  4. BackItUp Adapter jarvis Fehlermeldung
22 Beiträge 6 Kommentatoren 3.0k Aufrufe 6 Beobachtet
  • E Offline
    el-lutschi
    @mcu Danke für den Tipp. Hat leider auch nicht geholfen.
    chappo59C 1 Antwort Letzte Antwort
    • E el-lutschi
      chappo59C Offline
      chappo59C Offline
      chappo59
      Schade, dass es hier keine weiteren Lösungsvorschläge gibt. Habe nämlich das gleiche Problem.
      • chappo59C chappo59
        simatecS Offline
        simatecS Offline
        simatec
        @chappo59 Bitte poste hier den Debuglog
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        • simatecS simatec
          chappo59C Offline
          chappo59C Offline
          chappo59
          @simatec
          Ich sehe gerade, da hat sich eine Instanz 1 eingeschlichen, die es bei mir gar nicht gibt.
          [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0"
          [DEBUG] [jarvis] found Jarvis Instance: 0
          [DEBUG] [jarvis] start Jarvis Backup for Instance 0...
          [DEBUG] [jarvis] Created jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis1"
          [DEBUG] [jarvis] found Jarvis Instance: 1
          [DEBUG] [jarvis] start Jarvis Backup for Instance 1...
          [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/0 copy success!
          [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states"
          [DEBUG] [jarvis] /opt/iobroker/iobroker-data/jarvis/1 copy success!
          [DEBUG] [jarvis] Created states_tmp directory: "/opt/iobroker/backups/tmpJavis1/states"
          [WARN] [jarvis] settings "css" not found
          [WARN] [jarvis] settings "devices" not found
          [WARN] [jarvis] settings "layout" not found
          [WARN] [jarvis] settings "notifications" not found
          [WARN] [jarvis] settings "widgets" not found
          [WARN] [jarvis] settings "scripts" not found
          [WARN] [jarvis] settings "theme" not found
          [WARN] [jarvis] settings "pro" not found
          [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis1"
          [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis1" successfully deleted
          [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.1_2024_11_14-18_13_39_backupiobroker.tar.gz
          [DEBUG] [jarvis] Try deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0"
          [DEBUG] [jarvis] Jarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted
          [DEBUG] [jarvis] Backup created: /opt/iobroker/backups/jarvis.0_2024_11_14-18_13_39_backupiobroker.tar.gz
          [DEBUG] [jarvis] done
            @simatec
            simatecS Offline
            simatecS Offline
            simatec
            @chappo59 Dann lösche mal den Ordner in /iobroker-data und ggfs. die Objekte unter jarvis.1.
            • E el-lutschi
              seit einiger Zeit erhalte ich beim Backup von jarvis folgende Meldungen in der Log:
              2024-10-17 08:19:39.325 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "css" not found
              2024-10-17 08:19:39.326 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "devices" not found
              2024-10-17 08:19:39.328 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "layout" not found
              2024-10-17 08:19:39.330 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "notifications" not found
              2024-10-17 08:19:39.332 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "widgets" not found
              2024-10-17 08:19:39.333 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "scripts" not found
              2024-10-17 08:19:39.334 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "theme" not found
              2024-10-17 08:19:39.335 - warn: backitup.0 (2071895) [iobroker/jarvis] settings "pro" not found
              Ansonsten scheint laut Log alles OK zu sein. Auch wenn ich das Backup manuell starte wird es als erfolgreich gekennzeichnet. Jemand ne Idee was da los sein könnte?
              Gruss
              Chris
              simatecS Offline
              simatecS Offline
              simatec
              @el-lutschi auch bei dir wäre der vollständige Debuglog vom Backup interessant
              • simatecS simatec
                chappo59C Offline
                chappo59C Offline
                chappo59
                schrieb am zuletzt editiert von chappo59
                @simatec Das Objekt jarvis.1 hatte ich gerade kurz zuvor versuchsweise gelöscht. Das brachte keinen Erfolg.
                Des Rätsels Lösung war vermutlich den Ordner "1" unter /iobroker-data/jarvis zu löschen. Jetzt lief das Backup ohne Fehlermeldung durch.
                Herzlichen Dank für die tolle Unterstützung.
                  simatecS Offline
                  simatecS Offline
                  simatec
                  @chappo59 sehr gerne 😉
                  • G Offline
                    gutgut30
                    Auch ich erhalte die Meldung "[iobroker/jarvis] settings "theme" not found", habe den Eintrag "theme" in den Objekten aber auch nicht. Die Installation ist "frisch".
                    Den Eintrag im Adapter anlegen fühlt sich nicht so ganz korrekt an.
                    • G gutgut30
                      MCU
                      @gutgut30 Ist bei neueren Versionen korrigiert worden.
                      Dort gibt es aber noch andere Probleme, so dass man sich ein Wechsel überlegen, bzw. Issues prüfen sollte.
                      G 1 Antwort Letzte Antwort
                      • M MCU
                        gutgut30
                        @mcu Okay, danke für die Info. Dann warte ich mal ab.
                        Aktuell wird also die Meldung ausgegeben, das Backup aber erstellt?
                        • G gutgut30
                          MCU
                          @gutgut30 Solange du keine neue jarvis-Version installierst, kannst du auch einen jarvis.0.theme DP anlegen, dann verschwindet die Meldung.
                            "_id": "jarvis.0.theme",
                            "type": "state",
                            "common": {
                              "name": "Theme",
                              "role": "json",
                              "type": "string",
                              "read": true,
                              "write": true,
                              "def": "{}"
                            "from": "system.adapter.jarvis.0",
                            "user": "system.user.admin",
                            "ts": 1734304396000,
                            "acl": {
                              "object": 1636,
                              "state": 1636,
                              "owner": "system.user.admin",
                          • M MCU
                              "type": "state",
                              "common": {
                                "name": "Theme",
                                "role": "json",
                                "type": "string",
                                "read": true,
                                "write": true,
                                "def": "{}"
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                            sokrates
                            @mcu vielen dank, das hat bei mir funktioniert. aber man muss theme klein schreiben. :)
                            • S sokrates
                              MCU
                              @sokrates sagte in BackItUp Adapter jarvis Fehlermeldung:
                              Wo ist es groß geschrieben? Oder nur als Hinweis?
