  3. Einsteigerfragen
  4. Installation
  5. Zigbee.0: You need save and run adapter before pairing!
    5.3k
51 Beiträge 8 Kommentatoren 6.9k Aufrufe 7 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    @nilli sagte in Zigbee.0: You need save and run adapter before pairing!:
    Kann mir jemand einen Tip geben wie ich
    https://github.com/asgothian/ioBroker.zigbee/tarball/2.1.0
    installiere ? Danke !
    https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
    N 1 Antwort Letzte Antwort
    • arteckA arteck
      N Offline
      N Offline
      nilli
      @arteck
      Super ! Danke :-) Wenn man weiss wie es geht ganz einfach.
      Adapter 2.0.4 installiert und konfiguriert.
      Leider immer noch kein Erfolg ...
      2025-03-19 21:43:52.019 - info: host.raspi5 iobroker exit 0
      2025-03-19 21:43:53.877 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
      2025-03-19 21:43:54.259 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112722
      2025-03-19 21:43:55.356 - info: zigbee.1 (112722) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
      2025-03-19 21:43:55.365 - info: zigbee.1 (112722) init localConfig
      2025-03-19 21:43:55.368 - error: zigbee.1 (112722) Serial port not selected! Go to settings page.
      2025-03-19 21:43:55.369 - info: zigbee.1 (112722) --> transmitPower : normal
      2025-03-19 21:43:55.371 - info: zigbee.1 (112722) --- creating device debug ---
      2025-03-19 21:47:34.730 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
      2025-03-19 21:47:34.733 - info: zigbee.1 (112722) Got terminate signal TERMINATE_YOURSELF
      2025-03-19 21:47:34.734 - info: zigbee.1 (112722) cleaned everything up...
      2025-03-19 21:47:34.735 - info: zigbee.1 (112722) local config saved
      2025-03-19 21:47:34.737 - info: zigbee.1 (112722) Saved local configuration data
      2025-03-19 21:47:34.738 - info: zigbee.1 (112722) terminating
      2025-03-19 21:47:34.739 - info: zigbee.1 (112722) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-19 21:47:34.743 - error: zigbee.1 (112722) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
      at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:263:35)
      at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:690:33)
      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:664:24)
      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1070:17)
      2025-03-19 21:47:34.744 - warn: zigbee.1 (112722) Failed to stop zigbee during startup
      2025-03-19 21:47:34.744 - info: zigbee.1 (112722) terminating
      2025-03-19 21:47:35.241 - info: zigbee.1 (112722) terminating
      2025-03-19 21:47:35.269 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-03-19 21:47:38.427 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112848
      2025-03-19 21:47:39.389 - info: zigbee.1 (112848) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
      2025-03-19 21:47:39.398 - info: zigbee.1 (112848) init localConfig
      2025-03-19 21:47:39.401 - info: zigbee.1 (112848) --> transmitPower : normal
      2025-03-19 21:47:39.403 - info: zigbee.1 (112848) --- creating device debug ---
      • N nilli
        @arteck
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @nilli hast du versucht das zigbee-subsystem direkt aus dem Admin-Interface zu starten, wie das im Post beschrieben ist, oder hast du einfach nur den Haken bei ‘automatisch starten’ gesetzt ?
        A.
        • AsgothianA Asgothian
          A.
          N Offline
          N Offline
          nilli
          schrieb am zuletzt editiert von nilli
          @asgothian
          'start the Network automaticly' ist in den Instanzeneinstellungen nicht gesetzt.
          Ich habe den Adapter im 'instanzen' Menue gestartet.
          2025-03-19 22:08:47.638 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
          2025-03-19 22:08:50.036 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
          2025-03-19 22:08:52.842 - info: host.raspi5 "system.adapter.zigbee.1" enabled
          2025-03-19 22:08:53.076 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 113695
          2025-03-19 22:08:54.050 - info: zigbee.1 (113695) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
          2025-03-19 22:08:54.060 - info: zigbee.1 (113695) init localConfig
          2025-03-19 22:08:54.063 - info: zigbee.1 (113695) --> transmitPower : normal
          2025-03-19 22:08:54.066 - info: zigbee.1 (113695) --- creating device debug ---
          • N nilli
            @asgothian
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @nilli dann lies nochmal was ich oben geschrieben habe.
            Eine wichtige Eigenschaft dieser Version ist das das zigbee subsystem nicht automatisch gestartet wird. Du kannst (und sollst) versuchen das subsystem aus dem Admin zu starten um a die Meldungen vom Start zu kommen. Wenn du das nicht machst bleibt der Adapter “gelb”
              N Offline
              N Offline
              nilli
              @asgothian
              Danke für Deine Hilfe.
              Ich habe den Start/Stop button in der Instanzeinstellung benutzt.
              Ich hoffe das war, was Du meintest.
              • N nilli
                @asgothian
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @nilli Das sieht besser aus, aber nicht gut - das USB Device wird vom Zigbee-Herdsman nicht sauber akzeptiert.
                halte das Zigbee-Subsystem bitte wieder an (start/stop nochmal drücken) und setz dann den haken beim flow control. Danach noch einmal starten.
                A.
                  A.
                  N Offline
                  N Offline
                  nilli
                  @asgothian
                  Einmal gedrückt, wird der Start/Stop Button ausgegraut und hat keine Funktion mehr.
                  Extern angehalten, flow control aktiviert und neu gestartet :
                  2025-03-20 21:03:28.458 - info: zigbee.1 (164560) --- creating device debug ---
                  2025-03-20 21:03:30.876 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                  2025-03-20 21:03:33.961 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
                  2025-03-20 21:03:33.963 - info: zigbee.1 (164560) Got terminate signal TERMINATE_YOURSELF
                  2025-03-20 21:03:33.964 - info: zigbee.1 (164560) cleaned everything up...
                  2025-03-20 21:03:33.965 - info: zigbee.1 (164560) local config saved
                  2025-03-20 21:03:33.965 - info: zigbee.1 (164560) Saved local configuration data
                  2025-03-20 21:03:33.966 - info: zigbee.1 (164560) terminating
                  2025-03-20 21:03:33.967 - info: zigbee.1 (164560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-03-20 21:03:33.970 - error: zigbee.1 (164560) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                  2025-03-20 21:03:33.971 - warn: zigbee.1 (164560) Failed to stop zigbee during startup
                  2025-03-20 21:03:33.972 - info: zigbee.1 (164560) terminating
                  2025-03-20 21:03:34.005 - info: host.raspi5 stopInstance system.adapter.zigbee.1 send kill signal
                  2025-03-20 21:03:34.467 - info: zigbee.1 (164560) terminating
                  2025-03-20 21:03:34.496 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-03-20 21:03:37.710 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 164576
                  2025-03-20 21:03:38.740 - info: zigbee.1 (164576) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                  2025-03-20 21:03:38.750 - info: zigbee.1 (164576) init localConfig
                  2025-03-20 21:03:38.753 - info: zigbee.1 (164576) --> transmitPower : normal
                  2025-03-20 21:03:38.755 - info: zigbee.1 (164576) --- creating device debug ---
                  • N nilli
                    @asgothian
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @nilli da bin am Ende - ich gehe relativ fest davon aus das der Stick nicht in Ordnung ist.
                    Der Aufruf in den zigbee-Herdsman läuft so wie er soll, dieser sollte nach entsprechender Wartezeit zurück kommen. Das schreint er nicht zu tun. Der Adapter macht da nichts weiter. Die übergebenen Werte sehen OK aus. Warum der Herdsman ohne weitere Meldungen nicht startet kann ich kaum sagen.
                    Als letzten Versuch kannst du:
                    • den Adapter anhalten
                    • den Adapter auf 'debug' umstellen (wichtig)
                    • in der Adapter-Konfiguration den Haken bei 'zigbee-herdsman debug info' setzen
                    • auf der Hardware-Seite versuchen den Herdsman zu starten.
                    • 10 Minuten warten - schauen ob da überhaupt etwas kommt. Wenn nicht im Log schauen ob da debug-Meldungen aufgetaucht sind.
                    A.
                    • darkbluD Offline
                      darkbluD Offline
                      darkblu
                      schrieb am zuletzt editiert von darkblu
                      Selbigen Fehler wie der Threadersteller hatte ich gestern auch.
                      Und zwar nachdem es 9 updates für den Raspi gab.
                      Danach wurde der Adapter einfach nicht grün.
                      Neustart und stromlos machen hatte alles nix geholfen.
                      Dann habe ich „iob fix, iob update, iob upgrade self (?)“
                      (oder so ähnlich) und sudo reboot gemacht und erst danach wurde der Zigbee Adapter wieder grün.
                      War wieder ein sehr aufregender Abend 😰
                      Raspi 4, 4GB für Influxdb 1.8 und Grafana
                      Raspi 5, 8 GB für ioBroker
                      Threadnetzwerk per Apple
