  4. [Gelöst] Fehler bei node red auf dem slave
    1.0k
    6.1k
48 Beiträge 6 Kommentatoren 6.7k Aufrufe 3 Beobachtet
    @hant0r
    Schau mal ob das Skript nun durch läuft.
    Nochmal neu curlen.
    Hant0rH Offline
    Hant0rH Offline
    Hant0r
    schrieb am zuletzt editiert von Hant0r
    @thomas-braun sagte in Fehler bei node red auf dem slave:
    @hant0r
    Nochmal neu curlen.
    Jap, hat nun geklappt, danke!
    Hier das diag-log
    bash
    Script v.2024-12-08 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
       Static hostname: iobroker-slave
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     20:12:04 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-12-08 20:12:04 CET
               Universal time: Sun 2024-12-08 19:12:04 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            923M        314M         76M        0.0K        531M        543M
    Swap:            99M         11M         88M
    Total:          1.0G        326M        165M
    Active iob-Instances:   41
              923 M total memory
              314 M used memory
              280 M active memory
              435 M inactive memory
               76 M free memory
              144 M buffer memory
              387 M swap cache
               99 M total swap
               11 M used swap
               88 M free swap
    top - 20:12:05 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
    Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.7 us,  2.7 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    923.2 total,     76.7 free,    314.6 used,    531.9 buff/cache
    MiB Swap:    100.0 total,     88.5 free,     11.5 used.    544.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       15G  7.0G  6.8G  51% /
    devtmpfs       devtmpfs  430M     0  430M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     185M  576K  185M   1% /run
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Sat Dec  7 18:16:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d24dc3a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Dec  7 18:16:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Dec  7 18:16:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Dec  7 18:16:32 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    1.3G    /var/log/journal/6a1c6c0717794655a35c1e054c8a353a
    1.3G    /var/log
    855M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    452M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    132M    /opt/iobroker/iobroker-data/
    121M    /opt/iobroker/iobroker-data/node-red
    120M    /opt/iobroker/iobroker-data/node-red/node_modules
    19M     /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules
    1.9M    /opt/iobroker/iobroker-data/objects.jsonl
    1.9M    /opt/iobroker/iobroker-data/objects.json.migrated
    1.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    748K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules/mqtt/dist/mqtt.js
    584K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/icons/modbus.ico
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_527b0af45d29ec11a9796d7840c9ce8d-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.0
    Extended Pan ID:
    *** MASKED ***
    OR
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 94728)
    iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 33741)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     "javascript" not found
    nodejs modules from github:     3
    +-- iobroker.spritmonitor@0.0.2-beta.4 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#23065c8af34346cefc0cf5586fe2cc4eaf80962d)
    +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
    +-- iobroker.vw-connect@0.1.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#610c38af4b66cbc2875b03154da09059554c913a)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
      system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker-slave                           - disabled
    + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
      system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
    + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
    Upgrade policy: patch
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "openknx"      : 0.9.0    , installed 0.7.2  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        26963
    States:         23283
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12542      581/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55437      4330/node-red
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       55438      4330/node-red
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10073      581/sshd: /usr/sbin
    tcp6       0      0 :::20000                :::*                    LISTEN      1001       55440      4330/node-red
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10717      573/dhcpcd
    udp        0      0 0.0.0.0:51301           0.0.0.0:*                           108        10663      306/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10661      306/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55442      4330/node-red
    udp6       0      0 :::38107                :::*                                108        10664      306/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        10662      306/avahi-daemon: r
    2024-12-08 10:50:19.612  - info: node-red.0 (4293) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2024-12-08 10:50:19.628  - info: node-red.0 (4293) Node-RED started successfully (PID: 4330)
    2024-12-08 10:50:28.130  - info: zigbee.0 (4319) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
    2024-12-08 10:50:28.302  - info: zigbee.0 (4319) delete old Backup files. keep only last 10
    2024-12-08 10:50:28.306  - info: zigbee.0 (4319) Starting Zigbee  npm ...
    2024-12-08 10:50:29.172  - info: zigbee.0 (4319) Installed Version: iobroker.zigbee@1.10.3
    2024-12-08 10:50:30.765  - info: zigbee.0 (4319) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
    2024-12-08 10:50:30.782  - info: zigbee.0 (4319) Unable to disable LED, unsupported function.
    2024-12-08 10:50:30.824  - info: zigbee.0 (4319)   --> transmitPower : high
    2024-12-08 10:50:30.848  - info: zigbee.0 (4319) Currently 10 devices are joined:
    2024-12-08 10:50:31.035  - info: zigbee.0 (4319) 0x00158d00054bf061 (addr 22089): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.046  - info: zigbee.0 (4319) 0x00158d0002a216d7 (addr 41996): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.052  - info: zigbee.0 (4319) 0x00158d0002b7b5e1 (addr 14656): DJT11LM - Aqara Vibration sensor (EndDevice)
    2024-12-08 10:50:31.057  - info: zigbee.0 (4319) 0x00158d00054d161b (addr 55732): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.061  - info: zigbee.0 (4319) 0x00158d0009f4249e (addr 42548): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.065  - info: zigbee.0 (4319) 0x00158d000644472e (addr 59828): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.070  - info: zigbee.0 (4319) 0x00158d0006693825 (addr 29733): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.074  - info: zigbee.0 (4319) 0x00158d0006586493 (addr 61285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.079  - info: zigbee.0 (4319) 0x00158d00066980b6 (addr 42580): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.082  - info: zigbee.0 (4319) 0x00158d00024ece71 (addr 406): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.085  - info: zigbee.0 (4319) Zigbee started
    2024-12-08 10:50:31.205  - info: zigbee.0 (4319) deregister device Ping for deactivated device "0x00158d0002a216d7"
    2024-12-08 10:50:31.233  - info: zigbee.0 (4319) debug devices set to []
    2024-12-08 10:50:34.956  - warn: node-red.0 (4293) Node-RED: 8 Dec 10:50:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
    2024-12-08 19:44:36.546  - info: zigbee.0 (4319) Device '0x00158d00066980b6' announced itself
    iob diag has finished.
            Icon name: computer
         Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            923M        316M        111M        0.0K        495M        542M
    Swap:            99M         11M         88M
    Total:          1.0G        327M        200M
    ioBroker Core:          js-controller           7.0.3
                           admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                26963
    States:                 23283
    Size of iob-Database:
    244K    /opt/iobroker/iobroker-data/states.jsonl
    240K    /opt/iobroker/iobroker-data/states.json.migrated
    240K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    • Hant0rH Hant0r
      @hant0r
      Nochmal neu curlen.
      Hier das diag-log
      bash
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm
      Docker          : false
      Kernel          : armv7l
      Userland        : 32 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         11M         88M
                923 M total memory
                314 M used memory
                280 M active memory
                 76 M free memory
                144 M buffer memory
                387 M swap cache
                 99 M total swap
                 11 M used swap
                 88 M free swap
      *** FILESYSTEM ***
      /var:
      2.4G    /var/
      1.3G    /var/log
      855M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.0
      Extended Pan ID:
      *** MASKED ***
      OR
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.1.5
      Adapter State
      + instance is alive
      Objects and States
      Objects:        26963
      States:         23283
      Pending Updates: 0
              Icon name: computer
           Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1000
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
      Swap:            99M         11M         88M
                             admin                   7.1.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                26963
      States:                 23283
      @hant0r
      Installier da mal das OS von Grund auf neu.
      In der 64Bit-Lite-Version.
      Dann auch mit einem eigenen user, nicht 'pi'.
      Zu node-red springt mir halt
      ins Auge. Ohne das ich wüsste wo man Projekte wieder aktiviert.
      mickymM Hant0rH 2 Antworten Letzte Antwort
        @hant0r
        mickymM Offline
        mickymM Offline
        mickym
        @thomas-braun Das ist eine normale Fehlermeldung die man ignorieren kann. In der Regel lässt man die Projekte in NodeRed deaktiviert. Warum es diese Meldung seit ewigen Zeiten gibt, kann mir bis jetzt keiner erklären. Ich habe eine Instanz mit und ohne Projekte am Laufen.
        • mickymM mickym
          @mickym
          Okay.
            @hant0r
            Hant0rH Offline
            Hant0rH Offline
            Hant0r
            @hant0r
            Hmm ok... Wundert mich nur, dass es plötzlich so Probleme macht. Immerhin lief es vier Jahre.
            Da ich kein Linux crack bin, muss ich mal nach ner Anleitungen suchen, wo erklärt wird, wie man das System 'richtig' installiert. Denke 'iob backup' bzw. Backitup sollten als Sicherung ausreichen um alles wieder herzustellen, oder?
            Kennt jemand von euch ne gute Anleitung?
            • Hant0rH Hant0r
              @hant0r
              @hant0r
              https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
              Hant0rH 1 Antwort Letzte Antwort
                @hant0r
                Hant0rH Offline
                Hant0rH Offline
                Hant0r
                @hant0r
                Mega, danke!
                Werde ich mir morgen mal durchlesen :)
                • Hant0rH Offline
                  Hant0rH Offline
                  Hant0r
                  Habe das Slave-System nun neu aufgesetzt.
                  iobroker läuft und ist noch jungfreulich. Das Problem ist, ich bekomme den Slave nicht mehr mit dem Master verbunden :(
                  Wenn ich iobroker multihost connect beim Slave eingebe, wird mit der Host angezeigt, aber es erscheint folgende Meldung:
                  tim@iobroker-slave:/opt/iobroker/log $ iobroker multihost connect
                  1 |             10.1.0.1 |  host |             10.1.0.1 | "authentication required"
                  Please select host [1]: 1
                  Enter secret phrase for connection: *********************
                  Error: No configuration received!
                      at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupMultihost.js:254:26
                      at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:212:17)
                      at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:66:17)
                      at listOnTimeout (node:internal/timers:581:17)
                      at process.processTimers (node:internal/timers:519:7)
                  Gleichzeitg steht beim Master dies im Log und er bricht komplett weg, dass er nicht mehr erreichbar ist.
                  dbTools.isLocalObjectsDbServer is not a function
                  TypeError: dbTools.isLocalObjectsDbServer is not a function
                      at file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:142:53
                      at Hash.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:98:17)
                      at Hash.emit (node:events:518:28)
                      at Hash.emit (node:domain:489:12)
                      at emitReadable_ (node:internal/streams/readable:834:12)
                      at onEofChunk (node:internal/streams/readable:812:5)
                      at readableAddChunkPushByteMode (node:internal/streams/readable:466:5)
                      at Hash.Readable.push (node:internal/streams/readable:392:5)
                      at node:internal/streams/transform:141:12
                      at Hash._flush (node:internal/crypto/hash:104:3)
                  Ich muss den Docker komplett neustarten, damit ich wieder an ioBroker komme.
                  • Hant0rH Hant0r
                    @hant0r sagte in Fehler bei node red auf dem slave:
                    mach es zu Fuß mit iob setup custom
                      Hant0rH Offline
                      Hant0rH Offline
                      Hant0r
                      @homoran sagte in Fehler bei node red auf dem slave:
                      iob setup custom
                      Hat funktionert, danke dir 👍
                      • Hant0rH Offline
                        Hant0rH Offline
                        Hant0r
                        Also ioBroker Slave läuft wieder (neu augesetzt) und auch der Connect zum Master klappt.
                        Node-Red musste ich komplett neu installieren (also ohne restore), weil es damit nur Probleme gab.
                        Nachdem ich dann alle nodes wieder installiert und die Flows importiert habe, sieht alles sehr gut aus.
                        Ich kann auch die Settings Seite wieder erreichen :)
                        Vielen Dank bis dahin schon einmal 👍
                        Einzig was noch nicht wieder läuft ist mein ZigBee auf dem Slave.
                        Das liegt aber wohl daran, dass der USB Controller nicht erkannt wird und ich kein "ttyUSB" bekomme.
                        Suche mir gerade schon einen Wolf, aber finde noch nichts, wieso das so ist. Muss man das im System erst aktivieren oder so?
                        • Hant0rH Hant0r
                          Man verwendet ja auch die 'by-id'-Links und nicht direkt die Gerätedateien.
                          Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unmask.
                          Siehe hier:
                          https://forum.iobroker.net/topic/59549/iob-diag-skript
                            Siehe hier:
                            Hant0rH Offline
                            Hant0rH Offline
                            Hant0r
                            Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unhide.
                            Siehe hier:
                            hmm, also einen Pfad mit serial bzw. by-id gibt es nicht..
                            tim@iobroker-slave:/opt/iobroker $ ls /dev/
                            Display all 156 possibilities? (y or n)
                            autofs           loop1            ram14            tty15            tty36            tty57            vcsa
                            block/           loop2            ram15            tty16            tty37            tty58            vcsa1
                            bus/             loop3            ram2             tty17            tty38            tty59            vcsa2
                            cachefiles       loop4            ram3             tty18            tty39            tty6             vcsa3
                            char/            loop5            ram4             tty19            tty4             tty60            vcsa4
                            console          loop6            ram5             tty2             tty40            tty61            vcsa5
                            cpu_dma_latency  loop7            ram6             tty20            tty41            tty62            vcsa6
                            disk/            loop-control     ram7             tty21            tty42            tty63            vcsu
                            dma_heap/        mem              ram8             tty22            tty43            tty7             vcsu1
                            fb0              mmcblk0          ram9             tty23            tty44            tty8             vcsu2
                            fd/              mmcblk0p1        random           tty24            tty45            tty9             vcsu3
                            full             mmcblk0p2        shm/             tty25            tty46            ttyprintk        vcsu4
                            gpiochip0        mqueue/          stderr           tty26            tty47            urandom          vcsu5
                            gpiochip1        null             stdin            tty27            tty48            vchiq            vcsu6
                            gpiochip2        port             stdout           tty28            tty49            vcio             vga_arbiter
                            gpiochip4        ptmx             tty              tty29            tty5             vc-mem           watchdog
                            hwrng            pts/             tty0             tty3             tty50            vcs              watchdog0
                            initctl          ram0             tty1             tty30            tty51            vcs1             zero
                            input/           ram1             tty10            tty31            tty52            vcs2
                            kmsg             ram10            tty11            tty32            tty53            vcs3
                            kvm              ram11            tty12            tty33            tty54            vcs4
                            log              ram12            tty13            tty34            tty55            vcs5
                            loop0            ram13            tty14            tty35            tty56            vcs6
                            Im Diag steht auch:
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            mit lsusb kommt aber:
                            tim@iobroker-slave:/opt/iobroker $ lsusb
                            Bus 001 Device 008: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                            Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
                            Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
                            ```bash
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                      Kernel: Linux 6.6.62+rpt-rpi-v8
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             13:29:32 up  3:02,  1 user,  load average: 1.45, 1.16, 0.87
                            CPU threads: 4
                            Operating System is the current Debian stable version codenamed 'bookworm'!
                            Current issues:
                                           Local time: Mon 2024-12-09 13:29:32 CET
                                       Universal time: Mon 2024-12-09 12:29:32 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            tim
                            HOME=/home/tim
                            GROUPS=tim adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            951M        492M        178M         36K        348M        458M
                            Swap:           536M         22M        514M
                            Total:          1.5G        515M        692M
                                      907 M total memory
                                      469 M used memory
                                      363 M active memory
                                      276 M inactive memory
                                      169 M free memory
                                       28 M buffer memory
                                      304 M swap cache
                                      511 M total swap
                                       21 M used swap
                                      490 M free swap
                            top - 13:29:33 up  3:02,  1 user,  load average: 1.57, 1.19, 0.89
                            Tasks: 123 total,   2 running, 121 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 37.5 us, 12.5 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :    907.2 total,    168.2 free,    470.8 used,    332.5 buff/cache
                            MiB Swap:    512.0 total,    490.2 free,     21.8 used.    436.4 avail Mem
                              UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                            * proc-sys-fs-binfmt_misc.mount loaded failed failed Arbitrary Executable File Formats File System
                            * systemd-binfmt.service        loaded failed failed Set Up Additional Binary Formats
                            2 loaded units listed.
                            *** FILESYSTEM ***
                            udev           devtmpfs  318M     0  318M   0% /dev
                            tmpfs          tmpfs      91M  860K   90M   1% /run
                            /dev/mmcblk0p2 ext4       15G  4.0G  9.5G  30% /
                            tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                            /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                            tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                            [Mon Dec  9 10:27:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Mon Dec  9 10:27:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                            [Mon Dec  9 10:27:25 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.1G    /var/
                            296M    /var/cache
                            290M    /var/cache/apt
                            177M    /var/cache/apt/archives
                            164M    /var/lib
                            Archived and active journals take up 52.0M in the file system.
                            176K    /opt/iobroker/backups/
                            137M    /opt/iobroker/iobroker-data/
                            72M     /opt/iobroker/iobroker-data/node-red
                            71M     /opt/iobroker/iobroker-data/node-red/node_modules
                            60M     /opt/iobroker/iobroker-data/files
                            31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                            5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                            5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                            5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                 18.19.0+dfsg-6~deb12u2 500
                                    500 http://deb.debian.org/debian bookworm/main arm64 Packages
                                 18.19.0+dfsg-6~deb12u1 500
                                    500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 8423)
                            iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 2164)
                            admin:          7.1.5
                            nodejs modules from github:     0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        26984
                            States:         23316
                            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                            Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       22889      5560/node-red
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          619        446/sshd: /usr/sbin
                            tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       24006      5560/node-red
                            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       24003      5560/node-red
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        572        366/avahi-daemon: r
                            udp        0      0 0.0.0.0:51505           0.0.0.0:*                           104        5517       366/avahi-daemon: r
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24009      5560/node-red
                            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24008      5560/node-red
                            2024-12-09 12:57:30.441  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                            2024-12-09 12:57:30.451  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                            2024-12-09 12:57:30.474  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                            2024-12-09 12:57:31.633  - info: host.iobroker-slave iobroker exit 0
                            2024-12-09 12:57:35.950  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5493
                            2024-12-09 12:57:42.066  - info: node-red.0 (5493) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                            2024-12-09 12:57:42.172  - info: node-red.0 (5493) Requested NPM packages: []
                            2024-12-09 12:57:42.278  - warn: node-red.0 (5493) Cannot enable the dynamic object read as admin has authentication
                            2024-12-09 12:57:48.618  - info: node-red.0 (5493) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                            2024-12-09 12:57:48.634  - info: node-red.0 (5493) Node-RED started successfully (PID: 5525)
                            2024-12-09 12:58:03.330  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Projects disabled : editorTheme.projects.enabled=false
                            2024-12-09 12:58:03.399  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Encrypted credentials not found
                            2024-12-09 12:59:11.011  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                            2024-12-09 12:59:11.018  - info: node-red.0 (5493) kill node-red task
                            2024-12-09 12:59:11.075  - info: node-red.0 (5493) Node-RED exited with 0
                            2024-12-09 12:59:16.015  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 5493
                            2024-12-09 12:59:16.436  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                            2024-12-09 12:59:16.437  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                            2024-12-09 12:59:21.824  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5541
                            2024-12-09 12:59:26.410  - info: node-red.0 (5541) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                            2024-12-09 12:59:26.627  - warn: node-red.0 (5541) Cannot enable the dynamic object read as admin has authentication
                            2024-12-09 12:59:32.831  - info: node-red.0 (5541) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                            2024-12-09 12:59:32.847  - info: node-red.0 (5541) Node-RED started successfully (PID: 5560)
                            2024-12-09 12:59:43.856  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
                            2024-12-09 12:59:43.880  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Encrypted credentials not found
                            Copy text starting here:
                            bash
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            Pending iob updates:    0
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                            Mem:            951M        388M        108M         28K        521M        562M
                            Swap:           536M        135M        401M
                            Total:          1.5G        524M        510M
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                26984
                            States:                 23316
                            504K    /opt/iobroker/iobroker-data/states.jsonl
                            === Mark text until here for copying ===
                            tim@iobroker-slave:~ $ apt policy udev
                            udev:
                              Installed: 252.31-1~deb12u1
                              Candidate: 252.31-1~deb12u1
                              Version table:
                             *** 252.31-1~deb12u1 500
                            • Hant0rH Hant0r
                              Siehe hier:
                              Im Diag steht auch:
                              USB-Devices by-id:
                              ```bash
                              *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              CPU threads: 4
                              Current issues:
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              tim
                              HOME=/home/tim
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:           536M         22M        514M
                                        907 M total memory
                                        469 M used memory
                                        363 M active memory
                                        169 M free memory
                                         28 M buffer memory
                                        304 M swap cache
                                        511 M total swap
                                         21 M used swap
                                        490 M free swap
                              *** FILESYSTEM ***
                              /var:
                              1.1G    /var/
                              296M    /var/cache
                              290M    /var/cache/apt
                              164M    /var/lib
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyUSB0
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.1.5
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        26984
                              States:         23316
                              Pending Updates: 0
                              bash
                                     Icon name: computer
                                  Architecture: arm64
                              Kernel:                 aarch64
                              Userland:               64 bit
                              User-ID:                1000
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              MEMORY:
                                                      admin                   7.1.5
                              Objects type: jsonl
                              States  type: jsonl
                              Objects:                26984
                              States:                 23316
                              udev:
                                Version table:
                              Sollten eigentlich keine aufgeführt werden. Bei dir hängen da zwei drin.
                              Ich hatte auch oben die falsche Option genannt. Das muss
                              iob diag --unmask
                              lauten, nicht unhide (wollte ich zuerst so nennen, deswegen die Verwechslung).
                              Zum Stick: Steck den mal für eine Minute ab und dann wieder ein.
                                iob diag --unmask
                                Hant0rH Offline
                                Hant0rH Offline
                                Hant0r
                                Habe ich gemacht.
                                Keine Änderung. Mal dazwischen rebooten?
                                Hmm, woran kann das liegen? Ist doch ein frisches System?
                                bash
                                *** BASE SYSTEM ***
                                      Icon name: computer
                                   Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                14:19:58 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                                CPU threads: 4
                                Current issues:
                                              Local time: Mon 2024-12-09 14:19:59 CET
                                          Universal time: Mon 2024-12-09 13:19:59 UTC
                                                RTC time: n/a
                                             NTP service: active
                                         RTC in local TZ: no
                                tim
                                HOME=/home/tim
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            951M        507M        200M        872K        302M        444M
                                Swap:           536M          0B        536M
                                Total:          1.5G        507M        737M
                                         907 M total memory
                                         483 M used memory
                                          49 M active memory
                                         598 M inactive memory
                                         191 M free memory
                                          20 M buffer memory
                                         268 M swap cache
                                         511 M total swap
                                           0 M used swap
                                         511 M free swap
                                top - 14:19:59 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                                %Cpu(s): 27.3 us, 18.2 sy,  0.0 ni, 45.5 id,  0.0 wa,  0.0 hi,  9.1 si,  0.0 st
                                MiB Mem :    907.2 total,    190.8 free,    484.1 used,    288.8 buff/cache
                                MiB Swap:    512.0 total,    512.0 free,      0.0 used.    423.1 avail Mem
                                *** FILESYSTEM ***
                                tmpfs          tmpfs      91M  852K   90M   1% /run
                                /dev/mmcblk0p2 ext4       15G  4.0G  9.4G  30% /
                                [Mon Dec  9 13:50:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Mon Dec  9 13:50:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                [Mon Dec  9 13:50:07 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                /var:
                                1.1G    /var/
                                296M    /var/cache
                                290M    /var/cache/apt
                                164M    /var/lib
                                Archived and active journals take up 60.0M in the file system.
                                USB-Devices by-id:
                                HINT:
                                /dev/ttyUSB0
                                zigbee.0
                                Extended Pan ID:
                                addaddaddadd*****
                                Pan ID:
                                6754
                                Channel:
                                Network Key:
                                01030507090b0d0f0002040608******
                                ": "d21ced88487ab3b19afa98306fdb
                                ": "a94211b3fb87c6358ee3dea8b361
                                ": "782eeeb5ec2b9848d9e1f5fd0a5e
                                ": "10573f6faa3ef9a6a8709ea0b176
                                ": "229f52d535e2436939d7b4*****
                                ": "056ccf8b487ab3b14d8aba******
                                ": "ab4ba260aa3ef9a6136c03******
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 11454)
                                iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 1810)
                                admin:          7.1.5
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        27003
                                States:         23335
                                Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                                Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                                Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       4950       595/node-red
                                tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       4953       595/node-red
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4838       449/sshd: /usr/sbin
                                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       684        595/node-red
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2902       371/avahi-daemon: r
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4956       595/node-red
                                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4955       595/node-red
                                udp        0      0 0.0.0.0:55965           0.0.0.0:*                           104        2911       371/avahi-daemon: r
                                2024-12-09 13:50:10.070  - info: host.iobroker-slave added notifications configuration of host
                                2024-12-09 13:50:12.116  - info: host.iobroker-slave 63 instances found
                                2024-12-09 13:50:12.186  - info: host.iobroker-slave starting 3 instances
                                2024-12-09 13:50:14.725  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 555
                                2024-12-09 13:50:18.793  - info: host.iobroker-slave instance system.adapter.backitup.1 in version "3.0.25" started with pid 566
                                2024-12-09 13:50:20.524  - info: node-red.0 (555) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                2024-12-09 13:50:21.036  - warn: node-red.0 (555) Cannot enable the dynamic object read as admin has authentication
                                2024-12-09 13:50:22.920  - info: host.iobroker-slave instance system.adapter.zigbee.0 in version "1.10.3" started with pid 581
                                2024-12-09 13:50:42.300  - info: backitup.1 (566) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.1, js-controller: 7.0.3
                                2024-12-09 13:50:45.445  - info: node-red.0 (555) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                2024-12-09 13:50:45.462  - info: node-red.0 (555) Node-RED started successfully (PID: 595)
                                2024-12-09 13:50:56.411  - info: zigbee.0 (581) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                                2024-12-09 13:50:56.616  - info: zigbee.0 (581) Starting Zigbee  npm ...
                                2024-12-09 13:50:58.197  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                                2024-12-09 13:50:58.202  - error: zigbee.0 (581) Failed to start Zigbee
                                2024-12-09 13:50:58.204  - error: zigbee.0 (581) Error herdsman start
                                2024-12-09 13:50:58.214  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                                2024-12-09 13:51:08.213  - info: zigbee.0 (581) Try to reconnect. 1 attempts left
                                2024-12-09 13:51:08.215  - info: zigbee.0 (581) Starting Zigbee  npm ...
                                2024-12-09 13:51:08.243  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                                2024-12-09 13:51:08.258  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                                2024-12-09 13:51:08.260  - error: zigbee.0 (581) Failed to start Zigbee
                                2024-12-09 13:51:08.261  - error: zigbee.0 (581) Error herdsman start
                                2024-12-09 13:51:11.397  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                2024-12-09 13:51:11.540  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Encrypted credentials not found
                                • Hant0rH Hant0r
                                  Habe ich gemacht.
                                  bash
                                  *** BASE SYSTEM ***
                                        Icon name: computer
                                     Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                  CPU threads: 4
                                  Current issues:
                                                  RTC time: n/a
                                               NTP service: active
                                           RTC in local TZ: no
                                  tim
                                  HOME=/home/tim
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:           536M          0B        536M
                                           907 M total memory
                                           483 M used memory
                                            49 M active memory
                                           191 M free memory
                                            20 M buffer memory
                                           268 M swap cache
                                           511 M total swap
                                             0 M used swap
                                           511 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  1.1G    /var/
                                  296M    /var/cache
                                  290M    /var/cache/apt
                                  164M    /var/lib
                                  USB-Devices by-id:
                                  HINT:
                                  /dev/ttyUSB0
                                  zigbee.0
                                  Extended Pan ID:
                                  addaddaddadd*****
                                  Pan ID:
                                  6754
                                  Channel:
                                  Network Key:
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                   Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  admin:          7.1.5
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        27003
                                  States:         23335
                                  Pending Updates: 0
                                  Ja.
                                  Jedenfalls findet das System die Hardware nicht und es wird der Treiber nicht geladen. Ob das mit dem unwilligen Service in Zusammenhang steht weiß ich so ad hoc aber auch nicht.
                                  • Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    Habe das System nun nochmal neu aufgesetzt und den USB Dogle erstmal nicht angeschlossen.
                                    beim sudo apt update && sudo apt full-upgrade kommen aber schon einige Fehler. Ist das normal?
                                    Reading changelogs... Done
                                    Preconfiguring packages ...
                                    dpkg: warning: files list file for package 'libctf0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-pkg-resources' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'pinentry-curses' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'linux-headers-rpi-v8' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libdw1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libxdmcp6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libxcb1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libhogweed6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'apt-utils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'linux-base' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'nftables' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libavif15:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'psmisc' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libalgorithm-diff-perl' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'liblz4-1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'htop' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'fontconfig-config' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'iproute2' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-pycryptodome' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'pigpiod' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libc-bin' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'ncurses-bin' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'firmware-atheros' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'cifs-utils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libavahi-common3:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'firmware-misc-nonfree' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libdeflate0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'gettext-base' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libqmi-glib5:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libidn2-0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libossp-uuid16:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libsvtav1enc1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'vim-tiny' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libfdt1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'man-db' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'usbutils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'linux-image-6.6.51+rpt-rpi-v8' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libpcre2-16-0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libsystemd0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libpugixml1v5:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'liblgpio1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libv4l-0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-six' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'wpasupplicant' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libselinux1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'alsa-utils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libpigpiod-if1' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libcamera-ipa:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libglib2.0-data' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libkms++0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libfreetype6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-certifi' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libx11-data' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'librtmp1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libapt-pkg6.0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libdbus-1-3:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-requests' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'raspi-firmware' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'liblttng-ust-ctl5:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libmnl0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-idna' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'patch' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libpigpio-dev' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libsepol2:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libgav1-1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-rpi-lgpio' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'linux-image-rpi-v8' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libncursesw6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libfuse3-3:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-toml' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libdpkg-perl' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'logsave' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-urllib3' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libwebp7:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'ppp' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'g++' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'keyutils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'groff-base' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libmatroska7:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libcrypt-dev:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libnsl2:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'gpiod' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libtasn1-6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libc6-dev:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libx11-6:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libmtp9:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'sgml-base' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libpisp1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'usb-modeswitch' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libusb-1.0-0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libfontconfig1:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'apt-listchanges' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libndp0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libmbim-utils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libisl23:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libbz2-1.0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libsamplerate0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libbsd0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'raspi-config' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python-is-python3' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libyuv0:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libqmi-utils' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libalgorithm-diff-xs-perl:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'libjson-c5:arm64' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'readline-common' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'publicsuffix' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'python3-smbus2' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'dbus-bin' missing; assuming package has no files currently installed
                                    dpkg: warning: files list file for package 'raspi-utils-core' missing; assuming package has no files currently installed
                                    (Reading database ... 48569 files and directories currently installed.)
                                    Preparing to unpack .../00-raspi-firmware_1%3a1.20241126-1_all.deb ...
                                    /usr/sbin/update-initramfs: 1: /etc/initramfs-tools/update-initramfs.conf: ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒: File name too long
                                    dpkg: error processing package initramfs-tools (--configure):
                                     installed initramfs-tools package post-installation script subprocess returned error exit status 127
                                    dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-2712:
                                     linux-image-6.6.62+rpt-rpi-2712 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                      Package initramfs-tools is not configured yet.
                                      Package linux-initramfs-tool is not installed.
                                      Package initramfs-tools which provides linux-initramfs-tool is not configured yet.
                                    dpkg: error processing package linux-image-6.6.62+rpt-rpi-2712 (--configure):
                                     dependency problems - leaving unconfigured
                                    Setting up raspberrypi-sys-mods (20241202) ...
                                    dpkg: dependency problems prevent configuration of linux-image-rpi-2712:
                                     linux-image-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                      Package linux-image-6.6.62+rpt-rpi-2712 is not configured yet.
                                    dpkg: error processing package linux-image-rpi-2712 (--configure):
                                    Setting up raspberrypi-net-mods (1.4.3) ...
                                    Installing new version of config file /etc/profile.d/wifi-check.sh ...
                                    dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-v8:
                                     linux-image-6.6.62+rpt-rpi-v8 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                    dpkg: error processing package linux-image-6.6.62+rpt-rpi-v8 (--configure):
                                    dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-v8:
                                     linux-headers-6.6.62+rpt-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-v8-unsigned (= 1:6.6.62-1+rpt1); however:
                                      Package linux-image-6.6.62+rpt-rpi-v8 is not configured yet.
                                      Package linux-image-6.6.62+rpt-rpi-v8-unsigned is not installed.
                                    dpkg: error processing package linux-headers-6.6.62+rpt-rpi-v8 (--configure):
                                    dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-2712:
                                     linux-headers-6.6.62+rpt-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-2712-unsigned (= 1:6.6.62-1+rpt1); however:
                                      Package linux-image-6.6.62+rpt-rpi-2712-unsigned is not installed.
                                    dpkg: error processing package linux-headers-6.6.62+rpt-rpi-2712 (--configure):
                                    dpkg: dependency problems prevent configuration of linux-headers-rpi-2712:
                                     linux-headers-rpi-2712 depends on linux-headers-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                      Package linux-headers-6.6.62+rpt-rpi-2712 is not configured yet.
                                    dpkg: error processing package linux-headers-rpi-2712 (--configure):
                                    dpkg: dependency problems prevent configuration of linux-image-rpi-v8:
                                     linux-image-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                    dpkg: error processing package linux-image-rpi-v8 (--configure):
                                    dpkg: dependency problems prevent configuration of linux-headers-rpi-v8:
                                     linux-headers-rpi-v8 depends on linux-headers-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                      Package linux-headers-6.6.62+rpt-rpi-v8 is not configured yet.
                                    dpkg: error processing package linux-headers-rpi-v8 (--configure):
                                    Setting up libcamera0.3:arm64 (0.3.2+rpt20241119-1) ...
                                    Setting up libcamera-ipa:arm64 (0.3.2+rpt20241119-1) ...
                                    Setting up rpicam-apps-lite (1.5.3-1) ...
                                    Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
                                    Processing triggers for man-db (2.11.2-2) ...
                                    Errors were encountered while processing:
                                     initramfs-tools
                                     linux-image-rpi-v8
                                    E: Sub-process /usr/bin/dpkg returned an error code (1)
                                    Aber auch nach einer Neuinstallation, ohne das der USB Dongle dran war, bringt die zwei Fehler.
                                    *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                    OS is similar to:
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : 64 bit
                                     15:38:45 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Mon 2024-12-09 15:38:46 CET
                                               Universal time: Mon 2024-12-09 14:38:46 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    tim
                                    HOME=/home/tim
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            951M        353M        334M        114K        330M        597M
                                    Swap:           536M        786K        536M
                                    Total:          1.5G        354M        870M
                                    Active iob-Instances:   39
                                              907 M total memory
                                              336 M used memory
                                               62 M active memory
                                              423 M inactive memory
                                              319 M free memory
                                               19 M buffer memory
                                              296 M swap cache
                                              511 M total swap
                                                0 M used swap
                                              511 M free swap
                                    top - 15:38:46 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                    Tasks: 125 total,   1 running, 124 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s):  0.0 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi, 12.5 si,  0.0 st
                                    MiB Mem :    907.2 total,    318.3 free,    337.9 used,    315.4 buff/cache
                                    MiB Swap:    512.0 total,    511.2 free,      0.8 used.    569.3 avail Mem
                                    *** FILESYSTEM ***
                                    tmpfs          tmpfs      91M  844K   90M   1% /run
                                    [Mon Dec  9 15:29:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f6ca7d7-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Mon Dec  9 15:29:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                    [Mon Dec  9 15:29:31 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                    /var:
                                    1.1G    /var/
                                    296M    /var/cache
                                    290M    /var/cache/apt
                                    164M    /var/lib
                                    Archived and active journals take up 71.6M in the file system.
                                    4.0K    /opt/iobroker/backups/
                                    USB-Devices by-id:
                                    HINT:
                                    /dev/ttyUSB0
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 16180)
                                    iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 565)
                                    admin:          7.1.5
                                    Adapter State
                                      system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           - disabled, port: /dev/ttyUSB0
                                    + instance is alive
                                    Objects and States
                                    Objects:        26969
                                    States:         23298
                                    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       6341       779/node-red
                                    tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       5595       779/node-red
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3786       445/sshd: /usr/sbin
                                    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       5592       779/node-red
                                    udp        0      0 0.0.0.0:35171           0.0.0.0:*                           104        3741       366/avahi-daemon: r
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5597       779/node-red
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3739       366/avahi-daemon: r
                                    2024-12-09 15:32:27.711  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.outputCount created
                                    2024-12-09 15:32:27.727  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.eventLoopLag created
                                    2024-12-09 15:32:27.740  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.sigKill created
                                    2024-12-09 15:32:27.752  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.logLevel created
                                    2024-12-09 15:32:27.767  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info created
                                    2024-12-09 15:32:27.776  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                                    2024-12-09 15:32:27.786  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                                    2024-12-09 15:32:27.810  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                                    2024-12-09 15:32:28.855  - info: host.iobroker-slave iobroker exit 0
                                    2024-12-09 15:32:34.581  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 726
                                    2024-12-09 15:32:39.536  - info: node-red.0 (726) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                    2024-12-09 15:32:39.649  - info: node-red.0 (726) Requested NPM packages: []
                                    2024-12-09 15:32:39.763  - warn: node-red.0 (726) Cannot enable the dynamic object read as admin has authentication
                                    2024-12-09 15:32:40.765  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                                    2024-12-09 15:32:45.769  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 726
                                    2024-12-09 15:32:46.128  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                                    2024-12-09 15:32:46.129  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                                    2024-12-09 15:32:51.199  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 741
                                    2024-12-09 15:32:55.618  - info: node-red.0 (741) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                    2024-12-09 15:32:55.831  - warn: node-red.0 (741) Cannot enable the dynamic object read as admin has authentication
                                    2024-12-09 15:33:02.041  - info: node-red.0 (741) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                    2024-12-09 15:33:02.059  - info: node-red.0 (741) Node-RED started successfully (PID: 779)
                                    2024-12-09 15:33:16.464  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                                    9 Dec 15:33:16 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                    2024-12-09 15:33:16.571  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [warn] Encrypted credentials not found
                                    • Hant0rH Offline
                                      Hant0rH Offline
                                      Hant0r
                                      USB Dongle geht auch nach einer neuen Installation nicht :(
                                      • Hant0rH Hant0r
                                         initramfs-tools
                                         linux-image-rpi-v8
                                        Script v.2024-12-08 Raspbian+zigbee diag+masking
                                        *** BASE SYSTEM ***
                                         Static hostname: iobroker-slave
                                               Icon name: computer
                                            Architecture: arm64
                                        OS is similar to:
                                        Model           : Raspberry Pi 3 Model B Rev 1.2
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        *** TIME AND TIMEZONES ***
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        tim
                                        HOME=/home/tim
                                        iobroker
                                        HOME=/home/iobroker
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server: false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                                  907 M total memory
                                                  336 M used memory
                                                   62 M active memory
                                                  319 M free memory
                                                   19 M buffer memory
                                                  296 M swap cache
                                                  511 M total swap
                                                    0 M used swap
                                                  511 M free swap
                                        *** FAILED SERVICES ***
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        Show mounted filesystems:
                                        TARGET           SOURCE         FSTYPE OPTIONS
                                        /var:
                                        1.1G    /var/
                                        296M    /var/cache
                                        290M    /var/cache/apt
                                        164M    /var/lib
                                        /opt/iobroker/backups:
                                        /opt/iobroker/iobroker-data:
                                        USB-Devices by-id:
                                        HINT:
                                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                        /dev/ttyUSB0
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.18.1
                                        /usr/bin/node           v20.18.1
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.29.4
                                        nodejs:
                                          Installed: 20.18.1-1nodesource1
                                          Candidate: 20.18.1-1nodesource1
                                          Version table:
                                         *** 20.18.1-1nodesource1 1001
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        At least one iobroker host is running.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        Core adapters versions
                                        admin:          7.1.5
                                        javascript:     "javascript" not found
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                        + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                          system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
                                          system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                                          system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
                                        + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
                                          system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
                                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
                                        + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
                                        + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
                                        + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
                                        + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
                                          system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                                          system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
                                        + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                        + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
                                        + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
                                        + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                                          system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
                                        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                                        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
                                          system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
                                        + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
                                        + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
                                        + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
                                        + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
                                        + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                                        + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
                                        + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
                                        + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                        + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
                                        + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
                                        + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
                                        + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
                                        + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
                                        + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
                                        + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
                                        + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                                        + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
                                        + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
                                        + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                                          system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
                                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                                          system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
                                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
                                          system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
                                          system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
                                          system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                                        + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
                                        + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        ioBroker-Repositories
                                        │ (index) │ name               │ url                                                     │ auto upgrade │
                                        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                                        │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
                                        Upgrade policy: patch
                                        Installed ioBroker-Instances
                                        Adapter    "admin"        : 7.1.5    , installed 7.1.5
                                        Adapter    "backitup"     : 3.0.25   , installed 3.0.25
                                        Controller "js-controller": 7.0.3    , installed 7.0.3
                                        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                                        Objects and States
                                        Objects:        26969
                                        States:         23298
                                        Reading package lists... Done
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        Ist das normal?
                                        Natürlich nicht.
                                          Ist das normal?
                                          Natürlich nicht.
                                          Hant0rH Offline
                                          Hant0rH Offline
                                          Hant0r
                                          @thomas-braun sagte in Fehler bei node red auf dem slave:
                                          Ist das normal?
                                          Natürlich nicht.
                                          Das dachte ich mir auch. Finde bisher im Netz aber keine Lösung
