  4. iob started nicht nach raspi os update
55 Beiträge 4 Kommentatoren 8.4k Aufrufe 2 Beobachtet
  • H hukio
    @haselchen
    admin.0 hat nichts gebracht.
    Script v.2024-10-19
    *** BASE SYSTEM ***
     Static hostname: raspi5
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:17:16 up 11 min,  2 users,  load average: 0.07, 0.15, 0.10
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2024-12-18 17:17:16 CET
               Universal time: Wed 2024-12-18 16:17:16 UTC
                     RTC time: Wed 2024-12-18 16:17:16
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev influxdb gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        257M        7.6G        5.7M        734M        8.2G
    Swap:           209M          0B        209M
    Total:          8.7G        257M        7.8G
    Active iob-Instances:   1
             8052 M total memory
              245 M used memory
              281 M active memory
              426 M inactive memory
             7208 M free memory
               65 M buffer memory
              634 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 17:17:16 up 11 min,  2 users,  load average: 0.15, 0.17, 0.11
    Tasks: 160 total,   1 running, 159 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   7208.4 free,    245.2 used,    700.3 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   7807.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     806M  5.4M  800M   1% /run
    /dev/sdb2      ext4       29G   15G   13G  55% /
    tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/sdb1      vfat      253M   64M  189M  26% /boot/firmware
    tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
    [Wed Dec 18 17:05:40 2024] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:26:02:CA vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=4fa94ab9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Wed Dec 18 17:05:46 2024] EXT4-fs (sdb2): mounted filesystem 59fa7759-b600-4279-9af4-cd8198395907 ro with ordered data mode. Quota mode: none.
    [Wed Dec 18 17:05:48 2024] EXT4-fs (sdb2): re-mounted 59fa7759-b600-4279-9af4-cd8198395907 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sdb2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/sdb1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    1.6G    /var/log/journal/9bc553d4544e4bcc96a7d5aa03a8d697
    1.6G    /var/log
    453M    /var/cache
    Archived and active journals take up 1.5G in the file system.
    /opt/iobroker/backups:
    6.0G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    882M    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: redis
    Hosts:
    raspi5              raspi5 (version: 7.0.3, hostname: raspi5        , alive, uptime: 3845)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     8.8.3
    nodejs modules from github:     1
    `-- iobroker.zigbee@1.10.10 (git+ssh://git@github.com/ioBroker/ioBroker.zigbee.git#40073e03301995ffa45471b6b32204a37c9d6743)
    Adapter State
      system.adapter.adb.0                    : adb                   : raspi5                                   - disabled
      system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : raspi5                                   -  enabled
      system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
      system.adapter.ble.0                    : ble                   : raspi5                                   - disabled
      system.adapter.broadlink2.0             : broadlink2            : raspi5                                   - disabled
      system.adapter.daikin.0                 : daikin                : raspi5                                   -  enabled
      system.adapter.daikin.1                 : daikin                : raspi5                                   -  enabled
      system.adapter.discovery.0              : discovery             : raspi5                                   - disabled
      system.adapter.doorbird.0               : doorbird              : raspi5                                   -  enabled
      system.adapter.email.0                  : email                 : raspi5                                   - disabled
      system.adapter.email.1                  : email                 : raspi5                                   -  enabled
      system.adapter.flot.0                   : flot                  : raspi5                                   - disabled
      system.adapter.fritzdect.0              : fritzdect             : raspi5                                   -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : raspi5                                   -  enabled
      system.adapter.history.0                : history               : raspi5                                   -  enabled
      system.adapter.influxdb.0               : influxdb              : raspi5                                   -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : raspi5                                   -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspi5                                   -  enabled
      system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
      system.adapter.lgtv.0                   : lgtv                  : raspi5                                   -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspi5                                   -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo.0                : netatmo               : raspi5                                   -  enabled
      system.adapter.nuki-extended.0          : nuki-extended         : raspi5                                   -  enabled
      system.adapter.onkyo.0                  : onkyo                 : raspi5                                   -  enabled
      system.adapter.onvif.0                  : onvif                 : raspi5                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.onvif.1                  : onvif                 : raspi5                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.ping.0                   : ping                  : raspi5                                   - disabled
      system.adapter.robonect.0               : robonect              : raspi5                                   - disabled
      system.adapter.scenes.0                 : scenes                : raspi5                                   -  enabled
      system.adapter.shelly.0                 : shelly                : raspi5                                   -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shelly.1                 : shelly                : raspi5                                   -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.signal-cmb.0             : signal-cmb            : raspi5                                   -  enabled
      system.adapter.simple-api.0             : simple-api            : raspi5                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : raspi5                                   -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sonoff.0                 : sonoff                : raspi5                                   -  enabled, port: 1889, bind: 0.0.0.0
      system.adapter.telegram.0               : telegram              : raspi5                                   - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : raspi5                                   - disabled
      system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspi5                                   - disabled
      system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_323adb3b74d9eb11b6e6178e6fe9f4d9-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "adb"          : 0.0.7    , installed 0.0.7
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daikin"       : 1.4.2    , installed 1.4.2
    Adapter    "doorbird"     : 2.0.0    , installed 2.0.0
    Adapter    "email"        : 1.3.1    , installed 1.3.1
    Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
    Adapter    "fullybrowser" : 3.0.12   , installed 3.0.12
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "robonect"     : 1.4.2    , installed 1.4.2
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 8.2.1    , installed 8.2.1
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "telegram"     : 3.9.0    , installed 3.9.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 6.2.5    , installed 6.2.5
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.10
    Objects and States
    Objects:        11619
    States:         7667
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        7217       801/redis-server 12
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5694       809/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5696       809/sshd: /usr/sbin
    tcp6       0      0 ::1:6379                :::*                    LISTEN      106        7218       801/redis-server 12
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4096       666/avahi-daemon: r
    udp        0      0 0.0.0.0:58704           0.0.0.0:*                           104        7170       666/avahi-daemon: r
    udp6       0      0 fe80::555:b02a:8105:546 :::*                                0          5080       768/NetworkManager
    udp6       0      0 fe80::a6d8:8469:6a0:546 :::*                                0          5733       768/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        7169       666/avahi-daemon: r
    udp6       0      0 :::54578                :::*                                104        7171       666/avahi-daemon: r
    2024-12-18 13:27:27.731  - info: host.raspi5 instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:27.773  - info: host.raspi5 instance system.adapter.influxdb.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:27.850  - info: host.raspi5 instance system.adapter.daikin.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:27.892  - info: host.raspi5 instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:27.930  - info: host.raspi5 instance system.adapter.lgtv.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.006  - info: host.raspi5 instance system.adapter.netatmo.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.045  - info: host.raspi5 instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.087  - info: host.raspi5 instance system.adapter.fullybrowser.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.159  - info: host.raspi5 instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.201  - info: host.raspi5 instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.244  - warn: host.raspi5 instance system.adapter.javascript.0 terminated due to SIGKILL
    2024-12-18 13:27:28.244  - info: host.raspi5 instance system.adapter.javascript.0 terminated with code null ()
    2024-12-18 13:27:28.319  - warn: host.raspi5 instance system.adapter.sonoff.0 terminated due to SIGKILL
    2024-12-18 13:27:28.319  - info: host.raspi5 instance system.adapter.sonoff.0 terminated with code null ()
    2024-12-18 13:27:28.359  - warn: host.raspi5 instance system.adapter.signal-cmb.0 terminated due to SIGKILL
    2024-12-18 13:27:28.359  - info: host.raspi5 instance system.adapter.signal-cmb.0 terminated with code null ()
    2024-12-18 13:27:28.431  - warn: host.raspi5 instance system.adapter.web.0 terminated due to SIGKILL
    2024-12-18 13:27:28.431  - info: host.raspi5 instance system.adapter.web.0 terminated with code null ()
    2024-12-18 13:27:28.469  - info: host.raspi5 instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
    2024-12-18 13:27:28.470  - info: host.raspi5 All instances are stopped.
    2024-12-18 13:27:30.654  - error: host.raspi5 Cannot find view "system" for search "instance" : Connection is closed.
    2024-12-18 13:27:30.655  - warn: host.raspi5 instance system.adapter.zigbee.0 terminated due to SIGKILL
    2024-12-18 13:27:30.655  - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code null ()
    2024-12-18 13:27:30.655  - info: host.raspi5 All instances are stopped.
    2024-12-18 13:27:30.664  - info: host.raspi5 terminated
    iob diag has finished.
    @hukio sagte in iob started nicht nach raspi os update:
    mal mit --debug!
    iob start admin.0 --debug
    und Ergebnis zeigen!
    H 1 Antwort Letzte Antwort
    • H hukio
      hab ich oben doch schon gesendet
      hukio
      wenn ich iob fix laufen lasse kommt bei checking autostart folgende rote warnung:
      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
      Authentication is required to stop 'iobroker.service'.
      Authenticating as: ,,, (pi)
      Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
      hukraspiEnabling autostart...
      Autostart enabled!
      • H hukio
        @hukio
        Sorry, hatte ich übersehen.
        apt policy redis
        sagt? Und
        systemctl status iobroker.service
        • H hukio
          Autostart enabled!
          Hast du den User 'pi' nach der Installation des iobrokers ab- und wieder angemeldet? Oder gleich die ganze Kiste mal sauber durchgestartet?
          Grundsätzlich ist es auch nicht mehr empohlen, den ersten User 'pi' zu nennen. Verwende deinen Vornamen oder Forennick oder sowas.
            mal mit --debug!
            hukio
            @homoran said in iob started nicht nach raspi os update:
            iob start admin.0 --debug bringt keine reaktion, läuft durch
              @hukio
              apt policy redis
              sagt? Und
              hukio
              pi@raspi5:~ $ systemctl status iobroker.service
              ○ iobroker.service - ioBroker Server
                   Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: ena>
                   Active: inactive (dead)
                     Docs: http://iobroker.net
              Dec 18 17:33:25 raspi5 systemd[1]: Failed to start iobroker.service.
              lines 1-6/6 (END)
              pi@raspi5:~ $ apt policy redis
              redis:
                Installed: 5:7.0.15-1~deb12u1
                Candidate: 5:7.0.15-1~deb12u1
                Version table:
               *** 5:7.0.15-1~deb12u1 500
                      500 http://deb.debian.org/debian bookworm/main armhf Packages
                      500 http://deb.debian.org/debian-security bookworm-security/main armhf Packages
                hukio
                Ich bin mir nicht sicher. Schon länger her, daß ich installiert habe. Glaube aber, daß ich user nach user pi umbenannt habe.
                • H hukio
                  ich bat
                  @homoran sagte in iob started nicht nach raspi os update:
                  Ergebnis zeigen!
                  preset: ena>
                  abgeschnitten!
                  fehlt sonst noch was?
                    ich bat
                    Ergebnis zeigen!
                    preset: ena>
                    abgeschnitten!
                    hukio
                    nochmals
                    das ist das ganze
                    • H hukio
                      nochmals
                      das ist das ganze
                      @hukio
                      Nein, das geht rechts weiter.
                      Terminalfenster größer ziehen.
                      Hast du mal den hostname nachträglich geändert?
                        @hukio
                        hukio
                        schrieb am zuletzt editiert von hukio
                        glaube ich nicht. Habe installiert und dann nichts mehr geändert. Habe früher schon OS updates gemacht
                        • H hukio
                          @hukio
                          systemctl restart iobroker.service
                          Edit: Und in einem zweiten Terminal beobachten, was passiert:
                          watch systemctl status iobroker
                            @hukio
                            hukio
                            Every 2.0s: systemctl status iobroker        raspi5: Wed Dec 18 18:39:01 2024
                                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                            • H hukio
                              @hukio
                              Mit aktuellem Zeitstempel steht da nix drin?
                              H 2 Antworten Letzte Antwort
                                @hukio
                                hukio
                                bin mir nicht sicher, was Du meinst. Habe watch zuerst gestartet im 2. Fenster und dann systemctl in ersten
                                  @hukio
                                  hukio
                                  meinst Du, daß ich ein restore vom heutigen backup machen sollte? Wird das das Starten ermöglichen?
                                  • H hukio
                                    @hukio
                                    Kommt drauf an, was du mit 'backup' genau meinst.
                                      @hukio
                                      hukio
                                      das Standard backup, das ich mit dem Backitup Adapter jeden Tag mache.
                                      • H hukio
                                        @hukio
                                        Das wird dir vermutlich mit der Authentifizierung beim PAM nicht weiterhelfen.
                                          @hukio
                                          hukio
                                          Mir fällt gerade ein, daß ich vor Kurzem für den iobroker.ble Adapter folgendes installiert habe:
                                          sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev libcap2-bin
                                          Kann das das Starten beeinflußt haben?
