  4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
adapteremmahuaweiinverterluna2000modbus tcpmodbus-proxysdonglesmartloggersun2000
1.3k Beiträge 97 Kommentatoren 490.4k Aufrufe 87 Beobachtet
    myssv
    schrieb am zuletzt editiert von myssv
    #625
    ich bekomme mit einem mal diese Fehler:
    sun2000.0 	2024-11-07 23:12:43.232	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0 	2024-11-07 23:11:23.945	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:10:06.486	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:09:03.809	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:08:02.320	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:06:22.839	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:05:05.432	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:03:43.121	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:02:42.359	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:01:26.924	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 23:00:23.137	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:59:06.145	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:57:42.619	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:56:22.907	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:55:06.185	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:54:02.601	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:52:45.160	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:51:22.208	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:50:06.431	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:49:03.989	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:47:42.802	warn	_checkValidNumber 3276.7 from: -100 until: 100
    sun2000.0	2024-11-07 22:46:25.841	warn	_checkValidNumber 3276.7 from: -100 until: 100
    Das war mir sonst nie aufgefallen. Habe auch kein Update installiert.
    Adapter: v0.11.0
    Hat jemand eine Idee?
    • M myssv
      Adapter: v0.11.0
      bolliy
      #626
      @myssv bitte auf v0.17.0 updaten. Der Speicher ist im Sleep_mode. Die Temperatur des Speichers ist dann nicht mehr plausibel.
      Stephan
      • B bolliy
        Stephan
        myssv
        #627
        @bolliy Vielen Dank, ist installiert!
          myssv
          #628
          Nun kamen ganz unverhofft diese Warnungen:
          sun2000.0	2024-11-08 15:09:25.005	warn	Error while reading from 192.168.115.72 [Reg: 37765, Len: 2, modbusID: 1] with: Timed out
          sun2000.0	2024-11-08 15:09:10.003	warn	Error while reading from 192.168.115.72 [Reg: 32080, Len: 2, modbusID: 1] with: Timed out
          sun2000.0	2024-11-08 14:58:55.012	warn	Error while reading from 192.168.115.72 [Reg: 32080, Len: 2, modbusID: 1] with: Timed out
          sun2000.0	2024-11-08 14:58:40.008	warn	Error while reading from 192.168.115.72 [Reg: 32080, Len: 2, modbusID: 1] with: Timed out
          Davor nix und danach nix
          • M myssv
            bolliy
            #629
            @myssv der Sdongle ist eine Diva. Manchmal fühlt sich der Sdongle überfordert - gerade wenn der Inverter seinen mode umstellt. Das passiert im Winter, da die Sonneneinstrahlung sehr gering ist. Oder du bist auf der FusionSolar Webseite in der Batterieeinstellungen. Dann bekommt der Sdongle die Aufforderung seine Daten zu aktualisieren.
            Also wenn es nicht dauernd auftaucht, kannst du das vernachlässigen.
            LG Stephan
            • B bolliy
              LG Stephan
              myssv
              #630
              @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
              LG Stephan
              Alles klar, vielen Dank!
              • B bolliy
                @mhuber die Konstellation hört sich ja spannend an. Bei der nächsten Version werde ich die Abfragereihenfolge ändern. Vielleicht verbessert sich das Antwortverhalten ...
                LG Stephan
                mhuber
                #631
                LG Stephan
                dank @bolliy
                • M mhuber
                  LG Stephan
                  dank @bolliy
                  mhuber
                  #632
                  @boll
                  @mhuber sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                  LG Stephan
                  dank @bolliy
                  @bolliy Setup ist nun online. 2WR in Kaskade und ein 15KW+10KW Akku Turm. Die 3 5KW Packs vom 15KW Turm erkennt der Adapter aber die vom 10KW nicht. Macht mir aber nichts, da ich die Pack Abfrage eh nicht verwende, nur falls Du es Dir mal ansehen willst. Das 25KW gesamt nun da sind erkennt er. Rest klappt auch super, also 2WR erkannt....
                  • M mhuber
                    @boll
                    LG Stephan
                    dank @bolliy
                    mhuber
                    #633
                    @boll
                    LG Stephan
                    dank @bolliy
                    ah gerade taucht der 2te Akku auf und auch die Packs....hat etwas gedauert....
                      bolliy
                      #634
                      Neue Testversion sun2000 Adapter Version v0.17.1 released.
                      Anscheinend funktioniert die modbus-Schnittstelle bei der aktuellen Firmwareversionen auch im device status "Standby: detecting irradiation".
                      Die Installation erfolgt über npm oder morgen über das Beta Repository.
                      Changelog:
                      0.17.1 (2024-11-21)
                      • during the device status "Standby: detecting irradiation" (0x0002) register data is now also read from the inverter
                      • The reading order of the battery data has been adjusted
                      Marco DüthornM 1 Antwort Letzte Antwort
                      • B bolliy
                        Changelog:
                        0.17.1 (2024-11-21)
                        Marco DüthornM Offline
                        Marco Düthorn
                        #635
                        Hallo bolliy,
                        Ich nutze mit begeisterung seid circa 2 Wochen deinem adapter, der wo auch echt sehr stabil läuft.
                        Ich hatte vorher bevor die EMMA eingebaut wurde die Daten direkt mit Loxone abgefragt.
                        Leider kann Loxone die ID 0 nicht. Laut Loxone support ist die ID 0 für Broadcast und diese kann so nicht abgefragt werden.
                        Aktuell bekomme ich die Daten von den Wechselrichtern über den modbus proxy in Loxone.
                        Nur leider hab ich jetzt das Problem das ich die Werte von der EMMA nicht in Loxone bekomme weil die ja die ID 0 hat.
                        Ist es möglich die irgendwie umzuleiten zum Beispiel auf die ID 1?
                        Hättest du auch eine Liste welche adressen du genau abfragst?
                        Und ist es möglich den aktuellen verbrauch oder einspeißung am Netzpunkt sekündlich abzufragen?
                        Dies hatte ich vorher so für mein Überschußsteuerung.
                        Ich hatte einen modbus TCP Konverter an der Schnittstelle wo jetzt die EMMA oder auch der Smartlogger dran hängt.
                        Gruß Marco
                        • Marco DüthornM Marco Düthorn
                          Hallo bolliy,
                          Gruß Marco
                          bolliy
                          schrieb am zuletzt editiert von bolliy
                          #636
                          @marco-düthorn sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                          Hallo bolliy,
                          Das freut mich natürlich. 😁
                          Ich könnte mir ein id-mapping für dem modbus-proxy vorstellen.
                          In den Datenpunkten stehen die modbus-Register in der Beschreibung.
                          Jede Sekunde wird schwierig, da je WR ca. 150 + Emma Datenpunkte erzeugt werden. Das ist technisch nicht umsetzbar. Ich kann aber schauen ob es möglich wäre, die EMMA Register in einem kleineren Intervall zu lesen. Um welche Register handelt es sich konkret?
                          Die Definitionen findest du hier: https://github.com/bolliy/ioBroker.sun2000/blob/main/docs/definitions.md
                          Gruß Marco
                          • B bolliy
                            Hallo bolliy,
                            Gruß Marco
                            Marco Düthorn
                            #637
                            Müsste die 30358 wenn ich es richtig lese.
                            Das mit dem mapping wäre natürlich super 👍
                            Gruß Marco
                            • L Offline
                              lars10
                              schrieb am zuletzt editiert von lars10
                              #638
                              @bolliy: Erstmal vielen Dank für den sehr gut funktionierenden Adapter mit guter Doku!
                              Kurze Verständnisfrage: Kann ich auch den Sun2000 mit Batteriepack aktiv ins Standby schicken? Also dass die Batterie die Ladung hält und er in Standby geht und das Haus via Netzstrom versorgt wird?
                              Hintergrund: Wenn aktuell Nachts mal der Strom günstig ist und ich größere Verbraucher habe würde ich die dann gern laufen lassen und mir die Akkuladung für den nächsten Tag aufheben.
                              Lösungsansätze: Ich habe versucht die dischargeCutoffCapacity auf den Akkuellen Akkustand zu stellen, leider klappt das nur, wenn der Akku <=20% SOC hat. Das gleiche mit BackupPowerSOC ging auch nicht.
                              Habt ihr Ideen, wie ich das realisieren kann? Ich denke es werden andere auch solche Wünsche haben um das System weiter zu optimieren...
                              Vielen Dank für Eure Ideen und Hinweise!
                              B 2 Antworten Letzte Antwort
                              • L lars10
                                bolliy
                                #639
                                @lars10 vielleicht kann man über die Register
                                40201 (Power off) den Inverter ausschalten und
                                40200 (Power on) den Inverter wieder einschalten.
                                das habe ich aber noch nicht getestet!
                                Ist auf Seite 25 beschrieben https://www.photovoltaikforum.com/core/attachment/315028-solar-inverter-modbus-interface-definitions-pdf/
                                Siehe auch die Discussion bei der HA Integration https://github.com/wlcrs/huawei_solar/discussions/576
                                Ansonsten wüsste ich nicht wie man den WR/Batterie in den standby überführen kann.
                                LG Stephan
                                • L lars10
                                  bolliy
                                  #640
                                  @lars10 du könntest die Endladeleistung begrenzen.
                                  sun2000.0.inverter.x.control.battery.maximumDischargePower : 500 (begrenzt die Entladeleistung auf 500W)
                                  Die Einstellung benutze ich ebenfalls wenn das E-Auto geladen wird.
                                  LG Stephan
                                  L 1 Antwort Letzte Antwort
                                  • B bolliy
                                    LG Stephan
                                    lars10
                                    #641
                                    @bolliy Danke für deine Ideen! Das mit dem Power off scheint mir etwas heikel... An die Begrenzung der Entladeleistung habe ich schon gedacht, jedoch sinkt dann dadurch die Effizienz. Aber das lässt sich wohl dann nicht ändern. Wenn noch jemand anderes eine Idee hat immer gern :)
                                    D B 2 Antworten Letzte Antwort
                                    • L lars10
                                      dragst3r
                                      #642
                                      @lars10 Ich bin grad auch dabei eine Logik zu entwerfen. Außerdem hatte ich hier mal eine Dikussion angefangen.
                                      Es gibt aber tausend Fälle die man beachten muss. Hier im Thread wird ähnliches aufgebaut. Durch einen dynamischen Stromtarif wird die Sache für mich nochmal komplizierter. An deiner Stelle würde ich aber einfach die Batterie sperren, da gibt es verschiedene Optionen. Ideen findest du auch bei EVCC, da diese das auch so machen. Z.B. so:
                                          setState('sun2000.0.inverter.0.control.battery.forcibleChargeOrDischarge' /* Forcible charge/discharge (0: Stop,1: Charge, 2: Discharge) */, 2);
                                          setState('sun2000.0.inverter.0.control.battery.forcibleChargeOrDischargeSettingMode' /* Forcible charge/discharge setting mode (0: Duration,1: until SOC) */, 0);
                                          setState('sun2000.0.inverter.0.control.battery.forcedChargingAndDischargingPeriod' /* Forced charging and discharging period */, 1);
                                          setState('sun2000.0.inverter.0.control.battery.forcibleDischargePower' /* Forcible discharge power */, 0);
                                      • L lars10
                                        bolliy
                                        #643
                                        @lars10 beschrieben werden States hier: https://github.com/bolliy/ioBroker.sun2000/wiki/Erzwungenes-Laden-und-Entladen-der-Batterie-(Force-charge-discharge-battery)#erzwungenes-entladen-forcible-discharge
                                        Beachtet werden muss, dass der Speicher nicht im SLEEP_MODE sein darf. Also ca. 45 Minuten mit vorher mit
                                        sun2000.0.inverter.x.control.battery.chargeFromGridFunction : true
                                        aufwecken...
                                        • B bolliy
                                          aufwecken...
                                          bolliy
                                          #644
                                          Ich möchte hier gerne das Thema netzdienliche Solarspeicher zur Diskussion stellen:
                                          https://youtu.be/WqCyE_rpuas?si=X_d-r6y4FRn1gGwj
                                          Ich überlege eine Logik zu entwerfen, die ein netzdienliche Verhalten der Luna ermöglichen soll. Hierfür würde ich die Daten vom Adapter pvforcast und ggf. Wetterdaten einbeziehen.
                                          Wie ist eure Haltung zu dem Thema?
