  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • NegaleinN Negalein
    @simatec sagte in Test Adapter ioBroker.backitup v3.0.x:
    Gab es noch weitere Infos im Log?
    das ist alles
    23:12:22.043  - error: backitup.0 (479121) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    23:12:22.044  - error: backitup.0 (479121) unhandled promise rejection: undefined
    23:12:22.044  - error: backitup.0 (479121) Exception-Code: 429: undefined
    23:12:22.091  - warn: backitup.0 (479121) Terminated (UNCAUGHT_EXCEPTION): Without reason
    23:12:22.747  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    23:12:22.747  - error: host.ioBroker Caught by controller[1]: {
    23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error_summary: 'too_many_requests/.',
    23:12:22.747  - error: host.ioBroker Caught by controller[1]:   error: { reason: { '.tag': 'too_many_requests' }, retry_after: 15 },
    23:12:22.747  - error: host.ioBroker Caught by controller[1]:   code: 429
    23:12:22.747  - error: host.ioBroker Caught by controller[1]: }
    23:12:22.747  - error: host.ioBroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    23:12:22.747  - info: host.ioBroker Restart adapter system.adapter.backitup.0 because enabled
    simatecS Offline
    simatecS Offline
    simatec
    #2685
    @negalein und kannst du sehen, bei welchem Backup der fehler passiert ist? Hattest du den debuglog von Backitup an?
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #2686
      nein, leider nicht :(
      hab ihn seit Mitternacht aktiv.
      Werde heute beobachten.
      ° Fixer ---> iob fix
      • simatecS simatec
        Aktuelle Test Version 3.1.0
        Veröffentlichungsdatum 02.03.2025
        Github Link https://github.com/simatec/ioBroker.backitup
        Wiki Link https://github.com/simatec/ioBroker.backitup/wiki
        Hier geht es um die aktuelle Version von ioBroker.backitup, nachdem der alte Thread langsam zu unübersichtlich wurde.
        Bitte gebt euer Feedback und eure Anregungen hier ab.
        3.1.0 (2025-03-02)
        • (Bluefox) Dependencies updated
        • (Bluefox) Vite added
        • (simatec) jsonConfig updated
        • (simatec) Fix month for history
        3.0.37 (2025-02-28)
        • (simatec) Fix CronJob
        3.0.36 (2025-02-26)
        • (simatec) Fix src-admin
        3.0.35 (2025-02-26)
        3.0.34 (2025-02-26)
        3.0.33 (2025-02-25)
        • (simatec) Fix cronjob
        • (simatec) Fix Backup Console
        3.0.32 (2025-02-24)
        • (simatec) Error handling for GoogleDrive fix
        • (simatec) globalDependencies updated
        • (simatec) Dependencies updated
        • (simatec) Design Fix
        3.0.31 (2024-11-30)
        • (simatec) Fix Tab Menu
        3.0.30 (2024-11-29)
        3.0.29 (2024-11-29)
        3.0.28 (2024-11-27)
        • (simatec) eslint-config added
        • (bluefox) Allow to store files for up to ca 3 years
        • (Marc-Berg) Grafana Docu updated
        3.0.27 (2024-11-12)
        • (simatec) dependencies updated
        3.0.26 (2024-10-16)
        • (simatec) Fix FTP Connections
        • (simatec) Issue Workflow added
        3.0.25 (2024-09-26)
        • (bluefox) Improvement of Google Drive authentication workflow
        • (bluefox) Removed gulp from a build process
        • (simatec) small Design Fix
        • (simatec) Fix for Admin 7.1.5
        • (simatec) Fix Test & Release
        • (simatec) Fix ESlint errors
        3.0.22 (2024-09-03)
        • (simatec) Fix Notification Instance
        • (simatec) Fix Notification Design
        • (simatec) Fix Default Settings
        3.0.21 (2024-09-01)
        • (simatec) Fix Onedrive Notification
        • (simatec) Fix Zigbee2MQTT Backup
        3.0.20 (2024-08-22)
        • (simatec) Responsive Design for Tab added
        • (simatec) Responsive Design for jsonConfig added
        3.0.19 (2024-08-15)
        • (simatec) Fix CCU Backup
        • (simatec) Fix InfluxDB Backup Config
        • (simatec) Fix Backup-Log for Slave Instanz
        3.0.18 (2024-08-14)
        • (simatec) Package optimisation
        • (simatec) Fix the warning when opening the configuration
        3.0.17 (2024-08-12)
        • (simatec) Fix io-package for Release
        • (simatec) manual-review added
        • (simatec) Fix Slave Backup
        3.0.16 (2024-08-05)
        • (bluefox) dependencies updated
        • (simatec) Rename json5 Files
        3.0.15 (2024-08-03)
        • (simatec) fix dependencies
        3.0.14 (2024-08-02)
        • (simatec) Improved log outputs
        3.0.12 (2024-08-01)
        • (simatec) Backup Log for History added
        • (simatec) Added separate selection for deleting FTP backups
        • (simatec) Added separate selection for deleting Onedrive backups
        • (simatec) Added separate selection for deleting Webdav backups
        • (simatec) Added separate selection for deleting Dropbox backups
        • (simatec) Added separate selection for deleting Googledrive backups
        • (simatec) Source code cleaned up
        3.0.11 (2024-07-28)
        3.0.10 (2024-07-22)
        • (simatec) Design Fix for Dark Mode
        3.0.9 (2024-07-11)
        • (simatec) Tab Icons added
        • (simatec) small fix
        • (simatec) Docu updated
        3.0.8 (2024-07-01)
        • (Grothesk242/simatec) forceuid and forcegid added
        3.0.7 (2024-06-26)
        • (simatec) Restore Information added
        • (simatec) Fix Formaterrors
        • (bluefox) Fixing the problems with styles
        • (simatec) Fix iobroker Backup Error
        3.0.6 (2024-06-26)
        3.0.5 (2024-06-18)
        • (simatec) Fix Build
        3.0.4 (2024-06-18)
        • (simatec) History Gui Fix
        • (simatec) Tab GUI modified
        • (bluefox) Added support for Admin 7
        • (simatec) Onedrive ready for School/Business Accounts
        3.0.3 (2024-06-10)
        • (simatec) Fixed WebDav
        • (simatec) Admin Notification for Backup errors added
        • (simatec) Remove Sentry Config
        • (simatec) Translations updated
        • (simatec) Error handling optimized
        3.0.2 (2024-06-06)
        • (simatec) Fixed Google Drive
        • (simatec) Fixed Translations
        • (simatec) Fixed Onedrive
        • (simatec) Fixed MySql Backup
        • (simatec) Fixed Translation added
        • (simatec) new notifications content added
        3.0.1 (2024-05-29)
        • (simatec) Fixed umount callback
        • (simatec) Fixed Backup Message
        • (simatec) Fixed InfluxDB Multi Backup
        • (simatec) Fixed Restore Console
        • (simatec) Fixed Backup Console
        3.0.0 (2024-05-28)
        • (simatec) jsonConfig added
        • (bluefox) Conversion to React
        • (bluefox) Added react components
        • (bluefox/simatec) Working on React GUI
        • (simatec) Fix Yahka Backup
        • (simatec) Fix Nodered Backup
        • (simatec) some bugs fixed
        • (bluefox/simatec) New Restore-Interface
        • (simatec) Translation updated
        sigi234S Online
        sigi234S Online
        #2687
        @simatec
        Hallo, kann man das Backup von den History Adapter beim normalen Backup vom iob ausschließen?
        Ich möchte das History Backup nur manuell starten, was auch funktioniert.
        Windows System
        v3.0.27
        13:02:59.051INFOguiBackup gestartet ...
        13:03:07.440DEBUGiobrokerhost.SmartHome 24623 objects saved
        13:03:08.202DEBUGiobrokerhost.SmartHome 20996 states saved
        13:03:08.205DEBUGiobrokerhost.SmartHome Validating backup ...
        13:03:08.209DEBUGiobrokerhost.SmartHome "config.json" is valid
        13:03:08.215DEBUGiobrokerhost.SmartHome "objects.jsonl" exists
        13:03:08.220DEBUGiobrokerhost.SmartHome "states.jsonl" exists
        13:03:08.723DEBUGiobrokerhost.SmartHome JSONL lines are valid
        13:03:09.191DEBUGiobrokerhost.SmartHome The backup is valid!
        13:03:12.581DEBUGiobrokerBackup created: C:\SmartHome\backups\iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz
        13:03:12.590DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
        13:03:13.642DEBUGiobrokerdone
        13:03:14.591DEBUGhistoryDBcompress from historyDB started ...
        13:03:24.584DEBUGhistoryDBPacked 225MB so far...
        13:03:34.592DEBUGhistoryDBPacked 460MB so far...
        13:03:44.583DEBUGhistoryDBPacked 696MB so far...
        13:03:54.583DEBUGhistoryDBPacked 933MB so far...
        13:04:04.582DEBUGhistoryDBPacked 1164MB so far...
        13:04:14.585DEBUGhistoryDBPacked 1404MB so far...
        13:04:24.606DEBUGhistoryDBPacked 1651MB so far...
        13:04:34.610DEBUGhistoryDBPacked 1873MB so far...
        13:04:44.582DEBUGhistoryDBPacked 2114MB so far...
        13:04:54.587DEBUGhistoryDBPacked 2363MB so far...
        13:05:04.595DEBUGhistoryDBPacked 2605MB so far...
        13:05:14.606DEBUGhistoryDBPacked 2839MB so far...
        13:05:24.595DEBUGhistoryDBPacked 3087MB so far...
        13:05:34.587DEBUGhistoryDBPacked 3332MB so far...
        13:05:44.602DEBUGhistoryDBPacked 3570MB so far...
        13:05:54.595DEBUGhistoryDBPacked 3811MB so far...
        13:06:04.586DEBUGhistoryDBPacked 4054MB so far...
        13:06:14.588DEBUGhistoryDBPacked 4275MB so far...
        13:06:24.615DEBUGhistoryDBPacked 4524MB so far...
        13:06:34.600DEBUGhistoryDBPacked 4771MB so far...
        13:06:44.586DEBUGhistoryDBPacked 5017MB so far...
        13:06:54.587DEBUGhistoryDBPacked 5267MB so far...
        13:07:04.587DEBUGhistoryDBPacked 5515MB so far...
        13:07:14.586DEBUGhistoryDBPacked 5755MB so far...
        13:07:24.600DEBUGhistoryDBPacked 6007MB so far...
        13:07:34.586DEBUGhistoryDBPacked 6256MB so far...
        13:07:44.596DEBUGhistoryDBPacked 6497MB so far...
        13:07:54.587DEBUGhistoryDBPacked 6743MB so far...
        13:08:04.600DEBUGhistoryDBPacked 6994MB so far...
        13:08:14.586DEBUGhistoryDBPacked 7233MB so far...
        13:08:24.595DEBUGhistoryDBPacked 7482MB so far...
        13:08:34.586DEBUGhistoryDBPacked 7731MB so far...
        13:08:44.587DEBUGhistoryDBPacked 7969MB so far...
        13:08:54.601DEBUGhistoryDBPacked 8219MB so far...
        13:09:04.595DEBUGhistoryDBPacked 8464MB so far...
        13:09:14.592DEBUGhistoryDBPacked 8695MB so far...
        13:09:14.668DEBUGhistoryDBBackup created: C:\SmartHome\backups\historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz
        13:09:14.672DEBUGhistoryDBdone
        13:09:15.303DEBUGjarvisCreated jarvis_tmp directory: "C:/SmartHome/backups/tmpJavis0"
        13:09:15.323DEBUGjarvisstart Jarvis Backup for Instance 0...
        13:09:15.441DEBUGjarvisC:\SmartHome\iobroker-data\jarvis\0 copy success!
        13:09:15.443DEBUGjarvisCreated states_tmp directory: "C:/SmartHome/backups/tmpJavis0/states"
        13:09:15.745DEBUGjarvisTry deleting the Jarvis tmp directory: "C:/SmartHome/backups/tmpJavis0"
        13:09:15.754DEBUGjarvisJarvis tmp directory "C:/SmartHome/backups/tmpJavis0" successfully deleted
        13:09:15.759DEBUGjarvisdone
        13:09:16.337DEBUGjavascriptsCreated javascript_tmp directory: "C:/SmartHome/backups/tmpScripts"
        13:09:16.439DEBUGjavascriptsfound Script: SKRIPTE GEKÜRZT!
        13:10:08.039DEBUGjavascriptsfound Script: Servicemeldungen12
        13:10:08.361DEBUGjavascriptsTry deleting the Javascript tmp directory: "C:/SmartHome/backups/tmpScripts"
        13:10:08.373DEBUGjavascriptsdone
        13:10:09.299DEBUGcifsused copy path: H:/Backitup
        13:10:09.321DEBUGcifsCopy iobroker_2024_11_20-13_02_59_backupiobroker.tar.gz...
        13:10:10.417DEBUGcifsCopy historyDB_2024_11_20-13_03_14_backupiobroker.tar.gz...
        13:11:18.895DEBUGcifsCopy jarvis.0_2024_11_20-13_09_15_backupiobroker.tar.gz...
        13:11:18.947DEBUGcifsCopy javascripts_2024_11_20-13_09_16_backupiobroker.tar.gz...
        13:11:18.978DEBUGcifsdone
        13:11:19.635WARNcleanNo older backup files are deleted, because this backup was started manually
        13:11:19.641DEBUGcleandone
        13:11:19.802DEBUGhistoryHTMLnew history html values created
        13:11:19.836DEBUGhistoryHTMLdone
        13:11:20.017DEBUGhistoryJSONnew history json values created
        13:11:20.027DEBUGhistoryJSONdone
        13:11:22.580DEBUGnotificationdone
        13:11:22.744INFOguiDas Backup wurde erfolgreich erstellt!
        Grund ist das die History-DB schon sehr Groß ist.
        Natürlich könnte ich es auch manuell unter den Host löschen, bin mir aber nicht sicher ob das den Adapter nicht durcheinander bringt?
        • sigi234S sigi234
          @simatec
          Windows System
          v3.0.27
          #2688
          @sigi234 sagte in Test Adapter ioBroker.backitup v3.0.x:
          Das dauert natürlich!
            sigi234S Online
            sigi234S Online
            #2689
            @homoran sagte in Test Adapter ioBroker.backitup v3.0.x:
            Ja, manuell ca.10 Minuten.
            Sonst wird es automatisch ja um 2 Uhr gemacht, habe da keine Probleme.
            Nur das ich fast 10 GB doppelt habe und mir die Systemplatte Voll macht.
            • sigi234S sigi234
              #2690
              dann hast du aber einen Turborechner.
              Hab es nie gemessen, aber denke, dass ich auf dem Pi5 mit meinen 3GB gepackter History auch fast daran komme.
              Manchmal hab ich den Eindruck dass zu der Zeit Meldungen im log auftauchen weil der Pi da doch ans keuchen kommt.
                sigi234S Online
                sigi234S Online
                #2691
                Ja, komplettes Backup fertig in 9 Minuten. 😁
                Mit 8,5 GB History
                • Siggi0904S Offline
                  Siggi0904S Offline
                  Siggi0904
                  #2692
                  Hi @simatec , warum Maerz und nicht März?
                  • Siggi0904S Siggi0904
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2693
                    @siggi0904 Welche Version ist installiert?
                    Siggi0904S haselchenH 3 Antworten Letzte Antwort
                    • simatecS simatec
                      Siggi0904S Offline
                      Siggi0904S Offline
                      Siggi0904
                      #2694
                      @simatec Hallo, aktuelle Stable 3.0.31
                      • simatecS simatec
                        Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        #2695
                        @simatec Mahlzeit, hattest du die Korrektur gefunden?
                        Oder sollte ich da ein Issue erstellen?
                        • simatecS simatec
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          #2696
                          @simatec
                          Bin mir nicht sicher mit welchem, der letzten Updates das kam.
                          In der Seitenleiste sind die Icons weg
                          simatecS Thomas BraunT bahnuhrB 3 Antworten Letzte Antwort
                          • haselchenH haselchen
                            @simatec
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #2697
                            @haselchen Welche Version hast du installiert?
                              @simatec
                              #2698
                              @haselchen sagte in Test Adapter ioBroker.backitup v3.0.x:
                              Bei mir nicht.
                              system.adapter.backitup 3.0.37
                                @simatec
                                bahnuhrB Offline
                                bahnuhrB Offline
                                bahnuhr
                                #2699
                                @haselchen
                                Ich hab 3.0.31
                                Bei mir ist alles ok.
                                Danke.
                                • simatecS simatec
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  #2700
                                  @simatec
                                  3.0.37
                                  Bin nicht sicher, ob die Icons auch schon in Vorversionen weg waren.
                                  Ist mir eben erst aufgefallen.
                                  Edit:
                                  Hab nochmal ein Upload hinterhergeschoben, jetzt sind sie da .
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #2701
                                    @siggi0904 Wurde in v3.1.0 gefixt
                                    • JB_SullivanJ Offline
                                      JB_Sullivan
                                      #2702
                                      @simatec Gibt es irgend welche Beschränkungen, was das löschen von temporären Backups betrifft?
                                      Soll heißen, ich habe Adapter in der Version 3.1.0. In den Einstellungen habe ich festgelegt, das ich 3 historische Backups behalten möchte.
                                      Beim erstellen des Backups werden diese auf einem Windows System lokal unter c:\iobroker\GLT\backups\ abgelegt und mit jedem neuen Backup wird der älteste Tag entsprechend gelöscht - soweit so gut.
                                      Parallel dazu werden sie auf Google Drive gesichert.
                                      2025-03-29 02:41:40.540  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy zigbee.0_2025_03_29-02_24_10_backupiobroker.tar.gz...
                                      2025-03-29 02:41:42.743  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy grafana_2025_03_29-02_24_16_backupiobroker.tar.gz...
                                      2025-03-29 02:41:44.977  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy javascripts_2025_03_29-02_24_22_backupiobroker.tar.gz...
                                      2025-03-29 02:41:47.664  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete iobroker_2025_03_26-02_00_10_backupiobroker.tar.gz
                                      2025-03-29 02:41:48.260  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete influxDB_2025_03_26-02_00_42_backupiobroker.tar.gz
                                      2025-03-29 02:41:48.874  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete zigbee.0_2025_03_26-02_24_45_backupiobroker.tar.gz
                                      2025-03-29 02:41:49.415  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete grafana_2025_03_26-02_24_52_backupiobroker.tar.gz
                                      2025-03-29 02:41:49.940  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: delete javascripts_2025_03_26-02_24_58_backupiobroker.tar.gz
                                      2025-03-29 02:41:50.439  - debug: backitup.0 (2896) [iobroker/googledrive] done
                                      2025-03-29 02:41:50.599  - debug: backitup.0 (2896) [iobroker/clean] delete C:\ioBroker\GLT\backups\iobroker_2025_03_26-02_00_10_backupiobroker.tar.gz
                                      2025-03-29 02:41:50.603  - debug: backitup.0 (2896) [iobroker/clean] done
                                      2025-03-29 02:41:50.764  - debug: backitup.0 (2896) [iobroker/historyHTML] new history html values created
                                      2025-03-29 02:41:50.785  - debug: backitup.0 (2896) [iobroker/historyHTML] done
                                      2025-03-29 02:41:50.968  - debug: backitup.0 (2896) [iobroker/historyJSON] new history json values created
                                      2025-03-29 02:41:50.969  - debug: backitup.0 (2896) [iobroker/historyJSON] done
                                      2025-03-29 02:41:51.434  - debug: backitup.0 (2896) [iobroker/email] done
                                      Seit ca. einer Woche löscht er aber das älteste Backup auf Googel Drive nicht mehr (lokal schon) und gibt mir den folgenden Fehler aus (Zeile 24 - der Rest ist zur Information). Dies passierte von einem Tag auf den anderen, ohne das am System irgend welche Änderungen vorgenommen wurden (ich war zu der Zeit sogar im Urlaub). Die Sicherung der InfluxDB auf Google ist ca. 6,5 GB groß. Kann das ein Problem sein?
                                      2025-03-29 02:24:48.445  - debug: backitup.0 (2896) [iobroker/javascripts] Try deleting the Javascript tmp directory: "C:/ioBroker/GLT/backups/tmpScripts"
                                      2025-03-29 02:24:48.454  - debug: backitup.0 (2896) [iobroker/javascripts] Javascript tmp directory "C:/ioBroker/GLT/backups/tmpScripts" successfully deleted
                                      2025-03-29 02:24:48.455  - debug: backitup.0 (2896) [iobroker/javascripts] Backup created: C:\ioBroker\GLT\backups\javascripts_2025_03_29-02_24_22_backupiobroker.tar.gz
                                      2025-03-29 02:24:48.455  - debug: backitup.0 (2896) [iobroker/javascripts] done
                                      2025-03-29 02:24:51.006  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy iobroker_2025_03_29-02_00_10_backupiobroker.tar.gz...
                                      2025-03-29 02:24:55.822  - debug: backitup.0 (2896) [iobroker/googledrive] Google Drive: Copy influxDB_2025_03_29-02_00_40_backupiobroker.tar.gz...
                                      2025-03-29 02:41:51.438  - warn: email.0 (3284) From email address is not equal to the configured email address for authentication. Some services do not allow this!
                                      2025-03-29 02:41:51.440  - info: email.0 (3284) Send email: {"text":"Backitup:\nIhr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!\n\ncifs: Error: EPERM: operation not permitted, stat 'C:\\ioBroker\\GLT\\backups\\influxDB_2025_03_18-02_00_42_backupiobroker.tar.gz'","to":"meinemailadresse@arcor.de","subject":"Backitup","from":"meinemailadresse@arcor.de"}
                                      2025-03-29 02:41:53.495  - debug: backitup.0 (2896) [iobroker/notification] Admin notification will be sent
                                      2025-03-29 02:41:53.496  - debug: backitup.0 (2896) [iobroker/notification] done
                                      2025-03-29 02:41:53.656  - debug: backitup.0 (2896) [iobroker] exec: done
                                      simatecS NegaleinN 3 Antworten Letzte Antwort
                                      • JB_SullivanJ JB_Sullivan
                                        simatecS Offline
                                        simatecS Offline
                                        simatec
                                        #2703
                                        @jb_sullivan Da stimmen wohl irgendwelche Schreibrechte nicht... Was du da bei Windwos im speziellen beachten musst, kann ich dir leider nicht sagen. Ich nutze kein Windows
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #2704
                                          @jb_sullivan sagte in Test Adapter ioBroker.backitup v3.1.x:
                                          wie groß sind die anderen Backups?
                                          ioBroker, Zigbee, Grafana, Scripts?
                                          Hast Dateien in Gmail?
                                          Sicherst deine Fotos und WhatsApp auf Google?
                                          Du hast auf Google Drive nur 15 GB gratis.
                                          Willst mehr, musst ein Abo kaufen.
