  3. Einsteigerfragen
  4. Installation
  5. Update Node.js ioBroker läuft nicht
43 Beiträge 8 Kommentatoren 5.8k Aufrufe 7 Beobachtet
    @nagamichisan sagte in Update Node.js ioBroker läuft nicht:
    Daher sollte der PI4 eigentlich noch reichen.
    dann zeig uns doch fie Ausgabe der Langfassung von iob diag.
    dann kann man das beurteilen.
    N Offline
    N Offline
    Nagamichisan
    schrieb am zuletzt editiert von Nagamichisan
    @homoran said in Update Node.js ioBroker läuft nicht:
    Ich hoffe, dass passt so, wahrscheinlich das vor der Summary:
    ```bash
    Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
       Static hostname: raspberrypi4-iob
             Icon name: computer
      Operating System: Raspbian GNU/Linux 10 (buster)
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     17:50:33 up 5 days, 13:50,  1 user,  load average: 0.29, 0.44, 0.34
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-01-30 17:50:33 CET
               Universal time: Thu 2025-01-30 16:50:33 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:           3.8G        948M        1.5G        8.0M        1.4G        2.7G
    Swap:           99M          0B         99M
    Total:         3.9G        948M        1.6G
    Active iob-Instances:   16
             3838 M total memory
              948 M used memory
              437 M active memory
             1740 M inactive memory
             1480 M free memory
              174 M buffer memory
             1235 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 17:50:33 up 5 days, 13:50,  1 user,  load average: 0.34, 0.45, 0.35
    Tasks: 143 total,   1 running, 142 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  3.0 us,  6.1 sy,  0.0 ni, 90.9 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3838.7 total,   1479.4 free,    949.1 used,   1410.2 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2724.6 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       59G  7.5G   49G  14% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [Sat Jan 25 04:00:16 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:45:7A:9C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Jan 25 04:00:17 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jan 25 04:00:17 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jan 25 04:00:20 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    854M    /var/
    652M    /var/cache
    646M    /var/cache/apt
    587M    /var/cache/apt/archives
    98M     /var/lib
    Archived and active journals take up 8.0M in the file system.
    /opt/iobroker/backups:
    74M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    872M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    42M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
    8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2198950-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.20.6
    /usr/bin/node           v18.20.6
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 18.20.6-1nodesource1
      Candidate: 18.20.6-1nodesource1
      Version table:
     *** 18.20.6-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.20.5-1nodesource1 1001
         18.20.4-1nodesource1 1001
         18.20.3-1nodesource1 1001
         18.20.2-1nodesource1 1001
         18.20.1-1nodesource1 1001
         18.20.0-1nodesource1 1001
         18.19.1-1nodesource1 1001
         18.19.0-1nodesource1 1001
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi4-iob    raspberrypi4-iob (version: 7.0.6, hostname: raspberrypi4-iob, alive, uptime: 32467)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.deconz@2.0.7 (git+ssh://git@github.com/Jey-Cee/ioBroker.deconz.git#8af7464adc2de2241a4d0136e2189a9825d38105)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: xxxx, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi4-iob                         -  enabled, port: xx
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi4-iob                         -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4-iob                         -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: xxxxx
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: xxxxx
    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi4-iob                         -  enabled, port: xxxxx
      system.adapter.ring.0                   : ring                  : raspberrypi4-iob                         - disabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: xxxxx, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4-iob                         -  enabled, port: xxxxx, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: xxxxx, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : raspberrypi4-iob                         -  enabled
      system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         - disabled
      system.adapter.tr-064.1                 : tr-064                : raspberrypi4-iob                         - disabled
      system.adapter.tr-064.2                 : tr-064                : raspberrypi4-iob                         - disabled
      system.adapter.tr-064.3                 : tr-064                : raspberrypi4-iob                         - disabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         - disabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: xxxxx, bind: 0.0.0.0, run as: admin
    + instance is alive
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: xxxxx, bind: 0.0.0.0, run as: admin
    + system.adapter.deconz.0                 : deconz                : raspberrypi4-iob                         -  enabled, port: xxxxx
    ioBroker-Repositories
    │ (index) │   name    │                           url                           │ auto upgrade │
    │    0    │   '33'    │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
    │    1    │ 'default' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    │    2    │ 'stable'  │    'http://download.iobroker.net/sources-dist.json'     │    false     │
    Active repo(s): stable1, stable2, default, stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repositories: stable1, stable2, default, stable
    Error: unknown repository is active - "stable1". Known: 33, default, stable
    Error: unknown repository is active - "stable2". Known: 33, default, stable
    Adapter    "admin"        : 7.4.10   , installed 7.4.10
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "deconz"       : 1.6.4    , installed 2.0.7
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "ring"         : 6.3.0    , installed 5.1.0  [Updatable]
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "telegram"     : 4.0.0    , installed 3.9.0  [Updatable]
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Objects and States
    Objects:        4068
    States:         3704
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:xxxxx              0.0.0.0:*               LISTEN      1000       15331      373/deCONZ
    tcp        0      0 0.0.0.0:xxxxx              0.0.0.0:*               LISTEN      0          16227      665/sshd
    tcp        0      0 0.0.0.0:xxxxx            0.0.0.0:*               LISTEN      1001       10947450   9736/io.sonoff.0
    tcp        0      0 0.0.0.0:xxxxx             0.0.0.0:*               LISTEN      1000       15342      373/deCONZ
    tcp        0      0 192.168.x.x:xxxxx     0.0.0.0:*               LISTEN      1001       10948782   9712/io.hm-rpc.1
    tcp        0      0 127.0.0.1:xxxxx          0.0.0.0:*               LISTEN      1001       10945799   9257/iobroker.js-co
    tcp        0      0 127.0.0.1:xxxxx          0.0.0.0:*               LISTEN      1001       10946735   9257/iobroker.js-co
    tcp        0      0 192.168.x.x:xxxxx      0.0.0.0:*               LISTEN      1001       10947518   9721/io.hm-rpc.2
    tcp        0      0 192.168.x.x:xxxxx      0.0.0.0:*               LISTEN      1001       10946446   9700/io.hm-rpc.0
    tcp6       0      0 :::xxxxx                 :::*                    LISTEN      1001       10944420   9311/io.admin.0
    tcp6       0      0 :::xxxxx                 :::*                    LISTEN      1001       10949671   9937/io.web.0
    tcp6       0      0 :::xxxxx                   :::*                    LISTEN      0          16229      665/sshd
    tcp6       0      0 :::xxxxx                 :::*                    LISTEN      1001       10948108   9863/io.simple-api.
    udp        0      0 0.0.0.0:xxxxx              0.0.0.0:*                           0          17053      657/dhcpcd
    udp        0      0 0.0.0.0:xxxxx           0.0.0.0:*                           108        15997      353/avahi-daemon: r
    udp        0      0 0.0.0.0:xxxxx            0.0.0.0:*                           108        15995      353/avahi-daemon: r
    udp        0      0 0.0.0.0:xxxxx            0.0.0.0:*                           1001       10948856   9760/io.deconz.0
    udp        0      0 0.0.0.0:xxxxx            0.0.0.0:*                           1000       15345      373/deCONZ
    udp6       0      0 :::xxxxx                :::*                                108        15998      353/avahi-daemon: r
    udp6       0      0 :::xxxxx                  :::*                                0          14313      657/dhcpcd
    udp6       0      0 :::xxxxx                 :::*                                108        15996      353/avahi-daemon: r
    udp6       0      0 :::xxxxx                 :::*                                1001       10948858   9760/io.deconz.0
    udp6       0      0 :::xxxxx                 :::*                                1001       10948857   9760/io.deconz.0
    2025-01-30 15:53:03.893  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738248747424_4101 ==> New secret 1738248783888_79
    2025-01-30 16:03:13.947  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738248783888_7951 ==> New secret 1738249393941_14
    2025-01-30 16:03:24.175  - info: sonoff.0 (9736) Client [Tasmota5] reconnected. Old secret 1738248736326_9860 ==> New secret 1738249404174_61
    2025-01-30 16:05:41.941  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738249393941_1495 ==> New secret 1738249541940_66
    2025-01-30 16:05:42.204  - info: sonoff.0 (9736) Client [Tasmota5] reconnected. Old secret 1738249404174_6117 ==> New secret 1738249542203_12
    2025-01-30 16:08:06.939  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738249541940_6699 ==> New secret 1738249686938_53
    2025-01-30 16:16:06.046  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738249686938_5302 ==> New secret 1738250166040_3
    2025-01-30 16:16:18.180  - info: sonoff.0 (9736) Client [Tasmota5] reconnected. Old secret 1738249542203_1266 ==> New secret 1738250178150_89
    2025-01-30 16:27:19.863  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738250166040_309 ==> New secret 1738250839863_9
    2025-01-30 16:32:04.895  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738250839863_994 ==> New secret 1738251124894_96
    2025-01-30 16:39:13.871  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738251124894_9627 ==> New secret 1738251553871_45
    2025-01-30 16:39:48.909  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738251553871_4574 ==> New secret 1738251588908_88
    2025-01-30 16:39:49.966  - info: sonoff.0 (9736) Client [Tasmota5] reconnected. Old secret 1738250178150_8908 ==> New secret 1738251589965_28
    2025-01-30 16:40:13.192  - info: sonoff.0 (9736) Client [Tasmota8] reconnected. Old secret 1738243431926_8409 ==> New secret 1738251613191_41
    2025-01-30 16:42:01.858  - info: sonoff.0 (9736) Client [Tasmota5] reconnected. Old secret 1738251589965_2834 ==> New secret 1738251721858_58
    2025-01-30 16:42:01.910  - info: sonoff.0 (9736) Client [Tasmota1] reconnected. Old secret 1738251588908_8888 ==> New secret 1738251721907_21
    2025-01-30 17:44:38.337  - error: host.raspberrypi4-iob cannot call visUtils: Not exists
    2025-01-30 17:44:39.318  - warn: host.raspberrypi4-iob Requested repository "stable1" does not exist in config.
    2025-01-30 17:44:39.318  - warn: host.raspberrypi4-iob Requested repository "stable2" does not exist in config.
    2025-01-30 17:44:52.308  - warn: host.raspberrypi4-iob Requested repository "stable1" does not exist in config.
    2025-01-30 17:44:52.310  - warn: host.raspberrypi4-iob Requested repository "stable2" does not exist in config.
    2025-01-30 17:44:52.698  - warn: admin.0 (9311) No repository source configured
    2025-01-30 17:44:54.288  - warn: admin.0 (9311) No repository source configured
    2025-01-30 17:44:54.319  - warn: admin.0 (9311) No repository source configured
    2025-01-30 17:44:54.415  - warn: admin.0 (9311) No repository source configured
      Ich nutze den iob eigentlich nur für deconz, sonoff als Schnittstelle für Raspmatic (CCU3), damit ich die Sachen dort bedienen kann.
      Das 'ich nutz das nur für XYZ' heißt aber nicht, das man die Kisten dann nie aktuell halten muss.
      N Offline
      N Offline
      Nagamichisan
      @thomas-braun said in Update Node.js ioBroker läuft nicht:
      Danke, ja, das habe ich nun verstanden, war mir tatsächlich nicht bewusst.
      • N Nagamichisan
        @nagamichisan
        Veränder die Ausgaben des Skripts nicht.
        • N Nagamichisan
          ```bash
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm
          Docker          : false
          Kernel          : armv7l
          Userland        : 32 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           99M          0B         99M
                   3838 M total memory
                    948 M used memory
                    437 M active memory
                   1480 M free memory
                    174 M buffer memory
                   1235 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          854M    /var/
          652M    /var/cache
          646M    /var/cache/apt
          98M     /var/lib
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.4.10
          javascript:     8.8.3
          Adapter State
          + instance is alive
          Objects and States
          Objects:        4068
          States:         3704
          Pending Updates: 0
          Besser nur eine Quelle aktiv haben. Bei mehreren gibt es da immer Chaos.
          Ist eh schon ein chaotisches Setup bei dir:
          N 1 Antwort Letzte Antwort
            N Offline
            N Offline
            Nagamichisan
            ...was weiß ich, ich habe das vor ein paar Jahren nach Anleitung aufgesetzt und tut seither alles tutti.
            Da ich kein Deep Dive Pro da bin, kann ich das nicht beurteilen, da kein Plan ;)
            • N Nagamichisan
              Dann war das eine %"56"-Anleitung. Wo auch immer du die her hast.
              • N Nagamichisan
                @nagamichisan
                Saubere Repo sehen z. B. so aus:
                echad@chet:~ $ iob repo list
                │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                │ 1       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                │ 2       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                │ 3       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                Active repo(s): beta
                  @nagamichisan
                  mcm1957M Offline
                  mcm1957M Offline
                  mcm1957
                  Links oben gibts nen Button um die Repos auf Default zu resetten:
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • mcm1957M mcm1957
                    N Offline
                    N Offline
                    Nagamichisan
                    @mcm1957 said in Update Node.js ioBroker läuft nicht:
                    Aber jetzt brauch ich das nicht mehr tun, wenn ich eh neu aufsetzen muss, oder?
                    mcm1957M Thomas BraunT 2 Antworten Letzte Antwort
                    • N Nagamichisan
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @nagamichisan
                      Ja kannst mal lassen. Aber schau ob das nach dem Restore nicht wieder "komisch" ist.
                      • N Offline
                        N Offline
                        Nagamichisan
                        Dann freue ich mich eh alles neu zu machen, wenn das irgendwie alles nicht so passt.
                        Frage war noch, weil ihr das lange diag sehen wolltet, ob der pi4 ausreicht. Meine Leihenwissen sagt anhand der Werte "eher ja".
                        • N Nagamichisan
                          CodierknechtC Offline
                          Codierknecht
                          Sollte für die paar Adapter eigentlich reichen.
                          Den "Discovery" kannst Du bei einem einmal eingerichteten System rauswerfen.
                          Und ob da wirklich mehrere Instanzen von "tr-064" und "hm-rpc" laufen müssen?
                          Ansonsten dürfte der fürs Erste noch reichen.
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • N Nagamichisan
                            Würde ich jetzt geraderücken, sonst ist das in einem Backup ja noch so krumm drin.
                              Andreas 3
                              Hallo Zusammen,
                              ich bin ziemlich neu hier im Forum und habe (glaube ich) ein ähnliches Problem. Mein IO-Broker lief einige Jahre vor sich hin und ich habe mich ganz nach dem Motto "never touch a running system" verhalten. Jetz wollte ich einige Änderungen an meiner Visu vornehmen und dabei natürlich alles auf den neuesten Stand bringen.
                              Sudo update & sudo upgrade lief durch, der Pi wurde neugestartet - nun klappt das Update von js-controller (Ver. 4.0.23 -> 7.0.6) irgendwie nicht. Der Befehl "upgrade self" wird ausgeführt, geht aber ohne Meldung wieder in den Prompt zurück:
                              Wenn ich "iob diag" ausführe, bricht er ab mit:
                              "iob fix" läuft durch -> "iob diag" verlangt wieder "iob fix" usw.. Ich weiß nicht wo ich ansetzen kann, könnte mir bitte jemand eine Hilfestellung geben?
                              System:
                              Ich vermute, dass mehr Infos benötigt werden - ich weiß leider nicht welche sinnvoll wären. Sagt mir gerne Bescheid was benötigt wird, dann poste ich die Sachen hier.
                              Vielen Dank schon mal im voraus!
                              A Thomas BraunT 2 Antworten Letzte Antwort
                              • A Andreas 3
                                Hallo Zusammen,
                                System:
                                Andreas 3
                                @andreas-3 sagte in Update Node.js ioBroker läuft nicht:
                                Hallo Zusammen,
                                System:
                                PS:
                                kann es auch ander OS-Version liegen?:
                                pi@raspberrypi:~ $ lsb_release -a
                                No LSB modules are available.
                                Distributor ID: Raspbian
                                Description:    Raspbian GNU/Linux 10 (buster)
                                Release:        10
                                Codename:       buster
                                • A Andreas 3
                                  Hallo Zusammen,
                                  System:
                                  Grundlegend falsches Verhalten.
                                  Buster ist komplett veraltet. Wie der Rest dann auch.
                                  Du hast das System jetzt so lange nicht getatscht, musst du neuinstallieren.
                                  iob diag
                                  muss temporär auf einem Raspberry so aufgerufen werden:
                                  curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
                                  chmod 744 iob_diag.sh
                                  ./iob_diag.sh
                                  • A Andreas 3
                                    Hallo Zusammen,
                                    System:
                                    PS:
                                    Release:        10
                                    Codename:       buster
                                    @andreas-3
                                    Ist eine Folge vom 'never tatsch a system'...
                                      @andreas-3
                                      Andreas 3
                                      Danke für die schnelle Rückmeldung! So was habe ich schon befürchtet...
                                      Andreas
                                      • A Andreas 3
                                        Andreas
                                        Was heißt hier Befürchtung? Das ist die natürliche und zwangläufige Folge, wenn man das Ding nicht pflegt.
                                        Wer das also nicht regelmäßig 'toucht', der hat dann halt irgendwann genau diese Auswirkungen.
