  3. Off Topic
  4. Pflege des Betriebssystems
  5. Meldung über Zeitfehler - Was ist das ?
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
65 Beiträge 5 Kommentatoren 10.2k Aufrufe 3 Beobachtet
  • dogfight76D dogfight76
    Moment.....
    Edit Ergebnis @Thomas-braun
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: ioBroker-neu
           Icon name: computer
              Kernel: Linux 6.12.20+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     11:21:44 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2025-04-05 11:21:44 CEST
               Universal time: Sat 2025-04-05 09:21:44 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dogfight76
    HOME=/home/dogfight76
    GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        1.1G        2.2G        1.2M        808M        2.9G
    Swap:           536M          0B        536M
    Total:          4.5G        1.1G        2.7G
    Active iob-Instances:   14
             3791 M total memory
             1003 M used memory
              971 M active memory
              490 M inactive memory
             2093 M free memory
              100 M buffer memory
              670 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 11:21:45 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
    Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.4 total,   2094.0 free,   1003.5 used,    770.7 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2787.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  1.2M  379M   1% /run
    /dev/mmcblk0p2 ext4      117G  5.7G  106G   6% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Sat Apr  5 10:58:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Sat Apr  5 10:58:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat Apr  5 10:58:24 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    936M    /var/
    204M    /var/cache
    199M    /var/cache/apt
    167M    /var/lib
    135M    /var/lib/apt/lists
    Archived and active journals take up 52.0M in the file system.
    /opt/iobroker/backups:
    8.5M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    740M    /opt/iobroker/iobroker-data/
    727M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    12M     /opt/iobroker/iobroker-data/objects.jsonl
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker-neu        ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu  , alive, uptime: 1188)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.3
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker-neu                             -  enabled
    + system.adapter.chromecast.0             : chromecast            : ioBroker-neu                             -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker-neu                             -  enabled
      system.adapter.discovery.0              : discovery             : ioBroker-neu                             - disabled
      system.adapter.fritzdect.0              : fritzdect             : ioBroker-neu                             - disabled
    + system.adapter.history.0                : history               : ioBroker-neu                             -  enabled
      system.adapter.hm-rega.0                : hm-rega               : ioBroker-neu                             - disabled
      system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-neu                             - disabled, port: 18701
      system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12001
      system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12010
      system.adapter.influxdb.0               : influxdb              : ioBroker-neu                             - disabled, port: 8086
    + system.adapter.jarvis.0                 : jarvis                : ioBroker-neu                             -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker-neu                             -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 192.168.178.174
    + system.adapter.net-tools.0              : net-tools             : ioBroker-neu                             -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker-neu                             -  enabled
      system.adapter.solarlog.0               : solarlog              : ioBroker-neu                             - disabled, port: 80
    + system.adapter.time-switch.0            : time-switch           : ioBroker-neu                             -  enabled
      system.adapter.tr-064.0                 : tr-064                : ioBroker-neu                             - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-neu                             -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-neu                             - disabled
      system.adapter.vis.0                    : vis                   : ioBroker-neu                             -  enabled
    + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.3    , installed 7.6.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
    Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        1150
    States:         883
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:3 http://deb.debian.org/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 192.168.178.174:8885    0.0.0.0:*               LISTEN      1001       26077      4548/io.mqtt.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11133      2261/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4810       600/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11712      2059/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11707      2059/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4812       600/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11777      2077/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13592      2377/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12637      2173/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        561        461/avahi-daemon: r
    udp        0      0 0.0.0.0:34298           0.0.0.0:*                           104        563        461/avahi-daemon: r
    udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          767        539/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        562        461/avahi-daemon: r
    udp6       0      0 :::44980                :::*                                104        564        461/avahi-daemon: r
    2025-04-05 11:14:36.201  - info: mqtt.0 (4120) terminating
    2025-04-05 11:14:36.264  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-05 11:14:39.629  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4139
    2025-04-05 11:14:42.180  - info: mqtt.0 (4139) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
    2025-04-05 11:14:42.542  - info: mqtt.0 (4139) Starting MQTT server on 0.0.0.0:8885
    2025-04-05 11:14:42.547  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
    2025-04-05 11:14:42.560  - info: mqtt.0 (4139) Got terminate signal TERMINATE_YOURSELF
    2025-04-05 11:14:42.564  - info: mqtt.0 (4139) terminating
    2025-04-05 11:14:42.566  - info: mqtt.0 (4139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-04-05 11:14:42.619  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
    2025-04-05 11:14:43.069  - info: mqtt.0 (4139) terminating
    2025-04-05 11:14:43.138  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-05 11:14:46.552  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4185
    2025-04-05 11:14:49.095  - info: mqtt.0 (4185) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
    2025-04-05 11:14:49.433  - info: mqtt.0 (4185) Starting MQTT server on 0.0.0.0:8885
    2025-04-05 11:19:36.808  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
    2025-04-05 11:19:36.815  - info: mqtt.0 (4185) Got terminate signal TERMINATE_YOURSELF
    2025-04-05 11:19:36.819  - info: mqtt.0 (4185) terminating
    2025-04-05 11:19:36.821  - info: mqtt.0 (4185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-04-05 11:19:36.853  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
    2025-04-05 11:19:37.324  - info: mqtt.0 (4185) terminating
    2025-04-05 11:19:37.402  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-04-05 11:19:40.810  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4548
    2025-04-05 11:19:43.269  - info: mqtt.0 (4548) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
    2025-04-05 11:19:43.590  - info: mqtt.0 (4548) Starting MQTT server on 192.168.178.174:8885
    @dogfight76
    Jetzt ist es sauber.
    • dogfight76D Offline
      dogfight76D Offline
      dogfight76
      Da der Pi ja ein anderer ist als vorher , hat sich die IP geändert auf 192.168.178.174 (vorher .140)
      Jetzt meckert die MQTT-Instanz , weil dort ja die .140 eingetragen war.
      Ich also in den Settings von mqtt die IP im Auswahlfenster geändert auf:
      (ipv4) 192.168.178.174-wlan0 , beim Port steht ja die 8885.
      Muss das der Port sein wo man die VIS aufruft ?
      Thomas BraunT 1Topf1 2 Antworten Letzte Antwort
        @dogfight76
        mqtt hat mit der vis nix zu schaffen. Natürlich lauschen die Dienste auf unterschiedlichen Ports.
          dogfight76D Offline
          dogfight76
          Ok, danke.
          Aber warum zeigt mir die Instanz vom mqtt jetzt an:
          Verbunden - grün
          Lebenszeichen - grün
          Verbunden - rot
          Die Einstellungen in der Instanz mit der neuen IP stimmen doch, oder nicht ?
            Ok, danke.
            Verbunden - grün
            Verbunden - rot
            @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
            Aber warum
            Schau in das Log.
            dogfight76D 1 Antwort Letzte Antwort
              Aber warum
              Schau in das Log.
              dogfight76D Offline
              dogfight76D Offline
              dogfight76
              Im Log vom ioBroker steht was den mqtt betrifft:
              mqtt.0
              	2025-04-05 12:03:05.677	info	Starting MQTT server on 192.168.178.174:8885
              mqtt.0
              	2025-04-05 12:03:05.278	info	starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
              mqtt.0
              	2025-04-05 12:02:58.680	info	terminating
              mqtt.0
              	2025-04-05 12:02:58.177	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              mqtt.0
              	2025-04-05 12:02:58.175	info	terminating
              mqtt.0
              	2025-04-05 12:02:58.173	info	Got terminate signal TERMINATE_YOURSELF
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                mqtt.0
                @dogfight76 wissen die clients von der neuen IP?
                  dogfight76D Offline
                  dogfight76D Offline
                  dogfight76
                  Wo stelle ich die neue IP für Clients ein ?
                  Hatte jetzt nur an den mqqt gedacht ?
                    nicht für!
                    Bei den Clients
                      dogfight76D Offline
                      dogfight76
                      Ok, gefunden jetzt noch das in der Heishamon -PLatine noch die neue IP eingetragen werden musste !
                      Gemacht und dort ist ja im mqqt-Instanz auch die Port für eingetragen
                      Heishamonm rebootet und mqqt neu gestartet.
                      Aber in der ioBroker-Instanz vom mqqt steht immer
                      Verbunden - grün
                      Verbunden - rot
                      Oder muss da die IP von der Heishamon Platine rein ?
                        Verbunden - grün
                        Verbunden - rot
                        wo?
                        du sagst ja nicht was du
                        gefunden
                        hast
                          dogfight76D Offline
                          dogfight76
                          Mit „Gefunden“ meinte ich die eine Stellen in der heishamon-Einstellung !
                          Geändert auf die .174 , aber die Instanz im iobroker sagt immer noch:
                          Verbunden - grün
                          Verbunden - rot
                          Und die Temperatur im iobroker stimmt nicht überein mit der Anzeige im heishamon.
                          Die Verbindung scheint auch nicht stehen.
                          Weiß nicht warum !?
                            nicht für!
                            Bei den Clients
                            dogfight76D Offline
                            dogfight76D Offline
                            dogfight76
                            @homoran said in Meldung über Zeitfehler - Was ist das ?:
                            nicht für!
                            Bei den Clients
                            Dann hilf mir bitte mal auf die Sprünge ? Was meinst du damit ?
                            Ich habe im Setuo der Heishamon-PLatine die IP auf die .174 geändert.
                            In den Topics der Heishamon stimmt auch die outside.temp mit 13 Grad
                            Aber die mqtt-Instanz im ioBroker stellt keine Verbindung her.
                            Bei der Auswahl der IP im Setup der Instanz ist das zur Auswahl:
                            Die IP der Heishamon-Platine wäre 192.168.178.68, die steht nircht zur Auswahl.
                            Daher fiel meine Wahl auf "Alle IP zulassen"
                            Verstehe nicht warum der ioBroker keine Verbindung zur Heishamon aufbauen kann.
                            Ihr eine Idee ?
                              nicht für!
                              Bei den Clients
                              Ihr eine Idee ?
                              @dogfight76 was sagt denn das debug-log?
                                dogfight76D Offline
                                dogfight76D Offline
                                dogfight76
                                Vom start der mqtt Instanz ?
                                Wie mache ich ein log direkt davon ?
                                  ja!
                                  das kommt von selber wenn du startest
                                    ja!
                                    dogfight76D Offline
                                    dogfight76D Offline
                                    dogfight76
                                    Habe bei der Instanz vom mqtt die Protokollebene von Info umgestellt auf debug.
                                    Dann Neustart gemacht:
                                    2025-04-05 17:39:34.253 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                    2025-04-05 17:39:34.261 - info: mqtt.0 (14718) Got terminate signal TERMINATE_YOURSELF
                                    2025-04-05 17:39:34.264 - info: mqtt.0 (14718) terminating
                                    2025-04-05 17:39:34.267 - info: mqtt.0 (14718) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2025-04-05 17:39:34.301 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                    2025-04-05 17:39:34.771 - info: mqtt.0 (14718) terminating
                                    2025-04-05 17:39:34.827 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-04-05 17:39:38.220 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15640
                                    2025-04-05 17:39:40.700 - info: mqtt.0 (15640) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                    2025-04-05 17:39:41.096 - info: mqtt.0 (15640) Starting MQTT server on 0.0.0.0:8885
                                    2025-04-05 17:40:10.282 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                    2025-04-05 17:40:29.977 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:41:04.982 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                    2025-04-05 17:41:13.785 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:42:03.791 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                    2025-04-05 17:42:14.083 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:42:14.646 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:42:14.663 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                    2025-04-05 17:43:34.311 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:43:50.324 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:44:21.817 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:44:30.719 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:44:36.373 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:44:41.182 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:45:48.615 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:45:59.136 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:46:06.525 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                    2025-04-05 17:46:11.861 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 web
                                    2025-04-05 17:47:09.996 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                    2025-04-05 17:47:10.005 - info: mqtt.0 (15640) Got terminate signal TERMINATE_YOURSELF
                                    2025-04-05 17:47:10.007 - info: mqtt.0 (15640) terminating
                                    2025-04-05 17:47:10.010 - info: mqtt.0 (15640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2025-04-05 17:47:10.045 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                    2025-04-05 17:47:10.512 - info: mqtt.0 (15640) terminating
                                    2025-04-05 17:47:10.575 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-04-05 17:47:13.210 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15942
                                    2025-04-05 17:47:15.035 - debug: mqtt.0 (15942) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2025-04-05 17:47:15.089 - debug: mqtt.0 (15942) Objects client ready ... initialize now
                                    2025-04-05 17:47:15.100 - debug: mqtt.0 (15942) Objects create System PubSub Client
                                    2025-04-05 17:47:15.103 - debug: mqtt.0 (15942) Objects create User PubSub Client
                                    2025-04-05 17:47:15.127 - debug: mqtt.0 (15942) Objects client initialize lua scripts
                                    2025-04-05 17:47:15.137 - debug: mqtt.0 (15942) Objects connected to redis: 127.0.0.1:9001
                                    2025-04-05 17:47:15.160 - debug: mqtt.0 (15942) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2025-04-05 17:47:15.230 - debug: mqtt.0 (15942) States create System PubSub Client
                                    2025-04-05 17:47:15.237 - debug: mqtt.0 (15942) States create User PubSub Client
                                    2025-04-05 17:47:15.298 - debug: mqtt.0 (15942) States connected to redis: 127.0.0.1:9000
                                    2025-04-05 17:47:15.334 - debug: mqtt.0 (15942) Plugin sentry Initialize Plugin (enabled=true)
                                    2025-04-05 17:47:15.762 - info: mqtt.0 (15942) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                    2025-04-05 17:47:16.086 - info: mqtt.0 (15942) Starting MQTT server on 0.0.0.0:8885
                                    2025-04-05 17:47:16.165 - debug: mqtt.0 (15942) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868036160,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                                    2025-04-05 17:47:16.217 - debug: mqtt.0 (15942) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868036212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                                    2025-04-05 17:47:48.123 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                    2025-04-05 17:47:48.137 - info: mqtt.0 (15942) Got terminate signal TERMINATE_YOURSELF
                                    2025-04-05 17:47:48.143 - info: mqtt.0 (15942) terminating
                                    2025-04-05 17:47:48.146 - debug: mqtt.0 (15942) Plugin sentry destroyed
                                    2025-04-05 17:47:48.149 - info: mqtt.0 (15942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2025-04-05 17:47:48.174 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                    2025-04-05 17:47:48.652 - info: mqtt.0 (15942) terminating
                                    2025-04-05 17:47:48.711 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-04-05 17:47:52.106 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15988
                                    2025-04-05 17:47:54.611 - info: mqtt.0 (15988) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                    2025-04-05 17:47:54.938 - info: mqtt.0 (15988) Starting MQTT server on 0.0.0.0:8885
                                    2025-04-05 17:48:42.390 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                    2025-04-05 17:48:42.403 - info: mqtt.0 (15988) Got terminate signal TERMINATE_YOURSELF
                                    2025-04-05 17:48:42.407 - info: mqtt.0 (15988) terminating
                                    2025-04-05 17:48:42.412 - info: mqtt.0 (15988) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2025-04-05 17:48:42.456 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                    2025-04-05 17:48:42.914 - info: mqtt.0 (15988) terminating
                                    2025-04-05 17:48:42.971 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-04-05 17:48:45.831 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 16045
                                    2025-04-05 17:48:47.733 - debug: mqtt.0 (16045) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                    2025-04-05 17:48:47.767 - debug: mqtt.0 (16045) Objects client ready ... initialize now
                                    2025-04-05 17:48:47.770 - debug: mqtt.0 (16045) Objects create System PubSub Client
                                    2025-04-05 17:48:47.771 - debug: mqtt.0 (16045) Objects create User PubSub Client
                                    2025-04-05 17:48:47.797 - debug: mqtt.0 (16045) Objects client initialize lua scripts
                                    2025-04-05 17:48:47.807 - debug: mqtt.0 (16045) Objects connected to redis: 127.0.0.1:9001
                                    2025-04-05 17:48:47.845 - debug: mqtt.0 (16045) Redis States: Use Redis connection: 127.0.0.1:9000
                                    2025-04-05 17:48:47.856 - debug: mqtt.0 (16045) States create System PubSub Client
                                    2025-04-05 17:48:47.858 - debug: mqtt.0 (16045) States create User PubSub Client
                                    2025-04-05 17:48:47.914 - debug: mqtt.0 (16045) States connected to redis: 127.0.0.1:9000
                                    2025-04-05 17:48:47.950 - debug: mqtt.0 (16045) Plugin sentry Initialize Plugin (enabled=true)
                                    2025-04-05 17:48:48.364 - info: mqtt.0 (16045) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                    2025-04-05 17:48:48.725 - info: mqtt.0 (16045) Starting MQTT server on 0.0.0.0:8885
                                    2025-04-05 17:48:48.813 - debug: mqtt.0 (16045) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868128808,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                                    2025-04-05 17:48:48.864 - debug: mqtt.0 (16045) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868128860,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                                    Hoffe das hilft warum keine Verbindung zur Heishamon aufgebaut wird.
                                      wie oft??
                                      bitte nur einen Neustart.
                                      laut log wurde die Instanz 3x neu gestartet
                                        wie oft??
                                        dogfight76D Offline
                                        dogfight76D Offline
                                        dogfight76
                                        Das kann wohl sein , weil ich kucken musste wie man debug-log macht
                                        Aber was zu erkennen warum er die heishamon nicht verbinden kann ?
                                        Noch eine Idee ?
                                        Wo muss man die neue IP noch eintragen und gegen die alte IP tauscht.
                                        Habe bei den Instanzen alle setup durchgeschaut. Keine IP Einträge gefunden ! In der heishamon habe ich es angepasst.
                                        Irgendwo muss der Fehler ja liegen….
                                          Noch eine Idee ?
                                          nein.
                                          kann man an der Platine die Verbindung testen?
                                          sonst lass mal das log auf debug und starte die Platine neu.
                                          ein iob diag in der Langfassung schadet nie
