  4. Test Adapter Energiefluss-erweitert v0.8.x GitHub/Latest
diagrammenergieflussenergiefluss-erweitertvisvisualisierungvisualization
1.7k Beiträge 78 Kommentatoren 1.1m Aufrufe 78 Beobachtet
  • W warp735
    @skb
    na die aktuelle stable. Glaub 0.4.1 ist das
    energiefluss-erweitert.0
    	2024-11-10 12:03:22.852	debug	State changed! New value for Source: modbus.3.holdingRegisters.5.672_PV1_input_power with Value: 859 belongs to Elements: 2
    	2024-11-10 12:03:22.852	debug	Found corresponding animations for ID: modbus.3.holdingRegisters.5.672_PV1_input_power !Applying!
    	2024-11-10 12:03:22.852	debug	Threshold for: 2 is: 0
    	2024-11-10 12:03:22.852	debug	Value-Settings for Element 2 found! Applying Settings!
    	2024-11-10 12:03:22.852	debug	Updated through sources: {"0":859,"1":-1122,"2":52,"3":40,"4":150000}
    	2024-11-10 12:03:22.852	debug	Refreshing ACK state from foreign state!
    	2024-11-10 12:03:22.726	debug	Direction: discharge Battery-Time: 16:03h Percent: 52 Energy: 1122
    	2024-11-10 12:03:22.719	debug	State changed! New value for Source: modbus.3.holdingRegisters.5.590_Battery_output_power with Value: -1122 belongs to Elements: 16
    	2024-11-10 12:03:22.719	debug	Value: -1122 is greater than Threshold: 0. Applying Animation!
    	2024-11-10 12:03:22.719	debug	Animation has a negative factor!
    	2024-11-10 12:03:22.719	debug	Animation - Settings for Element anim_path_5_13 found! Applying Settings!
    	2024-11-10 12:03:22.719	debug	Found corresponding animations for ID: modbus.3.holdingRegisters.5.590_Battery_output_power !Applying!
    	2024-11-10 12:03:22.719	debug	Threshold for: 16 is: 0
    	2024-11-10 12:03:22.719	debug	Value-Settings for Element 16 found! Applying Settings!
    	2024-11-10 12:03:22.719	debug	Updated through sources: {"0":873,"1":-1122,"2":52,"3":40,"4":150000}
    	2024-11-10 12:03:22.719	debug	Refreshing ACK state from foreign state!
    	2024-11-10 12:03:06.953	debug	State changed! New value for Source: modbus.3.holdingRegisters.5.672_PV1_input_power with Value: 873 belongs to Elements: 2
    	2024-11-10 12:03:06.953	debug	Found corresponding animations for ID: modbus.3.holdingRegisters.5.672_PV1_input_power !Applying!
    	2024-11-10 12:03:06.952	debug	Threshold for: 2 is: 0
    SKBS Offline
    SKBS Offline
    SKB
    #571
    @warp735 Dann installier mal bitte die aktuelle Alpha von GitHub. Damit sollte dann die gewünschte Ausgabe kommen.
    W 1 Antwort Letzte Antwort
    • SKBS SKB
      W Offline
      W Offline
      warp735
      #572
      @skb
      Also passt der Wert doch net? ;-)
      Ne, ich installier grundsätzlich nix über die Katze. Ich schau einfach in paar Monaten nochmal, ob was neueres im stable liegt. Dank dir erstmal.
      SKBS 1 Antwort Letzte Antwort
      • W warp735
        @skb
        SKBS Offline
        SKBS Offline
        SKB
        #573
        @warp735 Diese Alpha Version enthält nur 2 Darstellungsfehler - somit ist sie nahezu sicher.
        Würde mir helfen - wenn hier ein Fehler vorhanden ist - damit dieser dann nicht im Stable landet.
        Die Berechnung meines Excel Ausschnitts sollte doch für dich so passen, oder? Das ist, wie der aktuelle Adapter rechnet.
        Fehlt also nur die Verifizierung durch dich - wenn's genehm wäre.
        • SKBS SKB
          W Offline
          W Offline
          warp735
          #574
          @skb sagte in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
          So kann man natürlich ewig argumentieren.
          Sorry, helfe gern, aber alpha Tester mach ich sicher nicht. Und persönlich mag ich dieses jahrelange im beta entwickle auch nicht unterstützen.
          Ist ja leider Standard bei ioBroker. Im stable passiert jahrelang nix und es passiert alles immer nur im beta oder auf git. Und wenn man dann nen Fehler hat, heißt´s nur: hast ja auch keine stable Version...
          Hab jetzt die Versionen seit April nicht gezählt, aber wird überhaupt mal wieder nen stable angestrebt?
          • W warp735
            SKBS Offline
            SKBS Offline
            SKB
            #575
            @warp735 Natürlich bin ich bestrebt, neue Versionen ins Stable zu bringen - das ist ja der Sinn vom Testen.
            Leider ist aktuell eine "kleine Flut" von Ideen, die nach und nach kommen - somit dauert das stable ein wenig (länger).
            Hinzu kommt auch, das natürlich eine Alpha auch Fehler enthält und ich schon wieder an einer neuen Version dran bin - dann überschlägt und zieht sich das ein wenig.
            Wie gesagt, mir würde es helfen, wenn Du diese Alpha installieren könntest, damit bestätigt ist, das die Berechnung nun stimmt - denn hier kann ich aktuell nur mit einer Alpha dienen und nicht eine stable veröffentlichen, die womöglich einen Fehler der Berechnung weiter mitschleppt.
            • SKBS SKB
              W Offline
              W Offline
              warp735
              #576
              Wenn wie oben in deiner Excel gerechnet wird, dann sollte das passen. Denk hier sind genug Tester mit Batterie, die kurz sagen können ob es stimmt oder nicht (wobei mich schon wundert warum das bis jetzt niemand aufgefallen ist)
              Dafür muss ich jetzt nicht auch nochmal ne alpha installieren.
              SKBS C 2 Antworten Letzte Antwort
              • W warp735
                SKBS Offline
                SKBS Offline
                SKB
                #577
                @warp735 Verstehe. Ich denke aber, das ich die Berechnung in einer anfänglichen Alpha bereits korrigiert habe - somit dürfte dies weiterhin funktionieren.
                Auch plane ich, die aktuelle Alpha - sollten keine Fehler auffallen - bald ins Stable zu bringen.
                • W warp735
                  c1olli
                  #578
                  @warp735
                  Ich z.B. nutze die Berechnungen im Adaper nicht, da baue ich mir eigene Datenpunkte, da diese auch gerne noch woanders nutze.
                  Deine Argumentation den neuen Adapter nicht zu nutzen finde ich echt traurig, denn nur durch Mithilfe wird so ein Adapter besser.
                  Du müsstest Deinen alten Adapter ja nicht einmal löschen, sondern könntest ein Duplikat erstellen und den neueren Adapter dort parallel installieren.
                  Oder setzt Du Dich immer ins gemachte Nest?
                  Olli
                  • SKBS SKB
                    @akwf Wohin genau hast du diesen Code denn kopiert? Linie oder Animation?
                    Welcher Browser Wire verwendet? Geht denn dieser Wert auch über 60? Ein Datenpunkt ist zugewiesen?
                    akwf
                    #579
                    @skb hallo, ich habe den Code unter Animation eingefügt. Datenpunkt ist auch vorhanden und zeigt Werte über 60 auch an. Als Browser habe ich auf meinen Tablet einmal Firefox für Android und dann probeweise noch Chrome ausprobiert. Es ändert sich nicht die Farbe der Animationspunkte.
                    Hab es auch nochmals auf meinen Laptop mit W11 und Firefox probiert, ebenfalls ergebnislos.
                    • A akwf
                      SKBS Offline
                      SKBS Offline
                      SKB
                      #580
                      @akwf Verwendest Du die aktuelle Alpha.10?
                      Dort greifen aktuell die Überschreibungen nur beim ersten Mal. Behebe ich als bald als möglich!
                      • SKBS SKB
                        akwf
                        #581
                        @skb ich nutze Release v0.5.1-alpha.10 und werde auf die korrigierte Nachfolgeversion warten.
                        Danke für die Anworten/Hilfe.
                        • C c1olli
                          @warp735
                          W Offline
                          W Offline
                          warp735
                          #582
                          @c1olli sagte in Test Adapter Energiefluss-erweitert v0.5.x-alpha.x GitHub:
                          Warum antwortest dann darauf?
                          Also sind jetzt alle ~80k ioBroker User plötzlich Alpha Tester bzw MÜSSEN das deiner Meinung nach sein?! Dann frag ich mich, warum es überhaupt ein stable repo gibt?
                          C 1 Antwort Letzte Antwort
                          • W warp735
                            c1olli
                            #583
                            @warp735
                            Nein natürlich nicht, aber es ging ja um Deine Art der Argumentation - also nicht anderen die Worte im Mund umdrehen.
                            Nur nutzen und dann noch über eine kostenfreie Sache meckern finde eben nicht gerade nett oder zielführend.
                            Ich habe mit Programmieren auch nicht viel am Hut, versuche aber beizutragen.
                            Olli
                            • SKBS Offline
                              SKBS Offline
                              SKB
                              #584
                              Hallo Zusammen,
                              ich habe soeben eine neue Version auf Github geladen. Es ist die 0.5.1-alpha.11!
                              Folgendes ist neu bzw. verbessert:
                              • FIX: Overrides wurden nicht korrekt angewendet (#272)
                              • FIX: Zeitstempel der letzten Änderung war Zeitstempel der letzten Aktualisierung (#279)
                              • FIX: Schriftgröße konnte nicht geändert werden
                              • Hinzugefügt: Verbesserte Benutzeroberfläche
                              • Hinzugefügt: Informationssymbol in der Live-Ansicht, um den Benutzer über aufgetretene Fehler zu informieren
                              • Hinzugefügt: Responsive Design für den Adapter-Admin-Bereich hinzugefügt, um neuen Anforderungen gerecht zu werden
                              • Hinzugefügt: Hinzugefügt: Zeitstempel der letzten Änderung für Datenquellenelemente. Entspricht Fix (#279)
                              Es wäre schön, wenn ihr Euch direkt meldet, sollten Fehler auftreten.
                              Ich plane nun erstmal keine Änderungen ein, da ich gerne diese Version dann zeitnah ins stable bringen möchte!
                              Vielen Dank! ;)
                              C H P mickemupM A 5 Antworten Letzte Antwort
                              • SKBS SKB
                                Hallo Zusammen,
                                Vielen Dank! ;)
                                c1olli
                                #585
                                @skb
                                Läuft 👍 👍 👍
                                Olli
                                • SKBS SKB
                                  Hallo Zusammen,
                                  Vielen Dank! ;)
                                  Hakemann
                                  #586
                                  @skb Overrides gehen bei mir mit 11 wieder. 👍
                                  • C c1olli
                                    @skb
                                    Läuft 👍 👍 👍
                                    SKBS Offline
                                    SKBS Offline
                                    SKB
                                    #587
                                    @c1olli @Hakemann Vielen Dank für die Rückmeldung! Warten wir noch einige andere Meldungen ab ;)
                                    • SKBS SKB
                                      Hallo Zusammen,
                                      Vielen Dank! ;)
                                      ps1304
                                      schrieb am zuletzt editiert von ps1304
                                      #588
                                      @skb bei mir gehen wohl 2 Überschreibungen nicht:
                                      damit will ich den Batteriestand farblich darstellen - das Rechteck bleibt grau
                                          ">0": {
                                              "borderfillcolor": "#FF0000",
                                              "bordercolor": "rgb(6,28,33)",
                                              "fillcolor": "#FF0000"
                                          ">25": {
                                              "borderfillcolor": "#E8BB43",
                                              "fillcolor": "#E8BB43"
                                          ">50": {
                                              "borderfillcolor": "rgb(45,224,212)",
                                              "fillcolor": "rgb(45,224,212)"
                                          ">75": {
                                              "borderfillcolor": "#86B038",
                                              "fillcolor": "#86B038"
                                      • P ps1304
                                            ">0": {
                                            ">25": {
                                            ">50": {
                                            ">75": {
                                        SKBS Offline
                                        SKBS Offline
                                        SKB
                                        #589
                                        @ps1304 Ist die Füllung für das Rechteck denn aktiv?
                                        Ich sehe dort auch viele BorderFills.
                                        Geht die Überschreibung jetzt nicht oder ging sie vorher schon nicht?
                                        P 1 Antwort Letzte Antwort
                                        • SKBS SKB
                                          ps1304
                                          #590
                                          @skb ging bis V10 - was meinst du mit aktiv?
                                          Gruß Peter
