  3. Off Topic
  4. Proxmox
  5. ioBroker in Proxmox gesperrt, wer kann helfen
    2.7k
    4.7k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
entsperreniobroker instanzenproxmox
201 Beiträge 9 Kommentatoren 34.2k Aufrufe 7 Beobachtet
  • A Altersrentner
    @ticaki sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
    Sicher das nicht dein Backuplaufwerk voll ist?
    Ja, aber wie erweitern?
    INFO: starting new backup job: vzdump 100 --remove 0 --notification-mode auto --notes-template 'Backup nach Sperrung 150225' --compress zstd --mode snapshot --node pve --storage local
    INFO: Starting Backup of VM 100 (lxc)
    INFO: Backup started at 2025-02-15 11:17:38
    INFO: status = running
    INFO: CT Name: iobroker
    INFO: including mount point rootfs ('/') in backup
    INFO: found old vzdump snapshot (force removal)
      Logical volume "snap_vm-100-disk-1_vzdump" successfully removed.
    INFO: backup mode: snapshot
    INFO: ionice priority: 7
    INFO: create storage snapshot 'vzdump'
      WARNING: You have not turned on protection against thin pools running out of space.
      WARNING: Set activation/thin_pool_autoextend_threshold below 100 to trigger automatic extension of thin pools before they get full.
      Logical volume "snap_vm-100-disk-1_vzdump" created.
      WARNING: Sum of all thin volume sizes (192.00 GiB) exceeds the size of thin pool pve/data and the amount of free space in volume group (16.00 GiB).
    INFO: creating vzdump archive '/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tar.zst'
    INFO: cleanup temporary 'vzdump' snapshot
    ERROR: Backup of VM 100 failed - command 'set -o pipefail && lxc-usernsexec -m u:0:100000:65536 -m g:0:100000:65536 -- tar cpf - --totals --one-file-system -p --sparse --numeric-owner --acls --xattrs '--xattrs-include=user.*' '--xattrs-include=security.capability' '--warning=no-file-ignored' '--warning=no-xattr-write' --one-file-system '--warning=no-file-ignored' '--directory=/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tmp' ./etc/vzdump/pct.conf ./etc/vzdump/pct.fw '--directory=/mnt/vzsnap0' --no-anchored '--exclude=lost+found' --anchored '--exclude=./tmp/?*' '--exclude=./var/tmp/?*' '--exclude=./var/run/?*.pid' ./ | zstd '--threads=1' >/var/lib/vz/dump/vzdump-lxc-100-2025_02_15-11_17_38.tar.dat' failed: interrupted by signal
    INFO: Failed at 2025-02-15 11:18:59
    INFO: Backup job finished with errors
    INFO: notified via target `mail-to-root`
    TASK ERROR: job errors
    T Nicht stören
    T Nicht stören
    ticaki
    @altersrentner
    Erstmal müsste man sehen wo die automatsichen Backups hingehen, dann wieviele da sind. Anschließend entscheiden ob den Speicherplatz vergrößern will oder die Vorrätig gehaltenen Backups reduzieren.
    Vielleicht hab ich es ja übersehen, wenn ja bitte gib mir links auf die Postings.
    Spenden
    • A Altersrentner
      @ilovegym sagte in [Geklärt] ioBroker in Proxmox gesperrt, wer kann helfen:
      Mach das Backup mal manuell
      Hatte das Backup manuell gemach.
      Jetzt Snapshot gemacht
      und versuche erneut ein Backup
      Es kommt folgende Meldung
      Heißt:
      WARNUNG: Sie haben den Schutz gegen zu wenig Speicherplatz in Thin Pools nicht aktiviert. WARNUNG: Setzen Sie activation/thin_pool_autoextend_threshold unter 100, um eine automatische Erweiterung der Thin Pools auszulösen, bevor diese voll sind. Logisches Volume „snap_vm-100-disk-1_vzdump“ erstellt. WARNUNG: Die Summe aller Thin-Volume-Größen (192,00 GiB) übersteigt die Größe des Thin Pools pve/data und die Menge an freiem Speicherplatz in der Volume-Gruppe (16,00 GiB).
      Ist das hier die richtige Stelle für die Änderung?
      Wie oder wo kann ich die Situation bereinigen?
      MfG Michael
      crunchipC Abwesend
      crunchipC Abwesend
      @altersrentner sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
      ich nehme an, das trifft zu
      https://forum.proxmox.com/threads/backup-of-ct-fails-vm-works.135900/
      übersetzt
      Kurz gesagt:
      Um unprivilegierte LXC zu sichern, benötigen sowohl UID 0 als auch UID 100000 Schreibberechtigungen für den temporären Speicher (der standardmäßig ein Unterverzeichnis Ihres Ziel-Backup-Speichers ist). Stellen Sie also entweder sicher, dass UID 100000 auf Ihrem NAS auch die Rechte hat, in das Share zu schreiben, oder bearbeiten Sie Ihre /etc/vzdump.conf und weisen Sie das tmpdir auf einen Ordner mit ausreichenden Rechten wie "/tmp" zu, der 777 hat.
      • T ticaki
        @altersrentner
        Altersrentner
        Danke für deine Nachricht
        Hier gehen sie hin:
        Hilft das weiter?
        MfG Michael
          übersetzt
          Kurz gesagt:
          Altersrentner
          @crunchip sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
          Ist sehr kompliziert für mich,
          Ich glaube mich zu erinnern, das der Speicher auch nachträglich vergrößert werden kann.
          Aber wie, das ist die Frage.😧
          MfG Michael
          T crunchipC 2 Antworten Letzte Antwort
          • A Altersrentner
            Hier gehen sie hin:
            Hilft das weiter?
            MfG Michael
            @altersrentner
            damit ist klar, warum das nicht mehr geht. Lokal speichert man am besten garkeine Backups, oder nur zum testen mal eins.
            Binde ein anderes Laufwerk in den Proxmox-Host ein, oder haeng per usb ne externe Festplatte dran, oder per SMB/NFS n Drive einbinden oder oder oder..
            Vergroessern bringt da nix, du sicherst ja deine Daten nicht weg, sondern nur im System, wenn das die Kraetsche macht, haste auch kein Backup mehr.
            • A Altersrentner
              MfG Michael
              T Nicht stören
              T Nicht stören
              ticaki
              @altersrentner
              Aber zu dem kompliziert - dort steht das du das temporäre Verzeichnis in einer Datei ändern sollst. Wenn du den Inhalt der Datei hier postet ist bestimmt einer so nett und ändert es für dich. :)
              Spenden
                @altersrentner
                Altersrentner
                @ilovegym sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
                OK, Habe ich verstanden.
                Reicht es dann wie schon beschrieben meine täglichen Sicherungen
                über BackitUp in Google Drive zur Wiederherstellung zu verwenden?
                Dann wäre alles geklärt.
                MfG Michael
                • A Altersrentner
                  MfG Michael
                  Hallo Michael,
                  wenn du sonst keine "extras" ( wie Redis oder sonstige besondere Einstellungen ) auf dem iobroker VM laufen hast, reicht das Backup mit dem Backitup-Adapter.
                  Schoen ist ein Backup von der VM natuerlich immer.
                  • A Altersrentner
                    MfG Michael
                    crunchipC Abwesend
                    crunchipC Abwesend
                    macht ja keinen Sinn, hier nochmal in deutsch
                    https://forum.proxmox.com/threads/proxmox-backup-ct-auf-nas.158704/
                      Altersrentner
                      OK, danke für den Hinweis
                      Werde ich mich damit beschäftigen wie ich eine Festplatte einbinden kann oder muss.
                      Danke auch dir nochmal. Ist zwar in unserer Landessprache aber für mich fast unerklärlich.
                      MfG Michael
                      Siggi0904S crunchipC 2 Antworten Letzte Antwort
                      • A Altersrentner
                        MfG Michael
                        Siggi0904S Offline
                        Siggi0904S Offline
                        Siggi0904
                        @altersrentner da hatte @haus-automatisierung ein super video zu gemacht.
                        https://www.youtube.com/watch?v=Ew1bEYWdBso
                        • A Altersrentner
                          MfG Michael
                          crunchipC Abwesend
                          crunchipC Abwesend
                          @altersrentner also mit eigenen Worten
                          • backups machen nur Sinn, wenn extern gesichert wird
                          • bedingt wäre auch ok, wenn wenigsten ein Stick oder Festplatte daran hängt und darauf die backups laufen
                          • LXC gibt es privilegiert und unprivilegiert, hängt mit den Rechten (Sicherheit) zusammen
                          • diesbezüglich muss man dann eben für unprivilegiert LXC die /etc/vzdump.conf bearbeiten und auf tmp stellen, damit das backup zwischengespeichert werden kann
                          • Siggi0904S Siggi0904
                            Altersrentner
                            @siggi0904 sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
                            Danke, habe ich mir gerade angesehen und glaube das kann ich realisieren.
                            Mal sehen ob ich noch eine Festplatte finde.
                            Nochmals danke,
                            wie gesagt werde versuchen über eine externe FP zu sichern
                            MfG Michael
                            uweklattU 1 Antwort Letzte Antwort
                            • A Altersrentner
                              Nochmals danke,
                              MfG Michael
                              uweklattU Offline
                              uweklattU Offline
                              uweklatt
                              @altersrentner
                              Wenn ein NAS vorhanden ist, kann man eine Freigabe als Backupverzeichnis vom PVE einrichten.
                              Tschau
                              Uwe
                              Intel i5/Proxmox/LXC/Docker/ioBroker
                              • uweklattU uweklatt
                                @altersrentner
                                Tschau
                                Uwe
                                Altersrentner
                                @uweklatt sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
                                Hallo Uwe,
                                Leider nicht, heißt nur eine alte die ich schon lange nicht mehr nutze,
                                aber gestern habe ich eine 2TB externe Festplatte eingebunden und
                                eine VM installiert. Die Festplatte wurde auf ext4 konfiguriert und nun muss ich sehen,
                                wie ich sie in die VM Test(102) eingebunden bekomme,
                                Mir haben ganz schön die Socken gequalmt😧
                                MfG Michael
                                • A Altersrentner
                                  Hallo Uwe,
                                  MfG Michael
                                  @altersrentner
                                  da fehlt noch das einbinden unter Storage im Datencenter, dann ist die Festplatte auch fuer alle und das Backup zu nutzen.
                                  Hier mal eine Anleitung in Deutsch, die ich zufaellig gefunden habe, die ersten Schritte hast du ja schon...
                                  https://www.server-verstehen.de/festplatte-proxmox-einbinden/
                                  A 3 Antworten Letzte Antwort
                                    @altersrentner
                                    Altersrentner
                                    Danke für die Anleitung
                                    MfG Michael
                                      @altersrentner
                                      Altersrentner
                                      So die Festplatte ist eingebunden,
                                      wenn ich sie mir aber auf der Shell mit
                                      slblk
                                      ansehen möchte, erscheint folgende Meldung
                                      Wie sollte ich hier weiter verfahren?
                                      hier ist die Festplatte zu sehen
                                      MfG Michael
                                      • A Altersrentner
                                        slblk
                                        MfG Michael
                                        das tun, was der Rechner sagt!
                                        lsblk
                                          lsblk
                                          Altersrentner
                                          @homoran sagte in ioBroker in Proxmox gesperrt, wer kann helfen:
                                          Alles klar😠
                                          War ein Dreher drin.
                                          Sollte es jetzt passen?
                                          MfG
