  4. Zigbee2MQTT auf LNX mit zyklischen Warnings
14 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    tklein
    für mich sieht es so aus, als wenn der Z2M Dienst alle ca 30 sek sich verabschiedet:
    root@iobroker:~# sudo service zigbee2mqtt status
    * zigbee2mqtt.service - zigbee2mqtt
         Loaded: loaded (/etc/systemd/system/zigbee2mqtt.service; enabled; preset: enabled)
         Active: activating (auto-restart) (Result: timeout) since Mon 2024-11-18 19:08:43 CET; 1s ago
        Process: 5331 ExecStart=/usr/bin/node index.js (code=exited, status=1/FAILURE)
       Main PID: 5331 (code=exited, status=1/FAILURE)
            CPU: 2.278s
         Active: activating (start) since Mon 2024-11-18 19:08:53 CET; 2s ago
       Main PID: 5367 (node)
          Tasks: 11 (limit: 18931)
         Memory: 98.0M
            CPU: 1.498s
         CGroup: /system.slice/zigbee2mqtt.service
                 `-5367 /usr/bin/node index.js
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> ACK  (5)
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> [8520dd7e]
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: <-- ACK (2): 4a0bb1a96b2a164fa674eb04aaa76d499db3d8fbe5ce67b2307e
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Unexpected packet sequence 2 | 0
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Skipping the packet as repeated (5)
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: <-- Error c20251a8bd7e
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: Uart reseting
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> Write reset
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: --> [1ac038bc7e]
    Nov 18 19:08:54 iobroker node[5367]: [2024-11-18 19:08:54] debug:         zh:ezsp:uart: -?- waiting reset
    root@iobroker:~# ^C
    root@iobroker:~#
      tklein
      was ich komisch finde ist, dass es eine Pause in den Logs gibt: 22:37 - 07:20 Uhr:
      • arteckA Offline
        arteckA Offline
        arteck
        kein plan was der da macht...
        kannst du mal zigbee2mqtt manuell starten über konsole
        zuerst service stoppen
        in dem zigbee2mqtt Ordner wechseln und dann
        npm start
        und dann gucken was da kommt..
        • arteckA arteck
          npm start
          tklein
          @arteck
          hier mal der anfang von der ausgabe:
          root@iobroker:/opt/zigbee2mqtt# npm start
          > zigbee2mqtt@1.40.1 start
          > node index.js
          Starting Zigbee2MQTT without watchdog.
          [2024-11-19 10:28:48] info:     z2m: Logging to console, file (filename: log.log)
          [2024-11-19 10:28:48] debug:    z2m: Loaded state from file /opt/zigbee2mqtt/data/state.json
          [2024-11-19 10:28:48] info:     z2m: Starting Zigbee2MQTT version 1.40.1 (commit #403d3c0)
          [2024-11-19 10:28:48] info:     z2m: Starting zigbee-herdsman (0.57.3)
          [2024-11-19 10:28:48] debug:    z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":1748,\"extendedPanID\":[106,111,32,69,142,92,130,83],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/opt/zigbee2mqtt/data/database.db\",\"databaseBackupPath\":\"/opt/zigbee2mqtt/data/database.db.backup\",\"backupPath\":\"/opt/zigbee2mqtt/data/coordinator_backup.json\",\"serialPort\":{\"baudRate\":115200,\"path\":\"tcp://192.168.0.33:6638\",\"adapter\":\"ezsp\"},\"adapter\":{\"concurrent\":null,\"delay\":null,\"disableLED\":false}}"'
          [2024-11-19 10:28:48] debug:    zh:ezsp: Adapter concurrent: 8
          [2024-11-19 10:28:48] debug:    zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":1748,"extendedPanID":[106,111,32,69,142,92,130,83],"channelList":[11]},"serialPort":{"baudRate":115200,"path":"tcp://192.168.0.33:6638","adapter":"ezsp"},"adapter":{"disableLED":false,"concurrent":null,"delay":null},"databasePath":"/opt/zigbee2mqtt/data/database.db","databaseBackupPath":"/opt/zigbee2mqtt/data/database.db.backup","backupPath":"/opt/zigbee2mqtt/data/coordinator_backup.json"}'
          [2024-11-19 10:28:48] warning:  zh:ezsp: Deprecated driver 'ezsp' currently in use, 'ember' will become the officially supported EmberZNet driver in next release. If using Zigbee2MQTT see https://github.com/Koenkk/zigbee2mqtt/discussions/21462
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Opening TCP socket with 192.168.0.33:6638
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket connected
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Socket ready
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Uart reseting
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> Write reset
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [1ac038bc7e]
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: -?- waiting reset
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- [2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3203b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67e70e7e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357e2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e3a03b1a96b2a7d334ea6944a3aaa5592499c4e275412ce67ff357ec20251a8bd7e4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e]
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 2203b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67d5e77e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: reject condition
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [a0547d3a7e]
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (2,2,1): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 0: packet replay
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (3)
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [83401b7e]
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 2a03b1a96b2a164fa674eb04aaa76d499db3d8e8e5ce67cddc7e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected packet sequence 2 | 0
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (3)
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,0): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> ACK  (4)
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: --> [8430fc7e]
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3203b1a96b2a134ea6944a3aaa5592499c4e275412ce67e70e7e
          [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== Frame: 4190013f0006fcff00001f00000000000000ffff0000
          [2024-11-19 10:28:48] debug:    zh:ezsp:ezsp: <== 0x1: {"_cls_":"getLibraryStatus","_id_":1,"_isRequest_":false,"status":63}
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 2 | 4: packet replay
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (3,2,1): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- ACK (2): 3a03b1a96b2a134ea6944a3aaa5592499c4e275412ce67ff357e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Skipping the packet as repeated (4)
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- Error c20251a8bd7e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: <-- DATA (4,2,0): 4203b1a96b2a164fa6904b23aa546d499d4e273d12ce67ebf57e
          [2024-11-19 10:28:48] debug:    zh:ezsp:uart: Unexpected DATA packet sequence 4 | 0: reject condition
          [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- [c1020b0a527e]
          [2024-11-19 10:28:49] debug:    zh:ezsp:uart: <-- RSTACK c1020b0a527e
          [2024-11-19 10:28:49] debug:    zh:ezsp:uart: RSTACK Version: 2 Reason: RESET_SOFTWARE frame: c1020b0a527e
          [2024-11-19 10:28:49] debug:    zh:ezsp:uart: -+- waiting reset success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":4}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":4}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 00000004
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004221a850ed2c7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (1)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0142a1a8582805c1ae247e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0142a1a8582805c1ae247e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (1)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8160597e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0142a1a8582805c1ae247e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0080000c021073
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x0: {"_cls_":"version","_id_":0,"_isRequest_":false,"protocolVersion":12,"stackType":2,"stackVersion":29456}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (1) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Switching to eszp version 12
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> version: {"desiredProtocolVersion":12}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"version","_id_":0,"_isRequest_":true,"desiredProtocolVersion":12}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 01000100000c
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314321a9542a1989fb7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (2)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1243a1a9542a19b049e7e2dc7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1243a1a9542a19b049e7e2dc7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (2)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [82503a7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1243a1a9542a19b049e7e2dc7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 01800100000c021073
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (2) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S = 90
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":56,"value":90}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":56,"value":90}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0200015300385a00
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224021a9072a2de8595e057e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (3)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2340a1a9072a159ab77e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2340a1a9072a159ab77e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (3)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [83401b7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2340a1a9072a159ab77e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 028001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x53: {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (3) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 2
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":25,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":25,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0300015300190200
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334121a9072a0cb05997eb7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (4)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3441a1a9072a15f1287e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3441a1a9072a15f1287e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (4)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8430fc7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3441a1a9072a15f1287e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 038001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (4) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_DELAY_MS = 50
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":29,"value":50}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":29,"value":50}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 04000153001d3200
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444621a9072a08805993d67e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (5)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4546a1a9072a1505697e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4546a1a9072a1505697e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (5)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8520dd7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4546a1a9072a1505697e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 048001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (5) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD = 2
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":34,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":34,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0500015300220200
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554721a9072a37b05980d97e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (6)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5647a1a9072a15af307e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5647a1a9072a15af307e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (6)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8610be7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5647a1a9072a15af307e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 058001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (6) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS = 3
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":42,"value":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":42,"value":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 06000153002a0300
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664421a9072a3fb1590b7a7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (7)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6744a1a9072a15803c7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6744a1a9072a15803c7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (7)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [87009f7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6744a1a9072a15803c7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 068001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (7) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 7680
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":18,"value":7680}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":18,"value":7680}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 070001530012001e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774521a9072a07b2473edc7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -?- waiting (0)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7045a1a9072a15eba37e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 7045a1a9072a15eba37e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> ACK  (0)
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [8070787e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 7045a1a9072a15eba37e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 078001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: -+- waiting (0) success
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT = 14
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":19,"value":14}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":19,"value":14}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 0800015300130e00
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [004a21a9072a06bc597d3aae7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [014aa1a9072a1512a07e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 014aa1a9072a1512a07e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 014aa1a9072a1512a07e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 088001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_SECURITY_LEVEL = 5
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":13,"value":5}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":13,"value":5}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 09000153000d0500
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d314b21a9072a7d38b75961387e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [124ba1a9072a15b8f97e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 124ba1a9072a15b8f97e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 124ba1a9072a15b8f97e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 098001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_STACK_PROFILE = 2
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":12,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":12,"value":2}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 0a000153000c0200
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [224821a9072a19b059deac7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2348a1a9072a1597f57e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2348a1a9072a1597f57e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2348a1a9072a1597f57e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0a8001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspConfigId.CONFIG_FRAGMENT_WINDOW_SIZE = 1
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConfigurationValue: {"configId":28,"value":1}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConfigurationValue","_id_":83,"_isRequest_":true,"configId":28,"value":1}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 0b000153001c0100
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [334921a9072a09b35937927e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3449a1a9072a15fc6a7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3449a1a9072a15fc6a7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3449a1a9072a15fc6a7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0b8001530000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.APP_KEY_REQUEST_POLICY = 96
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":6,"decisionId":96}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":6,"decisionId":96}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 0c00015500066000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [444e21a9012a7d33d2599bc67e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [454ea1a9012a15ba8b7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 454ea1a9012a15ba8b7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 454ea1a9012a15ba8b7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0c8001550000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x55: {"_cls_":"setPolicy","_id_":85,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TC_KEY_REQUEST_POLICY = 81
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":5,"decisionId":81}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":5,"decisionId":81}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 0d00015500055100
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [554f21a9012a10e3590b3c7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [564fa1a9012a1510d27e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 564fa1a9012a1510d27e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 564fa1a9012a1510d27e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0d8001550000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspPolicyId.TRUST_CENTER_POLICY = 3
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setPolicy: {"policyId":0,"decisionId":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setPolicy","_id_":85,"_isRequest_":true,"policyId":0,"decisionId":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 0e00015500000300
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [664c21a9012a15b15999227e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [674ca1a9012a153fde7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 674ca1a9012a153fde7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 674ca1a9012a153fde7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0e8001550000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_END_DEVICE_KEEP_ALIVE_SUPPORT_MODE = 3
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":63,"value":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":63,"value":3}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,7,0): 0f0001ab003f0003
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [774d21a9ff2a2ab25a7d3a767e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [704da1a9ff2a15ac127e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,0,0): 704da1a9ff2a15ac127e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 704da1a9ff2a15ac127e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 0f8001ab0000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xab: {"_cls_":"setValue","_id_":171,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set EzspValueId.VALUE_CCA_THRESHOLD = 0
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setValue: {"valueId":21,"value":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setValue","_id_":171,"_isRequest_":true,"valueId":21,"value":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,0,0): 100001ab00150000
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [005221a9ff2a00b25995147e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0152a1a9ff2a154f957e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,1,0): 0152a1a9ff2a154f957e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (1): 0152a1a9ff2a154f957e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 108001ab0000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setConcentrator: {"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setConcentrator","_id_":16,"_isRequest_":true,"on":true,"concentratorType":65529,"minTime":10,"maxTime":90,"routeErrorThreshold":4,"deliveryFailureThreshold":3,"maxHops":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (1,1,0): 110001100001f9ff0a005a00040300
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [7d315321a9442a144ba69e4a7faa519149699e7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [1253a1a9442a15ebc27e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (1,2,0): 1253a1a9442a15ebc27e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (2): 1253a1a9442a15ebc27e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 118001100000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x10: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Set concentrator type: {"_cls_":"setConcentrator","_id_":16,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> setSourceRouteDiscoveryMode: {"mode":1}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":true,"mode":1}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (2,2,0): 1200015a0001
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [225021a90e2a1494327e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [2350a1a90e2a3db2599476767e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (2,3,0): 2350a1a90e2a3db2599476767e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (3): 2350a1a90e2a3db2599476767e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 1280015a0028000000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x5a: {"_cls_":"setSourceRouteDiscoveryMode","_id_":90,"_isRequest_":false,"remainingTime":40}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":1,"profileId":260,"deviceId":48879,"appFlags":0,"inputClusterCount":7,"outputClusterCount":20,"inputClusterList":[0,3,6,10,25,26,768],"outputClusterList":[0,3,4,5,6,8,32,768,1024,1026,1029,1030,1280,2817,2819,2820,1794,4096,64513,64514]}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (3,3,0): 1300010200010401efbe0007140000030006000a0019001a0000030000030004000500060008002000000300040204050406040005010b030b040b0207001001fc02fc
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [335121a9562a14b6587bf425ad4192499f4e21abe7ce7d5e8be7c6638afc7d5e3ca7efcddb6f89ffcfdbf5d2698f4627abe8733fa3ee758740934f2d17bae277380c0ffbb91990397e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [3451a1a9562a1582527e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (3,4,0): 3451a1a9562a1582527e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (4): 3451a1a9562a1582527e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 138001020000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x2: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Ezsp adding endpoint: {"_cls_":"addEndpoint","_id_":2,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> addEndpoint: {"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"addEndpoint","_id_":2,"_isRequest_":true,"endpoint":242,"profileId":41440,"deviceId":97,"appFlags":0,"inputClusterCount":0,"outputClusterCount":1,"inputClusterList":[],"outputClusterList":[33]}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (4,4,0): 1400010200f2e0a161000000012100
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [445621a9562ae752f8f54a25aa54b349844e7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [4556a1a9562a15767d337e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (4,5,0): 4556a1a9562a1576137e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (5): 4556a1a9562a1576137e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 148001020000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Get EzspValueId.VALUE_VERSION_INFO
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getValue: {"valueId":17}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getValue","_id_":170,"_isRequest_":true,"valueId":17}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (5,5,0): 150001aa0011
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [555721a9fe2a0430357e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [5657a1a9fe2a15b5e9944d26ab5538abde7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (5,6,0): 5657a1a9fe2a15b5e9944d26ab5538abde7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (6): 5657a1a9fe2a15b5e9944d26ab5538abde7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 158001aa000007b00007030100aa
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0xaa: {"_cls_":"getValue","_id_":170,"_isRequest_":false,"status":0,"value":{"type":"Buffer","data":[176,0,7,3,1,0,170]}}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Got EzspValueId.VALUE_VERSION_INFO = ��
          [2024-11-19 10:28:52] debug:    zh:ezsp:driv: EmberZNet version: 7.3.1.0 build 176
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkInit: undefined
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkInit","_id_":23,"_isRequest_":true}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (6,6,0): 1600011700
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [665421a9432aff9d7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [6754a5a9432a15d2d37e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (6,7,0): 6754a5a9432a15d2d37e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 6754a5a9432a15d2d37e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 168401170000
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x17: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: Network init result: {"_cls_":"networkInit","_id_":23,"_isRequest_":false,"status":0}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [7754b1a94d2a85f04c7e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (7,7,0): 7754b1a94d2a85f04c7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (7): 7754b1a94d2a85f04c7e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 169001190090
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x19: {"_cls_":"stackStatusHandler","_id_":25,"_isRequest_":false,"status":144}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (7,0,0): 1700012800
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [705521a97c2ad7027e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- [0055a1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e37627e]
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- DATA (0,0,0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: <-- ACK (0): 0055a1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e37627e
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== Frame: 178001280000016a6f20458e5c8253d406050b0000000000f8ff07
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
          [2024-11-19 10:28:52] debug:    zh:ezsp:driv: Current Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> networkState: undefined
          [2024-11-19 10:28:52] debug:    zh:ezsp:ezsp: ==> {"_cls_":"networkState","_id_":24,"_isRequest_":true}
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> DATA (0,1,0): 1800011800
          [2024-11-19 10:28:52] debug:    zh:ezsp:uart: --> [015a21a94c2ab7527e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [7d315aa1a94c2a17f2417e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,1,0): 115aa1a94c2a17f2417e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (2)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [82503a7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (1): 115aa1a94c2a17f2417e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 188001180002
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x18: {"_cls_":"networkState","_id_":24,"_isRequest_":false,"status":2}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (1) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network state 2
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNetworkParameters: undefined
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":true}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (1,2,0): 1900012800
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [125b21a97c2accf27e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (2)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [225ba1a97c2a15b333fb6a602409107d3a484822a0edce678bfd3e9c8e782a7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,2,0): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (3)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [83401b7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (2): 225ba1a97c2a15b333fb6a602409101a484822a0edce678bfd3e9c8e782a7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 198001280000016a6f20458e5c8253d406050b0000000000f8ff07
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x28: {"_cls_":"getNetworkParameters","_id_":40,"_isRequest_":false,"status":0,"nodeType":1,"parameters":{"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (2) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node type: 1, Network parameters: EmberNetworkParameters: {"extendedPanId":[106,111,32,69,142,92,130,83],"panId":1748,"radioTxPower":5,"radioChannel":11,"joinMethod":0,"nwkManagerId":0,"nwkUpdateId":0,"channels":134215680}
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getNodeId: undefined
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getNodeId","_id_":39,"_isRequest_":true}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (2,3,0): 1a00012700
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [235821a9732a58327e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (3)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [3358a1a9732a15b2038c7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (3,3,0): 3358a1a9732a15b2038c7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (4)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8430fc7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (3): 3358a1a9732a15b2038c7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1a800127000000
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x27: {"_cls_":"getNodeId","_id_":39,"_isRequest_":false,"nodeId":0}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (3) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getEui64: undefined
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getEui64","_id_":38,"_isRequest_":true}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (3,4,0): 1b00012600
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [345921a9722a7d33977e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (4)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [4459a1a9722a6b30e56ab5fe1ed171177e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (4,4,0): 4459a1a9722a6b30e56ab5fe1ed171177e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (5)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8520dd7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (4): 4459a1a9722a6b30e56ab5fe1ed171177e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1b800126007e82bcfeffdbb484
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x26: {"_cls_":"getEui64","_id_":38,"_isRequest_":false,"eui64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (4) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Network ready
          [2024-11-19 10:28:53] debug:    zh:ezsp: Device join request received: 0 84b4dbfffebc827e
          [2024-11-19 10:28:53] debug:    zh:ezsp: Requesting 'Node Descriptor' for '0'
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: ZDO Node_Desc_req params: {"dstaddr":0}
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: EZSP nwk=0, IEEE=0x84b4dbfffebc827e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":1}
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":1}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (4,5,0): 1c00016a0001
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [455e21a93e2a147b6a7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (5)
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> sendUnicast: {"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7d5e3fa7ebcdde7d310d4339240e66ed86c57e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (5,5,0): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (6)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8610be7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (5): 555ea1a93e2a15a859953497816c278973099d1b3f48c352b8586319fc7e3fa7ebcdde110d4339240e66ed86c57e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1c80016a00001a00017eb22b39b5c0ef47bab0d286a4d9459e0090000000000000007e82bcfeffdbb484
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (5) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"sendUnicast","_id_":52,"_isRequest_":true,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":2,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"message":{"type":"Buffer","data":[2,0,0]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (5,6,0): 1d0001340000000000000200000000010000020303020000
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [565f21a9602a15b259944a27aa5592499d4e27a9eecd658bfd976f7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (6)
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: TRUST_CENTER_LINK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[126,178,43,57,181,192,239,71,186,176,210,134,164,217,69,158]},"outgoingFrameCounter":36864,"sequenceNumber":0,"bitmask":26,"type":1,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[132,180,219,255,254,188,130,126]}}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> getKey: {"keyType":3}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [665fa1a9602a15f071ef7e765fb5a97d312a15b259964a25aa5593499c0cd8abedce9874fec463893e537e065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (6,6,0): 665fa1a9602a15f071ef7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (7)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [87009f7e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 665fa1a9602a15f071ef7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d800134000042
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x34: {"_cls_":"sendUnicast","_id_":52,"_isRequest_":false,"status":0,"sequence":66}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (7,6,0): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (0)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8070787e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 765fb5a9112a15b259964a25aa5593499c0cd8abedce9874fec463893e537e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94014500000000020000000001000042ff000000ffff03020000
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp: processMessage: {"messageType":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lqi":255,"rssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (0,6,0): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> ACK  (1)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [8160597e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 065fb5a96b2a15b259944a27aa5592499d4e27e9eece67e18b7e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d94013f000000000000020000000001000042030000
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x3f: {"_cls_":"messageSentHandler","_id_":63,"_isRequest_":false,"type":0,"indexOrDestination":0,"apsFrame":{"profileId":0,"sequence":66,"clusterId":2,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"messageTag":3,"status":0,"message":{"type":"Buffer","data":[]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (6) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: ==> {"_cls_":"getKey","_id_":106,"_isRequest_":true,"keyType":3}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> DATA (6,1,0): 1e00016a0003
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: --> [615c21a93e2a167f587e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -?- waiting (7)
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [165fb1a97d312a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7d5e7f2826668cef8fbeeb5bd5d270177e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (1,6,0): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (6): 165fb1a9112a15b25996ca25aa5593499c0dd8abedce9874ecc46389fc7e7f2826668cef8fbeeb5bd5d270177e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: Unexpected packet sequence 6 | 7
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1d90014500000000028000000001000043ff000000ffff110200000000408fcdab528000412c800000
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x45: {"_cls_":"incomingMessageHandler","_id_":69,"_isRequest_":false,"type":0,"apsFrame":{"profileId":0,"sequence":67,"clusterId":32770,"sourceEndpoint":0,"destinationEndpoint":0,"groupId":0,"options":256},"lastHopLqi":255,"lastHopRssi":0,"sender":0,"bindingIndex":255,"addressIndex":255,"message":{"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp  frame: {"type":"Buffer","data":[2,0,0,0,0,64,143,205,171,82,128,0,65,44,128,0,0]}
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: Node_Desc_rsp parsed: {"_cls_":"nodeDescRsp","_id_":32770,"transId":2,"status":0,"nwkaddr":0,"descriptor":{"byte1":0,"byte2":64,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- [275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e]
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- DATA (2,7,0): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: <-- ACK (7): 275ca1a93e2a15b159978f4340c738bfebac33a1ff4ee34440546259277f3fa7ebcdde6f8fffc7dbd5d26929897e
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== Frame: 1e80016a0000030003c566ea92aaf677e2140a128084cfbd9201d0db0100000000000000000000000000
          [2024-11-19 10:28:53] debug:    zh:ezsp:ezsp: <== 0x6a: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
          [2024-11-19 10:28:53] debug:    zh:ezsp:uart: -+- waiting (7) success
          [2024-11-19 10:28:53] debug:    zh:ezsp:driv: CURRENT_NETWORK_KEY: {"_cls_":"getKey","_id_":106,"_isRequest_":false,"status":0,"keyStruct":{"key":{"contents":[197,102,234,146,170,246,119,226,20,10,18,128,132,207,189,146]},"outgoingFrameCounter":31182849,"sequenceNumber":0,"bitmask":3,"type":3,"incomingFrameCounter":0,"partnerEUI64":{"type":"Buffer","data":[0,0,0,0,0,0,0,0]}}}
          ^C[2024-11-19 10:28:53] debug:  zh:controller:device: Request Queue (0x84b4dbfffebc827e): default expiration timeout set to 0
          [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffeae693): default expiration timeout set to 0
          [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x282c02bfffec950b): default expiration timeout set to 0
          [2024-11-19 10:28:53] debug:    zh:controller:device: Request Queue (0x003c84fffe18aed5): default expiration timeout set to 43200000
          [2024-11-19 10:28:53] debug:    z2m: Saving state to file /opt/zigbee2mqtt/data/state.json
          [2024-11-19 10:28:53] error:    z2m: Not connected to MQTT server!
          [2024-11-19 10:28:53] error:    z2m: Cannot send message: topic: 'zigbee2mqtt/bridge/state', payload: '{"state":"offline"}
          [2024-11-19 10:28:53] info:     z2m: Disconnecting from MQTT server
          [2024-11-19 10:28:53] info:     z2m: Stopping zigbee-herdsman...
          [2024-11-19 10:28:53] debug:    zh:controller:database: Writing database to '/opt/zigbee2mqtt/data/database.db'
          [2024-11-19 10:28:53] info:     z2m: Stopped zigbee-herdsman
          [2024-11-19 10:28:53] info:     z2m: Stopped Zigbee2MQTT
            tklein
            hier mal die mqtt logs:
            mqtt.02024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:31:44.865	info	Client [mqttjs_b6def4ee] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:31:44.835	info	Client [mqttjs_b6def4ee] connected with secret 1732001504835_6979
            mqtt.0	2024-11-19 08:31:26.479	info	Client [mqttjs_297b7318] connection closed: disconnected
            mqtt.0	2024-11-19 08:30:03.883	info	Client [mqttjs_297b7318] publishOnSubscribe send all known states
            mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:30:03.684	info	Client [mqttjs_297b7318] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:30:03.653	info	Client [mqttjs_297b7318] connected with secret 1732001403653_5414
            mqtt.0	2024-11-19 08:29:45.478	info	Client [mqttjs_3e32c692] connection closed: disconnected
            mqtt.0	2024-11-19 08:28:22.870	info	Client [mqttjs_3e32c692] publishOnSubscribe send all known states
            mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:28:22.671	info	Client [mqttjs_3e32c692] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:28:22.640	info	Client [mqttjs_3e32c692] connected with secret 1732001302640_1750
            mqtt.0	2024-11-19 08:28:04.478	info	Client [mqttjs_f14b52fd] connection closed: disconnected
            mqtt.0	2024-11-19 08:26:41.793	info	Client [mqttjs_f14b52fd] publishOnSubscribe send all known states
            mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:26:41.593	info	Client [mqttjs_f14b52fd] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:26:41.564	info	Client [mqttjs_f14b52fd] connected with secret 1732001201564_9659
            mqtt.0	2024-11-19 08:26:23.478	info	Client [mqttjs_9029bbbb] connection closed: disconnected
            mqtt.0	2024-11-19 08:25:01.034	info	Client [mqttjs_9029bbbb] publishOnSubscribe send all known states
            mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^mqtt\.0\.zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:25:00.834	info	Client [mqttjs_9029bbbb] subscribes on "zigbee2mqtt/#" with regex /^zigbee2mqtt\..*/
            mqtt.0	2024-11-19 08:25:00.805	info	Client [mqttjs_9029bbbb] connected with secret 1732001100805_685
            mqtt.0	2024-11-19 08:24:42.478	info	Client [mqttjs_93e5d70e] connection closed: disconnected
            • arteckA Offline
              arteckA Offline
              arteck
              du musst den schon länger laufen lassen bist der wieder ein
              Start try again in 1 seconds...
              anzeigt...
              • arteckA arteck
                anzeigt...
                tklein
                @arteck
                die ausgabe in eine datei ist nicht lange gelaufen. dann kam das:
                root@iobroker:/opt/zigbee2mqtt# sudo service zigbee2mqtt stop
                root@iobroker:/opt/zigbee2mqtt# npm start >> zigbee2mqtt_log.txt
                /opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264
                  var er = new ERR_STREAM_WRITE_AFTER_END();
                Error: write after end
                    at writeAfterEnd (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:264:12)
                    at DerivedLogger.Writable.write (/opt/zigbee2mqtt/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:300:21)
                    at DerivedLogger.log (/opt/zigbee2mqtt/node_modules/winston/lib/winston/logger.js:231:12)
                    at Logger.log (/opt/zigbee2mqtt/lib/util/logger.ts:189:25)
                    at Logger.debug (/opt/zigbee2mqtt/lib/util/logger.ts:210:14)
                    at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                    at Object.onceWrapper (node:events:634:26)
                    at Socket.emit (node:events:531:35)
                    at TCP.<anonymous> (node:net:339:12)
                Hier die Datei:
                zigbee2mqtt_log.txt
                  tklein
                  hier noch die configuration.yaml:
                  homeassistant: false
                  frontend: true
                  mqtt:
                    base_topic: zigbee2mqtt
                    server: mqtt://192.168.0.22:1888
                  serial:
                    port: tcp://192.168.0.33:6638
                    baudrate: 115200
                    adapter: ezsp
                  advanced:
                    network_key:
                      - 197
                      - 102
                      - 234
                      - 146
                      - 170
                      - 246
                      - 119
                      - 226
                      - 20
                      - 10
                      - 18
                      - 128
                      - 132
                      - 207
                      - 189
                      - 146
                    pan_id: 1748
                    ext_pan_id:
                      - 106
                      - 111
                      - 32
                      - 69
                      - 142
                      - 92
                      - 130
                      - 83
                    homeassistant_legacy_entity_attributes: false
                    legacy_api: false
                    legacy_availability_payload: false
                    log_level: debug
                  device_options:
                    legacy: false
                  devices:
                    '0x282c02bfffeae693':
                      friendly_name: wassersensor_1
                    '0x282c02bfffec950b':
                      friendly_name: '0x282c02bfffec950b'
                    '0x003c84fffe18aed5':
                      friendly_name: '0x003c84fffe18aed5'
                    tklein
                    mit
                    sudo journalctl -u zigbee2mqtt.service -f
                    kam folgendes:
                    Nov 19 13:23:08 iobroker node[20281]:     at SerialDriver.onPortClose (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:380:16)
                    Nov 19 13:23:08 iobroker node[20281]:     at Object.onceWrapper (node:events:634:26)
                    Nov 19 13:23:08 iobroker node[20281]:     at Socket.emit (node:events:531:35)
                    Nov 19 13:23:08 iobroker node[20281]:     at TCP.<anonymous> (node:net:339:12)
                    Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Main process exited, code=exited, status=1/FAILURE
                    Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Failed with result 'timeout'.
                    Nov 19 13:23:08 iobroker systemd[1]: Failed to start zigbee2mqtt.service - zigbee2mqtt.
                    Nov 19 13:23:08 iobroker systemd[1]: zigbee2mqtt.service: Consumed 2.326s CPU time.
                    Nov 19 13:23:18 iobroker systemd[1]: zigbee2mqtt.service: Scheduled restart job, restart c
                    • T tklein
                      @arteck
                      Hier die Datei:
                      zigbee2mqtt_log.txt
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @tklein haswt du einen mosquitto installiert als mqtt server ??
                      • arteckA arteck
                        tklein
                        @arteck
                        brauche ich den, wenn der iob mqtt als server läuft?
                        • T tklein
                          @arteck
                          arteckA Offline
                          arteckA Offline
                          arteck
                          @tklein sagte in Zigbee2MQTT auf LNX mit zyklischen Warnings:
                          @arteck
                          da scheint irgendwas mit dem mqtt nicht zu stimmen...
                          stell mal den adapter so ein
                          und in der yaml von zigbee2mqtt mustt du es auch anpassten
                          server: mqtt://192.168.0.22:1884
                          • arteckA arteck
                            @arteck
                            tklein
                            @arteck jetzt sind die warnings weg :-) thx dafür
                            ist das ein normales verhalten?
                            zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m: Zigbee2MQTT started!
                            zigbee2mqtt.02024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                            zigbee2mqtt.0 2024-11-20 09:12:59.275	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                            zigbee2mqtt.0 2024-11-20 09:12:59.274	info	z2m: Started frontend on port 8080
                            zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m: Zigbee2MQTT started!
                            zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                            zigbee2mqtt.0 2024-11-20 09:11:18.123	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                            zigbee2mqtt.0 2024-11-20 09:11:18.122	info	z2m: Started frontend on port 8080
                            zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Zigbee2MQTT started!
                            zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                            zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                            zigbee2mqtt.0 2024-11-20 09:09:36.983	info	z2m: Started frontend on port 8080
                            zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Zigbee2MQTT started!
                            zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0x282c02bfffec950b', payload '{"battery":99,"battery_low":false,"linkquality":196,"tamper":false,"update":{"installed_version":40,"latest_version":53,"state":"available"},"vibration":false,"voltage":3200,"x_axis":46,"y_axis":-46,"z_axis":1031}'
                            zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/wassersensor_1', payload '{"battery":100,"battery_low":false,"linkquality":224,"tamper":false,"update":{"installed_version":58,"latest_version":66,"state":"available"},"voltage":3200,"water_leak":false}'
                            zigbee2mqtt.0 2024-11-20 09:07:55.987	info	z2m: Started frontend on port 8080
                            zigbee2mqtt.0 2024-11-20 09:06:15.147	info	z2m: Zigbee2MQTT started!
                            hier noch die logs on der gui des coordinators:
                            [09:07:49] taskZB | New client: 192.168.0.22 id: 0
                            [09:09:19] taskZB | Client disconnected, id: 0
                            [09:09:30] taskZB | New client: 192.168.0.22 id: 0
                            [09:11:00] taskZB | Client disconnected, id: 0
                            [09:11:11] taskZB | New client: 192.168.0.22 id: 0
                            [09:12:41] taskZB | Client disconnected, id: 0
                            [09:12:52] taskZB | New client: 192.168.0.22 id: 0
                            [09:14:22] taskZB | Client disconnected, id: 0
                            [09:14:33] taskZB | New client: 192.168.0.22 id: 0
                            [09:16:03] taskZB | Client disconnected, id: 0
                            [09:16:14] taskZB | New client: 192.168.0.22 id: 0
