  4. Änderungen iob CLI/Installer/Fixer mit Root Accounts
202 Beiträge 25 Kommentatoren 59.7k Aufrufe 30 Beobachtet
    @chaot
    Versuch mal den Fixer direkt zu laden:
    curl -fsL https://iobroker.net/fix.sh | bash -
    ChaotC Offline
    ChaotC Offline
    Chaot
    #166
    könnte klappen, wenn ich den iobroker stoppen kann
    haus@ioBroker:~$ iob stop
    Could not send "SIGTERM" to process 201: kill EPERM
    No "killall.sh" script found. Just stop.
    haus@ioBroker:~$ curl -fsL https://iobroker.net/fix.sh | bash -
    Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
    library: loaded
    Library version=2024-10-22
    ioBroker or some processes are still running:
    201 iobroker.js-con
    408 io.admin.0
    419 io.javascript.0
    449 io.email.0
    478 io.influxdb.0
    513 io.whatsapp-cmb
    528 io.history.0
    539 io.tr-064.0
    558 io.sonoff.0
    637 io.proxmox.0
    666 io.backitup.0
    816 io.nut.0
    831 io.alexa2.0
    842 io.unifi.0
    873 io.ems-esp.0
    888 io.drag-indicat
    903 io.tuya.0
    918 io.web.0
    972 io.tankerkoenig
    1178 io.fritzdect.0
    1185 io.phantomjs.0
    1263 io.nina.0
    1309 io.trashschedul
    1401 io.sourceanalyt
    1438 io.wled.0
    1453 io.vis-inventwo
    1468 io.smartcontrol
    1479 io.linux-contro
    1498 io.time-switch.
    1564 io.upnp.0
    1575 io.mytime.0
    1586 io.ws.0
    1620 io.rssfeed.0
    1632 io.alexa-timer-
    1647 io.wiegand-tcpi
    1662 io.drops-weathe
    Please stop them first and try again!
    haus@ioBroker:~$
    • ChaotC Chaot
      library: loaded
      201 iobroker.js-con
      408 io.admin.0
      419 io.javascript.0
      449 io.email.0
      478 io.influxdb.0
      513 io.whatsapp-cmb
      528 io.history.0
      539 io.tr-064.0
      558 io.sonoff.0
      637 io.proxmox.0
      666 io.backitup.0
      816 io.nut.0
      831 io.alexa2.0
      842 io.unifi.0
      873 io.ems-esp.0
      888 io.drag-indicat
      903 io.tuya.0
      918 io.web.0
      972 io.tankerkoenig
      1178 io.fritzdect.0
      1185 io.phantomjs.0
      1263 io.nina.0
      1438 io.wled.0
      1564 io.upnp.0
      1575 io.mytime.0
      1586 io.ws.0
      1620 io.rssfeed.0
      haus@ioBroker:~$
      #167
      @chaot
      sudo systemctl stop iobroker
        @chaot
        ChaotC Offline
        ChaotC Offline
        Chaot
        #168
        Danke. Deine "Zauberfinger" haben mir das wieder gerade gebogen
        ```bash
                               v.2024-10-19
          Static hostname: ioBroker
                Icon name: computer-container
                  Chassis: container
           Virtualization: lxc
         Operating System: Ubuntu 20.04.6 LTS
                   Kernel: Linux 6.5.13-5-pve
             Architecture: x86-64
        Installation:           lxc
        Kernel:                 x86_64
        Userland:               64 bit
        User-ID:                1001
        Display-Server:         false
        Boot Target:            multi-user.target
        Pending OS-Updates:     0
        Pending iob updates:    1
        Nodejs-Installation:
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        Recommended versions are nodejs  and npm 10.8.2
        nodeJS installation is correct
        MEMORY:
        Mem:           6.1G        3.7G        735M        1.0M        1.7G        2.4G
        Swap:          2.0G          0B        2.0G
        Total:         8.2G        3.7G        2.8G
        Active iob-Instances:   6
        Upgrade policy: none
        ioBroker Core:          js-controller           6.0.11
                               admin                   7.2.6
        Objects type: jsonl
        States  type: redis
        + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
         system.adapter.admin.1                  : admin                 : ioBroker                                 - disabled, port: 80, bind: 0.0.0.0, run as: admin
         system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        Objects:                2
        States:                 29089
        Size of iob-Database:
        29M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/objects.json.migrated
        21M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        8.0K    /opt/iobroker/iobroker-data/states.json
        4.0K    /opt/iobroker/iobroker-data/states.json.bak
        Operating System codenamed 'focal' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
        === Mark text until here for copying ===
        [/s]
        • ChaotC Chaot
          ```bash
                                 v.2024-10-19
                    Chassis: container
             Virtualization: lxc
          Installation:           lxc
          Kernel:                 x86_64
          Userland:               64 bit
          User-ID:                1001
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          MEMORY:
          Swap:          2.0G          0B        2.0G
                                 admin                   7.2.6
          Objects type: jsonl
          States  type: redis
          Objects:                2
          States:                 29089
          [/s]
          #169
          @chaot
          Okay, iob stop / iob start sowie iob fix funktionieren jetzt wieder im direkten Aufruf?
            @chaot
            ChaotC Offline
            ChaotC Offline
            Chaot
            #170
            @thomas-braun Ja, alles wieder wie gewohnt. Der neue Fixer hat auch gleich die GUI ausgeschaltet (die mir nicht bewusst war). Funktioniert also alles wieder wie gewohnt.
            Herzlichen Dank
            • ChaotC Chaot
              Herzlichen Dank
              #171
              @chaot sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
              Na ich hoffe aber, das du wenigstens gefragt wurdest und das aktiv per y-Taste bestätigt hast?
                ChaotC Offline
                ChaotC Offline
                Chaot
                #172
                @thomas-braun Ja, aber beim ersten Durchlauf lief der fixer nach der Frage weiter. Beim zweiten Start des fixers hat er dann angehalten und auf das "y" gewartet.
                • ChaotC Chaot
                  #173
                  @chaot
                  Ja, so ist es richtig.
                  • FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    #174
                    @Thomas-Braun Ich hab gerade die aktuelle Version von iob fix ausgeführt und das Terminal im Hintergrund einige Zeit vergessen.
                    Anscheinend läuft ein Timer der irgendwann die Authentifizierung abbricht und als Fehlerhaft ausgibt.
                    Hat es einen Grund, das das Skript nicht einfach auf die Eingabe wartet oder aktiv abgebrochen werden muss mit Strg+C?
                    Bei einem zweiten Aufruf von iob fix war dann alles i.O.
                        Checking autostart (5/5)
                    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
                    Authentication is required to stop 'iobroker.service'.
                    Authenticating as: ,,, (proxmox)
                    Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
                    Enabling autostart...
                    Autostart enabled!
                    • FeuersturmF Feuersturm
                      Autostart enabled!
                      #175
                      @feuersturm sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                      Kann ich nicht steuern, das kommt so vom polkit/pam.
                      Allerdings könnte man die falsche Erfolgsmeldung Autostart enabled! anpassen.
                      • David G.D Online
                        David G.D Online
                        David G.
                        #176
                        Leider nur ein Screenshot, das c&p wollte irgendwie nicht...
                        Debian 12.
                        • David G.D David G.
                          Debian 12.
                          #177
                          @david-g
                          Ja, ist bekannt. Fix ist 'in der Mache'.
                            @david-g
                            David G.D Online
                            David G.D Online
                            David G.
                            #178
                            Wird das Script das auch irgendwann selber lösen können?
                            david@iobroker:~$ iob stop
                            david@iobroker:~$ iob fix
                            [sudo] Passwort für david:
                            bash: /home/iobroker/.fix.sh: Keine Berechtigung
                            david@iobroker:~$ sudo iob fix
                            ***For security reasons ioBroker should not be run or administrated as root.***
                            By default only a user that is member of iobroker group can execute ioBroker commands.
                            Please read the Documentation on how to set up such a user, if not done yet.
                            Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                            Please note that this option may be disabled in the future, so please change your setup accordingly now.
                            david@iobroker:~$
                              david@iobroker:~$
                              #179
                              @david-g sagte in Änderungen iob CLI/Installer/Fixer mit Root Accounts:
                              Was genau?
                              Schau dir die Rechte an
                              ls -l /home/iobroker/
                              ls -l /home/iobroker/.fix.sh
                              Vermutlich ist david nicht in der Gruppe 'iobroker' enthalten.
                              groups
                              zeigt die.
                                Was genau?
                                groups
                                zeigt die.
                                David G.D Online
                                David G.D Online
                                David G.
                                #180
                                Dass ein User automatisch der erforderlichen Gruppe hinzugefügt werden kann.
                                Ggf hat man ja schon einen User den man verwenden möchte anstatt einen neuen anzulegen.
                                david@iobroker:~$ sudo ls -l /home/iobroker/
                                insgesamt 24
                                -rw-r--r-- 1 iobroker iobroker   122 21. Okt 22:17 iob_diag.log
                                -rwxr--r-- 1 iobroker iobroker 15796 29. Sep 2023  iob_node_update
                                drwxr-xr-x 5 iobroker iobroker  4096 31. Mär 2024  skripte
                                david@iobroker:~$ sudo ls -l /home/iobroker/.fix.sh
                                -rw-r--r-- 1 iobroker iobroker 45390 26. Okt 13:04 /home/iobroker/.fix.sh
                                david@iobroker:~$ groups
                                david sudo users
                                david@iobroker:~$
                                  insgesamt 24
                                  david sudo users
                                  david@iobroker:~$
                                  #181
                                  Nee, das muss der sys admin selber für bestehende user machen.
                                  Sonst könnte ja ein user, der es gar nicht in die Gruppe reingehört einfach das Skript aufrufen und sich dann so hinzufügen.
                                  sudo usermod -a -G iobroker david
                                  Den david dann einmal ausloggen und wieder einloggen.
                                  • David G.D Online
                                    David G.D Online
                                    David G.
                                    #182
                                    Kann aber gerne einen Thread auf machen.
                                    Ist ja eher sehr offtopic....
                                    Zumindest wenn der fixer es technisch nicht übernehmen kann.
                                    david@iobroker:~$ groups david
                                    david : david sudo users iobroker
                                    david@iobroker:~$
                                      david@iobroker:~$
                                      #183
                                      @david-g
                                      david wurde ausgeloggt?
                                      ls -l /home
                                      sagt?
                                        @david-g
                                        ls -l /home
                                        sagt?
                                        David G.D Online
                                        David G.D Online
                                        David G.
                                        #184
                                        Ja, auch einmal als anderen User angemeldet.
                                        david@iobroker:~$ ls -l /home
                                        insgesamt 8
                                        drwx------ 4 david    david    4096 26. Okt 13:36 david
                                        drwx------ 9 iobroker iobroker 4096 26. Okt 12:54 iobroker
                                        david@iobroker:~$
                                          insgesamt 8
                                          david@iobroker:~$
                                          #185
                                          Da fehlen die Gruppen-Rechte.
                                          sudo chmod 750 /home/iobroker
                                          Ist das heute frisch angelegt worden?
