  4. [Gelöst] Fehler bei node red auf dem slave
    1.0k
    6.1k
48 Beiträge 6 Kommentatoren 6.7k Aufrufe 3 Beobachtet
    @hant0r
    Für iob diag maldie Testversion davon verwenden.
    Hant0rH Offline
    Hant0rH Offline
    Hant0r
    schrieb am zuletzt editiert von Hant0r
    @thomas-braun sagte in [gelöst] Cannot read file "jsonConfig.json: Not exists:
    @hant0r
    Das Script aus deinem Footer?
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    Führt zum selben Ergebnis wie oben
    EDIT:
    Habe es hier gefunden: https://forum.iobroker.net/topic/59549/iob-diag-skript
    Hant0rH 1 Antwort Letzte Antwort
    • Hant0rH Hant0r
      @hant0r
      EDIT:
      Hant0rH Offline
      Hant0rH Offline
      Hant0r
      Diag-Test läuft auf einen Fehler im Script:
      pi@iobroker-slave:~ $ ./iob_diag.sh > iob_diag.log
      The state system.host.iobroker-slave.versions.nodeNewestNext was not found!
      The state system.host.iobroker-slave.versions.npmNewestNext was not found!
      npm error code ELSPROBLEMS
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
      npm error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
      npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
      ./iob_diag.sh: line 1259: syntax error: unexpected end of file
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.8.2
      2 info using node@v20.18.1
      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config load:file:/opt/iobroker/.npmrc
      5 silly config load:file:/home/pi/.npmrc
      6 silly config load:file:/usr/etc/npmrc
      7 verbose title npm ls
      8 verbose argv "ls" "--all"
      9 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-
      10 verbose logfile /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
      11 silly packumentCache heap:248512512 maxSize:62128128 maxEntrySize:31064064
      12 silly logfile start cleaning logs, removing 1 files
      13 silly logfile done cleaning log files
      14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
      15 verbose stack Error: invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
      15 verbose stack invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
      15 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:206:9)
      15 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
      15 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
      16 error code ELSPROBLEMS
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.admin/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.alexa2/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.backitup/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.info/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.node-red/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.openknx/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.spritmonitor/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.tibberconnect/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.vw-connect/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/socket-classes/node_modules/@iobroker/adapter-core
      17 error invalid: @iobroker/adapter-core@3.1.6 /opt/iobroker/node_modules/@iobroker/dm-utils/node_modules/@iobroker/adapter-core
      18 verbose cwd /opt/iobroker
      19 verbose os Linux 5.10.103-v7+
      20 verbose node v20.18.1
      21 verbose npm  v10.8.2
      22 verbose exit 1
      23 verbose code 1
      24 error A complete log of this run can be found in: /home/pi/.npm/_logs/2024-12-08T10_22_26_082Z-debug-0.log
      • Hant0rH Hant0r
        22 verbose exit 1
        23 verbose code 1
        @hant0r Das ist aber nichts im Skript, da klemmt es auf deinem System.
        • Hant0rH Offline
          Hant0rH Offline
          Hant0r
          @thomas-braun sagte in Fehler bei node red auf dem slave:
          Will ich gar nichr ausschließen, bin mir aber nicht sicher was und wo ich suchen sollte. :(
          In dem Log werden auch Adapter aufgelistet, die gar nicht auf dem Slave System installiert sind.
          • Hant0rH Hant0r
            @hant0r
            Wobei, ich sehe gerade, im Skript ist ein Fehler drin. Muss ich später noch einmal schauen.
            • Hant0rH Hant0r
              @hant0r
              Schau mal ob das Skript nun durch läuft.
              Nochmal neu curlen.
                @hant0r
                Nochmal neu curlen.
                Hant0rH Offline
                Hant0rH Offline
                Hant0r
                @hant0r
                Nochmal neu curlen.
                Jap, hat nun geklappt, danke!
                Hier das diag-log
                bash
                Script v.2024-12-08 Raspbian+zigbee diag+masking
                *** BASE SYSTEM ***
                   Static hostname: iobroker-slave
                         Icon name: computer
                  Operating System: Raspbian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.10.103-v7+
                      Architecture: arm
                OS is similar to: debian
                Model           : Raspberry Pi 3 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : armv7l
                Userland        : 32 bit
                Systemuptime and Load:
                 20:12:04 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
                CPU threads: 4
                *** LIFE CYCLE STATUS ***
                Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** TIME AND TIMEZONES ***
                               Local time: Sun 2024-12-08 20:12:04 CET
                           Universal time: Sun 2024-12-08 19:12:04 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** Users and Groups ***
                User that called 'iob diag':
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                *** DISPLAY-SERVER SETUP ***
                Display-Server: false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            923M        314M         76M        0.0K        531M        543M
                Swap:            99M         11M         88M
                Total:          1.0G        326M        165M
                Active iob-Instances:   41
                          923 M total memory
                          314 M used memory
                          280 M active memory
                          435 M inactive memory
                           76 M free memory
                          144 M buffer memory
                          387 M swap cache
                           99 M total swap
                           11 M used swap
                           88 M free swap
                top - 20:12:05 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
                Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  2.7 us,  2.7 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :    923.2 total,     76.7 free,    314.6 used,    531.9 buff/cache
                MiB Swap:    100.0 total,     88.5 free,     11.5 used.    544.1 avail Mem
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** DMESG CRITICAL ERRORS ***
                No critical errors detected
                *** FILESYSTEM ***
                /dev/root      ext4       15G  7.0G  6.8G  51% /
                devtmpfs       devtmpfs  430M     0  430M   0% /dev
                tmpfs          tmpfs     462M     0  462M   0% /dev/shm
                tmpfs          tmpfs     185M  576K  185M   1% /run
                /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
                [Sat Dec  7 18:16:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d24dc3a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [Sat Dec  7 18:16:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                [Sat Dec  7 18:16:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                [Sat Dec  7 18:16:32 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                Show mounted filesystems:
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                2.4G    /var/
                1.3G    /var/log/journal/6a1c6c0717794655a35c1e054c8a353a
                1.3G    /var/log
                855M    /var/cache
                Archived and active journals take up 1.2G in the file system.
                /opt/iobroker/backups:
                452M    /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                132M    /opt/iobroker/iobroker-data/
                121M    /opt/iobroker/iobroker-data/node-red
                120M    /opt/iobroker/iobroker-data/node-red/node_modules
                19M     /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules
                1.9M    /opt/iobroker/iobroker-data/objects.jsonl
                1.9M    /opt/iobroker/iobroker-data/objects.json.migrated
                1.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                748K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules/mqtt/dist/mqtt.js
                584K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/icons/modbus.ico
                USB-Devices by-id:
                /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_527b0af45d29ec11a9796d7840c9ce8d-if00-port0
                *** ZigBee Settings ***
                HINT:
                Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                /dev/ttyUSB0
                zigbee.0
                Extended Pan ID:
                *** MASKED ***
                OR
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v20.18.1
                /usr/bin/node           v20.18.1
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                /usr/bin/corepack       0.29.4
                nodejs:
                  Installed: 20.18.1-1nodesource1
                  Candidate: 20.18.1-1nodesource1
                  Version table:
                 *** 20.18.1-1nodesource1 1001
                        500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                     20.18.0-1nodesource1 1001
                     20.17.0-1nodesource1 1001
                     20.16.0-1nodesource1 1001
                     20.15.1-1nodesource1 1001
                     20.15.0-1nodesource1 1001
                     20.14.0-1nodesource1 1001
                     20.13.1-1nodesource1 1001
                     20.13.0-1nodesource1 1001
                     20.12.2-1nodesource1 1001
                     20.12.1-1nodesource1 1001
                     20.12.0-1nodesource1 1001
                     20.11.1-1nodesource1 1001
                     20.11.0-1nodesource1 1001
                     20.10.0-1nodesource1 1001
                     20.9.0-1nodesource1 1001
                     20.8.1-1nodesource1 1001
                     20.8.0-1nodesource1 1001
                     20.7.0-1nodesource1 1001
                     20.6.1-1nodesource1 1001
                     20.6.0-1nodesource1 1001
                     20.5.1-1nodesource1 1001
                     20.5.0-1nodesource1 1001
                     20.4.0-1nodesource1 1001
                     20.3.1-1nodesource1 1001
                     20.3.0-1nodesource1 1001
                     20.2.0-1nodesource1 1001
                     20.1.0-1nodesource1 1001
                     20.0.0-1nodesource1 1001
                     12.22.12~dfsg-1~deb11u5 500
                No problems detected
                Errors in npm tree: 0
                *** ioBroker-Installation ***
                ioBroker Status
                At least one iobroker host is running.
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 94728)
                iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 33741)
                Core adapters versions
                js-controller:  7.0.3
                admin:          7.1.5
                javascript:     "javascript" not found
                nodejs modules from github:     3
                +-- iobroker.spritmonitor@0.0.2-beta.4 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#23065c8af34346cefc0cf5586fe2cc4eaf80962d)
                +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
                +-- iobroker.vw-connect@0.1.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#610c38af4b66cbc2875b03154da09059554c913a)
                Adapter State
                + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
                  system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
                  system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                  system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
                  system.adapter.devices.0                : devices               : iobroker-slave                           - disabled
                + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
                  system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
                + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
                + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                  system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                  system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                  system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                  system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
                + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                  system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
                + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
                + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
                  system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
                + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
                + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
                + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
                + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
                + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
                + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
                  system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                  system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                  system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
                  system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                  system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                  system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                  system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                  system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
                + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
                + instance is alive
                ioBroker-Repositories
                │ (index) │ name               │ url                                                     │ auto upgrade │
                │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
                Upgrade policy: patch
                Installed ioBroker-Instances
                Adapter    "admin"        : 7.1.5    , installed 7.1.5
                Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                Adapter    "devices"      : 1.1.5    , installed 1.1.5
                Controller "js-controller": 7.0.3    , installed 7.0.3
                Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                Adapter    "openknx"      : 0.9.0    , installed 0.7.2  [Updatable]
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                Objects and States
                Objects:        26963
                States:         23283
                Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Reading package lists... Done
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12542      581/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55437      4330/node-red
                tcp6       0      0 :::80                   :::*                    LISTEN      1001       55438      4330/node-red
                tcp6       0      0 :::22                   :::*                    LISTEN      0          10073      581/sshd: /usr/sbin
                tcp6       0      0 :::20000                :::*                    LISTEN      1001       55440      4330/node-red
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10717      573/dhcpcd
                udp        0      0 0.0.0.0:51301           0.0.0.0:*                           108        10663      306/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10661      306/avahi-daemon: r
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55442      4330/node-red
                udp6       0      0 :::38107                :::*                                108        10664      306/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                108        10662      306/avahi-daemon: r
                2024-12-08 10:50:19.612  - info: node-red.0 (4293) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                2024-12-08 10:50:19.628  - info: node-red.0 (4293) Node-RED started successfully (PID: 4330)
                2024-12-08 10:50:28.130  - info: zigbee.0 (4319) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                2024-12-08 10:50:28.302  - info: zigbee.0 (4319) delete old Backup files. keep only last 10
                2024-12-08 10:50:28.306  - info: zigbee.0 (4319) Starting Zigbee  npm ...
                2024-12-08 10:50:29.172  - info: zigbee.0 (4319) Installed Version: iobroker.zigbee@1.10.3
                2024-12-08 10:50:30.765  - info: zigbee.0 (4319) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                2024-12-08 10:50:30.782  - info: zigbee.0 (4319) Unable to disable LED, unsupported function.
                2024-12-08 10:50:30.824  - info: zigbee.0 (4319)   --> transmitPower : high
                2024-12-08 10:50:30.848  - info: zigbee.0 (4319) Currently 10 devices are joined:
                2024-12-08 10:50:31.035  - info: zigbee.0 (4319) 0x00158d00054bf061 (addr 22089): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.046  - info: zigbee.0 (4319) 0x00158d0002a216d7 (addr 41996): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-12-08 10:50:31.052  - info: zigbee.0 (4319) 0x00158d0002b7b5e1 (addr 14656): DJT11LM - Aqara Vibration sensor (EndDevice)
                2024-12-08 10:50:31.057  - info: zigbee.0 (4319) 0x00158d00054d161b (addr 55732): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.061  - info: zigbee.0 (4319) 0x00158d0009f4249e (addr 42548): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-12-08 10:50:31.065  - info: zigbee.0 (4319) 0x00158d000644472e (addr 59828): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.070  - info: zigbee.0 (4319) 0x00158d0006693825 (addr 29733): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.074  - info: zigbee.0 (4319) 0x00158d0006586493 (addr 61285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.079  - info: zigbee.0 (4319) 0x00158d00066980b6 (addr 42580): RTCGQ11LM - Aqara Motion sensor (EndDevice)
                2024-12-08 10:50:31.082  - info: zigbee.0 (4319) 0x00158d00024ece71 (addr 406): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                2024-12-08 10:50:31.085  - info: zigbee.0 (4319) Zigbee started
                2024-12-08 10:50:31.205  - info: zigbee.0 (4319) deregister device Ping for deactivated device "0x00158d0002a216d7"
                2024-12-08 10:50:31.233  - info: zigbee.0 (4319) debug devices set to []
                2024-12-08 10:50:34.956  - warn: node-red.0 (4293) Node-RED: 8 Dec 10:50:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
                2024-12-08 19:44:36.546  - info: zigbee.0 (4319) Device '0x00158d00066980b6' announced itself
                iob diag has finished.
                        Icon name: computer
                     Architecture: arm
                Kernel:                 armv7l
                Userland:               32 bit
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                Boot Target:            multi-user.target
                Pending OS-Updates:     0
                Pending iob updates:    1
                Nodejs-Installation:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                Recommended versions are nodejs  and npm
                nodeJS installation is correct
                MEMORY:
                Mem:            923M        316M        111M        0.0K        495M        542M
                Swap:            99M         11M         88M
                Total:          1.0G        327M        200M
                ioBroker Core:          js-controller           7.0.3
                                       admin                   7.1.5
                Objects type: jsonl
                States  type: jsonl
                Objects:                26963
                States:                 23283
                Size of iob-Database:
                244K    /opt/iobroker/iobroker-data/states.jsonl
                240K    /opt/iobroker/iobroker-data/states.json.migrated
                240K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                • Hant0rH Hant0r
                  @hant0r
                  Nochmal neu curlen.
                  Hier das diag-log
                  bash
                  *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm
                  Docker          : false
                  Kernel          : armv7l
                  Userland        : 32 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  pi
                  HOME=/home/pi
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M         11M         88M
                            923 M total memory
                            314 M used memory
                            280 M active memory
                             76 M free memory
                            144 M buffer memory
                            387 M swap cache
                             99 M total swap
                             11 M used swap
                             88 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.4G    /var/
                  1.3G    /var/log
                  855M    /var/cache
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyUSB0
                  zigbee.0
                  Extended Pan ID:
                  *** MASKED ***
                  OR
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.1.5
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        26963
                  States:         23283
                  Pending Updates: 0
                          Icon name: computer
                       Architecture: arm
                  Kernel:                 armv7l
                  Userland:               32 bit
                  User-ID:                1000
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  MEMORY:
                  Swap:            99M         11M         88M
                                         admin                   7.1.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                26963
                  States:                 23283
                  @hant0r
                  Installier da mal das OS von Grund auf neu.
                  In der 64Bit-Lite-Version.
                  Dann auch mit einem eigenen user, nicht 'pi'.
                  Zu node-red springt mir halt
                  ins Auge. Ohne das ich wüsste wo man Projekte wieder aktiviert.
                  mickymM Hant0rH 2 Antworten Letzte Antwort
                    @hant0r
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @thomas-braun Das ist eine normale Fehlermeldung die man ignorieren kann. In der Regel lässt man die Projekte in NodeRed deaktiviert. Warum es diese Meldung seit ewigen Zeiten gibt, kann mir bis jetzt keiner erklären. Ich habe eine Instanz mit und ohne Projekte am Laufen.
                    • mickymM mickym
                      @mickym
                      Okay.
                        @hant0r
                        Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        @hant0r
                        Hmm ok... Wundert mich nur, dass es plötzlich so Probleme macht. Immerhin lief es vier Jahre.
                        Da ich kein Linux crack bin, muss ich mal nach ner Anleitungen suchen, wo erklärt wird, wie man das System 'richtig' installiert. Denke 'iob backup' bzw. Backitup sollten als Sicherung ausreichen um alles wieder herzustellen, oder?
                        Kennt jemand von euch ne gute Anleitung?
                        • Hant0rH Hant0r
                          @hant0r
                          @hant0r
                          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                            @hant0r
                            Hant0rH Offline
                            Hant0rH Offline
                            Hant0r
                            @hant0r
                            Mega, danke!
                            Werde ich mir morgen mal durchlesen :)
                            • Hant0rH Offline
                              Hant0rH Offline
                              Hant0r
                              Habe das Slave-System nun neu aufgesetzt.
                              iobroker läuft und ist noch jungfreulich. Das Problem ist, ich bekomme den Slave nicht mehr mit dem Master verbunden :(
                              Wenn ich iobroker multihost connect beim Slave eingebe, wird mit der Host angezeigt, aber es erscheint folgende Meldung:
                              tim@iobroker-slave:/opt/iobroker/log $ iobroker multihost connect
                              1 |             10.1.0.1 |  host |             10.1.0.1 | "authentication required"
                              Please select host [1]: 1
                              Enter secret phrase for connection: *********************
                              Error: No configuration received!
                                  at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupMultihost.js:254:26
                                  at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:212:17)
                                  at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:66:17)
                                  at listOnTimeout (node:internal/timers:581:17)
                                  at process.processTimers (node:internal/timers:519:7)
                              Gleichzeitg steht beim Master dies im Log und er bricht komplett weg, dass er nicht mehr erreichbar ist.
                              dbTools.isLocalObjectsDbServer is not a function
                              TypeError: dbTools.isLocalObjectsDbServer is not a function
                                  at file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:142:53
                                  at Hash.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:98:17)
                                  at Hash.emit (node:events:518:28)
                                  at Hash.emit (node:domain:489:12)
                                  at emitReadable_ (node:internal/streams/readable:834:12)
                                  at onEofChunk (node:internal/streams/readable:812:5)
                                  at readableAddChunkPushByteMode (node:internal/streams/readable:466:5)
                                  at Hash.Readable.push (node:internal/streams/readable:392:5)
                                  at node:internal/streams/transform:141:12
                                  at Hash._flush (node:internal/crypto/hash:104:3)
                              Ich muss den Docker komplett neustarten, damit ich wieder an ioBroker komme.
                              • Hant0rH Hant0r
                                @hant0r sagte in Fehler bei node red auf dem slave:
                                mach es zu Fuß mit iob setup custom
                                  Hant0rH Offline
                                  Hant0rH Offline
                                  Hant0r
                                  @homoran sagte in Fehler bei node red auf dem slave:
                                  iob setup custom
                                  Hat funktionert, danke dir 👍
                                  • Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    Also ioBroker Slave läuft wieder (neu augesetzt) und auch der Connect zum Master klappt.
                                    Node-Red musste ich komplett neu installieren (also ohne restore), weil es damit nur Probleme gab.
                                    Nachdem ich dann alle nodes wieder installiert und die Flows importiert habe, sieht alles sehr gut aus.
                                    Ich kann auch die Settings Seite wieder erreichen :)
                                    Vielen Dank bis dahin schon einmal 👍
                                    Einzig was noch nicht wieder läuft ist mein ZigBee auf dem Slave.
                                    Das liegt aber wohl daran, dass der USB Controller nicht erkannt wird und ich kein "ttyUSB" bekomme.
                                    Suche mir gerade schon einen Wolf, aber finde noch nichts, wieso das so ist. Muss man das im System erst aktivieren oder so?
                                    • Hant0rH Hant0r
                                      Man verwendet ja auch die 'by-id'-Links und nicht direkt die Gerätedateien.
                                      Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unmask.
                                      Siehe hier:
                                        Siehe hier:
                                        Hant0rH Offline
                                        Hant0rH Offline
                                        Hant0r
                                        Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unhide.
                                        Siehe hier:
                                        hmm, also einen Pfad mit serial bzw. by-id gibt es nicht..
                                        tim@iobroker-slave:/opt/iobroker $ ls /dev/
                                        Display all 156 possibilities? (y or n)
                                        autofs           loop1            ram14            tty15            tty36            tty57            vcsa
                                        block/           loop2            ram15            tty16            tty37            tty58            vcsa1
                                        bus/             loop3            ram2             tty17            tty38            tty59            vcsa2
                                        cachefiles       loop4            ram3             tty18            tty39            tty6             vcsa3
                                        char/            loop5            ram4             tty19            tty4             tty60            vcsa4
                                        console          loop6            ram5             tty2             tty40            tty61            vcsa5
                                        cpu_dma_latency  loop7            ram6             tty20            tty41            tty62            vcsa6
                                        disk/            loop-control     ram7             tty21            tty42            tty63            vcsu
                                        dma_heap/        mem              ram8             tty22            tty43            tty7             vcsu1
                                        fb0              mmcblk0          ram9             tty23            tty44            tty8             vcsu2
                                        fd/              mmcblk0p1        random           tty24            tty45            tty9             vcsu3
                                        full             mmcblk0p2        shm/             tty25            tty46            ttyprintk        vcsu4
                                        gpiochip0        mqueue/          stderr           tty26            tty47            urandom          vcsu5
                                        gpiochip1        null             stdin            tty27            tty48            vchiq            vcsu6
                                        gpiochip2        port             stdout           tty28            tty49            vcio             vga_arbiter
                                        gpiochip4        ptmx             tty              tty29            tty5             vc-mem           watchdog
                                        hwrng            pts/             tty0             tty3             tty50            vcs              watchdog0
                                        initctl          ram0             tty1             tty30            tty51            vcs1             zero
                                        input/           ram1             tty10            tty31            tty52            vcs2
                                        kmsg             ram10            tty11            tty32            tty53            vcs3
                                        kvm              ram11            tty12            tty33            tty54            vcs4
                                        log              ram12            tty13            tty34            tty55            vcs5
                                        loop0            ram13            tty14            tty35            tty56            vcs6
                                        Im Diag steht auch:
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        mit lsusb kommt aber:
                                        tim@iobroker-slave:/opt/iobroker $ lsusb
                                        Bus 001 Device 008: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                                        Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
                                        Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
                                        ```bash
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                                  Kernel: Linux 6.6.62+rpt-rpi-v8
                                            Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                         13:29:32 up  3:02,  1 user,  load average: 1.45, 1.16, 0.87
                                        CPU threads: 4
                                        Operating System is the current Debian stable version codenamed 'bookworm'!
                                        Current issues:
                                                       Local time: Mon 2024-12-09 13:29:32 CET
                                                   Universal time: Mon 2024-12-09 12:29:32 UTC
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        tim
                                        HOME=/home/tim
                                        GROUPS=tim adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            951M        492M        178M         36K        348M        458M
                                        Swap:           536M         22M        514M
                                        Total:          1.5G        515M        692M
                                                  907 M total memory
                                                  469 M used memory
                                                  363 M active memory
                                                  276 M inactive memory
                                                  169 M free memory
                                                   28 M buffer memory
                                                  304 M swap cache
                                                  511 M total swap
                                                   21 M used swap
                                                  490 M free swap
                                        top - 13:29:33 up  3:02,  1 user,  load average: 1.57, 1.19, 0.89
                                        Tasks: 123 total,   2 running, 121 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 37.5 us, 12.5 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :    907.2 total,    168.2 free,    470.8 used,    332.5 buff/cache
                                        MiB Swap:    512.0 total,    490.2 free,     21.8 used.    436.4 avail Mem
                                          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                                        * proc-sys-fs-binfmt_misc.mount loaded failed failed Arbitrary Executable File Formats File System
                                        * systemd-binfmt.service        loaded failed failed Set Up Additional Binary Formats
                                        2 loaded units listed.
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  318M     0  318M   0% /dev
                                        tmpfs          tmpfs      91M  860K   90M   1% /run
                                        /dev/mmcblk0p2 ext4       15G  4.0G  9.5G  30% /
                                        tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                        /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                                        tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                                        [Mon Dec  9 10:27:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                                        [Mon Dec  9 10:27:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                        [Mon Dec  9 10:27:25 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        1.1G    /var/
                                        296M    /var/cache
                                        290M    /var/cache/apt
                                        177M    /var/cache/apt/archives
                                        164M    /var/lib
                                        Archived and active journals take up 52.0M in the file system.
                                        176K    /opt/iobroker/backups/
                                        137M    /opt/iobroker/iobroker-data/
                                        72M     /opt/iobroker/iobroker-data/node-red
                                        71M     /opt/iobroker/iobroker-data/node-red/node_modules
                                        60M     /opt/iobroker/iobroker-data/files
                                        31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                        12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                                        7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                                        5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                                        5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                                        5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                                        USB-Devices by-id:
                                        HINT:
                                        /dev/ttyUSB0
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        nodejs:
                                          Version table:
                                                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                             18.19.0+dfsg-6~deb12u2 500
                                                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                             18.19.0+dfsg-6~deb12u1 500
                                                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 8423)
                                        iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 2164)
                                        admin:          7.1.5
                                        nodejs modules from github:     0
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        26984
                                        States:         23316
                                        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                                        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                                        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       22889      5560/node-red
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          619        446/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       24006      5560/node-red
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       24003      5560/node-red
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        572        366/avahi-daemon: r
                                        udp        0      0 0.0.0.0:51505           0.0.0.0:*                           104        5517       366/avahi-daemon: r
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24009      5560/node-red
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24008      5560/node-red
                                        2024-12-09 12:57:30.441  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                                        2024-12-09 12:57:30.451  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                                        2024-12-09 12:57:30.474  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                                        2024-12-09 12:57:31.633  - info: host.iobroker-slave iobroker exit 0
                                        2024-12-09 12:57:35.950  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5493
                                        2024-12-09 12:57:42.066  - info: node-red.0 (5493) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                        2024-12-09 12:57:42.172  - info: node-red.0 (5493) Requested NPM packages: []
                                        2024-12-09 12:57:42.278  - warn: node-red.0 (5493) Cannot enable the dynamic object read as admin has authentication
                                        2024-12-09 12:57:48.618  - info: node-red.0 (5493) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                        2024-12-09 12:57:48.634  - info: node-red.0 (5493) Node-RED started successfully (PID: 5525)
                                        2024-12-09 12:58:03.330  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                        2024-12-09 12:58:03.399  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Encrypted credentials not found
                                        2024-12-09 12:59:11.011  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                                        2024-12-09 12:59:11.018  - info: node-red.0 (5493) kill node-red task
                                        2024-12-09 12:59:11.075  - info: node-red.0 (5493) Node-RED exited with 0
                                        2024-12-09 12:59:16.015  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 5493
                                        2024-12-09 12:59:16.436  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                                        2024-12-09 12:59:16.437  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                                        2024-12-09 12:59:21.824  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5541
                                        2024-12-09 12:59:26.410  - info: node-red.0 (5541) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                        2024-12-09 12:59:26.627  - warn: node-red.0 (5541) Cannot enable the dynamic object read as admin has authentication
                                        2024-12-09 12:59:32.831  - info: node-red.0 (5541) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                        2024-12-09 12:59:32.847  - info: node-red.0 (5541) Node-RED started successfully (PID: 5560)
                                        2024-12-09 12:59:43.856  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                        2024-12-09 12:59:43.880  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Encrypted credentials not found
                                        Copy text starting here:
                                        bash
                                               Icon name: computer
                                            Architecture: arm64
                                        Kernel:                 aarch64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        Pending iob updates:    0
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
                                        Mem:            951M        388M        108M         28K        521M        562M
                                        Swap:           536M        135M        401M
                                        Total:          1.5G        524M        510M
        admin                   7.1.5
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                26984
                                        States:                 23316
                                        504K    /opt/iobroker/iobroker-data/states.jsonl
                                        === Mark text until here for copying ===
                                        tim@iobroker-slave:~ $ apt policy udev
                                        udev:
                                          Installed: 252.31-1~deb12u1
                                          Candidate: 252.31-1~deb12u1
                                          Version table:
                                         *** 252.31-1~deb12u1 500
                                        • Hant0rH Hant0r
                                          Siehe hier:
                                          Im Diag steht auch:
                                          USB-Devices by-id:
                                          ```bash
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          tim
                                          HOME=/home/tim
                                          iobroker
                                          HOME=/home/iobroker
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:           536M         22M        514M
                                                    907 M total memory
                                                    469 M used memory
                                                    363 M active memory
                                                    169 M free memory
                                                     28 M buffer memory
                                                    304 M swap cache
                                                    511 M total swap
                                                     21 M used swap
                                                    490 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.1G    /var/
                                          296M    /var/cache
                                          290M    /var/cache/apt
                                          164M    /var/lib
                                          USB-Devices by-id:
                                          HINT:
                                          /dev/ttyUSB0
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.1.5
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        26984
                                          States:         23316
                                          Pending Updates: 0
                                          bash
                                                 Icon name: computer
                                              Architecture: arm64
                                          Kernel:                 aarch64
                                          Userland:               64 bit
                                          User-ID:                1000
                                          /usr/bin/npm            10.8.2
                                          /usr/bin/npx            10.8.2
                                          MEMORY:
        admin                   7.1.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Objects:                26984
                                          States:                 23316
                                          udev:
                                            Version table:
                                          Sollten eigentlich keine aufgeführt werden. Bei dir hängen da zwei drin.
                                          Ich hatte auch oben die falsche Option genannt. Das muss
                                          iob diag --unmask
                                          lauten, nicht unhide (wollte ich zuerst so nennen, deswegen die Verwechslung).
                                          Zum Stick: Steck den mal für eine Minute ab und dann wieder ein.
