmal bei der v3.1.0 im stable, weil die nachfolgenden Versionen noch nicht verlässlich funktionieren.
            Mit der v3.1.0 bekomme ich zumindest von den Kia-Servern mehr oder weniger regelmäßig Daten (Kia ist offenbar ständig am basteln). Das Fzg steuern kann ich jedoch mit der v3.1.0 zuverlässig.
            Hat zwar vermutlich nichts mit deinem Problem zu tun, aber:
            Warum fährst du auf dem RPI4 ein 32-Bit System?
            Warum sind zwei Admin installiert?
            Wozu verwendest du den web.1?
            Das solltest du anpassen:
            HINT:
            /dev/ttyACM0
            Proxmox und HA ...
            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
            • M marchusar
              arteckA Offline
              arteckA Offline
              arteck
              #1928
              @marchusar sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
              installier mal die GIT
              https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck
              im LOG wird jetzt ein error mit dem anfange PARSECHECK stehen..
              poste mal die Zeilen vor dem abbruch.. vielleicht kann ich da schon was sehen
              sonst
              brauch ich deine Login Daten . das Problem ist mir bekannt aber ich kann es nicht nachstellen da mein PHEV in diesen Teil des sources nicht reinläuft..
              die und pin nicht vergessen
              @Neuschwansteini FL = FaceLift
              MaBu59M M 3 Antworten Letzte Antwort
              • arteckA arteck
                sonst
                MaBu59M Offline
                MaBu59M Offline
                MaBu59
                schrieb am zuletzt editiert von MaBu59
                #1929
                @arteck
                Ich verfolge schon länger die Posts hier. Bei mir läuft auch nur die Version 3.1.0, Ich habe den Adapter kompett gelöscht und mit deiner URL frisch installiert.
                Das sind die Zeilen aus dem Log.
                Ich hoffe, sie helfen dir weiter.
                Den Adapter finde ich richtig toll. Danke für deinen unermüdlichen Einsatz SUPER!!
                Manfred
                2025-05-02 18:57:13.468 - info: host.iobroker-pi iobroker url https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck --host iobroker-pi --debug
                2025-05-02 18:57:15.779 - info: host.iobroker-pi iobroker install Newan/ioBroker.bluelink#parsecheck
                2025-05-02 18:57:16.119 - info: host.iobroker-pi iobroker NPM version: 10.8.2
                2025-05-02 18:57:16.121 - info: host.iobroker-pi iobroker Installing Newan/ioBroker.bluelink#parsecheck... (System call)
                2025-05-02 18:57:27.369 - info: host.iobroker-pi iobroker
                2025-05-02 18:57:27.370 - info: host.iobroker-pi iobroker removed 120 packages, and changed 1 package in 11s
                2025-05-02 18:57:27.372 - info: host.iobroker-pi iobroker 280 packages are looking for funding run `npm fund` for details
                2025-05-02 18:57:27.464 - info: host.iobroker-pi iobroker upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
                2025-05-02 18:57:27.479 - info: host.iobroker-pi iobroker upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
                2025-05-02 18:57:27.492 - info: host.iobroker-pi iobroker Updating objects from io-package.json for adapter "bluelink" with version "3.1.2"
                2025-05-02 18:57:28.547 - info: host.iobroker-pi iobroker exit 0
                2025-05-02 18:58:01.723 - info: host.iobroker-pi iobroker add bluelink auto --host iobroker-pi --debug
                2025-05-02 18:58:04.052 - info: host.iobroker-pi iobroker host.iobroker-pi create instance bluelink
                2025-05-02 18:58:04.066 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.alive created
                2025-05-02 18:58:04.074 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.connected created
                2025-05-02 18:58:04.082 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.compactMode created
                2025-05-02 18:58:04.089 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cpu created
                2025-05-02 18:58:04.097 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cputime created
                2025-05-02 18:58:04.104 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapUsed created
                2025-05-02 18:58:04.114 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapTotal created
                2025-05-02 18:58:04.124 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memRss created
                2025-05-02 18:58:04.132 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.uptime created
                2025-05-02 18:58:04.141 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.inputCount created
                2025-05-02 18:58:04.147 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.outputCount created
                2025-05-02 18:58:04.155 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.eventLoopLag created
                2025-05-02 18:58:04.162 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.sigKill created
                2025-05-02 18:58:04.172 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.logLevel created
                2025-05-02 18:58:04.178 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info created
                2025-05-02 18:58:04.184 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info.connection created
                2025-05-02 18:58:04.190 - info: host.iobroker-pi iobroker host.iobroker-pi Set default value of bluelink.0.info.connection: false
                2025-05-02 18:58:04.206 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0 created
                2025-05-02 18:58:05.250 - info: host.iobroker-pi iobroker exit 0
                2025-05-02 18:58:08.043 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3381411
                2025-05-02 18:58:10.920 - info: bluelink.0 (3381411) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                2025-05-02 18:58:10.947 - error: bluelink.0 (3381411) Check Settings. No Username set
                2025-05-02 19:01:47.770 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 (force=false, process=true)
                2025-05-02 19:01:47.780 - info: bluelink.0 (3381411) Got terminate signal TERMINATE_YOURSELF
                2025-05-02 19:01:47.782 - info: bluelink.0 (3381411) Adapter bluelink cleaned up everything...
                2025-05-02 19:01:47.783 - info: bluelink.0 (3381411) terminating
                2025-05-02 19:01:47.784 - info: bluelink.0 (3381411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-05-02 19:01:47.819 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 send kill signal
                2025-05-02 19:01:48.286 - info: bluelink.0 (3381411) terminating
                2025-05-02 19:01:48.345 - info: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-05-02 19:01:52.136 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3386355
                2025-05-02 19:01:54.595 - info: bluelink.0 (3386355) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                2025-05-02 19:01:54.625 - info: bluelink.0 (3386355) Login to api
                2025-05-02 19:01:57.529 - info: bluelink.0 (3386355) 1 Vehicles found
                2025-05-02 19:01:58.384 - info: bluelink.0 (3386355) Read new update for KNACT811XXXXXXXXX from the server
                2025-05-02 19:01:58.783 - error: bluelink.0 (3386355) PARSECHECK [object Object] coord [object Object]
                2025-05-02 19:01:58.934 - error: bluelink.0 (3386355) PARSECHECK [object Object] speed [object Object]
                2025-05-02 19:01:59.034 - error: bluelink.0 (3386355) PARSECHECK [object Object] accuracy [object Object]
                2025-05-02 19:01:59.082 - error: bluelink.0 (3386355) PARSECHECK [object Object] vehicleLocation [object Object]
                2025-05-02 19:01:59.430 - error: bluelink.0 (3386355) PARSECHECK [object Object] doorOpen [object Object]
                2025-05-02 19:01:59.638 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:01:59.990 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc1 [object Object]
                2025-05-02 19:02:00.111 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc2 [object Object]
                2025-05-02 19:02:00.215 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc3 [object Object]
                2025-05-02 19:02:00.278 - error: bluelink.0 (3386355) PARSECHECK [object Object] atc [object Object]
                2025-05-02 19:02:00.279 - error: bluelink.0 (3386355) PARSECHECK [object Object] remainTime2 [object Object]
                2025-05-02 19:02:00.394 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:00.498 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:02:00.499 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:02:00.726 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:02:00.727 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:02:00.977 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:02:01.075 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfo [object Object]
                2025-05-02 19:02:01.190 - error: bluelink.0 (3386355) PARSECHECK [object Object] starttime [object Object]
                2025-05-02 19:02:01.290 - error: bluelink.0 (3386355) PARSECHECK [object Object] endtime [object Object]
                2025-05-02 19:02:01.291 - error: bluelink.0 (3386355) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                2025-05-02 19:02:01.342 - error: bluelink.0 (3386355) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                2025-05-02 19:02:01.513 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:02:01.514 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:02:01.779 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:02:01.886 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:02:01.887 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:02:01.888 - error: bluelink.0 (3386355) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                2025-05-02 19:02:02.023 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:02:02.025 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:140:34)
                at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:25)
                2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                2025-05-02 19:02:02.046 - info: bluelink.0 (3386355) Adapter bluelink cleaned up everything...
                2025-05-02 19:02:02.047 - info: bluelink.0 (3386355) terminating
                2025-05-02 19:02:02.051 - warn: bluelink.0 (3386355) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2025-05-02 19:02:02.063 - error: bluelink.0 (3386355) PARSECHECK [object Object] ect [object Object]
                2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:02:02.065 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                2025-05-02 19:02:02.066 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                2025-05-02 19:02:02.202 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:02.301 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:02:02.302 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:02:02.350 - error: bluelink.0 (3386355) PARSECHECK [object Object] dte [object Object]
                2025-05-02 19:02:02.553 - info: bluelink.0 (3386355) terminating
                2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.evModeRange.[object Object]
                2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error: Connection is closed.
                2025-05-02 19:02:02.566 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:02.568 - error: bluelink.0 (3386355) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                2025-05-02 19:02:02.570 - error: bluelink.0 (3386355) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                2025-05-02 19:02:02.619 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2025-05-02 19:02:02.620 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                2025-05-02 19:02:33.340 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3387262
                2025-05-02 19:02:35.793 - info: bluelink.0 (3387262) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                2025-05-02 19:02:35.822 - info: bluelink.0 (3387262) Login to api
                2025-05-02 19:02:37.874 - info: bluelink.0 (3387262) 1 Vehicles found
                2025-05-02 19:02:38.224 - info: bluelink.0 (3387262) Read new update for KNACT811XXXXXXXXX from the server
                2025-05-02 19:02:38.516 - error: bluelink.0 (3387262) PARSECHECK [object Object] coord [object Object]
                2025-05-02 19:02:38.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] speed [object Object]
                2025-05-02 19:02:38.621 - error: bluelink.0 (3387262) PARSECHECK [object Object] accuracy [object Object]
                2025-05-02 19:02:38.624 - error: bluelink.0 (3387262) PARSECHECK [object Object] vehicleLocation [object Object]
                2025-05-02 19:02:38.775 - error: bluelink.0 (3387262) PARSECHECK [object Object] doorOpen [object Object]
                2025-05-02 19:02:38.837 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:02:39.033 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc1 [object Object]
                2025-05-02 19:02:39.081 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc2 [object Object]
                2025-05-02 19:02:39.129 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc3 [object Object]
                2025-05-02 19:02:39.177 - error: bluelink.0 (3387262) PARSECHECK [object Object] atc [object Object]
                2025-05-02 19:02:39.178 - error: bluelink.0 (3387262) PARSECHECK [object Object] remainTime2 [object Object]
                2025-05-02 19:02:39.230 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:02:39.511 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:02:39.520 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfo [object Object]
                2025-05-02 19:02:39.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] starttime [object Object]
                2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] endtime [object Object]
                2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                2025-05-02 19:02:39.629 - error: bluelink.0 (3387262) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:02:39.828 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:02:39.834 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:02:39.835 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:02:39.836 - error: bluelink.0 (3387262) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                2025-05-02 19:02:39.889 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:02:39.891 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.893 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.894 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.898 - info: bluelink.0 (3387262) Adapter bluelink cleaned up everything...
                2025-05-02 19:02:39.900 - info: bluelink.0 (3387262) terminating
                2025-05-02 19:02:39.901 - warn: bluelink.0 (3387262) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2025-05-02 19:02:39.911 - error: bluelink.0 (3387262) PARSECHECK [object Object] ect [object Object]
                2025-05-02 19:02:39.913 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:02:39.914 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.918 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.919 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                2025-05-02 19:02:39.993 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:02:40.045 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                2025-05-02 19:02:40.164 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:02:40.327 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                2025-05-02 19:02:40.374 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfos [object Object]
                2025-05-02 19:02:40.403 - info: bluelink.0 (3387262) terminating
                2025-05-02 19:02:40.415 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                2025-05-02 19:02:40.416 - error: bluelink.0 (3387262) Error: Connection is closed.
                2025-05-02 19:02:40.418 - error: bluelink.0 (3387262) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                2025-05-02 19:02:40.421 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                2025-05-02 19:02:40.422 - error: bluelink.0 (3387262) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                2025-05-02 19:02:40.472 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2025-05-02 19:02:40.472 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                2025-05-02 19:03:11.070 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3388073
                2025-05-02 19:03:13.585 - info: bluelink.0 (3388073) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                2025-05-02 19:03:13.614 - info: bluelink.0 (3388073) Login to api
                2025-05-02 19:03:15.038 - info: bluelink.0 (3388073) 1 Vehicles found
                2025-05-02 19:03:15.320 - info: bluelink.0 (3388073) Read new update for KNACT811XXXXXXXXX from the server
                2025-05-02 19:03:15.617 - error: bluelink.0 (3388073) PARSECHECK [object Object] coord [object Object]
                2025-05-02 19:03:15.673 - error: bluelink.0 (3388073) PARSECHECK [object Object] speed [object Object]
                2025-05-02 19:03:15.722 - error: bluelink.0 (3388073) PARSECHECK [object Object] accuracy [object Object]
                2025-05-02 19:03:15.726 - error: bluelink.0 (3388073) PARSECHECK [object Object] vehicleLocation [object Object]
                2025-05-02 19:03:15.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] doorOpen [object Object]
                2025-05-02 19:03:15.942 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:03:16.094 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc1 [object Object]
                2025-05-02 19:03:16.141 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc2 [object Object]
                2025-05-02 19:03:16.188 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc3 [object Object]
                2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] atc [object Object]
                2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] remainTime2 [object Object]
                2025-05-02 19:03:16.290 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:03:16.442 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:03:16.443 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:03:16.551 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:03:16.559 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfo [object Object]
                2025-05-02 19:03:16.614 - error: bluelink.0 (3388073) PARSECHECK [object Object] starttime [object Object]
                2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] endtime [object Object]
                2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                2025-05-02 19:03:16.665 - error: bluelink.0 (3388073) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                2025-05-02 19:03:16.765 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                2025-05-02 19:03:16.766 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                2025-05-02 19:03:16.872 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                2025-05-02 19:03:16.880 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                2025-05-02 19:03:16.933 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:03:16.934 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:03:16.936 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                2025-05-02 19:03:16.937 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                2025-05-02 19:03:16.941 - info: bluelink.0 (3388073) Adapter bluelink cleaned up everything...
                2025-05-02 19:03:16.942 - info: bluelink.0 (3388073) terminating
                2025-05-02 19:03:16.943 - warn: bluelink.0 (3388073) Terminated (UNCAUGHT_EXCEPTION): Without reason
                2025-05-02 19:03:16.946 - error: bluelink.0 (3388073) PARSECHECK [object Object] ect [object Object]
                2025-05-02 19:03:16.947 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                2025-05-02 19:03:16.948 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                2025-05-02 19:03:16.949 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                2025-05-02 19:03:16.950 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                2025-05-02 19:03:17.008 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:03:17.061 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                2025-05-02 19:03:17.162 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                2025-05-02 19:03:17.213 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                2025-05-02 19:03:17.214 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                2025-05-02 19:03:17.217 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                2025-05-02 19:03:17.221 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfos [object Object]
                2025-05-02 19:03:17.445 - info: bluelink.0 (3388073) terminating
                2025-05-02 19:03:17.462 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batteryPower.[object Object]
                2025-05-02 19:03:17.463 - error: bluelink.0 (3388073) Error: Connection is closed.
                2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] batteryPower [object Object]
                2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] evStatus [object Object]
                2025-05-02 19:03:17.468 - error: bluelink.0 (3388073) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.[object Object]
                2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                2025-05-02 19:03:17.524 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                2025-05-02 19:03:17.524 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                2025-05-02 19:03:17.524 - warn: host.iobroker-pi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                • arteckA arteck
                  sonst
                  MaBu59M Offline
                  MaBu59M Offline
                  MaBu59
                  #1930
                  @arteck
                  Ich glaube, ich habe dir zu viele Zeilen gesendet. War mein erster Versuch. Sorry!!
                  • MaBu59M MaBu59
                    @arteck
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #1931
                    @mabu59 der knallt bei
                    reserveChargeInfo2
                    was immer da auch drin steht .. ich brauch die Login Daten..sonst wird das nix
                    • arteckA arteck
                      sonst
                      marchusar
                      schrieb am zuletzt editiert von marchusar
                      #1932
                      @arteck
                      Sorry, war nicht am PC - hier jetzt die Log:
                      2025-05-04 15:53:55.158 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23102
                      2025-05-04 15:53:59.236 - info: bluelink.0 (23102) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                      2025-05-04 15:53:59.266 - info: bluelink.0 (23102) Login to api
                      2025-05-04 15:54:01.542 - info: bluelink.0 (23102) 1 Vehicles found
                      2025-05-04 15:54:01.674 - info: bluelink.0 (23102) Read new update for KNAC381xxx from the server
                      2025-05-04 15:54:01.984 - error: bluelink.0 (23102) PARSECHECK [object Object] coord [object Object]
                      2025-05-04 15:54:02.008 - error: bluelink.0 (23102) PARSECHECK [object Object] speed [object Object]
                      2025-05-04 15:54:02.021 - error: bluelink.0 (23102) PARSECHECK [object Object] accuracy [object Object]
                      2025-05-04 15:54:02.027 - error: bluelink.0 (23102) PARSECHECK [object Object] vehicleLocation [object Object]
                      2025-05-04 15:54:02.111 - error: bluelink.0 (23102) PARSECHECK [object Object] doorOpen [object Object]
                      2025-05-04 15:54:02.134 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:02.220 - error: bluelink.0 (23102) PARSECHECK [object Object] etc1 [object Object]
                      2025-05-04 15:54:02.232 - error: bluelink.0 (23102) PARSECHECK [object Object] etc2 [object Object]
                      2025-05-04 15:54:02.285 - error: bluelink.0 (23102) PARSECHECK [object Object] etc3 [object Object]
                      2025-05-04 15:54:02.298 - error: bluelink.0 (23102) PARSECHECK [object Object] atc [object Object]
                      2025-05-04 15:54:02.299 - error: bluelink.0 (23102) PARSECHECK [object Object] remainTime2 [object Object]
                      2025-05-04 15:54:02.318 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:02.375 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:02.376 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:02.407 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                      2025-05-04 15:54:02.408 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                      2025-05-04 15:54:02.478 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:02.490 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                      2025-05-04 15:54:02.491 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                      2025-05-04 15:54:02.492 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfo [object Object]
                      2025-05-04 15:54:02.517 - error: bluelink.0 (23102) PARSECHECK [object Object] starttime [object Object]
                      2025-05-04 15:54:02.575 - error: bluelink.0 (23102) PARSECHECK [object Object] endtime [object Object]
                      2025-05-04 15:54:02.576 - error: bluelink.0 (23102) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                      2025-05-04 15:54:02.585 - error: bluelink.0 (23102) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                      2025-05-04 15:54:02.655 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                      2025-05-04 15:54:02.656 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                      2025-05-04 15:54:02.727 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:02.737 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                      2025-05-04 15:54:02.738 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                      2025-05-04 15:54:02.739 - error: bluelink.0 (23102) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                      2025-05-04 15:54:02.806 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-05-04 15:54:02.807 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.810 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.810 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.821 - info: bluelink.0 (23102) Adapter bluelink cleaned up everything...
                      2025-05-04 15:54:02.824 - info: bluelink.0 (23102) terminating
                      2025-05-04 15:54:02.825 - warn: bluelink.0 (23102) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-05-04 15:54:02.830 - error: bluelink.0 (23102) PARSECHECK [object Object] ect [object Object]
                      2025-05-04 15:54:02.831 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-05-04 15:54:02.832 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.833 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.834 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                      2025-05-04 15:54:02.927 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:02.939 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:02.940 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:02.947 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                      2025-05-04 15:54:02.976 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:02.991 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:02.992 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:02.998 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                      2025-05-04 15:54:03.004 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfos [object Object]
                      2025-05-04 15:54:03.035 - error: bluelink.0 (23102) PARSECHECK [object Object] batteryPower [object Object]
                      2025-05-04 15:54:03.036 - error: bluelink.0 (23102) PARSECHECK [object Object] evStatus [object Object]
                      2025-05-04 15:54:03.173 - error: bluelink.0 (23102) PARSECHECK [object Object] tirePressureLamp [object Object]
                      2025-05-04 15:54:03.194 - error: bluelink.0 (23102) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                      2025-05-04 15:54:03.201 - error: bluelink.0 (23102) PARSECHECK [object Object] battery [object Object]
                      2025-05-04 15:54:03.217 - error: bluelink.0 (23102) PARSECHECK [object Object] stopLamp [object Object]
                      2025-05-04 15:54:03.247 - error: bluelink.0 (23102) PARSECHECK [object Object] headLamp [object Object]
                      2025-05-04 15:54:03.328 - info: bluelink.0 (23102) terminating
                      2025-05-04 15:54:03.396 - warn: bluelink.0 (23102) get state error: Connection is closed.
                      2025-05-04 15:54:03.425 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                      2025-05-04 15:54:03.427 - warn: bluelink.0 (23102) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightFrontLamp: DB closed
                      2025-05-04 15:54:03.428 - warn: bluelink.0 (23102) get state error: Connection is closed.
                      2025-05-04 15:54:03.429 - error: bluelink.0 (23102) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                      2025-05-04 15:54:03.430 - error: bluelink.0 (23102) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                      2025-05-04 15:54:03.430 - error: bluelink.0 (23102) PARSECHECK [object Object] turnSignalLamp [object Object]
                      2025-05-04 15:54:03.431 - error: bluelink.0 (23102) PARSECHECK [object Object] lampWireStatus [object Object]
                      2025-05-04 15:54:03.435 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen": Connection is closed.
                      2025-05-04 15:54:03.684 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-05-04 15:54:03.685 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                      2025-05-04 15:54:34.900 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23155
                      2025-05-04 15:54:38.281 - info: bluelink.0 (23155) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                      2025-05-04 15:54:38.315 - info: bluelink.0 (23155) Login to api
                      2025-05-04 15:54:41.016 - info: bluelink.0 (23155) 1 Vehicles found
                      2025-05-04 15:54:41.199 - info: bluelink.0 (23155) Read new update for KNAC381xxx from the server
                      2025-05-04 15:54:41.518 - error: bluelink.0 (23155) PARSECHECK [object Object] coord [object Object]
                      2025-05-04 15:54:41.538 - error: bluelink.0 (23155) PARSECHECK [object Object] speed [object Object]
                      2025-05-04 15:54:41.595 - error: bluelink.0 (23155) PARSECHECK [object Object] accuracy [object Object]
                      2025-05-04 15:54:41.602 - error: bluelink.0 (23155) PARSECHECK [object Object] vehicleLocation [object Object]
                      2025-05-04 15:54:41.639 - error: bluelink.0 (23155) PARSECHECK [object Object] doorOpen [object Object]
                      2025-05-04 15:54:41.665 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:41.747 - error: bluelink.0 (23155) PARSECHECK [object Object] etc1 [object Object]
                      2025-05-04 15:54:41.805 - error: bluelink.0 (23155) PARSECHECK [object Object] etc2 [object Object]
                      2025-05-04 15:54:41.818 - error: bluelink.0 (23155) PARSECHECK [object Object] etc3 [object Object]
                      2025-05-04 15:54:41.833 - error: bluelink.0 (23155) PARSECHECK [object Object] atc [object Object]
                      2025-05-04 15:54:41.834 - error: bluelink.0 (23155) PARSECHECK [object Object] remainTime2 [object Object]
                      2025-05-04 15:54:41.885 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:41.935 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:41.936 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                      2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                      2025-05-04 15:54:42.035 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:42.046 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                      2025-05-04 15:54:42.047 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                      2025-05-04 15:54:42.048 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfo [object Object]
                      2025-05-04 15:54:42.069 - error: bluelink.0 (23155) PARSECHECK [object Object] starttime [object Object]
                      2025-05-04 15:54:42.082 - error: bluelink.0 (23155) PARSECHECK [object Object] endtime [object Object]
                      2025-05-04 15:54:42.083 - error: bluelink.0 (23155) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                      2025-05-04 15:54:42.091 - error: bluelink.0 (23155) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                      2025-05-04 15:54:42.115 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                      2025-05-04 15:54:42.116 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                      2025-05-04 15:54:42.186 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                      2025-05-04 15:54:42.200 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                      2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                      2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                      2025-05-04 15:54:42.266 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-05-04 15:54:42.267 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.269 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.270 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.275 - info: bluelink.0 (23155) Adapter bluelink cleaned up everything...
                      2025-05-04 15:54:42.276 - info: bluelink.0 (23155) terminating
                      2025-05-04 15:54:42.278 - warn: bluelink.0 (23155) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2025-05-04 15:54:42.282 - error: bluelink.0 (23155) PARSECHECK [object Object] ect [object Object]
                      2025-05-04 15:54:42.284 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2025-05-04 15:54:42.285 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.286 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.287 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                      2025-05-04 15:54:42.357 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:42.380 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                      2025-05-04 15:54:42.447 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                      2025-05-04 15:54:42.460 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                      2025-05-04 15:54:42.461 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                      2025-05-04 15:54:42.469 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                      2025-05-04 15:54:42.475 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfos [object Object]
                      2025-05-04 15:54:42.553 - error: bluelink.0 (23155) PARSECHECK [object Object] batteryPower [object Object]
                      2025-05-04 15:54:42.554 - error: bluelink.0 (23155) PARSECHECK [object Object] evStatus [object Object]
                      2025-05-04 15:54:42.656 - error: bluelink.0 (23155) PARSECHECK [object Object] tirePressureLamp [object Object]
                      2025-05-04 15:54:42.679 - error: bluelink.0 (23155) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                      2025-05-04 15:54:42.686 - error: bluelink.0 (23155) PARSECHECK [object Object] battery [object Object]
                      2025-05-04 15:54:42.699 - error: bluelink.0 (23155) PARSECHECK [object Object] stopLamp [object Object]
                      2025-05-04 15:54:42.774 - error: bluelink.0 (23155) PARSECHECK [object Object] headLamp [object Object]
                      2025-05-04 15:54:42.780 - info: bluelink.0 (23155) terminating
                      2025-05-04 15:54:42.791 - warn: bluelink.0 (23155) get state error: Connection is closed.
                      2025-05-04 15:54:42.800 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                      2025-05-04 15:54:42.803 - warn: bluelink.0 (23155) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftFrontLamp: DB closed
                      2025-05-04 15:54:42.805 - warn: bluelink.0 (23155) get state error: Connection is closed.
                      2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                      2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                      2025-05-04 15:54:42.814 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                      2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                      2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                      2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] turnSignalLamp [object Object]
                      2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] lampWireStatus [object Object]
                      2025-05-04 15:54:43.003 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-05-04 15:54:43.003 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because
                        @marchusar
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyACM0
                        marchusar
                        #1933
                        @meister-mopper
                        Bei mir läuft u.a. die Homematic nicht, wenn ich auf 64bit umstelle. Gerade nochmal versucht...
                        Mein Zigbee läuft und bietet den Direktlink in der Config selbst so an. Auch hier hatte ich mit dem by-id Link schon mal Schwierigkeiten und seitdem ich es so nutze läuft es stabil.
                        Die je 2 Instanzen sind für lokalen Zugriff ohne Passwort und externen Zugriff mit SSL und Passwort. Das funktioniert auch einwandfrei.
                        • arteckA arteck
                          reserveChargeInfo2
                          marchusar
                          #1934
                          @arteck
                          meine reserveChargeInfo2 aus der 3.1.0 :
                          • arteckA Offline
                            arteckA Offline
                            arteck
                            #1935
                            neue Version 3.1.3 ist unterwegs.. habe paar Fehler behoben..
                            und ich hätte mal hier
                            https://github.com/Newan/ioBroker.bluelink/tarball/bluelinky9
                            eine Version zum Testen ür alle die das neue System im Auto haben .. wo der ccs2Status Knoten weg fallen würde und die Infos ganz normal zur Verfügung stehen würden wie früher.. unter vehicleStatus ..
                            der ccs2Status Knoten würde dann nicht mehr aktualisiert..und könnte manuell gelöscht werden...
                            Peter V.P MaBu59M ? 3 Antworten Letzte Antwort
                            • arteckA arteck
                              Peter V.P Offline
                              Peter V.P Offline
                              Peter V.
                              #1936
                              @arteck said in Adapter Hyundai (Bluelink) oder KIA (UVO):
                              Mit dieser Version sind bei mir die (seltenen) Fehlermeldungen wieder weg und Maps läuft auch wieder.
                              Kia Ceed BJ 2024
                              Top, danke
                              • arteckA arteck
                                MaBu59M Offline
                                MaBu59M Offline
                                MaBu59
                                #1937
                                @arteck
                                Diese Version erzeugt bei mir auch keine Fehlermeldungen mehr und läuft!!
                                Siehst Du eine Chance, den "ccs2Status" ans Laufen zu bringen oder ist der Aufwand zu hoch?
                                Danke für Deinen Einsatz!!
                                • MaBu59M MaBu59
                                  @arteck
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #1938
                                  @mabu59 sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  was meinst du ???
                                  MaBu59M 1 Antwort Letzte Antwort
                                  • arteckA arteck
                                    #1939
                                    @arteck sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                    gerade mal getestet, sieht genauso aus wie die normale 3.1.3 .. nur mit einem Fehler beim Starten:
                                    bluelink.0
                                    2025-05-06 08:35:42.388	error	TypeError: Cannot read properties of undefined (reading 'airCtrlOn') at Bluelink.setNewFullStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:620:46) at Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:392:28) at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13) at async Pe.<anonymous> (/opt/iobroker/node_modules/iobroker.bluelink/main.js:298:21)
                                    hatte ich vorher gemacht, ist jetzt wieder da.. ?
                                    Ist die Version auch eine 3.1.3 ?
                                    • arteckA arteck
                                      was meinst du ???
                                      MaBu59M Offline
                                      MaBu59M Offline
                                      MaBu59
                                      #1940
                                      @arteck
                                      Du hast geschrieben "wo der ccs2Status Knoten weg fallen würde".
                                      Ich verstehe das so, ohne den Knoten funktioniert der Adapter, mit dem Knoten nicht.
                                      Der Knoten müßte angepasst werden, damit der Adapter funktioniert.
                                      Ich habe vermutet, dass der Aufwand dafür sehr hoch ist.
                                      • MaBu59M MaBu59
                                        @arteck
                                        #1941
                                        @mabu59
                                        nee, frueher gabs den Ordner mit ccs2Status nicht, das sind 394 Objects weniger.. :)
                                        Funktioniert bei meinem leider nicht, oder ich was falsch gemacht.. ?
                                          bluelink.0
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #1942
                                          @neuschwansteini dann brauch ich mehr kontext...
                                          auch ein KIA ?? welches Baujahr ??
                                          gibts den DP "vehicleStatus.airCtrlOn"
