  4. Could not determine controller directory
    1.0k
    6.1k
31 Beiträge 6 Kommentatoren 4.5k Aufrufe 5 Beobachtet
  • A arniworx
    ok, dann bekomme ich das hier:
    × iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Tue 2024-11-26 09:10:08 CET; 54min ago
           Docs: http://iobroker.net
        Process: 1609 ExecStart=/usr/bin/bash -c ${NODE} /opt/iobroker/node_modules/iobroker.js-controller/controller.js (code=exited, status=6)
       Main PID: 1609 (code=exited, status=6)
            CPU: 40.207s
    Nov 26 09:09:59 vm01 bash[1609]:     at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37)
    Nov 26 09:09:59 vm01 bash[1609]:     at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3224:30)
    Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
    Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [Process stopped]
    Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
    Nov 26 09:09:59 vm01 bash[1609]: ================================== > LOG REDIRECT system.adapter.javascript.0 => false [system.adapter.javascript.0.logging]
    Nov 26 09:10:00 vm01 systemd[1]: iobroker.service: Main process exited, code=exited, status=6/NOTCONFIGURED
    Nov 26 09:10:08 vm01 systemd[1]: iobroker.service: Failed with result 'exit-code'.
    Nov 26 09:10:08 vm01 systemd[1]: Stopped ioBroker Server.
    Nov 26 09:10:08 vm01 systemd[1]: iobroker.service: Consumed 40.207s CPU time.
    kannst du da was erkennen?
    einige reparatur-versuche hab ich schon erfolglos durch:
    iob nodejs-update 20
    iob fix
    curl -sL https://iobroker.net/fix.sh | bash -
    das hier, läuft in dauerschleife.
    @arniworx sagte in [gelöst] Dauerhafter ioBroker Restart nach JS-Update:
    das hier
    was genau?
    diese schwarze Briefmarke ist mobil nicht zu entziffern.
    deswegen code u.ä. immer als Text in code-tags posten!
    • A arniworx
              CPU: 40.207s
      iob fix
      ist auch ein total unüblicher Pfad. Das mit file:// vorweg kenne ich eigentlich nur von graphischen Filemanagern. Keine Ahnung wo das bei dir herkommt.
        ich hab diesen Teil mal abgetrennt.
        Ergibt ja keinen Sinn das an einen als [gelöst] markierten Thread anzuhängen.
        @arniworx Bitte den provisorischen Threadtitel anpassen
        • A arniworx
          moin!
          bei mir kommt nach dem js-controller update von V5.0.19 auf V7.0.3 auch die meldung in einer endlosschleife:
          uncaught exception: Could not determine controller directory
          ich hatte das gleiche problem schon beim update auf V6.x und bin deswegen dann erstmal bei der V5.0.19 geblieben.
          vielleicht hat jemand eine idee, was da der grund sein könnte.
          vielen dank schonmal
          iob diag kurzform:
                                  v.2024-10-19
           Static hostname: vm01
                 Icon name: computer-vm
                   Chassis: vm
            Virtualization: vmware
          Operating System: Ubuntu 22.04.5 LTS
                    Kernel: Linux 5.15.0-126-generic
              Architecture: x86-64
           Hardware Vendor: VMware, Inc.
            Hardware Model: VMware Virtual Platform
          Installation:           vmware
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          Recommended versions are nodejs  and npm
          nodeJS installation is correct
          MEMORY:
          Mem:            7.9G        777M        4.5G        7.0M        2.7G        6.9G
          Swap:           1.0G          0B        1.0G
          Total:          9.0G        777M        5.5G
          Active iob-Instances:   1
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.3
                                  admin                   7.4.2
          ioBroker Status:        iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
            system.adapter.admin.0                  : admin                 : vm01                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : vm01                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                10688
          States:                 151231
          Size of iob-Database:
          13M     /opt/iobroker/iobroker-data/objects.jsonl
          11M     /opt/iobroker/iobroker-data/objects.json.broken
          8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
          8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
          34M     /opt/iobroker/iobroker-data/states.json.migrated
          34M     /opt/iobroker/iobroker-data/states.json.bak.migrated
          32M     /opt/iobroker/iobroker-data/states.jsonl
          0       /opt/iobroker/iobroker-data/states.json.broken
          Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
          und dann hier noch mal in lang:
          Script v.2024-10-19
          *** BASE SYSTEM ***
                   Chassis: vm
          OS is similar to: debian
          model name      : Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
          Docker          : false
          Virtualization  : vmware
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           09:26:05 up 18 min,  2 users,  load average: 0.64, 0.58, 0.47
          CPU threads: 12
          *** LIFE CYCLE STATUS ***
          *** TIME AND TIMEZONES ***
                         Local time: Tue 2024-11-26 09:26:05 CET
                     Universal time: Tue 2024-11-26 08:26:05 UTC
                           RTC time: Tue 2024-11-26 08:26:05
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          arno
          DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
          JAVA_HOME=/usr/lib/jvm/java-8-oracle
          HOME=/home/arno
          GROUPS=arno adm cdrom sudo dip plugdev sambashare lpadmin iobroker
          js-controller is not running
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.9G        798M        4.3G        7.0M        2.8G        6.8G
          Swap:           1.0G          0B        1.0G
          Total:          9.0G        798M        5.4G
                   7935 M total memory
                    799 M used memory
                   1646 M active memory
                   1418 M inactive memory
                   4343 M free memory
                    691 M buffer memory
                   2101 M swap cache
                   1021 M total swap
                      0 M used swap
                   1021 M free swap
          top - 09:26:05 up 18 min,  2 users,  load average: 0.64, 0.58, 0.47
          Tasks: 283 total,   1 running, 282 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.5 us,  0.5 sy,  0.0 ni, 99.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7935.4 total,   4343.9 free,    798.9 used,   2792.6 buff/cache
          MiB Swap:   1022.0 total,   1022.0 free,      0.0 used.   6830.7 avail Mem
          *** FAILED SERVICES ***
            UNIT              LOAD   ACTIVE SUB    DESCRIPTION
          * iobroker.service  loaded failed failed ioBroker Server
          * tftpd-hpa.service loaded failed failed LSB: HPA's tftp server
          2 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                               Type   Size  Used Avail Use% Mounted on
          tmpfs                                    tmpfs  794M  2.6M  791M   1% /run
          /dev/sda1                                ext4    78G   40G   34G  54% /
          tmpfs                                    tmpfs  3.9G     0  3.9G   0% /dev/shm
          tmpfs                                    tmpfs  5.0M     0  5.0M   0% /run/lock
          /dev/sdb1                                ext4    59G   12G   45G  21% /mnt/hd1
          tmpfs                                    tmpfs  3.9G     0  3.9G   0% /run/qemu
          store01.worxnet.localnet:/volume1/shares nfs     13T  6.0T  6.3T  49% /mnt/autofs/store01_vol1_nfs
          tmpfs                                    tmpfs  794M     0  794M   0% /run/user/1000
          [Tue Nov 26 09:07:47 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          [Tue Nov 26 09:07:47 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
          [Tue Nov 26 09:07:48 2024] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
          Show mounted filesystems:
          TARGET                         SOURCE                                   FSTYPE OPTIONS
          /                              /dev/sda1                                ext4   rw,relatime,errors=remount-ro
          |-/mnt/hd1                     /dev/sdb1                                ext4   rw,relatime
          `-/mnt/autofs/store01_vol1_nfs store01.worxnet.localnet:/volume1/shares nfs    rw,relatime,vers=3,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.178.240,mountvers=3,mountport=892,mountproto=udp,local_lock=none,addr=192.168.178.240
          /var:
          1.4G    /var/
          632M    /var/cache
          625M    /var/lib
          359M    /var/lib/apt/lists
          359M    /var/lib/apt
          Archived and active journals take up 48.0M in the file system.
          /opt/iobroker/backups:
          383M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.8G    /opt/iobroker/iobroker-data/
          1009M   /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.6964fae2.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.9~dfsg-1ubuntu3.6 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                  500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
               12.22.9~dfsg-1ubuntu3 500
                  500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          vm01                vm01 (version: 7.0.3, hostname: vm01          , alive, uptime: 2)
          Core adapters versions
          js-controller:  7.0.3
          admin:          7.4.2
          javascript:     8.8.3
          nodejs modules from github:     1
          |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
          Adapter State
            system.adapter.alexa2.0                 : alexa2                : vm01                                     -  enabled
            system.adapter.email.0                  : email                 : vm01                                     -  enabled
            system.adapter.enigma2.0                : enigma2               : vm01                                     - disabled
            system.adapter.fritzdect.0              : fritzdect             : vm01                                     -  enabled
            system.adapter.history.0                : history               : vm01                                     -  enabled
            system.adapter.hm-rega.0                : hm-rega               : vm01                                     -  enabled
            system.adapter.hm-rpc.0                 : hm-rpc                : vm01                                     -  enabled, port: 0
            system.adapter.hm-rpc.1                 : hm-rpc                : vm01                                     -  enabled, port: 0
            system.adapter.hm-rpc.2                 : hm-rpc                : vm01                                     - disabled, port: 0
            system.adapter.hue.0                    : hue                   : vm01                                     -  enabled, port: 80
            system.adapter.ical.0                   : ical                  : vm01                                     -  enabled
            system.adapter.iot.0                    : iot                   : vm01                                     -  enabled
            system.adapter.javascript.0             : javascript            : vm01                                     -  enabled
            system.adapter.netatmo.0                : netatmo               : vm01                                     -  enabled
            system.adapter.nina.0                   : nina                  : vm01                                     -  enabled
            system.adapter.nut.0                    : nut                   : vm01                                     -  enabled
            system.adapter.openweathermap.0         : openweathermap        : vm01                                     - disabled
            system.adapter.scenes.0                 : scenes                : vm01                                     -  enabled
            system.adapter.simple-api.0             : simple-api            : vm01                                     -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sonos.0                  : sonos                 : vm01                                     -  enabled
            system.adapter.telegram.0               : telegram              : vm01                                     -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : vm01                                     -  enabled
            system.adapter.vis-2.0                  : vis-2                 : vm01                                     -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : vm01                                     -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : vm01                                     -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : vm01                                     -  enabled
            system.adapter.vis-players.0            : vis-players           : vm01                                     -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : vm01                                     -  enabled
            system.adapter.vis.0                    : vis                   : vm01                                     -  enabled
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : vm01                                     -  enabled
          + instance is alive
          ioBroker-Repositories
          │ (index) │ name      │ url        │ auto upgrade │
          │ 0       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
          │ 1       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
          │ 2       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
          │ 3       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 7.4.2    , installed 7.4.2
          Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
          Adapter    "email"        : 1.3.1    , installed 1.3.1
          Adapter    "enigma2"      : 2.2.1    , installed 2.2.1
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "hue"          : 3.13.1   , installed 3.13.1
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.4.3    , installed 3.4.3
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.3    , installed 7.0.3
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "nina"         : 0.0.26   , installed 0.0.26
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "signifylights": 0.4.2    , installed 0.4.2
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "telegram"     : 3.9.0    , installed 3.9.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "vis-2"        : 2.10.8   , installed 2.10.8
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "web"          : 6.3.1    , installed 6.3.1
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Objects and States
          Objects:        10688
          States:         151231
          Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
          Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
          Hit:3 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:41587           0.0.0.0:*               LISTEN      0          1024       925/rpc.mountd
          tcp        0      0 0.0.0.0:554             0.0.0.0:*               LISTEN      0          21714      986/MediaServer
          tcp        0      0 0.0.0.0:46055           0.0.0.0:*               LISTEN      0          16918      -
          tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      0          27389      784/node
          tcp        0      0 0.0.0.0:9100            0.0.0.0:*               LISTEN      0          23848      1055/xinetd
          tcp        0      0 0.0.0.0:81              0.0.0.0:*               LISTEN      0          21716      986/MediaServer
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          16940      1056/apache2
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          23582      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13889      930/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      0          16887      927/vsftpd
          tcp        0      0 0.0.0.0:444             0.0.0.0:*               LISTEN      0          21717      986/MediaServer
          tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      0          16942      1056/apache2
          tcp        0      0 0.0.0.0:1688            0.0.0.0:*               LISTEN      0          26869      965/XXXXX
          tcp        0      0 0.0.0.0:34400           0.0.0.0:*               LISTEN      0          17000      957/xteve
          tcp        0      0 0.0.0.0:1935            0.0.0.0:*               LISTEN      0          21715      986/MediaServer
          tcp        0      0 0.0.0.0:10000           0.0.0.0:*               LISTEN      0          21732      986/MediaServer
          tcp        0      0 192.168.178.20:445      0.0.0.0:*               LISTEN      0          27371      1042/smbd
          tcp        0      0 192.168.178.20:139      0.0.0.0:*               LISTEN      0          27372      1042/smbd
          tcp        0      0 0.0.0.0:55817           0.0.0.0:*               LISTEN      0          1004       925/rpc.mountd
          tcp        0      0 0.0.0.0:39465           0.0.0.0:*               LISTEN      0          995        925/rpc.mountd
          tcp        0      0 0.0.0.0:3010            0.0.0.0:*               LISTEN      0          29339      699/node
          tcp        0      0 0.0.0.0:44013           0.0.0.0:*               LISTEN      106        1010       890/rpc.statd
          tcp        0      0 0.0.0.0:23424           0.0.0.0:*               LISTEN      0          23849      1055/xinetd
          tcp        0      0 0.0.0.0:23423           0.0.0.0:*               LISTEN      0          23850      1055/xinetd
          tcp        0      0 0.0.0.0:2223            0.0.0.0:*               LISTEN      0          23847      1055/xinetd
          tcp        0      0 0.0.0.0:2222            0.0.0.0:*               LISTEN      0          23846      1055/xinetd
          tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          14945      -
          tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      117        21654      623/systemd-resolve
          tcp        0      0 127.0.0.1:445           0.0.0.0:*               LISTEN      0          27373      1042/smbd
          tcp        0      0 0.0.0.0:8079            0.0.0.0:*               LISTEN      0          23844      1055/xinetd
          tcp        0      0 0.0.0.0:8089            0.0.0.0:*               LISTEN      0          23843      1055/xinetd
          tcp        0      0 127.0.0.1:139           0.0.0.0:*               LISTEN      0          27374      1042/smbd
          tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      0          14578      713/adb
          tcp        0      0 0.0.0.0:3500            0.0.0.0:*               LISTEN      0          27392      784/node
          tcp        0      0 0.0.0.0:7522            0.0.0.0:*               LISTEN      0          23845      1055/xinetd
          udp        0      0 0.0.0.0:32784           0.0.0.0:*                           0          1001       925/rpc.mountd
          udp        0      0 127.0.0.53:53           0.0.0.0:*                           117        21653      623/systemd-resolve
          udp        0      0 192.168.178.20:68       0.0.0.0:*                           116        21638      586/systemd-network
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          24591      1/init
          udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          29754      874/nmbd
          udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          29753      874/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          29738      874/nmbd
          udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          29756      874/nmbd
          udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          29755      874/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          29739      874/nmbd
          udp        0      0 0.0.0.0:53392           0.0.0.0:*                           0          992        925/rpc.mountd
          udp        0      0 127.0.0.1:642           0.0.0.0:*                           0          16839      890/rpc.statd
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21745      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21744      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21743      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21742      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21740      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21739      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21738      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21737      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21736      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21735      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21734      986/MediaServer
          udp        0      0 0.0.0.0:9000            0.0.0.0:*                           0          21733      986/MediaServer
          udp        0      0 0.0.0.0:42718           0.0.0.0:*                           0          1021       925/rpc.mountd
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21731      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21730      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21729      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21728      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21727      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21726      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21725      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21724      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21723      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21722      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21721      986/MediaServer
          udp        0      0 0.0.0.0:10000           0.0.0.0:*                           0          21720      986/MediaServer
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           0          13902      957/xteve
          udp        0      0 0.0.0.0:44062           0.0.0.0:*                           0          16917      -
          udp        0      0 0.0.0.0:57097           0.0.0.0:*                           106        16864      890/rpc.statd
          2024-11-26 09:09:59.241  - info: host.vm01 stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
          2024-11-26 09:09:59.241  - info: host.vm01 stopInstance system.adapter.vis-players.0 (force=false, process=false)
          2024-11-26 09:09:59.242  - info: host.vm01 stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
          2024-11-26 09:09:59.242  - info: host.vm01 stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
          2024-11-26 09:09:59.242  - info: host.vm01 stopInstance system.adapter.vis-2.0 (force=false, process=false)
          2024-11-26 09:09:59.242  - info: host.vm01 stopInstance system.adapter.vis.0 (force=false, process=false)
          2024-11-26 09:09:59.251  - info: telegram.0 (1951) Got terminate signal TERMINATE_YOURSELF
          2024-11-26 09:09:59.251  - info: javascript.0 (1925) Got terminate signal TERMINATE_YOURSELF
          2024-11-26 09:09:59.253  - info: admin.0 (1627) Got terminate signal TERMINATE_YOURSELF
          2024-11-26 09:09:59.254  - info: javascript.0 (1925) terminating
          2024-11-26 09:09:59.254  - info: javascript.0 (1925) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-11-26 09:09:59.253  - info: admin.0 (1627) terminating http server on port 8081
          2024-11-26 09:09:59.254  - info: admin.0 (1627) terminating
          2024-11-26 09:09:59.254  - info: admin.0 (1627) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-11-26 09:09:59.326  - info: host.vm01 stopInstance system.adapter.admin.0 send kill signal
          2024-11-26 09:09:59.326  - info: host.vm01 stopInstance system.adapter.email.0 send kill signal
          2024-11-26 09:09:59.326  - info: host.vm01 stopInstance system.adapter.javascript.0 send kill signal
          2024-11-26 09:09:59.326  - info: host.vm01 stopInstance system.adapter.telegram.0 send kill signal
          2024-11-26 09:09:59.752  - info: telegram.0 (1951) terminating
          2024-11-26 09:09:59.752  - info: javascript.0 (1925) terminating
          2024-11-26 09:09:59.753  - info: telegram.0 (1951) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-11-26 09:09:59.755  - info: admin.0 (1627) terminating
          2024-11-26 09:09:59.795  - info: host.vm01 instance system.adapter.email.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-11-26 09:09:59.845  - info: host.vm01 instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-11-26 09:09:59.846  - info: host.vm01 instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          @arniworx sagte in Could not determine controller directory:
          v7 ist noch im Betastadium
          wenn aber
          existierte, wird die Fehlersuche jetzt möglicherweise durch andere überlagernde Issues von v7 erschwert.
          sehe ich das richtig, dass du unter VM-Ware eine Ubuntu VM betreibst?
          irgendwie funktioniert das Skript auch nicht richtig, da fehlt was
            wenn aber
            arniworx
            schrieb am zuletzt editiert von arniworx
            das kommt in dauerschleife (vorhin ging nur noch ein screenshot, sorry)
            2024-11-26 13:16:20.271	info	stopInstance system.adapter.admin.0 (force=false, process=true)
            2024-11-26 13:16:20.270	error	Error: Could not determine controller directory at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11) at Module.getAdapterDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1306:37) at startInstance (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:3224:30)
            2024-11-26 13:16:20.270	error	uncaught exception: Could not determine controller directory
            ja, "Ubuntu VM" unter ESXi ist richtig, ist das nicht erlaubt?
            was meinst du mit: "irgendwie funktioniert das Skript auch nicht richtig, da fehlt was" ?
            • A arniworx
              ich sammle nur Fakten, die nicht erwähnt wurden.
              fehlt was" ?
              die empfohlenen Versionen gehören da noch rein.
              So ergibt der Satz keinen Sinn
                fehlt was" ?
                @homoran sagte in Could not determine controller directory:
                Dann kann 'iob diag' die entsprechenden DPs nicht auslesen. Warum auch immer.
                  @thomas-braun sagte in Could not determine controller directory:
                  richtig!
                  Deswegen
                  Warum auch immer.
                  Da klemmt dan wohl noch mehr, deswegen der Blick auf
                  Vielleicht wird da mal wieder eine Sonderlocke geklöppelt
                    richtig!
                    Deswegen
                    Warum auch immer.
                    arniworx
                    @homoran said in Could not determine controller directory:
                    ...was das wohl heisst?
                    in der laufenden umgebung (V5.0.19), steht auch etwas mehr im summary von "iob diag":
                                            v.2024-10-19
                             Chassis: vm
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                1000
                    Pending OS-Updates:     1
                    Pending iob updates:    1
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    Recommended versions are nodejs 20.18.1 and npm 10.8.2
                    MEMORY:
                    Mem:            7.9G        582M        3.1G        8.0M        4.3G        7.0G
                    Swap:           1.0G          0B        1.0G
                    Total:          9.0G        582M        4.1G
                    ioBroker Core:          js-controller           5.0.19
                                            admin                   7.4.2
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                10663
                    States:                 151265
                    19M     /opt/iobroker/iobroker-data/objects.jsonl
                    • A arniworx
                                              v.2024-10-19
                               Chassis: vm
                      Kernel:                 x86_64
                      Userland:               64 bit
                      User-ID:                1000
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      MEMORY:
                      Swap:           1.0G          0B        1.0G
                                              admin                   7.4.2
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                10663
                      States:                 151265
                      war für @Thomas-Braun gedacht.
                      Ubuntu stammt zwar von Debian ab, macht aber immer wieder das ein oder andere anders.
                      Und ob das auch bei VM Ware gilt weiß ich nicht.
                      Wenn du das ausschließen kannst, dass dieses Verhalten vom OS oder Hypervisor bedingt ist, müssen wir es bei "dir" suchen.
                      Also einen "Fehler" an/bei deiner Installation
                        arniworx
                        ok, das mit dem "ausschliessen" ist immer so eine sache. ich würde allerdings sagen, dass ich ziemlich (~90%) sicher bin, dass es an meiner ioBroker installation liegt.
                        also lieber erstmal haupt-augenmerk darauf, ob mit node, berechtigungen, etc. alles stimmt, da bin ich mir nicht so sicher. hab ihr eine idee, wo ich da anfangen könnte?
                        • A arniworx
                          CodierknechtC Offline
                          Codierknecht
                          In den 8 Stunden in denen hier diskutiert wird hätte man vermutlich "mal eben" 'ne neue VM (mit Debian 12) aufgesetzt, ioBroker neu installiert und ein Backup wiederhergestellt.
                          Aber das wäre ja keine Herausforderung 😁
                          HmIP|ZigBee|Tasmota|Unifi
                          Zabbix Certified Specialist
                          • CodierknechtC Codierknecht
                            arniworx
                            @codierknecht
                            hast ja recht, hat 15 min gedauert.
                            ich dachte nur, es gäbe eine einfache lösung um die installation zu erhalten.
                            fehler nicht gefunden - wissenschaftlich betrachet, ein kompletter fehlschlag ;-)
                            vielen dank an @homoran und @thomas-braun
                            kann geschlossen werden
                            • A arniworx
                              @codierknecht
                              schade!
                              Dieser Fehler ist mWn zum ersten Mal aufgetreten. Da wäre es für später auftretende gleich gelagerte Fälle natürlich schön gewesen die Ursache zu kennen.
                                schade!
                                arniworx
                                finde ich auch. ich hatte nur keine idee, wo ich anfangen sollte zu suchen.
                                ich habe jetzt nur das alte verzeichnis umbenannt (in /opt/iobroker-) und ioBroker neu installiert (in /opt/iobroker)
                                danach das backup eingespielt und alles lief direkt.
                                demnach ist es sehr warscheinlich, dass es nicht an der umgebung (ubuntu, vmware, etc.) lag.
                                wenn ihr bock habt, kann ich die alte installation wieder scharfschalten und weiter nach dem fehler suchen.
                                alleine hab ich allerdings zu wenig ahnung 😐
                                • A arniworx
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @foxriver76
                                  Wenn dann könntest wahrscheinlich nur du da schaun ob was im js-controller zu verbessern wäre.
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                    tetzlav
                                    ich habe ein ähnliches Problem mit meiner Installation. Nach ein paar Updates von Adaptern stirbt der iobroker einfach immer wieder mit:
                                    2024-12-03 14:30:01.024  - error: host.omv Error: Could not determine controller directory
                                        at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
                                        at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3392:22)
                                        at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2863:91)
                                        at listOnTimeout (node:internal/timers:569:17)
                                        at processTimers (node:internal/timers:512:7)
                                    Ich hatte letzte Woche ein Update auf node v20 gewagt und bin auf das gleiche Problem gestoßen. Das Backup der /opt/iobroker/ directory lief dann wieder wunderbar, bis ich heute wieder ein paar Adapter Updates installieren wollte. Dann war igendwann einfach der js-controller weg (npm not found module). Das habe ich mit
                                    sudo -H -u iobroker npm install iobroker.js-controller --verbose
                                    wieder hergestellt. Und jetzt startet der iobroker normal durch bis er mit der Fehlermeldung oben gleich wieder wegstirbt.
                                    Ideen?
                                    Beste Grüße
                                    //tetzlav
                                    iob diag:
                                                            v.2024-10-19
                                       Static hostname: omv
                                             Icon name: computer-server
                                               Chassis: server
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.0-0.deb11.21-amd64
                                    Kernel:                 x86_64
                                    Userland:               64 bit
                                    User-ID:                1000
                                    Pending iob updates:    15
                                    /usr/bin/nodejs         v18.20.5
                                    /usr/bin/node           v18.20.5
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    Recommended versions are nodejs 18.20.5 and npm 10.8.2
                                    MEMORY:
                                    Mem:             31G         13G        8.2G        238M         10G         18G
                                    Swap:            20G        1.9G         18G
                                    Total:           52G         15G         26G
                                    ioBroker Core:          js-controller           6.0.11
                                                            admin                   6.17.3
                                    Objects type: jsonl
                                    States  type: jsonl
                                      system.adapter.admin.0                  : admin                 : omv                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      system.adapter.web.0                    : web                   : omv                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                      system.adapter.web.1                    : web                   : omv                                      - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                                    Objects:                25931
                                    States:                 19571
                                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                                    12M     /opt/iobroker/iobroker-data/objects.json.migrated
                                    12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    8.6M    /opt/iobroker/iobroker-data/states.jsonl
                                    2.9M    /opt/iobroker/iobroker-data/states.json.migrated
                                    2.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                    Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                                    • T tetzlav
                                      Ideen?
                                      Beste Grüße
                                      //tetzlav
                                      iob diag:
                                                              v.2024-10-19
                                                 Chassis: server
                                      Kernel:                 x86_64
                                      Userland:               64 bit
                                      User-ID:                1000
                                      /usr/bin/npm            10.8.2
                                      /usr/bin/npx            10.8.2
                                      MEMORY:
                                      Swap:            20G        1.9G         18G
                                      Total:           52G         15G         26G
                                                              admin                   6.17.3
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Objects:                25931
                                      States:                 19571
                                      @tetzlav
                                      Zunächst würde ich das alles in die Gegenwart heben.
                                      nodejs, die 15 iob-Updates und das Betriebssystem.
                                      • T tetzlav
                                        Ideen?
                                        Beste Grüße
                                        //tetzlav
                                        iob diag:
        v.2024-10-19
                                                   Chassis: server
                                        Kernel:                 x86_64
                                        Userland:               64 bit
                                        User-ID:                1000
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        MEMORY:
                                        Swap:            20G        1.9G         18G
                                        Total:           52G         15G         26G
        admin                   6.17.3
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Objects:                25931
                                        States:                 19571
                                        mcm1957M Offline
                                        mcm1957M Offline
                                        mcm1957
                                        @tetzlav
                                        Und bitte iob diag in der LANGfassung damit man auch sieht welche Adapter du in welcher Version installiert hast.
                                          tetzlav
                                          @thomas-braun said in Could not determine controller directory:
                                          @tetzlav
                                          Vielen Dank für die Antwort. Das komplette upgrade würde ich ja auch sehr gerne machen, aber das Debian ist noch oldstable und darauf laufen noch einige andere Dienste. Erfahrungsgemäß muß man bei/nach einem Betriebssystem upgrade wieder einiges gerade ziehen. Das ist eher Arbeit für die Weihnachtsfeiertage...
                                          Und nodejs v20 + iob-Updates hatte ich ja letzte Woche schon probiert, das lief aber in den o.g. Fehler, weshalb ich das Backup wieder hersgestellt habe. Das Update habe ich immer möglichst "sauber" als user via iob
                                          iob update
                                          iob upgrade -y
                                          iob nodejs-update
                                          iob fix
                                          etc. und generell immer möglichst nach Anleitung gemacht.
                                          Ich hatte gehofft euch gibt die Fehlermeldung einen Hinweis auf eine möglichst konkrete Ursache, ohne "auf Verdacht" einfach mal das gesamte System upzudaten, was einen ganzen Rattenschwanz an side issues mit sich bringt.
                                          Das iobroker System ist mittlerweile >5 Jahre im Einsatz und ich konnte immer recht problemlos alle updates installieren. Mittlerweile hängt nun unser sehr umfangreich konfiguriertes, gesamtes "smartes" Haus daran. Bei einem Ausfall bekommt meine Frau wieder schlechte Laune. Deshalb bin ich mit größeren Updates immer etwas vorsichtiger... ;)
                                          Evtl. schiebe ich den iobroker mal in eine virtuelle Maschine. Das macht das versions handling etwas leichter. Docker mag ich nicht sonderlich, das frisst zu viele Ressourcen.
                                          Wie kann ich möglichst in der console (und ohne BackItUp) ein Sicherung der gesamten iobroker Konfiguration machen und diese nach der Neuistallation von iobroker in einer virtuellen Maschine wieder herstellen?
