  4. BACKITUP host.raspy-io Cannot pack directory /...
58 Beiträge 5 Kommentatoren 6.9k Aufrufe 4 Beobachtet
  • MartinPM MartinP
    @qax1 jetzt noch einmal ein "df"
    Es scheint, als ob das NAS voll wäre
    Q Offline
    Q Offline
    Qax1
    @martinp
    pi@raspy-io:/opt/iobroker/backups $ df
    Filesystem     1K-blocks    Used Available Use% Mounted on
    udev             1673520       0   1673520   0% /dev
    tmpfs             388296    1168    387128   1% /run
    /dev/mmcblk0p2 122339224 5618616 110489016   5% /
    tmpfs            1941460       0   1941460   0% /dev/shm
    tmpfs               5120      16      5104   1% /run/lock
    /dev/mmcblk0p1    522230   55944    466286  11% /boot/firmware
    tmpfs             388292       0    388292   0% /run/user/1000
    Q 1 Antwort Letzte Antwort
    • Q Qax1
      @martinp
      Q Offline
      Q Offline
      Qax1
      @MartinP
      Sorry Frau hat gerufe "ESSEN is Fertig" :-)
      • Q Qax1
        @MartinP
        Q Offline
        Q Offline
        Qax1
        Da ich jetzt n bisschen den Faden verloren habe,
        hier nochmal n aktueller LOG
        19:18:53.857INFOguiBackup gestartet ...
        19:19:03.909DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
        19:19:04.335DEBUGmountmount successfully completed
        19:19:04.380DEBUGmountdone
        19:19:07.271DEBUGiobrokerhost.raspy-io 1333 objects saved
        19:19:07.355DEBUGiobrokerhost.raspy-io 488 states saved
        19:19:07.358DEBUGiobrokerhost.raspy-io Validating backup ...
        19:19:07.366DEBUGiobrokerhost.raspy-io "config.json" is valid
        19:19:07.376DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
        host.raspy-io "states.jsonl" exists
        19:19:07.619DEBUGiobrokerhost.raspy-io JSONL lines are valid
        19:19:07.623DEBUGiobrokerhost.raspy-io The backup is valid!
        19:19:11.354DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-19_19_03_backupiobroker.tar.gz
        19:19:11.358DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
        19:19:18.156DEBUGiobrokerdone
        19:19:19.223DEBUGzigbeefound zigbee database: zigbee.0
        19:19:19.233DEBUGzigbeedone
        19:19:19.261ERRORzigbeeError: ENOSPC: no space left on device, close
        19:19:20.876DEBUGcifsused copy path: /NetBackup/IO-Backup
        19:19:20.922DEBUGcifsdone
        19:19:21.498ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
        19:19:21.510DEBUGcleandone
        19:19:21.629DEBUGhistoryHTMLnew history html values created
        19:19:21.720DEBUGhistoryHTMLdone
        19:19:21.885DEBUGhistoryJSONnew history json values created
        19:19:21.927DEBUGhistoryJSONdone
        19:19:22.044DEBUGumountmount active, umount is started ...
        19:19:27.114DEBUGumountumount successfully completed
        19:19:27.162DEBUGumountdone
        19:19:29.522DEBUGnotificationAdmin notification will be sent
        19:19:29.536DEBUGnotificationdone
        19:19:29.628INFOguiDas Backup wurde erfolgreich erstellt!
        • mcm1957M mcm1957
          @martinp
          Synology kann auch nfs
          Q Offline
          Q Offline
          Qax1
          @mcm1957
          Aber es hatte ja n weile lang funktioniert.
          • Q Qax1
            @mcm1957
            @qax1
            Hat vermutlich solange funktioniert bis der Speicherplatz ausging.
              @qax1
              Q Offline
              Q Offline
              Qax1
              Deswegen hatte ich heute Morgen
              ganz neu aufgesetzt, was aber leider das Problem nicht behoben hat.
              Ich finde dieses ENOSPC auch nirgends
              • Q Qax1
                @qax1
                Schau auf dem NAS, was da noch verfügbar ist.
                • Q Qax1
                  @qax1 sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                  warum das als zigbeeError deklariert ist, ist mir allerdings schleierhaft
                  • Q Offline
                    Q Offline
                    Qax1
                    Von 2,68 TB sind 3,05 GB belegt....
                    Ich denke das sollte reichen
                      Q Offline
                      Q Offline
                      Qax1
                      Ja, ich meinte,
                      kann ich nicht direkt auf diesen Speicher gucken,
                      ob er wirklich voll ist, bzw. was löschen !?
                      • Q Qax1
                        Ja, ich meinte,
                        Das hängt halt von dem NAS ab. In der Regel kann man die ja auch lokal administirieren.
                          Q Offline
                          Q Offline
                          Qax1
                          Auf dem NAS ist ja Platz...
                          ich hab jetzt im Adapter den "Lokaler Festplattenspeicher Grenzwert für Fehlermeldung (MB)
                          Höher gestellt
                          Irgendwie muß es ja gehen, ging ja schon
                          • Q Qax1
                            Höher gestellt
                            auch in der Freigabe?
                              Q Offline
                              Q Offline
                              Qax1
                              Ja...
                              Was mir jetzt gerade auffällt...
                              //192.xxx.xxx.1xxx/NetBackup/IO-Backup
                              Ist der LEERE Ordner auf dem NAS...
                              Warum hängt da im LOG opt/iobroker/backups hinten dran....
                              Den Ordner gibt es dann ja gar nicht....
                              • Q Qax1
                                Ja...
                                Das ist der Mountpunkt. Also die Stelle, wo das entfernte Dateisystem eingehängt wird.
                                Und der Mountpunkt muss ein leeres Verzeichnis sein.
                                Häng das mal von Hand ein und schau dir df -h an.
                                Bei mir schaut das dann z. B. so aus:
                                echad@chet:~ $ mount /opt/iobroker/backups/
                                echad@chet:~ $ df -h
                                Filesystem                                                        Size  Used Avail Use% Mounted on
                                udev                                                              3.6G     0  3.6G   0% /dev
                                tmpfs                                                             781M  1.3M  780M   1% /run
                                /dev/sda2                                                         110G  8.0G   96G   8% /
                                tmpfs                                                             3.9G     0  3.9G   0% /dev/shm
                                tmpfs                                                             5.0M   16K  5.0M   1% /run/lock
                                /dev/sda1                                                         510M   57M  454M  11% /boot/firmware
                                tmpfs                                                             781M     0  781M   0% /run/user/1000
                                //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet  113G   34G   80G  30% /opt/iobroker/backups
                                echad@chet:~ $
                                Auf meinem NAS sind also noch 80GB / 70% frei.
                                Q 2 Antworten Letzte Antwort
                                  echad@chet:~ $
                                  Q Offline
                                  Q Offline
                                  Qax1
                                  @thomas-braun sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                                  pi@raspy-io:~ $  mount /opt/iobroker/backups/
                                  mount: /opt/iobroker/backups: can't find in /etc/fstab.
                                  kommt dann
                                    echad@chet:~ $
                                    Q Offline
                                    Q Offline
                                    Qax1
                                    Ich hab jetzt mal dsas ZIGBEE Backup rausgenommen,
                                    dann gibt s nur beim IObrocker Backup das :
                                    20:07:56.503INFOguiBackup gestartet ...
                                    20:07:56.642DEBUGmountmount activ... umount is started before mount!!
                                    20:07:56.679DEBUGmountumount successfully completed
                                    20:08:06.649DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
                                    20:08:07.078DEBUGmountmount successfully completed
                                    20:08:07.130DEBUGmountdone
                                    20:08:10.010DEBUGiobrokerhost.raspy-io 1333 objects saved
                                    20:08:10.109DEBUGiobrokerhost.raspy-io 488 states saved
                                    20:08:10.119DEBUGiobrokerhost.raspy-io Validating backup ...
                                    20:08:10.156DEBUGiobrokerhost.raspy-io "config.json" is valid
                                    20:08:10.376DEBUGiobrokerhost.raspy-io JSONL lines are valid
                                    20:08:10.382DEBUGiobrokerhost.raspy-io The backup is valid!
                                    20:08:10.893DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-20_08_06_backupiobroker.tar.gz
                                    20:08:10.896DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                                    20:08:10.954ERRORiobrokerhost.raspy-io Cannot pack directory /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup: ENOSPC: no space left on device, close
                                    20:08:11.890DEBUGiobrokerdone
                                    20:08:14.614DEBUGcifsused copy path: /NetBackup/IO-Backup
                                    20:08:14.659DEBUGcifsdone
                                    20:08:15.236WARNcleanNo older backup files are deleted, because this backup was started manually
                                    20:08:15.260DEBUGcleandone
                                    20:08:15.384DEBUGhistoryHTMLnew history html values created
                                    20:08:15.480DEBUGhistoryHTMLdone
                                    20:08:15.672DEBUGhistoryJSONnew history json values created
                                    20:08:15.713DEBUGhistoryJSONdone
                                    20:08:15.830DEBUGumountmount active, umount is started ...
                                    20:08:20.863DEBUGumountumount successfully completed
                                    20:08:20.909DEBUGumountdone
                                    20:08:23.228DEBUGnotificationdone
                                    20:08:23.379INFOguiDas Backup wurde erfolgreich erstellt!
                                    • Q Qax1
                                      kommt dann
                                      kommt dann
                                      Sorry, das funktioniert so nur auf einem System mit entsprechenden Einträgen in der fstab.
                                      Hast du aber nicht. Also musst du dass mit dem Befehl aus dem Backitup-Log machen.
                                      password halt richtig setzen. Und zuvor schauen, ob /opt/iobroker/backups leer ist:
                                      ls -l /opt/iobroker/backups/
                                        kommt dann
                                        Q Offline
                                        Q Offline
                                        Qax1
                                        schrieb am zuletzt editiert von Qax1
                                        Das gibt nicht mal n Fehlermeldung....
                                        pi@raspy-io:~ $ sudo mount -t cifs -o username=iostefan,password=xxxxx,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups
                                        pi@raspy-io:~ $
                                        Waren 2 Dateien drin, hab ich mit rm gelöscht
                                        • Q Qax1
                                          pi@raspy-io:~ $
                                          Linuxisch: Keine Meldung, alles i.O.
