  3. Off Topic
  4. Proxmox
  5. Problem mit unzureichendem Speicherplatz
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
32 Beiträge 8 Kommentatoren 4.3k Aufrufe 6 Beobachtet
  • B bastler
    @homoran so jetzt noch einmal alles
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-31-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
    OS is similar to:
    model name	: Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
    CPU threads: 16
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-10 11:12:49 CET
               Universal time: Mon 2025-03-10 10:12:49 UTC
                     RTC time: Mon 2025-03-10 10:12:49
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    ingo
    HOME=/home/ingo
    GROUPS=ingo adm cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:             11G        3.7G        7.4G        585K        982M        8.1G
    Swap:           1.0G          0B        1.0G
    Total:           12G        3.7G        8.4G
    Active iob-Instances: 	45
            11265 M total memory
             3557 M used memory
              422 M active memory
             3459 M inactive memory
             7048 M free memory
              125 M buffer memory
              811 M swap cache
              974 M total swap
                0 M used swap
              974 M free swap
    top - 11:12:49 up  1:57,  2 users,  load average: 0.13, 0.19, 0.18
    Tasks: 180 total,   1 running, 179 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :  11265.7 total,   7048.9 free,   3557.6 used,    936.9 buff/cache
    MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7708.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  5.5G     0  5.5G   0% /dev
    tmpfs          tmpfs     1.2G  576K  1.1G   1% /run
    /dev/sda1      ext4       31G   29G  470M  99% /
    tmpfs          tmpfs     5.6G     0  5.6G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.2G     0  1.2G   0% /run/user/1000
    [Mon Mar 10 09:15:15 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Mar 10 09:15:16 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.6G	/var/
    975M	/var/log
    890M	/var/log/journal/00d6058392fa44d3b60e2dcfbf39a290
    427M	/var/cache
    Archived and active journals take up 889.8M in the file system.
    /opt/iobroker/backups:
    13G	/opt/iobroker/backups/
    516K	/opt/iobroker/backups/grafana_tmp
    264K	/opt/iobroker/backups/grafana_tmp/dashboards
    240K	/opt/iobroker/backups/grafana_tmp/dashboards_manually_restore
    8.0K	/opt/iobroker/backups/grafana_tmp/datasource
    /opt/iobroker/iobroker-data:
    1.9G	/opt/iobroker/iobroker-data/
    1.3G	/opt/iobroker/iobroker-data/files
    617M	/opt/iobroker/iobroker-data/files/javascript.admin
    560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
    558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
    52M	/opt/iobroker/iobroker-data/objects.jsonl
    38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.3
    /usr/bin/node 		v20.18.3
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 7038)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		7.4.10
    javascript: 	8.8.3
    nodejs modules from github: 	2
    +-- iobroker.deyeidc@0.2.0 (git+ssh://git@github.com/raschy/ioBroker.deyeidc.git#0504bb34191750e47bfb509c3c9fb08aef980eb2)
    +-- iobroker.zigbee@2.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#0a1913bc5e2c61db265a338e6474ed367959dc49)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : ioBroker                                 -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.esphome.0                : esphome               : ioBroker                                 -  enabled
      system.adapter.espresense.0             : espresense            : ioBroker                                 - disabled
    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.nut.0                    : nut                   : ioBroker                                 - disabled
    + system.adapter.opendtu.0                : opendtu               : ioBroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
      system.adapter.philips-air.0            : philips-air           : ioBroker                                 - disabled
      system.adapter.powerfox2.0              : powerfox2             : ioBroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
    + system.adapter.reolink.0                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.1                : reolink               : ioBroker                                 -  enabled
    + system.adapter.reolink.2                : reolink               : ioBroker                                 -  enabled
    + system.adapter.sayit.0                  : sayit                 : ioBroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.statistics.0             : statistics            : ioBroker                                 -  enabled
    + system.adapter.tahoma.0                 : tahoma                : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      system.adapter.weatherunderground.1     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2191141-if00
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "espresense"   : 0.4.8    , installed 0.4.8
    Adapter    "fb-checkpresence": 1.2.8 , installed 1.2.8
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
    Adapter    "powerfox2"    : 0.0.14   , installed 0.0.14
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "reolink"      : 1.2.1    , installed 1.2.1
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tahoma"       : 0.10.4   , installed 0.10.4
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Adapter    "terminal"     : 1.0.0    , installed 1.0.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
    Adapter    "wireless-settings": 1.0.2, installed 1.0.2
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "zigbee"       : 1.10.14  , installed 2.0.3
    Objects and States
    Objects: 	18065
    States: 	15235
    Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://repos.influxdata.com/debian stable InRelease
    Hit:5 https://repos.influxdata.com/debian bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1262       656/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1257       656/iobroker.js-con
    tcp        0      0 127.0.0.1:42623         0.0.0.0:*               LISTEN      1001       19344      1824/io.yahka.0
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       24041      1710/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22094      569/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          15551      1/init
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       18952      937/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1599       982/io.shelly.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       20733      861/io.mqtt.0
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        19727      607/influxd
    tcp6       0      0 :::8086                 :::*                    LISTEN      998        15701      607/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18830      675/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21180      1665/io.web.0
    tcp6       0      0 :::45127                :::*                    LISTEN      1001       744        1824/io.yahka.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       1414       891/io.sonos.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          22096      569/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13349      1/init
    tcp6       0      0 :::41289                :::*                    LISTEN      1001       746        1824/io.yahka.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24254      1965/io.esphome.0
    udp        0      0 192.168.178.186:5353    0.0.0.0:*                           1001       13685      906/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           105        19711      544/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       19851      876/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       548        1083/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       549        1083/io.tuya.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          215        421/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18577      1/init
    udp        0      0 0.0.0.0:58779           0.0.0.0:*                           105        19713      544/avahi-daemon: r
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1411       846/io.mihome-vacuu
    udp6       0      0 :::5353                 :::*                                105        19712      544/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          17808      1/init
    udp6       0      0 :::33044                :::*                                105        19714      544/avahi-daemon: r
    2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 472
    2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
    2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1675.1
    2025-03-10 11:13:04.142  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC unten = 472
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 225.1
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1672.1
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC oben = 978
    2025-03-10 11:13:04.147  - info: javascript.0 (741) script.js.PV_Funktionen.PV_ges._Dach: Leistung DC gesamt = 1447
    2025-03-10 11:13:04.236  - debug: deyeidc.0 (1098) Response: (payload) {"register":7,"modbus":{"type":"Buffer","data":[1,3,6,0,80,0,100,255,255,161]}}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) Data reception for 7 registersets completed
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_Leistung+PV2_Leistung","key":"PV1_PV2_Leistung","name":"PV1+PV2 - Leistung","unit":"W","factor":0}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung+P_GEN_TOTAL","key":"PV_Gesamtleistung","name":"PV - Gesamtleistung","unit":"W","factor":0}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"P_BACKUP_LOAD_TOTAL+0","key":"Hausverbrauch","name":"Hausverbrauch","unit":"W","factor":0}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Day_PV_Power_Wh-Day_GridSell_Power_Wh","key":"Day_Eigenverbrauch","name":"Day Eigenverbrauch","unit":"kWh","factor":0}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"PV1_PV2_Leistung*2","key":"PV_Gesamt-Cluster","name":"PV_Gesamt-Cluster","unit":"W","factor":0}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData]  {"values":"Battery_Level*12.5/100","key":"Batterieladung","name":"Batterieladung","unit":"kWh","factor":2}
    2025-03-10 11:13:04.239  - debug: deyeidc.0 (1098) [computeData] ResultJson: [{"key":"PV1_PV2_Leistung","value":"1447.00","unit":"W","name":"PV1+PV2 - Leistung"},{"key":"PV_Gesamtleistung","value":"1456.00","unit":"W","name":"PV - Gesamtleistung"},{"key":"Hausverbrauch","value":"175.00","unit":"W","name":"Hausverbrauch"},{"key":"Day_Eigenverbrauch","value":"3.80","unit":"kWh","name":"Day Eigenverbrauch"},{"key":"PV_Gesamt_Cluster","value":"2912.00","unit":"W","name":"PV_Gesamt-Cluster"},{"key":"Batterieladung","value":"9.50","unit":"kWh","name":"Batterieladung"}]
    2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: Ost_Gesamt = 123.4
    2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.Ost_West_zusammenfassung: West_Gesamt113.19999999999999
    2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 978
    2025-03-10 11:13:06.927  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 469
    2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: 224.9
    2025-03-10 11:13:06.928  - info: javascript.0 (741) script.js.PV_Funktionen.PV_Gesamtl.PV_Gesamtl._beide_Anlagen: Gesamtleistung alle Anlagen = 1671.9
    @bastler
    hast du vielleicht in der gleichen VM noch andere Anwendungen installiert, ausser iobroker?
    Influx vielleicht?
    • B bastler
      Script v.2025-02-23
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 16
                    NTP service: active
                RTC in local TZ: no
      ingo
      HOME=/home/ingo
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
               3557 M used memory
                422 M active memory
               7048 M free memory
                125 M buffer memory
                811 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      *** FILESYSTEM ***
      /var:
      1.6G	/var/
      975M	/var/log
      427M	/var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		7.4.10
      javascript: 	8.8.3
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	18065
      States: 	15235
      Pending Updates: 0
      CodierknechtC Offline
      Codierknecht
      @bastler
      Da liegen noch 13 GB in Backups.
      Außerdem bootest Du nach graphical.target. Bewusst? Ansonsten solltest Du den Hinweis auch ernst nehmen.
      HmIP|ZigBee|Tasmota|Unifi
      Zabbix Certified Specialist
        @bastler
        Influx vielleicht?
        bastler
        @neuschwansteini Ja, die läuft in einer eigenen VM.
        CodierknechtC ? 2 Antworten Letzte Antwort
        • B bastler
          Codierknecht
          @bastler sagte in Problem mit unzureichendem Speicherplatz:
          Dann hat influx ja auch sein eigenes Dateisystem.
          • B bastler
            @bastler
            wie @Codierknecht schon sagte.. da liegen 13GB im Backup.. deine 32GB VM ist daher zu 99% voll..
            also die Backups mal dahin schaffen, wo se hingehoeren..
              @bastler
              bastler
              schrieb am zuletzt editiert von bastler
              @neuschwansteini
              Dann ist es kein Wunder 😵 Nur woher kommt die Umstellung?
              === Mark text until here for copying ===
              ingo@ioBroker:~$ /opt/iobroker/backups/
              -bash: /opt/iobroker/backups/: Ist ein Verzeichnis
              ingo@ioBroker:~$ cd /opt/iobroker/backups/
              ingo@ioBroker:/opt/iobroker/backups$ dir
              grafana_2024_11_08-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_13-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_16-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_01_22-03_35_54_backupiobroker.tar.gz	   zigbee.0_2024_11_09-03_35_43_backupiobroker.tar.gz
              grafana_2024_11_09-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_14-03_35_13_backupiobroker.tar.gz	iobroker_2024_12_17-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_05-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_10-03_35_43_backupiobroker.tar.gz
              grafana_2024_11_10-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_15-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_02-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_21-03_35_52_backupiobroker.tar.gz	   zigbee.0_2024_11_11-03_35_47_backupiobroker.tar.gz
              grafana_2024_11_11-03_35_47_backupiobroker.tar.gz   influxDB_2024_11_16-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_11-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_02_26-03_35_50_backupiobroker.tar.gz	   zigbee.0_2024_11_12-03_35_44_backupiobroker.tar.gz
              grafana_2024_11_12-03_35_45_backupiobroker.tar.gz   influxDB_2024_11_26-03_35_13_backupiobroker.tar.gz	iobroker_2025_01_22-03_35_10_backupiobroker.tar.gz  jarvis.0_2025_03_08-03_35_37_backupiobroker.tar.gz	   zigbee.0_2024_11_13-03_35_44_backupiobroker.tar.gz
              grafana_2024_11_13-03_35_44_backupiobroker.tar.gz   influxDB_2024_11_29-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_05-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_08-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_14-03_35_43_backupiobroker.tar.gz
              grafana_2024_11_14-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_16-03_35_14_backupiobroker.tar.gz	iobroker_2025_02_21-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_09-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_11_15-03_35_42_backupiobroker.tar.gz
              grafana_2024_11_15-03_35_43_backupiobroker.tar.gz   influxDB_2024_12_17-03_35_15_backupiobroker.tar.gz	iobroker_2025_02_26-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_10-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_16-03_35_45_backupiobroker.tar.gz
              grafana_2024_11_16-03_35_45_backupiobroker.tar.gz   influxDB_2025_01_02-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_08-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_11-03_35_53_backupiobroker.tar.gz  zigbee.0_2024_11_26-03_35_46_backupiobroker.tar.gz
              grafana_2024_11_26-03_35_46_backupiobroker.tar.gz   influxDB_2025_01_11-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_09-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_12-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_11_29-03_35_47_backupiobroker.tar.gz
              grafana_2024_11_29-03_35_47_backupiobroker.tar.gz   influxDB_2025_01_22-03_35_15_backupiobroker.tar.gz	iobroker_2025_03_10-03_35_10_backupiobroker.tar.gz  javascripts_2024_11_13-03_35_50_backupiobroker.tar.gz  zigbee.0_2024_12_16-03_35_50_backupiobroker.tar.gz
              grafana_2024_12_16-03_35_51_backupiobroker.tar.gz   influxDB_2025_02_05-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_08-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_14-03_35_49_backupiobroker.tar.gz  zigbee.0_2024_12_17-03_35_46_backupiobroker.tar.gz
              grafana_2024_12_17-03_35_47_backupiobroker.tar.gz   influxDB_2025_02_21-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_09-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_15-03_35_48_backupiobroker.tar.gz  zigbee.0_2025_01_02-03_35_48_backupiobroker.tar.gz
              grafana_2025_01_02-03_35_49_backupiobroker.tar.gz   influxDB_2025_02_26-03_35_15_backupiobroker.tar.gz	jarvis.0_2024_11_10-03_35_49_backupiobroker.tar.gz  javascripts_2024_11_16-03_35_51_backupiobroker.tar.gz  zigbee.0_2025_01_11-03_35_48_backupiobroker.tar.gz
              grafana_2025_01_11-03_35_49_backupiobroker.tar.gz   influxDB_2025_03_08-03_35_14_backupiobroker.tar.gz	jarvis.0_2024_11_11-03_35_52_backupiobroker.tar.gz  javascripts_2024_11_26-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_01_22-03_35_49_backupiobroker.tar.gz
              grafana_2025_01_22-03_35_49_backupiobroker.tar.gz   iobroker_2024_11_08-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_12-03_35_50_backupiobroker.tar.gz  javascripts_2024_11_29-03_35_53_backupiobroker.tar.gz  zigbee.0_2025_02_05-03_35_45_backupiobroker.tar.gz
              grafana_2025_02_05-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_09-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_13-03_35_49_backupiobroker.tar.gz  javascripts_2024_12_16-03_35_56_backupiobroker.tar.gz  zigbee.0_2025_02_21-03_35_46_backupiobroker.tar.gz
              grafana_2025_02_21-03_35_47_backupiobroker.tar.gz   iobroker_2024_11_10-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_14-03_35_48_backupiobroker.tar.gz  javascripts_2024_12_17-03_35_52_backupiobroker.tar.gz  zigbee.0_2025_02_26-03_35_45_backupiobroker.tar.gz
              grafana_2025_02_26-03_35_45_backupiobroker.tar.gz   iobroker_2024_11_11-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_15-03_35_48_backupiobroker.tar.gz  javascripts_2025_01_02-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_08-03_35_32_backupiobroker.tar.gz
              grafana_2025_03_08-03_35_32_backupiobroker.tar.gz   iobroker_2024_11_12-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_16-03_35_50_backupiobroker.tar.gz  javascripts_2025_01_11-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_09-03_35_21_backupiobroker.tar.gz
              grafana_tmp					    iobroker_2024_11_13-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_26-03_35_51_backupiobroker.tar.gz  javascripts_2025_01_22-03_35_55_backupiobroker.tar.gz  zigbee.0_2025_03_10-03_35_24_backupiobroker.tar.gz
              influxDB_2024_11_08-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_14-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_11_29-03_35_53_backupiobroker.tar.gz  javascripts_2025_02_05-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_08-03_35_32_backupiobroker.tar.gz
              influxDB_2024_11_09-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_15-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_16-03_35_56_backupiobroker.tar.gz  javascripts_2025_02_21-03_35_52_backupiobroker.tar.gz  zigbee.1_2025_03_09-03_35_21_backupiobroker.tar.gz
              influxDB_2024_11_10-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_16-03_35_10_backupiobroker.tar.gz	jarvis.0_2024_12_17-03_35_52_backupiobroker.tar.gz  javascripts_2025_02_26-03_35_51_backupiobroker.tar.gz  zigbee.1_2025_03_10-03_35_24_backupiobroker.tar.gz
              influxDB_2024_11_11-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_26-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_02-03_35_54_backupiobroker.tar.gz  javascripts_2025_03_08-03_35_38_backupiobroker.tar.gz
              influxDB_2024_11_12-03_35_13_backupiobroker.tar.gz  iobroker_2024_11_29-03_35_10_backupiobroker.tar.gz	jarvis.0_2025_01_11-03_35_54_backupiobroker.tar.gz  zigbee.0_2024_11_08-03_35_44_backupiobroker.tar.gz
              • B bastler
                @neuschwansteini
                Codierknecht
                @bastler
                Treten beim Backup Fehler auf?
                Dann werden die Dateien nicht aufs NAS geschoben.
                • B bastler
                  @codierknecht
                  *** MEMORY ***
                  Swap:           1.0G          0B        1.0G
                           3557 M used memory
                            422 M active memory
                           7048 M free memory
                            125 M buffer memory
                            811 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  *** FILESYSTEM ***
                  @bastler sagte:
                  • CodierknechtC Codierknecht
                    @bastler
                    bastler
                    @codierknecht Hatte gerade versucht vom Backup Adapter aus eine neue Sicherung durchzuführen. Da gab es eine Fehlermeldung bei der Influx Sicherung. Nach einem 2. Durchlauf sieht es jetzt wie unten dargestellt aus. Es scheint, das alle Daten eben nur lokal gesichert werden?
                    Die Einstellungen in der Backup Instanz sieht so aus.
                    11:43:20.780INFOguiBackup gestartet ...
                    11:43:22.899DEBUGiobrokerhost.ioBroker 18075 objects saved
                    11:43:23.531DEBUGiobrokerhost.ioBroker 15235 states saved
                    11:43:23.533DEBUGiobrokerhost.ioBroker Validating backup ...
                    11:43:23.576DEBUGiobrokerhost.ioBroker "config.json" is valid
                    11:43:23.579DEBUGiobrokerhost.ioBroker "objects.jsonl" exists
                    11:43:23.664DEBUGiobrokerhost.ioBroker "states.jsonl" exists
                    11:43:23.826DEBUGiobrokerhost.ioBroker JSONL lines are valid
                    11:43:23.830DEBUGiobrokerhost.ioBroker The backup is valid!
                    11:43:24.212DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz
                    11:43:24.217DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                    11:43:25.226DEBUGiobrokerdone
                    11:43:25.379DEBUGinfluxDBInfluxDB-Backup started ...
                    11:43:25.382DEBUGinfluxDBInfluxDB Backup tmp directory created
                    11:43:28.329DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker"
                    11:43:28.352DEBUGinfluxDB2025/03/10 11:43:25 backing up metastore to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/meta.00
                    2025/03/10 11:43:25 backing up db=iobroker
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1283 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01283.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1291 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01291.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1299 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01299.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1307 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01307.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1315 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01315.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1323 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01323.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1331 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01331.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1339 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01339.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1347 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01347.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1355 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01355.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1363 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01363.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1371 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01371.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1379 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01379.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1387 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01387.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1395 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01395.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1403 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01403.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1411 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01411.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1419 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01419.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1427 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01427.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1435 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01435.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1443 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01443.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1451 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01451.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1459 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01459.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1467 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01467.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1475 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01475.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1483 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01483.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1491 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01491.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1499 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01499.00 since 0001-01-01T00:00:00Z
                    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1507 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01507.00 since 0001-01-01T00:00:00Z
                    11:43:28.401DEBUGinfluxDBdone
                    11:43:29.246DEBUGzigbeefound zigbee database: zigbee.0,zigbee.1
                    11:43:29.289DEBUGzigbeedone
                    11:43:29.550DEBUGgrafanaStart Grafana Backup ...
                    11:43:29.553DEBUGgrafanaCreated dashboards_manually_restore directory
                    11:43:29.557DEBUGgrafanastart Grafana request ...
                    11:43:29.599DEBUGgrafanaGrafana is available ... Status: 200
                    11:43:29.603DEBUGgrafanafound Dashboard: heizung
                    11:43:29.605DEBUGgrafanafound Dashboard: new-dashboard-copy
                    11:43:29.608DEBUGgrafanafound Dashboard: espeasy-2
                    11:43:29.652DEBUGgrafanafound Dashboard: 1-dashboard
                    11:43:29.712DEBUGgrafanastart Grafana backup compress ...
                    11:43:34.723DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                    11:43:34.769DEBUGgrafanadone
                    11:43:34.875DEBUGjarvisCreated jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
                    11:43:34.878DEBUGjarvisfound Jarvis Instance: 0
                    11:43:34.892DEBUGjarvisstart Jarvis Backup for Instance 0...
                    11:43:34.893DEBUGjarvis/opt/iobroker/iobroker-data/jarvis/0 copy success!
                    11:43:34.924DEBUGjarvisCreated states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
                    11:43:35.025DEBUGjarvisTry deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
                    11:43:35.030DEBUGjarvisJarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
                    11:43:35.071DEBUGjarvisBackup created: /opt/iobroker/backups/jarvis.0_2025_03_10-11_43_34_backupiobroker.tar.gz
                    11:43:35.073DEBUGjarvisdone
                    11:43:35.345DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
                    11:43:35.408DEBUGjavascriptsfound Script: Wama_und_Trockner_Meldung
                    11:43:35.516DEBUGjavascriptsfound Script: Alias_anlegen
                    11:43:35.667DEBUGjavascriptsfound Script: Gaszähler
                    11:43:35.818DEBUGjavascriptsfound Script: Stromüberschuss3
                    11:43:35.969DEBUGjavascriptsfound Script: Wasserverbrauch2
                    11:43:36.120DEBUGjavascriptsfound Script: Stromüberschuss_Kühlschank
                    11:43:36.271DEBUGjavascriptsfound Script: Wasserverbrauch
                    11:43:36.422DEBUGjavascriptsfound Script: Gasverbrauch
                    11:43:36.572DEBUGjavascriptsfound Script: Einspeisung
                    11:43:36.723DEBUGjavascriptsfound Script: Brunnenwasser
                    11:43:36.875DEBUGjavascriptsfound Script: Nur_Brunnenwasser
                    11:43:37.026DEBUGjavascriptsfound Script: Brunnenwasser_alt
                    11:43:37.175DEBUGjavascriptsfound Script: Gesamtverbräuche
                    11:43:37.325DEBUGjavascriptsfound Script: Stromüberschuss_Heizer
                    11:43:37.475DEBUGjavascriptsfound Script: Steckdose_Robo
                    11:43:37.628DEBUGjavascriptsfound Script: Windberechnung
                    11:43:37.777DEBUGjavascriptsfound Script: Licht_Esszimmer
                    11:43:37.927DEBUGjavascriptsfound Script: Watchdog_Adapter1
                    11:43:38.083DEBUGjavascriptsfound Script: Gefrierschrank
                    11:43:38.231DEBUGjavascriptsfound Script: Drucker_an_aus
                    11:43:38.383DEBUGjavascriptsfound Script: Garage_korrigierter_Verbrauch
                    11:43:38.534DEBUGjavascriptsfound Script: Ost_West_zusammenfassung
                    11:43:38.684DEBUGjavascriptsfound Script: _beide_Anlagen
                    11:43:38.834DEBUGjavascriptsfound Script: Deckenventilator
                    11:43:38.985DEBUGjavascriptsfound Script: Stromüberschuss_Deckenlüfter_Terrasse_
                    11:43:39.135DEBUGjavascriptsfound Script: 1i
                    11:43:39.284DEBUGjavascriptsfound Script: 1j
                    11:43:39.435DEBUGjavascriptsfound Script: 1k
                    11:43:39.586DEBUGjavascriptsfound Script: Schalter_Stube_Ikea_
                    11:43:39.737DEBUGjavascriptsfound Script: Schalter_Terrasse_Ikea_
                    11:43:39.887DEBUGjavascriptsfound Script: Gewächshaus
                    11:43:40.039DEBUGjavascriptsfound Script: Stromüberschuss_Lüfter_Keller
                    11:43:40.189DEBUGjavascriptsfound Script: Shelly_Temp_Brunnenpumpe1
                    11:43:40.339DEBUGjavascriptsfound Script: Shelly_Temp_Garagenboden1
                    11:43:40.490DEBUGjavascriptsfound Script: Staubsauger_Garage
                    11:43:40.641DEBUGjavascriptsfound Script: Brunnenwasser_neu
                    11:43:40.803DEBUGjavascriptsfound Script: Stromkosten_täglich
                    11:43:40.941DEBUGjavascriptsfound Script: Jalousie
                    11:43:41.093DEBUGjavascriptsfound Script: Jalousie_Test
                    11:43:41.244DEBUGjavascriptsfound Script: Kostenersparnis
                    11:43:41.395DEBUGjavascriptsfound Script: Lüfter_WR
                    11:43:41.545DEBUGjavascriptsfound Script: _Dach
                    11:43:41.694DEBUGjavascriptsfound Script: Berechnung_Hausverbrauch
                    11:43:41.855DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
                    11:43:41.900DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_03_10-11_43_35_backupiobroker.tar.gz
                    11:43:41.901DEBUGjavascriptsdone
                    11:43:43.210DEBUGgoogledriveGoogle Drive: Copy iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz...
                    • B bastler
                      das ist normal, wenn es nicht am Ziel ankommt.
                      backup.dir dürfte nicht der Pfad zu Google sein
                      ... wäre wahrscheinlich das wichtigste
                        @bastler sagte:
                        @paul53 sagte in Problem mit unzureichendem Speicherplatz:
                        @bastler sagte:
                        @bastler
                        zuerst platz machen, solange deine Platte voll ist, geht auch kein backup.. er kanns ja nicht zwischenspeichern..
                          @bastler sagte:
                          @bastler
                          bastler
                          @neuschwansteini Ich habe den Fehler entdeckt, Google Drive war zu voll! Kann mich aber nicht an eine Fehlermeldung erinnern. Es ist dann wohl so, dass das Backup auf dem lokalen Laufwerk durchgeführt wird.
                          Gibt es eine Möglichkeit über so ein Problem (Google Speicher voll) informiert zu werden?
                          Danke an alle Helfer!
                          HomoranH crunchipC 2 Antworten Letzte Antwort
                          • B bastler
                            ja!
                            @homoran sagte in Problem mit unzureichendem Speicherplatz:
                            • B bastler
                              crunchipC Abwesend
                              crunchipC Abwesend
                              Bekommt man da nicht unabhängig vom Smarthome eine Mail, da benachrichtigt dich doch Google.
                                bastler
                                @crunchip Nein, nur direkt in Google Drive wurde mir angezeigt, dass nur noch 83% frei sind und ein Speichern von weiteren Dateien nicht mehr möglich ist.
                                  ja!
                                  bastler
                                  @homoran Der Backup Vorgang läuft scheinbar nicht weiter? Google Drive ist mit 8GB belegt von 17GB. Die alten Backups im lokalen LW und auch im Google Drive habe ich gelöscht. Wenn ich direkt in Google Drive nachschaue, ist das Verzeichnis noch leer. Bin ich zu ungeduldig? Aber 700MB sollten doch in 15 Minuten locker hochgeladen werden?
                                  Habe jetzt den Vorgang gestoppt, den ioBroker neu gestartet und noch einmal den Upload angeschoben. Sieht nicht anders aus. Oben im Fenster läuft der blaue Balken von links nach rechts, mehr passiert nicht.
                                  Habe nun den Token versucht neu anzufordern, war aber nicht nötig, da der Zugriff möglich war. Allerdings schien da doch etwas geklemmt zu haben, denn danach klappte die Sicherung.
                                  • B bastler
                                    Moin zusammen,
                                    habe folgenden Hinweis bezüglich zu wenig Speicherplatz erhalten.
                                    Allerdings sieht es direkt auf der VM anders aus:
                                    Habe jetzt dort noch einmal 1GB frei gegeben. Jetzt steht aber deutlich mehr Platz zur Verfügung?
                                    Hier ist die Zusammenfassung der Diagnose:
                                             Chassis: vm 🖴
                                      Virtualization: kvm
                                    Installation: 		kvm
                                    Kernel: 		x86_64
                                    Userland: 		64 bit
                                    Timezone: 		Europe/Berlin (CET, +0100)
                                    User-ID: 		1000
                                    Boot Target: 		graphical.target
                                    Pending OS-Updates: 	0
                                    Pending iob updates: 	0
                                    Nodejs-Installation:
                                    /usr/bin/npm 		10.8.2
                                    /usr/bin/npx 		10.8.2
                                    Recommended versions are nodejs 20.18.3 and npm 10.8.2
                                    nodeJS installation is correct
                                    MEMORY:
                                    Mem:             11G        3.7G        7.5G        589K        939M        8.2G
                                    Swap:           1.0G          0B        1.0G
                                    Total:           12G        3.7G        8.5G
                                    ioBroker Core: 		js-controller 		7.0.6
                                    			admin 			7.4.10
                                    ioBroker Status: 	iobroker is running on this host.
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Objects: 		18065
                                    States: 		15226
                                    Size of iob-Database:
                                    22M	/opt/iobroker/iobroker-data/objects.jsonl
                                    9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
                                    9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    28M	/opt/iobroker/iobroker-data/states.jsonl
                                    4.6M	/opt/iobroker/iobroker-data/states.json.migrated
                                    4.6M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Kann mir das jemand erklären, bzw. was muss ich tun um den Hinweis zum "geringen Speicherplatz" zu vermeiden?
                                    mago
                                    ich hänge mich hier mal dran mit einem ähnlichen Problem. Hatte dieselbe Meldung und hab nach einiger Recherche schonmal ein paar Caches und Backups gelöscht.
                                    Nun kondensiert sich das Ganze im Wesentlichen auf Javascript:
                                        3.0 GiB [#################] /opt
                                        1.2 GiB [######           ] /usr
                                      324.5 MiB [#                ] /home
                                    . 249.2 MiB [#                ] /var
                                    .   3.2 MiB [                 ] /etc
                                    und weiter
                                    --- /opt/iobroker -----------------------------------------------------------------------------------------------------------
                                        1.4 GiB [#################] /node_modules
                                      920.9 MiB [##########       ] /iobroker-data
                                      453.7 MiB [#####            ] /backups
                                        1.5 MiB [                 ] /log
                                    In den beiden größten Foldern sind jeweils javascript Unterordner die Maßgeblichen:
                                    --- /opt/iobroker/node_modules ----------------------------------------------------------------------------------------------
                                      621.7 MiB [#################] /iobroker.javascript
                                      181.0 MiB [####             ] /canvas
                                      152.2 MiB [####             ] /iobroker.echarts
                                       84.0 MiB [##               ] /iobroker.admin
                                    und
                                    --- /opt/iobroker/iobroker-data/files ---------------------------------------------------------------------------------------
                                      616.2 MiB [#################] /javascript.admin
                                       66.2 MiB [#                ] /echarts.admin
                                       60.5 MiB [#                ] /echarts
                                    Kann mir jemand sagen woran das liegt und wie ich hier ein bisschen entschlacken kann?
                                    Vielen Dank & viele Grüße
                                    Marco
                                    • M mago
                                      .   3.2 MiB [                 ] /etc
                                      und weiter
                                          1.5 MiB [                 ] /log
                                      und
                                      Marco
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @mago
                                      Such mal hier im Forum. Irgendeine JS Version belegt sehr viel Speicher. Da kannst nix direkt machen außer aktualisisern.
                                      Hab den diesbezüglichen Thread aber nicht ium Kopf.
                                      Und mit Proxmox hat das eigentlich nix zu tun ...
                                      EDIT:
                                      8.8.3 belegt 648MB
                                      https://www.npmjs.com/package/iobroker.javascript/v/8.8.3
                                      8.9.2 belehgt nur 34,8MB
                                      https://www.npmjs.com/package/iobroker.javascript/v/8.9.2
                                      Ich kann aber keinerlei Empfehlungen zum Update / Downgrade geben.
                                      Support Repositoryverwaltung.
                                      LESEN - gute Forenbeitrage
                                      • mcm1957M mcm1957
                                        @mago
                                        EDIT:
                                        8.8.3 belegt 648MB
                                        mago
                                        @mcm1957 Guter Hinweis! Zumindest habe ich die 8.8.3 installiert. Ist offenbar auch die stable. Vielleicht beobachte ich das erstmal, meine Befürchtung war dass das immer weiter anschwillt. Wenn das mehr oder weniger fix ist und beim nächsten Upgrade schmäler wird reicht mir das.
                                        Danke!
                                        • M mago
                                          Danke!
                                          mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          @mago
                                          Bei dieser Version dürften was beim Bau 'unglücklich' gelaufen sein, Eine dedizieret Ursachenforschung ist m.E. nicht sinnvoll, da die neueren Versionen alle wieder normale Speicheranforderungen habn.
