  4. Kann IoBroker nicht mehr aufrufen
36 Beiträge 4 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • F Offline
    Fuxsism
    wenn ich Job Diagnose starte kommt das:
    The state system.host.iobroker.versions.nodeNewestNext was not found!
    The state system.host.iobroker.versions.npmNewestNext was not found!
    The state system.host.iobroker.versions.nodeCurrent was not found!
    • F Fuxsism
      nach erneuter Anmeldung per Terminal:
      iobroker@iobroker:~ $ Connection to iobroker closed by remote host.
      Connection to iobroker closed.
      fuxism@MBP-von-Michael ~ % ssh iobroker@iobroker
      iobroker@iobroker's password:
      Linux iobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
      permitted by applicable law.
      Last login: Sun Sep 22 13:11:31 2024
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      -bash: source: /home/iobroker/.iobroker/iobroker_completions: Kann die Datei nicht ausführen.
      @fuxsism
      Man meldet sich ja auch nicht als user 'iobroker' sondern mit seinem richtigen Login an.
      • F Offline
        Fuxsism
        Lob Diagnose sagt nun:
        Skript v.2024-05-22
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model		: Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         13:13:36 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-09-22 13:13:37 CEST
                   Universal time: Sun 2024-09-22 11:13:37 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
        iobroker
        HOME=/home/iobroker
        *** Display-Server-Setup ***
        Display-Server: true
        Desktop:
        Terminal: 	tty
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            3.8G        1.6G        1.5G         35M        732M        2.1G
        Swap:            99M          0B         99M
        Total:          3.9G        1.6G        1.6G
        Active iob-Instances: 	18
                 3794 M total memory
                 1566 M used memory
                 1753 M active memory
                  379 M inactive memory
                 1495 M free memory
                   45 M buffer memory
                  687 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 13:13:37 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
        Tasks: 216 total,   4 running, 212 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 28.0 us,  9.3 sy,  0.0 ni, 61.3 id,  0.0 wa,  0.0 hi,  1.3 si,  0.0 st
        MiB Mem :   3794.3 total,   1494.7 free,   1566.6 used,    733.0 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2117.1 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       29G  7.8G   20G  28% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [sudo] password for iobroker:
        [Sun Sep 22 13:11:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8E:3F:E4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7e9f8956-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sun Sep 22 13:11:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Sep 22 13:11:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Sun Sep 22 13:11:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET                       SOURCE         FSTYPE          OPTIONS
        /                            /dev/mmcblk0p2 ext4            rw,noatime
        |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
        | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
        | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
        | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
        |-/proc                      proc           proc            rw,relatime
        | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
        |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
        | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
        | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
        | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
        | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
        | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
        |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
        | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
        | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
        | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
        |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.8G	/var/
        940M	/var/log
        937M	/var/log/journal/365fb86da8514c2a85a61e3d210b6795
        609M	/var/cache
        Archived and active journals take up 936.1M in the file system.
        /opt/iobroker/backups:
        22M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        593M	/opt/iobroker/iobroker-data/
        520M	/opt/iobroker/iobroker-data/files
        441M	/opt/iobroker/iobroker-data/files/javascript.admin
        409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        14M	/opt/iobroker/iobroker-data/objects.jsonl
        14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
        8.8M	/opt/iobroker/iobroker-data/states.jsonl
        8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.17.0
        /usr/bin/node 		v20.17.0
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.29.3
        nodejs:
          Installed: 20.17.0-1nodesource1
          Candidate: 20.17.0-1nodesource1
          Version table:
         *** 20.17.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u5 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	6.0.11
        admin: 		7.1.2
        javascript: 	8.7.6
        nodejs modules from github: 	0
        Adapter State
          system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: ::
        + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonoff.2                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.sonoff.3                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
          system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 7.1.2    , installed 7.1.2
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.0.22   , installed 3.0.22
        Adapter    "hue"          : 3.12.0   , installed 3.12.0
        Adapter    "javascript"   : 8.7.6    , installed 8.7.6
        Controller "js-controller": 6.0.11   , installed 6.0.11
        Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "shelly"       : 7.0.0    , installed 7.0.0
        Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
        Adapter    "tado"         : 0.5.6    , installed 0.5.6
        Adapter    "web"          : 6.2.5    , installed 6.2.5
        Objects and States
        Objects: 	6973
        States: 	5294
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       16293      1847/io.sonoff.2
        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16270      1816/io.sonoff.1
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       17209      1890/io.sonoff.3
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12991      575/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17699      543/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15009      543/iobroker.js-con
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15459      542/cupsd
        tcp6       0      0 :::1883                 :::*                    LISTEN      1000       16215      1756/io.sonoff.0
        tcp6       0      0 :::8084                 :::*                    LISTEN      1000       19753      1959/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16344      1944/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12993      575/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15458      542/cupsd
        tcp6       0      0 :::51989                :::*                    LISTEN      1000       18665      1731/io.nuki-extend
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      382/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       18666      1763/io.shelly.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15475      458/dhcpcd
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       18626      1742/io.mihome-vacu
        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       18664      1770/io.mihome-vacu
        udp        0      0 0.0.0.0:37206           0.0.0.0:*                           108        11225      382/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1858       599/cups-browsed
        udp6       0      0 :::5353                 :::*                                108        11224      382/avahi-daemon: r
        udp6       0      0 :::59394                :::*                                108        11226      382/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          1874       458/dhcpcd
        2024-09-22 13:13:24.008  - info: host.iobroker instance system.adapter.socketio.0 in version "6.7.1" started with pid 1959
        2024-09-22 13:13:24.176  - info: web.0 (1944) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
        2024-09-22 13:13:24.709  - info: web.0 (1944) socket.io server listening on port 8082
        2024-09-22 13:13:24.724  - info: web.0 (1944) http server listening on port 8082
        2024-09-22 13:13:28.006  - info: host.iobroker instance system.adapter.tado.0 in version "0.5.6" started with pid 1986
        2024-09-22 13:13:28.310  - info: socketio.0 (1959) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
        2024-09-22 13:13:28.461  - info: socketio.0 (1959) socket.io server listening on port 8084
        2024-09-22 13:13:30.609  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.temperature.temperature_report
        2024-09-22 13:13:30.610  - info: javascript.0 (1227) script.js.Hue_Push: {"owner":{"rid":"0045d363-a198-4f59-a8b4-8281aac23ba4","rtype":"device"},"temperature":{"temperature":23.84,"temperature_report":{"changed":"2024-09-22T11:13:30.518Z","temperature":23.84}}}
        2024-09-22 13:13:32.547  - info: tado.0 (1986) starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.tado, node: v20.17.0, js-controller: 6.0.11
        2024-09-22 13:13:32.583  - info: tado.0 (1986) Started with JSON-Explorer version 0.1.16
        2024-09-22 13:13:33.300  - info: tado.0 (1986) Connected to Tado cloud, initialyzing...
        2024-09-22 13:13:40.226  - info: tado.0 (1986) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
        2024-09-22 13:13:44.435  - info: sonoff.1 (1816) Client [Bilderrahmen] connected with secret 1727003624426_6331
        2024-09-22 13:13:44.476  - info: sonoff.0 (1756) Client [Stecker Küche] connected with secret 1727003624466_4294
        2024-09-22 13:13:44.545  - info: sonoff.3 (1890) Client [Growzelt Venti] connected with secret 1727003624528_421
        2024-09-22 13:13:45.027  - info: sonoff.2 (1847) Client [Growzelt Licht] connected with secret 1727003625018_9545
        2024-09-22 13:14:03.236  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
        2024-09-22 13:14:03.237  - info: javascript.0 (1227) script.js.Hue_Push: {"light":{"light_level":18515,"light_level_report":{"changed":"2024-09-22T11:14:03.139Z","light_level":18515}},"owner":{"rid":"f2e4a67a-b010-4fc1-be1b-5fa10a0b6594","rtype":"device"}}
        2024-09-22 13:14:06.049  - info: alexa2.0 (1690) Using cached smart home devices list from Sun Sep 22 2024 13:07:36 GMT+0200 (Mitteleuropäische Sommerzeit)
        2024-09-22 13:14:21.131  - info: alexa2.0 (1690) No smart home devices to query
        2024-09-22 13:14:22.587  - info: alexa2.0 (1690) Subscribing to states...
        2024-09-22 13:14:22.598  - info: alexa2.0 (1690) Deleting the following states: ["Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#enabled","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#delete","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.powerState","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity-reason","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#query","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#includeInAllQuery","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#enabled","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#delete","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.powerState","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity-reason","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#query","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#includeInAllQuery","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#enabled","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#delete","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.powerState","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity-reason","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#query","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#includeInAllQuery","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#enabled","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#delete","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.powerState","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity-reason","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#query","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#includeInAllQuery","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#enabled","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#delete","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.powerState","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity-reason","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#query","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#includeInAllQuery","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#enabled","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#delete","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.powerState","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity-reason","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#query","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#includeInAllQuery","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#enabled","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#delete","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.powerState","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity-reason","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#query","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#includeInAllQuery","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#enabled","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#delete","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.powerState","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity-reason","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#query","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#includeInAllQuery","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#enabled","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#delete","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.powerState","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.brightness","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity-reason","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#query","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#includeInAllQuery","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#enabled","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#delete","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.powerState","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.brightness","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity-reason","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#query","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#includeInAllQuery","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#enabled","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#delete","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.powerState","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity-reason","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#query","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#includeInAllQuery","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#enabled","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#delete","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.powerState","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity-reason","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#query","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#includeInAllQuery","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#enabled","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#delete","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.powerState","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity-reason","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#query","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#includeInAllQuery","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#enabled","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#delete","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.powerState","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity-reason","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#query","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#includeInAllQuery","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#enabled","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#delete","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.powerState","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity-reason","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#query","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#includeInAllQuery"]
        2024-09-22 13:14:24.390  - info: alexa2.0 (1690) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-09-22 13:14:36.945  - info: alexa2.0 (1690) Initialization Done ...
        • F Fuxsism
          Skript v.2024-05-22
          *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          HOME=/home/iobroker
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal: 	tty
          *** MEMORY ***
          Swap:            99M          0B         99M
                   3794 M total memory
                   1566 M used memory
                   1495 M free memory
                     45 M buffer memory
                    687 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          *** FILESYSTEM ***
          /var:
          1.8G	/var/
          940M	/var/log
          609M	/var/cache
          USB-Devices by-id:
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          nodejs:
            Version table:
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin: 		7.1.2
          javascript: 	8.7.6
          Adapter State
          + instance is alive
          Objects and States
          Objects: 	6973
          States: 	5294
          Pending Updates: 0
          @fuxsism sagte in Kann IoBroker nicht mehr aufrufen:
          MACH DAS AUS!!!!!!!!!!!!!!!!!!!!!!!
          Zum xten Mal:
          sudo systemctl set-default multi-user.target
          sudo reboot
          Dann mit deinem user anmelden, NICHT als iobroker.
          F 1 Antwort Letzte Antwort
            Zum xten Mal:
            sudo reboot
            Fuxsism
            @thomas-braun said in Kann IoBroker nicht mehr aufrufen:
            hab ich aus geschaltet und gerobotet....
            ich glaube ehrlich gesagt der Biobroker ist mein user
            • F Fuxsism
              Fuxsism
              @fuxsism said in Kann IoBroker nicht mehr aufrufen:
              hab ich aus geschaltet und gerebootet....
              ich glaube ehrlich gesagt der iobroker ist mein user
              hab mich zumindest IMMER so angemeldet
              • F Fuxsism
                Dann ist es auch schon IMMER falsch. Der 'iobroker' wird eigentlich vom iobroker-Installer als Systemuser angelegt und der Standarduser in die Gruppe 'iobroker' gepackt. Dann funktioniert das auch alles wie vorgesehen.
                Kannst du ja bei der bald fälligen Neuinstallation von 'Raspberry OS Bookworm' dann besser machen.
                  Fuxsism
                  okay werde ich versuchen...
                  wie geht es denn nun weiter?
                  • F Fuxsism
                    @fuxsism
                    Display-Server aus?
                    Dann
                    iob start admin
                      @fuxsism
                      Display-Server aus?
                      Dann
                      iob start admin
                      Fuxsism
                      schrieb am zuletzt editiert von Fuxsism
                      ja display server aus
                      und nach start admin lädt es auch direkt wieder!!!!
                      kann jetzt auf jeden fall wieder per Firefox drauf zugreifen.....
                      Danke!!!!!
                      Soll ich denn jetzt noch etwas machen?
                      • F Fuxsism
                        Danke!!!!!
                        Zeig mal abschließend die Zusammenfassung von
                        iob diag
                          iob diag
                          Fuxsism
                          			v.2024-05-22
                                   Icon name: computer
                                Architecture: arm64
                          Installation: 		native
                          Kernel: 		aarch64
                          Userland: 		64 bit
                          Timezone: 		Europe/Berlin (CEST, +0200)
                          User-ID: 		1000
                          Display-Server: 	false
                          Boot Target: 		multi-user.target
                          Pending OS-Updates: 	0
                          Pending iob updates: 	0
                          Nodejs-Installation:
                          /usr/bin/npm 		10.8.2
                          /usr/bin/npx 		10.8.2
                          Recommended versions are nodejs 20.17.0 and npm 10.8.2
                          MEMORY:
                          Mem:            3.8G        1.2G        1.9G        1.0M        617M        2.5G
                          Swap:            99M          0B         99M
                          Total:          3.9G        1.2G        2.0G
                          Active iob-Instances: 	21
                          ioBroker Core: 		js-controller 		6.0.11
                          			admin 			7.1.2
                          ioBroker Status: 	iobroker is running on this host.
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		6979
                          States: 		5309
                          Size of iob-Database:
                          18M	/opt/iobroker/iobroker-data/objects.jsonl
                          4.7M	/opt/iobroker/iobroker-data/states.jsonl
                          • F Fuxsism
                            			v.2024-05-22
                                     Icon name: computer
                                  Architecture: arm64
                            Kernel: 		aarch64
                            Userland: 		64 bit
                            User-ID: 		1000
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            MEMORY:
                            Swap:            99M          0B         99M
                            			admin 			7.1.2
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		6979
                            States: 		5309
                            @fuxsism
                            Jetzt passt es.
                            In nächster Zeit eine NEUINSTALLATION von Raspberry OS Lite einplanen.
                              @fuxsism
                              Jetzt passt es.
                              Fuxsism
                              okay... es scheint auch alles wieder gut und normal zu laufen!!!
                              Vielen vielen Dank für die schnelle Hilfe!!!
                              LG
