  4. [Gelöst] Fehler bei node red auf dem slave
    1.0k
    6.1k
48 Beiträge 6 Kommentatoren 6.7k Aufrufe 3 Beobachtet
  • Hant0rH Hant0r
    @thomas-braun sagte in Fehler bei node red auf dem slave:
    @hant0r
    Schau mal ob das Skript nun durch läuft.
    Nochmal neu curlen.
    Jap, hat nun geklappt, danke!
    Hier das diag-log
    bash
    Script v.2024-12-08 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
       Static hostname: iobroker-slave
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.103-v7+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 3 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     20:12:04 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2024-12-08 20:12:04 CET
               Universal time: Sun 2024-12-08 19:12:04 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            923M        314M         76M        0.0K        531M        543M
    Swap:            99M         11M         88M
    Total:          1.0G        326M        165M
    Active iob-Instances:   41
              923 M total memory
              314 M used memory
              280 M active memory
              435 M inactive memory
               76 M free memory
              144 M buffer memory
              387 M swap cache
               99 M total swap
               11 M used swap
               88 M free swap
    top - 20:12:05 up 1 day,  1:55,  1 user,  load average: 0.35, 0.10, 0.03
    Tasks: 119 total,   1 running, 118 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.7 us,  2.7 sy,  0.0 ni, 94.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    923.2 total,     76.7 free,    314.6 used,    531.9 buff/cache
    MiB Swap:    100.0 total,     88.5 free,     11.5 used.    544.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4       15G  7.0G  6.8G  51% /
    devtmpfs       devtmpfs  430M     0  430M   0% /dev
    tmpfs          tmpfs     462M     0  462M   0% /dev/shm
    tmpfs          tmpfs     185M  576K  185M   1% /run
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Sat Dec  7 18:16:25 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=2d24dc3a-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Dec  7 18:16:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Dec  7 18:16:28 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Dec  7 18:16:32 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.4G    /var/
    1.3G    /var/log/journal/6a1c6c0717794655a35c1e054c8a353a
    1.3G    /var/log
    855M    /var/cache
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    452M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    132M    /opt/iobroker/iobroker-data/
    121M    /opt/iobroker/iobroker-data/node-red
    120M    /opt/iobroker/iobroker-data/node-red/node_modules
    19M     /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules
    1.9M    /opt/iobroker/iobroker-data/objects.jsonl
    1.9M    /opt/iobroker/iobroker-data/objects.json.migrated
    1.9M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    748K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-virtual-smart-home/node_modules/mqtt/dist/mqtt.js
    584K    /opt/iobroker/iobroker-data/node-red/node_modules/node-red-contrib-modbus/modbus/icons/modbus.ico
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_527b0af45d29ec11a9796d7840c9ce8d-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.0
    Extended Pan ID:
    *** MASKED ***
    OR
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.1-1nodesource1
      Version table:
     *** 20.18.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u5 500
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 94728)
    iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 33741)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.1.5
    javascript:     "javascript" not found
    nodejs modules from github:     3
    +-- iobroker.spritmonitor@0.0.2-beta.4 (git+ssh://git@github.com/ice987987/ioBroker.spritmonitor.git#23065c8af34346cefc0cf5586fe2cc4eaf80962d)
    +-- iobroker.tibberconnect@0.0.10 (git+ssh://git@github.com/Codibris/ioBroker.tibberconnect.git#3d3cb4129718fbaf00fcdc00b23d1a68e35d2c83)
    +-- iobroker.vw-connect@0.1.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#610c38af4b66cbc2875b03154da09059554c913a)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.backitup.1               : backitup              : iobroker-slave                           -  enabled
      system.adapter.cameras.0                : cameras               : ioBroker                                 - disabled, port: 8200, bind: 127.0.0.1
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : iobroker-slave                           - disabled
    + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
      system.adapter.dysonairpurifier.0       : dysonairpurifier      : ioBroker                                 - disabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
    + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.jablotron.0              : jablotron             : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.mbus.0                   : mbus                  : ioBroker                                 - disabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker-slave                           -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
    + system.adapter.openknx.0                : openknx               : ioBroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 10.1.1.5
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
    + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.spritmonitor.0           : spritmonitor          : ioBroker                                 -  enabled
    + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ioBroker                                 - disabled
    + system.adapter.tibberlink.0             : tibberlink            : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : ioBroker                                 -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'List'             │ 'http://download.iobroker.net/list.html'                │ false        │
    Upgrade policy: patch
    Installed ioBroker-Instances
    Adapter    "admin"        : 7.1.5    , installed 7.1.5
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "backitup"     : 3.0.25   , installed 3.0.25
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "node-red"     : 5.2.1    , installed 5.2.1
    Adapter    "openknx"      : 0.9.0    , installed 0.7.2  [Updatable]
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
    Objects and States
    Objects:        26963
    States:         23283
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12542      581/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       55437      4330/node-red
    tcp6       0      0 :::80                   :::*                    LISTEN      1001       55438      4330/node-red
    tcp6       0      0 :::22                   :::*                    LISTEN      0          10073      581/sshd: /usr/sbin
    tcp6       0      0 :::20000                :::*                    LISTEN      1001       55440      4330/node-red
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10717      573/dhcpcd
    udp        0      0 0.0.0.0:51301           0.0.0.0:*                           108        10663      306/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10661      306/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       55442      4330/node-red
    udp6       0      0 :::38107                :::*                                108        10664      306/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        10662      306/avahi-daemon: r
    2024-12-08 10:50:19.612  - info: node-red.0 (4293) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2024-12-08 10:50:19.628  - info: node-red.0 (4293) Node-RED started successfully (PID: 4330)
    2024-12-08 10:50:28.130  - info: zigbee.0 (4319) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
    2024-12-08 10:50:28.302  - info: zigbee.0 (4319) delete old Backup files. keep only last 10
    2024-12-08 10:50:28.306  - info: zigbee.0 (4319) Starting Zigbee  npm ...
    2024-12-08 10:50:29.172  - info: zigbee.0 (4319) Installed Version: iobroker.zigbee@1.10.3
    2024-12-08 10:50:30.765  - info: zigbee.0 (4319) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
    2024-12-08 10:50:30.782  - info: zigbee.0 (4319) Unable to disable LED, unsupported function.
    2024-12-08 10:50:30.824  - info: zigbee.0 (4319)   --> transmitPower : high
    2024-12-08 10:50:30.848  - info: zigbee.0 (4319) Currently 10 devices are joined:
    2024-12-08 10:50:31.035  - info: zigbee.0 (4319) 0x00158d00054bf061 (addr 22089): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.046  - info: zigbee.0 (4319) 0x00158d0002a216d7 (addr 41996): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.052  - info: zigbee.0 (4319) 0x00158d0002b7b5e1 (addr 14656): DJT11LM - Aqara Vibration sensor (EndDevice)
    2024-12-08 10:50:31.057  - info: zigbee.0 (4319) 0x00158d00054d161b (addr 55732): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.061  - info: zigbee.0 (4319) 0x00158d0009f4249e (addr 42548): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.065  - info: zigbee.0 (4319) 0x00158d000644472e (addr 59828): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.070  - info: zigbee.0 (4319) 0x00158d0006693825 (addr 29733): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.074  - info: zigbee.0 (4319) 0x00158d0006586493 (addr 61285): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.079  - info: zigbee.0 (4319) 0x00158d00066980b6 (addr 42580): RTCGQ11LM - Aqara Motion sensor (EndDevice)
    2024-12-08 10:50:31.082  - info: zigbee.0 (4319) 0x00158d00024ece71 (addr 406): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
    2024-12-08 10:50:31.085  - info: zigbee.0 (4319) Zigbee started
    2024-12-08 10:50:31.205  - info: zigbee.0 (4319) deregister device Ping for deactivated device "0x00158d0002a216d7"
    2024-12-08 10:50:31.233  - info: zigbee.0 (4319) debug devices set to []
    2024-12-08 10:50:34.956  - warn: node-red.0 (4293) Node-RED: 8 Dec 10:50:34 - [warn] Projekte deaktiviert: editorTheme.projects.enabled=false
    2024-12-08 19:44:36.546  - info: zigbee.0 (4319) Device '0x00158d00066980b6' announced itself
    iob diag has finished.
            Icon name: computer
         Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            923M        316M        111M        0.0K        495M        542M
    Swap:            99M         11M         88M
    Total:          1.0G        327M        200M
    ioBroker Core:          js-controller           7.0.3
                           admin                   7.1.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                26963
    States:                 23283
    Size of iob-Database:
    244K    /opt/iobroker/iobroker-data/states.jsonl
    240K    /opt/iobroker/iobroker-data/states.json.migrated
    240K    /opt/iobroker/iobroker-data/states.json.bak.migrated
    @hant0r
    Installier da mal das OS von Grund auf neu.
    In der 64Bit-Lite-Version.
    Dann auch mit einem eigenen user, nicht 'pi'.
    Zu node-red springt mir halt
    ins Auge. Ohne das ich wüsste wo man Projekte wieder aktiviert.
    mickymM Hant0rH 2 Antworten Letzte Antwort
      @hant0r
      mickymM Offline
      mickymM Offline
      mickym
      @thomas-braun Das ist eine normale Fehlermeldung die man ignorieren kann. In der Regel lässt man die Projekte in NodeRed deaktiviert. Warum es diese Meldung seit ewigen Zeiten gibt, kann mir bis jetzt keiner erklären. Ich habe eine Instanz mit und ohne Projekte am Laufen.
      • mickymM mickym
        @mickym
        Okay.
          @hant0r
          Hant0rH Offline
          Hant0rH Offline
          Hant0r
          @hant0r
          Hmm ok... Wundert mich nur, dass es plötzlich so Probleme macht. Immerhin lief es vier Jahre.
          Da ich kein Linux crack bin, muss ich mal nach ner Anleitungen suchen, wo erklärt wird, wie man das System 'richtig' installiert. Denke 'iob backup' bzw. Backitup sollten als Sicherung ausreichen um alles wieder herzustellen, oder?
          Kennt jemand von euch ne gute Anleitung?
          • Hant0rH Hant0r
            @hant0r
            @hant0r
            https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
            Hant0rH 1 Antwort Letzte Antwort
              @hant0r
              Hant0rH Offline
              Hant0rH Offline
              Hant0r
              @hant0r
              Mega, danke!
              Werde ich mir morgen mal durchlesen :)
              • Hant0rH Offline
                Hant0rH Offline
                Hant0r
                Habe das Slave-System nun neu aufgesetzt.
                iobroker läuft und ist noch jungfreulich. Das Problem ist, ich bekomme den Slave nicht mehr mit dem Master verbunden :(
                Wenn ich iobroker multihost connect beim Slave eingebe, wird mit der Host angezeigt, aber es erscheint folgende Meldung:
                tim@iobroker-slave:/opt/iobroker/log $ iobroker multihost connect
                1 |             10.1.0.1 |  host |             10.1.0.1 | "authentication required"
                Please select host [1]: 1
                Enter secret phrase for connection: *********************
                Error: No configuration received!
                    at file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/setupMultihost.js:254:26
                    at onFinished (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:212:17)
                    at Timeout.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/multihostClient.js:66:17)
                    at listOnTimeout (node:internal/timers:581:17)
                    at process.processTimers (node:internal/timers:519:7)
                Gleichzeitg steht beim Master dies im Log und er bricht komplett weg, dass er nicht mehr erreichbar ist.
                dbTools.isLocalObjectsDbServer is not a function
                TypeError: dbTools.isLocalObjectsDbServer is not a function
                    at file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:142:53
                    at Hash.<anonymous> (file:///opt/iobroker/node_modules/iobroker.js-controller/src/lib/multihostServer.js:98:17)
                    at Hash.emit (node:events:518:28)
                    at Hash.emit (node:domain:489:12)
                    at emitReadable_ (node:internal/streams/readable:834:12)
                    at onEofChunk (node:internal/streams/readable:812:5)
                    at readableAddChunkPushByteMode (node:internal/streams/readable:466:5)
                    at Hash.Readable.push (node:internal/streams/readable:392:5)
                    at node:internal/streams/transform:141:12
                    at Hash._flush (node:internal/crypto/hash:104:3)
                Ich muss den Docker komplett neustarten, damit ich wieder an ioBroker komme.
                • Hant0rH Hant0r
                  @hant0r sagte in Fehler bei node red auf dem slave:
                  mach es zu Fuß mit iob setup custom
                    Hant0rH Offline
                    Hant0rH Offline
                    Hant0r
                    @homoran sagte in Fehler bei node red auf dem slave:
                    iob setup custom
                    Hat funktionert, danke dir 👍
                    • Hant0rH Offline
                      Hant0rH Offline
                      Hant0r
                      Also ioBroker Slave läuft wieder (neu augesetzt) und auch der Connect zum Master klappt.
                      Node-Red musste ich komplett neu installieren (also ohne restore), weil es damit nur Probleme gab.
                      Nachdem ich dann alle nodes wieder installiert und die Flows importiert habe, sieht alles sehr gut aus.
                      Ich kann auch die Settings Seite wieder erreichen :)
                      Vielen Dank bis dahin schon einmal 👍
                      Einzig was noch nicht wieder läuft ist mein ZigBee auf dem Slave.
                      Das liegt aber wohl daran, dass der USB Controller nicht erkannt wird und ich kein "ttyUSB" bekomme.
                      Suche mir gerade schon einen Wolf, aber finde noch nichts, wieso das so ist. Muss man das im System erst aktivieren oder so?
                      • Hant0rH Hant0r
                        Man verwendet ja auch die 'by-id'-Links und nicht direkt die Gerätedateien.
                        Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unmask.
                        Siehe hier:
                        https://forum.iobroker.net/topic/59549/iob-diag-skript
                          Siehe hier:
                          Hant0rH Offline
                          Hant0rH Offline
                          Hant0r
                          schrieb am zuletzt editiert von Hant0r
                          Den richtigen Link und die Einstellungen auf dem Coordinator finden sich in der Test-Version von iob diag --unhide.
                          Siehe hier:
                          hmm, also einen Pfad mit serial bzw. by-id gibt es nicht..
                          tim@iobroker-slave:/opt/iobroker $ ls /dev/
                          Display all 156 possibilities? (y or n)
                          autofs           loop1            ram14            tty15            tty36            tty57            vcsa
                          block/           loop2            ram15            tty16            tty37            tty58            vcsa1
                          bus/             loop3            ram2             tty17            tty38            tty59            vcsa2
                          cachefiles       loop4            ram3             tty18            tty39            tty6             vcsa3
                          char/            loop5            ram4             tty19            tty4             tty60            vcsa4
                          console          loop6            ram5             tty2             tty40            tty61            vcsa5
                          cpu_dma_latency  loop7            ram6             tty20            tty41            tty62            vcsa6
                          disk/            loop-control     ram7             tty21            tty42            tty63            vcsu
                          dma_heap/        mem              ram8             tty22            tty43            tty7             vcsu1
                          fb0              mmcblk0          ram9             tty23            tty44            tty8             vcsu2
                          fd/              mmcblk0p1        random           tty24            tty45            tty9             vcsu3
                          full             mmcblk0p2        shm/             tty25            tty46            ttyprintk        vcsu4
                          gpiochip0        mqueue/          stderr           tty26            tty47            urandom          vcsu5
                          gpiochip1        null             stdin            tty27            tty48            vchiq            vcsu6
                          gpiochip2        port             stdout           tty28            tty49            vcio             vga_arbiter
                          gpiochip4        ptmx             tty              tty29            tty5             vc-mem           watchdog
                          hwrng            pts/             tty0             tty3             tty50            vcs              watchdog0
                          initctl          ram0             tty1             tty30            tty51            vcs1             zero
                          input/           ram1             tty10            tty31            tty52            vcs2
                          kmsg             ram10            tty11            tty32            tty53            vcs3
                          kvm              ram11            tty12            tty33            tty54            vcs4
                          log              ram12            tty13            tty34            tty55            vcs5
                          loop0            ram13            tty14            tty35            tty56            vcs6
                          Im Diag steht auch:
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          mit lsusb kommt aber:
                          tim@iobroker-slave:/opt/iobroker $ lsusb
                          Bus 001 Device 008: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                          Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
                          Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
                          ```bash
                          *** BASE SYSTEM ***
                                 Icon name: computer
                                    Kernel: Linux 6.6.62+rpt-rpi-v8
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           13:29:32 up  3:02,  1 user,  load average: 1.45, 1.16, 0.87
                          CPU threads: 4
                          Operating System is the current Debian stable version codenamed 'bookworm'!
                          Current issues:
                                         Local time: Mon 2024-12-09 13:29:32 CET
                                     Universal time: Mon 2024-12-09 12:29:32 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          tim
                          HOME=/home/tim
                          GROUPS=tim adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            951M        492M        178M         36K        348M        458M
                          Swap:           536M         22M        514M
                          Total:          1.5G        515M        692M
                                    907 M total memory
                                    469 M used memory
                                    363 M active memory
                                    276 M inactive memory
                                    169 M free memory
                                     28 M buffer memory
                                    304 M swap cache
                                    511 M total swap
                                     21 M used swap
                                    490 M free swap
                          top - 13:29:33 up  3:02,  1 user,  load average: 1.57, 1.19, 0.89
                          Tasks: 123 total,   2 running, 121 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 37.5 us, 12.5 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :    907.2 total,    168.2 free,    470.8 used,    332.5 buff/cache
                          MiB Swap:    512.0 total,    490.2 free,     21.8 used.    436.4 avail Mem
                            UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
                          * proc-sys-fs-binfmt_misc.mount loaded failed failed Arbitrary Executable File Formats File System
                          * systemd-binfmt.service        loaded failed failed Set Up Additional Binary Formats
                          2 loaded units listed.
                          *** FILESYSTEM ***
                          udev           devtmpfs  318M     0  318M   0% /dev
                          tmpfs          tmpfs      91M  860K   90M   1% /run
                          /dev/mmcblk0p2 ext4       15G  4.0G  9.5G  30% /
                          tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                          /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
                          tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                          [Mon Dec  9 10:27:18 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Mon Dec  9 10:27:22 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                          [Mon Dec  9 10:27:25 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                          /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          1.1G    /var/
                          296M    /var/cache
                          290M    /var/cache/apt
                          177M    /var/cache/apt/archives
                          164M    /var/lib
                          Archived and active journals take up 52.0M in the file system.
                          176K    /opt/iobroker/backups/
                          137M    /opt/iobroker/iobroker-data/
                          72M     /opt/iobroker/iobroker-data/node-red
                          71M     /opt/iobroker/iobroker-data/node-red/node_modules
                          60M     /opt/iobroker/iobroker-data/files
                          31M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
                          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.0c96b194.chunk.js.map
                          5.6M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-f0ed96.6c33ff1f.chunk.js
                          5.5M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-2d33e4.42bb0640.chunk.js.map
                          5.0M    /opt/iobroker/iobroker-data/objects.jsonl
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyUSB0
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                               18.19.0+dfsg-6~deb12u2 500
                                  500 http://deb.debian.org/debian bookworm/main arm64 Packages
                               18.19.0+dfsg-6~deb12u1 500
                                  500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 8423)
                          iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 2164)
                          admin:          7.1.5
                          nodejs modules from github:     0
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        26984
                          States:         23316
                          Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                          Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       22889      5560/node-red
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          619        446/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       24006      5560/node-red
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       24003      5560/node-red
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        572        366/avahi-daemon: r
                          udp        0      0 0.0.0.0:51505           0.0.0.0:*                           104        5517       366/avahi-daemon: r
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24009      5560/node-red
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24008      5560/node-red
                          2024-12-09 12:57:30.441  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                          2024-12-09 12:57:30.451  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                          2024-12-09 12:57:30.474  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                          2024-12-09 12:57:31.633  - info: host.iobroker-slave iobroker exit 0
                          2024-12-09 12:57:35.950  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5493
                          2024-12-09 12:57:42.066  - info: node-red.0 (5493) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                          2024-12-09 12:57:42.172  - info: node-red.0 (5493) Requested NPM packages: []
                          2024-12-09 12:57:42.278  - warn: node-red.0 (5493) Cannot enable the dynamic object read as admin has authentication
                          2024-12-09 12:57:48.618  - info: node-red.0 (5493) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          2024-12-09 12:57:48.634  - info: node-red.0 (5493) Node-RED started successfully (PID: 5525)
                          2024-12-09 12:58:03.330  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Projects disabled : editorTheme.projects.enabled=false
                          2024-12-09 12:58:03.399  - warn: node-red.0 (5493) Node-RED: 9 Dec 12:58:03 - [warn] Encrypted credentials not found
                          2024-12-09 12:59:11.011  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                          2024-12-09 12:59:11.018  - info: node-red.0 (5493) kill node-red task
                          2024-12-09 12:59:11.075  - info: node-red.0 (5493) Node-RED exited with 0
                          2024-12-09 12:59:16.015  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 5493
                          2024-12-09 12:59:16.436  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                          2024-12-09 12:59:16.437  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                          2024-12-09 12:59:21.824  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 5541
                          2024-12-09 12:59:26.410  - info: node-red.0 (5541) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                          2024-12-09 12:59:26.627  - warn: node-red.0 (5541) Cannot enable the dynamic object read as admin has authentication
                          2024-12-09 12:59:32.831  - info: node-red.0 (5541) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                          2024-12-09 12:59:32.847  - info: node-red.0 (5541) Node-RED started successfully (PID: 5560)
                          2024-12-09 12:59:43.856  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Projects disabled : editorTheme.projects.enabled=false
                          2024-12-09 12:59:43.880  - warn: node-red.0 (5541) Node-RED: 9 Dec 12:59:43 - [warn] Encrypted credentials not found
                          Copy text starting here:
                          bash
                                 Icon name: computer
                              Architecture: arm64
                          Kernel:                 aarch64
                          Userland:               64 bit
                          User-ID:                1000
                          Pending iob updates:    0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          MEMORY:
                          Mem:            951M        388M        108M         28K        521M        562M
                          Swap:           536M        135M        401M
                          Total:          1.5G        524M        510M
                                                  admin                   7.1.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects:                26984
                          States:                 23316
                          504K    /opt/iobroker/iobroker-data/states.jsonl
                          === Mark text until here for copying ===
                          tim@iobroker-slave:~ $ apt policy udev
                          udev:
                            Installed: 252.31-1~deb12u1
                            Candidate: 252.31-1~deb12u1
                            Version table:
                           *** 252.31-1~deb12u1 500
                          • Hant0rH Hant0r
                            Siehe hier:
                            Im Diag steht auch:
                            USB-Devices by-id:
                            ```bash
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            tim
                            HOME=/home/tim
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           536M         22M        514M
                                      907 M total memory
                                      469 M used memory
                                      363 M active memory
                                      169 M free memory
                                       28 M buffer memory
                                      304 M swap cache
                                      511 M total swap
                                       21 M used swap
                                      490 M free swap
                            *** FILESYSTEM ***
                            /var:
                            1.1G    /var/
                            296M    /var/cache
                            290M    /var/cache/apt
                            164M    /var/lib
                            USB-Devices by-id:
                            HINT:
                            /dev/ttyUSB0
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.1.5
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        26984
                            States:         23316
                            Pending Updates: 0
                            bash
                                   Icon name: computer
                                Architecture: arm64
                            Kernel:                 aarch64
                            Userland:               64 bit
                            User-ID:                1000
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            MEMORY:
                                                    admin                   7.1.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects:                26984
                            States:                 23316
                            udev:
                              Version table:
                            Sollten eigentlich keine aufgeführt werden. Bei dir hängen da zwei drin.
                            Ich hatte auch oben die falsche Option genannt. Das muss
                            iob diag --unmask
                            lauten, nicht unhide (wollte ich zuerst so nennen, deswegen die Verwechslung).
                            Zum Stick: Steck den mal für eine Minute ab und dann wieder ein.
                              iob diag --unmask
                              Hant0rH Offline
                              Hant0rH Offline
                              Hant0r
                              Habe ich gemacht.
                              Keine Änderung. Mal dazwischen rebooten?
                              Hmm, woran kann das liegen? Ist doch ein frisches System?
                              bash
                              *** BASE SYSTEM ***
                                    Icon name: computer
                                 Architecture: arm64
                              OS is similar to:
                              Docker          : false
                              Kernel          : aarch64
                              Userland        : 64 bit
                              14:19:58 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                              CPU threads: 4
                              Current issues:
                                            Local time: Mon 2024-12-09 14:19:59 CET
                                        Universal time: Mon 2024-12-09 13:19:59 UTC
                                              RTC time: n/a
                                           NTP service: active
                                       RTC in local TZ: no
                              tim
                              HOME=/home/tim
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            951M        507M        200M        872K        302M        444M
                              Swap:           536M          0B        536M
                              Total:          1.5G        507M        737M
                                       907 M total memory
                                       483 M used memory
                                        49 M active memory
                                       598 M inactive memory
                                       191 M free memory
                                        20 M buffer memory
                                       268 M swap cache
                                       511 M total swap
                                         0 M used swap
                                       511 M free swap
                              top - 14:19:59 up 29 min,  1 user,  load average: 1.75, 1.27, 1.07
                              %Cpu(s): 27.3 us, 18.2 sy,  0.0 ni, 45.5 id,  0.0 wa,  0.0 hi,  9.1 si,  0.0 st
                              MiB Mem :    907.2 total,    190.8 free,    484.1 used,    288.8 buff/cache
                              MiB Swap:    512.0 total,    512.0 free,      0.0 used.    423.1 avail Mem
                              *** FILESYSTEM ***
                              tmpfs          tmpfs      91M  852K   90M   1% /run
                              /dev/mmcblk0p2 ext4       15G  4.0G  9.4G  30% /
                              [Mon Dec  9 13:50:00 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=782cb9f1-02 rootfstype=ext4 fsck.repair=yes rootwait
                              [Mon Dec  9 13:50:04 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                              [Mon Dec  9 13:50:07 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                              /var:
                              1.1G    /var/
                              296M    /var/cache
                              290M    /var/cache/apt
                              164M    /var/lib
                              Archived and active journals take up 60.0M in the file system.
                              USB-Devices by-id:
                              HINT:
                              /dev/ttyUSB0
                              zigbee.0
                              Extended Pan ID:
                              addaddaddadd*****
                              Pan ID:
                              6754
                              Channel:
                              Network Key:
                              01030507090b0d0f0002040608******
                              ": "d21ced88487ab3b19afa98306fdb
                              ": "a94211b3fb87c6358ee3dea8b361
                              ": "782eeeb5ec2b9848d9e1f5fd0a5e
                              ": "10573f6faa3ef9a6a8709ea0b176
                              ": "229f52d535e2436939d7b4*****
                              ": "056ccf8b487ab3b14d8aba******
                              ": "ab4ba260aa3ef9a6136c03******
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                               Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 11454)
                              iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 1810)
                              admin:          7.1.5
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        27003
                              States:         23335
                              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                              Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                              Hit:5 http://deb.debian.org/debian bullseye-backports InRelease
                              Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Pending Updates: 0
                              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       4950       595/node-red
                              tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       4953       595/node-red
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4838       449/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       684        595/node-red
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2902       371/avahi-daemon: r
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4956       595/node-red
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       4955       595/node-red
                              udp        0      0 0.0.0.0:55965           0.0.0.0:*                           104        2911       371/avahi-daemon: r
                              2024-12-09 13:50:10.070  - info: host.iobroker-slave added notifications configuration of host
                              2024-12-09 13:50:12.116  - info: host.iobroker-slave 63 instances found
                              2024-12-09 13:50:12.186  - info: host.iobroker-slave starting 3 instances
                              2024-12-09 13:50:14.725  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 555
                              2024-12-09 13:50:18.793  - info: host.iobroker-slave instance system.adapter.backitup.1 in version "3.0.25" started with pid 566
                              2024-12-09 13:50:20.524  - info: node-red.0 (555) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                              2024-12-09 13:50:21.036  - warn: node-red.0 (555) Cannot enable the dynamic object read as admin has authentication
                              2024-12-09 13:50:22.920  - info: host.iobroker-slave instance system.adapter.zigbee.0 in version "1.10.3" started with pid 581
                              2024-12-09 13:50:42.300  - info: backitup.1 (566) starting. Version 3.0.25 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.1, js-controller: 7.0.3
                              2024-12-09 13:50:45.445  - info: node-red.0 (555) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                              2024-12-09 13:50:45.462  - info: node-red.0 (555) Node-RED started successfully (PID: 595)
                              2024-12-09 13:50:56.411  - info: zigbee.0 (581) starting. Version 1.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.18.1, js-controller: 7.0.3
                              2024-12-09 13:50:56.616  - info: zigbee.0 (581) Starting Zigbee  npm ...
                              2024-12-09 13:50:58.197  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                              2024-12-09 13:50:58.202  - error: zigbee.0 (581) Failed to start Zigbee
                              2024-12-09 13:50:58.204  - error: zigbee.0 (581) Error herdsman start
                              2024-12-09 13:50:58.214  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                              2024-12-09 13:51:08.213  - info: zigbee.0 (581) Try to reconnect. 1 attempts left
                              2024-12-09 13:51:08.215  - info: zigbee.0 (581) Starting Zigbee  npm ...
                              2024-12-09 13:51:08.243  - info: zigbee.0 (581) Installed Version: iobroker.zigbee@1.10.3
                              2024-12-09 13:51:08.258  - error: zigbee.0 (581) Starting zigbee-herdsman problem : "Error: No such file or directory, cannot open /dev/ttyUSB0"
                              2024-12-09 13:51:08.260  - error: zigbee.0 (581) Failed to start Zigbee
                              2024-12-09 13:51:08.261  - error: zigbee.0 (581) Error herdsman start
                              2024-12-09 13:51:11.397  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Projects disabled : editorTheme.projects.enabled=false
                              2024-12-09 13:51:11.540  - warn: node-red.0 (555) Node-RED: 9 Dec 13:51:11 - [warn] Encrypted credentials not found
                              • Hant0rH Hant0r
                                Habe ich gemacht.
                                bash
                                *** BASE SYSTEM ***
                                      Icon name: computer
                                   Architecture: arm64
                                OS is similar to:
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : 64 bit
                                CPU threads: 4
                                Current issues:
                                                RTC time: n/a
                                             NTP service: active
                                         RTC in local TZ: no
                                tim
                                HOME=/home/tim
                                iobroker
                                HOME=/home/iobroker
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:           536M          0B        536M
                                         907 M total memory
                                         483 M used memory
                                          49 M active memory
                                         191 M free memory
                                          20 M buffer memory
                                         268 M swap cache
                                         511 M total swap
                                           0 M used swap
                                         511 M free swap
                                *** FILESYSTEM ***
                                /var:
                                1.1G    /var/
                                296M    /var/cache
                                290M    /var/cache/apt
                                164M    /var/lib
                                USB-Devices by-id:
                                HINT:
                                /dev/ttyUSB0
                                zigbee.0
                                Extended Pan ID:
                                addaddaddadd*****
                                Pan ID:
                                6754
                                Channel:
                                Network Key:
                                /usr/bin/npm            10.8.2
                                /usr/bin/npx            10.8.2
                                nodejs:
                                 Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                Hosts:
                                admin:          7.1.5
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        27003
                                States:         23335
                                Pending Updates: 0
                                Ja.
                                Jedenfalls findet das System die Hardware nicht und es wird der Treiber nicht geladen. Ob das mit dem unwilligen Service in Zusammenhang steht weiß ich so ad hoc aber auch nicht.
                                • Hant0rH Offline
                                  Hant0rH Offline
                                  Hant0r
                                  Habe das System nun nochmal neu aufgesetzt und den USB Dogle erstmal nicht angeschlossen.
                                  beim sudo apt update && sudo apt full-upgrade kommen aber schon einige Fehler. Ist das normal?
                                  Reading changelogs... Done
                                  Preconfiguring packages ...
                                  dpkg: warning: files list file for package 'libctf0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-pkg-resources' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'pinentry-curses' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'linux-headers-rpi-v8' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libdw1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libxdmcp6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libxcb1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libhogweed6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'apt-utils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'linux-base' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'nftables' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libavif15:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'psmisc' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libalgorithm-diff-perl' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'liblz4-1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'htop' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'fontconfig-config' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'iproute2' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-pycryptodome' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'pigpiod' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libc-bin' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'ncurses-bin' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'firmware-atheros' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'cifs-utils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libavahi-common3:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'firmware-misc-nonfree' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libdeflate0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'gettext-base' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libqmi-glib5:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libidn2-0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libossp-uuid16:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libsvtav1enc1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'vim-tiny' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libfdt1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'man-db' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'usbutils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'linux-image-6.6.51+rpt-rpi-v8' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libpcre2-16-0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libsystemd0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libpugixml1v5:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'liblgpio1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libv4l-0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-six' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'wpasupplicant' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libselinux1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'alsa-utils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libpigpiod-if1' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libcamera-ipa:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libglib2.0-data' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libkms++0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libfreetype6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-certifi' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libx11-data' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'librtmp1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libapt-pkg6.0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libdbus-1-3:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-requests' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'raspi-firmware' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'liblttng-ust-ctl5:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libmnl0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-idna' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'patch' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libpigpio-dev' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libsepol2:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libgav1-1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-rpi-lgpio' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'linux-image-rpi-v8' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libncursesw6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libfuse3-3:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-toml' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libdpkg-perl' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'logsave' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-urllib3' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libwebp7:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'ppp' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'g++' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'keyutils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'groff-base' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libmatroska7:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libcrypt-dev:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libnsl2:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'gpiod' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libtasn1-6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libc6-dev:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libx11-6:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libmtp9:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'sgml-base' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libpisp1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'usb-modeswitch' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libusb-1.0-0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libfontconfig1:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'apt-listchanges' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libndp0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libmbim-utils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libisl23:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libbz2-1.0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libsamplerate0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libbsd0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'raspi-config' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python-is-python3' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libyuv0:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libqmi-utils' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libalgorithm-diff-xs-perl:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'libjson-c5:arm64' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'readline-common' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'publicsuffix' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'python3-smbus2' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'dbus-bin' missing; assuming package has no files currently installed
                                  dpkg: warning: files list file for package 'raspi-utils-core' missing; assuming package has no files currently installed
                                  (Reading database ... 48569 files and directories currently installed.)
                                  Preparing to unpack .../00-raspi-firmware_1%3a1.20241126-1_all.deb ...
                                  /usr/sbin/update-initramfs: 1: /etc/initramfs-tools/update-initramfs.conf: ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒: File name too long
                                  dpkg: error processing package initramfs-tools (--configure):
                                   installed initramfs-tools package post-installation script subprocess returned error exit status 127
                                  dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-2712:
                                   linux-image-6.6.62+rpt-rpi-2712 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                    Package initramfs-tools is not configured yet.
                                    Package linux-initramfs-tool is not installed.
                                    Package initramfs-tools which provides linux-initramfs-tool is not configured yet.
                                  dpkg: error processing package linux-image-6.6.62+rpt-rpi-2712 (--configure):
                                   dependency problems - leaving unconfigured
                                  Setting up raspberrypi-sys-mods (20241202) ...
                                  dpkg: dependency problems prevent configuration of linux-image-rpi-2712:
                                   linux-image-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                    Package linux-image-6.6.62+rpt-rpi-2712 is not configured yet.
                                  dpkg: error processing package linux-image-rpi-2712 (--configure):
                                  Setting up raspberrypi-net-mods (1.4.3) ...
                                  Installing new version of config file /etc/profile.d/wifi-check.sh ...
                                  dpkg: dependency problems prevent configuration of linux-image-6.6.62+rpt-rpi-v8:
                                   linux-image-6.6.62+rpt-rpi-v8 depends on initramfs-tools (>= 0.120+deb8u2) | linux-initramfs-tool; however:
                                  dpkg: error processing package linux-image-6.6.62+rpt-rpi-v8 (--configure):
                                  dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-v8:
                                   linux-headers-6.6.62+rpt-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-v8-unsigned (= 1:6.6.62-1+rpt1); however:
                                    Package linux-image-6.6.62+rpt-rpi-v8 is not configured yet.
                                    Package linux-image-6.6.62+rpt-rpi-v8-unsigned is not installed.
                                  dpkg: error processing package linux-headers-6.6.62+rpt-rpi-v8 (--configure):
                                  dpkg: dependency problems prevent configuration of linux-headers-6.6.62+rpt-rpi-2712:
                                   linux-headers-6.6.62+rpt-rpi-2712 depends on linux-image-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1) | linux-image-6.6.62+rpt-rpi-2712-unsigned (= 1:6.6.62-1+rpt1); however:
                                    Package linux-image-6.6.62+rpt-rpi-2712-unsigned is not installed.
                                  dpkg: error processing package linux-headers-6.6.62+rpt-rpi-2712 (--configure):
                                  dpkg: dependency problems prevent configuration of linux-headers-rpi-2712:
                                   linux-headers-rpi-2712 depends on linux-headers-6.6.62+rpt-rpi-2712 (= 1:6.6.62-1+rpt1); however:
                                    Package linux-headers-6.6.62+rpt-rpi-2712 is not configured yet.
                                  dpkg: error processing package linux-headers-rpi-2712 (--configure):
                                  dpkg: dependency problems prevent configuration of linux-image-rpi-v8:
                                   linux-image-rpi-v8 depends on linux-image-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                  dpkg: error processing package linux-image-rpi-v8 (--configure):
                                  dpkg: dependency problems prevent configuration of linux-headers-rpi-v8:
                                   linux-headers-rpi-v8 depends on linux-headers-6.6.62+rpt-rpi-v8 (= 1:6.6.62-1+rpt1); however:
                                    Package linux-headers-6.6.62+rpt-rpi-v8 is not configured yet.
                                  dpkg: error processing package linux-headers-rpi-v8 (--configure):
                                  Setting up libcamera0.3:arm64 (0.3.2+rpt20241119-1) ...
                                  Setting up libcamera-ipa:arm64 (0.3.2+rpt20241119-1) ...
                                  Setting up rpicam-apps-lite (1.5.3-1) ...
                                  Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) ...
                                  Processing triggers for man-db (2.11.2-2) ...
                                  Errors were encountered while processing:
                                   initramfs-tools
                                   linux-image-rpi-v8
                                  E: Sub-process /usr/bin/dpkg returned an error code (1)
                                  Aber auch nach einer Neuinstallation, ohne das der USB Dongle dran war, bringt die zwei Fehler.
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   15:38:45 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Mon 2024-12-09 15:38:46 CET
                                             Universal time: Mon 2024-12-09 14:38:46 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  tim
                                  HOME=/home/tim
                                  iobroker
                                  HOME=/home/iobroker
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            951M        353M        334M        114K        330M        597M
                                  Swap:           536M        786K        536M
                                  Total:          1.5G        354M        870M
                                  Active iob-Instances:   39
                                            907 M total memory
                                            336 M used memory
                                             62 M active memory
                                            423 M inactive memory
                                            319 M free memory
                                             19 M buffer memory
                                            296 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  top - 15:38:46 up 9 min,  1 user,  load average: 0.29, 0.88, 0.58
                                  Tasks: 125 total,   1 running, 124 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us, 12.5 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi, 12.5 si,  0.0 st
                                  MiB Mem :    907.2 total,    318.3 free,    337.9 used,    315.4 buff/cache
                                  MiB Swap:    512.0 total,    511.2 free,      0.8 used.    569.3 avail Mem
                                  *** FILESYSTEM ***
                                  tmpfs          tmpfs      91M  844K   90M   1% /run
                                  [Mon Dec  9 15:29:24 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3f6ca7d7-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Dec  9 15:29:28 2024] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                                  [Mon Dec  9 15:29:31 2024] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                                  /var:
                                  1.1G    /var/
                                  296M    /var/cache
                                  290M    /var/cache/apt
                                  164M    /var/lib
                                  Archived and active journals take up 71.6M in the file system.
                                  4.0K    /opt/iobroker/backups/
                                  USB-Devices by-id:
                                  HINT:
                                  /dev/ttyUSB0
                                  /usr/bin/npm            10.8.2
                                  /usr/bin/npx            10.8.2
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  ioBroker            ioBroker (version: 7.0.3, hostname: ioBroker      , alive, uptime: 16180)
                                  iobroker-slave      iobroker-slave (version: 7.0.3, hostname: iobroker-slave, alive, uptime: 565)
                                  admin:          7.1.5
                                  Adapter State
                                    system.adapter.zigbee.0                 : zigbee                : iobroker-slave                           - disabled, port: /dev/ttyUSB0
                                  + instance is alive
                                  Objects and States
                                  Objects:        26969
                                  States:         23298
                                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:2 http://deb.debian.org/debian bookworm InRelease
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       6341       779/node-red
                                  tcp        0      0 0.0.0.0:20000           0.0.0.0:*               LISTEN      1001       5595       779/node-red
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3786       445/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1001       5592       779/node-red
                                  udp        0      0 0.0.0.0:35171           0.0.0.0:*                           104        3741       366/avahi-daemon: r
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5597       779/node-red
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3739       366/avahi-daemon: r
                                  2024-12-09 15:32:27.711  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.outputCount created
                                  2024-12-09 15:32:27.727  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.eventLoopLag created
                                  2024-12-09 15:32:27.740  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.sigKill created
                                  2024-12-09 15:32:27.752  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0.logLevel created
                                  2024-12-09 15:32:27.767  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info created
                                  2024-12-09 15:32:27.776  - info: host.iobroker-slave iobroker host.iobroker-slave object node-red.0.info.connection created
                                  2024-12-09 15:32:27.786  - info: host.iobroker-slave iobroker host.iobroker-slave Set default value of node-red.0.info.connection: false
                                  2024-12-09 15:32:27.810  - info: host.iobroker-slave iobroker host.iobroker-slave object system.adapter.node-red.0 created
                                  2024-12-09 15:32:28.855  - info: host.iobroker-slave iobroker exit 0
                                  2024-12-09 15:32:34.581  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 726
                                  2024-12-09 15:32:39.536  - info: node-red.0 (726) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-09 15:32:39.649  - info: node-red.0 (726) Requested NPM packages: []
                                  2024-12-09 15:32:39.763  - warn: node-red.0 (726) Cannot enable the dynamic object read as admin has authentication
                                  2024-12-09 15:32:40.765  - info: host.iobroker-slave stopInstance system.adapter.node-red.0 (force=false, process=true)
                                  2024-12-09 15:32:45.769  - info: host.iobroker-slave stopInstance timeout 5000 system.adapter.node-red.0 killing pid 726
                                  2024-12-09 15:32:46.128  - warn: host.iobroker-slave instance system.adapter.node-red.0 terminated due to SIGKILL
                                  2024-12-09 15:32:46.129  - info: host.iobroker-slave instance system.adapter.node-red.0 terminated with code null ()
                                  2024-12-09 15:32:51.199  - info: host.iobroker-slave instance system.adapter.node-red.0 in version "5.2.1" started with pid 741
                                  2024-12-09 15:32:55.618  - info: node-red.0 (741) starting. Version 5.2.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v20.18.1, js-controller: 7.0.3
                                  2024-12-09 15:32:55.831  - warn: node-red.0 (741) Cannot enable the dynamic object read as admin has authentication
                                  2024-12-09 15:33:02.041  - info: node-red.0 (741) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                                  2024-12-09 15:33:02.059  - info: node-red.0 (741) Node-RED started successfully (PID: 779)
                                  2024-12-09 15:33:16.464  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                                  9 Dec 15:33:16 - [warn] Projects disabled : editorTheme.projects.enabled=false
                                  2024-12-09 15:33:16.571  - warn: node-red.0 (741) Node-RED: 9 Dec 15:33:16 - [warn] Encrypted credentials not found
                                  • Hant0rH Offline
                                    Hant0rH Offline
                                    Hant0r
                                    USB Dongle geht auch nach einer neuen Installation nicht :(
                                    • Hant0rH Hant0r
                                       initramfs-tools
                                       linux-image-rpi-v8
                                      Script v.2024-12-08 Raspbian+zigbee diag+masking
                                      *** BASE SYSTEM ***
                                       Static hostname: iobroker-slave
                                             Icon name: computer
                                          Architecture: arm64
                                      OS is similar to:
                                      Model           : Raspberry Pi 3 Model B Rev 1.2
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                      Systemuptime and Load:
                                      CPU threads: 4
                                      *** LIFE CYCLE STATUS ***
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      *** TIME AND TIMEZONES ***
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      *** Users and Groups ***
                                      User that called 'iob diag':
                                      tim
                                      HOME=/home/tim
                                      iobroker
                                      HOME=/home/iobroker
                                      *** DISPLAY-SERVER SETUP ***
                                      Display-Server: false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                                907 M total memory
                                                336 M used memory
                                                 62 M active memory
                                                319 M free memory
                                                 19 M buffer memory
                                                296 M swap cache
                                                511 M total swap
                                                  0 M used swap
                                                511 M free swap
                                      *** FAILED SERVICES ***
                                      *** DMESG CRITICAL ERRORS ***
                                      No critical errors detected
                                      *** FILESYSTEM ***
                                      Show mounted filesystems:
                                      TARGET           SOURCE         FSTYPE OPTIONS
                                      /var:
                                      1.1G    /var/
                                      296M    /var/cache
                                      290M    /var/cache/apt
                                      164M    /var/lib
                                      /opt/iobroker/backups:
                                      /opt/iobroker/iobroker-data:
                                      USB-Devices by-id:
                                      HINT:
                                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                                      /dev/ttyUSB0
                                      *** NodeJS-Installation ***
                                      /usr/bin/nodejs         v20.18.1
                                      /usr/bin/node           v20.18.1
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      /usr/bin/corepack       0.29.4
                                      nodejs:
                                        Installed: 20.18.1-1nodesource1
                                        Candidate: 20.18.1-1nodesource1
                                        Version table:
                                       *** 20.18.1-1nodesource1 1001
                                           20.18.0-1nodesource1 1001
                                           20.17.0-1nodesource1 1001
                                           20.16.0-1nodesource1 1001
                                           20.15.1-1nodesource1 1001
                                           20.15.0-1nodesource1 1001
                                           20.14.0-1nodesource1 1001
                                           20.13.1-1nodesource1 1001
                                           20.13.0-1nodesource1 1001
                                           20.12.2-1nodesource1 1001
                                           20.12.1-1nodesource1 1001
                                           20.12.0-1nodesource1 1001
                                           20.11.1-1nodesource1 1001
                                           20.11.0-1nodesource1 1001
                                           20.10.0-1nodesource1 1001
                                           20.9.0-1nodesource1 1001
                                           20.8.1-1nodesource1 1001
                                           20.8.0-1nodesource1 1001
                                           20.7.0-1nodesource1 1001
                                           20.6.1-1nodesource1 1001
                                           20.6.0-1nodesource1 1001
                                           20.5.1-1nodesource1 1001
                                           20.5.0-1nodesource1 1001
                                           20.4.0-1nodesource1 1001
                                           20.3.1-1nodesource1 1001
                                           20.3.0-1nodesource1 1001
                                           20.2.0-1nodesource1 1001
                                           20.1.0-1nodesource1 1001
                                           20.0.0-1nodesource1 1001
                                      No problems detected
                                      Errors in npm tree: 0
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      At least one iobroker host is running.
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      Core adapters versions
                                      admin:          7.1.5
                                      javascript:     "javascript" not found
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                                      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                                      + instance is alive
                                      Objects and States
                                      Objects:        26969
                                      States:         23298
                                      Pending Updates: 0
                                      Ist das normal?
                                      Natürlich nicht.
                                        Ist das normal?
                                        Natürlich nicht.
                                        Hant0rH Offline
                                        Hant0rH Offline
                                        Hant0r
                                        @thomas-braun sagte in Fehler bei node red auf dem slave:
                                        Ist das normal?
                                        Natürlich nicht.
                                        Das dachte ich mir auch. Finde bisher im Netz aber keine Lösung
                                        • Hant0rH Hant0r
                                          Ist das normal?
                                          Natürlich nicht.
                                          @hant0r
                                          Bei dem 'Fehler'bild würde ich es nochmal langsam und in Ruhe installieren.
                                          Auf dem RPi3 dauert eine simple Installation nur des Basissystems auch schon mal gerne eine Stunde.
