  4. BackItUp Adapter jarvis Fehlermeldung
22 Beiträge 6 Kommentatoren 3.0k Aufrufe 6 Beobachtet
  • simatecS simatec
    @chappo59 Bitte poste hier den Debuglog
    chappo59C Offline
    chappo59C Offline
    chappo59
    @simatec
    Ich sehe gerade, da hat sich eine Instanz 1 eingeschlichen, die es bei mir gar nicht gibt.
    [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
    [DEBUG] [jarvis] found Jarvis Instance: 0
    [DEBUG] [jarvis] start Jarvis Backup for Instance 0...
    [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis1"
    [DEBUG] [jarvis] found Jarvis Instance: 1
    [DEBUG] [jarvis] start Jarvis Backup for Instance 1...
    [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/0 copy success!
    [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
    [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/1 copy success!
    [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis1/states"
    [WARN] [jarvis] settings "css" not found
    [WARN] [jarvis] settings "devices" not found
    [WARN] [jarvis] settings "layout" not found
    [WARN] [jarvis] settings "notifications" not found
    [WARN] [jarvis] settings "widgets" not found
    [WARN] [jarvis] settings "scripts" not found
    [WARN] [jarvis] settings "theme" not found
    [WARN] [jarvis] settings "pro" not found
    [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis1"
    [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis1" successfully deleted
    [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.1_2024_11_14-18_13_39_backupiobroker.tar.gz
    [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
    [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
    [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.0_2024_11_14-18_13_39_backupiobroker.tar.gz
    [DEBUG] [jarvis] done
    • chappo59C chappo59
      @simatec
      simatecS Offline
      simatecS Offline
      simatec
      @chappo59 Dann lösche mal den Ordner in /iobroker-data und ggfs. die Objekte unter jarvis.1.
      • Besuche meine Github Seite
      • HowTo Restore ioBroker
      • E el-lutschi
        seit einiger Zeit erhalte ich beim Backup von jarvis folgende Meldungen in der Log:
        2024-10-17 08:19:39.325 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "css" not found
        2024-10-17 08:19:39.326 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "devices" not found
        2024-10-17 08:19:39.328 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "layout" not found
        2024-10-17 08:19:39.330 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "notifications" not found
        2024-10-17 08:19:39.332 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "widgets" not found
        2024-10-17 08:19:39.333 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "scripts" not found
        2024-10-17 08:19:39.334 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "theme" not found
        2024-10-17 08:19:39.335 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "pro" not found
        Ansonsten scheint laut Log alles OK zu sein. Auch wenn ich das Backup manuell starte wird es als erfolgreich gekennzeichnet. Jemand ne Idee was da los sein könnte?
        Gruss
        Chris
        simatecS Offline
        simatecS Offline
        simatec
        @el-lutschi auch bei dir wäre der vollständige Debuglog vom Backup interessant
        chappo59C 1 Antwort Letzte Antwort
        • simatecS simatec
          chappo59C Offline
          chappo59C Offline
          chappo59
          schrieb am zuletzt editiert von chappo59
          @simatec Das Objekt jarvis.1 hatte ich gerade kurz zuvor versuchsweise gelöscht. Das brachte keinen Erfolg.
          Des Rätsels Lösung war vermutlich den Ordner "1" unter /iobroker-data/jarvis zu löschen. Jetzt lief das Backup ohne Fehlermeldung durch.
          Herzlichen Dank für die tolle Unterstützung.
            simatecS Offline
            simatecS Offline
            simatec
            @chappo59 sehr gerne 😉
            • G Offline
              gutgut30
              Auch ich erhalte die Meldung "[iobroker/jarvis] settings "theme" not found", habe den Eintrag "theme" in den Objekten aber auch nicht. Die Installation ist "frisch".
              Den Eintrag im Adapter anlegen fühlt sich nicht so ganz korrekt an.
              • G gutgut30
                MCU
                @gutgut30 Ist bei neueren Versionen korrigiert worden.
                Dort gibt es aber noch andere Probleme, so dass man sich ein Wechsel überlegen, bzw. Issues prüfen sollte.
                G 1 Antwort Letzte Antwort
                • M MCU
                  gutgut30
                  @mcu Okay, danke für die Info. Dann warte ich mal ab.
                  Aktuell wird also die Meldung ausgegeben, das Backup aber erstellt?
                  • G gutgut30
                    MCU
                    @gutgut30 Solange du keine neue jarvis-Version installierst, kannst du auch einen jarvis.0.theme DP anlegen, dann verschwindet die Meldung.
                      "_id": "jarvis.0.theme",
                      "type": "state",
                      "common": {
                        "name": "Theme",
                        "role": "json",
                        "type": "string",
                        "read": true,
                        "write": true,
                        "def": "{}"
                      "from": "system.adapter.jarvis.0",
                      "user": "system.user.admin",
                      "ts": 1734304396000,
                      "acl": {
                        "object": 1636,
                        "state": 1636,
                        "owner": "system.user.admin",
                    • M MCU
                        "type": "state",
                        "common": {
                          "name": "Theme",
                          "role": "json",
                          "type": "string",
                          "read": true,
                          "write": true,
                          "def": "{}"
                        "acl": {
                          "object": 1636,
                          "state": 1636,
                      sokrates
                      @mcu vielen dank, das hat bei mir funktioniert. aber man muss theme klein schreiben. :)
                      • S sokrates
                        MCU
                        @sokrates sagte in BackItUp Adapter jarvis Fehlermeldung:
                        Wo ist es groß geschrieben? Oder nur als Hinweis?
