  3. Off Topic
  4. Proxmox
  5. Problem mit unzureichendem Speicherplatz
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
32 Beiträge 8 Kommentatoren 4.3k Aufrufe 6 Beobachtet
  • B bastler
    @codierknecht Hatte gerade versucht vom Backup Adapter aus eine neue Sicherung durchzuführen. Da gab es eine Fehlermeldung bei der Influx Sicherung. Nach einem 2. Durchlauf sieht es jetzt wie unten dargestellt aus. Es scheint, das alle Daten eben nur lokal gesichert werden?
    Die Einstellungen in der Backup Instanz sieht so aus.
    11:43:20.780INFOguiBackup gestartet ...
    11:43:22.899DEBUGiobrokerhost.ioBroker 18075 objects saved
    11:43:23.531DEBUGiobrokerhost.ioBroker 15235 states saved
    11:43:23.533DEBUGiobrokerhost.ioBroker Validating backup ...
    11:43:23.576DEBUGiobrokerhost.ioBroker "config.json" is valid
    11:43:23.579DEBUGiobrokerhost.ioBroker "objects.jsonl" exists
    11:43:23.664DEBUGiobrokerhost.ioBroker "states.jsonl" exists
    11:43:23.826DEBUGiobrokerhost.ioBroker JSONL lines are valid
    11:43:23.830DEBUGiobrokerhost.ioBroker The backup is valid!
    11:43:24.212DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz
    11:43:24.217DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
    11:43:25.226DEBUGiobrokerdone
    11:43:25.379DEBUGinfluxDBInfluxDB-Backup started ...
    11:43:25.382DEBUGinfluxDBInfluxDB Backup tmp directory created
    11:43:28.329DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker"
    11:43:28.352DEBUGinfluxDB2025/03/10 11:43:25 backing up metastore to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/meta.00
    2025/03/10 11:43:25 backing up db=iobroker
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1283 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01283.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1291 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01291.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1299 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01299.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1307 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01307.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1315 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01315.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1323 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01323.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1331 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01331.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1339 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01339.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1347 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01347.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1355 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01355.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1363 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01363.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1371 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01371.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1379 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01379.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1387 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01387.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1395 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01395.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1403 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01403.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1411 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01411.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1419 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01419.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1427 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01427.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1435 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01435.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1443 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01443.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1451 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01451.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1459 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01459.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1467 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01467.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1475 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01475.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1483 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01483.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1491 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01491.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1499 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01499.00 since 0001-01-01T00:00:00Z
    2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1507 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01507.00 since 0001-01-01T00:00:00Z
    11:43:28.401DEBUGinfluxDBdone
    11:43:29.246DEBUGzigbeefound zigbee database: zigbee.0,zigbee.1
    11:43:29.289DEBUGzigbeedone
    11:43:29.550DEBUGgrafanaStart Grafana Backup ...
    11:43:29.553DEBUGgrafanaCreated dashboards_manually_restore directory
    11:43:29.557DEBUGgrafanastart Grafana request ...
    11:43:29.599DEBUGgrafanaGrafana is available ... Status: 200
    11:43:29.603DEBUGgrafanafound Dashboard: heizung
    11:43:29.605DEBUGgrafanafound Dashboard: new-dashboard-copy
    11:43:29.608DEBUGgrafanafound Dashboard: espeasy-2
    11:43:29.652DEBUGgrafanafound Dashboard: 1-dashboard
    11:43:29.712DEBUGgrafanastart Grafana backup compress ...
    11:43:34.723DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    11:43:34.769DEBUGgrafanadone
    11:43:34.875DEBUGjarvisCreated jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
    11:43:34.878DEBUGjarvisfound Jarvis Instance: 0
    11:43:34.892DEBUGjarvisstart Jarvis Backup for Instance 0...
    11:43:34.893DEBUGjarvis/opt/iobroker/iobroker-data/jarvis/0 copy success!
    11:43:34.924DEBUGjarvisCreated states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
    11:43:35.025DEBUGjarvisTry deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
    11:43:35.030DEBUGjarvisJarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
    11:43:35.071DEBUGjarvisBackup created: /opt/iobroker/backups/jarvis.0_2025_03_10-11_43_34_backupiobroker.tar.gz
    11:43:35.073DEBUGjarvisdone
    11:43:35.345DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
    11:43:35.408DEBUGjavascriptsfound Script: Wama_und_Trockner_Meldung
    11:43:35.516DEBUGjavascriptsfound Script: Alias_anlegen
    11:43:35.667DEBUGjavascriptsfound Script: Gaszähler
    11:43:35.818DEBUGjavascriptsfound Script: Stromüberschuss3
    11:43:35.969DEBUGjavascriptsfound Script: Wasserverbrauch2
    11:43:36.120DEBUGjavascriptsfound Script: Stromüberschuss_Kühlschank
    11:43:36.271DEBUGjavascriptsfound Script: Wasserverbrauch
    11:43:36.422DEBUGjavascriptsfound Script: Gasverbrauch
    11:43:36.572DEBUGjavascriptsfound Script: Einspeisung
    11:43:36.723DEBUGjavascriptsfound Script: Brunnenwasser
    11:43:36.875DEBUGjavascriptsfound Script: Nur_Brunnenwasser
    11:43:37.026DEBUGjavascriptsfound Script: Brunnenwasser_alt
    11:43:37.175DEBUGjavascriptsfound Script: Gesamtverbräuche
    11:43:37.325DEBUGjavascriptsfound Script: Stromüberschuss_Heizer
    11:43:37.475DEBUGjavascriptsfound Script: Steckdose_Robo
    11:43:37.628DEBUGjavascriptsfound Script: Windberechnung
    11:43:37.777DEBUGjavascriptsfound Script: Licht_Esszimmer
    11:43:37.927DEBUGjavascriptsfound Script: Watchdog_Adapter1
    11:43:38.083DEBUGjavascriptsfound Script: Gefrierschrank
    11:43:38.231DEBUGjavascriptsfound Script: Drucker_an_aus
    11:43:38.383DEBUGjavascriptsfound Script: Garage_korrigierter_Verbrauch
    11:43:38.534DEBUGjavascriptsfound Script: Ost_West_zusammenfassung
    11:43:38.684DEBUGjavascriptsfound Script: _beide_Anlagen
    11:43:38.834DEBUGjavascriptsfound Script: Deckenventilator
    11:43:38.985DEBUGjavascriptsfound Script: Stromüberschuss_Deckenlüfter_Terrasse_
    11:43:39.135DEBUGjavascriptsfound Script: 1i
    11:43:39.284DEBUGjavascriptsfound Script: 1j
    11:43:39.435DEBUGjavascriptsfound Script: 1k
    11:43:39.586DEBUGjavascriptsfound Script: Schalter_Stube_Ikea_
    11:43:39.737DEBUGjavascriptsfound Script: Schalter_Terrasse_Ikea_
    11:43:39.887DEBUGjavascriptsfound Script: Gewächshaus
    11:43:40.039DEBUGjavascriptsfound Script: Stromüberschuss_Lüfter_Keller
    11:43:40.189DEBUGjavascriptsfound Script: Shelly_Temp_Brunnenpumpe1
    11:43:40.339DEBUGjavascriptsfound Script: Shelly_Temp_Garagenboden1
    11:43:40.490DEBUGjavascriptsfound Script: Staubsauger_Garage
    11:43:40.641DEBUGjavascriptsfound Script: Brunnenwasser_neu
    11:43:40.803DEBUGjavascriptsfound Script: Stromkosten_täglich
    11:43:40.941DEBUGjavascriptsfound Script: Jalousie
    11:43:41.093DEBUGjavascriptsfound Script: Jalousie_Test
    11:43:41.244DEBUGjavascriptsfound Script: Kostenersparnis
    11:43:41.395DEBUGjavascriptsfound Script: Lüfter_WR
    11:43:41.545DEBUGjavascriptsfound Script: _Dach
    11:43:41.694DEBUGjavascriptsfound Script: Berechnung_Hausverbrauch
    11:43:41.855DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
    11:43:41.900DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_03_10-11_43_35_backupiobroker.tar.gz
    11:43:41.901DEBUGjavascriptsdone
    11:43:43.210DEBUGgoogledriveGoogle Drive: Copy iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz...
    @bastler sagte in Problem mit unzureichendem Speicherplatz:
    das ist normal, wenn es nicht am Ziel ankommt.
    backup.dir dürfte nicht der Pfad zu Google sein
    ... wäre wahrscheinlich das wichtigste
      @bastler sagte:
      /dev/sda1      ext4       31G   29G  470M  99% /
      @paul53 sagte in Problem mit unzureichendem Speicherplatz:
      @bastler sagte:
      @bastler
      zuerst platz machen, solange deine Platte voll ist, geht auch kein backup.. er kanns ja nicht zwischenspeichern..
        @bastler sagte:
        @bastler
        bastler
        schrieb am zuletzt editiert von bastler
        @neuschwansteini Ich habe den Fehler entdeckt, Google Drive war zu voll! Kann mich aber nicht an eine Fehlermeldung erinnern. Es ist dann wohl so, dass das Backup auf dem lokalen Laufwerk durchgeführt wird.
        Gibt es eine Möglichkeit über so ein Problem (Google Speicher voll) informiert zu werden?
        Danke an alle Helfer!
        HomoranH crunchipC 2 Antworten Letzte Antwort
        • B bastler
          ja!
          @homoran sagte in Problem mit unzureichendem Speicherplatz:
          • B bastler
            crunchipC Abwesend
            crunchipC Abwesend
            Bekommt man da nicht unabhängig vom Smarthome eine Mail, da benachrichtigt dich doch Google.
              bastler
              @crunchip Nein, nur direkt in Google Drive wurde mir angezeigt, dass nur noch 83% frei sind und ein Speichern von weiteren Dateien nicht mehr möglich ist.
                ja!
                bastler
                @homoran Der Backup Vorgang läuft scheinbar nicht weiter? Google Drive ist mit 8GB belegt von 17GB. Die alten Backups im lokalen LW und auch im Google Drive habe ich gelöscht. Wenn ich direkt in Google Drive nachschaue, ist das Verzeichnis noch leer. Bin ich zu ungeduldig? Aber 700MB sollten doch in 15 Minuten locker hochgeladen werden?
                Habe jetzt den Vorgang gestoppt, den ioBroker neu gestartet und noch einmal den Upload angeschoben. Sieht nicht anders aus. Oben im Fenster läuft der blaue Balken von links nach rechts, mehr passiert nicht.
                Habe nun den Token versucht neu anzufordern, war aber nicht nötig, da der Zugriff möglich war. Allerdings schien da doch etwas geklemmt zu haben, denn danach klappte die Sicherung.
                • B bastler
                  Moin zusammen,
                  habe folgenden Hinweis bezüglich zu wenig Speicherplatz erhalten.
                  Allerdings sieht es direkt auf der VM anders aus:
                  Habe jetzt dort noch einmal 1GB frei gegeben. Jetzt steht aber deutlich mehr Platz zur Verfügung?
                  Hier ist die Zusammenfassung der Diagnose:
                   Static hostname: ioBroker
                         Icon name: computer-vm
                           Chassis: vm 🖴
                    Virtualization: kvm
                            Kernel: Linux 6.1.0-31-amd64
                      Architecture: x86-64
                   Hardware Vendor: QEMU
                    Hardware Model: Standard PC _i440FX + PIIX, 1996_
                  Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
                  Installation: 		kvm
                  Kernel: 		x86_64
                  Userland: 		64 bit
                  Timezone: 		Europe/Berlin (CET, +0100)
                  User-ID: 		1000
                  Display-Server: 	false
                  Boot Target: 		graphical.target
                  Pending OS-Updates: 	0
                  Pending iob updates: 	0
                  Nodejs-Installation:
                  /usr/bin/nodejs 	v20.18.3
                  /usr/bin/node 		v20.18.3
                  /usr/bin/npm 		10.8.2
                  /usr/bin/npx 		10.8.2
                  /usr/bin/corepack 	0.30.0
                  Recommended versions are nodejs 20.18.3 and npm 10.8.2
                  nodeJS installation is correct
                  MEMORY:
                  Mem:             11G        3.7G        7.5G        589K        939M        8.2G
                  Swap:           1.0G          0B        1.0G
                  Total:           12G        3.7G        8.5G
                  Active iob-Instances: 	45
                  Upgrade policy: none
                  ioBroker Core: 		js-controller 		7.0.6
                  			admin 			7.4.10
                  ioBroker Status: 	iobroker is running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                  + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  Objects: 		18065
                  States: 		15226
                  Size of iob-Database:
                  22M	/opt/iobroker/iobroker-data/objects.jsonl
                  9.4M	/opt/iobroker/iobroker-data/objects.json.migrated
                  9.4M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                  28M	/opt/iobroker/iobroker-data/states.jsonl
                  4.6M	/opt/iobroker/iobroker-data/states.json.migrated
                  4.6M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                  Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
                  Kann mir das jemand erklären, bzw. was muss ich tun um den Hinweis zum "geringen Speicherplatz" zu vermeiden?
                  mago
                  ich hänge mich hier mal dran mit einem ähnlichen Problem. Hatte dieselbe Meldung und hab nach einiger Recherche schonmal ein paar Caches und Backups gelöscht.
                  Nun kondensiert sich das Ganze im Wesentlichen auf Javascript:
                      3.0 GiB [#################] /opt
                      1.2 GiB [######           ] /usr
                    324.5 MiB [#                ] /home
                  . 249.2 MiB [#                ] /var
                  .   3.2 MiB [                 ] /etc
                  und weiter
                  --- /opt/iobroker -----------------------------------------------------------------------------------------------------------
                      1.4 GiB [#################] /node_modules
                    920.9 MiB [##########       ] /iobroker-data
                    453.7 MiB [#####            ] /backups
                      1.5 MiB [                 ] /log
                  In den beiden größten Foldern sind jeweils javascript Unterordner die Maßgeblichen:
                  --- /opt/iobroker/node_modules ----------------------------------------------------------------------------------------------
                    621.7 MiB [#################] /iobroker.javascript
                    181.0 MiB [####             ] /canvas
                    152.2 MiB [####             ] /iobroker.echarts
                     84.0 MiB [##               ] /iobroker.admin
                  und
                  --- /opt/iobroker/iobroker-data/files ---------------------------------------------------------------------------------------
                    616.2 MiB [#################] /javascript.admin
                     66.2 MiB [#                ] /echarts.admin
                     60.5 MiB [#                ] /echarts
                  Kann mir jemand sagen woran das liegt und wie ich hier ein bisschen entschlacken kann?
                  Vielen Dank & viele Grüße
                  Marco
                  • M mago
                    .   3.2 MiB [                 ] /etc
                    und weiter
                        1.5 MiB [                 ] /log
                    und
                    Marco
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    @mago
                    Such mal hier im Forum. Irgendeine JS Version belegt sehr viel Speicher. Da kannst nix direkt machen außer aktualisisern.
                    Hab den diesbezüglichen Thread aber nicht ium Kopf.
                    Und mit Proxmox hat das eigentlich nix zu tun ...
                    EDIT:
                    8.8.3 belegt 648MB
                    https://www.npmjs.com/package/iobroker.javascript/v/8.8.3
                    8.9.2 belehgt nur 34,8MB
                    https://www.npmjs.com/package/iobroker.javascript/v/8.9.2
                    Ich kann aber keinerlei Empfehlungen zum Update / Downgrade geben.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M mcm1957
                      @mago
                      EDIT:
                      8.8.3 belegt 648MB
                      mago
                      @mcm1957 Guter Hinweis! Zumindest habe ich die 8.8.3 installiert. Ist offenbar auch die stable. Vielleicht beobachte ich das erstmal, meine Befürchtung war dass das immer weiter anschwillt. Wenn das mehr oder weniger fix ist und beim nächsten Upgrade schmäler wird reicht mir das.
                      Danke!
                      • M mago
                        Danke!
                        mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        @mago
                        Bei dieser Version dürften was beim Bau 'unglücklich' gelaufen sein, Eine dedizieret Ursachenforschung ist m.E. nicht sinnvoll, da die neueren Versionen alle wieder normale Speicheranforderungen habn.
