  4. [gelöst] Zigbee-Adapter
    1.0k
    6.1k
zigbee netzwerkkarte
63 Beiträge 7 Kommentatoren 9.2k Aufrufe 4 Beobachtet
    @lenny-cb
    Verwende die Beta-Version von iob diag:
    curl https://raw.githubusercontent.com/Grothesk242/ioBroker/refs/heads/Raspbian/diag.sh > iob_diag.sh
    chmod 744 iob_diag.sh
    ./iob_diag.sh
    Lenny.CBL Offline
    Lenny.CBL Offline
    Lenny.CB
    @thomas-braun sagte in [gelöst] Zigbee-Adapter:
    ./iob_diag.sh
                            v.2024-10-26 Raspbian
     Static hostname: raspberrypi
           Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
              Kernel: Linux 6.1.21-v7+
        Architecture: arm
    Kernel:                 armv7l
    Userland:               32 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1001
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs  and npm
    nodeJS installation is correct
    MEMORY:
    Mem:            966M        135M        305M        925K        593M        831M
    Swap:           209M        786K        208M
    Total:          1.2G        135M        514M
    Active iob-Instances:   34
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.3
                            admin                   7.4.3
    ioBroker Status:        iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.1                  : admin                 : RPI2                                     - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.admin.3                  : admin                 : iobroker                                 - disabled, port: 8881, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    Objects:                25550
    States:                 22170
    Size of iob-Database:
    3.7M    /opt/iobroker/iobroker-data/objects.jsonl
    76K     /opt/iobroker/iobroker-data/states.jsonl
    2 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    Operating System is the current Debian stable version codenamed 'bookworm'!
    • Lenny.CBL Lenny.CB
      ./iob_diag.sh
             Icon name: computer
          Architecture: arm
      Kernel:                 armv7l
      Userland:               32 bit
      User-ID:                1001
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      MEMORY:
                              admin                   7.4.3
      Objects type: jsonl
      States  type: jsonl
      Objects:                25550
      States:                 22170
      @lenny-cb
      Die Langfassung.
      Und log dich mit deinem Standard-User (mit der uid=1000) ein. Vermutlich pi dann.
      Lenny.CBL 1 Antwort Letzte Antwort
        ./iob_diag.sh
               Icon name: computer
            Architecture: arm
        Kernel:                 armv7l
        Userland:               32 bit
        User-ID:                1001
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        MEMORY:
                                admin                   7.4.3
        Objects type: jsonl
        States  type: jsonl
        Objects:                25550
        States:                 22170
        @lenny-cb sagte in [gelöst] Zigbee-Adapter:
        ensthaft?
        bei
        hast du noch nie Probleme mit dem RAM gehabt?
          ensthaft?
          bei
          Lenny.CBL Offline
          Lenny.CBL Offline
          Lenny.CB
          @homoran sagte in [gelöst] Zigbee-Adapter:
          ensthaft?
          bei
          nö, noch keine Probleme mit dem RAM.
          Jedoch wundern mich die "34 aktiven Instanzen" etwas. Auf dem PI (als Slave) läuft nur Zigbee, Traccar und Backup.
            @lenny-cb
            Die Langfassung.
            Lenny.CBL Offline
            Lenny.CBL Offline
            Lenny.CB
            schrieb am zuletzt editiert von Lenny.CB
            Die Langfassung.
            Script v.2024-10-26 Raspbian
            *** BASE SYSTEM ***
                  Icon name: computer
               Architecture: arm
            OS is similar to: debian
            Model           : Raspberry Pi 2 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
            12:03:35 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            ~ Under-voltage has occurred
            ~ Arm frequency capping has occurred
            *** TIME AND TIMEZONES ***
                          Local time: Mon 2024-12-02 12:03:35 CET
                      Universal time: Mon 2024-12-02 11:03:35 UTC
                            RTC time: n/a
                         NTP service: active
                     RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            966M        136M        299M        925K        598M        830M
            Total:          1.2G        137M        508M
                     921 M total memory
                     130 M used memory
                     296 M active memory
                     239 M inactive memory
                     285 M free memory
                      97 M buffer memory
                     474 M swap cache
                     199 M total swap
                       0 M used swap
                     199 M free swap
            top - 12:03:36 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
            Tasks: 121 total,   1 running, 120 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 75.0 id,  8.3 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :    922.0 total,    283.8 free,    132.0 used,    571.1 buff/cache
            MiB Swap:    200.0 total,    199.2 free,      0.8 used.    790.0 avail Mem
            *** FAILED SERVICES ***
             UNIT             LOAD   ACTIVE SUB    DESCRIPTION
            * iobroker.service loaded failed failed ioBroker Server
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            *** FILESYSTEM ***
            /dev/root      ext4       29G  6.4G   22G  23% /
            devtmpfs       devtmpfs  333M     0  333M   0% /dev
            tmpfs          tmpfs     461M     0  461M   0% /dev/shm
            tmpfs          tmpfs     185M  976K  184M   1% /run
            tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
            /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
            tmpfs          tmpfs      93M     0   93M   0% /run/user/0
            tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
            [Sun Dec  1 14:28:17 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=572b59fd-02 rootfstype=ext4 fsck.repair=yes rootwait
            [Sun Dec  1 14:28:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sun Dec  1 14:28:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Sun Dec  1 14:28:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET  SOURCE         FSTYPE OPTIONS
            /       /dev/mmcblk0p2 ext4   rw,noatime
            `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            1.6G    /var/
            885M    /var/log
            882M    /var/log/journal/24de808e72c141b89cdc93c28511878d
            418M    /var/cache
            Archived and active journals take up 881.3M in the file system.
            /opt/iobroker/backups:
            148M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            18M     /opt/iobroker/iobroker-data/
            15M     /opt/iobroker/iobroker-data/files
            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
            652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
            HINT:
            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
            /dev/ttyACM0
            *** NodeJS-Installation ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
             Installed: 20.18.1-1nodesource1
             Candidate: 20.18.1-1nodesource1
             Version table:
            *** 20.18.1-1nodesource1 1001
                   500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                20.18.0-1nodesource1 1001
                20.17.0-1nodesource1 1001
                20.16.0-1nodesource1 1001
                20.15.1-1nodesource1 1001
                20.15.0-1nodesource1 1001
                20.14.0-1nodesource1 1001
                20.13.1-1nodesource1 1001
                20.13.0-1nodesource1 1001
                20.12.2-1nodesource1 1001
                20.12.1-1nodesource1 1001
                20.12.0-1nodesource1 1001
                20.11.1-1nodesource1 1001
                20.11.0-1nodesource1 1001
                20.10.0-1nodesource1 1001
                20.9.0-1nodesource1 1001
                20.8.1-1nodesource1 1001
                20.8.0-1nodesource1 1001
                20.7.0-1nodesource1 1001
                20.6.1-1nodesource1 1001
                20.6.0-1nodesource1 1001
                20.5.1-1nodesource1 1001
                20.5.0-1nodesource1 1001
                20.4.0-1nodesource1 1001
                20.3.1-1nodesource1 1001
                20.3.0-1nodesource1 1001
                20.2.0-1nodesource1 1001
                20.1.0-1nodesource1 1001
                20.0.0-1nodesource1 1001
                18.19.0+dfsg-6~deb12u2+rpi1 500
                   500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            RPI2                RPI2 (version: 7.0.3, hostname: RPI2          , alive, uptime: 75819)
            iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 78188)
            Core adapters versions
            js-controller:  7.0.3
            admin:          7.4.3
            javascript:     8.8.3
            nodejs modules from github:     1
            +-- iobroker.gartenbewaesserung@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#a88728c2b522e8171960c3001a9edd92ce60f3bd)
            Adapter State
             system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
             system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
             system.adapter.apg-info.0               : apg-info              : iobroker                                 -  enabled
             system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
             system.adapter.backitup.2               : backitup              : RPI2                                     -  enabled
             system.adapter.cloud.1                  : cloud                 : iobroker                                 - disabled
             system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
             system.adapter.devices.0                : devices               : iobroker                                 - disabled
             system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
            + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
            + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 -  enabled
             system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
             system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
             system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : RPI2                                     - disabled
             system.adapter.history.0                : history               : iobroker                                 - disabled
             system.adapter.hm-rega.0                : hm-rega               : RPI2                                     - disabled
             system.adapter.hm-rpc.0                 : hm-rpc                : RPI2                                     - disabled, port: 0
             system.adapter.hm-rpc.1                 : hm-rpc                : RPI2                                     - disabled, port: 0
             system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
             system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
             system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
             system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
             system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
             system.adapter.javascript.3             : javascript            : RPI2                                     - disabled
             system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
             system.adapter.material.0               : material              : iobroker                                 -  enabled
             system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 - disabled
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
            + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
             system.adapter.pid.0                    : pid                   : iobroker                                 - disabled
             system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
             system.adapter.pollenflug.0             : pollenflug            : RPI2                                     - disabled
            + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1879, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1887, bind: 0.0.0.0
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
             system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
             system.adapter.traccar.0                : traccar               : RPI2                                     -  enabled
             system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
             system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
             system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
             system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
             system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
             system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
             system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
             system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
             system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
             system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
             system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
             system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
             system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
             system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled
            + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
            + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
             system.adapter.yr.0                     : yr                    : iobroker                                 - disabled
             system.adapter.zigbee.0                 : zigbee                : RPI2                                     -  enabled, port: /dev/ttyACM0
            + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name          │ url                                                     │ auto upgrade │
            │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            │ 1       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
            │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
            Active repo(s): beta
            Installed ioBroker-Instances
            Used repository: beta
            Adapter    "admin"        : 7.4.3    , installed 7.4.3
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.3    , installed 7.0.3
            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
            Adapter    "traccar"      : 1.1.6    , installed 1.1.6
            Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
            Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
            Objects and States
            Objects:        25550
            States:         22170
            Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
            Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
            Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists... Done
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14320      495/sshd: /usr/sbin
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14339      495/sshd: /usr/sbin
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10974      564/dhcpcd
            udp        0      0 0.0.0.0:50300           0.0.0.0:*                           108        10907      343/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10905      343/avahi-daemon: r
            udp6       0      0 :::58156                :::*                                108        10908      343/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                108        10906      343/avahi-daemon: r
            2024-12-02 11:32:24.899  - info: host.RPI2 stopInstance system.adapter.hm-rega.0 (force=false, process=false)
            2024-12-02 11:32:24.901  - info: host.RPI2 stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
            2024-12-02 11:32:24.904  - info: host.RPI2 stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
            2024-12-02 11:32:24.906  - info: host.RPI2 stopInstance system.adapter.pollenflug.0 (force=false, process=false)
            2024-12-02 11:32:24.908  - info: host.RPI2 stopInstance system.adapter.zigbee.0 (force=false, process=true)
            2024-12-02 11:32:24.910  - info: host.RPI2 stopInstance system.adapter.gartenbewaesserung.0 (force=false, process=false)
            2024-12-02 11:32:24.913  - info: host.RPI2 stopInstance system.adapter.traccar.0 (force=false, process=true)
            2024-12-02 11:32:24.934  - silly: traccar.0 (636) States system redis pmessage system.adapter.traccar.0.sigKill/system.adapter.traccar.0.sigKill:{"val":-1,"ack":false,"ts":1733135544930,"q":0,"from":"system.host.RPI2","lc":1733135544930}
            2024-12-02 11:32:24.936  - info: traccar.0 (636) Got terminate signal TERMINATE_YOURSELF
            2024-12-02 11:32:24.940  - info: host.RPI2 stopInstance system.adapter.backitup.2 send kill signal
            2024-12-02 11:32:24.945  - info: host.RPI2 stopInstance system.adapter.zigbee.0 send kill signal
            2024-12-02 11:32:24.947  - info: host.RPI2 stopInstance system.adapter.traccar.0 send kill signal
            2024-12-02 11:32:25.416  - info: traccar.0 (636) terminating
            2024-12-02 11:32:24.938  - info: zigbee.0 (2394) Zigbee: disabling joining new devices.
            2024-12-02 11:32:25.922  - info: zigbee.0 (2394) Got terminate signal TERMINATE_YOURSELF
            2024-12-02 11:32:25.944  - info: zigbee.0 (2394) terminating
            2024-12-02 11:32:25.948  - info: zigbee.0 (2394) Terminated (NO_ERROR): Without reason
            2024-12-02 11:32:26.031  - info: host.RPI2 instance system.adapter.traccar.0 terminated with code 0 (NO_ERROR)
            2024-12-02 11:32:26.036  - info: host.RPI2 stopInstance timeout system.adapter.zigbee.0 killing pid 2394
            2024-12-02 11:32:26.511  - info: host.RPI2 instance system.adapter.backitup.2 terminated with code 0 (NO_ERROR)
            2024-12-02 11:32:26.515  - info: host.RPI2 All instances are stopped.
            2024-12-02 11:32:27.010  - warn: host.RPI2 instance system.adapter.zigbee.0 terminated due to SIGKILL
            2024-12-02 11:32:27.013  - info: host.RPI2 instance system.adapter.zigbee.0 terminated with code null ()
            2024-12-02 11:32:27.014  - info: host.RPI2 All instances are stopped.
            2024-12-02 11:32:27.045  - info: host.RPI2 terminated
              ensthaft?
              bei
              ok, da alkes über/auf dem Master läuft, sieht iob diag dann wohl alles.
              das geht auch mit 1GB
                Die Langfassung.
                *** BASE SYSTEM ***
                      Icon name: computer
                   Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                RTC time: n/a
                             NTP service: active
                         RTC in local TZ: no
                pi
                HOME=/home/pi
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                         921 M total memory
                         130 M used memory
                         296 M active memory
                         285 M free memory
                          97 M buffer memory
                         474 M swap cache
                         199 M total swap
                           0 M used swap
                         199 M free swap
                *** FILESYSTEM ***
                /var:
                1.6G    /var/
                885M    /var/log
                418M    /var/cache
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                 Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.4.3
                javascript:     8.8.3
                Adapter State
                + instance is alive
                Objects and States
                Objects:        25550
                States:         22170
                Pending Updates: 0
                Schau dir die an.
                Die Spannungsversorgung meldet Probleme:
                Beim Filesystem ist wie erwartet der boot-Eintrag falsch:
                Setz den zigbee-Adapter auf den Link 'by-id'.
                USB-Devices by-id:
                HINT:
                /dev/ttyACM0
                Setz das LogLevel nicht auf silly, wenn du den nichtt gerade debuggst:
                silly: traccar.0
                Wie nicht anders erwartet hat das 'in-line'-Upgrade nicht richtig funktioniert.
                Installier es wie vorgesehen komplett neu.
                Lenny.CBL 2 Antworten Letzte Antwort
                  Schau dir die an.
                  USB-Devices by-id:
                  HINT:
                  /dev/ttyACM0
                  silly: traccar.0
                  Lenny.CBL Offline
                  Lenny.CBL Offline
                  Lenny.CB
                  pi@raspberrypi:~ $ sudo dmesg --level=emerg,alert,crit -T
                  [Sun Dec 1 14:28:31 2024] hwmon hwmon1: Undervoltage detected!
                  [Sun Dec 1 18:51:28 2024] hwmon hwmon1: Undervoltage detected!
                  pi@raspberrypi:~ $
                    Schau dir die an.
                    USB-Devices by-id:
                    HINT:
                    /dev/ttyACM0
                    silly: traccar.0
                    Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    Kann man es beheben? (außer mit einer Neuinstallation)
                      pi@raspberrypi:~ $
                      @lenny-cb
                      Das passt zu
                        Nein. Da sind mit Sicherheit auch noch andere Kinken drin.
                          Lenny.CBL Offline
                          Lenny.CBL Offline
                          Lenny.CB
                          @thomas-braun ich werd gleich mal mit dem Adapter auf den Master "umziehen". Mal schauen...
                            Lenny.CBL Offline
                            Lenny.CBL Offline
                            Lenny.CB
                            @Thomas-Braun, @Asgothian ich bin nun auf den Master umgezogen.
                            Umzug war super einfach. Leider alles beim Alten. Was funktionierte geht, sonst wie oben beschrieben.
                            Morgen geht es mit dem neuen Stick weiter.
                            Mich wunderts halt, dass sonst keiner Probleme hat. Ich kann doch nicht der Einzige sein, der noch mit nem CC2538 rumfummelt.
                              @lenny-cb
                              NEIN, Du bist nicht der einzige ;-)
                              Und JA, ich habe ebenfalls Probleme nach dem Update von 1.10.3 auf 1.10.13
                              Ich konnte keine Aktoren mehr steuern (Zwischenstecker und Licht), Sensoren lieferten aber Daten.
                              Im Log gab es keine Fehlermeldungen und der Adapter startete korrekt.
                              Nach einem Downgrade zurück auf 1.10.3 funktioniert nun alles wieder wie vorher.
                                @lenny-cb
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @jimmybondi sagte in [gelöst] Zigbee-Adapter:
                                Na ja - bisher ist es mir nicht gelungen den Fehler nachzustellen, auch mangels Hardware. Versuche mit dem cc2531 sind bis zu einem bestimmten Punkt gekommen - dann wurde die Hardware gewechselt (auf einen Sonoff Stick - meines Wissens erfolgreich).
                                Ohne eine Möglichkeit das ganze zu testen können wir da nichts machen.
                                A.
