  4. Iobroker Oberfläche nicht mehr nutzbar
    6.8k
26 Beiträge 6 Kommentatoren 3.6k Aufrufe 4 Beobachtet
    @kellerkind-86 sagte in Iobroker Oberfläche nicht mehr nutzbar:
    hier die ausgabe von dialog:
    bitte die Langfassung!
    die nötigen Informationen sind nicht in der Summary enthalten
    Kellerkind-86
    sorry. hier :
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
    Failed to query system properties: Connection timed out
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     06:43:40 up 1 day, 14:15,  0 user,  load average: 0.10, 0.18, 0.23
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** TIME AND TIMEZONES ***
    Failed to query server: Connection timed out
    Failed to parse bus message: Connection timed out
    *** Users and Groups ***
    User that called 'iob diag':
    tigger
    HOME=/home/tigger
    GROUPS=tigger users iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:
    *** MEMORY ***
    Mem:            8.6G        185M        7.4G         81K        973M        8.4G
    Swap:           2.1G          0B        2.1G
    Total:           10G        185M        9.6G
    Active iob-Instances:   1
             8192 M total memory
              176 M used memory
              163 M active memory
              782 M inactive memory
             7086 M free memory
                0 M buffer memory
              928 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    top - 06:44:55 up 1 day, 14:16,  0 user,  load average: 0.02, 0.14, 0.21
    Tasks:  24 total,   1 running,  23 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8192.0 total,   7085.4 free,    178.3 used,    928.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   8013.7 avail Mem
    *** FAILED SERVICES ***
      UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service                   loaded failed failed ioBroker Server
    * logrotate.service                  loaded failed failed Rotate log files
    * man-db.service                     loaded failed failed Daily man-db regeneration
    * nftables.service                   loaded failed failed nftables
    * systemd-hostnamed.service          loaded failed failed Hostname Service
    * systemd-logind.service             loaded failed failed User Login Management
    * systemd-networkd.service           loaded failed failed Network Configuration
    * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
    * systemd-sysusers.service           loaded failed failed Create System Users
    * systemd-timedated.service          loaded failed failed Time & Date Service
    * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
    * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
    * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
    * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
    14 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--174--disk--0 ext4    25G  6.7G   17G  29% /
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G   76K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    [Wed Apr 16 09:22:31 2025] EXT4-fs (dm-1): mounted filesystem 67833da0-c8be-4097-98f5-d42afffe5926 ro with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:22:32 2025] EXT4-fs (dm-1): re-mounted 67833da0-c8be-4097-98f5-d42afffe5926 r/w. Quota mode: none.
    [Wed Apr 16 09:51:03 2025] EXT4-fs (loop0): mounted filesystem c29867de-ff93-475f-82b5-a2b4945a5cd0 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:52:06 2025] EXT4-fs (loop0): unmounting filesystem c29867de-ff93-475f-82b5-a2b4945a5cd0.
    [Wed Apr 16 09:54:46 2025] EXT4-fs (loop0): mounted filesystem d1209dba-7cdf-4b63-94e5-cff03986f8bd r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 09:56:00 2025] EXT4-fs (loop0): unmounting filesystem d1209dba-7cdf-4b63-94e5-cff03986f8bd.
    [Wed Apr 16 09:57:03 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 348 higher than expected, please wait.
    [Wed Apr 16 10:02:54 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 10:02:54 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 10:06:47 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 10:06:54 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 10:06:55 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 10:10:39 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 10:10:40 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 11:21:26 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 11:21:27 2025] EXT4-fs (dm-7): mounted filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:17:49 2025] EXT4-fs (loop0): mounted filesystem 45a4aef7-de9b-47a1-9e57-2e50b0691d4b r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:18:56 2025] EXT4-fs (loop0): unmounting filesystem 45a4aef7-de9b-47a1-9e57-2e50b0691d4b.
    [Wed Apr 16 17:19:42 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 130 higher than expected, please wait.
    [Wed Apr 16 17:21:56 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 17:21:56 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 17:28:35 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 17:28:42 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 17:28:50 2025] EXT4-fs (dm-7): unmounting filesystem 4eadf865-3011-45b3-a21a-f0e4fab7645e.
    [Wed Apr 16 17:29:03 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 18:59:14 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 19:00:46 2025] EXT4-fs (dm-8): mounted filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:01:16 2025] EXT4-fs (dm-8): unmounting filesystem a41b6e9d-84d5-4b28-848b-99df50660ee2.
    [Wed Apr 16 19:03:23 2025] EXT4-fs (loop0): mounted filesystem efbced7f-2bad-47db-904a-b7c880dd61c2 r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:04:12 2025] EXT4-fs (loop0): unmounting filesystem efbced7f-2bad-47db-904a-b7c880dd61c2.
    [Wed Apr 16 19:05:14 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 270 higher than expected, please wait.
    [Wed Apr 16 19:09:47 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Wed Apr 16 19:09:47 2025] EXT4-fs (loop0): mount failed
    [Wed Apr 16 19:11:54 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:12:00 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Wed Apr 16 19:12:01 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 19:45:50 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Wed Apr 16 19:45:51 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Wed Apr 16 22:55:01 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
    [Wed Apr 16 22:55:44 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
    [Wed Apr 16 22:55:44 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 05:54:29 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Thu Apr 17 05:54:30 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 15:12:02 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
    [Thu Apr 17 15:12:45 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
    [Thu Apr 17 15:12:45 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 15:21:05 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 15:21:11 2025] EXT4-fs (dm-8): unmounting filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1.
    [Thu Apr 17 15:21:12 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 16:18:07 2025] EXT4-fs (loop0): mounted filesystem f3abe6cb-d3c2-417b-b258-f48d1f72d3b4 r/w with ordered data mode. Quota mode: none.
    [Thu Apr 17 16:20:34 2025] EXT4-fs (loop0): unmounting filesystem f3abe6cb-d3c2-417b-b258-f48d1f72d3b4.
    [Thu Apr 17 16:24:32 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 158 higher than expected, please wait.
    [Thu Apr 17 16:27:15 2025] EXT4-fs (loop0): I/O error while writing superblock
    [Thu Apr 17 16:27:15 2025] EXT4-fs (loop0): mount failed
    [Thu Apr 17 16:27:54 2025] EXT4-fs (dm-7): unmounting filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab.
    [Thu Apr 17 16:27:55 2025] EXT4-fs (dm-7): mounted filesystem 0ae6d9a1-2f88-4473-9efb-7f89b6e291ab r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--174--disk--0 ext4   rw,relatime,stripe=16
    /var:
    445M    /var/
    251M    /var/cache
    247M    /var/cache/apt
    172M    /var/cache/apt/archives
    147M    /var/lib
          Users in the 'systemd-journal' group can see all messages. Pass -q to
          turn off this notice.
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    90M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 1186)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     2
    +-- iobroker.evcc@0.1.1 (git+ssh://git@github.com/Newan/ioBroker.evcc.git#47c01e1026b8011a8407e3cb5f039a22d92ef9b2)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
      system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : IO-Broker                                - disabled
      system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
      system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
      system.adapter.birthdays.0              : birthdays             : IO-Broker                                -  enabled
      system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
      system.adapter.devices.0                : devices               : IO-Broker                                - disabled
      system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
      system.adapter.dwd.0                    : dwd                   : IO-Broker                                - disabled
      system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
      system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
      system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
      system.adapter.feiertage.0              : feiertage             : IO-Broker                                -  enabled
      system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                - disabled
      system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
      system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
      system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
      system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
      system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
      system.adapter.homekit-controller.0     : homekit-controller    : IO-Broker                                - disabled
      system.adapter.ical.0                   : ical                  : IO-Broker                                -  enabled
      system.adapter.ical.1                   : ical                  : IO-Broker                                -  enabled
      system.adapter.influxdb.0               : influxdb              : IO-Broker                                - disabled, port: 8086
      system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
      system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
      system.adapter.luftdaten.0              : luftdaten             : IO-Broker                                -  enabled
      system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
      system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.octoprint.0              : octoprint             : IO-Broker                                - disabled
      system.adapter.onvif.0                  : onvif                 : IO-Broker                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
      system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
      system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
      system.adapter.schoolfree.0             : schoolfree            : IO-Broker                                -  enabled
      system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : IO-Broker                                - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
      system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
      system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
      system.adapter.tr-064.0                 : tr-064                : IO-Broker                                - disabled
      system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
      system.adapter.unifi.0                  : unifi                 : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IO-Broker                                - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IO-Broker                                - disabled
      system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : IO-Broker                                -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : IO-Broker                                - disabled
      system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                - disabled
      system.adapter.vis-metro.0              : vis-metro             : IO-Broker                                - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : IO-Broker                                - disabled
      system.adapter.vis.0                    : vis                   : IO-Broker                                -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                - disabled
      system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                - disabled
      system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
      system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.yr.0                     : yr                    : IO-Broker                                -  enabled
      system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "alexa-shoppinglist": 1.0.3, installed 1.0.3
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "evcc"         : 0.1.1    , installed 0.1.1
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homekit-controller": 0.5.11, installed 0.5.11
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "renacidc"     : 0.1.4    , installed 0.1.4
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "schoolfree"   : 1.1.9    , installed 1.1.9
    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
    Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        20284
    States:         15789
    Hit:1 http://security.debian.org bookworm-security InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 https://repo.mosquitto.org/debian bookworm InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3590799    1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        3590963    148/mosquitto
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          3591052    313/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          3589749    1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          3588769    1/init
    tcp6       0      0 :::1883                 :::*                    LISTEN      105        3590964    148/mosquitto
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          3591053    313/master
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3590800    1/init
    udp6       0      0 :::111                  :::*                                0          3589710    1/init
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.pollenflug.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.synology.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.234  - info: host.IO-Broker instance system.adapter.energiefluss-erweitert.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.235  - info: host.IO-Broker instance system.adapter.evcc.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - info: host.IO-Broker All instances are stopped.
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
    2025-04-19 06:39:42.255  - warn: host.IO-Broker instance system.adapter.web.1 terminated due to SIGKILL
    2025-04-19 06:39:42.255  - info: host.IO-Broker instance system.adapter.web.1 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.telegram.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.telegram.0 terminated with code null ()
    2025-04-19 06:39:42.377  - info: host.IO-Broker All instances are stopped.
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.echarts.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.echarts.0 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.text2command.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.text2command.0 terminated with code null ()
    2025-04-19 06:39:42.377  - warn: host.IO-Broker instance system.adapter.web.0 terminated due to SIGKILL
    2025-04-19 06:39:42.377  - info: host.IO-Broker instance system.adapter.web.0 terminated with code null ()
    2025-04-19 06:39:42.488  - info: host.IO-Broker terminated
    iob diag has finished.
    Gruß Marcell
    HomoranH Ro75R 2 Antworten Letzte Antwort
    • K Kellerkind-86
      sorry. hier :
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
      tigger
      HOME=/home/tigger
      Desktop:
      Terminal:
      *** MEMORY ***
      Swap:           2.1G          0B        2.1G
               8192 M total memory
                176 M used memory
                163 M active memory
               7086 M free memory
                  0 M buffer memory
                928 M swap cache
               2048 M total swap
                  0 M used swap
               2048 M free swap
      *** FILESYSTEM ***
      /var:
      445M    /var/
      251M    /var/cache
      247M    /var/cache/apt
      147M    /var/lib
      USB-Devices by-id:
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.3
      javascript:     8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        20284
      States:         15789
      Pending Updates: 0
      da ist aber einiges im Argen!
      ebenso hier
      sieht nach Ärger mit der Platte aus
      mehr weiß ich nicht
      ob das auch mit
      ein Problem mit Proxmox hatte,
      wäre zu prüfen
        ebenso hier
        mehr weiß ich nicht
        ob das auch mit
        wäre zu prüfen
        Kellerkind-86
        @homoran okay, danke.. ich versuch mal was herauszufinden. würde mich hier melden, sobald ich was herausgefunden habe..
        Gruß Marcell
        • K Kellerkind-86
          sorry. hier :
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
          tigger
          HOME=/home/tigger
          Desktop:
          Terminal:
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   8192 M total memory
                    176 M used memory
                    163 M active memory
                   7086 M free memory
                      0 M buffer memory
                    928 M swap cache
                   2048 M total swap
                      0 M used swap
                   2048 M free swap
          *** FILESYSTEM ***
          /var:
          445M    /var/
          251M    /var/cache
          247M    /var/cache/apt
          147M    /var/lib
          USB-Devices by-id:
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.3
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        20284
          States:         15789
          Pending Updates: 0
          Ro75R Offline
          Ro75R Offline
          Ro75
          [Thu Apr 17 15:12:45 2025] EXT4-fs (loop0): I/O error while writing superblock [Thu Apr 17 15:21:05 2025] EXT4-fs (dm-8): mounted filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1 r/w with ordered data mode. Quota mode: none. [Thu Apr 17 15:21:11 2025] EXT4-fs (dm-8): unmounting filesystem d4b19c32-f31a-4d8d-9ee9-cff3e02cebd1.
          Für mich eindeutig der Datenträger.
          Ro75.
          • Ro75R Ro75
            Ro75.
            Kellerkind-86
            @ro75 okay, damit hatte ich auch irgendwie probleme mit proxmox.. daraufhin hab ich alles neuaufgespielt und die backups wieder eingespielt.wie gehe ich da am besten vor ? um was herauszufinden ?
            Gruß Marcell
            Ro75R 1 Antwort Letzte Antwort
            • K Kellerkind-86
              Ro75R Offline
              Ro75R Offline
              Ro75
              Backup (falls gemeint) wird nicht reichen - da muss ein neuer Datenträger rein.
              Ro75.
              K 2 Antworten Letzte Antwort
              • Ro75R Ro75
                Ro75.
                Kellerkind-86
                @ro75 okay, dankeschön
                Gruß Marcell
                • Ro75R Ro75
                  Ro75.
                  Kellerkind-86
                  @ro75 so.. jetzt ne neue ssd drin. aber was sagen diese fehlermeldungen und wie kann ich sie beheben ?
                  ```bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   09:20:31 up 50 min,  0 user,  load average: 0.32, 0.26, 0.27
                  CPU threads: 4
                  Failed to query server: Unit dbus-org.freedesktop.timedate1.service failed to load properly, please adjust/correct and reload service manager: File exists
                  Failed to parse bus message: File exists
                  tigger
                  HOME=/home/tigger
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:            8.6G        123M        7.4G         77K        1.0G        8.5G
                  Swap:           2.1G          0B        2.1G
                  Total:           10G        123M        9.6G
                           8192 M total memory
                            118 M used memory
                            120 M active memory
                            874 M inactive memory
                           7099 M free memory
                              0 M buffer memory
                            974 M swap cache
                           2048 M total swap
                              0 M used swap
                           2048 M free swap
                  top - 09:20:32 up 50 min,  0 user,  load average: 0.30, 0.26, 0.27
                  Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
                  MiB Mem :   8192.0 total,   7098.2 free,    119.6 used,    974.3 buff/cache
                  MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   8072.4 avail Mem
                  * systemd-timedated.service          masked failed failed systemd-timedated.service
                  12 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--103--disk--0 ext4    25G  7.0G   17G  31% /
                  tmpfs                            tmpfs  3.2G   72K  3.2G   1% /run
                  [Tue Apr 22 16:56:52 2025] EXT4-fs (dm-1): mounted filesystem 208af763-f721-4927-a9c2-c7e1b74a0dd0 ro with ordered data mode. Quota mode: none.
                  [Tue Apr 22 16:56:53 2025] EXT4-fs (dm-1): re-mounted 208af763-f721-4927-a9c2-c7e1b74a0dd0 r/w. Quota mode: none.
                  [Tue Apr 22 17:13:45 2025] EXT4-fs (loop0): mounted filesystem 43d49d75-3d08-481b-b503-83b22a667290 r/w with ordered data mode. Quota mode: none.
                  [Tue Apr 22 17:16:34 2025] EXT4-fs (loop0): unmounting filesystem 43d49d75-3d08-481b-b503-83b22a667290.
                  [Tue Apr 22 17:17:05 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 50 higher than expected, please wait.
                  [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): I/O error while writing superblock
                  [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): mount failed
                  [Tue Apr 22 17:19:42 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
                  [Tue Apr 22 17:20:40 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
                  [Tue Apr 22 17:21:21 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 66 higher than expected, please wait.
                  [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): I/O error while writing superblock
                  [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): mount failed
                  [Tue Apr 22 18:30:44 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                  [Tue Apr 22 18:31:27 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
                  [Tue Apr 22 18:31:27 2025] EXT4-fs (loop0): I/O error while writing superblock
                  [Tue Apr 22 22:41:44 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
                  [Tue Apr 22 22:43:26 2025] EXT4-fs warning (device loop1): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                  [Tue Apr 22 22:44:09 2025] EXT4-fs warning (device loop1): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
                  [Tue Apr 22 22:44:09 2025] EXT4-fs (loop1): I/O error while writing superblock
                  [Tue Apr 22 22:57:45 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
                  [Tue Apr 22 23:12:23 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
                  [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): I/O error while writing superblock
                  [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): mount failed
                  [Wed Apr 23 01:49:04 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 01:49:36 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
                  [Wed Apr 23 01:50:25 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 01:51:19 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 01:51:34 2025] EXT4-fs (dm-17): unmounting filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9.
                  [Wed Apr 23 01:53:09 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 07:23:44 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 07:23:57 2025] EXT4-fs (dm-18): unmounting filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d.
                  [Wed Apr 23 07:24:04 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
                  [Wed Apr 23 08:29:19 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
                  [Wed Apr 23 08:29:34 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
                  /      /dev/mapper/pve-vm--103--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  497M    /var/
                  282M    /var/cache
                  278M    /var/cache/apt
                  202M    /var/cache/apt/archives
                  147M    /var/lib
                  USB-Devices by-id:
                  HINT:
                  tcp
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/nodejs         v20.19.1
                  /usr/bin/node           v20.19.1
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Installed: 20.19.1-1nodesource1
                    Candidate: 20.19.1-1nodesource1
                    Version table:
                   *** 20.19.1-1nodesource1 1001
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 601)
                  admin:          7.6.3
                  javascript:     8.8.3
                  Adapter State
                    system.adapter.dwd.0                    : dwd                   : IO-Broker                                -  enabled
                    system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
                    system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                -  enabled
                  + instance is alive
                  Objects and States
                  Objects:        19956
                  States:         15607
                  Hit:4 https://repo.mosquitto.org/debian bookworm InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        1664487    155/mosquitto
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1664324    1/init
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1664587    313/master
                  tcp6       0      0 :::1883                 :::*                    LISTEN      105        1664488    155/mosquitto
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1663846    1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          1662748    1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1664588    313/master
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1664325    1/init
                  udp6       0      0 :::111                  :::*                                0          1661881    1/init
                  2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.bluelink.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.evcc.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                  2025-04-23 06:39:47.921  - info: host.IO-Broker All instances are stopped.
                  2025-04-23 06:39:48.054  - warn: host.IO-Broker instance system.adapter.telegram.0 terminated due to SIGKILL
                  2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.telegram.0 terminated with code null ()
                  2025-04-23 06:39:48.055  - info: host.IO-Broker All instances are stopped.
                  2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.echarts.0 terminated due to SIGKILL
                  2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.echarts.0 terminated with code null ()
                  2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.text2command.0 terminated due to SIGKILL
                  2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.text2command.0 terminated with code null ()
                  2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.web.0 terminated due to SIGKILL
                  2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.web.0 terminated with code null ()
                  2025-04-23 06:39:48.060  - warn: host.IO-Broker instance system.adapter.web.1 terminated due to SIGKILL
                  2025-04-23 06:39:48.060  - info: host.IO-Broker instance system.adapter.web.1 terminated with code null ()
                  2025-04-23 06:39:48.060  - info: host.IO-Broker All instances are stopped.
                  2025-04-23 06:39:48.124  - info: host.IO-Broker terminated
                  Gruß Marcell
                  • K Kellerkind-86
                    ```bash
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 4
                    tigger
                    HOME=/home/tigger
                    Desktop:
                    Terminal:
                    *** MEMORY ***
                    Swap:           2.1G          0B        2.1G
                             8192 M total memory
                              118 M used memory
                              120 M active memory
                             7099 M free memory
                                0 M buffer memory
                              974 M swap cache
                             2048 M total swap
                                0 M used swap
                             2048 M free swap
                    *** FILESYSTEM ***
                    /var:
                    497M    /var/
                    282M    /var/cache
                    278M    /var/cache/apt
                    147M    /var/lib
                    USB-Devices by-id:
                    HINT:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.3
                    javascript:     8.8.3
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        19956
                    States:         15607
                    Pending Updates: 0
                    *** BASE SYSTEM *** Failed to query system properties: Connection timed out
                    Das ist schon der erste Fehler. Da kann iob diag schon nicht die grundlegenden Systeminformationen abrufen.
                    Hat mit dem ioBroker nix zu tun.
                    Ist was mit dem Dateisystem.
                    Zu LXCs kann ich aber weiter nix sagen, muss dir wer anders helfen.
                      CodierknechtC Offline
                      Codierknecht
                      @thomas-braun sagte in Iobroker Oberfläche nicht mehr nutzbar:
                      @Kellerkind-86
                      Was hast Du da für ein Template verwendet? Das Standard-Debian12 von Proxmox?
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                        Kellerkind-86
                        @codierknecht
                        tigger@IO-Broker:~$ lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Debian
                        Description: Debian GNU/Linux 12 (bookworm)
                        Release: 12
                        Codename: bookworm
                        tigger@IO-Broker:~$
                        genau.
                        echt mal komisch
                        Gruß Marcell
                        • K Kellerkind-86
                          @codierknecht
                          Release: 12
                          Codename: bookworm
                          tigger@IO-Broker:~$
                          genau.
                          echt mal komisch
                          Codierknecht
                          @kellerkind-86
                          Also ich nehme dieses Template:
                          Baue damit den LXC (ohne Desktop oder sonstigen Firlefanz) und installiere ioBroker mit dem Einzeiler.
                          • CodierknechtC Codierknecht
                            @kellerkind-86
                            Kellerkind-86
                            @codierknecht okay, ich werde es nochmal heute abend machen.. ja.. iobroker hab ich auch so installiert.
                            Gruß Marcell
                              @kellerkind-86
                              Kellerkind-86
                              @codierknecht okay, hat leider etwas länger gedauert.. jetzt sollte es laufen.. oder ?
                              ```bash
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                               Static hostname: IO-Broker
                                     Icon name: computer-container
                                       Chassis: container ☐
                                Virtualization: lxc
                                        Kernel: Linux 6.8.12-9-pve
                                  Architecture: x86-64
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                               23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                              CPU threads: 4
                                             Local time: Tue 2025-05-06 23:34:57 CEST
                                         Universal time: Tue 2025-05-06 21:34:57 UTC
                                               RTC time: n/a
                                            NTP service: inactive
                                        RTC in local TZ: no
                              tigger
                              HOME=/home/tigger
                              GROUPS=tigger sudo users iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            8.6G        2.8G        4.6G        139K        1.2G        5.8G
                              Swap:           2.1G          0B        2.1G
                              Total:           10G        2.8G        6.8G
                              Active iob-Instances:   42
                                       8192 M total memory
                                       2641 M used memory
                                       2538 M active memory
                                        994 M inactive memory
                                       4398 M free memory
                                          0 M buffer memory
                                       1151 M swap cache
                                       2048 M total swap
                                          0 M used swap
                                       2048 M free swap
                              top - 23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                              Tasks:  72 total,   1 running,  71 sleeping,   0 stopped,   0 zombie
                              %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :   8192.0 total,   4396.9 free,   2643.6 used,   1151.6 buff/cache
                              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5548.4 avail Mem
                              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                              1 loaded units listed.
                              dmesg: read kernel buffer failed: Operation not permitted
                              *** FILESYSTEM ***
                              /dev/mapper/pve-vm--174--disk--0 ext4       16G  6.4G  8.5G  44% /
                              udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                              tmpfs                            tmpfs     3.2G  132K  3.2G   1% /run
                              tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                              /var:
                              421M    /var/
                              250M    /var/cache
                              246M    /var/cache/apt
                              170M    /var/cache/apt/archives
                              147M    /var/lib
                              28M     /opt/iobroker/backups/
                              USB-Devices by-id:
                              HINT:
                              tcp
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 2626)
                              admin:          7.6.3
                              javascript:     8.8.3
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
                              + system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
                              + system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
                              + system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
                              + system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
                              + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
                              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
                              + system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
                              + system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                -  enabled
                              + system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
                              + system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
                              + system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                              + system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
                              + system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
                              + system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
                              + system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
                              + system.adapter.onvif.0                  : onvif                 : IO-Broker                                -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                              + system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
                              + system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
                              + system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
                              + system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
                              + system.adapter.shelly.1                 : shelly                : IO-Broker                                -  enabled, port: 1882, bind: 0.0.0.0
                              + system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
                              + system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
                              + system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
                              + system.adapter.unifi.0                  : unifi                 : IO-Broker                                -  enabled
                              + system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
                              + system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                -  enabled
                              + system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
                              + system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
                              + instance is alive
                              Objects and States
                              Objects:        20154
                              States:         16138
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45754451   1/init
                              tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       45919336   4914/io.hm-rpc.0
                              tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       45921323   4929/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       45919548   4944/io.shelly.1
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        45916862   4883/mosquitto
                              tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       45797552   3670/io.wiffi-wz.0
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45777028   1847/iobroker.js-co
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       45777033   1847/iobroker.js-co
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          45753745   294/master
                              tcp6       0      0 :::20002                :::*                    LISTEN      1001       45796519   3655/io.web.1
                              tcp6       0      0 :::111                  :::*                    LISTEN      0          45754453   1/init
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          45753746   294/master
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          45752838   1/init
                              tcp6       0      0 :::1883                 :::*                    LISTEN      105        45916863   4883/mosquitto
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       45795819   3685/io.ws.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45794286   3640/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       45777930   1866/io.admin.0
                              tcp6       0      0 :::61991                :::*                    LISTEN      1001       45779797   2171/io.harmony.0
                              udp        0      0 0.0.0.0:57269           0.0.0.0:*                           1001       45786621   2607/io.shelly.0
                              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          45754452   1/init
                              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       45779798   2171/io.harmony.0
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       45783545   2607/io.shelly.0
                              udp6       0      0 :::111                  :::*                                0          45754454   1/init
                              2025-05-06 23:31:21.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                              2025-05-06 23:31:30.051  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                              2025-05-06 23:32:51.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                              2025-05-06 23:33:15.985  - info: admin.0 (1866) <== Disconnect system.user.admin from ::ffff:192.168.178.25 javascript
                              2025-05-06 23:33:16.503  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                              2025-05-06 23:34:21.195  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                              danke
                              Gruß Marcell
                              • K Kellerkind-86
                                ```bash
                                Script v.2025-02-23
                                *** BASE SYSTEM ***
                                  Virtualization: lxc
                                OS is similar to:
                                Docker          : false
                                Kernel          : x86_64
                                Userland        : 64 bit
                                CPU threads: 4
                                                 RTC time: n/a
                                          RTC in local TZ: no
                                tigger
                                HOME=/home/tigger
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           2.1G          0B        2.1G
                                         8192 M total memory
                                         2641 M used memory
                                         4398 M free memory
                                            0 M buffer memory
                                         1151 M swap cache
                                         2048 M total swap
                                            0 M used swap
                                         2048 M free swap
                                *** FILESYSTEM ***
                                /var:
                                421M    /var/
                                250M    /var/cache
                                246M    /var/cache/apt
                                147M    /var/lib
                                USB-Devices by-id:
                                HINT:
                                tcp
                                zigbee.X
                                Extended Pan ID:
                                *** MASKED ***
                                Pan ID:
                                *** MASKED ***
                                Channel:
                                *** MASKED ***
                                Network Key:
                                *** MASKED ***
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.6.3
                                javascript:     8.8.3
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        20154
                                States:         16138
                                Pending Updates: 0
                                danke
                                Codierknecht
                                @kellerkind-86
                                Sieht doch prinzipiell ganz gut aus.
                                Das kannst Du uns hoffentlich sagen ;-)
                                Was es mit dem
                                auf sich hat, kann vielleicht @Thomas-Braun sagen. Ich vermute ein Rechte-Problem.
                                Achtung: admin.0 und onvif.0 verwenden beide Port 8081. Das könnte zu Problemen führen.
                                  @kellerkind-86
                                  Was es mit dem
                                  @codierknecht sagte in Iobroker Oberfläche nicht mehr nutzbar:
                                  Der user darf nicht in den Kernelringpuffer des Hosts schauen.
                                  Ist bei einem LXC ja auch Sinn und Zweck, das solche Kisten weggekapselt sind.
                                    Codierknecht
                                    Und? Kann das Probleme bereiten oder kann das ignoriert werden?
                                    Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                      @codierknecht
                                      Kann bei LXCs ignoriert werden, das ist halt 'works as intended'.
                                        Meister MopperM Offline
                                        Meister Mopper
                                        Als der ioBroker bei mir in einem LXC lief, kam natürlich auch diese Fehlermeldung. Ich habe sie ignoriert und gut war.
                                        Jetzt läuft der ioBroker in einer VM und die Meldung kommt natürlich nicht mehr.
                                        @Thomas-Braun
                                        Vielleicht kann das Skript ja so angepasst werden, dass die Prüfung bei einem Container nicht durchgeführt wird.
                                        Das ist aus meiner Sicht zumindest eine kosmetische Lösung.
                                        Proxmox und HA ...
                                          @Thomas-Braun
                                          @meister-mopper
                                          Ich halte nix von kosmetischen Eingriffen.
                                          Die Meldung kommt ja zu Recht. Die Bewertung obliegt dann demjenigen, der das Log interpretiert.
