  4. jarvis v3.0.0 - just another remarkable vis
4.5k Beiträge 254 Kommentatoren 3.2m Aufrufe 209 Beobachtet
  • M MCU
    @kuddel Sieht sonst normal aus
    Kuddel
    schrieb am zuletzt editiert von Kuddel
    #4398
    @mcu
    aktuell macht mein javascript nicht nicht was es soll.
    Infos der verbundenen Clients in den JSON DP schreiben funzt, der offline Clients noch nicht.
    Da bin ich aber dran.
    So jetzt läuft es. Hier das JSON File
    [{"client_status":"🟢","client_name":"Daniel-Handy","client_ip":"*.*.*.*","client_transfer_formatted_dl":"0.03 GB","client_transfer_formatted_ul":"0.51 GB","client_latest_handshake":"Di. 15.10.2024 - 14:59 Uhr","client_origin_flag":"<img src=\"https://cdn.ipwhois.io/flags/de.svg\" style=\"width:20px;height:20px;\">","client_origin":"Bremen / Vodafone GmbH"},{"client_status":"🔴","client_name":"Jenny-Handy","client_ip":"","client_transfer_formatted_dl":"","client_transfer_formatted_ul":"","client_latest_handshake":"","client_origin_flag":"","client_origin":""},{"client_status":"🔴","client_name":"GalaxyS7","client_ip":"","client_transfer_formatted_dl":"","client_transfer_formatted_ul":"","client_latest_handshake":"","client_origin_flag":"","client_origin":""},{"client_status":"🔴","client_name":"DELL","client_ip":"","client_transfer_formatted_dl":"","client_transfer_formatted_ul":"","client_latest_handshake":"","client_origin_flag":"","client_origin":""},{"client_status":"🔴","client_name":"Galaxy-Tab","client_ip":"","client_transfer_formatted_dl":"","client_transfer_formatted_ul":"","client_latest_handshake":"","client_origin_flag":"","client_origin":""},{"client_status":"🔴","client_name":"XMG","client_ip":"","client_transfer_formatted_dl":"","client_transfer_formatted_ul":"","client_latest_handshake":"","client_origin_flag":"","client_origin":""}]
    • ? Offline
      #4399
      ich hab mal eine saudumme Frage:
      Wir haben Jarvis seit der ersten Stunde in der alten (?) ioBroker App auf dem iPhone eingebunden, was auch einwandfrei funktioniert:
      Oben bei der Notch und auch nach unten hin beim Balken zum App-Swipe ist reichlich Platz und behindert nicht die Bedienung.
      Nun würden wir gerne auf die ioBroker Visu App wechseln, da diese ein paar nette Features wie Face-ID etc. mit sich bringt.
      Jetzt habe ich aber zwei Probleme:
      1. Durch die fehlenden Abstände unten habe ich immer das Thema, dass ich bei der Tab-Bar unten Gefahr laufe, ungewollt den App-Swipe auszulösen.
      2. Ist generell immer die Notch im Weg. Lege ich die Tab-Bar nach oben, wird sie durch die Notch verdeckt.
      Gibt es eine Möglichkeit in Jarvis unten oder oben "Leerraum" zu schaffen um das ganze etwas zu verschieben?
      • M Online
        M Online
        MCU
        #4400
        @hunduster Also der Leerraum soll oben sein?
        /* Tab-Auswahl ist oben */
        .jarvis-tabs-container {
        	padding-top: 40px;
        /* muss immer +5px vom tabs-container sein */
        .container.desktop {
        	padding-top: 45px!important;
        Nur fürs Handy
        /* 1px mehr als Handybreite */
        @media all and (max-width:413px) {
        		padding-top: 40px;
        • M MCU
          	padding-top: 40px;
          Nur fürs Handy
          		padding-top: 40px;
          #4401
          @mcu ja genau, das geht in die richtige Richtung, vielen Dank!
          Der Code nur für Handy bewirkt bei mir leider gar nichts. Der erstere geht hingegen. Problem ist dann nur, dass ich zwar die Tab-Bar weiter nach unten legen kann, sie sich dann aber über die Widgets legt und diese bedeckt. De Widgets rutsch nicht mit nach unten.
          • ? Offline
            #4402
            Hab es nun glaube ich hinbekommen, indem ich mir oben noch ein Widget gesetzt habe auf dem Dashboard. Da durch ist alles ein paar Pixel nach unten gerutscht. Passt für mich. Danke dir @MCU !
              M Online
              M Online
              MCU
              #4403
              @hunduster Du musst beim Handy die richtige Breite einstellen. Es scheint Dein Handy ist breiter als 413px.
              Dann nutze mal 600px?
              Es muss beides nach unten gehen, welche Version nutzt du?
              Ich habe es für v3.2.0-rc.5 getestet.
              • M MCU
                #4404
                @mcu aktuell habe ich 3.1.8.
                Wenn ich die Breite auf 600px und die Höhe auf 50px stelle passt es. Ich muss mit den Werten mal rum spielen, da ich das iPhone Max und meine Frau das Normale hat.
                Dumme Frage: ginge es auch, selbiges bei der Tab-Bar unten zu realisieren? Irgendwie ist es hübscher, wenn die Tab-Bar unten ist. Sie müsste dann nur etwas nach oben gedrückt werden, der Space also unter und nicht über den Buttons sein, damit man nicht immer an den App-Swipe dran kommt. Ich finde im Debug Modus des Browsers leider nicht den passenden Parameter.
                  M Online
                  M Online
                  MCU
                  #4405
                  @hunduster Man kann die Tab-Bar nach oben schieben, man sieht dann aber die Seite drunter.
                  Mit padding statt margin sieht es besser aus.
                  	.jarvis-footer {
                  		padding-bottom: 20px!important;
                  • M MCU
                    	.jarvis-footer {
                    #4406
                    @mcu das ist perfekt!
                    Ich habe das max-width wieder auf 600 angepasst und nun passt das. Es entsteht ein schmaler weißer Streifen aber das stört nicht die Bohne, da hier dann der Balken für den App Switch liegt. Sieht sogar schick aus. Danke dir!
                      bastian-m
                      #4407
                      @hunduster sagte in jarvis v3.0.0 - just another remarkable vis:
                      Kurze Zwischenfrage am Rande von einem Jarvis-Einsteiger: Mit welchen Widget-Elementen machst du diese schöne simple Darstellung mit jeweils dem großen Icon, Unterschrift + Datenwert
                      Liebe Grüße und schönes Wochenende!
                      Bastian
                      • B bastian-m
                        Bastian
                        M Online
                        M Online
                        MCU
                        #4408
                        @bastian-m HomeKitTile
                        • F Offline
                          firechumper
                          #4409
                          Hallo Zusammen,
                          ich verzweifel gerade daran bei einem HomeKitTile einen Umbruch hinzubekommen.
                          Was mache ich falsch?!
                          • F firechumper
                            Hallo Zusammen,
                            M Online
                            M Online
                            MCU
                            #4410
                            @firechumper
                            1. falscher Thread -> v3.2.x-Thread
                            2. Ist der DP-Inhalt vorgegeben vom Adapter oder selbst erstellt?
                            • <br> nutzen
                            • .middle .center zusammensetzen
                            .jarvis-widget-.... .middle.center {
                            F 1 Antwort Letzte Antwort
                            • M MCU
                              @firechumper
                              • <br> nutzen
                              firechumper
                              #4411
                              @mcu
                              Sorry für falschen Thread :-/
                              Vielen Dank für deine Hilfe.
                              Den Namen habe ich selbst geändert in Jarvis. Den Umbruch kann ich wahrscheinlich nicht bestimmen oder? Er macht das jetzt nach jedem Leerzeichen (wo ich das <br> einfügen kann habe ich nicht ganz geschnallt sorry)
                              Lösung war wirklich das Leerzeichen zwischen middle.center (stand allerdings auch so in der Doku mit Leerzeichen)
                              So funktioniert es mal (allerdings mit Umbruch nach jedem Leerzeichen).
                              • F firechumper
                                @mcu
                                M Online
                                M Online
                                MCU
                                #4412
                                @firechumper sagte in jarvis v3.0.0 - just another remarkable vis:
                                Wo?
                                • M MCU
                                  Wo?
                                  firechumper
                                  #4413
                                  @mcu
                                  https://mcuiobroker.gitbook.io/jarvis-infos/jarvis-v3/besonderheiten-v3/styles/.q-card-+-widgets-id
                                  Hier :-)
                                  M 2 Antworten Letzte Antwort
                                  • F firechumper
                                    @mcu
                                    Hier :-)
                                    M Online
                                    M Online
                                    MCU
                                    #4414
                                    @firechumper Korrigiert, Danke.
                                    • F firechumper
                                      @mcu
                                      Hier :-)
                                      M Online
                                      M Online
                                      MCU
                                      #4415
                                      @firechumper
                                      Liegt an der Breite vom Widget?
                                      • M MCU
                                        @firechumper
                                        firechumper
                                        #4416
                                        @mcu
                                        Gut Möglich… allerdings will ich dir Breite nicht anpassen. Ein gesteuerter Umbruch nach einem bestimmten Wort wird nicht möglich sein oder?
                                        • F firechumper
                                          @mcu
                                          M Online
                                          M Online
                                          MCU
                                          #4417
                                          @firechumper Wenn du den DP-Inhalt selbst eingibst, Trennung mit <br>.
                                          Ist das Label oder State?
