  4. Tester für Zigbee Adapter 2.0.x gesucht
zigbee 2.0.1
529 Beiträge 51 Kommentatoren 147.5k Aufrufe 41 Beobachtet
  • DuffyD Duffy
    ich habe soeben auch mal auf meinen Test Pi den Zigbee Adapter 2.0.5 installiert.
    Hier sind nur 3 Geräte gekoppelt aber ich werde reich mit Warnungen bedacht mit denen ich so gar nichts anfangen kann.
    Das sind die Warnungen:
    Log-Größe: 20.6 KB
    Zeit
    zigbee.0
    	2025-04-11 16:28:05.619	warn	ELEVATED:I02 (2ead) value generated '38.03' from device a4c13883edd22a61 for 'Humidity'
    zigbee.0
    	2025-04-11 16:28:05.619	warn	ELEVATED:I01 (2ead) message received '{"humidity":38.03}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:28:05.617	warn	ELEVATED:I02 (2ead) value generated '102' from device a4c13883edd22a61 for 'Link quality'
    zigbee.0
    	2025-04-11 16:28:05.617	warn	ELEVATED:I01 (2ead) message received '{"linkquality":102}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:28:05.616	warn	ELEVATED:I02 (2ea4) value generated '20.4' from device a4c13883edd22a61 for 'Temperature'
    zigbee.0
    	2025-04-11 16:28:05.615	warn	ELEVATED:I01 (2ea4) message received '{"temperature":20.4}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:28:05.614	warn	ELEVATED:I02 (2ea4) value generated '102' from device a4c13883edd22a61 for 'Link quality'
    zigbee.0
    	2025-04-11 16:28:05.612	warn	ELEVATED:I01 (2ea4) message received '{"linkquality":102}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:28:05.421	warn	ELEVATED:I01 (2ead) Zigbee Event of Type attributeReport from device 0xa4c13883edd22a61, incoming event: {"type":"attributeReport","data":{"measuredValue":3803},"linkquality":102,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":67,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-04-11 16:28:05.413	warn	ELEVATED:I01 (2ea4) Zigbee Event of Type attributeReport from device 0xa4c13883edd22a61, incoming event: {"type":"attributeReport","data":{"measuredValue":2040},"linkquality":102,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":66,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    admin.0
    	2025-04-11 16:28:03.193	info	==> Connected system.user.admin from ::ffff:192.168.178.116
    zigbee.0
    	2025-04-11 16:27:15.319	warn	ELEVATED:I02 (6aed) value generated '38.58' from device a4c13883edd22a61 for 'Humidity'
    zigbee.0
    	2025-04-11 16:27:15.319	warn	ELEVATED:I01 (6aed) message received '{"humidity":38.58}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:27:15.317	warn	ELEVATED:I02 (6aed) value generated '98' from device a4c13883edd22a61 for 'Link quality'
    zigbee.0
    	2025-04-11 16:27:15.316	warn	ELEVATED:I01 (6aed) message received '{"linkquality":98}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:27:15.310	warn	ELEVATED:I01 (6aed) Zigbee Event of Type attributeReport from device 0xa4c13883edd22a61, incoming event: {"type":"attributeReport","data":{"measuredValue":3858},"linkquality":98,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":65,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-04-11 16:26:35.234	warn	ELEVATED:I02 (ce59) value generated '39.12' from device a4c13883edd22a61 for 'Humidity'
    zigbee.0
    	2025-04-11 16:26:35.234	warn	ELEVATED:I01 (ce59) message received '{"humidity":39.12}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:26:35.232	warn	ELEVATED:I02 (ce59) value generated '94' from device a4c13883edd22a61 for 'Link quality'
    zigbee.0
    	2025-04-11 16:26:35.231	warn	ELEVATED:I01 (ce59) message received '{"linkquality":94}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:26:35.226	warn	ELEVATED:I01 (ce59) Zigbee Event of Type attributeReport from device 0xa4c13883edd22a61, incoming event: {"type":"attributeReport","data":{"measuredValue":3912},"linkquality":94,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":64,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-04-11 16:26:32.125	warn	ELEVATED:I02 (c235) value generated '72' from device a4c13855231a9ca2 for 'Link quality'
    zigbee.0
    	2025-04-11 16:26:32.125	warn	ELEVATED:I01 (c235) message received '{"linkquality":72}' from device a4c13855231a9ca2 type 'TS0001_fingerbot'
    zigbee.0
    	2025-04-11 16:26:32.123	warn	ELEVATED:NOCONV (c235) No converter available for 'TS0001_fingerbot' 'a4c13855231a9ca2' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2025-04-11 16:26:32.118	warn	ELEVATED:I01 (c235) Zigbee Event of Type attributeReport from device 0xa4c13855231a9ca2, incoming event: {"type":"attributeReport","data":{"65503":"�n\\/\u0013&o\\/\u0013�o\\/\u0013\u0000\u0000\u0000\u0000\u0011Yp\\/\u0012�p\\/\u0012\u0000\u0000\u0000\u0000\u0011���/\u0012"},"linkquality":72,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":183,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-04-11 16:26:31.986	warn	ELEVATED:I02 (c1a4) value generated '69' from device a4c13855231a9ca2 for 'Link quality'
    zigbee.0
    	2025-04-11 16:26:31.985	warn	ELEVATED:I01 (c1a4) message received '{"linkquality":69}' from device a4c13855231a9ca2 type 'TS0001_fingerbot'
    zigbee.0
    	2025-04-11 16:26:31.984	warn	ELEVATED:NOCONV (c1a4) No converter available for 'TS0001_fingerbot' 'a4c13855231a9ca2' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2025-04-11 16:26:31.972	warn	ELEVATED:I01 (c1a4) Zigbee Event of Type attributeReport from device 0xa4c13855231a9ca2, incoming event: {"type":"attributeReport","data":{"65503":"Q_\\/\u0013T`\\/\u0013�b\\/\u0012�b\\/\u0012\u0000\u0000\u0000\u0000\u0011\u0000\u0000\u0000\u0000\u0011\u0000\u0000\u0000\u0000\u0011\u0000\u0000\u0000\u0000\u0011\u0000\u0000\u0000\u0000\u0011\u001d\u0000\u0000\u0000\u0013Qn\\/\u0012�n\\/\u0013"},"linkquality":69,"groupID":0,"cluster":"genBasic","meta":{"zclTransactionSequenceNumber":182,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2025-04-11 16:26:25.218	warn	ELEVATED:I02 (a737) value generated '39.78' from device a4c13883edd22a61 for 'Humidity'
    zigbee.0
    	2025-04-11 16:26:25.217	warn	ELEVATED:I01 (a737) message received '{"humidity":39.78}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:26:25.215	warn	ELEVATED:I02 (a737) value generated '87' from device a4c13883edd22a61 for 'Link quality'
    zigbee.0
    	2025-04-11 16:26:25.214	warn	ELEVATED:I01 (a737) message received '{"linkquality":87}' from device a4c13883edd22a61 type 'LYWSD03MMC-z'
    zigbee.0
    	2025-04-11 16:26:25.208	warn	ELEVATED:I01 (a737) Zigbee Event of Type attributeReport from device 0xa4c13883edd22a61, incoming event: {"type":"attributeReport","data":{"measuredValue":3978},"linkquality":87,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":63,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    Das hier sind die Geräte:
    Da ich was Zigbee betrifft ein echter schisser bin, zumal ich auch nicht wirklich viel Ahnung davon habe, habe ich es erst mal , wie bereits erwähnt, auf dem Tes Pi installiert. Ich will vermeiden bei meinem aktuellen Aktiv System im dunklen zu stehen.
    Kann mir bitte jemand sagen was die Warnungen bedeuten und was ich dagegen tun kann?
    Es grüßt euch Duffy
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #278
    @duffy sagte in Tester für Zigbee Adapter 2.0.x gesucht:
    Log-Größe: 20.6 KB
    Zeit
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    admin.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    zigbee.0
    Es grüßt euch Duffy
    click mal auf die grünen bugs auf den Kacheln, dann sind die Meldungen auch weg.
    A.
    DuffyD 1 Antwort Letzte Antwort
    • T tom_33
      @asgothian Ich hoffe, ich habs richtig verstanden:
      Debugging über Kachel aktiviert
      1x Taste gedrückt
      Reconfigure angestossen
      Copy vom Fenster:
      0x04cf8cdf3c7c87f9 lumi.remote.b486opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7c87f9/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
      Im Protokoll gibts zwischen der Link quality folgende Zeile:
      ELEVATED:I01 (c426) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":84,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":225,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #279
      @tom_33 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
      1x Taste gedrückt
      Copy vom Fenster:
      Das deutet darauf hin das das Gerät sich nicht konfigurieren lassen will. Ich würde Dich bitten die Batterie (wenn er eine hat) heraus zu nehmen, die Knöpfe jeden einmal drücken, dann 60 sekunden warten, Batterien wieder rein und nochmal versuchen.
      A
      Nachtrag: zu der Meldung mit (c2426) muss es weitere Meldungen mit dem gleichen 'tag' geben. Bitte immer mit posten.
      • AsgothianA Asgothian
        @schranzer sagte in Tester für Zigbee Adapter 2.0.x gesucht:
        Wahrscheinlich bin ich hier falsch. Aber ich leg mal los.
        Ich habe einen SMLIGHT SLZB-06p10 und würde diesen gerne für ZigBee hernehmen auf einem Raspberry Pi 5. Ich bekomme den Adapter aber nicht zum laufen. liegt das daran, weil der Adapter nur den normalen SLZB-06/M unterstützt?
        Der sollte gehen, wenn du ihn korrekt einsetzt.
        A.
        Schranzer
        #280
        @asgothian Sry das ich nochmal dazwischen Grätsche. Aber könntest du mir die Settings sagen welche ich einstellen muss. Weil egal was ich einstelle er verbindet sich nicht.
        Vielen Dank im vorraus
        • S Schranzer
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          #281
          @schranzer Ich kann dir nicht sagen was du einstellen musst. Dazu hab ich zu wenig Informationen. Da musst du schon deutlich mehr Details liefern.
          A.
            1x Taste gedrückt
            Copy vom Fenster:
            A
            tom_33
            #282
            @asgothian Das ist der ganze Log nach dem die Batt. raus und wieder rein gegeben wurde. Die Link quality hab ich jetzt auf die Schnelle nicht rausgefiltert.
            2025-04-11 17:02:45.713	warn	DeviceConfigure:0x04cf8cdf3c7c87f9 lumi.remote.b486opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7c87f9/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
            zigbee.0
            	2025-04-11 17:02:02.724	warn	DeviceConfigure:0x04cf8cdf3c7c87f9 lumi.remote.b486opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7c87f9/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
            zigbee.0
            	2025-04-11 17:01:19.712	warn	ELEVATED:I02 (9cd6) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_3_single'
            zigbee.0
            	2025-04-11 17:01:19.711	warn	ELEVATED:I02 (9cd6) value generated '"button_3_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
            zigbee.0
            	2025-04-11 17:01:19.711	warn	ELEVATED:I01 (9cd6) message received '{"action":"button_3_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 17:01:19.709	warn	ELEVATED:I02 (9cd6) value generated '78' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 17:01:19.708	warn	ELEVATED:I01 (9cd6) message received '{"linkquality":78}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 17:01:19.703	warn	ELEVATED:I01 (9cd6) Zigbee Event of Type attributeReport from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"attributeReport","data":{"presentValue":1},"linkquality":78,"groupID":0,"cluster":"genMultistateInput","meta":{"zclTransactionSequenceNumber":1,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":3}
            zigbee.0
            	2025-04-11 16:57:44.289	warn	ELEVATED:I02 (533c) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.288	warn	ELEVATED:I01 (533c) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.278	warn	ELEVATED:I02 (533b) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.277	warn	ELEVATED:I01 (533b) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.277	warn	ELEVATED:I02 (533a) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.277	warn	ELEVATED:I01 (533a) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.276	warn	ELEVATED:I02 (5338) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.276	warn	ELEVATED:I01 (5338) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.276	warn	ELEVATED:I02 (5337) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.275	warn	ELEVATED:I01 (5337) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.275	warn	ELEVATED:I02 (5322) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.274	warn	ELEVATED:I01 (5322) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.265	warn	ELEVATED:I02 (5321) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.264	warn	ELEVATED:I01 (5321) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.264	warn	ELEVATED:I02 (5320) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.264	warn	ELEVATED:I01 (5320) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.263	warn	ELEVATED:I02 (531e) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.263	warn	ELEVATED:I01 (531e) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.262	warn	ELEVATED:I02 (5312) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.262	warn	ELEVATED:I01 (5312) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.252	warn	ELEVATED:I01 (533c) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.251	warn	ELEVATED:I01 (533b) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.250	warn	ELEVATED:I01 (533a) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.249	warn	ELEVATED:I01 (5338) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.247	warn	ELEVATED:I01 (5337) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.237	warn	ELEVATED:I02 (5311) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.236	warn	ELEVATED:I01 (5311) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.235	warn	ELEVATED:I02 (530a) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.234	warn	ELEVATED:I01 (530a) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.226	warn	ELEVATED:I01 (5322) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.225	warn	ELEVATED:I01 (5321) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.224	warn	ELEVATED:I01 (5320) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.223	warn	ELEVATED:I01 (531e) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.215	warn	ELEVATED:I02 (5308) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.215	warn	ELEVATED:I01 (5308) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.210	warn	ELEVATED:I01 (5312) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.209	warn	ELEVATED:I01 (5311) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.202	warn	ELEVATED:I01 (530a) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.200	warn	ELEVATED:I01 (5308) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            zigbee.0
            	2025-04-11 16:57:44.192	warn	ELEVATED:I02 (52fb) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_3_single'
            zigbee.0
            	2025-04-11 16:57:44.192	warn	ELEVATED:I02 (52fb) value generated '"button_3_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
            zigbee.0
            	2025-04-11 16:57:44.192	warn	ELEVATED:I01 (52fb) message received '{"action":"button_3_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.191	warn	ELEVATED:I02 (52fb) value generated '72' from device 04cf8cdf3c7c87f9 for 'Link quality'
            zigbee.0
            	2025-04-11 16:57:44.190	warn	ELEVATED:I01 (52fb) message received '{"linkquality":72}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
            zigbee.0
            	2025-04-11 16:57:44.188	warn	ELEVATED:I01 (52fb) Zigbee Event of Type commandStep from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"commandStep","data":{"stepmode":1,"stepsize":85,"transtime":7},"linkquality":72,"groupID":0,"cluster":"genLevelCtrl","meta":{"zclTransactionSequenceNumber":0,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
            BTW: So schauts Innen aus:
            • T tom_33
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              zigbee.0
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #283
              @tom_33 welche knöpfe hast du gedrückt ? Laut Log kommt nur vom Button 3 etwas an.
              A.
                A.
                tom_33
                #284
                @asgothian Oh, sorry! Nochmal mit allen Tasten.
                zigbee.0
                	2025-04-11 17:16:46.651	warn	DeviceConfigure:0x04cf8cdf3c7c87f9 lumi.remote.b486opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7c87f9/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
                zigbee.0
                	2025-04-11 17:16:03.662	warn	DeviceConfigure:0x04cf8cdf3c7c87f9 lumi.remote.b486opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7c87f9/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'MAC transaction expired' (240))
                javascript.0
                	2025-04-11 17:15:27.753	error	script.js.Meine_Skripte.BA_Volumio: Error: getaddrinfo ENOTFOUND volumio.local at GetAddrInfoReqWrap.onlookupall [as oncomplete] (node:dns:120:26) { errno: -3008, code: 'ENOTFOUND', syscall: 'getaddrinfo', hostname: 'volumio.local'}
                zigbee.0
                	2025-04-11 17:15:22.682	warn	ELEVATED:I02 (79b4) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_4_single'
                zigbee.0
                	2025-04-11 17:15:22.681	warn	ELEVATED:I02 (79b4) value generated '"button_4_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
                zigbee.0
                	2025-04-11 17:15:22.681	warn	ELEVATED:I01 (79b4) message received '{"action":"button_4_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:22.680	warn	ELEVATED:I02 (79b4) value generated '81' from device 04cf8cdf3c7c87f9 for 'Link quality'
                zigbee.0
                	2025-04-11 17:15:22.679	warn	ELEVATED:I01 (79b4) message received '{"linkquality":81}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:22.676	warn	ELEVATED:I01 (79b4) Zigbee Event of Type attributeReport from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"attributeReport","data":{"presentValue":1},"linkquality":81,"groupID":0,"cluster":"genMultistateInput","meta":{"zclTransactionSequenceNumber":5,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":4}
                zigbee.0
                	2025-04-11 17:15:21.733	warn	ELEVATED:I02 (7600) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_3_single'
                zigbee.0
                	2025-04-11 17:15:21.733	warn	ELEVATED:I02 (7600) value generated '"button_3_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
                zigbee.0
                	2025-04-11 17:15:21.733	warn	ELEVATED:I01 (7600) message received '{"action":"button_3_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:21.732	warn	ELEVATED:I02 (7600) value generated '111' from device 04cf8cdf3c7c87f9 for 'Link quality'
                zigbee.0
                	2025-04-11 17:15:21.731	warn	ELEVATED:I01 (7600) message received '{"linkquality":111}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:21.728	warn	ELEVATED:I01 (7600) Zigbee Event of Type attributeReport from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"attributeReport","data":{"presentValue":1},"linkquality":111,"groupID":0,"cluster":"genMultistateInput","meta":{"zclTransactionSequenceNumber":4,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":3}
                zigbee.0
                	2025-04-11 17:15:20.824	warn	ELEVATED:I02 (7273) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_2_single'
                zigbee.0
                	2025-04-11 17:15:20.824	warn	ELEVATED:I02 (7273) value generated '"button_2_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
                zigbee.0
                	2025-04-11 17:15:20.824	warn	ELEVATED:I01 (7273) message received '{"action":"button_2_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:20.823	warn	ELEVATED:I02 (7273) value generated '81' from device 04cf8cdf3c7c87f9 for 'Link quality'
                zigbee.0
                	2025-04-11 17:15:20.822	warn	ELEVATED:I01 (7273) message received '{"linkquality":81}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:20.820	warn	ELEVATED:I01 (7273) Zigbee Event of Type attributeReport from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"attributeReport","data":{"presentValue":1},"linkquality":81,"groupID":0,"cluster":"genMultistateInput","meta":{"zclTransactionSequenceNumber":3,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":2}
                zigbee.0
                	2025-04-11 17:15:19.971	warn	ELEVATED:I02 (6f18) value generated 'true' from device 04cf8cdf3c7c87f9 for 'button_1_single'
                zigbee.0
                	2025-04-11 17:15:19.970	warn	ELEVATED:I02 (6f18) value generated '"button_1_single"' from device 04cf8cdf3c7c87f9 for 'Triggered action (e.g. a button click)'
                zigbee.0
                	2025-04-11 17:15:19.970	warn	ELEVATED:I01 (6f18) message received '{"action":"button_1_single"}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:19.968	warn	ELEVATED:I02 (6f18) value generated '69' from device 04cf8cdf3c7c87f9 for 'Link quality'
                zigbee.0
                	2025-04-11 17:15:19.968	warn	ELEVATED:I01 (6f18) message received '{"linkquality":69}' from device 04cf8cdf3c7c87f9 type 'WXCJKG12LM'
                zigbee.0
                	2025-04-11 17:15:19.960	warn	ELEVATED:I01 (6f18) Zigbee Event of Type attributeReport from device 0x04cf8cdf3c7c87f9, incoming event: {"type":"attributeReport","data":{"presentValue":1},"linkquality":69,"groupID":0,"cluster":"genMultistateInput","meta":{"zclTransactionSequenceNumber":2,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                • T tom_33
                  zigbee.0
                  zigbee.0
                  javascript.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #285
                  zigbee.0
                  zigbee.0
                  javascript.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  zigbee.0
                  Jetzt sollten alle 'single' clicks im ioBroker ankommen. Bitte das gleiche mit den Doubleclick und tripleclick probieren, und besser einen Screenshot vom Debug Interface zeigen. Dabei die Meldungen 'zusammenfassen' lassen.
                  A.
                    zigbee.0
                    zigbee.0
                    javascript.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    zigbee.0
                    A.
                    tom_33
                    schrieb am zuletzt editiert von tom_33
                    #286
                    @asgothian Double: Error Fenster:
                    ID	Zigbee Payload	 	State Payload	ID	value	Flags
                    5dff	{"type":"attributeReport", "data":{"presentValue":2}, "linkquality":81, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":9, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":4}		{"action":"button_4_double"}	button_4_double	true	SUCCESS
                    	{"action":"button_4_double"}	action	button_4_double	SUCCESS
                    	{"linkquality":81}	link_quality	81	SUCCESS
                    5a30	{"type":"attributeReport", "data":{"presentValue":2}, "linkquality":93, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":8, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":3}		{"action":"button_3_double"}	button_3_double	true	SUCCESS
                    	{"action":"button_3_double"}	action	button_3_double	SUCCESS
                    	{"linkquality":93}	link_quality	93	SUCCESS
                    5634	{"type":"attributeReport", "data":{"presentValue":2}, "linkquality":78, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":7, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":2}		{"action":"button_2_double"}	button_2_double	true	SUCCESS
                    	{"action":"button_2_double"}	action	button_2_double	SUCCESS
                    	{"linkquality":78}	link_quality	78	SUCCESS
                    525b	{"type":"attributeReport", "data":{"presentValue":2}, "linkquality":54, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":6, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"action":"button_1_double"}	button_1_double	true	SUCCESS
                    	{"action":"button_1_double"}	action	button_1_double	SUCCESS
                    	{"linkquality":54}	link_quality	54	SUCCESS
                    Triple mit der selben Errormeldung im Fenster
                    13c2	{"type":"attributeReport", "data":{"presentValue":3}, "linkquality":87, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":13, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":4}		{"action":"button_4_triple"}	button_4_triple	true	SUCCESS
                    	{"action":"button_4_triple"}	action	button_4_triple	SUCCESS
                    	{"linkquality":87}	link_quality	87	SUCCESS
                    0f73	{"type":"attributeReport", "data":{"presentValue":3}, "linkquality":81, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":12, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":3}		{"action":"button_3_triple"}	button_3_triple	true	SUCCESS
                    	{"action":"button_3_triple"}	action	button_3_triple	SUCCESS
                    0b07	{"type":"attributeReport", "data":{"presentValue":3}, "linkquality":72, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":11, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":2}		{"action":"button_2_triple"}	button_2_triple	true	SUCCESS
                    	{"action":"button_2_triple"}	action	button_2_triple	SUCCESS
                    	{"linkquality":72}	link_quality	72	SUCCESS
                    0607	{"type":"attributeReport", "data":{"presentValue":3}, "linkquality":87, "groupID":0, "cluster":"genMultistateInput", "meta":{"zclTransactionSequenceNumber":10, "frameControl":{"frameType":0, "manufacturerSpecific":false, "direction":1, "disableDefaultResponse":true, "reservedBits":0}}, "endpoint_id":1}		{"action":"button_1_triple"}	button_1_triple	true	SUCCESS
                    	{"action":"button_1_triple"}	action	button_1_triple	SUCCESS
                    Soweit ich das kapiere, kommt alles richtig an. Auch die schaltbaren Geräte reagieren nicht mehr. Und Hold funktioniert wieder!
                    Dann war das entfernen der Batterie mit längerem Warten das Ausschlaggebende!? Ich habe schon gestern die Batt. getauscht, aber nicht so lange gewartet.
                    Alle abhängigen Scripte wieder Aktiviert und alles läuft! Hurra!!
                    Herzlichen Dank für Alles!!!
                      Log-Größe: 20.6 KB
                      Zeit
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      admin.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      zigbee.0
                      Es grüßt euch Duffy
                      A.
                      DuffyD Online
                      DuffyD Online
                      Duffy
                      #287
                      A.
                      Danke dir.
                      Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
                      Node.js: v22.23.2
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                        A.
                        Schranzer
                        #288
                        @asgothian Also ich habe wie gesagt den SMLIGHT SLZB-06p10. Dann habe ich auf einem Raspberry Pi 5 den Zigbee Adapter mit der Github Version 3.0.0 installiert (neu). Alles was IoBroker betrifft ist auf dem neusten Stand, da es eine Neuinstallation ist.
                        Ich komme auf die Homepage des SMLIGHT SLZB-06p10 und kann dort diese Ip auslesen mit dem Port:tcp://192.168.188.123:6638
                        Ich habe verstanden das ich diese ipadresse mit Port in Com Anschluss rein machen muss und dann unten eigentlich die Hardware auswählen muss.
                        Der SLZB-06p10 hat glaub ich einen Texas Instrument Chip dementsprechend müsse das so doch passen oder? Weil er findet ihn einfach nicht.
                        Brauchst du sonst noch Infos? VG
                        • S Schranzer
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #289
                          • Was passiert wenn du auf den Button 'test port' clickst. (weiter unten in der Konfiguration ist ein Log-Auszug. Diesen posten
                          • Wenn 'test port' erfolgreich ist: Was passiert wenn du auf 'start stop' clickst (auch wieder Log Auszug aus dem Log posten - ggf. warten bis eine endgültige Nachricht kommt.
                          A.
                          D S 2 Antworten Letzte Antwort
                          • T tom_33
                            @rushmed Ich habe den Taster mehrmals gelöscht und angelernt. Sogar die "Empfänger" resetet. Die bleiben hartnäckig zusammen. Aber ich werde das "Rezept" von asgothian durcharbeiten. Danke
                            dimaiv
                            schrieb am zuletzt editiert von dimaiv
                            #290
                            @tom_33
                            Ich habe oben schon geschrieben,
                            bei dem Taster (Opple) Reconfiguration funktioniert nur mit mehrmals klicken auf die Reset Taste, nicht auf eine von vier vorderen.
                            Und es gibt noch ein Datenpunkt Operation Mode. Da muss "Command" stehen.
                            Wichtig: beim Anlernen, nach Interview , Reset Taste weiter klicken bis Meldung kommt: Konfiguration erfolgreich...
                            ioBroker- NUC8i3 / Proxmox / VM
                            Node.js v22.21.0
                            NPM v10.9.4
                            JS controller 7.1.0
                            Admin 7.7.20
                            ZigBee Adapter 3.3.1alpha.0
                            Zigbee LAN Gateway CC2652P
                            Zigbee Firmware 20250321
                              A.
                              dimaiv
                              #291
                              @asgothian
                              Zur Info:
                              Ich habe mehrere Opple Taster da, die funktionieren mit 3.0.0 und früheren Versionen einwandfrei.
                              Node.js v22.21.0
                              NPM v10.9.4
                              JS controller 7.1.0
                              Admin 7.7.20
                              • D dimaiv
                                @tom_33
                                tom_33
                                #292
                                @dimaiv Vielen Dank für den Tipp. Mein zweiter Opple, welcher genauso alle Zigbees Steckdosen und Lampen gekapert hat, konnte ich mit dem längeren entfernen der Batterie wieder zähmen. Geprüft habe ich ihn, mit der oben angeführten Angaben von asgothian, trotzdem. Von den 1-Taster Aqara wird die Hold Funktion noch nicht ausgewertet. Ich hoffe, dieselbe Prozedur hilft hier auch.
                                Bei "Command" steht bei mir in der Spalte "Wert" nix. In der Spalte "Name" : Operation mode, select "command" to enable bindings (wake up the device before changing modes!)
                                  A.
                                  Schranzer
                                  #293
                                  @asgothian
                                  Zur ersten Frage, das ist die Ausgabe, wenn ich auf Test Port drücke:
                                  attempting dns lookup for 192.168.188.123
                                  dns lookup for tcp://192.168.188.123:6638 produced 192.168.188.123
                                  connected successfully to connect to 192.168.188.123 port 6638
                                  Zur zweiten Frage, das ist die Ausgabe, wenn ich auf Start/Stop drücke:
                                  overriding zigbee options with:
                                  extPanID : b574a814e360b356
                                  panID : 820
                                  channel : 11
                                  port : tcp://192.168.188.123:6638
                                  adapterType : zstack
                                  baudRate : 115200
                                  precfgkey : 01030507090B0D0F00020406080A0C0D
                                  flowCTRL : false
                                  Starting Adapter npm ...
                                  Installed Version: ioBroker/ioBroker.zigbee (Converters 23.25.0 Herdsman 3.5.1)
                                  Starting zigbee-herdsman...
                                  Unable to obtain herdsman settings
                                  Starting zigbee-herdsman problem : Error while opening socket
                                  Error herdsman start
                                  Viele Grüße
                                  • S Schranzer
                                    @asgothian
                                    panID : 820
                                    channel : 11
                                    baudRate : 115200
                                    flowCTRL : false
                                    Viele Grüße
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #294
                                    @schranzer die zigbee Firmware läuft auf deinem Netzwerk Koordinator nicht. Bitte hart zurücksetzen (Strom ab 30 sek. Warten, Strom an und neu versuchen das zigbee subsystem zu starten.
                                    A.
                                      A.
                                      Schranzer
                                      schrieb am zuletzt editiert von Schranzer
                                      #295
                                      @asgothian Ich habe das Problem gelöst.
                                      Lösungsweg:
                                      • Ich habe den SMLIGHT SLZB-06p10 komplett neu aufgesetzt, mit der aller neuesten Dev-Version v2.8.2.dev3 (Diese hat deutlich mehr Einstellung Funktionen als die alte)
                                      • Typ: Für den SMLIGHT SLZB-06p10 "Ti" einstellen bei Hardware
                                      • PanID: 13410
                                      • Channel: 11
                                      • COM Anschluss: tcp://EIGENEIP:6638
                                      • start Zigbee network automatically Hacken aktiv
                                      • flow control Hacken aktiv (bin mir nicht sicher was es macht)
                                      Ich habe zuerst den SMLIGHT SLZB-06p10 aufgesetzt das er bereit ist und DANN den Zigbee Adapter eingeschalten (welcher schon fertig konfiguriert war).
                                      Und noch mal danke für deine Hilfe :)!
                                      • S Schranzer
                                        Lösungsweg:
                                        • PanID: 13410
                                        • Channel: 11
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #296
                                        In deinem Fall: Nichts. Dieser Haken ist nur bei USB Kommunikation notwendig.
                                        A.
                                          martinschm
                                          schrieb am zuletzt editiert von martinschm
                                          #297
                                          ich hab die Tage auf Zigbee 2 upgedatet.
                                          Heute kam erst die Meldung das einige Geräte offline sind, komischerweise alles Geräte mit 230V
                                          Und jetzt bekam ich im Adapter erst eine Fehlermeldung als ich das pairing aktivieren wollte und dann das der Adapter ständig abstürzt.
                                          Im Log steht das hier
                                          zigbee.0
                                          2025-04-14 18:52:47.993	info	terminating
                                          zigbee.0
                                          2025-04-14 18:52:47.953	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                                          zigbee.0
                                          2025-04-14 18:52:47.383	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          zigbee.0
                                          2025-04-14 18:52:47.381	info	terminating
                                          zigbee.0
                                          2025-04-14 18:52:47.380	info	Saved local configuration data
                                          zigbee.0
                                          2025-04-14 18:52:47.378	info	local config saved
                                          zigbee.0
                                          2025-04-14 18:52:47.376	info	cleaned everything up...
                                          zigbee.0
                                          2025-04-14 18:52:47.373	error	undefined
                                          zigbee.0
                                          2025-04-14 18:52:47.372	error	unhandled promise rejection: undefined
                                          zigbee.0
                                          2025-04-14 18:52:47.372	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          zigbee.0
                                          2025-04-14 18:52:47.369	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                                          zigbee.0
                                          2025-04-14 18:52:47.321	info	Unable to obtain herdsman settings
                                          zigbee.0
                                          2025-04-14 18:52:20.699	info	Starting Zigbee-Herdsman
                                          zigbee.0
                                          2025-04-14 18:52:20.696	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.1)
                                          zigbee.0
                                          2025-04-14 18:52:20.642	info	Starting Adapter npm ...
                                          zigbee.0
                                          2025-04-14 18:52:20.640	info	--- creating device debug ---
                                          zigbee.0
                                          2025-04-14 18:52:20.635	info	delete old Backup files. keep only last 10
                                          zigbee.0
                                          2025-04-14 18:52:20.616	info	--> transmitPower : normal
                                          zigbee.0
                                          2025-04-14 18:52:20.604	info	init localConfig
                                          zigbee.0
                                          2025-04-14 18:52:20.565	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.6
                                          host.smarthome
                                          2025-04-14 18:52:15.676	info	instance system.adapter.zigbee.0 in version "2.0.5" started with pid 2760598
                                          device-watcher.0
                                          2025-04-14 18:52:04.279	info	Instanz-Wachdog:zigbee.0: Instanz deaktiviert
                                          host.smarthome
                                          2025-04-14 18:51:44.252	info	Restart adapter system.adapter.zigbee.0 because enabled
                                          host.smarthome
                                          2025-04-14 18:51:44.251	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          zigbee.0
                                          2025-04-14 18:51:43.649	error	unhandled promise rejection: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:633:26) at Socket.emit (node:events:518:28) at TCP.<anonymous> (node:net:343:12)
                                          zigbee.0
                                          2025-04-14 18:51:43.649	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          zigbee.0
                                          2025-04-14 18:51:43.649	error	Error: DB closed
                                          zigbee.0
                                          2025-04-14 18:51:43.649	error	DB closed
                                          Bei mir läuft
                                          js-controller 7.0.6
                                          zigbee 2.0.5
                                          Node.js: v20.18.1(20.19.0)
                                          NPM: 10.8.2
