  4. Zigbee2MQTT auf LNX mit zyklischen Warnings
14 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • arteckA Offline
    arteckA Offline
    arteck
    kein plan was der da macht...
    kannst du mal zigbee2mqtt manuell starten über konsole
    zuerst service stoppen
    in dem zigbee2mqtt Ordner wechseln und dann
    npm start
    und dann gucken was da kommt..
    • arteckA arteck
      npm start
      tklein
      @arteck
      hier mal der anfang von der ausgabe:
      root@iobroker:/opt/zigbee2mqtt# npm start
      > zigbee2mqtt@1.40.1 start
      > node index.js
      Starting Zigbee2MQTT without watchdog.
      [2024-11-19 10:28:48] info:     z2m: Logging to console, file (filename: log.log)
      [2024-11-19 10:28:48] debug:    z2m: Loaded state from file /opt/zigbee2mqtt/data/state.json
      [2024-11-19 10:28:48] info:     z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
      [2024-11-19 10:28:48] info:     z2m: Starting zigbee-herdsman (0.57.3)
      [2024-11-19 10:28:48] debug:    z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":1748,\"extendedPanID\":[106,111,32,69,142,92,130,83],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/opt/zigbee2mqtt/data/database.db\",\"databaseBackupPath\":\"/opt/zigbee2mqtt/data/database.db.backup\",\"backupPath\":\"/opt/zigbee2mqtt/data/coordinator_backup.json\",\"serialPort\":{\"baudRate\":115200,\"path\":\"tcp://192.168.0.33:6638\",\"adapter\":\"ezsp\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
      [2024-11-19 10:28:48] debug:    zh:ezsp: Adapter concurrent: 8
      [2024-11-19 10:28:48] debug:    zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":1748,"extendedPanID":[106,111,32,69,142,92,130,83],"channelList":[11]},"serialPort":{"baudRate":115200,"path":"tcp://192.168.0.33:6638","adapter":"ezsp"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json"}'
      [2024-11-19 10:28:48] warning:  zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Opening TCP socket with 192.168.0.33:6638
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket connected
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket ready
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Uart reseting
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> Write reset
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [1ac038bc7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: -?- waiting reset
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- [2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3203b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67e70e7e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357ec20251a8bd7e4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: reject condition
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [a0547d3a7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,1): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: packet replay
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected packet sequence 2 | 0
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (3)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,0): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== Frame: 4190013f0006fcff00001f00000000000000ffff0000
      [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== 0x1: {"_cls_":"getLibraryStatus","_id_":1,"_isRequest_":false,"status":63}
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 4: packet replay
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,1): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (4)
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- Error c20251a8bd7e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (4,2,0): 4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e
      [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 4 | 0: reject condition
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- [c1020b0a527e]
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- RSTACK c1020b0a527e
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
      [2024-11-19 10:28:49] debug:    zh:ezsp:uart: -+- waiting reset success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":4}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 00000004
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004221a850ed2c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (1)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0142a1a8582805c1ae247e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0142a1a8582805c1ae247e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (1)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8160597e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0142a1a8582805c1ae247e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0080000c021073
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":12,"stackType":2,"stackVersion":29456}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (1) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Switching to eszp version 12
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":12}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":12}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 01000100000c
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314321a9542a1989fb7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (2)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1243a1a9542a19b049e7e2dc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1243a1a9542a19b049e7e2dc7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (2)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [82503a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1243a1a9542a19b049e7e2dc7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 01800100000c021073
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (2) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S = 90
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":56,"value":90}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":56,"value":90}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0200015300385a00
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224021a9072a2de8595e057e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (3)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2340a1a9072a159ab77e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2340a1a9072a159ab77e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2340a1a9072a159ab77e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 028001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x53: {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (3) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":25,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":25,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0300015300190200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334121a9072a0cb05997eb7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (4)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3441a1a9072a15f1287e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3441a1a9072a15f1287e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3441a1a9072a15f1287e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 038001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (4) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_DELAY_MS = 50
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":29,"value":50}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":29,"value":50}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 04000153001d3200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444621a9072a08805993d67e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (5)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4546a1a9072a1505697e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4546a1a9072a1505697e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (5)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8520dd7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4546a1a9072a1505697e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 048001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (5) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":34,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":34,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0500015300220200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554721a9072a37b05980d97e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (6)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5647a1a9072a15af307e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5647a1a9072a15af307e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (6)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8610be7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5647a1a9072a15af307e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 058001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (6) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":42,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":42,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 06000153002a0300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664421a9072a3fb1590b7a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (7)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6744a1a9072a15803c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6744a1a9072a15803c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (7)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [87009f7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6744a1a9072a15803c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 068001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (7) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 7680
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":18,"value":7680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":18,"value":7680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 070001530012001e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774521a9072a07b2473edc7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (0)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7045a1a9072a15eba37e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 7045a1a9072a15eba37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (0)
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8070787e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 7045a1a9072a15eba37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 078001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (0) success
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT = 14
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":19,"value":14}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":19,"value":14}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 0800015300130e00
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004a21a9072a06bc597d3aae7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [014aa1a9072a1512a07e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 014aa1a9072a1512a07e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 014aa1a9072a1512a07e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 088001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_SECURITY_LEVEL = 5
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":13,"value":5}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":13,"value":5}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 09000153000d0500
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314b21a9072a7d38b75961387e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [124ba1a9072a15b8f97e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 124ba1a9072a15b8f97e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 124ba1a9072a15b8f97e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 098001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_STACK_PROFILE = 2
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":12,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":12,"value":2}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0a000153000c0200
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224821a9072a19b059deac7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2348a1a9072a1597f57e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2348a1a9072a1597f57e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2348a1a9072a1597f57e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0a8001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_WINDOW_SIZE = 1
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":28,"value":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":28,"value":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0b000153001c0100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334921a9072a09b35937927e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3449a1a9072a15fc6a7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3449a1a9072a15fc6a7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3449a1a9072a15fc6a7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0b8001530000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.APP_KEY_REQUEST_POLICY = 96
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":6,"decisionId":96}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":6,"decisionId":96}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 0c00015500066000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444e21a9012a7d33d2599bc67e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [454ea1a9012a15ba8b7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 454ea1a9012a15ba8b7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 454ea1a9012a15ba8b7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0c8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x55: {"_cls_":"setPolicy","_id_":85,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TC_KEY_REQUEST_POLICY = 81
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":5,"decisionId":81}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":5,"decisionId":81}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0d00015500055100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554f21a9012a10e3590b3c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [564fa1a9012a1510d27e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 564fa1a9012a1510d27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 564fa1a9012a1510d27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0d8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TRUST_CENTER_POLICY = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":0,"decisionId":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":0,"decisionId":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 0e00015500000300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664c21a9012a15b15999227e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [674ca1a9012a153fde7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 674ca1a9012a153fde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 674ca1a9012a153fde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0e8001550000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_END_DEVICE_KEEP_ALIVE_SUPPORT_MODE = 3
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":63,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":63,"value":3}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 0f0001ab003f0003
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774d21a9ff2a2ab25a7d3a767e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [704da1a9ff2a15ac127e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 704da1a9ff2a15ac127e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 704da1a9ff2a15ac127e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0f8001ab0000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xab: {"_cls_":"setValue","_id_":171,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_CCA_THRESHOLD = 0
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":21,"value":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":21,"value":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 100001ab00150000
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [005221a9ff2a00b25995147e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0152a1a9ff2a154f957e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0152a1a9ff2a154f957e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0152a1a9ff2a154f957e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 108001ab0000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConcentrator: {"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConcentrator","_id_":16,"_isRequest_":true,"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 110001100001f9ff0a005a00040300
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d315321a9442a144ba69e4a7faa519149699e7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1253a1a9442a15ebc27e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1253a1a9442a15ebc27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1253a1a9442a15ebc27e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 118001100000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x10: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set concentrator type: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setSourceRouteDiscoveryMode: {"mode":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":true,"mode":1}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 1200015a0001
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [225021a90e2a1494327e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2350a1a90e2a3db2599476767e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2350a1a90e2a3db2599476767e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2350a1a90e2a3db2599476767e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 1280015a0028000000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x5a: {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":false,"remainingTime":40}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 1300010200010401efbe0007140000030006000a0019001a0000030000030004000500060008002000000300040204050406040005010b030b040b0207001001fc02fc
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [335121a9562a14b6587bf425ad4192499f4e21abe7ce7d5e8be7c6638afc7d5e3ca7efcddb6f89ffcfdbf5d2698f4627abe8733fa3ee758740934f2d17bae277380c0ffbb91990397e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3451a1a9562a1582527e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3451a1a9562a1582527e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3451a1a9562a1582527e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 138001020000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x2: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Ezsp adding endpoint: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 1400010200f2e0a161000000012100
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [445621a9562ae752f8f54a25aa54b349844e7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4556a1a9562a15767d337e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4556a1a9562a1576137e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4556a1a9562a1576137e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 148001020000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Get EzspValueId.VALUE_VERSION_INFO
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getValue: {"valueId":17}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getValue","_id_":170,"_isRequest_":true,"valueId":17}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 150001aa0011
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [555721a9fe2a0430357e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5657a1a9fe2a15b5e9944d26ab5538abde7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5657a1a9fe2a15b5e9944d26ab5538abde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5657a1a9fe2a15b5e9944d26ab5538abde7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 158001aa000007b00007030100aa
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xaa: {"_cls_":"getValue","_id_":170,"_isRequest_":false,"status":0,"value":{"type":"Buffer","data":[176,0,7,3,1,0,170]}}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Got EzspValueId.VALUE_VERSION_INFO = ��
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: EmberZNet version: 7.3.1.0 build 176
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkInit: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkInit","_id_":23,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 1600011700
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [665421a9432aff9d7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6754a5a9432a15d2d37e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6754a5a9432a15d2d37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6754a5a9432a15d2d37e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 168401170000
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x17: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Network init result: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7754b1a94d2a85f04c7e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,7,0): 7754b1a94d2a85f04c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 7754b1a94d2a85f04c7e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 169001190090
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x19: {"_cls_":"stackStatusHandler","_id_":25,"_isRequest_":false,"status":144}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,0,0): 1700012800
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [705521a97c2ad7027e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0055a1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e37627e]
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,0,0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 178001280000016a6f20458e5c8253d406050b0000000000f8ff07
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
      [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Current Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkState: undefined
      [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkState","_id_":24,"_isRequest_":true}
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,1,0): 1800011800
      [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [015a21a94c2ab7527e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [7d315aa1a94c2a17f2417e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,1,0): 115aa1a94c2a17f2417e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (2)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [82503a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (1): 115aa1a94c2a17f2417e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 188001180002
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x18: {"_cls_":"networkState","_id_":24,"_isRequest_":false,"status":2}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (1) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network state 2
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (1,2,0): 1900012800
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [125b21a97c2accf27e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (2)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [225ba1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e782a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (3)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [83401b7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (2): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 198001280000016a6f20458e5c8253d406050b0000000000f8ff07
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (2) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNodeId: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNodeId","_id_":39,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (2,3,0): 1a00012700
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [235821a9732a58327e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (3)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [3358a1a9732a15b2038c7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (3,3,0): 3358a1a9732a15b2038c7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (4)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8430fc7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (3): 3358a1a9732a15b2038c7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1a800127000000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x27: {"_cls_":"getNodeId","_id_":39,"_isRequest_":false,"nodeId":0}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (3) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getEui64: undefined
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getEui64","_id_":38,"_isRequest_":true}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (3,4,0): 1b00012600
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [345921a9722a7d33977e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (4)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [4459a1a9722a6b30e56ab5fe1ed171177e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (4,4,0): 4459a1a9722a6b30e56ab5fe1ed171177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (5)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8520dd7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (4): 4459a1a9722a6b30e56ab5fe1ed171177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1b800126007e82bcfeffdbb484
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x26: {"_cls_":"getEui64","_id_":38,"_isRequest_":false,"eui64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (4) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network ready
      [2024-11-19 10:28:53] debug:    zh:ezsp: Device join request received: 0 84b4dbfffebc827e
      [2024-11-19 10:28:53] debug:    zh:ezsp: Requesting 'Node Descriptor' for '0'
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: ZDO Node_Desc_req params: {"dstaddr":0}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: EZSP nwk=0, IEEE=0x84b4dbfffebc827e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":1}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":1}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (4,5,0): 1c00016a0001
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [455e21a93e2a147b6a7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (5)
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> sendUnicast: {"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7d5e3fa7ebcdde7d310d4339240e66ed86c57e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (5,5,0): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (6)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8610be7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (5): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1c80016a00001a00017eb22b39b5c0ef47bab0d286a4d9459e0090000000000000007e82bcfeffdbb484
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (5) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"sendUnicast","_id_":52,"_isRequest_":true,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (5,6,0): 1d0001340000000000000200000000010000020303020000
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [565f21a9602a15b259944a27aa5592499d4e27a9eecd658bfd976f7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (6)
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: TRUST_CENTER_LINK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":3}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [665fa1a9602a15f071ef7e765fb5a97d312a15b259964a25aa5593499c0cd8abedce9874fec463893e537e065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (6,6,0): 665fa1a9602a15f071ef7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (7)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [87009f7e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 665fa1a9602a15f071ef7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d800134000042
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x34: {"_cls_":"sendUnicast","_id_":52,"_isRequest_":false,"status":0,"sequence":66}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (7,6,0): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (0)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8070787e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94014500000000020000000001000042ff000000ffff03020000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp: processMessage: {"messageType":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lqi":255,"rssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (0,6,0): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (1)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8160597e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94013f000000000000020000000001000042030000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x3f: {"_cls_":"messageSentHandler","_id_":63,"_isRequest_":false,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"status":0,"message":{"type":"Buffer","data":[]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (6) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":3}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (6,1,0): 1e00016a0003
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [615c21a93e2a167f587e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (7)
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [165fb1a97d312a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7d5e7f2826668cef8fbeeb5bd5d270177e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,6,0): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: Unexpected packet sequence 6 | 7
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d90014500000000028000000001000043ff000000ffff110200000000408fcdab528000412c800000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":67,"clusterId":32770,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp  frame: {"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp parsed: {"_cls_":"nodeDescRsp","_id_":32770,"transId":2,"status":0,"nwkaddr":0,"descriptor":{"byte1":0,"byte2":64,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e]
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,7,0): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (7): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1e80016a0000030003c566ea92aaf677e2140a128084cfbd9201d0db0100000000000000000000000000
      [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
      [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (7) success
      [2024-11-19 10:28:53] debug:    zh:ezsp:driv: CURRENT_NETWORK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
      ^C[2024-11-19 10:28:53] debug:  zh:controller:device: Request Queue (0x84b4dbfffebc827e): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffeae693): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffec950b): default expiration timeout set to 0
      [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x003c84fffe18aed5): default expiration timeout set to 43200000
      [2024-11-19 10:28:53] debug:    z2m: Saving state to file /opt/zigbee2mqtt/data/state.json
      [2024-11-19 10:28:53] error:    z2m: Not connected to MQTT server!
      [2024-11-19 10:28:53] error:    z2m: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
      [2024-11-19 10:28:53] info:     z2m: Disconnecting from MQTT server
      [2024-11-19 10:28:53] info:     z2m: Stopping zigbee-herdsman...
      [2024-11-19 10:28:53] debug:    zh:controller:database: Writing database to '/opt/zigbee2mqtt/data/database.db'
      [2024-11-19 10:28:53] info:     z2m: Stopped zigbee-herdsman
      [2024-11-19 10:28:53] info:     z2m: Stopped Zigbee2MQTT
        tklein
        hier mal die mqtt logs:
        mqtt.02024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:31:44.835	info	Client [mqttjs_b6def4ee] connected with secret 1732001504835_6979
        mqtt.0	2024-11-19 08:31:26.479	info	Client [mqttjs_297b7318] connection closed: disconnected
        mqtt.0	2024-11-19 08:30:03.883	info	Client [mqttjs_297b7318] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:30:03.653	info	Client [mqttjs_297b7318] connected with secret 1732001403653_5414
        mqtt.0	2024-11-19 08:29:45.478	info	Client [mqttjs_3e32c692] connection closed: disconnected
        mqtt.0	2024-11-19 08:28:22.870	info	Client [mqttjs_3e32c692] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:28:22.640	info	Client [mqttjs_3e32c692] connected with secret 1732001302640_1750
        mqtt.0	2024-11-19 08:28:04.478	info	Client [mqttjs_f14b52fd] connection closed: disconnected
        mqtt.0	2024-11-19 08:26:41.793	info	Client [mqttjs_f14b52fd] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:26:41.564	info	Client [mqttjs_f14b52fd] connected with secret 1732001201564_9659
        mqtt.0	2024-11-19 08:26:23.478	info	Client [mqttjs_9029bbbb] connection closed: disconnected
        mqtt.0	2024-11-19 08:25:01.034	info	Client [mqttjs_9029bbbb] publishOnSubscribe send all known states
        mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
        mqtt.0	2024-11-19 08:25:00.805	info	Client [mqttjs_9029bbbb] connected with secret 1732001100805_685
        mqtt.0	2024-11-19 08:24:42.478	info	Client [mqttjs_93e5d70e] connection closed: disconnected
        • arteckA Offline
          arteckA Offline
          arteck
          du musst den schon länger laufen lassen bist der wieder ein
          Start try again in 1 seconds...
          anzeigt...
          • arteckA arteck
            anzeigt...
            tklein
            @arteck
            die ausgabe in eine datei ist nicht lange gelaufen. dann kam das:
            root@iobroker:/opt/zigbee2mqtt# sudo service zigbee2mqtt stop
            root@iobroker:/opt/zigbee2mqtt# npm start >> zigbee2mqtt_log.txt
            /opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
              var er = new ERR_STREAM_WRITE_AFTER_END();
            Error: write after end
                at writeAfterEnd (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
                at DerivedLogger.Writable.write (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
                at DerivedLogger.log (/opt/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
                at Logger.log (/opt/zigbee2mqtt/lib/util/logger.ts:189:25)
                at Logger.debug (/opt/zigbee2mqtt/lib/util/logger.ts:210:14)
                at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                at Object.onceWrapper (node:events:634:26)
                at Socket.emit (node:events:531:35)
                at TCP.<anonymous> (node:net:339:12)
            Hier die Datei:
            zigbee2mqtt_log.txt
              tklein
              hier noch die configuration.yaml:
              homeassistant: false
              frontend: true
              mqtt:
                base_topic: zigbee2mqtt
                server: mqtt://192.168.0.22:1888
              serial:
                port: tcp://192.168.0.33:6638
                baudrate: 115200
                adapter: ezsp
              advanced:
                network_key:
                  - 197
                  - 102
                  - 234
                  - 146
                  - 170
                  - 246
                  - 119
                  - 226
                  - 20
                  - 10
                  - 18
                  - 128
                  - 132
                  - 207
                  - 189
                  - 146
                pan_id: 1748
                ext_pan_id:
                  - 106
                  - 111
                  - 32
                  - 69
                  - 142
                  - 92
                  - 130
                  - 83
                homeassistant_legacy_entity_attributes: false
                legacy_api: false
                legacy_availability_payload: false
                log_level: debug
              device_options:
                legacy: false
              devices:
                '0x282c02bfffeae693':
                  friendly_name: wassersensor_1
                '0x282c02bfffec950b':
                  friendly_name: '0x282c02bfffec950b'
                '0x003c84fffe18aed5':
                  friendly_name: '0x003c84fffe18aed5'
                tklein
                mit
                sudo journalctl -u zigbee2mqtt.service -f
                kam folgendes:
                Nov 19 13:23:08 iobroker node[20281]:     at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                Nov 19 13:23:08 iobroker node[20281]:     at Object.onceWrapper (node:events:634:26)
                Nov 19 13:23:08 iobroker node[20281]:     at Socket.emit (node:events:531:35)
                Nov 19 13:23:08 iobroker node[20281]:     at TCP.<anonymous> (node:net:339:12)
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Failed with result 'timeout'.
                Nov 19 13:23:08 iobroker systemd[1]: Failed to start zigbee2mqtt.service - zigbee2mqtt.
                Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Consumed 2.326s CPU time.
                Nov 19 13:23:18 iobroker systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart c
                • T tklein
                  @arteck
                  Hier die Datei:
                  zigbee2mqtt_log.txt
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @tklein haswt du einen mosquitto installiert als mqtt server ??
                  • arteckA arteck
                    tklein
                    @arteck
                    brauche ich den, wenn der iob mqtt als server läuft?
                    • T tklein
                      @arteck
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @tklein sagte in Zigbee2MQTT auf LNX mit zyklischen Warnings:
                      @arteck
                      da scheint irgendwas mit dem mqtt nicht zu stimmen...
                      stell mal den adapter so ein
                      und in der yaml von zigbee2mqtt mustt du es auch anpassten
                      server: mqtt://192.168.0.22:1884
                      • arteckA arteck
                        @arteck
                        tklein
                        @arteck jetzt sind die warnings weg :-) thx dafür
                        ist das ein normales verhalten?
                        zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:12:59.274	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:11:18.122	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Zigbee2MQTT started!
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                        zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Started frontend on port 8080
                        zigbee2mqtt.0 2024-11-20 09:06:15.147	info	z2m: Zigbee2MQTT started!
                        hier noch die logs on der gui des coordinators:
                        [09:07:49] taskZB | New client: 192.168.0.22 id: 0
                        [09:09:19] taskZB | Client disconnected, id: 0
                        [09:09:30] taskZB | New client: 192.168.0.22 id: 0
                        [09:11:00] taskZB | Client disconnected, id: 0
                        [09:11:11] taskZB | New client: 192.168.0.22 id: 0
                        [09:12:41] taskZB | Client disconnected, id: 0
                        [09:12:52] taskZB | New client: 192.168.0.22 id: 0
                        [09:14:22] taskZB | Client disconnected, id: 0
                        [09:14:33] taskZB | New client: 192.168.0.22 id: 0
                        [09:16:03] taskZB | Client disconnected, id: 0
                        [09:16:14] taskZB | New client: 192.168.0.22 id: 0
