  4. Kann IoBroker nicht mehr aufrufen
36 Beiträge 4 Kommentatoren 5.2k Aufrufe 4 Beobachtet
  • F Offline
    Fuxsism
    Okay... hier also im Anhang
    			v.2024-05-22
       Static hostname: iobroker
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    Installation: 		native
    Kernel: 		aarch64
    Userland: 		64 bit
    Timezone: 		Europe/Berlin (CEST, +0200)
    User-ID: 		1000
    Display-Server: 	true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	246
    Pending iob updates: 	0
    Nodejs-Installation:
    nodejs: 		N/A
    /usr/bin/node 		v18.17.1
    /usr/bin/npm 		9.6.7
    /usr/bin/npx 		9.6.7
    /usr/bin/corepack 	0.18.0
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iobroker nodejs-update
    to fix these errors.
    MEMORY:
    Mem:            3.8G        1.5G        1.5G         35M        770M        2.2G
    Swap:            99M          0B         99M
    Total:          3.9G        1.5G        1.6G
    Active iob-Instances: 	20
    Upgrade policy: none
    ioBroker Core: 		js-controller 		6.0.11
    			admin 			7.1.2
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
      system.adapter.admin.0                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
    Objects: 		6973
    States: 		5279
    Size of iob-Database:
    22M	/opt/iobroker/iobroker-data/objects.jsonl
    5.5M	/opt/iobroker/iobroker-data/states.jsonl
    • F Fuxsism
      			v.2024-05-22
               Icon name: computer
            Architecture: arm64
      Kernel: 		aarch64
      Userland: 		64 bit
      User-ID: 		1000
      nodejs: 		N/A
      /usr/bin/npm 		9.6.7
      /usr/bin/npx 		9.6.7
      Please execute
      MEMORY:
      Swap:            99M          0B         99M
      			admin 			7.1.2
      Objects type: jsonl
      States  type: jsonl
      Objects: 		6973
      States: 		5279
      @fuxsism
      iob nodejs-update 20
      iob start admin
      Und schalt den graphischen Mumpitz auf einem Server AUS!
      Und das Betriebssystem möchte auch regelmäßig aktualisiert werden!
      sudo systemctl set-default multi-user.target
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      F 1 Antwort Letzte Antwort
        @fuxsism
        iob start admin
        sudo apt update
        sudo reboot
        Fuxsism
        also bisher hängt er wohl noch an diesem nodejs update
        Updating fallback to latest nodejs v20 release
        • F Fuxsism
          HomoranH Offline
          HomoranH Offline
          @fuxsism sagte in Kann IoBroker nicht mehr aufrufen:
          können wir nicht sehen!
          SUMMARY
          ist nicht die Langfassung!
          die kommt vorher
          aber das ist schon heftig!
          Seit der Installation keine Betriebssystem Updates gefahren?
          • F Fuxsism
            @fuxsism
            Könnte daran liegen, daß nicht die aktuelle Version verfügbar ist.
            Versuch mal die Beta-Version von hier:
            @apollon77 Bitte hochladen!!!
              SUMMARY
              die kommt vorher
              Fuxsism
              hmm ich fürchte ehrlich gesagt nicht.
              Bin da nicht son fit und bin froh wenn alles läuft ;-)
              Ich mache in regelmäßigen abständen diesen Update Durchlauf mit
              iob stop
              iob update
              iob upgrade self
              iob fix
              das war es dann aber auch schon mehr oder weniger.
              Das Update er Node läuft Imme rnoch... er ist kräftig am installieren und am installieren...
              • F Offline
                Fuxsism
                schaut mal was hier nun so abläuft:
                ioBroker nodejs fixer 2024-05-23
                You requested to install latest version from nodejs v20 tree.
                Your current setup is:
                /usr/bin/npm 		9.6.7
                /usr/bin/npx 		9.6.7
                We found these nodejs versions available for installation:
                nodejs:
                  Installed: 18.17.1-deb-1nodesource1
                  Candidate: 18.17.1-deb-1nodesource1
                  Version table:
                 *** 18.17.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u5 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                Nothing to do - Your installation is using the correct paths.
                You are running nodejs v18.17.1. Do you want to install latest version from nodejs v.20 tree?
                Press <y> to continue or any other key to quit
                Trying to fix your installation now. Please be patient.
                [sudo] password for iobroker:
                find: '/run/user/1000/gvfs': Permission denied
                Waiting for ioBroker to shut down - Give me a minute...
                *** These repos are active on your system:
                Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://deb.debian.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                Reading package lists... Done
                *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                (Reading database ... 107742 files and directories currently installed.)
                Preparing to unpack .../curl_7.74.0-1.3+deb11u13_arm64.deb ...
                Unpacking curl (7.74.0-1.3+deb11u13) over (7.74.0-1.3+deb11u7) ...
                Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u13_arm64.deb ...
                Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u13) over (7.74.0-1.3+deb11u7) ...
                Setting up libcurl4:arm64 (7.74.0-1.3+deb11u13) ...
                Setting up curl (7.74.0-1.3+deb11u13) ...
                Processing triggers for man-db (2.9.4-2) ...
                Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
                *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                Package: nodejs
                Pin: origin deb.nodesource.com
                Pin-Priority: 1001
                *** These repos are active after the adjustments:
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Get:5 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                Get:6 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [9132 B]
                Get:7 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [9124 B]
                Fetched 30.4 kB in 2s (19.7 kB/s)
                Installing nodejs now!
                /home/iobroker/.nodejs-update.sh: line 370: [: : integer expression expected
                Exact recommended version unknown, installing a fallback!
                Preparing to unpack .../nodejs_20.0.0-1nodesource1_arm64.deb ...
                Detected old npm client, removing...
                Unpacking nodejs (20.0.0-1nodesource1) over (18.17.1-deb-1nodesource1) ...
                Setting up nodejs (20.0.0-1nodesource1) ...
                E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/f/ffmpeg/libavcodec58_4.3.7-0%2bdeb11u1%2brpt2_arm64.deb  Error reading from server - read (104: Connection reset by peer) [IP: 2a00:1098:80:56::2:1 80]
                E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                v20.0.0 has been installed! You are using the latest version now!
                /home/iobroker/.nodejs-update.sh: line 387: [: : integer expression expected
                Installing the nodejs!
                Extracting templates from packages: 100%
                Preconfiguring packages ...
                (Reading database ... 107506 files and directories currently installed.)
                Preparing to unpack .../base-files_11.1+deb11u11_arm64.deb ...
                Unpacking base-files (11.1+deb11u11) over (11.1+deb11u7) ...
                Setting up base-files (11.1+deb11u11) ...
                Installing new version of config file /etc/debian_version ...
                Preparing to unpack .../bsdutils_1%3a2.36.1-8+deb11u2_arm64.deb ...
                Unpacking bsdutils (1:2.36.1-8+deb11u2) over (1:2.36.1-8+deb11u1) ...
                Setting up bsdutils (1:2.36.1-8+deb11u2) ...
                Preparing to unpack .../tar_1.34+dfsg-1+deb11u1_arm64.deb ...
                Unpacking tar (1.34+dfsg-1+deb11u1) over (1.34+dfsg-1) ...
                Setting up tar (1.34+dfsg-1+deb11u1) ...
                Preparing to unpack .../dpkg_1.20.13_arm64.deb ...
                Unpacking dpkg (1.20.13) over (1.20.12) ...
                Setting up dpkg (1.20.13) ...
                Preparing to unpack .../ncurses-bin_6.2+20201114-2+deb11u2_arm64.deb ...
                Unpacking ncurses-bin (6.2+20201114-2+deb11u2) over (6.2+20201114-2+deb11u1) ...
                Setting up ncurses-bin (6.2+20201114-2+deb11u2) ...
                Preparing to unpack .../libperl5.32_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking libperl5.32:arm64 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../perl_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking perl (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../perl-base_5.32.1-4+deb11u3_arm64.deb ...
                Unpacking perl-base (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Setting up perl-base (5.32.1-4+deb11u3) ...
                Preparing to unpack .../0-perl-modules-5.32_5.32.1-4+deb11u3_all.deb ...
                Unpacking perl-modules-5.32 (5.32.1-4+deb11u3) over (5.32.1-4+deb11u2) ...
                Preparing to unpack .../1-libc6-dbg_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc6-dbg:arm64 (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Preparing to unpack .../2-libc-devtools_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc-devtools (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Preparing to unpack .../3-libc6-dev_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc6-dev:arm64 (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Preparing to unpack .../4-libc-dev-bin_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc-dev-bin (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Preparing to unpack .../5-libc6_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc6:arm64 (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Setting up libc6:arm64 (2.31-13+rpt2+rpi1+deb11u11) ...
                (Reading database ... 107509 files and directories currently installed.)
                Preparing to unpack .../uuid-dev_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking uuid-dev:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../libuuid1_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libuuid1:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Setting up libuuid1:arm64 (2.36.1-8+deb11u2) ...
                Preparing to unpack .../libblkid-dev_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libblkid-dev:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../libblkid1_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libblkid1:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Setting up libblkid1:arm64 (2.36.1-8+deb11u2) ...
                Preparing to unpack .../libfdisk1_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libfdisk1:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../libmount-dev_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libmount-dev:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../libmount1_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libmount1:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Setting up libmount1:arm64 (2.36.1-8+deb11u2) ...
                Preparing to unpack .../libncurses6_6.2+20201114-2+deb11u2_arm64.deb ...
                Unpacking libncurses6:arm64 (6.2+20201114-2+deb11u2) over (6.2+20201114-2+deb11u1) ...
                Preparing to unpack .../libncursesw6_6.2+20201114-2+deb11u2_arm64.deb ...
                Unpacking libncursesw6:arm64 (6.2+20201114-2+deb11u2) over (6.2+20201114-2+deb11u1) ...
                Preparing to unpack .../libtinfo6_6.2+20201114-2+deb11u2_arm64.deb ...
                Unpacking libtinfo6:arm64 (6.2+20201114-2+deb11u2) over (6.2+20201114-2+deb11u1) ...
                Setting up libtinfo6:arm64 (6.2+20201114-2+deb11u2) ...
                Preparing to unpack .../libsmartcols1_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking libsmartcols1:arm64 (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Setting up libsmartcols1:arm64 (2.36.1-8+deb11u2) ...
                Preparing to unpack .../fdisk_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking fdisk (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../util-linux_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking util-linux (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Setting up util-linux (2.36.1-8+deb11u2) ...
                fstrim.service is a disabled or a static unit not running, not starting it.
                Preparing to unpack .../libc-bin_2.31-13+rpt2+rpi1+deb11u11_arm64.deb ...
                Unpacking libc-bin (2.31-13+rpt2+rpi1+deb11u11) over (2.31-13+rpt2+rpi1+deb11u5) ...
                Setting up libc-bin (2.31-13+rpt2+rpi1+deb11u11) ...
                Preparing to unpack .../ncurses-base_6.2+20201114-2+deb11u2_all.deb ...
                Unpacking ncurses-base (6.2+20201114-2+deb11u2) over (6.2+20201114-2+deb11u1) ...
                Setting up ncurses-base (6.2+20201114-2+deb11u2) ...
                Preparing to unpack .../0-libdbus-1-dev_1.12.28-0+deb11u1_arm64.deb ...
                Unpacking libdbus-1-dev:arm64 (1.12.28-0+deb11u1) over (1.12.24-0+deb11u1) ...
                Preparing to unpack .../1-dbus-user-session_1.12.28-0+deb11u1_arm64.deb ...
                Unpacking dbus-user-session (1.12.28-0+deb11u1) over (1.12.24-0+deb11u1) ...
                Preparing to unpack .../2-libx11-dev_2%3a1.7.2-1+deb11u2_arm64.deb ...
                Unpacking libx11-dev:arm64 (2:1.7.2-1+deb11u2) over (2:1.7.2-1+deb11u1) ...
                Preparing to unpack .../3-libx11-data_2%3a1.7.2-1+deb11u2_all.deb ...
                Unpacking libx11-data (2:1.7.2-1+deb11u2) over (2:1.7.2-1) ...
                Preparing to unpack .../4-libx11-6_2%3a1.7.2-1+deb11u2_arm64.deb ...
                Unpacking libx11-6:arm64 (2:1.7.2-1+deb11u2) over (2:1.7.2-1+deb11u1) ...
                Preparing to unpack .../5-libx11-xcb1_2%3a1.7.2-1+deb11u2_arm64.deb ...
                Unpacking libx11-xcb1:arm64 (2:1.7.2-1+deb11u2) over (2:1.7.2-1+deb11u1) ...
                Preparing to unpack .../6-dbus-x11_1.12.28-0+deb11u1_arm64.deb ...
                Unpacking dbus-x11 (1.12.28-0+deb11u1) over (1.12.24-0+deb11u1) ...
                Preparing to unpack .../7-dbus_1.12.28-0+deb11u1_arm64.deb ...
                Unpacking dbus (1.12.28-0+deb11u1) over (1.12.24-0+deb11u1) ...
                Preparing to unpack .../8-libdbus-1-3_1.12.28-0+deb11u1_arm64.deb ...
                Unpacking libdbus-1-3:arm64 (1.12.28-0+deb11u1) over (1.12.24-0+deb11u1) ...
                Preparing to unpack .../9-adduser_3.118+deb11u1_all.deb ...
                Unpacking adduser (3.118+deb11u1) over (3.118) ...
                Setting up adduser (3.118+deb11u1) ...
                Preparing to unpack .../0-libexpat1-dev_2.2.10-2+deb11u6_arm64.deb ...
                Unpacking libexpat1-dev:arm64 (2.2.10-2+deb11u6) over (2.2.10-2+deb11u5) ...
                Preparing to unpack .../1-libexpat1_2.2.10-2+deb11u6_arm64.deb ...
                Unpacking libexpat1:arm64 (2.2.10-2+deb11u6) over (2.2.10-2+deb11u5) ...
                Preparing to unpack .../2-systemd-sysv_247.3-7+deb11u6_arm64.deb ...
                Unpacking systemd-sysv (247.3-7+deb11u6) over (247.3-7+deb11u2) ...
                Preparing to unpack .../3-libpam-systemd_247.3-7+deb11u6_arm64.deb ...
                Unpacking libpam-systemd:arm64 (247.3-7+deb11u6) over (247.3-7+deb11u2) ...
                Preparing to unpack .../4-xserver-common_2%3a1.20.11-1+rpt3+deb11u13_all.deb ...
                Unpacking xserver-common (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u6) ...
                Preparing to unpack .../5-libudev-dev_247.3-7+deb11u6_arm64.deb ...
                Unpacking libudev-dev:arm64 (247.3-7+deb11u6) over (247.3-7+deb11u4) ...
                Preparing to unpack .../6-libsystemd0_247.3-7+deb11u6_arm64.deb ...
                Unpacking libsystemd0:arm64 (247.3-7+deb11u6) over (247.3-7+deb11u2) ...
                Setting up libsystemd0:arm64 (247.3-7+deb11u6) ...
                Preparing to unpack .../0-xserver-xorg-core_2%3a1.20.11-1+rpt3+deb11u13_arm64.deb ...
                Unpacking xserver-xorg-core (2:1.20.11-1+rpt3+deb11u13) over (2:1.20.11-1+rpt3+deb11u6) ...
                Preparing to unpack .../1-systemd-timesyncd_247.3-7+deb11u6_arm64.deb ...
                Unpacking systemd-timesyncd (247.3-7+deb11u6) over (247.3-7+deb11u2) ...
                Preparing to unpack .../2-systemd_247.3-7+deb11u6_arm64.deb ...
                Unpacking systemd (247.3-7+deb11u6) over (247.3-7+deb11u2) ...
                Preparing to unpack .../3-bluez_5.55-3.1+rpt2+deb11u1_arm64.deb ...
                Unpacking bluez (5.55-3.1+rpt2+deb11u1) over (5.55-3.1+rpt2) ...
                Preparing to unpack .../4-udev_247.3-7+deb11u6_arm64.deb ...
                Unpacking udev (247.3-7+deb11u6) over (247.3-7+deb11u4) ...
                Preparing to unpack .../5-libudev1_247.3-7+deb11u6_arm64.deb ...
                Unpacking libudev1:arm64 (247.3-7+deb11u6) over (247.3-7+deb11u4) ...
                Setting up libudev1:arm64 (247.3-7+deb11u6) ...
                Preparing to unpack .../0-libglib2.0-dev_2.66.8-1+deb11u4_arm64.deb ...
                Unpacking libglib2.0-dev:arm64 (2.66.8-1+deb11u4) over (2.66.8-1) ...
                Preparing to unpack .../1-libglib2.0-dev-bin_2.66.8-1+deb11u4_arm64.deb ...
                Unpacking libglib2.0-dev-bin (2.66.8-1+deb11u4) over (2.66.8-1) ...
                Preparing to unpack .../2-libglib2.0-data_2.66.8-1+deb11u4_all.deb ...
                Unpacking libglib2.0-data (2.66.8-1+deb11u4) over (2.66.8-1) ...
                Preparing to unpack .../3-libglib2.0-bin_2.66.8-1+deb11u4_arm64.deb ...
                Unpacking libglib2.0-bin (2.66.8-1+deb11u4) over (2.66.8-1) ...
                Preparing to unpack .../4-libglib2.0-0_2.66.8-1+deb11u4_arm64.deb ...
                Unpacking libglib2.0-0:arm64 (2.66.8-1+deb11u4) over (2.66.8-1) ...
                Preparing to unpack .../5-libbsd0_0.11.3-1+deb11u1_arm64.deb ...
                Unpacking libbsd0:arm64 (0.11.3-1+deb11u1) over (0.11.3-1) ...
                Preparing to unpack .../6-libgnutls30_3.7.1-5+deb11u6_arm64.deb ...
                Unpacking libgnutls30:arm64 (3.7.1-5+deb11u6) over (3.7.1-5+deb11u3) ...
                Setting up libgnutls30:arm64 (3.7.1-5+deb11u6) ...
                Preparing to unpack .../0-mount_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking mount (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../1-nftables_0.9.8-3.1+deb11u2_arm64.deb ...
                Unpacking nftables (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
                Preparing to unpack .../2-libnftables1_0.9.8-3.1+deb11u2_arm64.deb ...
                Unpacking libnftables1:arm64 (0.9.8-3.1+deb11u2) over (0.9.8-3.1+deb11u1) ...
                Preparing to unpack .../3-bsdextrautils_2.36.1-8+deb11u2_arm64.deb ...
                Unpacking bsdextrautils (2.36.1-8+deb11u2) over (2.36.1-8+deb11u1) ...
                Preparing to unpack .../4-chromium-browser-l10n_126.0.6478.164-rpt1_all.deb ...
                Unpacking chromium-browser-l10n (126.0.6478.164-rpt1) over (113.0.5672.59-rpt1) ...
                Preparing to unpack .../5-libk5crypto3_1.18.3-6+deb11u5_arm64.deb ...
                Unpacking libk5crypto3:arm64 (1.18.3-6+deb11u5) over (1.18.3-6+deb11u3) ...
                Setting up libk5crypto3:arm64 (1.18.3-6+deb11u5) ...
                Preparing to unpack .../libkrb5support0_1.18.3-6+deb11u5_arm64.deb ...
                Unpacking libkrb5support0:arm64 (1.18.3-6+deb11u5) over (1.18.3-6+deb11u3) ...
                Setting up libkrb5support0:arm64 (1.18.3-6+deb11u5) ...
                Preparing to unpack .../libkrb5-3_1.18.3-6+deb11u5_arm64.deb ...
                Unpacking libkrb5-3:arm64 (1.18.3-6+deb11u5) over (1.18.3-6+deb11u3) ...
                Setting up libkrb5-3:arm64 (1.18.3-6+deb11u5) ...
                Preparing to unpack .../libgssapi-krb5-2_1.18.3-6+deb11u5_arm64.deb ...
                Unpacking libgssapi-krb5-2:arm64 (1.18.3-6+deb11u5) over (1.18.3-6+deb11u3) ...
                Setting up libgssapi-krb5-2:arm64 (1.18.3-6+deb11u5) ...
                Preparing to unpack .../libssl1.1_1.1.1w-0+deb11u1+rpt1_arm64.deb ...
                Unpacking libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) over (1.1.1n-0+deb11u4+rpt1) ...
                Setting up libssl1.1:arm64 (1.1.1w-0+deb11u1+rpt1) ...
                Preparing to unpack .../000-cups-daemon_2.3.3op2-3+deb11u8_arm64.deb ...
                Unpacking cups-daemon (2.3.3op2-3+deb11u8) over (2.3.3op2-3+deb11u2) ...
                Preparing to unpack .../001-cups-ipp-utils_2.3.3op2-3+deb11u8_arm64.deb ...
                Unpacking cups-ipp-utils (2.3.3op2-3+deb11u8) over (2.3.3op2-3+deb11u2) ...
                Preparing to unpack .../002-cups-common_2.3.3op2-3+deb11u8_all.deb ...
                Unpacking cups-common (2.3.3op2-3+deb11u8) over (2.3.3op2-3+deb11u2) ...
                Preparing to unpack .../003-cups-client_2.3.3op2-3+deb11u8_arm64.deb ...
                Unpacking cups-client (2.3.3op2-3+deb11u8) over (2.3.3op2-3+deb11u2) ...
                Preparing to unpack .../004-libwebp6_0.6.1-2.1+deb11u2_arm64.deb ...
                Unpacking libwebp6:arm64 (0.6.1-2.1+deb11u2) over (0.6.1-2.1) ...
                Preparing to unpack .../005-libtiff5_4.2.0-1+deb11u5_arm64.deb ...
                Unpacking libtiff5:arm64 (4.2.0-1+deb11u5) over (4.2.0-1+deb11u4) ...
                Preparing to unpack .../006-libcupsfilters1_1.28.7-1+deb11u2_arm64.deb ...
                • F Fuxsism
                  iob stop
                  iob update
                  iob upgrade self
                  iob fix
                  Dann fux dich da rein und halte das System immer auf Stand, damit das auch weiterhin 'läuft'.
                  'Never tatsch a rannink süstäm' ist jedenfalls großer Bullshit.
                  Dann erweiter es um ein gefälliges
                  sudo apt update
                  • F Fuxsism
                    iob stop
                    iob update
                    iob upgrade self
                    iob fix
                    Ja, das System schraubt jetzt die versäumten 246 Updates rein.
                    Davon wäre vermutlich ein Großteil gar nicht erforderlich, wenn du nicht da einen vollen Desktopt mit Druckerserver, Videoplayer usw. am Start hättest...
                    F W 2 Antworten Letzte Antwort
                      Fuxsism
                      und das wird nun n Tag dauern so ca??
                      • F Fuxsism
                        Ein paar Minuten wird das dauern. Wenn keine Fehler auftauchen.
                        Das ist natürlich bei 246 mit höherer Wahrscheinlichkeit möglich als auf einem schlank aufgesetzen, regelmäßig gewarteten System.
                        Du sparst dir also durch deinen 'never tatsch a ranning süstäm'-Ansatz nichts, es wird im Gegenteil nur komplexer und aufwändiger und fehleranfälliger, wenn man das Ding versumpfen lässt.
                          Fuxsism
                          ja... das Gefühl habe ich auch gerade...
                          War aber keine Absicht :-)
                            @worxweis sagte in Kann IoBroker nicht mehr aufrufen:
                            Sorry, habe jetzt die iobroker-Oberfläche nochmal ganz normal aufgerufen und sie funktioniert wieder. Auch der Admin sieht aus, als wäre er aktuell auf 1.7,2.
                            Aber auch für dich gilt:
                            Updates einspielen und den Desktop AUS!
                            Fuxsism
                            also die updates scheinen jetzt durch zu sein.
                            Da stand nun noch einmal mit iob diagnostiziert bestätigen.
                            Dabei kam nun das raus:
                            Skript v.2024-05-22
                            *** BASE SYSTEM ***
                                     Icon name: computer
                                  Architecture: arm64
                            Model		: Raspberry Pi 4 Model B Rev 1.2
                            Docker          : false
                            Virtualization  : none
                            Kernel          : aarch64
                            Userland        : 64 bit
                            Systemuptime and Load:
                             13:07:13 up  1:05,  3 users,  load average: 4.21, 3.34, 3.12
                            CPU threads: 4
                            *** RASPBERRY THROTTLING ***
                            Current issues:
                            Previously detected issues:
                            This system needs to be REBOOTED!
                            *** Time and Time Zones ***
                                           Local time: Sun 2024-09-22 13:07:13 CEST
                                       Universal time: Sun 2024-09-22 11:07:13 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** Users and Groups ***
                            User that called 'iob diag':
                            iobroker
                            HOME=/home/iobroker
                            GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth lpadmin gpio i2c spi
                            iobroker
                            HOME=/home/iobroker
                            *** Display-Server-Setup ***
                            Desktop:
                            Terminal: 	tty
                            *** MEMORY ***
                            Mem:            3.8G        1.5G        130M         35M        2.2G        2.1G
                            Swap:            99M          0B         99M
                            Total:          3.9G        1.5G        230M
                            Active iob-Instances: 	15
                                     3794 M total memory
                                     1510 M used memory
                                     1673 M active memory
                                     1684 M inactive memory
                                      130 M free memory
                                       78 M buffer memory
                                     2075 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            top - 13:07:13 up  1:05,  3 users,  load average: 4.21, 3.34, 3.12
                            Tasks: 214 total,   3 running, 211 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 23.6 us,  5.6 sy,  0.0 ni, 70.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3794.3 total,    127.4 free,   1513.4 used,   2153.5 buff/cache
                            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2122.7 avail Mem
                            *** FAILED SERVICES ***
                            0 loaded units listed.
                            *** FILESYSTEM ***
                            /dev/root      ext4       29G  7.8G   20G  29% /
                            devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                            tmpfs          tmpfs     759M  1.2M  758M   1% /run
                            /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
                            tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                            [Sun Sep 22 12:01:29 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:8E:3F:E4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=7e9f8956-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                            [Sun Sep 22 12:01:30 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
                            [Sun Sep 22 12:01:30 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
                            [Sun Sep 22 12:01:32 2024] EXT4-fs (mmcblk0p2): recovery complete
                            [Sun Sep 22 12:01:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Sun Sep 22 12:01:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                            [Sun Sep 22 12:01:34 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                            Show mounted filesystems:
                            TARGET                       SOURCE         FSTYPE          OPTIONS
                            /                            /dev/mmcblk0p2 ext4            rw,noatime
                            |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=1678472k,nr_inodes=419618,mode=755
                            | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
                            | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
                            | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
                            |-/proc                      proc           proc            rw,relatime
                            | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
                            |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
                            | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                            | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
                            | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
                            | |-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
                            | `-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
                            |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=777080k,nr_inodes=819200,mode=755
                            | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
                            | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
                            | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=388536k,nr_inodes=97134,mode=700,uid=1000,gid=1000
                            |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                            `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            1.8G	/var/
                            931M	/var/log
                            929M	/var/log/journal/365fb86da8514c2a85a61e3d210b6795
                            609M	/var/cache
                            Archived and active journals take up 928.1M in the file system.
                            /opt/iobroker/backups:
                            22M	/opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            588M	/opt/iobroker/iobroker-data/
                            520M	/opt/iobroker/iobroker-data/files
                            441M	/opt/iobroker/iobroker-data/files/javascript.admin
                            409M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                            408M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                            24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                            14M	/opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.2cca4954.js
                            10M	/opt/iobroker/iobroker-data/objects.jsonl
                            8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                            8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                            USB-Devices by-id:
                            No Devices found 'by-id'
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs 	v20.17.0
                            /usr/bin/node 		v20.17.0
                            /usr/bin/npm 		10.8.2
                            /usr/bin/npx 		10.8.2
                            /usr/bin/corepack 	0.29.3
                            nodejs:
                              Installed: 20.17.0-1nodesource1
                              Candidate: 20.17.0-1nodesource1
                              Version table:
                             *** 20.17.0-1nodesource1 1001
                                    500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                 20.16.0-1nodesource1 1001
                                 20.15.1-1nodesource1 1001
                                 20.15.0-1nodesource1 1001
                                 20.14.0-1nodesource1 1001
                                 20.13.1-1nodesource1 1001
                                 20.13.0-1nodesource1 1001
                                 20.12.2-1nodesource1 1001
                                 20.12.1-1nodesource1 1001
                                 20.12.0-1nodesource1 1001
                                 20.11.1-1nodesource1 1001
                                 20.11.0-1nodesource1 1001
                                 20.10.0-1nodesource1 1001
                                 20.9.0-1nodesource1 1001
                                 20.8.1-1nodesource1 1001
                                 20.8.0-1nodesource1 1001
                                 20.7.0-1nodesource1 1001
                                 20.6.1-1nodesource1 1001
                                 20.6.0-1nodesource1 1001
                                 20.5.1-1nodesource1 1001
                                 20.5.0-1nodesource1 1001
                                 20.4.0-1nodesource1 1001
                                 20.3.1-1nodesource1 1001
                                 20.3.0-1nodesource1 1001
                                 20.2.0-1nodesource1 1001
                                 20.1.0-1nodesource1 1001
                                 20.0.0-1nodesource1 1001
                            No problems detected
                            Errors in npm tree:
                            *** ioBroker-Installation ***
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Core adapters versions
                            js-controller: 	6.0.11
                            admin: 		7.1.2
                            javascript: 	8.7.6
                            nodejs modules from github: 	0
                            Adapter State
                            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                              system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                            + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
                            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                              system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: ::
                            + system.adapter.sonoff.1                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                            + system.adapter.sonoff.2                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                              system.adapter.sonoff.3                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                              system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                            + instance is alive
                            ioBroker-Repositories
                            Active repo(s): stable
                            Installed ioBroker-Instances
                            Used repository: stable
                            Adapter    "admin"        : 7.1.2    , installed 7.1.2
                            Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                            Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                            Adapter    "hue"          : 3.12.0   , installed 3.12.0
                            Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                            Controller "js-controller": 6.0.11   , installed 6.0.11
                            Adapter    "lgtv"         : 2.2.0    , installed 2.2.0
                            Adapter    "meross"       : 1.17.0   , installed 1.17.0
                            Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
                            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                            Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                            Adapter    "sonoff"       : 3.1.0    , installed 3.1.0
                            Adapter    "tado"         : 0.5.6    , installed 0.5.6
                            Adapter    "web"          : 6.2.5    , installed 6.2.5
                            Objects and States
                            Objects: 	6973
                            States: 	5294
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          57969      10932/sshd: /usr/sb
                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          59458      11334/cupsd
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       66609      17374/iobroker.js-c
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       66614      17374/iobroker.js-c
                            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       66890      17603/io.sonoff.1
                            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       66910      17646/io.sonoff.2
                            tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       67768      17673/io.sonoff.3
                            tcp6       0      0 :::51989                :::*                    LISTEN      1000       66747      17477/io.nuki-exten
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          57971      10932/sshd: /usr/sb
                            tcp6       0      0 :::1883                 :::*                    LISTEN      1000       66832      17553/io.sonoff.0
                            tcp6       0      0 :::8084                 :::*                    LISTEN      1000       67815      17730/io.socketio.0
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       68627      17714/io.web.0
                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          59457      11334/cupsd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14883      375/avahi-daemon: r
                            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       66843      17521/io.shelly.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15434      452/dhcpcd
                            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       64376      17492/io.mihome-vac
                            udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1000       67706      17556/io.mihome-vac
                            udp        0      0 0.0.0.0:47504           0.0.0.0:*                           108        14885      375/avahi-daemon: r
                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          61466      11453/cups-browsed
                            udp6       0      0 :::5353                 :::*                                108        14884      375/avahi-daemon: r
                            udp6       0      0 :::39079                :::*                                108        14886      375/avahi-daemon: r
                            udp6       0      0 :::546                  :::*                                0          15445      452/dhcpcd
                            2024-09-22 13:06:57.667  - info: host.iobroker instance system.adapter.discovery.0 in version "5.0.0" started with pid 17694
                            2024-09-22 13:06:57.951  - info: sonoff.3 (17673) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v20.17.0, js-controller: 6.0.11
                            2024-09-22 13:06:58.027  - info: sonoff.3 (17673) Starting MQTT authenticated  server on port 1886
                            2024-09-22 13:07:01.718  - info: host.iobroker instance system.adapter.web.0 in version "6.2.5" started with pid 17714
                            2024-09-22 13:07:01.876  - info: discovery.0 (17694) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.17.0, js-controller: 6.0.11
                            2024-09-22 13:07:05.582  - info: host.iobroker instance system.adapter.socketio.0 in version "6.7.1" started with pid 17730
                            2024-09-22 13:07:05.815  - info: web.0 (17714) starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
                            2024-09-22 13:07:06.316  - info: web.0 (17714) socket.io server listening on port 8082
                            2024-09-22 13:07:06.327  - info: web.0 (17714) http server listening on port 8082
                            2024-09-22 13:07:08.788  - info: socketio.0 (17730) starting. Version 6.7.1 in /opt/iobroker/node_modules/iobroker.socketio, node: v20.17.0, js-controller: 6.0.11
                            2024-09-22 13:07:08.881  - info: socketio.0 (17730) socket.io server listening on port 8084
                            2024-09-22 13:07:09.565  - info: host.iobroker instance system.adapter.tado.0 in version "0.5.6" started with pid 17760
                            2024-09-22 13:07:13.576  - info: tado.0 (17760) starting. Version 0.5.6 in /opt/iobroker/node_modules/iobroker.tado, node: v20.17.0, js-controller: 6.0.11
                            2024-09-22 13:07:13.611  - info: tado.0 (17760) Started with JSON-Explorer version 0.1.16
                            2024-09-22 13:07:14.263  - info: tado.0 (17760) Connected to Tado cloud, initialyzing...
                            2024-09-22 13:07:20.929  - info: tado.0 (17760) Initialisation finished, connected to Tado cloud service refreshing every 30 seconds
                            2024-09-22 13:07:49.273  - info: alexa2.0 (17447) No smart home devices to query
                            2024-09-22 13:07:52.362  - info: javascript.0 (17395) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
                            2024-09-22 13:07:52.363  - info: javascript.0 (17395) script.js.Hue_Push: {"light":{"light_level":18437,"light_level_report":{"changed":"2024-09-22T11:07:52.269Z","light_level":18437}},"owner":{"rid":"29e5dd1b-dce7-41dc-8f39-1e6205527c74","rtype":"device"}}
                            2024-09-22 13:07:50.997  - info: alexa2.0 (17447) Subscribing to states...
                            2024-09-22 13:07:51.004  - info: alexa2.0 (17447) Deleting the following states: ["Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#enabled","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#delete","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.powerState","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.connectivity-reason","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#query","Smart-Home-Devices.9a149c71-2334-4f37-ba0a-191ce6da7cb7.#includeInAllQuery","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#enabled","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#delete","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.powerState","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.connectivity-reason","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#query","Smart-Home-Devices.57550b1c-5943-4d84-9324-307a61cd0c13.#includeInAllQuery","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#enabled","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#delete","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.powerState","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.connectivity-reason","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#query","Smart-Home-Devices.aae785aa-8a9e-422e-8266-ddb3e80d836b.#includeInAllQuery","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#enabled","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#delete","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.powerState","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.connectivity-reason","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#query","Smart-Home-Devices.73c1f150-8997-4752-bf73-9b687e46cf99.#includeInAllQuery","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#enabled","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#delete","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.powerState","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.connectivity-reason","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#query","Smart-Home-Devices.30cb7c91-b1be-4228-a814-804cb8cc0a0a.#includeInAllQuery","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#enabled","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#delete","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.powerState","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.connectivity-reason","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#query","Smart-Home-Devices.3d78131d-adfc-42f1-a9ff-d485ca5769a5.#includeInAllQuery","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#enabled","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#delete","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.powerState","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.connectivity-reason","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#query","Smart-Home-Devices.b408872e-a06b-430a-ac61-2db625a35858.#includeInAllQuery","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#enabled","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#delete","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.powerState","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.connectivity-reason","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#query","Smart-Home-Devices.3c2026ad-2e95-4955-8b1e-b5a2b87978aa.#includeInAllQuery","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#enabled","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#delete","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.powerState","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.brightness","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.connectivity-reason","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#query","Smart-Home-Devices.b08a9684-6542-46aa-989c-b14b406faa27.#includeInAllQuery","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#enabled","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#delete","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.powerState","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.brightness","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.connectivity-reason","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#query","Smart-Home-Devices.bdbbb442-2579-42b6-9c8f-5cc8cbbb4457.#includeInAllQuery","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#enabled","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#delete","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.powerState","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.connectivity-reason","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#query","Smart-Home-Devices.0c3b5822-3998-42d3-8064-3e443f575a10.#includeInAllQuery","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#enabled","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#delete","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.powerState","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.connectivity-reason","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#query","Smart-Home-Devices.18337ae9-f949-4b40-8959-e7e9397ceb83.#includeInAllQuery","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#enabled","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#delete","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.powerState","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.connectivity-reason","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#query","Smart-Home-Devices.2db89f87-9eae-4c24-b003-e28b07d27c76.#includeInAllQuery","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#enabled","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#delete","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.powerState","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.connectivity-reason","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#query","Smart-Home-Devices.9d6f241d-e347-4c1b-94b6-009bd35cb597.#includeInAllQuery","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#enabled","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#delete","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.powerState","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.connectivity-reason","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#query","Smart-Home-Devices.010add55-37cc-48b4-b43b-7cc065f12ccb.#includeInAllQuery"]
                            2024-09-22 13:07:55.951  - info: alexa2.0 (17447) Alexa-Push-Connection (macDms = true) established. Disable Polling
                            2024-09-22 13:08:06.251  - info: alexa2.0 (17447) Initialization Done ...
                            2024-09-22 13:08:06.703  - info: javascript.0 (17395) script.js.Hue_Push: missing update instructions for sensors.light.light_level_report
                            2024-09-22 13:08:06.704  - info: javascript.0 (17395) script.js.Hue_Push: {"light":{"light_level":10401,"light_level_report":{"changed":"2024-09-22T11:08:06.609Z","light_level":10401}},"owner":{"rid":"0045d363-a198-4f59-a8b4-8281aac23ba4","rtype":"device"}}
                            • F Offline
                              Fuxsism
                              			v.2024-05-22
                                       Icon name: computer
                                    Architecture: arm64
                              Kernel: 		aarch64
                              Userland: 		64 bit
                              User-ID: 		1000
                              Pending OS-Updates: 	0
                              This system needs to be REBOOTED NOW!
                              /usr/bin/npm 		10.8.2
                              /usr/bin/npx 		10.8.2
                              MEMORY:
                              Mem:            3.8G        1.3G        409M         35M        2.1G        2.4G
                              Swap:            99M          0B         99M
                              Total:          3.9G        1.3G        509M
                              			admin 			7.1.2
                              Objects type: jsonl
                              States  type: jsonl
                              Objects: 		6973
                              States: 		5294
                              12M	/opt/iobroker/iobroker-data/objects.jsonl
                              8.0M	/opt/iobroker/iobroker-data/states.jsonl
                              Was mache ich denn nun?
                              • F Fuxsism
                                			v.2024-05-22
                                         Icon name: computer
                                      Architecture: arm64
                                Kernel: 		aarch64
                                Userland: 		64 bit
                                User-ID: 		1000
                                /usr/bin/npm 		10.8.2
                                /usr/bin/npx 		10.8.2
                                MEMORY:
                                Swap:            99M          0B         99M
                                			admin 			7.1.2
                                Objects type: jsonl
                                States  type: jsonl
                                Objects: 		6973
                                States: 		5294
                                @fuxsism
                                Mach das!
                                iob stop
                                sudo reboot
                                  @fuxsism
                                  Mach das!
                                  iob stop
                                  sudo reboot
                                  Fuxsism
                                  hab ich gemacht...
                                  dann neu auf der Konsole anmelden?
                                  • F Fuxsism
                                    hab ich gemacht...
                                    Ja, und dann einen frischen Lauf von
                                    iob diag
                                    • F Offline
                                      Fuxsism
                                      nach erneuter Anmeldung per Terminal:
                                      iobroker@iobroker:~ $ Connection to iobroker closed by remote host.
                                      Connection to iobroker closed.
                                      fuxism@MBP-von-Michael ~ % ssh iobroker@iobroker
                                      iobroker@iobroker's password:
                                      Linux iobroker 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr  3 17:24:16 BST 2023 aarch64
                                      permitted by applicable law.
                                      Last login: Sun Sep 22 13:11:31 2024
                                      Wi-Fi is currently blocked by rfkill.
                                      Use raspi-config to set the country before use.
                                      -bash: source: /home/iobroker/.iobroker/iobroker_completions: Kann die Datei nicht ausführen.
                                      • F Offline
                                        Fuxsism
                                        wenn ich Job Diagnose starte kommt das:
                                        The state system.host.iobroker.versions.nodeNewestNext was not found!
                                        The state system.host.iobroker.versions.npmNewestNext was not found!
                                        The state system.host.iobroker.versions.nodeCurrent was not found!
                                        • F Fuxsism
                                          @fuxsism
                                          Man meldet sich ja auch nicht als user 'iobroker' sondern mit seinem richtigen Login an.
