  4. Could not determine controller directory
    1.0k
    6.1k
31 Beiträge 6 Kommentatoren 4.5k Aufrufe 5 Beobachtet
  • A arniworx
    @homoran said in Could not determine controller directory:
    Vielleicht wird da mal wieder eine Sonderlocke geklöppelt
    ...was das wohl heisst?
    in der laufenden umgebung (V5.0.19), steht auch etwas mehr im summary von "iob diag":
                            v.2024-10-19
     Static hostname: vm01
           Icon name: computer-vm
             Chassis: vm
      Virtualization: vmware
    Operating System: Ubuntu 22.04.5 LTS
              Kernel: Linux 5.15.0-126-generic
        Architecture: x86-64
     Hardware Vendor: VMware, Inc.
      Hardware Model: VMware Virtual Platform
    Installation:           vmware
    Kernel:                 x86_64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Pending OS-Updates:     1
    Pending iob updates:    1
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    Recommended versions are nodejs 20.18.1 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            7.9G        582M        3.1G        8.0M        4.3G        7.0G
    Swap:           1.0G          0B        1.0G
    Total:          9.0G        582M        4.1G
    Active iob-Instances:   1
    Active repo(s): beta
    ioBroker Core:          js-controller           5.0.19
                            admin                   7.4.2
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : vm01                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.web.0                    : web                   : vm01                                     -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                10663
    States:                 151265
    Size of iob-Database:
    19M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/objects.json.broken
    8.0M    /opt/iobroker/iobroker-data/objects.json.migrated
    8.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
    34M     /opt/iobroker/iobroker-data/states.json.migrated
    34M     /opt/iobroker/iobroker-data/states.json.bak.migrated
    32M     /opt/iobroker/iobroker-data/states.jsonl
    0       /opt/iobroker/iobroker-data/states.json.broken
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    HomoranH Offline
    HomoranH Offline
    @arniworx sagte in Could not determine controller directory:
    war für @Thomas-Braun gedacht.
    Ubuntu stammt zwar von Debian ab, macht aber immer wieder das ein oder andere anders.
    Und ob das auch bei VM Ware gilt weiß ich nicht.
    Wenn du das ausschließen kannst, dass dieses Verhalten vom OS oder Hypervisor bedingt ist, müssen wir es bei "dir" suchen.
    Also einen "Fehler" an/bei deiner Installation
      arniworx
      ok, das mit dem "ausschliessen" ist immer so eine sache. ich würde allerdings sagen, dass ich ziemlich (~90%) sicher bin, dass es an meiner ioBroker installation liegt.
      also lieber erstmal haupt-augenmerk darauf, ob mit node, berechtigungen, etc. alles stimmt, da bin ich mir nicht so sicher. hab ihr eine idee, wo ich da anfangen könnte?
      • A arniworx
        CodierknechtC Offline
        Codierknecht
        In den 8 Stunden in denen hier diskutiert wird hätte man vermutlich "mal eben" 'ne neue VM (mit Debian 12) aufgesetzt, ioBroker neu installiert und ein Backup wiederhergestellt.
        Aber das wäre ja keine Herausforderung 😁
        HmIP|ZigBee|Tasmota|Unifi
        Zabbix Certified Specialist
        • CodierknechtC Codierknecht
          arniworx
          @codierknecht
          hast ja recht, hat 15 min gedauert.
          ich dachte nur, es gäbe eine einfache lösung um die installation zu erhalten.
          fehler nicht gefunden - wissenschaftlich betrachet, ein kompletter fehlschlag ;-)
          vielen dank an @homoran und @thomas-braun
          kann geschlossen werden
          • A arniworx
            @codierknecht
            HomoranH Offline
            HomoranH Offline
            schade!
            Dieser Fehler ist mWn zum ersten Mal aufgetreten. Da wäre es für später auftretende gleich gelagerte Fälle natürlich schön gewesen die Ursache zu kennen.
              schade!
              arniworx
              finde ich auch. ich hatte nur keine idee, wo ich anfangen sollte zu suchen.
              ich habe jetzt nur das alte verzeichnis umbenannt (in /opt/iobroker-) und ioBroker neu installiert (in /opt/iobroker)
              danach das backup eingespielt und alles lief direkt.
              demnach ist es sehr warscheinlich, dass es nicht an der umgebung (ubuntu, vmware, etc.) lag.
              wenn ihr bock habt, kann ich die alte installation wieder scharfschalten und weiter nach dem fehler suchen.
              alleine hab ich allerdings zu wenig ahnung 😐
              • A arniworx
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                @foxriver76
                Wenn dann könntest wahrscheinlich nur du da schaun ob was im js-controller zu verbessern wäre.
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                  tetzlav
                  ich habe ein ähnliches Problem mit meiner Installation. Nach ein paar Updates von Adaptern stirbt der iobroker einfach immer wieder mit:
                  2024-12-03 14:30:01.024  - error: host.omv Error: Could not determine controller directory
                      at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1853:11)
                      at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3392:22)
                      at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2863:91)
                      at listOnTimeout (node:internal/timers:569:17)
                      at processTimers (node:internal/timers:512:7)
                  Ich hatte letzte Woche ein Update auf node v20 gewagt und bin auf das gleiche Problem gestoßen. Das Backup der /opt/iobroker/ directory lief dann wieder wunderbar, bis ich heute wieder ein paar Adapter Updates installieren wollte. Dann war igendwann einfach der js-controller weg (npm not found module). Das habe ich mit
                  sudo -H -u iobroker npm install iobroker.js-controller --verbose
                  wieder hergestellt. Und jetzt startet der iobroker normal durch bis er mit der Fehlermeldung oben gleich wieder wegstirbt.
                  Ideen?
                  Beste Grüße
                  //tetzlav
                  iob diag:
                                          v.2024-10-19
                     Static hostname: omv
                           Icon name: computer-server
                             Chassis: server
                    Operating System: Debian GNU/Linux 11 (bullseye)
                              Kernel: Linux 6.1.0-0.deb11.21-amd64
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1000
                  Boot Target:            multi-user.target
                  Pending OS-Updates:     0
                  Pending iob updates:    15
                  /usr/bin/nodejs         v18.20.5
                  /usr/bin/node           v18.20.5
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  Recommended versions are nodejs 18.20.5 and npm 10.8.2
                  MEMORY:
                  Mem:             31G         13G        8.2G        238M         10G         18G
                  Swap:            20G        1.9G         18G
                  Total:           52G         15G         26G
                  Upgrade policy: none
                  ioBroker Core:          js-controller           6.0.11
                                          admin                   6.17.3
                  Objects type: jsonl
                  States  type: jsonl
                    system.adapter.admin.0                  : admin                 : omv                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    system.adapter.web.0                    : web                   : omv                                      -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    system.adapter.web.1                    : web                   : omv                                      - disabled, port: 8085, bind: 0.0.0.0, run as: admin
                  Objects:                25931
                  States:                 19571
                  26M     /opt/iobroker/iobroker-data/objects.jsonl
                  12M     /opt/iobroker/iobroker-data/objects.json.migrated
                  12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
                  8.6M    /opt/iobroker/iobroker-data/states.jsonl
                  2.9M    /opt/iobroker/iobroker-data/states.json.migrated
                  2.9M    /opt/iobroker/iobroker-data/states.json.bak.migrated
                  Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                  Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
                  • T tetzlav
                    Ideen?
                    Beste Grüße
                    //tetzlav
                    iob diag:
                                            v.2024-10-19
                               Chassis: server
                    Kernel:                 x86_64
                    Userland:               64 bit
                    User-ID:                1000
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    MEMORY:
                    Swap:            20G        1.9G         18G
                    Total:           52G         15G         26G
                                            admin                   6.17.3
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                25931
                    States:                 19571
                    @tetzlav
                    Zunächst würde ich das alles in die Gegenwart heben.
                    nodejs, die 15 iob-Updates und das Betriebssystem.
                    • T tetzlav
                      Ideen?
                      Beste Grüße
                      //tetzlav
                      iob diag:
                                              v.2024-10-19
                                 Chassis: server
                      Kernel:                 x86_64
                      Userland:               64 bit
                      User-ID:                1000
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      MEMORY:
                      Swap:            20G        1.9G         18G
                      Total:           52G         15G         26G
                                              admin                   6.17.3
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                25931
                      States:                 19571
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @tetzlav
                      Und bitte iob diag in der LANGfassung damit man auch sieht welche Adapter du in welcher Version installiert hast.
                        tetzlav
                        @thomas-braun said in Could not determine controller directory:
                        @tetzlav
                        Vielen Dank für die Antwort. Das komplette upgrade würde ich ja auch sehr gerne machen, aber das Debian ist noch oldstable und darauf laufen noch einige andere Dienste. Erfahrungsgemäß muß man bei/nach einem Betriebssystem upgrade wieder einiges gerade ziehen. Das ist eher Arbeit für die Weihnachtsfeiertage...
                        Und nodejs v20 + iob-Updates hatte ich ja letzte Woche schon probiert, das lief aber in den o.g. Fehler, weshalb ich das Backup wieder hersgestellt habe. Das Update habe ich immer möglichst "sauber" als user via iob
                        iob update
                        iob upgrade -y
                        iob nodejs-update
                        iob fix
                        etc. und generell immer möglichst nach Anleitung gemacht.
                        Ich hatte gehofft euch gibt die Fehlermeldung einen Hinweis auf eine möglichst konkrete Ursache, ohne "auf Verdacht" einfach mal das gesamte System upzudaten, was einen ganzen Rattenschwanz an side issues mit sich bringt.
                        Das iobroker System ist mittlerweile >5 Jahre im Einsatz und ich konnte immer recht problemlos alle updates installieren. Mittlerweile hängt nun unser sehr umfangreich konfiguriertes, gesamtes "smartes" Haus daran. Bei einem Ausfall bekommt meine Frau wieder schlechte Laune. Deshalb bin ich mit größeren Updates immer etwas vorsichtiger... ;)
                        Evtl. schiebe ich den iobroker mal in eine virtuelle Maschine. Das macht das versions handling etwas leichter. Docker mag ich nicht sonderlich, das frisst zu viele Ressourcen.
                        Wie kann ich möglichst in der console (und ohne BackItUp) ein Sicherung der gesamten iobroker Konfiguration machen und diese nach der Neuistallation von iobroker in einer virtuellen Maschine wieder herstellen?
                        • T tetzlav
                          @tetzlav
                          iob update
                          iob upgrade -y
                          iob nodejs-update
                          iob fix
                          @tetzlav sagte in Could not determine controller directory:
                          Auch für diese Dienste ist die Basis seit 111 Tagen abgekündigt.
                          [thomas@roamer ~]$ debian-distro-info --unsupported -yeol -f | grep Bullseye
                          Debian 11 "Bullseye" -111
                          • mcm1957M mcm1957
                            @tetzlav
                            tetzlav
                            @mcm1957 said in Could not determine controller directory:
                            @tetzlav
                            Ein paar uninteressante bzw. zu sensible Infos habe ich rausgenommen.
                            Script v.2024-10-19
                            *** BASE SYSTEM ***
                                       Chassis: server
                            OS is similar to:
                            model name      : Intel(R) Core(TM) i3-7320 CPU @ 4.10GHz
                            Docker          : false
                            Virtualization  : none
                            Kernel          : x86_64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             16:57:03 up 4 days,  1:14,  5 users,  load average: 2.20, 2.17, 1.95
                            CPU threads: 4
                            *** LIFE CYCLE STATUS ***
                            *** TIME AND TIMEZONES ***
                                           Local time: Tue 2024-12-03 16:57:04 CET
                                       Universal time: Tue 2024-12-03 15:57:04 UTC
                                             RTC time: Tue 2024-12-03 15:57:04
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            tetzlav
                            HOME=/home/tetzlav
                            GROUPS=users sudo ssh sambashare davfs2 docker tetzlav bilder musik iobroker
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker tty dialout audio video plugdev redis bluetooth
                            *** DISPLAY-SERVER SETUP ***
                            Desktop:
                            Terminal:
                            *** MEMORY ***
                            Mem:             31G         16G        1.3G        233M         14G         15G
                            Swap:            20G        2.1G         18G
                            Total:           52G         18G         19G
                            Active iob-Instances:   35
                                    31921 M total memory
                                    16341 M used memory
                                     9492 M active memory
                                    17568 M inactive memory
                                     1326 M free memory
                                     2280 M buffer memory
                                    11973 M swap cache
                                    20479 M total swap
                                     2058 M used swap
                                    18421 M free swap
                            top - 16:57:04 up 4 days,  1:14,  5 users,  load average: 2.20, 2.17, 1.95
                            Tasks: 1412 total,   2 running, 1408 sleeping,   0 stopped,   2 zombie
                            %Cpu(s):  3.5 us,  7.0 sy,  0.0 ni, 88.4 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
                            MiB Mem :  31921.3 total,   1326.1 free,  16341.0 used,  14254.1 buff/cache
                            MiB Swap:  20480.0 total,  18422.0 free,   2058.0 used.  15470.5 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** DMESG CRITICAL ERRORS ***
                            No critical errors detected
                            *** FILESYSTEM ***
                            /var:
                            26G     /var/
                            14G     /var/lib
                            11G     /var/lib/mysql-data
                            6.2G    /var/www
                            5.3G    /var/www/nextcloud
                            Archived and active journals take up 208.0M in the file system.
                            /opt/iobroker/backups:
                            23M     /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            1.4G    /opt/iobroker/iobroker-data/
                            993M    /opt/iobroker/iobroker-data/files
                            617M    /opt/iobroker/iobroker-data/files/javascript.admin
                            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                            34M     /opt/iobroker/iobroker-data/objects.jsonl
                            26M     /opt/iobroker/iobroker-data/states.jsonl
                            26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                            26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                            USB-Devices by-id:
                            /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A50285BI-if00-port0
                            HINT:
                            Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e89d0a954beed11ac1b642e38a92db5-if00-port0
                            HINT:
                            Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                            /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                            *** NodeJS-Installation ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Installed: 18.20.5-1nodesource1
                              Candidate: 18.20.5-1nodesource1
                              Version table:
                             *** 18.20.5-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                 18.20.4-1nodesource1 1001
                                 18.20.3-1nodesource1 1001
                                 18.20.2-1nodesource1 1001
                                 18.20.1-1nodesource1 1001
                                 18.20.0-1nodesource1 1001
                                 18.19.1-1nodesource1 1001
                                 18.19.0-1nodesource1 1001
                                 18.18.2-1nodesource1 1001
                                 18.18.1-1nodesource1 1001
                                 18.18.0-1nodesource1 1001
                                 18.17.1-1nodesource1 1001
                                 18.17.0-1nodesource1 1001
                                 18.16.1-1nodesource1 1001
                                 18.16.0-1nodesource1 1001
                                 18.15.0-1nodesource1 1001
                                 18.14.2-1nodesource1 1001
                                 18.14.1-1nodesource1 1001
                                 18.14.0-1nodesource1 1001
                                 18.13.0-1nodesource1 1001
                                 18.12.0-1nodesource1 1001
                                 18.11.0-1nodesource1 1001
                                 18.10.0-1nodesource1 1001
                                 18.9.1-1nodesource1 1001
                                 18.9.0-1nodesource1 1001
                                 18.8.0-1nodesource1 1001
                                 18.7.0-1nodesource1 1001
                                 18.6.0-1nodesource1 1001
                                 18.5.0-1nodesource1 1001
                                 18.4.0-1nodesource1 1001
                                 18.3.0-1nodesource1 1001
                                 18.2.0-1nodesource1 1001
                                 18.1.0-1nodesource1 1001
                                 18.0.0-1nodesource1 1001
                                 12.22.12~dfsg-1~deb11u4 500
                                    500 http://deb.debian.org/debian bullseye/main amd64 Packages
                            No problems detected
                            Errors in npm tree: 0
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            omv                 omv (version: 6.0.11, hostname: omv           , alive, uptime: 7322)
                            phoscon             phoscon (version: 6.0.11, hostname: phoscon       , alive, uptime: 7326)
                            zigbee-OG           zigbee-OG (version: 6.0.11, hostname: zigbee-OG     , alive, uptime: 7296)
                            Core adapters versions
                            js-controller:  6.0.11
                            admin:          6.17.3
                            javascript:     8.8.3
                            nodejs modules from github:     7
                            +-- iobroker.connector-local-control@0.0.4 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#af6ca3a95371ad333ec5e967fa33ce251bb87ad3)
                            +-- iobroker.firetv@2.1.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.firetv.git#3175f52430b71cc8d07bbeab3ff9b62da52a7d1c)
                            | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                            +-- iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#5e1839b1adece7fbc92213409f953417a1907475)
                            +-- iobroker.nctalk@0.4.0 (git+ssh://git@github.com/jjqoie/ioBroker.nctalk.git#3686e3ad961797ce65a5174d3262d66e97adf829)
                            +-- iobroker.omada@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#9d0f51a6d77e0b43df24f2b9d31aca4b323fdd55)
                            +-- iobroker.wireless-mbus@0.9.4 (git+ssh://git@github.com/lvogt/ioBroker.wireless-mbus.git#b0b4b1f20930d5a02d97eaed4b235748918b4fa2)
                            Adapter State
                              system.adapter.adb.0                    : adb                   : omv                                      - disabled
                            + system.adapter.admin.0                  : admin                 : omv                                      -  enabled, port: XXXX, bind: 0.0.0.0, run as: admin
                              system.adapter.alias-manager.0          : alias-manager         : omv                                      -  enabled
                              system.adapter.artnet.0                 : artnet                : omv                                      - disabled, port: XXXX
                            + system.adapter.backitup.0               : backitup              : omv                                      -  enabled
                            + system.adapter.broadlink2.0             : broadlink2            : omv                                      -  enabled
                            + system.adapter.bsblan.0                 : bsblan                : omv                                      -  enabled
                              system.adapter.bsblan.1                 : bsblan                : omv                                      - disabled
                              system.adapter.connector-local-control.0: connector-local-control: omv                                      - disabled
                              system.adapter.daswetter.0              : daswetter             : omv                                      -  enabled
                            + system.adapter.device-reminder.0        : device-reminder       : omv                                      -  enabled
                            + system.adapter.device-watcher.0         : device-watcher        : omv                                      -  enabled
                              system.adapter.devices.0                : devices               : omv                                      -  enabled
                              system.adapter.discovery.0              : discovery             : omv                                      - disabled
                              system.adapter.dwd.0                    : dwd                   : omv                                      -  enabled
                            + system.adapter.ebus.0                   : ebus                  : zigbee-OG                                -  enabled
                            + system.adapter.echarts.0                : echarts               : omv                                      -  enabled
                            + system.adapter.email.0                  : email                 : omv                                      -  enabled
                              system.adapter.fhem.0                   : fhem                  : omv                                      - disabled, port: XXXX
                              system.adapter.firetv.0                 : firetv                : omv                                      - disabled
                              system.adapter.flot.0                   : flot                  : omv                                      -  enabled
                            + system.adapter.go-e.0                   : go-e                  : omv                                      -  enabled
                              system.adapter.ham.0                    : ham                   : omv                                      - disabled
                            + system.adapter.hass.0                   : hass                  : omv                                      -  enabled, port: XXXX
                              system.adapter.hyperion_ng.0            : hyperion_ng           : omv                                      - disabled
                              system.adapter.ical.0                   : ical                  : omv                                      -  enabled
                            + system.adapter.influxdb.0               : influxdb              : omv                                      -  enabled, port: XXXX
                              system.adapter.info.0                   : info                  : omv                                      - disabled
                              system.adapter.jarvis.0                 : jarvis                : omv                                      - disabled, port: XXXX, bind: 0.0.0.0, run as: admin
                            + system.adapter.javascript.0             : javascript            : omv                                      -  enabled
                            + system.adapter.knx.0                    : knx                   : omv                                      -  enabled, bind: 192.168.178.4
                              system.adapter.kodi.0                   : kodi                  : omv                                      - disabled, port: XXXX
                              system.adapter.kodi.1                   : kodi                  : omv                                      - disabled, port: XXXX
                              system.adapter.kodi.2                   : kodi                  : omv                                      - disabled, port: XXXX
                              system.adapter.linkeddevices.0          : linkeddevices         : omv                                      - disabled
                              system.adapter.linux-control.0          : linux-control         : omv                                      - disabled
                              system.adapter.midea.0                  : midea                 : omv                                      - disabled
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : omv                                      -  enabled, port: XXXX1
                            + system.adapter.mqtt.0                   : mqtt                  : omv                                      -  enabled, port: XXXX, bind: 0.0.0.0
                            + system.adapter.musiccast.0              : musiccast             : omv                                      -  enabled
                              system.adapter.mytime.0                 : mytime                : omv                                      - disabled
                              system.adapter.nctalk.0                 : nctalk                : omv                                      - disabled, port: XXXX
                            + system.adapter.node-red.0               : node-red              : omv                                      -  enabled, port: XXXX, bind: 192.168.178.4
                            + system.adapter.nut.0                    : nut                   : omv                                      -  enabled
                            + system.adapter.omada.0                  : omada                 : omv                                      -  enabled, port: XXXX
                            + system.adapter.onvif.0                  : onvif                 : omv                                      -  enabled, port: XX, XXXX, XXXX, XXXX, XXXX, XXXX
                            + system.adapter.opendtu.0                : opendtu               : omv                                      -  enabled
                              system.adapter.openknx.0                : openknx               : omv                                      - disabled
                              system.adapter.parser.0                 : parser                : omv                                      - disabled
                              system.adapter.rpi2.0                   : rpi2                  : phoscon                                  - disabled
                              system.adapter.rpi2.1                   : rpi2                  : zigbee-OG                                - disabled
                            + system.adapter.sainlogic.0              : sainlogic             : omv                                      -  enabled, port: XXXX4, bind: 192.168.178.4
                              system.adapter.samsung_tizen.0          : samsung_tizen         : omv                                      - disabled, port: XXXX
                            + system.adapter.scenes.0                 : scenes                : omv                                      -  enabled
                              system.adapter.simple-api.0             : simple-api            : omv                                      - disabled, port: XXXX, bind: 192.168.178.4, run as: admin
                            + system.adapter.smartmeter.0             : smartmeter            : omv                                      -  enabled
                              system.adapter.snmp.0                   : snmp                  : omv                                      - disabled
                              system.adapter.socketio.0               : socketio              : omv                                      - disabled, port: XXXX, bind: 0.0.0.0 (SSL), run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : omv                                      -  enabled, port: XXXX, bind: 192.168.178.4
                              system.adapter.spotify-premium.0        : spotify-premium       : omv                                      - disabled
                              system.adapter.spotify-premium.1        : spotify-premium       : omv                                      - disabled
                              system.adapter.spotify-premium.2        : spotify-premium       : omv                                      - disabled
                            + system.adapter.sql.0                    : sql                   : omv                                      -  enabled, port: XXXX
                              system.adapter.sureflap.0               : sureflap              : omv                                      - disabled
                              system.adapter.systeminfo.0             : systeminfo            : omv                                      - disabled
                            + system.adapter.telegram.0               : telegram              : omv                                      -  enabled, port: XXXX, bind: 0.0.0.0
                            + system.adapter.trashschedule.0          : trashschedule         : omv                                      -  enabled
                              system.adapter.tuya.0                   : tuya                  : omv                                      - disabled
                              system.adapter.vis.0                    : vis                   : omv                                      -  enabled
                            + system.adapter.web.0                    : web                   : omv                                      -  enabled, port: XXXX, bind: 0.0.0.0, run as: admin
                              system.adapter.web.1                    : web                   : omv                                      - disabled, port: XXXX, bind: 0.0.0.0, run as: admin
                              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : omv                                      - disabled
                            + system.adapter.wireless-mbus.0          : wireless-mbus         : omv                                      -  enabled
                            + system.adapter.yamaha.0                 : yamaha                : omv                                      -  enabled
                              system.adapter.yamaha.1                 : yamaha                : omv                                      - disabled
                            + system.adapter.zigbee.0                 : zigbee                : zigbee-OG                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0e89d0a954beed11ac1b642e38a92db5-if00-port0
                            + system.adapter.zigbee.1                 : zigbee                : phoscon                                  -  enabled, port: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0
                              system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : omv                                      - disabled
                              system.adapter.zigbee2mqtt.1            : zigbee2mqtt           : omv                                      - disabled
                            + instance is alive
                            + system.adapter.telegram.0               : telegram              : omv                                      -  enabled, port: 88, bind: 0.0.0.0
                            ioBroker-Repositories
                            │ (index) │   name   │                           url                           │ auto upgrade │
                            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                            Installed ioBroker-Instances
                            Used repository: beta
                            Adapter    "adb"          : 0.0.7    , installed 0.0.7
                            Adapter    "admin"        : 7.4.3    , installed 6.17.3 [Updatable]
                            Adapter    "alias-manager": 2.0.0    , installed 1.2.6  [Updatable]
                            Adapter    "artnet"       : 1.2.2    , installed 1.2.2
                            Adapter    "backitup"     : 3.0.31   , installed 2.9.10 [Updatable]
                            Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                            Adapter    "bsblan"       : 0.3.4    , installed 0.3.4
                            Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
                            Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                            Adapter    "devices"      : 1.1.5    , installed 1.1.5
                            Adapter    "ebus"         : 3.3.8    , installed 3.3.6  [Updatable]
                            Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                            Adapter    "email"        : 1.3.1    , installed 1.3.1
                            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                            Adapter    "firetv"       : 2.1.0    , installed 2.1.0
                            Adapter    "go-e"         : 1.0.41   , installed 1.0.38 [Updatable]
                            Adapter    "ham"          : 5.3.1    , installed 5.3.1
                            Adapter    "hass"         : 1.4.0    , installed 1.4.0
                            Adapter    "hyperion_ng"  : 0.1.23   , installed 0.1.23
                            Adapter    "ical"         : 1.16.1   , installed 1.15.0 [Updatable]
                            Adapter    "iqontrol"     : 3.0.0    , installed 2.3.0  [Updatable]
                            Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.1.8 [Updatable]
                            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                            Controller "js-controller": 7.0.3    , installed 6.0.11 [Updatable]
                            Adapter    "knx"          : 2.0.28   , installed 2.0.28
                            Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                            Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                            Adapter    "linux-control": 1.1.5    , installed 1.1.5
                            Adapter    "midea"        : 0.0.7    , installed 0.1.0
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                            Adapter    "mqtt-client"  : 2.1.0    , installed 2.0.1  [Updatable]
                            Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
                            Adapter    "mytime"       : 1.2.2    , installed 0.7.12 [Updatable]
                            Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                            Adapter    "nut"          : 1.6.0    , installed 1.6.0
                            Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                            Adapter    "opendtu"      : 3.1.0    , installed 2.0.0  [Updatable]
                            Adapter    "openknx"      : 0.9.0    , installed 0.9.0
                            Adapter    "parser"       : 2.2.4    , installed 2.2.4
                            Adapter    "rpi2"         : 2.2.2    , installed 2.0.0  [Updatable]
                            Adapter    "sainlogic"    : 0.11.4   , installed 0.11.4
                            Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                            Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                            Adapter    "sonoff"       : 3.2.1    , installed 3.1.2  [Updatable]
                            Adapter    "spotify-premium": 1.5.0  , installed 1.5.0
                            Adapter    "sql"          : 3.0.1    , installed 3.0.1
                            Adapter    "sureflap"     : 2.3.1    , installed 2.3.0  [Updatable]
                            Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
                            Adapter    "telegram"     : 3.9.0    , installed 3.9.0
                            Adapter    "trashschedule": 3.4.1    , installed 3.3.0  [Updatable]
                            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                            Adapter    "web"          : 6.3.1    , installed 6.3.1
                            Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                            Adapter    "wireless-mbus": 0.9.4    , installed 0.9.4
                            Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                            Adapter    "zigbee"       : 1.10.13  , installed 1.10.3 [Updatable]
                            Adapter    "zigbee2mqtt"  : 2.13.11  , installed 2.13.10 [Updatable]
                            Objects and States
                            Objects:        26435
                            States:         20022
                            Fetched 12.7 kB in 2s (7517 B/s)
                            Reading package lists...
                            Pending Updates: 0
                            • T tetzlav
                              @tetzlav
                              Script v.2024-10-19
                              *** BASE SYSTEM ***
                                         Chassis: server
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 4
                                            NTP service: active
                                        RTC in local TZ: no
                              tetzlav
                              HOME=/home/tetzlav
                              iobroker
                              HOME=/home/iobroker
                              Desktop:
                              Terminal:
                              *** MEMORY ***
                              Swap:            20G        2.1G         18G
                              Total:           52G         18G         19G
                                      16341 M used memory
                                       1326 M free memory
                                      11973 M swap cache
                                      20479 M total swap
                                       2058 M used swap
                                      18421 M free swap
                              *** FILESYSTEM ***
                              /var:
                              26G     /var/
                              14G     /var/lib
                              6.2G    /var/www
                              USB-Devices by-id:
                              HINT:
                              HINT:
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          6.17.3
                              javascript:     8.8.3
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        26435
                              States:         20022
                              Pending Updates: 0
                              Was sollen diese sein?
                              Allenfalls im den letzten 25 Zeilen aus dem LogFile stehen evtl. persönliche Infos drin.
                              Der Rest ist für eine gescheite Diagnose von diversen Problemen wesentlich und wichtig. Sonst wären sie nicht im Skript drin.
                              • mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                @tetzlav
                                Warum installierst du Adapter von Github?
                                Kann mir schwer vorstellen, dass du derzeit an 7 Adaptern auf Anregung und zusammen mit dem Dev Tests durchführst...
                                https://github.com/ConnectorGit/ioBroker.connector-local-control ist z.B. nicht in einem Repo gelisted. Und er verwendet einen veralteten Adapter core. Sollte im Prinzip "noch" gehen aber nach js-controller 7.0.x ziemlioch sicher nicht mehr. Und da der Adapter nicht in den Repos gelistet ist wurde der Maintainer - sofern es einen gibt - auch nicht verständigt.
                                Ich hab keine Zeit alle github installs zu checken. Es kann sein - muss aber nicht sein - dass ein nicht kompatibler Adapter das gesammte System lahmlegt. Dies wurde zuletzt im Zuge der js-controlelr 6 Tests mehrfach festgestellt - wobei im Controlelr und bei allen Adaptern im Repo ein geeignetes Workaround bis zur Behebung umgesetzt wurde. Wie gesagt - ein Adapter im Alpha Status kann das Porblem verursachen - es kann auch was anderes sein.
                                Ich kann dir nur raten alle Adapter auf eine offizielle Version zu bringen und nur via Github verfügbare Adapter ggF zumindest testweise zu deinstallieren (nicht nur deaktivieren - flasche npm dependencies werden durch ein Deaktivieren nicht entfernt).
                                Ansonsten von mir nur der Hinweis:
                                Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten. GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                                Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                                Und falls es irgendwie unklar ist:
                                ioBroker unterstützt folgende Arten von Installation:
                                • aus dem STABLE Repository
                                  Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                                • aus dem LATEST Repository
                                  Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                                • direkt von GITHUB
                                  Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                                • direkt von npm
                                  Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                                Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit Sicherheit minimalistisch.
                                  tetzlav
                                  @mcm1957: Vielen Dank für die ausführliche Antwort. Du hast recht, ich muss aufräumen und updaten. So ist die Fehlersuche ein Stochern im Nebel...
                                  LG // tetzlav
                                  • T tetzlav
                                    LG // tetzlav
                                    mcm1957M Offline
                                    mcm1957M Offline
                                    mcm1957
                                    @tetzlav
                                    Wenn ein / zwei GitHub only Adapter übrig bleiben kann ich gerne nochmal schaun. Aber wie du schon geschrieben hast bitte zuerst mal aufräumen. Und bitte nicht böse sein, wenn ein GitHub only plötzlich nicht mehr geht.
                                    Gerne auch den Maintainer eines GitHub Only Adapter anstoßen damit er eine Aufnahme in die Repos veranlasst. Wir sind prinzipiell für JEDE Mitarbeit dankbar.
                                      tetzlav
                                      schrieb am zuletzt editiert von tetzlav
                                      Hier nochmal Feedback zur Info:
                                      Ich habe letztendlich /opt/iobroker gelöscht und iobroker via
                                      curl -sLf https://iobroker.net/install.sh | bash -
                                      neu installiert und danach ein backup wieder hergestellt.
                                      iobroker restore ../iobroker_241209/backups/iobroker_2024_12_09-02_00_10_backupiobroker.tar.gz
                                      Dann alle Adapter wieder aktiviert und es läuft.
                                      Ein github-only-Adapter ist leider übrig geblieben: https://github.com/TA2k/ioBroker.omada Den brauche ich leider für die WLAN-Anwesenheitserkennung.
                                      Aber dieser Adapter scheint ohnehin nicht das Problem gewesen zu sein. Ich hatte vorher (also bei den Reparaturversuchen vorher und vor der Neuinstallation) alle github-only sowie alle deaktivierten Adapter deinstalliert. Der bekannte Fehler trat trotzdem auf: Sporadisch hat sich iobroker beim starten verschluckt und ist einfach weggestorben:
                                      Danach war sogar manchmal das iobroker modul weg und musste mit
                                      wieder installiert werden. Das verstehe ich nicht. Wie kann das npm Modul einfach weg sein?
                                      Jedenfalls läuft jetzt wieder alles wieder sauber. Selbst ein nodejs Update 18->20 hat keine Probleme gemacht.
                                      Leider dauert das sehr lange, weil bei dem nodejs update via
                                      iobroker nodejs-update 20
                                      unter anderem nach den Repo Keys gesucht wird
                                      find / ( -path /proc -o -path /dev -o -path /sys -o -path /lost+found -o -path /mnt ) -prune -false -o -name nodesource.[gk]* -print
                                      Das dauert bei ~10TB gemountet unter /media sehr lange...
                                      Trotzdem nochmal vielen Dank für die Anregungen.
                                      • T tetzlav
                                        Das ist halt ein Einzelschicksal, auf das keine Rücksicht genommen werden kann, wenn es für den Rest der Welt weiterhin so einfach funktionieren soll.
