  4. [gelöst] Zigbee-Adapter
    1.0k
    6.1k
zigbee netzwerkkarte
63 Beiträge 7 Kommentatoren 9.2k Aufrufe 4 Beobachtet
    @lenny-cb
    Die Langfassung.
    Und log dich mit deinem Standard-User (mit der uid=1000) ein. Vermutlich pi dann.
    Lenny.CBL Offline
    Lenny.CBL Offline
    Lenny.CB
    schrieb am zuletzt editiert von Lenny.CB
    @thomas-braun sagte in [gelöst] Zigbee-Adapter:
    Die Langfassung.
    Script v.2024-10-26 Raspbian
    *** BASE SYSTEM ***
    Static hostname: raspberrypi
          Icon name: computer
    Operating System: Raspbian GNU/Linux 12 (bookworm)
             Kernel: Linux 6.1.21-v7+
       Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 2 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
    12:03:35 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                  Local time: Mon 2024-12-02 12:03:35 CET
              Universal time: Mon 2024-12-02 11:03:35 UTC
                    RTC time: n/a
                 NTP service: active
             RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            966M        136M        299M        925K        598M        830M
    Swap:           209M        786K        208M
    Total:          1.2G        137M        508M
    Active iob-Instances:   34
             921 M total memory
             130 M used memory
             296 M active memory
             239 M inactive memory
             285 M free memory
              97 M buffer memory
             474 M swap cache
             199 M total swap
               0 M used swap
             199 M free swap
    top - 12:03:36 up 21:35,  1 user,  load average: 0.02, 0.22, 0.27
    Tasks: 121 total,   1 running, 120 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 75.0 id,  8.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :    922.0 total,    283.8 free,    132.0 used,    571.1 buff/cache
    MiB Swap:    200.0 total,    199.2 free,      0.8 used.    790.0 avail Mem
    *** FAILED SERVICES ***
     UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    2 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    /dev/root      ext4       29G  6.4G   22G  23% /
    devtmpfs       devtmpfs  333M     0  333M   0% /dev
    tmpfs          tmpfs     461M     0  461M   0% /dev/shm
    tmpfs          tmpfs     185M  976K  184M   1% /run
    tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
    tmpfs          tmpfs      93M     0   93M   0% /run/user/0
    tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
    [Sun Dec  1 14:28:17 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=572b59fd-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Dec  1 14:28:21 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Sun Dec  1 14:28:21 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sun Dec  1 14:28:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.6G    /var/
    885M    /var/log
    882M    /var/log/journal/24de808e72c141b89cdc93c28511878d
    418M    /var/cache
    Archived and active journals take up 881.3M in the file system.
    /opt/iobroker/backups:
    148M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M     /opt/iobroker/iobroker-data/
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.7M    /opt/iobroker/iobroker-data/objects.jsonl
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
     Installed: 20.18.1-1nodesource1
     Candidate: 20.18.1-1nodesource1
     Version table:
    *** 20.18.1-1nodesource1 1001
           500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
        20.18.0-1nodesource1 1001
        20.17.0-1nodesource1 1001
        20.16.0-1nodesource1 1001
        20.15.1-1nodesource1 1001
        20.15.0-1nodesource1 1001
        20.14.0-1nodesource1 1001
        20.13.1-1nodesource1 1001
        20.13.0-1nodesource1 1001
        20.12.2-1nodesource1 1001
        20.12.1-1nodesource1 1001
        20.12.0-1nodesource1 1001
        20.11.1-1nodesource1 1001
        20.11.0-1nodesource1 1001
        20.10.0-1nodesource1 1001
        20.9.0-1nodesource1 1001
        20.8.1-1nodesource1 1001
        20.8.0-1nodesource1 1001
        20.7.0-1nodesource1 1001
        20.6.1-1nodesource1 1001
        20.6.0-1nodesource1 1001
        20.5.1-1nodesource1 1001
        20.5.0-1nodesource1 1001
        20.4.0-1nodesource1 1001
        20.3.1-1nodesource1 1001
        20.3.0-1nodesource1 1001
        20.2.0-1nodesource1 1001
        20.1.0-1nodesource1 1001
        20.0.0-1nodesource1 1001
        18.19.0+dfsg-6~deb12u2+rpi1 500
           500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    At least one iobroker host is running.
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    RPI2                RPI2 (version: 7.0.3, hostname: RPI2          , alive, uptime: 75819)
    iobroker            iobroker (version: 7.0.3, hostname: iobroker      , alive, uptime: 78188)
    Core adapters versions
    js-controller:  7.0.3
    admin:          7.4.3
    javascript:     8.8.3
    nodejs modules from github:     1
    +-- iobroker.gartenbewaesserung@0.0.6 (git+ssh://git@github.com/TA2k/ioBroker.gartenbewaesserung.git#a88728c2b522e8171960c3001a9edd92ce60f3bd)
    Adapter State
     system.adapter.admin.1                  : admin                 : RPI2                                     - disabled, port: 8081, bind: 0.0.0.0, run as: admin
     system.adapter.admin.3                  : admin                 : iobroker                                 - disabled, port: 8881, bind: 0.0.0.0 (SSL), run as: admin
     system.adapter.alexa2.0                 : alexa2                : iobroker                                 - disabled
     system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
     system.adapter.apg-info.0               : apg-info              : iobroker                                 -  enabled
     system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
     system.adapter.backitup.2               : backitup              : RPI2                                     -  enabled
     system.adapter.cloud.1                  : cloud                 : iobroker                                 - disabled
     system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
     system.adapter.devices.0                : devices               : iobroker                                 - disabled
     system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
    + system.adapter.ebus.0                   : ebus                  : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 -  enabled
     system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
     system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 - disabled
     system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : RPI2                                     - disabled
     system.adapter.history.0                : history               : iobroker                                 - disabled
     system.adapter.hm-rega.0                : hm-rega               : RPI2                                     - disabled
     system.adapter.hm-rpc.0                 : hm-rpc                : RPI2                                     - disabled, port: 0
     system.adapter.hm-rpc.1                 : hm-rpc                : RPI2                                     - disabled, port: 0
     system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
     system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
     system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
     system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
     system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
     system.adapter.javascript.3             : javascript            : RPI2                                     - disabled
     system.adapter.luftdaten.0              : luftdaten             : iobroker                                 - disabled
     system.adapter.material.0               : material              : iobroker                                 -  enabled
     system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 - disabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
     system.adapter.pid.0                    : pid                   : iobroker                                 - disabled
     system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
     system.adapter.pollenflug.0             : pollenflug            : RPI2                                     - disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1879, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartcontrol.0           : smartcontrol          : iobroker                                 -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1887, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
     system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
     system.adapter.traccar.0                : traccar               : RPI2                                     -  enabled
     system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
     system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
     system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
     system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
     system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
     system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
     system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
     system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
     system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
     system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
     system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
     system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
     system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
     system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
    + system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.yeelight-2.0             : yeelight-2            : iobroker                                 -  enabled
     system.adapter.yr.0                     : yr                    : iobroker                                 - disabled
     system.adapter.zigbee.0                 : zigbee                : RPI2                                     -  enabled, port: /dev/ttyACM0
    + system.adapter.zwave2.0                 : zwave2                : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name          │ url                                                     │ auto upgrade │
    │ 0       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 1       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
    │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Instances
    Used repository: beta
    Adapter    "admin"        : 7.4.3    , installed 7.4.3
    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
    Controller "js-controller": 7.0.3    , installed 7.0.3
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "traccar"      : 1.1.6    , installed 1.1.6
    Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
    Adapter    "zigbee"       : 1.10.13  , installed 1.10.13
    Objects and States
    Objects:        25550
    States:         22170
    Hit:1 http://archive.raspberrypi.org/debian bookworm InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14320      495/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14339      495/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10974      564/dhcpcd
    udp        0      0 0.0.0.0:50300           0.0.0.0:*                           108        10907      343/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10905      343/avahi-daemon: r
    udp6       0      0 :::58156                :::*                                108        10908      343/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        10906      343/avahi-daemon: r
    2024-12-02 11:32:24.899  - info: host.RPI2 stopInstance system.adapter.hm-rega.0 (force=false, process=false)
    2024-12-02 11:32:24.901  - info: host.RPI2 stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
    2024-12-02 11:32:24.904  - info: host.RPI2 stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
    2024-12-02 11:32:24.906  - info: host.RPI2 stopInstance system.adapter.pollenflug.0 (force=false, process=false)
    2024-12-02 11:32:24.908  - info: host.RPI2 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2024-12-02 11:32:24.910  - info: host.RPI2 stopInstance system.adapter.gartenbewaesserung.0 (force=false, process=false)
    2024-12-02 11:32:24.913  - info: host.RPI2 stopInstance system.adapter.traccar.0 (force=false, process=true)
    2024-12-02 11:32:24.934  - silly: traccar.0 (636) States system redis pmessage system.adapter.traccar.0.sigKill/system.adapter.traccar.0.sigKill:{"val":-1,"ack":false,"ts":1733135544930,"q":0,"from":"system.host.RPI2","lc":1733135544930}
    2024-12-02 11:32:24.936  - info: traccar.0 (636) Got terminate signal TERMINATE_YOURSELF
    2024-12-02 11:32:24.940  - info: host.RPI2 stopInstance system.adapter.backitup.2 send kill signal
    2024-12-02 11:32:24.945  - info: host.RPI2 stopInstance system.adapter.zigbee.0 send kill signal
    2024-12-02 11:32:24.947  - info: host.RPI2 stopInstance system.adapter.traccar.0 send kill signal
    2024-12-02 11:32:25.416  - info: traccar.0 (636) terminating
    2024-12-02 11:32:24.938  - info: zigbee.0 (2394) Zigbee: disabling joining new devices.
    2024-12-02 11:32:25.922  - info: zigbee.0 (2394) Got terminate signal TERMINATE_YOURSELF
    2024-12-02 11:32:25.944  - info: zigbee.0 (2394) terminating
    2024-12-02 11:32:25.948  - info: zigbee.0 (2394) Terminated (NO_ERROR): Without reason
    2024-12-02 11:32:26.031  - info: host.RPI2 instance system.adapter.traccar.0 terminated with code 0 (NO_ERROR)
    2024-12-02 11:32:26.036  - info: host.RPI2 stopInstance timeout system.adapter.zigbee.0 killing pid 2394
    2024-12-02 11:32:26.511  - info: host.RPI2 instance system.adapter.backitup.2 terminated with code 0 (NO_ERROR)
    2024-12-02 11:32:26.515  - info: host.RPI2 All instances are stopped.
    2024-12-02 11:32:27.010  - warn: host.RPI2 instance system.adapter.zigbee.0 terminated due to SIGKILL
    2024-12-02 11:32:27.013  - info: host.RPI2 instance system.adapter.zigbee.0 terminated with code null ()
    2024-12-02 11:32:27.014  - info: host.RPI2 All instances are stopped.
    2024-12-02 11:32:27.045  - info: host.RPI2 terminated
    • Lenny.CBL Lenny.CB
      @homoran sagte in [gelöst] Zigbee-Adapter:
      @lenny-cb sagte in [gelöst] Zigbee-Adapter:
      Mem: 966M 135M 305M 925K 593M 831M
      ensthaft?
      bei
      hast du noch nie Probleme mit dem RAM gehabt?
      nö, noch keine Probleme mit dem RAM.
      Jedoch wundern mich die "34 aktiven Instanzen" etwas. Auf dem PI (als Slave) läuft nur Zigbee, Traccar und Backup.
      ok, da alkes über/auf dem Master läuft, sieht iob diag dann wohl alles.
      das geht auch mit 1GB
        Die Langfassung.
        *** BASE SYSTEM ***
              Icon name: computer
           Architecture: arm
        Docker          : false
        Kernel          : armv7l
        Userland        : 32 bit
        CPU threads: 4
        Current issues:
                        RTC time: n/a
                     NTP service: active
                 RTC in local TZ: no
        pi
        HOME=/home/pi
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 921 M total memory
                 130 M used memory
                 296 M active memory
                 285 M free memory
                  97 M buffer memory
                 474 M swap cache
                 199 M total swap
                   0 M used swap
                 199 M free swap
        *** FILESYSTEM ***
        /var:
        1.6G    /var/
        885M    /var/log
        418M    /var/cache
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
         Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.4.3
        javascript:     8.8.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        25550
        States:         22170
        Pending Updates: 0
        Schau dir die an.
        Die Spannungsversorgung meldet Probleme:
        Beim Filesystem ist wie erwartet der boot-Eintrag falsch:
        Setz den zigbee-Adapter auf den Link 'by-id'.
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        Setz das LogLevel nicht auf silly, wenn du den nichtt gerade debuggst:
        silly: traccar.0
        Wie nicht anders erwartet hat das 'in-line'-Upgrade nicht richtig funktioniert.
        Installier es wie vorgesehen komplett neu.
        Lenny.CBL 2 Antworten Letzte Antwort
          Schau dir die an.
          USB-Devices by-id:
          HINT:
          /dev/ttyACM0
          silly: traccar.0
          Lenny.CBL Offline
          Lenny.CBL Offline
          Lenny.CB
          pi@raspberrypi:~ $ sudo dmesg --level=emerg,alert,crit -T
          [Sun Dec 1 14:28:31 2024] hwmon hwmon1: Undervoltage detected!
          [Sun Dec 1 18:51:28 2024] hwmon hwmon1: Undervoltage detected!
          pi@raspberrypi:~ $
            Schau dir die an.
            USB-Devices by-id:
            HINT:
            /dev/ttyACM0
            silly: traccar.0
            Lenny.CBL Offline
            Lenny.CBL Offline
            Lenny.CB
            Kann man es beheben? (außer mit einer Neuinstallation)
              pi@raspberrypi:~ $
              @lenny-cb
              Das passt zu
                Nein. Da sind mit Sicherheit auch noch andere Kinken drin.
                Lenny.CBL 1 Antwort Letzte Antwort
                  Lenny.CBL Offline
                  Lenny.CBL Offline
                  Lenny.CB
                  @thomas-braun ich werd gleich mal mit dem Adapter auf den Master "umziehen". Mal schauen...
                    Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    @Thomas-Braun, @Asgothian ich bin nun auf den Master umgezogen.
                    Umzug war super einfach. Leider alles beim Alten. Was funktionierte geht, sonst wie oben beschrieben.
                    Morgen geht es mit dem neuen Stick weiter.
                    Mich wunderts halt, dass sonst keiner Probleme hat. Ich kann doch nicht der Einzige sein, der noch mit nem CC2538 rumfummelt.
                      @lenny-cb
                      NEIN, Du bist nicht der einzige ;-)
                      Und JA, ich habe ebenfalls Probleme nach dem Update von 1.10.3 auf 1.10.13
                      Ich konnte keine Aktoren mehr steuern (Zwischenstecker und Licht), Sensoren lieferten aber Daten.
                      Im Log gab es keine Fehlermeldungen und der Adapter startete korrekt.
                      Nach einem Downgrade zurück auf 1.10.3 funktioniert nun alles wieder wie vorher.
                        @lenny-cb
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @jimmybondi sagte in [gelöst] Zigbee-Adapter:
                        Na ja - bisher ist es mir nicht gelungen den Fehler nachzustellen, auch mangels Hardware. Versuche mit dem cc2531 sind bis zu einem bestimmten Punkt gekommen - dann wurde die Hardware gewechselt (auf einen Sonoff Stick - meines Wissens erfolgreich).
                        Ohne eine Möglichkeit das ganze zu testen können wir da nichts machen.
                        A.
