  4. Blink Camera System
Blink Camera System
blink xtcamera
407 Beiträge 63 Kommentatoren 166.2k Aufrufe 65 Beobachtet
    @varg Dann vielleicht diesem Hinweis folgen:
    You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
    Aber vorher ein Backup machen!
    V Offline
    V Offline
    varg
    #393
    @dr-bakterius ok danke aber das folgende machts auch nicht besser ;(
    pi@iobroker:~ $ pip install blinkpy --break-system-packages
    Defaulting to user installation because normal site-packages is not writeable
    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
    Collecting blinkpy
      Downloading https://www.piwheels.org/simple/blinkpy/blinkpy-0.23.0-py3-none-an        y.whl (30 kB)
    Collecting python-dateutil>=2.8.1
      Downloading https://www.piwheels.org/simple/python-dateutil/python_dateutil-2.        9.0.post0-py2.py3-none-any.whl (229 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 229.9/229.9 kB 2.7 MB/s eta 0:00:00
    Requirement already satisfied: requests>=2.24.0 in /usr/lib/python3/dist-package        s (from blinkpy) (2.28.1)
    Collecting python-slugify>=4.0.1
      Downloading https://www.piwheels.org/simple/python-slugify/python_slugify-8.0.        4-py3-none-any.whl (10 kB)
    Collecting sortedcontainers~=2.4.0
      Downloading https://www.piwheels.org/simple/sortedcontainers/sortedcontainers-        2.4.0-py2.py3-none-any.whl (29 kB)
    Collecting aiohttp>=3.8.4
      Downloading aiohttp-3.11.14-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_a        arch64.whl (1.7 MB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.7/1.7 MB 5.8 MB/s eta 0:00:00
    Collecting aiofiles>=23.1.0
      Downloading https://www.piwheels.org/simple/aiofiles/aiofiles-24.1.0-py3-none-        any.whl (15 kB)
    Collecting aiohappyeyeballs>=2.3.0
      Downloading https://www.piwheels.org/simple/aiohappyeyeballs/aiohappyeyeballs-        2.6.1-py3-none-any.whl (15 kB)
    Collecting aiosignal>=1.1.2
      Downloading https://www.piwheels.org/simple/aiosignal/aiosignal-1.3.2-py2.py3-        none-any.whl (7.6 kB)
    Collecting attrs>=17.3.0
      Downloading https://www.piwheels.org/simple/attrs/attrs-25.3.0-py3-none-any.wh        l (63 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 63.8/63.8 kB 1.4 MB/s eta 0:00:00
    Collecting frozenlist>=1.1.1
      Downloading frozenlist-1.5.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_        aarch64.whl (276 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 276.4/276.4 kB 5.0 MB/s eta 0:00:00
    Collecting multidict<7.0,>=4.5
      Downloading multidict-6.2.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_a        arch64.whl (135 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 135.7/135.7 kB 4.1 MB/s eta 0:00:00
    Collecting propcache>=0.2.0
      Downloading propcache-0.3.0-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_a        arch64.whl (232 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 232.4/232.4 kB 5.0 MB/s eta 0:00:00
    Collecting yarl<2.0,>=1.17.0
      Downloading yarl-1.18.3-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch        64.whl (340 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 340.6/340.6 kB 4.6 MB/s eta 0:00:00
    Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from        python-dateutil>=2.8.1->blinkpy) (1.16.0)
    Collecting text-unidecode>=1.3
      Downloading https://www.piwheels.org/simple/text-unidecode/text_unidecode-1.3-        py2.py3-none-any.whl (78 kB)
         ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 78.2/78.2 kB 1.1 MB/s eta 0:00:00
    Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from        yarl<2.0,>=1.17.0->aiohttp>=3.8.4->blinkpy) (3.3)
    Installing collected packages: text-unidecode, sortedcontainers, python-slugify,        python-dateutil, propcache, multidict, frozenlist, attrs, aiohappyeyeballs, aio        files, yarl, aiosignal, aiohttp, blinkpy
      WARNING: The script slugify is installed in '/home/pi/.local/bin' which is not        on PATH.
      Consider adding this directory to PATH or, if you prefer to suppress this warn        ing, use --no-warn-script-location.
    Successfully installed aiofiles-24.1.0 aiohappyeyeballs-2.6.1 aiohttp-3.11.14 ai        osignal-1.3.2 attrs-25.3.0 blinkpy-0.23.0 frozenlist-1.5.0 multidict-6.2.0 propc        ache-0.3.0 python-dateutil-2.9.0.post0 python-slugify-8.0.4 sortedcontainers-2.4        .0 text-unidecode-1.3 yarl-1.18.3
    pi@iobroker:~ $ await Blink.start()
    -bash: syntax error near unexpected token `('
    pi@iobroker:~ $ import asyncio
    -bash: import: command not found
    pi@iobroker:~ $ cd blinkpy
    -bash: cd: blinkpy: No such file or directory
    Dr. BakteriusD 1 Antwort Letzte Antwort
    • V varg
      Collecting blinkpy
      Dr. BakteriusD Offline
      Dr. Bakterius
      #394
      @varg Die Befehle ruft man nicht in der Konsole auf sondern per Python-Skript. Zum Speichern eines Bildes sieht es bei mir so aus (abgelegt unter /opt/iobroker/bild.py mit den Rechten 674:
      import asyncio
      from aiohttp import ClientSession
      from blinkpy.blinkpy import Blink
      from blinkpy.auth import Auth
      from blinkpy.helpers.util import json_load
      async def start():
          blink = Blink()
          auth = Auth(await json_load("/opt/iobroker/blink_auth.json"))
          blink.auth = auth
          await blink.start()
          camera = blink.cameras['Eingangstuere']
          await camera.snap_picture()       # Take a new picture with the camera
          await blink.refresh()             # Get new information from server
          await camera.image_to_file('/opt/iobroker/blink.jpg')
          return blink
      blink = asyncio.run(start())
      Wie man die blink_auth.json erstellt, habe ich weiter oben schon beschrieben.
      Der Aufruf mit Blockly wird dann mit diesem Befehl ausgeführt:
      So kannst du auch auf in der Konsole einen Test starten.
        Ich grabe diesen Thread aus aktuellem Anlass wieder aus.
        Seit irgendwann im April hat Blinkpy nicht mehr funktioniert, weil Amazon bei der Anmeldung etwas geändert hat und dadurch jedes Mal ein neuer 2FA Code gesendet wurde. Das wurde auch auf GitHub behandelt (https://github.com/fronzbot/blinkpy/issues/917). Inzwischen dürfte es eine Lösung geben die ich hier gerne zusammenfassen möchte. Vielleicht nützt es ja jemandem.
        Aktuell muss man folgende beiden Skripte von GitHub herunterladen und bei sich im Ordner /home/<user>/.local/lib/python3.11/site-packages/blinkpy ersetzen: auth.py und blinkpy.py.
        Man erstellt einmalig ein Skript (z.B. anmelden.py) mit folgendem Inhalt:
        import asyncio
        async def start():
            blink = Blink(session=ClientSession())
            # Can set no_prompt when initializing auth handler
            auth = Auth({"username": <your username>, "password": <your password>}, no_prompt=True)
            blink.auth = auth
            await blink.start()
            await blink.save("/opt/iobroker/blink_auth.json")
            return blink
        Wenn man dieses von der Console aufruft
        python3.11 anmelden.py
        , wird man nach seinen Anmeldedaten gefragt und erhält dann den 2FA Code welchen man angibt. Anschließend wird in /opt/iobroker die Datei blink_auth.json erstellt. Diese enthält die Anmeldedaten für künftige Abfragen. Danach kann man das Skript wenn man möchte wieder löschen.
        Um jetzt ein Bild abzufragen braucht man folgendes Skript:
        import asyncio
        async def start():
            blink = Blink()
            auth = Auth(await json_load("/opt/iobroker/blink_auth.json"))   # Anmeldeinformationen laden
            blink.auth = auth   # Anmeldeinformationen senden
            await blink.start()   # Verbindung starten
            camera = blink.cameras['<Kameraname>']   # Kameraname angeben
            await camera.snap_picture()   # Bild aufnehmen
            await blink.refresh()   # Daten vom Blink-Server abfragen
            await camera.image_to_file('/opt/iobroker/blink.jpg')   # Bild speichern
            return blink
        Leider ist es mir nicht gelungen das Skript mit exec (JS oder Blockly) wegen fehlender Berechtigung aufzurufen. Ich habe das dann mit dem Linux-Control Adapter gelöst.
        Dette
        #395
        Daran bin ich auch fast gestorben, denn auch mit dem Linux-Control klappt es bei mir nicht.
        Die einfache Lösung:
        Man muss blinkpy mit dem user "iobroker" installieren:
        sudo -H -u iobroker pip install blinkpy
        Danach kann man das Python Skript normal via exec aufrufen.
        • D Dette
          Brekkis
          schrieb am zuletzt editiert von Brekkis
          #396
          Howto Blink in IoBroker einbinden
          WICHTIG: Diese Anleitung ist noch ein Entwurf, ich brauche hier vermutlich noch Input von den Profis hier im Forum, aber Ziel ist es, eine für jeden nachvollziehbare Anleitung als Basis für die Einbindung der Blink-Kameras in IoBroker zu erhalten! edit 2025-03-28: es scheint zu funktionieren.
          Basis dieses How-To sind die Informationen zusammengefasst aus diesem Thread und dem GitHub-Projekt: https://github.com/fronzbot/blinkpy
          Ich habe mal hier aus dem Thread die Informationen, Codezeilen und Scripte übernommen, damit ein ordentliches How-To für Neulinge nachvollziehbar dokumentiert ist.... Gerne könnt ihr mir helfen, das How-To zu vervollständigen, zu berichtigen, und lauffähig zu machen, damit alle ihre Blink-Kameras in Iobroker einbinden können)
          Will vorher noch anmerken, dass ich nicht der Coding-Spezialist bin und mit dem "Try and Error-Prizip" arbeite.
          Start des HOWTO (Stand 2025-03-28)
          Ich werde den Stand (nach Korrekturen) dann immer updaten
          Welche Funktionen erwarten euch nach erfolgreicher Durchführung:
          • Blink Kameras sind in IoBroker eingebunden
          • Zugriff auf das letzte gespeicherte Bild der Kameras
          • Zugriff auf das letzte gespeicherte Video der Kameras
          • Anzeige des Bilds in der Visu
          • Anzeige des Videos in der Visu
          • Scharfschalten und Deaktivieren via Datenpunkt
          Grundlagen:
          (bei mir läuft das ganze in einer Proxmox Installation auf Debian 11.3.0 in einem Container, sollte aber auch auf einem PI funktionieren)
          • funktionierende IoBroker-Installation
          • funktionierende Homebridge-Installation (läuft bei mir in der V.1.85, ebenfalls in einer VM auf Proxmox)
          • mindestens eine in der Blink-App funktionierende Kamera
          • NodeJS und NPM (über Konsolenbefehl
          nodejs -v
          und
          npm -v
          abrufbar)
          edit: (ich habe aktuell die Versionen NodeJS 22.14.0 und NPM10.9.2 installiert)
          zusätzlich installierte Adapter Ioboker:
          • HAM (Homebridge Zubehör-Manager V5.3.1)
            Im Homebridge-Adapter muss ersten Tab unter "zusätzliche NPM Module installieren" noch "homebridge-blink-for-home@3.7.6" eingetragen werden und der Haken "beim nächsten Start die Homebridge Plugins von NPM installieren" gesetzt sein! Im Tab Konfigurationsdatei muss folgender Code eingetragen werden:
          "platforms" : [
              "name"     : "Blink",
              "username" : "<your blink email address>",
              "password" : "<your blink password>",
              "pin"      : "<pin>",
              "platform" : "Blink"
          Die Daten in den <> Klammern durch die eigenen Anmeldedaten ersetzen.
          • Javascript Adapter und Grundverständnis für die Anwendung des scripens
          Über die Konsole installiert: (via Putty oder wie bei mir über die Proxmox-eigene Konsole)
          • Python, Ich habe V 3.11.2 installiert. Installation kann man überprüfen mit
          python --version
          Python 3.11.2
          Falls Python und Pip nicht installiert sind, geht man wie folgt vor:
          Konsolenbefehle:
          Version abfragen
          python3 --version
          pip3 --version
          sudo apt update
          sudo apt install python3
          sudo apt install python3-pip
          • Blinkpy:
            Installation als User "iobroker" siehe Beitrag von @Dr-Bakterius
          sudo -H -u iobroker pipx install blinkpy
          (edit: 27.03.2025, Hinweis @Thomas-Braun)
          ich habe pip3 installiert und mit folgendem Befehl blinkpy installiert:
          sudo -H -u iobroker pip3 install blinkpy
          Danach werden 2 Scripte angelegt
          Script 1: "anmelden.py" (erstellen im Ordner: /home/iobroker)
          erstellt wird das Script mit
          cd /home/iobroker
          nano anmelden.py
          Inhalt des Scripts:
          import asyncio
          async def start():
              blink.auth = auth
              await blink.start()
              return blink
          <your username>
          <your password>
          müssen mit den Anmeldedaten aus der Blink-Anmeldung (in der App) ersetzt werden.
          mit Strg + x beenden, speichern, Name bestätigen
          mit
          das Script ausführen
          (Bei mir kam eine Fehlermeldung bzgl fehlendem aiohttp-Addon, das habe ich dann nochmal nachinstalliert)
          pip3 install aiohttp
          Danach sollte man/wird man nach seinen Anmeldedaten gefragt und erhält dann den 2FA Code welchen man angibt. Anschließend wird in /opt/iobroker die Datei blink_auth.json erstellt. Diese enthält die Anmeldedaten für künftige Abfragen. Den Pin auch in der Instanz des Homebridge Zubehör Adapter unter Konfigurationsdatei "PIN" eintragen.
          Danach kann man das Skript wenn man möchte wieder löschen. (ich habe es nicht gelöscht)
          cd /opt/iobroker/bild.py
          nano bild.py
          Name kann frei gewählt werden.
          Zugriffsrechte anpassen /opt/iobroker/bild.py
          mit den Rechten 674 (ich habe die Rechte auf 655 gesetzt)
          cd /opt/ibroker
          chmod 755 bild.py
          import asyncio
          async def start():
              blink = Blink()
              return blink
          <Kameraname>
          muss mit dem Namen der Blink-Kamera in der App übereinstimmen!
          mit
          python3.11 bild.py
          Der Aufruf des Bildes wird dann über den Javascript-Adapter gemacht:
          Hierzu ein Blockly erstellen und u.a. diese Zeile (von @Dr-Bakterius ) eingeben:
          (Trigger z.b. Cronjob, Tastendruck eines Button-Widgets fehlt hier noch, oder ggf. Datenpunkt "Bewegung" als Trigger)
          Werde dann hier später noch ein komplettes Blockly-Script einfügen
          Das Bild liegt dann hier ab:
          Über ein "Image-Widget" kann dann das Bild in die Visu eingebunden werden:
          Ein Beispiel ergänze ich dann, wenn es bei mir funktioniert! :-)
          Ergänzung für Abfrage des Videos und Kamera "ARM" und "DISARM" wird später noch ergänzt.
          Ende des HowTos.
          Ich hoffe hier um aktive Hilfestellung, damit wir eine verständliche Anleitung für jedermann hinbekommen.
          Bis demnächst, Gruß Brekkis
          • B Brekkis
            Grundlagen:
            nodejs -v
            und
            npm -v
            abrufbar)
            "platforms" : [
                "name"     : "Blink",
                "pin"      : "<pin>",
            python --version
            Python 3.11.2
            Konsolenbefehle:
            Version abfragen
            python3 --version
            pip3 --version
            sudo apt update
            • Blinkpy:
            cd /home/iobroker
            nano anmelden.py
            Inhalt des Scripts:
            import asyncio
            async def start():
                blink.auth = auth
                await blink.start()
                return blink
            <your username>
            <your password>
            mit
            nano bild.py
            cd /opt/ibroker
            chmod 755 bild.py
            import asyncio
            async def start():
                blink = Blink()
                return blink
            <Kameraname>
            mit
            python3.11 bild.py
            Ende des HowTos.
            #397
            @brekkis sagte in Blink Camera System:
            Besser:
            pip sollte auf modernen Python-Installationen nicht mehr verwendet werden.
              Besser:
              Brekkis
              #398
              @thomas-braun Ok, habe deinen Hinweis im HowTo eingearbeitet. Danke dir. Ist dir sonst noch was aufgefallen, was falsch oder nicht so schön ist....?
              • B Brekkis
                #399
                @brekkis
                Da ich die Hardware nicht habe kann ich auch nichts aus eigener Erfahrung beitragen.
                Nur bist du sicher, das z. B. mindestens nodejs@22 benötigt wird? Widerspricht der derzeitigen Empfehlung von nodejs@20 für den ioBroker.
                Die python Version wird so geprüft:
                python --version
                Python 3.13.2
                  @brekkis
                  python --version
                  Python 3.13.2
                  Brekkis
                  #400
                  @thomas-braun Das habe ich doof geschrieben, das ist keine Mindestanforderung, sondern meine aktuell installierte Version. Ich schreibe das mal um. Danke
                  • B Brekkis
                    #401
                    @brekkis
                    Und so als Vorausblick:
                    Da wird es wohl 'irgendwann' mal ein Debian-Paket zu geben.
                    Liegt momentan im Testing-Zweig und dürfte dann im Sommer zum Release von Debian 13 'Trixie' direkt aus dem Paket-Manager per apt install python3-blinkpy installierbar sein.
                    https://packages.debian.org/trixie/python3-blinkpy
                      Brekkis
                      #402
                      So, jetzt ist schon wieder ein Punkt, wo ich nicht weiterkomme.
                      Ich habe das Script und die Einstellungen soweit, dass ein Bild "Blink.jpg" im Ordner /opt/iobroker/iobroker-data abgelegt wird. Wie kann ich von der Vis auf das Bild zugreifen, bzw. es mir anzeigen lassen? Habe das Bild schon in den Imageordner auf den die Vis zugreift gelegt, aber da erscheint kein Blink.jpg!
                      was mache ich noch falsch?
                      Gruß Brekkis
                      • B Brekkis
                        Gruß Brekkis
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #403
                        @brekkis
                        da kommst du nicht dran
                        leg dir ein Ordner für die Bilder an da hin
                        /opt/iobroker/pics
                        • V varg
                          Frickel schon bei der Installation seit ner Stunde rum 👌
                          error: externally-managed-environment
                          × This environment is externally managed
                          ╰─> To install Python packages system-wide, try apt install
                              python3-xyz, where xyz is the package you are trying to
                              install.
                              If you wish to install a non-Debian-packaged Python package,
                              create a virtual environment using python3 -m venv path/to/venv.
                              Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
                              sure you have python3-full installed.
                              For more information visit http://rptl.io/venv
                          note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
                          hint: See PEP 668 for the detailed specification.
                          pi@iobroker:~ $ ^C
                          Egal was ich mache ich kann das ding nicht installieren. Evtl. hat mir jemand einen Tip ?
                          V Offline
                          V Offline
                          varg
                          schrieb am zuletzt editiert von varg
                          #404
                          @Thomas-Braun
                          moin, vielleicht weisst Du wie ich das gerade biege. Dieses Problem verfolgt mich schon seit dem ersten Versuch (s.o).
                          pi@iobroker:~ $ sudo -H -u iobroker pip3 install blinkpy
                              install.
                          pi@iobroker:/home/iobroker $ python3 --version
                          Python 3.11.2
                          pi@iobroker:/home/iobroker $ pip3 --version
                          pip 23.0.1 from /usr/lib/python3/dist-packages/pip (python 3.11)
                          pi@iobroker:/home/iobroker $ nodejs -v
                          v20.19.0
                          pi@iobroker:/home/iobroker $ npm -v
                          10.8.2
                          Beim letzten mal habe ich dann den "override" Befehl genutzt.
                          Collecting blinkpy
                          Das haut dann aber mit den Berechtigungen bestimmt alles nicht hin. Ja evtl. hast Du ja kurz Zeit für nen "kleinen" workarround ;)
                          • arteckA arteck
                            @brekkis
                            /opt/iobroker/pics
                            Brekkis
                            #405
                            @arteck Danke für den Tipp, geht leider immer noch nicht.
                            Das Bild liegt im Ordner /opt/iobroker/pics. Von der Visu aus (Image oder HTML Widget, Ordnername und Bildname eingetragen) zeigt es aber nichts an.
                            Wenn ich über WINSCP auf das Dateisystem zugreife und auf den Ordner /opt/iobroker/pics navigiere und das Bild ins Windowssystem herunterlade und öffne sehe ich das Bild von der Kamera.
                            Ich kann es einfach nicht in der Vis anzeigen. Verflucht.
                            Bild-Widget bei Quelle: ../opt/iobroker/pics/blink.jpg
                            Es wird nur ein Frame mit Fragezeichen dargestellt. Oh mann, ich bin auf der Zielgeraden und dann sowas....
                            • V varg
                              @Thomas-Braun
                                  install.
                              Python 3.11.2
                              v20.19.0
                              10.8.2
                              Collecting blinkpy
                              #406
                              @varg sagte in Blink Camera System:
                              pipx verwenden. Ist auch kein Workaround sondern der vorgesehene Weg.
                              • PischleuderP Offline
                                Pischleuder
                                #407
                                Guten Morgen,
                                ich habe mich einmal an eine Weiterentwicklung gewagt - ggf. ist das etwas für Euch ?
                                KLICK
