  4. Kann IoBroker nicht mehr aufrufen
36 Beiträge 4 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • F Offline
    Fuxsism
    nach erneuter Anmeldung per Terminal:
    iobroker@iobroker:~ $ Connection to iobroker closed by remote host.
    Connection to iobroker closed.
    fuxism@MBP-von-Michael ~ % ssh iobroker@iobroker
    iobroker@iobroker's password:
    Linux iobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
    permitted by applicable law.
    Last login: Sun Sep 22 13:11:31 2024
    Wi-Fi is currently blocked by rfkill.
    Use raspi-config to set the country before use.
    -bash: source: /home/iobroker/.iobroker/iobroker_completions: Kann die Datei nicht ausführen.
    • F Offline
      Fuxsism
      wenn ich Job Diagnose starte kommt das:
      The state system.host.iobroker.versions.nodeNewestNext was not found!
      The state system.host.iobroker.versions.npmNewestNext was not found!
      The state system.host.iobroker.versions.nodeCurrent was not found!
      • F Fuxsism
        @fuxsism
        Man meldet sich ja auch nicht als user 'iobroker' sondern mit seinem richtigen Login an.
        • F Offline
          Fuxsism
          Lob Diagnose sagt nun:
          Skript v.2024-05-22
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Model		: Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           13:13:36 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sun 2024-09-22 13:13:37 CEST
                     Universal time: Sun 2024-09-22 11:13:37 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
          iobroker
          HOME=/home/iobroker
          *** Display-Server-Setup ***
          Display-Server: true
          Desktop:
          Terminal: 	tty
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            3.8G        1.6G        1.5G         35M        732M        2.1G
          Swap:            99M          0B         99M
          Total:          3.9G        1.6G        1.6G
          Active iob-Instances: 	18
                   3794 M total memory
                   1566 M used memory
                   1753 M active memory
                    379 M inactive memory
                   1495 M free memory
                     45 M buffer memory
                    687 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 13:13:37 up 1 min,  3 users,  load average: 4.90, 1.95, 0.72
          Tasks: 216 total,   4 running, 212 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 28.0 us,  9.3 sy,  0.0 ni, 61.3 id,  0.0 wa,  0.0 hi,  1.3 si,  0.0 st
          MiB Mem :   3794.3 total,   1494.7 free,   1566.6 used,    733.0 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2117.1 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       29G  7.8G   20G  28% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
          tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
          [sudo] password for iobroker:
          [Sun Sep 22 13:11:43 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8E:3F:E4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7e9f8956-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun Sep 22 13:11:44 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sun Sep 22 13:11:44 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Sun Sep 22 13:11:47 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET                       SOURCE         FSTYPE          OPTIONS
          /                            /dev/mmcblk0p2 ext4            rw,noatime
          |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
          | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
          | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
          |-/proc                      proc           proc            rw,relatime
          | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
          |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
          | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
          | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
          |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.8G	/var/
          940M	/var/log
          937M	/var/log/journal/365fb86da8514c2a85a61e3d210b6795
          609M	/var/cache
          Archived and active journals take up 936.1M in the file system.
          /opt/iobroker/backups:
          22M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          593M	/opt/iobroker/iobroker-data/
          520M	/opt/iobroker/iobroker-data/files
          441M	/opt/iobroker/iobroker-data/files/javascript.admin
          409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          14M	/opt/iobroker/iobroker-data/objects.jsonl
          14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
          8.8M	/opt/iobroker/iobroker-data/states.jsonl
          8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v20.17.0
          /usr/bin/node 		v20.17.0
          /usr/bin/npm 		10.8.2
          /usr/bin/npx 		10.8.2
          /usr/bin/corepack 	0.29.3
          nodejs:
            Installed: 20.17.0-1nodesource1
            Candidate: 20.17.0-1nodesource1
            Version table:
           *** 20.17.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u5 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	6.0.11
          admin: 		7.1.2
          javascript: 	8.7.6
          nodejs modules from github: 	0
          Adapter State
            system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
          + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
          + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
          + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: ::
          + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sonoff.2                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
          + system.adapter.sonoff.3                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
            system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.1.2    , installed 7.1.2
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.22   , installed 3.0.22
          Adapter    "hue"          : 3.12.0   , installed 3.12.0
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.11   , installed 6.0.11
          Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "pushover"     : 4.1.0    , installed 4.1.0
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
          Adapter    "tado"         : 0.5.6    , installed 0.5.6
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Objects and States
          Objects: 	6973
          States: 	5294
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       16293      1847/io.sonoff.2
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       16270      1816/io.sonoff.1
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       17209      1890/io.sonoff.3
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12991      575/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17699      543/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       15009      543/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15459      542/cupsd
          tcp6       0      0 :::1883                 :::*                    LISTEN      1000       16215      1756/io.sonoff.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       19753      1959/io.socketio.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       16344      1944/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          12993      575/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15458      542/cupsd
          tcp6       0      0 :::51989                :::*                    LISTEN      1000       18665      1731/io.nuki-extend
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11223      382/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       18666      1763/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15475      458/dhcpcd
          udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       18626      1742/io.mihome-vacu
          udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       18664      1770/io.mihome-vacu
          udp        0      0 0.0.0.0:37206           0.0.0.0:*                           108        11225      382/avahi-daemon: r
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          1858       599/cups-browsed
          udp6       0      0 :::5353                 :::*                                108        11224      382/avahi-daemon: r
          udp6       0      0 :::59394                :::*                                108        11226      382/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          1874       458/dhcpcd
          2024-09-22 13:13:24.008  - info: host.iobroker instance system.adapter.socketio.0 in version "6.7.1" started with pid 1959
          2024-09-22 13:13:24.176  - info: web.0 (1944) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
          2024-09-22 13:13:24.709  - info: web.0 (1944) socket.io server listening on port 8082
          2024-09-22 13:13:24.724  - info: web.0 (1944) http server listening on port 8082
          2024-09-22 13:13:28.006  - info: host.iobroker instance system.adapter.tado.0 in version "0.5.6" started with pid 1986
          2024-09-22 13:13:28.310  - info: socketio.0 (1959) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
          2024-09-22 13:13:28.461  - info: socketio.0 (1959) socket.io server listening on port 8084
          2024-09-22 13:13:30.609  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.temperature.temperature_report
          2024-09-22 13:13:30.610  - info: javascript.0 (1227) script.js.Hue_Push: {"owner":{"rid":"0045d363-a198-4f59-a8b4-8281aac23ba4","rtype":"device"},"temperature":{"temperature":23.84,"temperature_report":{"changed":"2024-09-22T11:13:30.518Z","temperature":23.84}}}
          2024-09-22 13:13:32.547  - info: tado.0 (1986) starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.tado, node: v20.17.0, js-controller: 6.0.11
          2024-09-22 13:13:32.583  - info: tado.0 (1986) Started with JSON-Explorer version 0.1.16
          2024-09-22 13:13:33.300  - info: tado.0 (1986) Connected to Tado cloud, initialyzing...
          2024-09-22 13:13:40.226  - info: tado.0 (1986) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
          2024-09-22 13:13:44.435  - info: sonoff.1 (1816) Client [Bilderrahmen] connected with secret 1727003624426_6331
          2024-09-22 13:13:44.476  - info: sonoff.0 (1756) Client [Stecker Küche] connected with secret 1727003624466_4294
          2024-09-22 13:13:44.545  - info: sonoff.3 (1890) Client [Growzelt Venti] connected with secret 1727003624528_421
          2024-09-22 13:13:45.027  - info: sonoff.2 (1847) Client [Growzelt Licht] connected with secret 1727003625018_9545
          2024-09-22 13:14:03.236  - info: javascript.0 (1227) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
          2024-09-22 13:14:03.237  - info: javascript.0 (1227) script.js.Hue_Push: {"light":{"light_level":18515,"light_level_report":{"changed":"2024-09-22T11:14:03.139Z","light_level":18515}},"owner":{"rid":"f2e4a67a-b010-4fc1-be1b-5fa10a0b6594","rtype":"device"}}
          2024-09-22 13:14:06.049  - info: alexa2.0 (1690) Using cached smart home devices list from Sun Sep 22 2024 13:07:36 GMT+0200 (Mitteleuropäische Sommerzeit)
          2024-09-22 13:14:21.131  - info: alexa2.0 (1690) No smart home devices to query
          2024-09-22 13:14:22.587  - info: alexa2.0 (1690) Subscribing to states...
          2024-09-22 13:14:22.598  - info: alexa2.0 (1690) Deleting the following states: ["Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#enabled","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#delete","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.powerState","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity-reason","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#query","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#includeInAllQuery","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#enabled","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#delete","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.powerState","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity-reason","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#query","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#includeInAllQuery","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#enabled","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#delete","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.powerState","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity-reason","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#query","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#includeInAllQuery","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#enabled","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#delete","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.powerState","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity-reason","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#query","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#includeInAllQuery","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#enabled","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#delete","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.powerState","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity-reason","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#query","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#includeInAllQuery","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#enabled","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#delete","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.powerState","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity-reason","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#query","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#includeInAllQuery","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#enabled","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#delete","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.powerState","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity-reason","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#query","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#includeInAllQuery","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#enabled","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#delete","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.powerState","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity-reason","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#query","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#includeInAllQuery","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#enabled","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#delete","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.powerState","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.brightness","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity-reason","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#query","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#includeInAllQuery","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#enabled","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#delete","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.powerState","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.brightness","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity-reason","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#query","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#includeInAllQuery","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#enabled","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#delete","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.powerState","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity-reason","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#query","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#includeInAllQuery","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#enabled","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#delete","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.powerState","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity-reason","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#query","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#includeInAllQuery","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#enabled","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#delete","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.powerState","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity-reason","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#query","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#includeInAllQuery","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#enabled","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#delete","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.powerState","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity-reason","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#query","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#includeInAllQuery","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#enabled","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#delete","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.powerState","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity-reason","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#query","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#includeInAllQuery"]
          2024-09-22 13:14:24.390  - info: alexa2.0 (1690) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2024-09-22 13:14:36.945  - info: alexa2.0 (1690) Initialization Done ...
          • F Fuxsism
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            HOME=/home/iobroker
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal: 	tty
            *** MEMORY ***
            Swap:            99M          0B         99M
                     3794 M total memory
                     1566 M used memory
                     1495 M free memory
                       45 M buffer memory
                      687 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            *** FILESYSTEM ***
            /var:
            1.8G	/var/
            940M	/var/log
            609M	/var/cache
            USB-Devices by-id:
            /usr/bin/npm 		10.8.2
            /usr/bin/npx 		10.8.2
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin: 		7.1.2
            javascript: 	8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects: 	6973
            States: 	5294
            Pending Updates: 0
            @fuxsism sagte in Kann IoBroker nicht mehr aufrufen:
            MACH DAS AUS!!!!!!!!!!!!!!!!!!!!!!!
            Zum xten Mal:
            sudo systemctl set-default multi-user.target
            sudo reboot
            Dann mit deinem user anmelden, NICHT als iobroker.
            F 1 Antwort Letzte Antwort
              Zum xten Mal:
              sudo reboot
              Fuxsism
              @thomas-braun said in Kann IoBroker nicht mehr aufrufen:
              hab ich aus geschaltet und gerobotet....
              ich glaube ehrlich gesagt der Biobroker ist mein user
              • F Fuxsism
                Fuxsism
                @fuxsism said in Kann IoBroker nicht mehr aufrufen:
                hab ich aus geschaltet und gerebootet....
                ich glaube ehrlich gesagt der iobroker ist mein user
                hab mich zumindest IMMER so angemeldet
                • F Fuxsism
                  Dann ist es auch schon IMMER falsch. Der 'iobroker' wird eigentlich vom iobroker-Installer als Systemuser angelegt und der Standarduser in die Gruppe 'iobroker' gepackt. Dann funktioniert das auch alles wie vorgesehen.
                  Kannst du ja bei der bald fälligen Neuinstallation von 'Raspberry OS Bookworm' dann besser machen.
                    Fuxsism
                    okay werde ich versuchen...
                    wie geht es denn nun weiter?
                    • F Fuxsism
                      @fuxsism
                      Display-Server aus?
                      Dann
                      iob start admin
                        @fuxsism
                        Display-Server aus?
                        Dann
                        iob start admin
                        Fuxsism
                        schrieb am zuletzt editiert von Fuxsism
                        ja display server aus
                        und nach start admin lädt es auch direkt wieder!!!!
                        kann jetzt auf jeden fall wieder per Firefox drauf zugreifen.....
                        Danke!!!!!
                        Soll ich denn jetzt noch etwas machen?
                        • F Fuxsism
                          Danke!!!!!
                          Zeig mal abschließend die Zusammenfassung von
                          iob diag
                            iob diag
                            Fuxsism
                            			v.2024-05-22
                                     Icon name: computer
                                  Architecture: arm64
                            Installation: 		native
                            Kernel: 		aarch64
                            Userland: 		64 bit
                            Timezone: 		Europe/Berlin (CEST, +0200)
                            User-ID: 		1000
                            Display-Server: 	false
                            Boot Target: 		multi-user.target
                            Pending OS-Updates: 	0
                            Pending iob updates: 	0
                            Nodejs-Installation:
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            Recommended versions are nodejs 20.17.0 and npm 10.8.2
                            MEMORY:
                            Mem:            3.8G        1.2G        1.9G        1.0M        617M        2.5G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.2G        2.0G
                            Active iob-Instances: 	21
                            ioBroker Core: 		js-controller 		6.0.11
                            			admin 			7.1.2
                            ioBroker Status: 	iobroker is running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		6979
                            States: 		5309
                            Size of iob-Database:
                            18M	/opt/iobroker/iobroker-data/objects.jsonl
                            4.7M	/opt/iobroker/iobroker-data/states.jsonl
                            • F Fuxsism
                              			v.2024-05-22
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		64 bit
                              User-ID: 		1000
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              MEMORY:
                              Swap:            99M          0B         99M
                              			admin 			7.1.2
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		6979
                              States: 		5309
                              @fuxsism
                              Jetzt passt es.
                              In nächster Zeit eine NEUINSTALLATION von Raspberry OS Lite einplanen.
                                @fuxsism
                                Jetzt passt es.
                                Fuxsism
                                okay... es scheint auch alles wieder gut und normal zu laufen!!!
                                Vielen vielen Dank für die schnelle Hilfe!!!
                                LG
