  3. Einsteigerfragen
  4. Installation
  5. Zigbee.0: You need save and run adapter before pairing!
    5.3k
51 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
    @nilli
    Der Link 'by-id' ist immer zu bevorzugen, der ändert sich nämlich nicht.
    Du kannst auch mal in der zigbee-Sektion von
    iob diag --unmask
    schauen, was da eingestellt ist.
    N Offline
    N Offline
    nilli
    schrieb am zuletzt editiert von nilli
    leider nichts auffälliges ...
    USB-Devices by-id:
    /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.0
    Extended Pan ID:
    grep: /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json: No such file or directory
    Pan ID:
    /home/iobroker/.diag.sh: line 699: printf: 0x: invalid hex number
    Channel:
    Network Key:
    Adapter State
    + system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: raspi5
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     19:16:26 up 1 day, 11:01,  2 users,  load average: 113.00, 112.51, 111.72
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-03-19 19:16:27 CET
               Universal time: Wed 2025-03-19 18:16:27 UTC
                     RTC time: Wed 2025-03-19 18:16:27
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    nils
    HOME=/home/nils
    GROUPS=nils adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            2.1G        1.5G        163M        425K        557M        651M
    Swap:           536M        536M        573K
    Total:          2.6G        2.0G        163M
    Active iob-Instances: 	22
             2009 M total memory
             1387 M used memory
              754 M active memory
              838 M inactive memory
              155 M free memory
               87 M buffer memory
              443 M swap cache
              511 M total swap
              511 M used swap
                0 M free swap
    top - 19:16:27 up 1 day, 11:01,  2 users,  load average: 113.00, 112.51, 111.72
    Tasks: 293 total,   1 running, 292 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 66.7 id, 33.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2009.0 total,    155.0 free,   1387.7 used,    531.4 buff/cache
    MiB Swap:    512.0 total,      0.5 free,    511.4 used.    621.3 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    15 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  967M     0  967M   0% /dev
    tmpfs          tmpfs     201M  5.2M  196M   3% /run
    /dev/mmcblk0p2 ext4       59G  9.7G   46G  18% /
    tmpfs          tmpfs    1005M     0 1005M   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
    tmpfs          tmpfs     201M     0  201M   0% /run/user/1000
    [Tue Mar 18 08:14:35 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:7A:6F:0D vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a7b4f037-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Tue Mar 18 08:14:38 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Tue Mar 18 08:14:39 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G	/var/
    206M	/var/cache
    200M	/var/cache/apt
    174M	/var/lib
    135M	/var/lib/apt/lists
    Archived and active journals take up 133.0M in the file system.
    /opt/iobroker/backups:
    19M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G	/opt/iobroker/iobroker-data/
    1.3G	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    USB-Devices by-id:
    zigbee.0
    Extended Pan ID:
    Pan ID:
    Channel:
    Network Key:
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.19.0
    /usr/bin/node 		v20.19.0
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi5              raspi5 (version: 7.0.6, hostname: raspi5        , alive, uptime: 114649)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.4.10
    javascript: 	8.8.3
    nodejs modules from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
      system.adapter.cloud.0                  : cloud                 : raspi5                                   - disabled
    + system.adapter.discovery.0              : discovery             : raspi5                                   -  enabled
    + system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
    + system.adapter.email.0                  : email                 : raspi5                                   -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspi5                                   -  enabled
    + system.adapter.history.0                : history               : raspi5                                   -  enabled
      system.adapter.iot.0                    : iot                   : raspi5                                   - disabled
    + system.adapter.iqontrol.0               : iqontrol              : raspi5                                   -  enabled
    + system.adapter.jarvis.0                 : jarvis                : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
    + system.adapter.maxcube.0                : maxcube               : raspi5                                   -  enabled, port: 62910, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : raspi5                                   -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : raspi5                                   -  enabled
      system.adapter.ping.0                   : ping                  : raspi5                                   - disabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi5                                   -  enabled
    + system.adapter.scenes.0                 : scenes                : raspi5                                   -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : raspi5                                   -  enabled
    + system.adapter.sql.0                    : sql                   : raspi5                                   -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspi5                                   -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspi5                                   - disabled
    + system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "notification-manager": 1.2.1, installed 1.2.1
    Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
    Objects and States
    Objects: 	1841
    States: 	937
    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:6 https://packages.adoptium.net/artifactory/deb bookworm InRelease
    Reading package lists...
    Pending Updates: 12
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4944       675/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       88612      21571/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       88607      21571/iobroker.js-c
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       90865      22057/io.jarvis.0
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       90518      21746/node-red
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4946       675/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87450      21591/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89048      21978/io.web.0
    udp        0      0 192.168.2.87:5353       0.0.0.0:*                           1001       87961      22014/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4799       541/avahi-daemon: r
    udp        0      0 0.0.0.0:39307           0.0.0.0:*                           104        4801       541/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4800       541/avahi-daemon: r
    udp6       0      0 fe80::cfaa:2ac1:4ed:546 :::*                                0          372348     618/NetworkManager
    udp6       0      0 :::41901                :::*                                104        4802       541/avahi-daemon: r
    2025-03-19 19:15:51.328  - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
    2025-03-19 19:15:51.329  - debug: fritzdect.0 (22085) __________________________
    2025-03-19 19:15:51.329  - debug: fritzdect.0 (22085) updating Devices / Groups
    2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) devices
    2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) [{"identifier":"08761 0147624","id":"16","functionbitmask":"35456","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"0","txbusy":"0","name":"FRITZ!DECT 200 #1","switch":{"state":"","mode":"","lock":"","devicelock":""},"simpleonoff":{"state":""},"powermeter":{"voltage":"","power":"","energy":""}}]
    2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) update Devices 1
    2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) _____________________________________________
    2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) updating Device FRITZ!DECT 200 #1
    2025-03-19 19:15:53.101  - silly: fritzdect.0 (22085) States user redis pmessage fritzdect.0.*/fritzdect.0.DECT_087610147624.present:{"val":false,"ack":true,"ts":1742408153100,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1739294859072}
    2025-03-19 19:15:53.101  - debug: fritzdect.0 (22085) onStateChange => state fritzdect.0.DECT_087610147624.present changed: false (ack = true)
    2025-03-19 19:15:53.101  - debug: fritzdect.0 (22085) DECT_087610147624 is not present, check the device connection, no values are written
    2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) groups
    2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) []
    2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) __________________________
    2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) updating Routines
    2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) __________________________
    2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) routines
    2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) []
    2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) glob state ["087610147624"]
    2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) updating Stats of device 087610147624
    2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) update Stats objects 087610147624
    2025-03-19 19:15:56.368  - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
    • AsgothianA Asgothian
      @nilli das letzte was mir einfällt hatte ich weiter oben schon geschrieben.
      Auffällig ist das Fehlen jeglicher Fehlermeldungen seitens des Adapters - das ist unüblich.
      Deswegen ist ein Update auf eine 2.0.x version zu empfehlen - da habe ich den exakten Quelltext hier.
      A.
      N Offline
      N Offline
      nilli
      @asgothian said in Zigbee.0: You need save and run adapter before pairing!:
      Würde ich gerne versuchen, leider bin ich noch etwas unerfahren.
      Wie gehe ich zur Installation vor ? Gibt es irgendwo eine Anleitung ?
      Danke !!
      • N nilli
        USB-Devices by-id:
        zigbee.0
        Extended Pan ID:
        Pan ID:
        Channel:
        Network Key:
        Adapter State
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        nils
        HOME=/home/nils
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
                 2009 M total memory
                 1387 M used memory
                  754 M active memory
                  155 M free memory
                   87 M buffer memory
                  443 M swap cache
                  511 M total swap
                  511 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        /var:
        1.1G	/var/
        206M	/var/cache
        200M	/var/cache/apt
        174M	/var/lib
        USB-Devices by-id:
        zigbee.0
        Extended Pan ID:
        Pan ID:
        Channel:
        Network Key:
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin: 		7.4.10
        javascript: 	8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects: 	1841
        States: 	937
        Pending Updates: 12
        @nilli sagte in Zigbee.0: You need save and run adapter before pairing!:
        Was sind denn das für Errors?
        N 1 Antwort Letzte Antwort
          N Offline
          N Offline
          nilli
          Ich habe gestern versucht nach https://stmxcsr.com/micro/raspberry-signal-client.html signal-cli zu compelieren, bin aber leider krachend gescheitert 😧
          nils@raspi5:~ $ sudo dmesg --level=emerg,alert,crit -T
          [Tue Mar 18 08:14:41 2025] Unable to handle kernel paging request at virtual address ffffc00080aa3f04
          [Tue Mar 18 08:14:41 2025] Mem abort info:
          [Tue Mar 18 08:14:41 2025]   ESR = 0x0000000096000047
          [Tue Mar 18 08:14:41 2025]   EC = 0x25: DABT (current EL), IL = 32 bits
          [Tue Mar 18 08:14:41 2025]   SET = 0, FnV = 0
          [Tue Mar 18 08:14:41 2025]   EA = 0, S1PTW = 0
          [Tue Mar 18 08:14:41 2025]   FSC = 0x07: level 3 translation fault
          [Tue Mar 18 08:14:41 2025] Data abort info:
          [Tue Mar 18 08:14:41 2025]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
          [Tue Mar 18 08:14:41 2025]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
          [Tue Mar 18 08:14:41 2025]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
          [Tue Mar 18 08:14:41 2025] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
          [Tue Mar 18 08:14:41 2025] [ffffc00080aa3f04] pgd=100000000619c003, p4d=100000000619c003, pud=100000000619c003, pmd=10000000061a0003, pte=0000000000000000
          [Tue Mar 18 08:14:41 2025] Internal error: Oops: 0000000096000047 [#1] PREEMPT SMP
          [Tue Mar 18 08:14:41 2025] Code: d503201f b50000e2 14000020 38401423 (39000003)
            A.
            N Offline
            N Offline
            nilli
            Kann mir jemand einen Tip geben wie ich
            https://github.com/asgothian/ioBroker.zigbee/tarball/2.1.0
            installiere ? Danke !
            • N nilli
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @nilli
              • Adapter anhalten (Wichtig!!!)
              • Adapter Seite aufrufen
              • Experten modus aktivieren (1)
              • Installation mit der 'Katze' (2)
              • Benutzerdefiniert auswählen
              • Link hinein kopieren
              • Installieren
              A.
              Nachtrag: Ich hatte einen Link auf den Post zum Testen der 2.0.x Version gegeben - da stand auch drin von wo die 'standard' 2.0.x zu installieren sind - diese sind im Latest verfügbar.
              Ich hoffe Du hast diesen Post gelesen.
              • arteckA Offline
                arteckA Offline
                arteck
                https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                • arteckA arteck
                  N Offline
                  N Offline
                  nilli
                  @arteck
                  Super ! Danke :-) Wenn man weiss wie es geht ganz einfach.
                  Adapter 2.0.4 installiert und konfiguriert.
                  Leider immer noch kein Erfolg ...
                  2025-03-19 21:43:52.019 - info: host.raspi5 iobroker exit 0
                  2025-03-19 21:43:53.877 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                  2025-03-19 21:43:54.259 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112722
                  2025-03-19 21:43:55.356 - info: zigbee.1 (112722) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                  2025-03-19 21:43:55.365 - info: zigbee.1 (112722) init localConfig
                  2025-03-19 21:43:55.368 - error: zigbee.1 (112722) Serial port not selected! Go to settings page.
                  2025-03-19 21:43:55.369 - info: zigbee.1 (112722) --> transmitPower : normal
                  2025-03-19 21:43:55.371 - info: zigbee.1 (112722) --- creating device debug ---
                  2025-03-19 21:47:34.730 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
                  2025-03-19 21:47:34.733 - info: zigbee.1 (112722) Got terminate signal TERMINATE_YOURSELF
                  2025-03-19 21:47:34.734 - info: zigbee.1 (112722) cleaned everything up...
                  2025-03-19 21:47:34.735 - info: zigbee.1 (112722) local config saved
                  2025-03-19 21:47:34.737 - info: zigbee.1 (112722) Saved local configuration data
                  2025-03-19 21:47:34.738 - info: zigbee.1 (112722) terminating
                  2025-03-19 21:47:34.739 - info: zigbee.1 (112722) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-19 21:47:34.743 - error: zigbee.1 (112722) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                  at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:263:35)
                  at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:690:33)
                  at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:664:24)
                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                  at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1070:17)
                  2025-03-19 21:47:34.744 - warn: zigbee.1 (112722) Failed to stop zigbee during startup
                  2025-03-19 21:47:34.744 - info: zigbee.1 (112722) terminating
                  2025-03-19 21:47:35.241 - info: zigbee.1 (112722) terminating
                  2025-03-19 21:47:35.269 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-19 21:47:38.427 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112848
                  2025-03-19 21:47:39.389 - info: zigbee.1 (112848) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                  2025-03-19 21:47:39.398 - info: zigbee.1 (112848) init localConfig
                  2025-03-19 21:47:39.401 - info: zigbee.1 (112848) --> transmitPower : normal
                  2025-03-19 21:47:39.403 - info: zigbee.1 (112848) --- creating device debug ---
                  • N nilli
                    @arteck
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @nilli hast du versucht das zigbee-subsystem direkt aus dem Admin-Interface zu starten, wie das im Post beschrieben ist, oder hast du einfach nur den Haken bei ‘automatisch starten’ gesetzt ?
                    A.
                      A.
                      N Offline
                      N Offline
                      nilli
                      @asgothian
                      'start the Network automaticly' ist in den Instanzeneinstellungen nicht gesetzt.
                      Ich habe den Adapter im 'instanzen' Menue gestartet.
                      2025-03-19 22:08:47.638 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                      2025-03-19 22:08:50.036 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                      2025-03-19 22:08:52.842 - info: host.raspi5 "system.adapter.zigbee.1" enabled
                      2025-03-19 22:08:53.076 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 113695
                      2025-03-19 22:08:54.050 - info: zigbee.1 (113695) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                      2025-03-19 22:08:54.060 - info: zigbee.1 (113695) init localConfig
                      2025-03-19 22:08:54.063 - info: zigbee.1 (113695) --> transmitPower : normal
                      2025-03-19 22:08:54.066 - info: zigbee.1 (113695) --- creating device debug ---
                      • N nilli
                        @asgothian
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @nilli dann lies nochmal was ich oben geschrieben habe.
                        Eine wichtige Eigenschaft dieser Version ist das das zigbee subsystem nicht automatisch gestartet wird. Du kannst (und sollst) versuchen das subsystem aus dem Admin zu starten um a die Meldungen vom Start zu kommen. Wenn du das nicht machst bleibt der Adapter “gelb”
                          N Offline
                          N Offline
                          nilli
                          @asgothian
                          Danke für Deine Hilfe.
                          Ich habe den Start/Stop button in der Instanzeinstellung benutzt.
                          Ich hoffe das war, was Du meintest.
                          • N nilli
                            @asgothian
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            @nilli Das sieht besser aus, aber nicht gut - das USB Device wird vom Zigbee-Herdsman nicht sauber akzeptiert.
                            halte das Zigbee-Subsystem bitte wieder an (start/stop nochmal drücken) und setz dann den haken beim flow control. Danach noch einmal starten.
                            A.
                              A.
                              N Offline
                              N Offline
                              nilli
                              @asgothian
                              Einmal gedrückt, wird der Start/Stop Button ausgegraut und hat keine Funktion mehr.
                              Extern angehalten, flow control aktiviert und neu gestartet :
                              2025-03-20 21:03:28.458 - info: zigbee.1 (164560) --- creating device debug ---
                              2025-03-20 21:03:30.876 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                              2025-03-20 21:03:33.961 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
                              2025-03-20 21:03:33.963 - info: zigbee.1 (164560) Got terminate signal TERMINATE_YOURSELF
                              2025-03-20 21:03:33.964 - info: zigbee.1 (164560) cleaned everything up...
                              2025-03-20 21:03:33.965 - info: zigbee.1 (164560) local config saved
                              2025-03-20 21:03:33.965 - info: zigbee.1 (164560) Saved local configuration data
                              2025-03-20 21:03:33.966 - info: zigbee.1 (164560) terminating
                              2025-03-20 21:03:33.967 - info: zigbee.1 (164560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2025-03-20 21:03:33.970 - error: zigbee.1 (164560) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                              2025-03-20 21:03:33.971 - warn: zigbee.1 (164560) Failed to stop zigbee during startup
                              2025-03-20 21:03:33.972 - info: zigbee.1 (164560) terminating
                              2025-03-20 21:03:34.005 - info: host.raspi5 stopInstance system.adapter.zigbee.1 send kill signal
                              2025-03-20 21:03:34.467 - info: zigbee.1 (164560) terminating
                              2025-03-20 21:03:34.496 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2025-03-20 21:03:37.710 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 164576
                              2025-03-20 21:03:38.740 - info: zigbee.1 (164576) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                              2025-03-20 21:03:38.750 - info: zigbee.1 (164576) init localConfig
                              2025-03-20 21:03:38.753 - info: zigbee.1 (164576) --> transmitPower : normal
                              2025-03-20 21:03:38.755 - info: zigbee.1 (164576) --- creating device debug ---
                              • N nilli
                                @asgothian
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @nilli da bin am Ende - ich gehe relativ fest davon aus das der Stick nicht in Ordnung ist.
                                Der Aufruf in den zigbee-Herdsman läuft so wie er soll, dieser sollte nach entsprechender Wartezeit zurück kommen. Das schreint er nicht zu tun. Der Adapter macht da nichts weiter. Die übergebenen Werte sehen OK aus. Warum der Herdsman ohne weitere Meldungen nicht startet kann ich kaum sagen.
                                Als letzten Versuch kannst du:
                                • den Adapter anhalten
                                • den Adapter auf 'debug' umstellen (wichtig)
                                • in der Adapter-Konfiguration den Haken bei 'zigbee-herdsman debug info' setzen
                                • auf der Hardware-Seite versuchen den Herdsman zu starten.
                                • 10 Minuten warten - schauen ob da überhaupt etwas kommt. Wenn nicht im Log schauen ob da debug-Meldungen aufgetaucht sind.
                                A.
                                • darkbluD Offline
                                  darkbluD Offline
                                  darkblu
                                  schrieb am zuletzt editiert von darkblu
                                  Selbigen Fehler wie der Threadersteller hatte ich gestern auch.
                                  Und zwar nachdem es 9 updates für den Raspi gab.
                                  Danach wurde der Adapter einfach nicht grün.
                                  Neustart und stromlos machen hatte alles nix geholfen.
                                  Dann habe ich „iob fix, iob update, iob upgrade self (?)“
                                  (oder so ähnlich) und sudo reboot gemacht und erst danach wurde der Zigbee Adapter wieder grün.
                                  War wieder ein sehr aufregender Abend 😰
                                  Raspi 4, 4GB für Influxdb 1.8 und Grafana
                                  Raspi 5, 8 GB für ioBroker
                                  Threadnetzwerk per Apple
