  4. BACKITUP host.raspy-io Cannot pack directory /...
58 Beiträge 5 Kommentatoren 6.9k Aufrufe 4 Beobachtet
  • Q Qax1
    17:00:18.754INFOguiBackup gestartet ...
    17:00:28.804DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
    17:00:29.225DEBUGmountmount successfully completed
    17:00:29.272DEBUGmountdone
    17:00:32.119DEBUGiobrokerhost.raspy-io 1333 objects saved
    17:00:32.200DEBUGiobrokerhost.raspy-io 486 states saved
    17:00:32.208DEBUGiobrokerhost.raspy-io Validating backup ...
    17:00:32.261DEBUGiobrokerhost.raspy-io "config.json" is valid
    17:00:32.265DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
    host.raspy-io "states.jsonl" exists
    17:00:32.470DEBUGiobrokerhost.raspy-io JSONL lines are valid
    17:00:32.475DEBUGiobrokerhost.raspy-io The backup is valid!
    17:00:32.950DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-17_00_28_backupiobroker.tar.gz
    This backup can only be restored with js-controller version 7.0 or higher
    17:00:33.977DEBUGiobrokerdone
    17:00:35.040DEBUGzigbeefound zigbee database: zigbee.0
    17:00:35.047DEBUGzigbeedone
    17:00:35.106ERRORzigbeeError: ENOSPC: no space left on device, close
    17:00:36.688DEBUGcifsused copy path: /NetBackup/IO-Backup
    17:00:36.730DEBUGcifsdone
    17:00:37.319ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
    17:00:37.330DEBUGcleandone
    17:00:37.443DEBUGhistoryHTMLnew history html values created
    17:00:37.537DEBUGhistoryHTMLdone
    17:00:37.700DEBUGhistoryJSONnew history json values created
    17:00:37.742DEBUGhistoryJSONdone
    17:00:37.859DEBUGumountmount active, umount is started ...
    17:00:42.895DEBUGumountumount successfully completed
    17:00:42.937DEBUGumountdone
    17:00:45.304DEBUGnotificationAdmin notification will be sent
    17:00:45.317DEBUGnotificationdone
    17:00:45.405INFOguiDas Backup wurde erfolgreich erstellt!
    MartinPM Offline
    MartinPM Offline
    MartinP
    @qax1 jetzt noch einmal ein "df"
    Es scheint, als ob das NAS voll wäre
    mcm1957M Q 2 Antworten Letzte Antwort
    • MartinPM MartinP
      mcm1957M Online
      mcm1957M Online
      mcm1957
      Bitte beachten - es wird offenbar gemounted:
      //192.168.2.100/homes/
      In /homes haben am synology (zu recht) nur adminstratoren Zugriff. Dort ist aber wie Thomas schon geschrieben hat sicher kein guter Platz für Backups.
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • mcm1957M mcm1957
        MartinPM Offline
        MartinPM Offline
        MartinP
        @mcm1957 Ich habe mir am Cifs Mounten aus meinem LXC Container die Zähne ausgebissen, und mache jetzt lokale Backups, die später in der Nacht per Cronjob mit rsync auf das Netzlaufwerk geschoben werden ...
        • MartinPM MartinP
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @martinp
          Synology kann auch nfs
          Thomas BraunT MartinPM Q 3 Antworten Letzte Antwort
          • mcm1957M mcm1957
            @martinp
            @mcm1957
            Aber auch das muss richtig eingestellt / freigegeben werden.
            • mcm1957M mcm1957
              @martinp
              MartinPM Offline
              MartinPM Offline
              MartinP
              @mcm1957 Mein NAS war damals eine Seagate Dockstar ... ich glaube, ich lasse das aber bei rsync - never change a running system ...
              Habe dadurch jetzt eine Woche Lokal im LXC-Container als Backups, und 40 Tage auf dem NAS....
                @mcm1957
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Ja sicher :-)
                • MartinPM MartinP
                  Q Offline
                  Q Offline
                  Qax1
                  @martinp
                  pi@raspy-io:/opt/iobroker/backups $ df
                  Filesystem     1K-blocks    Used Available Use% Mounted on
                  udev             1673520       0   1673520   0% /dev
                  tmpfs             388296    1168    387128   1% /run
                  /dev/mmcblk0p2 122339224 5618616 110489016   5% /
                  tmpfs            1941460       0   1941460   0% /dev/shm
                  tmpfs               5120      16      5104   1% /run/lock
                  /dev/mmcblk0p1    522230   55944    466286  11% /boot/firmware
                  tmpfs             388292       0    388292   0% /run/user/1000
                  Q 1 Antwort Letzte Antwort
                  • Q Qax1
                    @martinp
                    Q Offline
                    Q Offline
                    Qax1
                    @MartinP
                    Sorry Frau hat gerufe "ESSEN is Fertig" :-)
                    • Q Qax1
                      @MartinP
                      Q Offline
                      Q Offline
                      Qax1
                      Da ich jetzt n bisschen den Faden verloren habe,
                      hier nochmal n aktueller LOG
                      19:18:53.857INFOguiBackup gestartet ...
                      19:19:03.909DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=iostefan,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.2.100/NetBackup/IO-Backup /opt/iobroker/backups"
                      19:19:04.335DEBUGmountmount successfully completed
                      19:19:04.380DEBUGmountdone
                      19:19:07.271DEBUGiobrokerhost.raspy-io 1333 objects saved
                      19:19:07.355DEBUGiobrokerhost.raspy-io 488 states saved
                      19:19:07.358DEBUGiobrokerhost.raspy-io Validating backup ...
                      19:19:07.366DEBUGiobrokerhost.raspy-io "config.json" is valid
                      19:19:07.376DEBUGiobrokerhost.raspy-io "objects.jsonl" exists
                      19:19:07.619DEBUGiobrokerhost.raspy-io JSONL lines are valid
                      19:19:07.623DEBUGiobrokerhost.raspy-io The backup is valid!
                      19:19:11.354DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2024_12_10-19_19_03_backupiobroker.tar.gz
                      19:19:11.358DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher
                      19:19:18.156DEBUGiobrokerdone
                      19:19:19.223DEBUGzigbeefound zigbee database: zigbee.0
                      19:19:19.233DEBUGzigbeedone
                      19:19:19.261ERRORzigbeeError: ENOSPC: no space left on device, close
                      19:19:20.876DEBUGcifsused copy path: /NetBackup/IO-Backup
                      19:19:20.922DEBUGcifsdone
                      19:19:21.498ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                      19:19:21.510DEBUGcleandone
                      19:19:21.629DEBUGhistoryHTMLnew history html values created
                      19:19:21.720DEBUGhistoryHTMLdone
                      19:19:21.885DEBUGhistoryJSONnew history json values created
                      19:19:21.927DEBUGhistoryJSONdone
                      19:19:22.044DEBUGumountmount active, umount is started ...
                      19:19:27.114DEBUGumountumount successfully completed
                      19:19:27.162DEBUGumountdone
                      19:19:29.522DEBUGnotificationAdmin notification will be sent
                      19:19:29.536DEBUGnotificationdone
                      19:19:29.628INFOguiDas Backup wurde erfolgreich erstellt!
                      • mcm1957M mcm1957
                        @martinp
                        Q Offline
                        Q Offline
                        Qax1
                        @mcm1957
                        Aber es hatte ja n weile lang funktioniert.
                        • Q Qax1
                          @mcm1957
                          @qax1
                          Hat vermutlich solange funktioniert bis der Speicherplatz ausging.
                            @qax1
                            Q Offline
                            Q Offline
                            Qax1
                            Deswegen hatte ich heute Morgen
                            ganz neu aufgesetzt, was aber leider das Problem nicht behoben hat.
                            Ich finde dieses ENOSPC auch nirgends
                            • Q Qax1
                              @qax1
                              Schau auf dem NAS, was da noch verfügbar ist.
                              • Q Qax1
                                @qax1 sagte in BACKITUP host.raspy-io Cannot pack directory /...:
                                warum das als zigbeeError deklariert ist, ist mir allerdings schleierhaft
                                • Q Offline
                                  Q Offline
                                  Qax1
                                  Von 2,68 TB sind 3,05 GB belegt....
                                  Ich denke das sollte reichen
                                    Q Offline
                                    Q Offline
                                    Qax1
                                    Ja, ich meinte,
                                    kann ich nicht direkt auf diesen Speicher gucken,
                                    ob er wirklich voll ist, bzw. was löschen !?
                                    • Q Qax1
                                      Ja, ich meinte,
                                      Das hängt halt von dem NAS ab. In der Regel kann man die ja auch lokal administirieren.
                                        Q Offline
                                        Q Offline
                                        Qax1
                                        Auf dem NAS ist ja Platz...
                                        ich hab jetzt im Adapter den "Lokaler Festplattenspeicher Grenzwert für Fehlermeldung (MB)
                                        Höher gestellt
                                        Irgendwie muß es ja gehen, ging ja schon
                                        • Q Qax1
                                          Höher gestellt
                                          auch in der Freigabe?
