  4. Iobroker Oberfläche nicht mehr nutzbar
    6.8k
26 Beiträge 6 Kommentatoren 3.6k Aufrufe 4 Beobachtet
  • K Kellerkind-86
    sorry. hier :
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     06:43:40 up 1 day, 14:15,  0 user,  load average: 0.10, 0.18, 0.23
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    Failed to query server: Connection timed out
    Failed to parse bus message: Connection timed out
    *** Users and Groups ***
    User that called 'iob diag':
    tigger
    HOME=/home/tigger
    GROUPS=tigger users iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        185M        7.4G         81K        973M        8.4G
    Swap:           2.1G          0B        2.1G
    Total:           10G        185M        9.6G
    Active iob-Instances:   1
             8192 M total memory
              176 M used memory
              163 M active memory
              782 M inactive memory
             7086 M free memory
                0 M buffer memory
              928 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    top - 06:44:55 up 1 day, 14:16,  0 user,  load average: 0.02, 0.14, 0.21
    Tasks:  24 total,   1 running,  23 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   7085.4 free,    178.3 used,    928.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   8013.7 avail Mem
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service                   loaded failed failed ioBroker Server
    * logrotate.service                  loaded failed failed Rotate log files
    * man-db.service                     loaded failed failed Daily man-db regeneration
    * nftables.service                   loaded failed failed nftables
    * systemd-hostnamed.service          loaded failed failed Hostname Service
    * systemd-logind.service             loaded failed failed User Login Management
    * systemd-networkd.service           loaded failed failed Network Configuration
    * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
    * systemd-sysusers.service           loaded failed failed Create System Users
    * systemd-timedated.service          loaded failed failed Time & Date Service
    * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
    * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
    * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
    * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
    14 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--174--disk--0 ext4    25G  6.7G   17G  29% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G   76K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    [Wed Apr 16 09:22:31 2025] EXT4-fs (dm-1): mounted filesystem 67833da0-c8be-4097-98f5-d42afffe5926 ro with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:22:32 2025] EXT4-fs (dm-1): re-mounted 67833da0-c8be-4097-98f5-d42afffe5926 r/w. Quota mode: none.
    [Wed Apr 16 09:51:03 2025] EXT4-fs (loop0): mounted filesystem c29867de-ff93-475f-82b5-a2b4945a5cd0 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:52:06 2025] EXT4-fs (loop0): unmounting filesystem c29867de-ff93-475f-82b5-a2b4945a5cd0.
    [Wed Apr 16 09:54:46 2025] EXT4-fs (loop0): mounted filesystem d1209dba-7cdf-4b63-94e5-cff03986f8bd r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:56:00 2025] EXT4-fs (loop0): unmounting filesystem d1209dba-7cdf-4b63-94e5-cff03986f8bd.
    [Wed Apr 16 09:57:03 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 348 higher than expected, please wait.
    [Wed Apr 16 10:02:54 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 10:02:54 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 10:06:47 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 10:06:54 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 10:06:55 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 10:10:39 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 10:10:40 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 11:21:26 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 11:21:27 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:17:49 2025] EXT4-fs (loop0): mounted filesystem 45a4aef7-de9b-47a1-9e57-2e50b0691d4b r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:18:56 2025] EXT4-fs (loop0): unmounting filesystem 45a4aef7-de9b-47a1-9e57-2e50b0691d4b.
    [Wed Apr 16 17:19:42 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 130 higher than expected, please wait.
    [Wed Apr 16 17:21:56 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 17:21:56 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 17:28:35 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:28:42 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 17:28:50 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 17:29:03 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 18:59:14 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 19:00:46 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:01:16 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 19:03:23 2025] EXT4-fs (loop0): mounted filesystem efbced7f-2bad-47db-904a-b7c880dd61c2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:04:12 2025] EXT4-fs (loop0): unmounting filesystem efbced7f-2bad-47db-904a-b7c880dd61c2.
    [Wed Apr 16 19:05:14 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 270 higher than expected, please wait.
    [Wed Apr 16 19:09:47 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 19:09:47 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 19:11:54 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:12:00 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Wed Apr 16 19:12:01 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:45:50 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Wed Apr 16 19:45:51 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 22:55:01 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
    [Wed Apr 16 22:55:44 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
    [Wed Apr 16 22:55:44 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 05:54:29 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Thu Apr 17 05:54:30 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 15:12:02 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
    [Thu Apr 17 15:12:45 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
    [Thu Apr 17 15:12:45 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 15:21:05 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 15:21:11 2025] EXT4-fs (dm-8): unmounting filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1.
    [Thu Apr 17 15:21:12 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 16:18:07 2025] EXT4-fs (loop0): mounted filesystem f3abe6cb-d3c2-417b-b258-f48d1f72d3b4 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 16:20:34 2025] EXT4-fs (loop0): unmounting filesystem f3abe6cb-d3c2-417b-b258-f48d1f72d3b4.
    [Thu Apr 17 16:24:32 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 158 higher than expected, please wait.
    [Thu Apr 17 16:27:15 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 16:27:15 2025] EXT4-fs (loop0): mount failed
    [Thu Apr 17 16:27:54 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Thu Apr 17 16:27:55 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--174--disk--0 ext4   rw,relatime,stripe=16
    /var:
    445M    /var/
    251M    /var/cache
    247M    /var/cache/apt
    172M    /var/cache/apt/archives
    147M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    90M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 1186)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.evcc@0.1.1 (git+ssh://git@github.com/Newan/ioBroker.evcc.git#47c01e1026b8011a8407e3cb5f039a22d92ef9b2)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
      system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : IO-Broker                                - disabled
      system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
      system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
      system.adapter.birthdays.0              : birthdays             : IO-Broker                                -  enabled
      system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
      system.adapter.devices.0                : devices               : IO-Broker                                - disabled
      system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
      system.adapter.dwd.0                    : dwd                   : IO-Broker                                - disabled
      system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
      system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
      system.adapter.feiertage.0              : feiertage             : IO-Broker                                -  enabled
      system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
      system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
      system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
      system.adapter.homekit-controller.0     : homekit-controller    : IO-Broker                                - disabled
      system.adapter.ical.0                   : ical                  : IO-Broker                                -  enabled
      system.adapter.ical.1                   : ical                  : IO-Broker                                -  enabled
      system.adapter.influxdb.0               : influxdb              : IO-Broker                                - disabled, port: 8086
      system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
      system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
      system.adapter.luftdaten.0              : luftdaten             : IO-Broker                                -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
      system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : IO-Broker                                - disabled
      system.adapter.onvif.0                  : onvif                 : IO-Broker                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
      system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
      system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
      system.adapter.schoolfree.0             : schoolfree            : IO-Broker                                -  enabled
      system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : IO-Broker                                - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
      system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
      system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
      system.adapter.tr-064.0                 : tr-064                : IO-Broker                                - disabled
      system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
      system.adapter.unifi.0                  : unifi                 : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IO-Broker                                - disabled
      system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : IO-Broker                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IO-Broker                                - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : IO-Broker                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IO-Broker                                - disabled
      system.adapter.vis.0                    : vis                   : IO-Broker                                -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                - disabled
      system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                - disabled
      system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
      system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : IO-Broker                                -  enabled
      system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "alexa-shoppinglist": 1.0.3, installed 1.0.3
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "renacidc"     : 0.1.4    , installed 0.1.4
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "schoolfree"   : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        20284
    States:         15789
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://repo.mosquitto.org/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3590799    1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        3590963    148/mosquitto
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          3591052    313/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3589749    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3588769    1/init
    tcp6       0      0 :::1883                 :::*                    LISTEN      105        3590964    148/mosquitto
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          3591053    313/master
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3590800    1/init
    udp6       0      0 :::111                  :::*                                0          3589710    1/init
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.synology.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.235  - info: host.IO-Broker instance system.adapter.evcc.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker All instances are stopped.
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - warn: host.IO-Broker instance system.adapter.web.1 terminated due to SIGKILL
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.web.1 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.telegram.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.telegram.0 terminated with code null ()
    2025-04-19 06:39:42.377  - info: host.IO-Broker All instances are stopped.
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.echarts.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.echarts.0 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.text2command.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.text2command.0 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.web.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.web.0 terminated with code null ()
    2025-04-19 06:39:42.488  - info: host.IO-Broker terminated
    iob diag has finished.
    @kellerkind-86 sagte in Iobroker Oberfläche nicht mehr nutzbar:
    da ist aber einiges im Argen!
    ebenso hier
    sieht nach Ärger mit der Platte aus
    mehr weiß ich nicht
    ob das auch mit
    ein Problem mit Proxmox hatte,
    wäre zu prüfen
      ebenso hier
      mehr weiß ich nicht
      ob das auch mit
      wäre zu prüfen
      Kellerkind-86
      @homoran okay, danke.. ich versuch mal was herauszufinden. würde mich hier melden, sobald ich was herausgefunden habe..
      Gruß Marcell
      • K Kellerkind-86
        sorry. hier :
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 4
        tigger
        HOME=/home/tigger
        Desktop:
        Terminal:
        *** MEMORY ***
        Swap:           2.1G          0B        2.1G
                 8192 M total memory
                  176 M used memory
                  163 M active memory
                 7086 M free memory
                    0 M buffer memory
                  928 M swap cache
                 2048 M total swap
                    0 M used swap
                 2048 M free swap
        *** FILESYSTEM ***
        /var:
        445M    /var/
        251M    /var/cache
        247M    /var/cache/apt
        147M    /var/lib
        USB-Devices by-id:
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.3
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        20284
        States:         15789
        Pending Updates: 0
        Ro75R Offline
        Ro75R Offline
        Ro75
        [Thu Apr 17 15:12:45 2025] EXT4-fs (loop0): I/O error while writing superblock [Thu Apr 17 15:21:05 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none. [Thu Apr 17 15:21:11 2025] EXT4-fs (dm-8): unmounting filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1.
        Für mich eindeutig der Datenträger.
        Ro75.
        • Ro75R Ro75
          Ro75.
          Kellerkind-86
          @ro75 okay, damit hatte ich auch irgendwie probleme mit proxmox.. daraufhin hab ich alles neuaufgespielt und die backups wieder eingespielt.wie gehe ich da am besten vor ? um was herauszufinden ?
          Gruß Marcell
          Ro75R 1 Antwort Letzte Antwort
          • K Kellerkind-86
            Ro75R Offline
            Ro75R Offline
            Ro75
            Backup (falls gemeint) wird nicht reichen - da muss ein neuer Datenträger rein.
            Ro75.
            K 2 Antworten Letzte Antwort
            • Ro75R Ro75
              Ro75.
              Kellerkind-86
              @ro75 okay, dankeschön
              Gruß Marcell
              • Ro75R Ro75
                Ro75.
                Kellerkind-86
                @ro75 so.. jetzt ne neue ssd drin. aber was sagen diese fehlermeldungen und wie kann ich sie beheben ?
                ```bash
                Script v.2025-02-23
                *** BASE SYSTEM ***
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 09:20:31 up 50 min,  0 user,  load average: 0.32, 0.26, 0.27
                CPU threads: 4
                Failed to query server: Unit dbus-org.freedesktop.timedate1.service failed to load properly, please adjust/correct and reload service manager: File exists
                Failed to parse bus message: File exists
                tigger
                HOME=/home/tigger
                Desktop:
                Terminal:
                *** MEMORY ***
                Mem:            8.6G        123M        7.4G         77K        1.0G        8.5G
                Swap:           2.1G          0B        2.1G
                Total:           10G        123M        9.6G
                         8192 M total memory
                          118 M used memory
                          120 M active memory
                          874 M inactive memory
                         7099 M free memory
                            0 M buffer memory
                          974 M swap cache
                         2048 M total swap
                            0 M used swap
                         2048 M free swap
                top - 09:20:32 up 50 min,  0 user,  load average: 0.30, 0.26, 0.27
                Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                MiB Mem :   8192.0 total,   7098.2 free,    119.6 used,    974.3 buff/cache
                MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   8072.4 avail Mem
                * systemd-timedated.service          masked failed failed systemd-timedated.service
                12 loaded units listed.
                *** FILESYSTEM ***
                /dev/mapper/pve-vm--103--disk--0 ext4    25G  7.0G   17G  31% /
                tmpfs                            tmpfs  3.2G   72K  3.2G   1% /run
                [Tue Apr 22 16:56:52 2025] EXT4-fs (dm-1): mounted filesystem 208af763-f721-4927-a9c2-c7e1b74a0dd0 ro with ordered data mode. Quota mode: none.
                [Tue Apr 22 16:56:53 2025] EXT4-fs (dm-1): re-mounted 208af763-f721-4927-a9c2-c7e1b74a0dd0 r/w. Quota mode: none.
                [Tue Apr 22 17:13:45 2025] EXT4-fs (loop0): mounted filesystem 43d49d75-3d08-481b-b503-83b22a667290 r/w with ordered data mode. Quota mode: none.
                [Tue Apr 22 17:16:34 2025] EXT4-fs (loop0): unmounting filesystem 43d49d75-3d08-481b-b503-83b22a667290.
                [Tue Apr 22 17:17:05 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 50 higher than expected, please wait.
                [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): I/O error while writing superblock
                [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): mount failed
                [Tue Apr 22 17:19:42 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
                [Tue Apr 22 17:20:40 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
                [Tue Apr 22 17:21:21 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 66 higher than expected, please wait.
                [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): I/O error while writing superblock
                [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): mount failed
                [Tue Apr 22 18:30:44 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                [Tue Apr 22 18:31:27 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
                [Tue Apr 22 18:31:27 2025] EXT4-fs (loop0): I/O error while writing superblock
                [Tue Apr 22 22:41:44 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
                [Tue Apr 22 22:43:26 2025] EXT4-fs warning (device loop1): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                [Tue Apr 22 22:44:09 2025] EXT4-fs warning (device loop1): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
                [Tue Apr 22 22:44:09 2025] EXT4-fs (loop1): I/O error while writing superblock
                [Tue Apr 22 22:57:45 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
                [Tue Apr 22 23:12:23 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): I/O error while writing superblock
                [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): mount failed
                [Wed Apr 23 01:49:04 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 01:49:36 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
                [Wed Apr 23 01:50:25 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 01:51:19 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 01:51:34 2025] EXT4-fs (dm-17): unmounting filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9.
                [Wed Apr 23 01:53:09 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 07:23:44 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 07:23:57 2025] EXT4-fs (dm-18): unmounting filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d.
                [Wed Apr 23 07:24:04 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
                [Wed Apr 23 08:29:19 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
                [Wed Apr 23 08:29:34 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                /      /dev/mapper/pve-vm--103--disk--0 ext4   rw,relatime,stripe=16
                /var:
                497M    /var/
                282M    /var/cache
                278M    /var/cache/apt
                202M    /var/cache/apt/archives
                147M    /var/lib
                USB-Devices by-id:
                HINT:
                tcp
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                /usr/bin/nodejs         v20.19.1
                /usr/bin/node           v20.19.1
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Installed: 20.19.1-1nodesource1
                  Candidate: 20.19.1-1nodesource1
                  Version table:
                 *** 20.19.1-1nodesource1 1001
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 601)
                admin:          7.6.3
                javascript:     8.8.3
                Adapter State
                  system.adapter.dwd.0                    : dwd                   : IO-Broker                                -  enabled
                  system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
                  system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                -  enabled
                + instance is alive
                Objects and States
                Objects:        19956
                States:         15607
                Hit:4 https://repo.mosquitto.org/debian bookworm InRelease
                Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        1664487    155/mosquitto
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1664324    1/init
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1664587    313/master
                tcp6       0      0 :::1883                 :::*                    LISTEN      105        1664488    155/mosquitto
                tcp6       0      0 :::22                   :::*                    LISTEN      0          1663846    1/init
                tcp6       0      0 :::111                  :::*                    LISTEN      0          1662748    1/init
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1664588    313/master
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1664325    1/init
                udp6       0      0 :::111                  :::*                                0          1661881    1/init
                2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.bluelink.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.evcc.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                2025-04-23 06:39:47.921  - info: host.IO-Broker All instances are stopped.
                2025-04-23 06:39:48.054  - warn: host.IO-Broker instance system.adapter.telegram.0 terminated due to SIGKILL
                2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.telegram.0 terminated with code null ()
                2025-04-23 06:39:48.055  - info: host.IO-Broker All instances are stopped.
                2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.echarts.0 terminated due to SIGKILL
                2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.echarts.0 terminated with code null ()
                2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.text2command.0 terminated due to SIGKILL
                2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.text2command.0 terminated with code null ()
                2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.web.0 terminated due to SIGKILL
                2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.web.0 terminated with code null ()
                2025-04-23 06:39:48.060  - warn: host.IO-Broker instance system.adapter.web.1 terminated due to SIGKILL
                2025-04-23 06:39:48.060  - info: host.IO-Broker instance system.adapter.web.1 terminated with code null ()
                2025-04-23 06:39:48.060  - info: host.IO-Broker All instances are stopped.
                2025-04-23 06:39:48.124  - info: host.IO-Broker terminated
                Gruß Marcell
                • K Kellerkind-86
                  ```bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 4
                  tigger
                  HOME=/home/tigger
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Swap:           2.1G          0B        2.1G
                           8192 M total memory
                            118 M used memory
                            120 M active memory
                           7099 M free memory
                              0 M buffer memory
                            974 M swap cache
                           2048 M total swap
                              0 M used swap
                           2048 M free swap
                  *** FILESYSTEM ***
                  /var:
                  497M    /var/
                  282M    /var/cache
                  278M    /var/cache/apt
                  147M    /var/lib
                  USB-Devices by-id:
                  HINT:
                  tcp
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.6.3
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        19956
                  States:         15607
                  Pending Updates: 0
                  *** BASE SYSTEM *** Failed to query system properties: Connection timed out
                  Das ist schon der erste Fehler. Da kann iob diag schon nicht die grundlegenden Systeminformationen abrufen.
                  Hat mit dem ioBroker nix zu tun.
                  Ist was mit dem Dateisystem.
                  Zu LXCs kann ich aber weiter nix sagen, muss dir wer anders helfen.
                    CodierknechtC Offline
                    Codierknecht
                    @thomas-braun sagte in Iobroker Oberfläche nicht mehr nutzbar:
                    @Kellerkind-86
                    Was hast Du da für ein Template verwendet? Das Standard-Debian12 von Proxmox?
                    HmIP|ZigBee|Tasmota|Unifi
                    Zabbix Certified Specialist
                      Kellerkind-86
                      @codierknecht
                      tigger@IO-Broker:~$ lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Debian
                      Description: Debian GNU/Linux 12 (bookworm)
                      Release: 12
                      Codename: bookworm
                      tigger@IO-Broker:~$
                      genau.
                      echt mal komisch
                      Gruß Marcell
                      • K Kellerkind-86
                        @codierknecht
                        Release: 12
                        Codename: bookworm
                        tigger@IO-Broker:~$
                        genau.
                        echt mal komisch
                        Codierknecht
                        @kellerkind-86
                        Also ich nehme dieses Template:
                        Baue damit den LXC (ohne Desktop oder sonstigen Firlefanz) und installiere ioBroker mit dem Einzeiler.
                        • CodierknechtC Codierknecht
                          @kellerkind-86
                          Kellerkind-86
                          @codierknecht okay, ich werde es nochmal heute abend machen.. ja.. iobroker hab ich auch so installiert.
                          Gruß Marcell
                            @kellerkind-86
                            Kellerkind-86
                            @codierknecht okay, hat leider etwas länger gedauert.. jetzt sollte es laufen.. oder ?
                            ```bash
                            Script v.2025-02-23
                            *** BASE SYSTEM ***
                             Static hostname: IO-Broker
                                   Icon name: computer-container
                                     Chassis: container ☐
                              Virtualization: lxc
                                      Kernel: Linux 6.8.12-9-pve
                                Architecture: x86-64
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                            CPU threads: 4
                                           Local time: Tue 2025-05-06 23:34:57 CEST
                                       Universal time: Tue 2025-05-06 21:34:57 UTC
                                             RTC time: n/a
                                          NTP service: inactive
                                      RTC in local TZ: no
                            tigger
                            HOME=/home/tigger
                            GROUPS=tigger sudo users iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            8.6G        2.8G        4.6G        139K        1.2G        5.8G
                            Swap:           2.1G          0B        2.1G
                            Total:           10G        2.8G        6.8G
                            Active iob-Instances:   42
                                     8192 M total memory
                                     2641 M used memory
                                     2538 M active memory
                                      994 M inactive memory
                                     4398 M free memory
                                        0 M buffer memory
                                     1151 M swap cache
                                     2048 M total swap
                                        0 M used swap
                                     2048 M free swap
                            top - 23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                            Tasks:  72 total,   1 running,  71 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   8192.0 total,   4396.9 free,   2643.6 used,   1151.6 buff/cache
                            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5548.4 avail Mem
                            * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                            1 loaded units listed.
                            dmesg: read kernel buffer failed: Operation not permitted
                            *** FILESYSTEM ***
                            /dev/mapper/pve-vm--174--disk--0 ext4       16G  6.4G  8.5G  44% /
                            udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                            tmpfs                            tmpfs     3.2G  132K  3.2G   1% /run
                            tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                            /var:
                            421M    /var/
                            250M    /var/cache
                            246M    /var/cache/apt
                            170M    /var/cache/apt/archives
                            147M    /var/lib
                            28M     /opt/iobroker/backups/
                            USB-Devices by-id:
                            HINT:
                            tcp
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 2626)
                            admin:          7.6.3
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
                            + system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
                            + system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
                            + system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
                            + system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
                            + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
                            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
                            + system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
                            + system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                -  enabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
                            + system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
                            + system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
                            + system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                            + system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                            + system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
                            + system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
                            + system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
                            + system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
                            + system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
                            + system.adapter.onvif.0                  : onvif                 : IO-Broker                                -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                            + system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
                            + system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
                            + system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
                            + system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
                            + system.adapter.shelly.1                 : shelly                : IO-Broker                                -  enabled, port: 1882, bind: 0.0.0.0
                            + system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
                            + system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
                            + system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
                            + system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
                            + system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
                            + system.adapter.unifi.0                  : unifi                 : IO-Broker                                -  enabled
                            + system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
                            + system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                -  enabled
                            + system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
                            + system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
                            + instance is alive
                            Objects and States
                            Objects:        20154
                            States:         16138
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45754451   1/init
                            tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       45919336   4914/io.hm-rpc.0
                            tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       45921323   4929/io.hm-rpc.1
                            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       45919548   4944/io.shelly.1
                            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        45916862   4883/mosquitto
                            tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       45797552   3670/io.wiffi-wz.0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45777028   1847/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       45777033   1847/iobroker.js-co
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          45753745   294/master
                            tcp6       0      0 :::20002                :::*                    LISTEN      1001       45796519   3655/io.web.1
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          45754453   1/init
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          45753746   294/master
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          45752838   1/init
                            tcp6       0      0 :::1883                 :::*                    LISTEN      105        45916863   4883/mosquitto
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       45795819   3685/io.ws.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45794286   3640/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       45777930   1866/io.admin.0
                            tcp6       0      0 :::61991                :::*                    LISTEN      1001       45779797   2171/io.harmony.0
                            udp        0      0 0.0.0.0:57269           0.0.0.0:*                           1001       45786621   2607/io.shelly.0
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          45754452   1/init
                            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       45779798   2171/io.harmony.0
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       45783545   2607/io.shelly.0
                            udp6       0      0 :::111                  :::*                                0          45754454   1/init
                            2025-05-06 23:31:21.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                            2025-05-06 23:31:30.051  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                            2025-05-06 23:32:51.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                            2025-05-06 23:33:15.985  - info: admin.0 (1866) <== Disconnect system.user.admin from ::ffff:192.168.178.25 javascript
                            2025-05-06 23:33:16.503  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                            2025-05-06 23:34:21.195  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                            danke
                            Gruß Marcell
                            • K Kellerkind-86
                              ```bash
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                               RTC time: n/a
                                        RTC in local TZ: no
                              tigger
                              HOME=/home/tigger
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           2.1G          0B        2.1G
                                       8192 M total memory
                                       2641 M used memory
                                       4398 M free memory
                                          0 M buffer memory
                                       1151 M swap cache
                                       2048 M total swap
                                          0 M used swap
                                       2048 M free swap
                              *** FILESYSTEM ***
                              /var:
                              421M    /var/
                              250M    /var/cache
                              246M    /var/cache/apt
                              147M    /var/lib
                              USB-Devices by-id:
                              HINT:
                              tcp
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.6.3
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        20154
                              States:         16138
                              Pending Updates: 0
                              danke
                              Codierknecht
                              @kellerkind-86
                              Sieht doch prinzipiell ganz gut aus.
                              Das kannst Du uns hoffentlich sagen ;-)
                              Was es mit dem
                              auf sich hat, kann vielleicht @Thomas-Braun sagen. Ich vermute ein Rechte-Problem.
                              Achtung: admin.0 und onvif.0 verwenden beide Port 8081. Das könnte zu Problemen führen.
                                @kellerkind-86
                                Was es mit dem
                                @codierknecht sagte in Iobroker Oberfläche nicht mehr nutzbar:
                                Der user darf nicht in den Kernelringpuffer des Hosts schauen.
                                Ist bei einem LXC ja auch Sinn und Zweck, das solche Kisten weggekapselt sind.
                                  Codierknecht
                                  Und? Kann das Probleme bereiten oder kann das ignoriert werden?
                                  Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                    @codierknecht
                                    Kann bei LXCs ignoriert werden, das ist halt 'works as intended'.
                                      Meister MopperM Offline
                                      Meister Mopper
                                      Als der ioBroker bei mir in einem LXC lief, kam natürlich auch diese Fehlermeldung. Ich habe sie ignoriert und gut war.
                                      Jetzt läuft der ioBroker in einer VM und die Meldung kommt natürlich nicht mehr.
                                      @Thomas-Braun
                                      Vielleicht kann das Skript ja so angepasst werden, dass die Prüfung bei einem Container nicht durchgeführt wird.
                                      Das ist aus meiner Sicht zumindest eine kosmetische Lösung.
                                      Proxmox und HA ...
                                        @Thomas-Braun
                                        @meister-mopper
                                        Ich halte nix von kosmetischen Eingriffen.
                                        Die Meldung kommt ja zu Recht. Die Bewertung obliegt dann demjenigen, der das Log interpretiert.
                                          @meister-mopper
                                          Codierknecht
                                          Bei mir kommt die nicht. Dafür kann in meinem LXC das Release nicht sauber erkannt werden ;-)
                                          Script v.2025-02-23
                                          *** BASE SYSTEM ***
                                           Static hostname: iobroker
                                            Virtualization: lxc
                                                    Kernel: Linux 6.8.12-10-pve
                                          OS is similar to:
                                          model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
                                          Docker          : false
                                          Kernel          : x86_64
                                          Userland        : 64 bit
                                           10:17:35 up 7 days, 4 min,  2 users,  load average: 0.33, 0.36, 0.49
                                          CPU threads: 2
                                          Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                                         Local time: Wed 2025-05-07 10:17:35 CEST
                                                     Universal time: Wed 2025-05-07 08:17:35 UTC
                                                           RTC time: n/a
                                                    RTC in local TZ: no
                                          codierknecht
                                          HOME=/home/codierknecht
                                          GROUPS=codierknecht adm sudo users systemd-journal iobroker
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:
                                          *** MEMORY ***
                                          Mem:            8.6G        2.4G        5.7G        397K        482M        6.2G
                                          Swap:           1.1G        512M        561M
                                          Total:          9.7G        2.9G        6.3G
                                          Active iob-Instances:   36
                                                   8192 M total memory
                                                   2289 M used memory
                                                   1102 M active memory
                                                   1506 M inactive memory
                                                   5443 M free memory
                                                      0 M buffer memory
                                                    459 M swap cache
                                                   1024 M total swap
                                                    488 M used swap
                                                    535 M free swap
                                          top - 10:17:36 up 7 days, 4 min,  2 users,  load average: 0.33, 0.36, 0.49
                                          Tasks:  67 total,   1 running,  66 sleeping,   0 stopped,   0 zombie
                                          MiB Mem :   8192.0 total,   5441.1 free,   2291.2 used,    460.1 buff/cache
                                          MiB Swap:   1024.0 total,    535.6 free,    488.4 used.   5900.8 avail Mem
                                          0 loaded units listed.
                                          *** FILESYSTEM ***
                                          /dev/mapper/pve-vm--104--disk--0 ext4    20G  9.6G  9.0G  52% /
                                          tmpfs                            tmpfs  3.2G  232K  3.2G   1% /run
                                          [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): mounted filesystem 35e403cc-3cb6-4691-937c-5b0dccb22862 ro with ordered data mode. Quota mode: none.
                                          [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): re-mounted 35e403cc-3cb6-4691-937c-5b0dccb22862 r/w. Quota mode: none.
                                          [Wed Apr 30 10:12:51 2025] EXT4-fs (dm-6): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 r/w with ordered data mode. Quota mode: none.
                                          [Wed Apr 30 10:12:53 2025] EXT4-fs (dm-7): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 r/w with ordered data mode. Quota mode: none.
                                          [Wed Apr 30 10:12:55 2025] EXT4-fs (dm-8): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 r/w with ordered data mode. Quota mode: none.
                                          [Wed Apr 30 10:12:58 2025] EXT4-fs (dm-10): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 r/w with ordered data mode. Quota mode: none.
                                          [Thu May  1 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Thu May  1 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Thu May  1 03:03:11 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Thu May  1 03:03:12 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Thu May  1 03:03:12 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Thu May  1 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Thu May  1 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Thu May  1 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Thu May  1 03:07:08 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Fri May  2 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Fri May  2 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Fri May  2 03:01:35 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Fri May  2 03:01:36 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Fri May  2 03:01:36 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Fri May  2 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Fri May  2 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Fri May  2 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Fri May  2 03:07:25 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Sat May  3 03:00:05 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sat May  3 03:00:05 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Sat May  3 03:01:39 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Sat May  3 03:01:40 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sat May  3 03:01:40 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Sat May  3 03:03:22 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Sat May  3 03:03:23 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sat May  3 03:03:23 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Sat May  3 03:03:49 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Sat May  3 03:03:50 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sat May  3 03:03:50 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Sat May  3 03:07:19 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Sun May  4 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sun May  4 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Sun May  4 03:01:36 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Sun May  4 03:01:37 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sun May  4 03:01:37 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Sun May  4 03:03:38 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Sun May  4 03:03:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Sun May  4 03:03:39 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Sun May  4 03:07:14 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Mon May  5 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Mon May  5 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Mon May  5 03:02:56 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Mon May  5 03:02:57 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Mon May  5 03:02:57 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Mon May  5 03:03:28 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Mon May  5 03:03:29 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Mon May  5 03:03:29 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Mon May  5 03:07:00 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Tue May  6 03:00:02 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Tue May  6 03:00:02 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Tue May  6 03:01:38 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Tue May  6 03:01:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Tue May  6 03:01:39 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Tue May  6 03:03:14 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Tue May  6 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Tue May  6 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Tue May  6 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Tue May  6 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Tue May  6 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Tue May  6 03:07:24 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          [Wed May  7 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Wed May  7 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                          [Wed May  7 03:01:42 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                          [Wed May  7 03:01:43 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Wed May  7 03:01:43 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                          [Wed May  7 03:03:23 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                          [Wed May  7 03:03:24 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Wed May  7 03:03:24 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                          [Wed May  7 03:03:54 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                          [Wed May  7 03:03:55 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                          [Wed May  7 03:03:55 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                          [Wed May  7 03:07:32 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                          /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
                                          /var:
                                          3.2G    /var/
                                          2.1G    /var/log/journal/c56b513cffd54f1394845d28e4aeddf1
                                          2.1G    /var/log
                                          954M    /var/cache
                                          Archived and active journals take up 2.0G in the file system.
                                          4.0K    /opt/iobroker/backups/
                                          991M    /opt/iobroker/iobroker-data/
                                          857M    /opt/iobroker/iobroker-data/files
                                          29M     /opt/iobroker/iobroker-data/objects.jsonl
                                          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                          17M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.64d9ecc7.js.map
                                          9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                                          USB-Devices by-id:
                                          HINT:
                                          tcp
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 605072)
                                          admin:          7.6.3
                                          javascript:     8.8.3
                                          +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                                          +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#860bde5a0d4828af5e85cc4569c56d740523d767)
                                          Adapter State
                                          + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          + system.adapter.boschindego.0            : boschindego           : iobroker                                 -  enabled
                                          + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                                          + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                          + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                                          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                          + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                            system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                            system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                          + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                          + system.adapter.lupusec.0                : lupusec               : iobroker                                 -  enabled
                                          + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                          + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                                            system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
                                          + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                                            system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                          + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker                                 -  enabled, port: 8000
                                          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                                          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                          + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                                          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                            system.adapter.scheduler.0              : scheduler             : iobroker                                 - disabled
                                          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                          + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                          + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                          + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                          + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                          + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.179.141:6638
                                          + instance is alive
                                          │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                          Upgrade policy: minor
                                          Adapter    "adguard"      : 1.0.1    , installed 1.0.1
                                          Adapter    "boschindego"  : 1.3.9    , installed 1.3.9
                                          Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                          Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                          Adapter    "email"        : 2.0.3    , installed 2.0.3
                                          Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                          Adapter    "fritzdect"    : 2.6.1    , installed 2.6.1
                                          Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                                          Adapter    "linux-control": 1.1.5    , installed 1.1.6
                                          Adapter    "lupusec"      : 2.0.7    , installed 2.0.7
                                          Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                          Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                          Adapter    "paperless-ngx": 0.4.4    , installed 0.4.4
                                          Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                          Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                                          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                          Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
                                          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                          Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                          Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                          Objects and States
                                          Objects:        10034
                                          States:         7944
                                          Hit:2 http://security.debian.org bookworm-security InRelease
                                          Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                                          Pending Updates: 0
                                          tcp        0      0 127.0.0.1:39603         0.0.0.0:*               LISTEN      1001       52141433   1353/io.yahka.0
                                          tcp        0      0 0.0.0.0:38509           0.0.0.0:*               LISTEN      1001       36404      1353/io.yahka.0
                                          tcp        0      0 127.0.0.1:37835         0.0.0.0:*               LISTEN      1001       52138637   1353/io.yahka.0
                                          tcp        0      0 127.0.0.1:38711         0.0.0.0:*               LISTEN      1001       52138642   1353/io.yahka.0
                                          tcp        0      0 0.0.0.0:8087            0.0.0.0:*               LISTEN      1001       34556      1152/io.lupusec.0
                                          tcp        0      0 0.0.0.0:40401           0.0.0.0:*               LISTEN      1001       36422      1353/io.yahka.0
                                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       20512      145/iobroker.js-con
                                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       20517      145/iobroker.js-con
                                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17811      1/init
                                          tcp        0      0 0.0.0.0:33273           0.0.0.0:*               LISTEN      1001       36414      1353/io.yahka.0
                                          tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       21281      538/io.hm-rpc.0
                                          tcp        0      0 0.0.0.0:10050           0.0.0.0:*               LISTEN      105        27697967   578950/zabbix_agent
                                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       26164      649/io.mqtt.0
                                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       29931      703/io.sonoff.0
                                          tcp        0      0 127.0.0.1:33163         0.0.0.0:*               LISTEN      1001       52141438   1353/io.yahka.0
                                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18295      315/master
                                          tcp        0      0 0.0.0.0:43447           0.0.0.0:*               LISTEN      1001       36418      1353/io.yahka.0
                                          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18296      315/master
                                          tcp6       0      0 :::8083                 :::*                    LISTEN      1001       37981      1264/io.simple-api.
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38176      1336/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20594      326/io.admin.0
                                          tcp6       0      0 :::8000                 :::*                    LISTEN      1001       38540      1302/io.upnp.0
                                          tcp6       0      0 :::41527                :::*                    LISTEN      1001       36407      1353/io.yahka.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          18822      1/init
                                          tcp6       0      0 :::111                  :::*                    LISTEN      0          17813      1/init
                                          tcp6       0      0 :::10050                :::*                    LISTEN      105        27697968   578950/zabbix_agent
                                          tcp6       0      0 :::35443                :::*                    LISTEN      1001       36409      1353/io.yahka.0
                                          tcp6       0      0 :::34843                :::*                    LISTEN      1001       36405      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       38251      1302/io.upnp.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36419      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36415      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36411      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36410      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36408      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36406      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36401      1353/io.yahka.0
                                          udp        0      0 0.0.0.0:55640           0.0.0.0:*                           1001       36205      1302/io.upnp.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18746      87/dhclient
                                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17812      1/init
                                          udp6       0      0 :::111                  :::*                                0          17814      1/init
                                          2025-05-07 09:23:53.981  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                          2025-05-07 09:23:56.819  - info: admin.0 (326) Repository received successfully.
                                          2025-05-07 09:23:57.175  - info: host.iobroker Check for available automatic adapter upgrades
                                          2025-05-07 09:32:00.012  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1128208
                                          2025-05-07 09:32:06.894  - info: host.iobroker instance system.adapter.ical.0 having pid 1128208 terminated with code 0 (NO_ERROR)
                                          2025-05-07 09:34:00.009  - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1128302
                                          2025-05-07 09:34:07.823  - info: host.iobroker instance system.adapter.ical.1 having pid 1128302 terminated with code 0 (NO_ERROR)
                                          2025-05-07 09:36:00.010  - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1128749
                                          2025-05-07 09:36:07.257  - info: host.iobroker instance system.adapter.ical.2 having pid 1128749 terminated with code 0 (NO_ERROR)
                                          2025-05-07 09:45:44.384  - info: javascript.0 (392) script.js.common.Informationen.Renault: Austral-Standort: 387, Friedrich-Ebert-Straße, Stadtwald, Bockum, Krefeld, North Rhine-Westphalia, 47800, Germany
                                          2025-05-07 09:47:37.009  - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1129921
                                          2025-05-07 09:47:53.163  - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1129921 terminated with code 0 (NO_ERROR)
                                          2025-05-07 09:52:00.024  - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest mit Server 54504 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                                          2025-05-07 09:52:17.539  - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 49.1 MB/s | Upload: 24.5 MB/s | Ping: 7.983ms
                                          2025-05-07 10:02:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1131604
                                          2025-05-07 10:02:06.805  - info: host.iobroker instance system.adapter.ical.0 having pid 1131604 terminated with code 0 (NO_ERROR)
                                          2025-05-07 10:04:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1131698
                                          2025-05-07 10:04:07.751  - info: host.iobroker instance system.adapter.ical.1 having pid 1131698 terminated with code 0 (NO_ERROR)
                                          2025-05-07 10:06:00.012  - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1132140
                                          2025-05-07 10:06:07.131  - info: host.iobroker instance system.adapter.ical.2 having pid 1132140 terminated with code 0 (NO_ERROR)
                                          2025-05-07 10:13:00.948  - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs ENR.DE: 72.82 €
                                          2025-05-07 10:13:00.948  - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs SIE.DE: 209.55 €
                                          2025-05-07 10:13:11.339  - info: admin.0 (326) Adapter rating updated
                                          2025-05-07 10:17:37.015  - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1133590
                                          2025-05-07 10:17:43.169  - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1133590 terminated with code 0 (NO_ERROR)
